  3. Einsteigerfragen
  4. NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
    5.5k
30 Beiträge 6 Kommentatoren 3.9k Aufrufe 5 Beobachtet
    @ravsu leider ist das nicht die Langversion, sondern ur ein Ausschnitt.
    bitte nachliefern!
    raVsu
    Hier nochmal die Zusammenfassung:
                            v.2023-10-10
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.1.0-18-arm64
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            9.2.0
                            /usr/bin/npx            9.2.0
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            4.0G        3.0G        280M        712K        848M        928M
    Swap:             0B          0B          0B
    Total:          4.0G        3.0G        280M
    Active iob-Instances:   26
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.13.16
    Objects type: jsonl
    States  type: redis
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.178.64, run as: admin
    Objects:                3554
    States:                 2849
    Size of iob-Database:
    42M     /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    408K    /opt/iobroker/iobroker-data/states.json
    32K     /opt/iobroker/iobroker-data/states.json.bak
    • R raVsu
      danke. Jetzt habe ich gesehen das nodejs nicht korrekt installiert ist.
      Wie kann ich das korrigieren?
      *** NodeJS-Installation ***
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           14.21.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
      Ja, den Befehl habe ich ausgeführt
      GlasfaserG Offline
      GlasfaserG Offline
      @ravsu sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
      wurde dir schon gesagt :
      @djmarc75 sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
      @ravsu
      https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
      • GlasfaserG Glasfaser
        @ravsu
        @glasfaser sollte das nicht im nodejs-update mit drin sein?
        @Thomas-Braun oder wo war das mit drin?
        GlasfaserG DJMarc75D 2 Antworten Letzte Antwort
          GlasfaserG Offline
          GlasfaserG Offline
          ich kann hier keine Antwort sehen ... was er schon gemacht hat !
          • R raVsu
            /usr/bin/npm            9.2.0
            /usr/bin/npx            9.2.0
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            @Glasfaser
            aber leider weder die Eingabe noch die Ausgabe gezeigt
            R 1 Antwort Letzte Antwort
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @homoran sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
              bei einer Neuinstallation über den Einzeiler
              Lehrling seit 1975 !!!
                @Glasfaser
                raVsu
                pi@iobroker:~$ iob nodejs-update
                iobroker nodejs-update [<major-version>]
                Upgrade the Node.JS installation to the current LTS
                Options:
                  --help  Show help  [boolean]
                GlasfaserG HomoranH 2 Antworten Letzte Antwort
                • R raVsu
                  Options:
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @ravsu
                  Danke für die Ausgabe ... dann ist alles klar , warum es nicht geht
                  Aktualisiere erstmal :
                  iob stop
                  iob fix
                  iob start
                  dann
                  iob nodejs-update
                  • R raVsu
                    Options:
                    Options:
                    Das ist ein gutes Beispiel warum immer alles gezeigt werden muss!
                    hier steht das alles drin
                      @ravsu
                      iob stop
                      iob fix
                      iob start
                      dann
                      iob nodejs-update
                      raVsu
                      @glasfaser
                      iob stop
                      iob fix
                      iob start
                      dann
                      iob nodejs-update
                      durchgeführt
                      ioBroker nodejs updater 2023-10-13
                      Recommended nodejs-version is: 18.19.0
                      Checking your installation now. Please be patient!
                      Your current setup is:
                      /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                      /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                      /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                      /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                      We found these nodejs versions available for installation:
                      nodejs:
                        Candidate: 14.21.3-deb-1nodesource1
                        Version table:
                           18.13.0+dfsg1-1 500
                           14.21.3-deb-1nodesource1 1001
                      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                      Press <y> to continue or any other key to quit
                      Fixing your nodejs setup
                      *** Deleting  ***
                      rm: cannot remove '': No such file or directory
                      *** Deleting  ***
                      Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                      Nothing to do - Your version is the recommended one.
                      You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
                      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
                      jetzt wird folgendes angezeigt:
                      • R raVsu
                        @glasfaser
                        iob stop
                        iob fix
                        iob start
                        dann
                        iob nodejs-update
                        durchgeführt
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        *** Deleting  ***
                        *** Deleting  ***
                        @ravsu
                        https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                        • R raVsu
                          @glasfaser
                          iob stop
                          iob fix
                          iob start
                          dann
                          iob nodejs-update
                          durchgeführt
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          *** Deleting  ***
                          *** Deleting  ***
                          @ravsu
                          bitte in code-tags setzen!
                          bitte nicht nur selektierte Ausschnitte posten!
                            @ravsu
                            raVsu
                            Danke für den Link.
                            Bei dem Befehl
                            sudo apt install nodejs=18.19.0-1nodesource1
                            wird am ende eine Fehlermeldung geliefert:
                            E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
                            pi@iobroker:~$ apt policy nodejs
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                            sudo apt update
                            iob stop
                            sudo apt remove npm
                            iob restart
                            Package: nodejs
                            Pin-Priority: 1001
                            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                            Hit:2 http://deb.debian.org/debian bookworm InRelease
                            Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
                            Fetched 4586 B in 1s (4087 B/s)
                            Reading package lists... Done
                            All packages are up to date.
                            Package 'npm' is not installed, so not removed
                            The following packages were automatically installed and are no longer required:
                              distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
                              libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
                              libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
                              libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
                              libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
                              libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
                              libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
                              libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
                              liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
                              libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
                              libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
                              libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
                              libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
                              libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
                              libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
                              linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
                              node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
                              node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
                              node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
                              node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
                              node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
                              node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
                              node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
                              node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
                              node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
                              node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
                              node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
                              node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
                              node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
                              node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
                              node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
                              node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
                              node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
                              node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
                              node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
                              node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
                              node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
                              node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
                              node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
                              node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
                              node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
                              node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
                              node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
                              node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
                              node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
                              node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
                              node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
                              node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
                              node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
                              node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
                              node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
                              node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
                              node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
                              node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
                              node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
                              node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
                              node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
                              node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
                              node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
                              node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
                              node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
                              node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
                              node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
                              node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
                              node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
                              node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
                              pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
                              xdg-utils zutty
                            Use 'sudo apt autoremove' to remove them.
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            Package nodejs is not available, but is referred to by another package.
                            This may mean that the package is missing, has been obsoleted, or
                            is only available from another source
                            However the following packages replace it:
                              nodejs-doc
                            • R raVsu
                              Danke für den Link.
                              Bei dem Befehl
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              sudo apt update
                              iob stop
                              sudo apt remove npm
                              iob restart
                              Package: nodejs
                              Pin-Priority: 1001
                                xdg-utils zutty
                                nodejs-doc
                              @ravsu
                              Da fehlt die nodesource.list
                              iob nodejs-update 18
                              legt die aber eigentlich an.
                              Zuvor
                              sudo apt autoremove
                              sudo apt remove node-* nodejs-doc
                              dann
                              sollte zu einer richtigen Installation führen.
                                @ravsu
                                raVsu
                                danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
                                • R raVsu
                                  das und noch viel mehr nützliches steht hier
                                    @ravsu
                                    Zuvor
                                    sudo apt autoremove
                                    dann
                                    raVsu
                                    Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
                                    Besseren support kann man nicht haben.
                                    Danke an alle.
                                    • R raVsu
                                      Danke an alle.
                                      Und was sagt ein erneutes
                                      iob nodejs-update
                                      Und ein
                                      apt policy nodejs
                                      liefert?
                                        iob nodejs-update
                                        Und ein
                                        apt policy nodejs
                                        liefert?
                                        raVsu
                                        schrieb am zuletzt editiert von raVsu
                                        @thomas-braun said in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                                        iob nodejs-update
                                        Alles bestens 😄
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        /usr/bin/corepack       0.22.0
                                        nodejs:
                                          Installed: 18.19.0-1nodesource1
                                          Candidate: 18.19.0-1nodesource1
                                          Version table:
                                         *** 18.19.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0+dfsg1-1 500
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        Nothing to do - Your installation is using the correct paths.
                                        • R raVsu
                                          iob nodejs-update
                                          Alles bestens 😄
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          @ravsu
                                          Ja, jetzt passt es.
