  4. Smartmeter: D0 Einstellungen ?
111 Beiträge 6 Kommentatoren 13.3k Aufrufe 3 Beobachtet
    @mathiasl sagte in Smartmeter: D0 Einstellungen ?:
    Opera
    ist nicht so richtig kompatibel.
    Nach Browseraktualisierung steht das Feld nicht mehr auf Benutzerdefiniert
    dann gib mal die Langfassung von iob diag
    MathiasL
    @Homoran
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspi-IOB
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     22:07:40 up 30 min,  1 user,  load average: 0.15, 0.55, 0.37
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2024-02-15 22:07:40 CET
               Universal time: Thu 2024-02-15 21:07:40 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        614M        2.7G        8.0M        543M        3.1G
    Swap:           99M          0B         99M
    Total:         3.9G        614M        2.8G
             3838 M total memory
              614 M used memory
              282 M active memory
              778 M inactive memory
             2680 M free memory
               87 M buffer memory
              456 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       15G  8.6G  5.2G  63% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Thu Feb 15 21:36:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:8D:7F:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=400f6d20-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Thu Feb 15 21:36:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Feb 15 21:36:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Feb 15 21:36:48 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    832M    /var/cache
    827M    /var/cache/apt
    767M    /var/cache/apt/archives
    93M     /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    63M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    697M    /opt/iobroker/iobroker-data/
    541M    /opt/iobroker/iobroker-data/files
    162M    /opt/iobroker/iobroker-data/files/vis-2
    120M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/vis-2/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.34d14c04.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0081-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi-IOB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.awtrix-light.0           : awtrix-light          : raspi-IOB                                -  enabled
      system.adapter.backitup.0               : backitup              : raspi-IOB                                - disabled
      system.adapter.daswetter.0              : daswetter             : raspi-IOB                                -  enabled
      system.adapter.device-reminder.0        : device-reminder       : raspi-IOB                                - disabled
      system.adapter.devices.0                : devices               : raspi-IOB                                -  enabled
    + system.adapter.discovery.0              : discovery             : raspi-IOB                                -  enabled
      system.adapter.dwd.0                    : dwd                   : raspi-IOB                                - disabled
      system.adapter.ekey.0                   : ekey                  : raspi-IOB                                - disabled, port: 56000, bind: 0.0.0.0
      system.adapter.feiertage.0              : feiertage             : raspi-IOB                                -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : raspi-IOB                                -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspi-IOB                                - disabled
      system.adapter.ical.0                   : ical                  : raspi-IOB                                -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi-IOB                                -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi-IOB                                -  enabled
    + system.adapter.javascript.0             : javascript            : raspi-IOB                                -  enabled
      system.adapter.knx.0                    : knx                   : raspi-IOB                                - disabled, bind: 192.168.0.205
      system.adapter.modbus.0                 : modbus                : raspi-IOB                                - disabled
      system.adapter.net-tools.0              : net-tools             : raspi-IOB                                - disabled
      system.adapter.openknx.0                : openknx               : raspi-IOB                                - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspi-IOB                                -  enabled
      system.adapter.sayit.0                  : sayit                 : raspi-IOB                                - disabled
    + system.adapter.smartmeter.0             : smartmeter            : raspi-IOB                                -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspi-IOB                                -  enabled
    + system.adapter.telegram.0               : telegram              : raspi-IOB                                -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : raspi-IOB                                - disabled, port: 8088, bind: 192.168.0.205, run as: admin
      system.adapter.time-switch.0            : time-switch           : raspi-IOB                                - disabled
    + system.adapter.trashschedule.0          : trashschedule         : raspi-IOB                                -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspi-IOB                                -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi-IOB                                -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi-IOB                                -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspi-IOB                                -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi-IOB                                -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi-IOB                                -  enabled
      system.adapter.vis-material.0           : vis-material          : raspi-IOB                                -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspi-IOB                                -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspi-IOB                                -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi-IOB                                -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspi-IOB                                -  enabled
      system.adapter.vis.0                    : vis                   : raspi-IOB                                -  enabled
    + system.adapter.web.0                    : web                   : raspi-IOB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : raspi-IOB                                - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Ulanzi Uhr BETA: https://github.com/klein0r/ioBroker.awtrix-light.git
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "awtrix-light" : 0.13.1   , installed 0.13.1
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "ekey"         : 1.2.3    , installed 1.2.3
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullcalendar" : 2.3.4    , installed 2.3.4
    Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
    Adapter    "ical"         : 1.13.3   , installed 1.13.5
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "knx"          : 2.0.24   , installed 2.0.24
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "openknx"      : 0.6.3    , installed 0.7.0
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        4710
    States:         4186
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 12
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17523      568/sshd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16942      573/iobroker.js-con
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16048      569/redis-server 12
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16202      594/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19679      856/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17525      568/sshd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16049      569/redis-server 12
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14945      561/dhcpcd
    udp        0      0 0.0.0.0:32931           0.0.0.0:*                           108        14812      389/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14810      389/avahi-daemon: r
    udp6       0      0 :::53256                :::*                                108        14813      389/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14811      389/avahi-daemon: r
    2024-02-15 22:00:06.928  - info: ical.0 (1826) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
    2024-02-15 22:00:07.704  - info: ical.0 (1826) processing URL: Abfuhrkalender.ics http://cloud.msl-data.de/
    2024-02-15 22:00:07.948  - info: daswetter.0 (1811) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-02-15 22:00:08.468  - info: daswetter.0 (1811) cleaned everything up...
    2024-02-15 22:00:08.485  - info: host.raspi-IOB instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-15 22:00:10.013  - info: ical.0 (1826) processing URL: Abfuhrkalender.ics https://46.128.125.220/nas/filelink.lua?id=31b695d5fa878f05
    2024-02-15 22:00:15.157  - info: ical.0 (1826) Terminated (NO_ERROR): Without reason
    2024-02-15 22:00:15.706  - info: host.raspi-IOB instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-02-15 22:01:25.311  - debug: smartmeter.0 (1499) MESSAGE TIMEOUT TRIGGERED
    2024-02-15 22:01:25.312  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
    2024-02-15 22:01:25.312  - warn: smartmeter.0 (1499) No or too long answer from Serial Device after last request.
    2024-02-15 22:01:25.313  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
    2024-02-15 22:01:25.313  - debug: smartmeter.0 (1499) Transport Reset!! Restart = true
    2024-02-15 22:01:25.319  - debug: smartmeter.0 (1499) SERIALPORT CLOSE
    2024-02-15 22:01:25.320  - debug: smartmeter.0 (1499) SCHEDULE NEXT RUN IN 300s
    2024-02-15 22:06:25.320  - debug: smartmeter.0 (1499) CREATE SERIALPORT: 9600 8 1 none
    2024-02-15 22:06:25.327  - debug: smartmeter.0 (1499) SERIALPORT OPEN
    2024-02-15 22:06:25.329  - debug: smartmeter.0 (1499) SET MESSAGE TIMEOUT TIMER: 120000
    2024-02-15 22:08:25.329  - debug: smartmeter.0 (1499) MESSAGE TIMEOUT TRIGGERED
    2024-02-15 22:08:25.330  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
    2024-02-15 22:08:25.331  - warn: smartmeter.0 (1499) No or too long answer from Serial Device after last request.
    2024-02-15 22:08:25.332  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
    2024-02-15 22:08:25.333  - debug: smartmeter.0 (1499) Transport Reset!! Restart = true
    2024-02-15 22:08:25.348  - debug: smartmeter.0 (1499) SERIALPORT CLOSE
    2024-02-15 22:08:25.348  - debug: smartmeter.0 (1499) SCHEDULE NEXT RUN IN 300s
      buster
      Aber auch diese Zusammfassung zeigt, dass du da ein totes Pferd reitest.
      Absteigen...
      Neuinstallatioin von Raspberry OS 12 'Bookworm' in der 64 Bit-Lite-Version.
      MathiasL
      Ist eben noch die Testumgebung
      Davon abgesehen habe ich als Nicht-Linux-Mensch so meine Probleme:
      Ich müsste jetzt ein Backup vom IOB machen und auf der neuen OS einspielen, davor drück ich mich gerade noch...
      • M MathiasL
        Und wie sinnvoll sind Test in einer veralteten, abgekündigten Umgebung?
        Und genau DAS solltest du als erstes tun. Auf einer stabilen Basis kannste dann weiter testen...
          MathiasL
          Das sollte dann eigentlich keine Testumgebung mehr werden.
          Ich denke auch nicht, dass das was daran ändert, warum ich keine Daten vom Zähler bekomme.
          • M MathiasL
            Das spielt aber auch keine Rolle...
              MathiasL
              Ich bin ja gerade dabei ein Image zu schreiben ;)
              Muss halt nur die ganzen Daten vom IOB aufs neue Image bringen (...und da ich kaum Linux kann, stellt mich das vor einige Probleme)
              • M MathiasL
                Mit dem Backitup-Adapter. Linuxisch muss man dafür auch nicht können.
                M 3 Antworten Letzte Antwort
                  MathiasL
                  OK. Arbeite mich gerade durch Deine Upgrade-Anleitung
                    MathiasL
                    Keine Angst, ich mache eine komplette Neuinstallation, dient nur dem Lernen von Linux
                    • M MathiasL
                      @mathiasl
                      Hab ich was von dist-upgrade geschrieben?
                      Du musst das NEU installieren.
                        @mathiasl
                        MathiasL
                        Ja, mach ich doch auch. Das wird ein komplett neues Image.
                        Ist trotzdem lehrreich, das Vorgehen zu einem Upgrade durchzulesen
                          MathiasL
                          ...Der übrigens nicht richtig funktioniert.
                          • M MathiasL
                            Natürlich nicht. Ein Dist-Upgrade auf Raspbian 12 von Vorversionen aus funktioniert bekanntermaßen nicht, weswegen ich dir auch gleich zu einer Neuinstallation geraten habe...
                              MathiasL
                              Wenn du gelesen hättest, wüsstest Du, dass ich mir das Dist-Upgrade-Verfahre aus reinem Interesse durchgelesen habe, um Hintergrundabläufe unter Linux zu verstehen (Befehle, Repos einbinden, usw).
                              Ich habe sehr wohl eine Neuinstallation gemacht.
                              Leider ist 'Backitup' trotzdem fehlerhaft und unvollständig... Und eine Rücksicherung bis dato unmöglich...
                              Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                              • M MathiasL
                                Hab ich.
                                Muss aber an dir liegen, hier funktioniert das nämlich.
                                • M MathiasL
                                  wendy2702W Online
                                  wendy2702W Online
                                  @mathiasl was funktioniert denn nicht bei der Rücksicherung?
                                  Wenn du die alte SD Karte oder was auch immer noch hast kannst du ja auch mal ein Backup ohne Adapter machen und versuchen das wieder herzustellen.
                                    Hab ich.
                                    MathiasL
                                    #66
                                    So Fehler wie: Weisser Text auf weissem Grund liegen also an mir? Sowohl im Firefox als auch im Opera kann das Problem auftreten, das man keine Texte mehr sieht.
                                    • Update mit ssh war bisher nicht möglich, da das Zertifikat ungültig ist
                                    • Update ohne ssh geht soweit, das man die Datei direkt runterladen kann, beim raufladen werden aber vom IOB Sachen zerschossen, hier teste ich aber noch.
                                    Das gehört aber eigentlich alles nicht hier her. Es ging ja um die Einbindung des Smartmeter
                                    Thomas BraunT wendy2702W HomoranH 3 Antworten Letzte Antwort
                                    • M MathiasL
                                      #67
                                      Nee, deine offenbar hinten und vorne verfummelte Kiste gehört hier nicht hin.
                                      • M MathiasL
                                        wendy2702W Online
                                        wendy2702W Online
                                        #68
                                        @mathiasl wo steht denn was von weißem Text auf weißem Grund?
                                        Und was wird wie beim Kopieren zerschossen?
                                        Aber wie du selber schon geschrieben hast dafür besser ein neues Thema aufmachen und dann am besten mit Logausgaben zeigen was du machst und was dann nicht funktioniert
                                        • M MathiasL
                                          HomoranH Offline
                                          HomoranH Offline
                                          #69
                                          wo wurde dieser Fehler bisher beschrieben?
                                          die anderen Punkte lasse ich erst malweg, denn mit
                                          gehört es ja doch hierher, wenn aus irgendeinem Grund etwas nicht korrekt installiert ist, dass es zu fehlendem/falschen Zertifikat führt, dann kann da noch mehr schief sein, dass auch die Grafik oder die Kommunikation mit dem Lesekopf betroffen ist.
                                          Auch wenn ich was den Lesekopf angeht nach wie vor befürchte dass die Dioeen zu schwach sind, solange wir bicht einmal etwas segen, was der Zähler ausspuckt
