  3. Einsteigerfragen
  4. NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
    5.5k
30 Beiträge 6 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • R raVsu
    pi@iobroker:~$ iob nodejs-update
    iobroker nodejs-update [<major-version>]
    Upgrade the Node.JS installation to the current LTS
    Options:
      --help  Show help  [boolean]
    GlasfaserG Offline
    GlasfaserG Offline
    @ravsu
    Danke für die Ausgabe ... dann ist alles klar , warum es nicht geht
    Aktualisiere erstmal :
    iob stop
    iob fix
    iob start
    dann
    iob nodejs-update
    R 1 Antwort Letzte Antwort
    • R raVsu
      Options:
      @ravsu sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
      Options:
      Das ist ein gutes Beispiel warum immer alles gezeigt werden muss!
      hier steht das alles drin
      • GlasfaserG Glasfaser
        @ravsu
        iob stop
        iob fix
        iob start
        dann
        iob nodejs-update
        raVsu
        @glasfaser
        iob stop
        iob fix
        iob start
        dann
        iob nodejs-update
        durchgeführt
        ioBroker nodejs updater 2023-10-13
        Recommended nodejs-version is: 18.19.0
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
        /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
        /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
        /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
        *** nodejs is NOT correctly installed ***
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 18.19.0+dfsg-6~deb12u1
          Candidate: 14.21.3-deb-1nodesource1
          Version table:
         *** 18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
             14.21.3-deb-1nodesource1 1001
                500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
        Your nodejs-Installation seems to be faulty. Shall we try to fix it?
        Press <y> to continue or any other key to quit
        Fixing your nodejs setup
        *** Deleting  ***
        rm: cannot remove '': No such file or directory
        *** Deleting  ***
        Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
        Nothing to do - Your version is the recommended one.
        You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
        Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
        jetzt wird folgendes angezeigt:
        • R raVsu
          @glasfaser
          iob stop
          iob fix
          iob start
          dann
          iob nodejs-update
          durchgeführt
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          *** Deleting  ***
          *** Deleting  ***
          @ravsu
          https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
          • R raVsu
            @glasfaser
            iob stop
            iob fix
            iob start
            dann
            iob nodejs-update
            durchgeführt
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            *** Deleting  ***
            *** Deleting  ***
            @ravsu
            bitte in code-tags setzen!
            bitte nicht nur selektierte Ausschnitte posten!
              @ravsu
              raVsu
              Danke für den Link.
              Bei dem Befehl
              sudo apt install nodejs=18.19.0-1nodesource1
              wird am ende eine Fehlermeldung geliefert:
              E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
              pi@iobroker:~$ apt policy nodejs
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
              sudo apt update
              iob stop
              sudo apt remove npm
              iob restart
              Package: nodejs
              Pin-Priority: 1001
              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
              Fetched 4586 B in 1s (4087 B/s)
              Reading package lists... Done
              All packages are up to date.
              Package 'npm' is not installed, so not removed
              The following packages were automatically installed and are no longer required:
                distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
                libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
                libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
                libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
                libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
                libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
                libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
                libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
                liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
                libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
                libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
                libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
                libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
                libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
                libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
                linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
                node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
                node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
                node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
                node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
                node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
                node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
                node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
                node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
                node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
                node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
                node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
                node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
                node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
                node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
                node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
                node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
                node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
                node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
                node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
                node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
                node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
                node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
                node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
                node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
                node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
                node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
                node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
                node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
                node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
                node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
                node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
                node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
                node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
                node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
                node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
                node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
                node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
                node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
                node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
                node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
                node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
                node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
                node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
                node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
                node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
                node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
                node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
                node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
                node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
                node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
                pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
                xdg-utils zutty
              Use 'sudo apt autoremove' to remove them.
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Package nodejs is not available, but is referred to by another package.
              This may mean that the package is missing, has been obsoleted, or
              is only available from another source
              However the following packages replace it:
                nodejs-doc
              • R raVsu
                Danke für den Link.
                Bei dem Befehl
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                sudo apt update
                iob stop
                sudo apt remove npm
                iob restart
                Package: nodejs
                Pin-Priority: 1001
                  xdg-utils zutty
                  nodejs-doc
                @ravsu
                Da fehlt die nodesource.list
                iob nodejs-update 18
                legt die aber eigentlich an.
                Zuvor
                sudo apt autoremove
                sudo apt remove node-* nodejs-doc
                dann
                sollte zu einer richtigen Installation führen.
                  @ravsu
                  raVsu
                  danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
                  • R raVsu
                    das und noch viel mehr nützliches steht hier
                      @ravsu
                      Zuvor
                      sudo apt autoremove
                      dann
                      raVsu
                      Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
                      Besseren support kann man nicht haben.
                      Danke an alle.
                      • R raVsu
                        Danke an alle.
                        Und was sagt ein erneutes
                        iob nodejs-update
                        Und ein
                        apt policy nodejs
                        liefert?
                          iob nodejs-update
                          Und ein
                          apt policy nodejs
                          liefert?
                          raVsu
                          schrieb am zuletzt editiert von raVsu
                          @thomas-braun said in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                          iob nodejs-update
                          Alles bestens 😄
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          /usr/bin/corepack       0.22.0
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0+dfsg1-1 500
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          Nothing to do - Your installation is using the correct paths.
                          • R raVsu
                            iob nodejs-update
                            Alles bestens 😄
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            @ravsu
                            Ja, jetzt passt es.
