  4. Smartmeter: D0 Einstellungen ?
111 Beiträge 6 Kommentatoren 13.3k Aufrufe 3 Beobachtet
    MathiasL
    ich habe versucht Smartmeter einzurichten, bin aber kläglich gescheitert. Wenn ich es richtig verstehe, benötige ich im D0-Protokoll Modus E...?
    Zähler: Logarex LK13BE
    IR-Kopf: Hichi, USB, (IC CP2102)
    Anschluss am USB0 am IOB-Raspberry, alles Aktuell
    Log Beim Start vom Smartmeter:
    2024-02-14 18:39:59.570 - info: host.raspi-IOB stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2024-02-14 18:39:59.575 - info: host.raspi-IOB stopInstance system.adapter.smartmeter.0 send kill signal
    2024-02-14 18:39:59.575 - info: smartmeter.0 (4963) Got terminate signal TERMINATE_YOURSELF
    2024-02-14 18:39:59.580 - info: smartmeter.0 (4963) terminating
    2024-02-14 18:39:59.584 - info: smartmeter.0 (4963) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-02-14 18:40:00.087 - info: smartmeter.0 (4963) terminating
    2024-02-14 18:40:00.199 - info: host.raspi-IOB instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-14 18:40:02.728 - info: host.raspi-IOB instance system.adapter.smartmeter.0 started with pid 5447
    2024-02-14 18:40:04.965 - info: smartmeter.0 (5447) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2024-02-14 18:40:05.110 - info: smartmeter.0 (5447) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.19.0, js-controller: 5.0.17
    2024-02-14 18:40:35.582 - info: smartmeter.0 (5447) Error: No or too long answer from Serial Device after last request.
    2024-02-14 18:40:35.587 - warn: smartmeter.0 (5447) No or too long answer from Serial Device after last request.
    Lt. Wiki-Volkszähler:
    benötigt der Zähler anscheinend folgende Einstellungen (im vzlogger):
    "protocol": "d0",
             "device": "/dev/ttyUSB0",
             "pullseq": "2F3F210D0A",
             "ackseq": "063030300D0A",
             "baudrate": 300,
             "parity": "7E1",
             "read_timeout": 10,
             "interval": 1,
    Also senden der pullseq, auf Antwort warten dann senden der ackseq und dann bekomme ich Zählerdaten zurück.
    Sehe ich das richtig? Wie binde ich den Zähler dann ein? Ist im Smartmeter ja nicht vorgesehen, Codes zu senden?
    • M MathiasL
      "protocol": "d0",
               "baudrate": 300,
               "parity": "7E1",
               "read_timeout": 10,
               "interval": 1,
      HomoranH Offline
      HomoranH Offline
      @mathiasl sagte in Smartmeter: D0 Einstellungen ?:
      macht alles der Adapter unter der Haube
      erstmal alle Einstellungen auf default lassen und nur das Protokoll auswählen und die Schnittstelle definieren
      M 2 Antworten Letzte Antwort
        MathiasL
        Hab Smartmeter neu installiert.
        Nur die Schnittstelle ausgewählt, das D0-Protokoll gewählt, 300 baud, 7e1
        Rest: Leer (also alle D0 Einstellungen)
        Kein Effekt. Gleiches Log.
        Preobiere jetzt noch mal SML...
        • M MathiasL
          HomoranH Offline
          HomoranH Offline
          , 300 baud, 7e1
          nicht eintragen!
          bitte Konfig zeigen
            MathiasL
            Auch kein Effekt:
            SML, USB0, 9600 baud, 8n1
            • M MathiasL
              Auch kein Effekt:
              HomoranH Offline
              HomoranH Offline
              @mathiasl bitte due Einstellungen zeigen!
              • M MathiasL
                "protocol": "d0",
                         "baudrate": 300,
                         "parity": "7E1",
                         "read_timeout": 10,
                         "interval": 1,
                HomoranH Offline
                HomoranH Offline
                welches Modell genau?
                wie alt?
                  wie alt?
                  MathiasL
                  Logarex LK13BE803039, BJ: 2018
                  So sieht es aus, wenn ich nur das Protokoll und den USB auswähle...
                  GlasfaserG HomoranH 2 Antworten Letzte Antwort
                  • M MathiasL
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Hier der gleiche ..Lesekopf . vielleicht hilft es dir :
                    https://forum.iobroker.net/post/1041297
                    • M MathiasL
                      HomoranH Offline
                      HomoranH Offline
                      da müsste man noch einmal nachsehen. Damals gab es tatsächlich Modelle mit SML.
                      Aber viel schlimmer wird sein, dass bei Logarex die IR Dioden schnell altern und bei 6 Jahren wahrscheinlich gar nichts mehr ausgeben.
                      die Einstellungen von dem Link unterscheiden sich nur in der Schnittstelle.
                      dort nicht direkt /dev/serial... einfeben, sondern benutzerdefinierte
                      • GlasfaserG Glasfaser
                        MathiasL
                        @glasfaser
                        Ich kann höchstens noch den IR umdrehen, oder etwas Abstand schaffen.
                        Allerdings frage ich mich auch, ob der Zähler noch von der Aktivierung per Pin weiss... Ich habe das Gefühl, der schaltet sich nach ein paar Minute wieder auf Inaktiv - Und nein, die Anzeige im Zähler ist da keine Hilfe. Geht schon los damit, das der Taster zum Pin eingeben hakt und immer wieder eine Ziffer weiter springt, weil er deinen doppelten Klick bekommt, weshalb ich die Pin immer 5x eingeben darf...
                        • GlasfaserG Offline
                          GlasfaserG Offline
                          @mathiasl
                          Das ist aber jetzt keine Antwort zu meinem Link !?
                          Hast du die Instanz nach der Vorlage im beigestellten Link auch jetzt so eingestellt bzw. den Thread gelesen !?
                            MathiasL
                            Na super...
                            Hab den Pfad via Benutzerdefiniert eingegeben, kein Erfolg.
                            Eigentlich müsste der Zähler aber was rausschmeissen, hab noch einen IR-Kopf der RX / TX LED hat, die blinkern beide beim Aufsetzen des Kopfes
                            • M MathiasL
                              Na super...
                              HomoranH Offline
                              HomoranH Offline
                              Na super...
                              ja nach 5 Minuten
                              sonst nimm mal sml
                              und stell die Logstufe der Instanz auf debug
                                @mathiasl
                                MathiasL
                                @glasfaser
                                Naja, die Einstellungen hab ich Im Smartmeter auch.
                                Wie ich am Stromzähler noch irgendwas einstellen soll, ausser Eingabe der Pin, wüsste ich nicht.
                                Nach Eingabe stellt der Zähler kurz die Anzeige auf momentanen Verbrauch, ab dem Zeitpunkt sollte er senden.
                                Ich müsste mir sonst die Tschechische Herstelleranleitung übersetzen...
                                  Na super...
                                  ja nach 5 Minuten
                                  sonst nimm mal sml
                                  MathiasL
                                  Ich geb erst noch mal die Pin ein, das kann dauern...
                                  • M MathiasL
                                    @glasfaser
                                    HomoranH Offline
                                    HomoranH Offline
                                    üblicherweise müsste in einem der nächsten Menüpunkte noch INF auf on gestellt werden.
                                      MathiasL
                                      Ich mach das 'gerne' noch mal. Aber direkt nach Eingabe der Pin erscheint:
                                      info
                                      p: xxxx w
                                      im Display
                                        MathiasL
                                        Stunden später:
                                        Es gibt ein Menü, nach Eingabe der Pin, leider wird das aufgrund des anscheinend leicht defekten Tasters nur manchmal angezeigt. Wenn ich INFO auf ON stelle, Geht er wieder zur Pin.
                                        Muss die dann noch mal eingegeben werden? Funktioniert leider nicht wirklich, da er sofort auf die 2te Ziffer springt...
                                        Demnächst klopp ich das Ding von der Wand.... :(
                                        • M MathiasL
                                          Stunden später:
                                          MathiasL
                                          @mathiasl
                                          Was ich noch gemacht habe:
                                          • 5mm Abstand zw IR-Kopf und Zähler geschaffen
                                          • Ausrichtung der LEDs geprüft: Transparent auf schwarz - Ist also OK
