  3. Einsteigerfragen
  4. NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
    5.5k
30 Beiträge 6 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • R raVsu
    pi@iobroker:~$ iob nodejs-update
    iobroker nodejs-update [<major-version>]
    Upgrade the Node.JS installation to the current LTS
    Options:
      --help  Show help  [boolean]
    @ravsu sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
    Options:
    Das ist ein gutes Beispiel warum immer alles gezeigt werden muss!
    hier steht das alles drin
    • GlasfaserG Glasfaser
      @ravsu
      Danke für die Ausgabe ... dann ist alles klar , warum es nicht geht
      Aktualisiere erstmal :
      iob stop
      iob fix
      iob start
      dann
      iob nodejs-update
      raVsu
      @glasfaser
      iob stop
      iob fix
      iob start
      dann
      iob nodejs-update
      durchgeführt
      ioBroker nodejs updater 2023-10-13
      Recommended nodejs-version is: 18.19.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
      /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
      /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
      /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
      *** nodejs is NOT correctly installed ***
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           14.21.3-deb-1nodesource1 1001
              500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting  ***
      rm: cannot remove '': No such file or directory
      *** Deleting  ***
      Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
      Nothing to do - Your version is the recommended one.
      You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
      jetzt wird folgendes angezeigt:
      • R raVsu
        @glasfaser
        iob stop
        iob fix
        iob start
        dann
        iob nodejs-update
        durchgeführt
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        *** Deleting  ***
        *** Deleting  ***
        @ravsu
        https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
        R 1 Antwort Letzte Antwort
        • R raVsu
          @glasfaser
          iob stop
          iob fix
          iob start
          dann
          iob nodejs-update
          durchgeführt
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          *** Deleting  ***
          *** Deleting  ***
          @ravsu
          bitte in code-tags setzen!
          bitte nicht nur selektierte Ausschnitte posten!
            @ravsu
            raVsu
            Danke für den Link.
            Bei dem Befehl
            sudo apt install nodejs=18.19.0-1nodesource1
            wird am ende eine Fehlermeldung geliefert:
            E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
            pi@iobroker:~$ apt policy nodejs
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
            sudo apt update
            iob stop
            sudo apt remove npm
            iob restart
            Package: nodejs
            Pin-Priority: 1001
            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
            Fetched 4586 B in 1s (4087 B/s)
            Reading package lists... Done
            All packages are up to date.
            Package 'npm' is not installed, so not removed
            The following packages were automatically installed and are no longer required:
              distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
              libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
              libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
              libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
              libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
              libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
              libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
              libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
              liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
              libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
              libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
              libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
              libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
              libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
              libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
              linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
              node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
              node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
              node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
              node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
              node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
              node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
              node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
              node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
              node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
              node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
              node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
              node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
              node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
              node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
              node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
              node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
              node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
              node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
              node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
              node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
              node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
              node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
              node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
              node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
              node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
              node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
              node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
              node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
              node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
              node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
              node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
              node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
              node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
              node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
              node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
              node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
              node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
              node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
              node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
              node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
              node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
              node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
              node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
              node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
              node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
              node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
              node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
              node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
              node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
              node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
              pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
              xdg-utils zutty
            Use 'sudo apt autoremove' to remove them.
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Package nodejs is not available, but is referred to by another package.
            This may mean that the package is missing, has been obsoleted, or
            is only available from another source
            However the following packages replace it:
              nodejs-doc
            • R raVsu
              Danke für den Link.
              Bei dem Befehl
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              sudo apt update
              iob stop
              sudo apt remove npm
              iob restart
              Package: nodejs
              Pin-Priority: 1001
                xdg-utils zutty
                nodejs-doc
              @ravsu
              Da fehlt die nodesource.list
              iob nodejs-update 18
              legt die aber eigentlich an.
              Zuvor
              sudo apt autoremove
              sudo apt remove node-* nodejs-doc
              dann
              sollte zu einer richtigen Installation führen.
                @ravsu
                raVsu
                danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
                • R raVsu
                  das und noch viel mehr nützliches steht hier
                    @ravsu
                    Zuvor
                    sudo apt autoremove
                    dann
                    raVsu
                    Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
                    Besseren support kann man nicht haben.
                    Danke an alle.
                    • R raVsu
                      Danke an alle.
                      Und was sagt ein erneutes
                      iob nodejs-update
                      Und ein
                      apt policy nodejs
                      liefert?
                        iob nodejs-update
                        Und ein
                        apt policy nodejs
                        liefert?
                        raVsu
                        schrieb am zuletzt editiert von raVsu
                        @thomas-braun said in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                        iob nodejs-update
                        Alles bestens 😄
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        /usr/bin/corepack       0.22.0
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                         *** 18.19.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Nothing to do - Your installation is using the correct paths.
                        • R raVsu
                          iob nodejs-update
                          Alles bestens 😄
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          @ravsu
                          Ja, jetzt passt es.
