  4. Smartmeter: D0 Einstellungen ?
111 Beiträge 6 Kommentatoren 13.3k Aufrufe 3 Beobachtet
  • M MathiasL
    Auch kein Effekt:
    SML, USB0, 9600 baud, 8n1
    HomoranH Offline
    HomoranH Offline
    @mathiasl bitte due Einstellungen zeigen!
    • M MathiasL
      ich habe versucht Smartmeter einzurichten, bin aber kläglich gescheitert. Wenn ich es richtig verstehe, benötige ich im D0-Protokoll Modus E...?
      Zähler: Logarex LK13BE
      IR-Kopf: Hichi, USB, (IC CP2102)
      Anschluss am USB0 am IOB-Raspberry, alles Aktuell
      Log Beim Start vom Smartmeter:
      2024-02-14 18:39:59.570 - info: host.raspi-IOB stopInstance system.adapter.smartmeter.0 (force=false, process=true)
      2024-02-14 18:39:59.575 - info: host.raspi-IOB stopInstance system.adapter.smartmeter.0 send kill signal
      2024-02-14 18:39:59.575 - info: smartmeter.0 (4963) Got terminate signal TERMINATE_YOURSELF
      2024-02-14 18:39:59.580 - info: smartmeter.0 (4963) terminating
      2024-02-14 18:39:59.584 - info: smartmeter.0 (4963) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-02-14 18:40:00.087 - info: smartmeter.0 (4963) terminating
      2024-02-14 18:40:00.199 - info: host.raspi-IOB instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-02-14 18:40:02.728 - info: host.raspi-IOB instance system.adapter.smartmeter.0 started with pid 5447
      2024-02-14 18:40:04.965 - info: smartmeter.0 (5447) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-02-14 18:40:05.110 - info: smartmeter.0 (5447) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 18:40:35.582 - info: smartmeter.0 (5447) Error: No or too long answer from Serial Device after last request.
      2024-02-14 18:40:35.587 - warn: smartmeter.0 (5447) No or too long answer from Serial Device after last request.
      Lt. Wiki-Volkszähler:
      benötigt der Zähler anscheinend folgende Einstellungen (im vzlogger):
      "protocol": "d0",
               "device": "/dev/ttyUSB0",
               "pullseq": "2F3F210D0A",
               "ackseq": "063030300D0A",
               "baudrate": 300,
               "parity": "7E1",
               "read_timeout": 10,
               "interval": 1,
      Also senden der pullseq, auf Antwort warten dann senden der ackseq und dann bekomme ich Zählerdaten zurück.
      Sehe ich das richtig? Wie binde ich den Zähler dann ein? Ist im Smartmeter ja nicht vorgesehen, Codes zu senden?
      HomoranH Offline
      HomoranH Offline
      @mathiasl sagte in Smartmeter: D0 Einstellungen ?:
      welches Modell genau?
      wie alt?
        wie alt?
        MathiasL
        Logarex LK13BE803039, BJ: 2018
        So sieht es aus, wenn ich nur das Protokoll und den USB auswähle...
        GlasfaserG HomoranH 2 Antworten Letzte Antwort
        • M MathiasL
          GlasfaserG Offline
          GlasfaserG Offline
          Hier der gleiche ..Lesekopf . vielleicht hilft es dir :
          https://forum.iobroker.net/post/1041297
          • M MathiasL
            HomoranH Offline
            HomoranH Offline
            da müsste man noch einmal nachsehen. Damals gab es tatsächlich Modelle mit SML.
            Aber viel schlimmer wird sein, dass bei Logarex die IR Dioden schnell altern und bei 6 Jahren wahrscheinlich gar nichts mehr ausgeben.
            die Einstellungen von dem Link unterscheiden sich nur in der Schnittstelle.
            dort nicht direkt /dev/serial... einfeben, sondern benutzerdefinierte
            • GlasfaserG Glasfaser
              MathiasL
              @glasfaser
              Ich kann höchstens noch den IR umdrehen, oder etwas Abstand schaffen.
              Allerdings frage ich mich auch, ob der Zähler noch von der Aktivierung per Pin weiss... Ich habe das Gefühl, der schaltet sich nach ein paar Minute wieder auf Inaktiv - Und nein, die Anzeige im Zähler ist da keine Hilfe. Geht schon los damit, das der Taster zum Pin eingeben hakt und immer wieder eine Ziffer weiter springt, weil er deinen doppelten Klick bekommt, weshalb ich die Pin immer 5x eingeben darf...
              • GlasfaserG Offline
                GlasfaserG Offline
                @mathiasl
                Das ist aber jetzt keine Antwort zu meinem Link !?
                Hast du die Instanz nach der Vorlage im beigestellten Link auch jetzt so eingestellt bzw. den Thread gelesen !?
                  MathiasL
                  Na super...
                  Hab den Pfad via Benutzerdefiniert eingegeben, kein Erfolg.
                  Eigentlich müsste der Zähler aber was rausschmeissen, hab noch einen IR-Kopf der RX / TX LED hat, die blinkern beide beim Aufsetzen des Kopfes
                  • M MathiasL
                    Na super...
                    HomoranH Offline
                    HomoranH Offline
                    Na super...
                    ja nach 5 Minuten
                    sonst nimm mal sml
                    und stell die Logstufe der Instanz auf debug
                      @mathiasl
                      MathiasL
                      @glasfaser
                      Naja, die Einstellungen hab ich Im Smartmeter auch.
                      Wie ich am Stromzähler noch irgendwas einstellen soll, ausser Eingabe der Pin, wüsste ich nicht.
                      Nach Eingabe stellt der Zähler kurz die Anzeige auf momentanen Verbrauch, ab dem Zeitpunkt sollte er senden.
                      Ich müsste mir sonst die Tschechische Herstelleranleitung übersetzen...
                        Na super...
                        ja nach 5 Minuten
                        sonst nimm mal sml
                        MathiasL
                        Ich geb erst noch mal die Pin ein, das kann dauern...
                        • M MathiasL
                          @glasfaser
                          HomoranH Offline
                          HomoranH Offline
                          üblicherweise müsste in einem der nächsten Menüpunkte noch INF auf on gestellt werden.
                          M 2 Antworten Letzte Antwort
                            MathiasL
                            Ich mach das 'gerne' noch mal. Aber direkt nach Eingabe der Pin erscheint:
                            info
                            p: xxxx w
                            im Display
                              MathiasL
                              Stunden später:
                              Es gibt ein Menü, nach Eingabe der Pin, leider wird das aufgrund des anscheinend leicht defekten Tasters nur manchmal angezeigt. Wenn ich INFO auf ON stelle, Geht er wieder zur Pin.
                              Muss die dann noch mal eingegeben werden? Funktioniert leider nicht wirklich, da er sofort auf die 2te Ziffer springt...
                              Demnächst klopp ich das Ding von der Wand.... :(
                              • M MathiasL
                                Stunden später:
                                MathiasL
                                @mathiasl
                                Was ich noch gemacht habe:
                                • 5mm Abstand zw IR-Kopf und Zähler geschaffen
                                • Ausrichtung der LEDs geprüft: Transparent auf schwarz - Ist also OK
                                • M MathiasL
                                  @mathiasl
                                  MathiasL
                                  @mathiasl
                                  Versuche gleich noch mal ins Menü zu kommen und die Pin auf OFF zu schalten...
                                  • M MathiasL
                                    @mathiasl
                                    MathiasL
                                    @mathiasl
                                    Ich wechsel noch mal den USB-Port am Raspi...
                                    Pin im Menü ist OFF
                                    Info im Menü ist ON
                                    Ändert nix
                                    • M MathiasL
                                      @mathiasl
                                      Pin im Menü ist OFF
                                      Info im Menü ist ON
                                      Ändert nix
                                      wendy2702W Online
                                      wendy2702W Online
                                      @mathiasl hast du mal ohne aktiven Smartmeter Adapter geschaut ob der Lesekopf Daten empfängt?
                                      Wurde der Lesekopf richtig erkannt im System?
                                      • wendy2702W wendy2702
                                        MathiasL
                                        @wendy2702
                                        kenne mich mit Linux leider nicht gut aus. Komme vom PC...
                                        Wollte das Teil sonst mal an den Laptop hängen. Ich hab leider auch nix zum IR-Daten senden (ausser Fernbedienung TV)
                                          MathiasL
                                          @wendy2702
                                          Hab auf beide Seiten (IR-Kopf und auch Zähler) Handykamera gehalten. Auf beiden Seiten blinken die Sende-LEDs.
                                          Also, senden tut beides physikalisch.
