  4. Test Adapter sureflap v3.4.2
154 Beiträge 17 Kommentatoren 44.5k Aufrufe 19 Beobachtet
  • S Stefi
    @sickboy78 Hi, habe es endlich geschafft auf die 1.2.1 zu aktualisieren. Aber es scheint noch immer nicht zu gehen:
    sureflap.0
    2023-11-26 20:46:34.517	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    sureflap.0
    2023-11-26 20:46:34.461	error	adapter disabled
    sureflap.0
    2023-11-26 20:46:01.951	info	terminating
    sureflap.0
    2023-11-26 20:46:01.438	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    sureflap.0
    2023-11-26 20:46:01.436	info	terminating
    sureflap.0
    2023-11-26 20:46:01.435	info	everything cleaned up
    sureflap.0
    2023-11-26 20:46:01.433	error	unhandled promise rejection: null
    sureflap.0
    2023-11-26 20:46:01.432	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    sureflap.0
    2023-11-26 20:45:51.866	info	update loop started
    sureflap.0
    2023-11-26 20:45:51.858	info	starting update loop...
    sureflap.0
    2023-11-26 20:45:51.857	info	connected
    sureflap.0
    2023-11-26 20:45:50.894	info	connecting...
    sureflap.0
    2023-11-26 20:45:50.889	info	adapter configuration ok
    sureflap.0
    2023-11-26 20:45:50.888	info	felaqua battery voltage empty: 5.2
    sureflap.0
    2023-11-26 20:45:50.888	info	felaqua battery voltage full: 6.2
    sureflap.0
    2023-11-26 20:45:50.887	info	surefeed battery voltage empty: 5.2
    sureflap.0
    2023-11-26 20:45:50.886	info	surefeed battery voltage full: 6.2
    sureflap.0
    2023-11-26 20:45:50.886	info	sureflap battery voltage empty: 5.1
    sureflap.0
    2023-11-26 20:45:50.884	info	sureflap battery voltage full: 6.1
    sureflap.0
    2023-11-26 20:45:50.883	info	checking adapter configuration...
    sureflap.0
    2023-11-26 20:45:50.839	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.16
    Hilft dir das etwas?
    Liebe Grüße,
    Stefi
    Sickboy78S Offline
    Sickboy78S Offline
    Sickboy78
    #84
    Sure Petcare hat seine App auf eine neue API umgestellt. Ich weiß nicht, wann die alte API abgeschaltet wird.
    Ab Version 1.2.3 kann man die API konfigurieren und standardmäßig wird die neue API verwendet.
    Falls der Adapter also plötzlich nicht mehr funktioniert, bitte auf eine Version >=1.2.3 upgraden.
    Ich habe alle Funktionen mit der neuen API erfolgreich getestet. Falls euch Probleme oder Funktionen auffallen, die nicht mehr funktionieren, bitte hier im Forum oder auf Github https://github.com/Sickboy78/ioBroker.sureflap/issues bescheid geben.
    Ich wünsche euch allen einen Guten Rutsch ins neue Jahr!
    English:
    Sure Petcare has changed its app to a new API. I don't know when the old API will be switched off.
    From version 1.2.3 you can configure the API and the new API is used by default.
    So if the adapter suddenly stops working for you, please upgrade to a version >=1.2.3.
    I have successfully tested all functions with the new API. If you notice any problems or functions that no longer work, please let me know here in the forum or on Github https://github.com/Sickboy78/ioBroker.sureflap/issues.
    I wish you all a Happy New Year!
    @Stefi
    Ich hoffe ich habe dein Problem mit der neuesten Version behoben. Bitte probier mal Version 1.2.3 (auf dem latest repository oder direkt von github) und gib mir Bescheid, ob es funktioniert hat.
    Sickboy78S 1 Antwort Letzte Antwort
    • Sickboy78S Sickboy78
      English:
      @Stefi
      Sickboy78S Offline
      Sickboy78S Offline
      Sickboy78
      schrieb am zuletzt editiert von Sickboy78
      #85
      Version 2.0.1 ist da und zeigt nun an, welches Tier zuletzt durch welche Klappe gegangen ist. Das ist vor allem für diejenigen interessant, die sich mit mehreren Klappen eine "Schleuse" gebaut haben. Außerdem gibt es Datenpunkte für wie oft und wie lange jedes Tier draußen war.
      Anmerkung: Die movement.last_* Datenpunkte enthalten nur tatsächliche Bewegungen durch eine Klappe, aber keine Änderung der Position, die per App oder Adapter vorgenommen wurde.
      English:
      Version 2.0.1 is now available and shows which animal last passed through which flap. This is particularly interesting for those who have built a "sluice" with several flaps. There are also data points for how often and for how long each animal was outside.
      Note: The movement.last_* data points only contain actual movements through a flap, but no location change made via app or adapter.
      C 1 Antwort Letzte Antwort
        English:
        christianfeu
        #86
        @sickboy78
        Hallo, vielen Dank erstmal für diesen Adapter. Ich bin noch relativ neu bei SureFlap und habe meine Katzenklappe erst seit vergangener Woche. Bei mir hat die Stable 1.3.2 ein paar Tage funktioniert und auch die 2.0.1 lief bei mir. Seit ein paar Tagen gibt es bei mir aber Probleme. Ich kann die Klappe nicht mehr per Adapter verriegeln oder entriegeln. Das manuelle Setzen der An- oder Abwesenheit funktioniert aber. Weiterhin stürzt bei mir mir alle 20-30 min der javascript Adapter ab. Nur dann wenn der Sureflap Adapter läuft. Sobald er gestoppt wird, läuft wieder alles stabil. Die Probleme betreffen sowohl 1.3.2 als auch 2.0.1 & 2.0.2. Mein iobroker ist auf dem aktuellen Stand, node und js sind aktuell.
        Bin ich der Einzige mit diesen Problemen? Sind das Probleme durch die neue API seitens SureFlap?
        • C christianfeu
          @sickboy78
          #87
          @christianfeu
          Und im Log steht dazu genau was?
            @christianfeu
            christianfeu
            schrieb am zuletzt editiert von christianfeu
            #88
            Sehr schwierige Frage: kein Error, kein Warn, weder bei javascript noch beim sureflap
            Was genau ist die Frage? Das Protokoll ist groß….
            • C christianfeu
              @sickboy78
              #89
              @christianfeu sagte in Test Adapter sureflap v1.0.x GitHub:
              Das tut der unter Garantie nicht lautlos.
              Schau in
              iob logs --watch
              uns spiel mit dem Adapter herum.
                Schau in
                iob logs --watch
                christianfeu
                #90
                ok mache ich. Vielen Dank.
                Wollte erstmal rausfinden, ob ich der einzige bin mit Problemen…
                • C christianfeu
                  christianfeu
                  #91
                  @christianfeu
                  Also, in dem Moment wo ich eine Aktion über den SureFlap Adapter ansteuere und ein paar Sekunden später stürzt der Javascript Adapter ab. Habe das jetzt exakt beobachtet. Beim Absturz kommen Meldungen, die mit Redis zusammenhängen.
                  Hilft das weiter?
                  2024-02-08 19:57:40.560 - silly: sureflap.0 (102333) doing http request with tag get_data
                  2024-02-08 19:57:50.615 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.inputCount
                  2024-02-08 19:57:50.716 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cputime
                  2024-02-08 19:57:50.717 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.alive
                  2024-02-08 19:57:51.019 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cpu
                  2024-02-08 19:57:51.052 - silly: sureflap.0 (102333) doing http request with tag get_data
                  2024-02-08 19:57:51.122 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.outputCount
                  2024-02-08 19:57:51.123 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.eventLoopLag
                  2024-02-08 19:57:51.632 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapUsed
                  2024-02-08 19:57:51.935 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapTotal
                  2024-02-08 19:57:52.140 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memRss
                  2024-02-08 19:57:52.343 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.connected
                  2024-02-08 19:57:52.344 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.uptime
                  2024-02-08 19:58:01.520 - silly: sureflap.0 (102333) doing http request with tag get_data
                    Aktuelle Test Version 3.4.2
                    Aktuelle Stable Version 3.4.2
                    Veröffentlichungsdatum 09.01.2026
                    Github Link https://github.com/Sickboy78/ioBroker.sureflap
                    Beschreibung des Adapters
                    Der Adapter erlaubt Zugriff auf Smarte Haustierklappen, Futterautomaten und Wasserspender von Surepetcare, einer der führenden Hersteller von smarten Katzenklappen und Futterautomaten mit App-Integration am Markt.
                    Es werden Statuswerte zum Hub (LED und Verbindung) und zur Katzenklappe (Batterie, Verbindung, Sperrmodus und Ausgangssperre) angezeigt. Es wird der Aufenthaltsort (drin oder draußen, seit) des oder der Haustiere angezeigt.
                    Über den Adapter kann der Sperrmodus der Klappe verändert werden, die Ausgangssperre ein- oder ausgeschaltet werden oder der Aufenthaltsort des Haustiers aktualisiert werden, wenn es z.B. das Haus auf einem anderen Weg als der Klappe verlassen oder betreten hat. Für den Futterautomat und den Wasserspende werden die verbleibende Menge Wasser und Futter angezeigt, sowie wieviel und wie oft das Tier heute getrunken und/oder gefressen hat.
                    Vorraussetzungen
                    Um den Adapter sinnvoll einsetzen zu können, benötigt man eine Katzenklappe Connect oder Haustierklappe Connect oder Futterautomat Connect oder Felaqua Connect sowie einen Hub und einen Account für die Surepetcare App (Android oder Apple).
                    cooper2k4
                    schrieb am zuletzt editiert von cooper2k4
                    #92
                    ich habe seit ca. 3 Wochen das Problem, dass die Protokollierung via SQL-Adapter (sqlite) nicht mehr funktioniert. Ich kann mich leider an keine Änderung an der ioBroker Installation erinnern...
                    Wenn ich den sureflap-Adapter neustarte wird das Logging automatisch deaktiviert. Ich habe gerade von v1.2.3 auf v2.0.1 aktualisiert. Das hat aber keine Änderung gebracht. Mit anderen Adaptern funktioniert das SQL-Logging ohne Probleme. Liegt es am sureflap- oder SQL-Adapter?
                    Ich habe schon alles Mögliche probiert (npm cache clean/rebuild, iob Objekte löschen etc.). Weiß jemand noch Rat?
                    Viele Grüße
                    Thorsten
                    pi@iobroker:/opt/iobroker $ iob info
                    Platform       : linux
                    os             : linux
                    Architecture   : arm64
                    CPUs           : 4
                    Speed          : 1700 MHz
                    Model          : Cortex-A72
                    RAM            : 3.7 GB
                    System uptime  : 1d. 15:52:06
                    Node.js        : v20.5.1
                    time           : 1707651469831
                    timeOffset     : -60
                    NPM            : 10.4.0
                    adapters count : 530
                    Disk size      : 29.1 GiB
                    Disk free      : 9.2 GiB
                    • C cooper2k4
                      Viele Grüße
                      Thorsten
                      Platform       : linux
                      os             : linux
                      CPUs           : 4
                      Speed          : 1700 MHz
                      Model          : Cortex-A72
                      RAM            : 3.7 GB
                      Node.js        : v20.5.1
                      timeOffset     : -60
                      NPM            : 10.4.0
                      Disk free      : 9.2 GiB
                      #93
                      @cooper2k4
                      Installier nodejs/npm ordentlich.
                      iob nodejs-update 18
                      Und künftig die Finger von individuellen Installationen von npm lassen.
                        @cooper2k4
                        cooper2k4
                        #94
                        @thomas-braun sagte in Test Adapter sureflap v1.0.x GitHub:
                        Danke für den Hinweis. Das ändert aber nichts.
                        Platform       : linux
                        os             : linux
                        CPUs           : 4
                        Speed          : 1700 MHz
                        Model          : Cortex-A72
                        RAM            : 3.7 GB
                        System uptime  : 1d. 20:53:35
                        Node.js        : v18.17.1
                        time           : 1707669559211
                        timeOffset     : -60
                        NPM            : 10.4.0
                        Disk free      : 9.2 GiB
                        • C cooper2k4
                          Platform       : linux
                          os             : linux
                          CPUs           : 4
                          Speed          : 1700 MHz
                          Model          : Cortex-A72
                          RAM            : 3.7 GB
                          Node.js        : v18.17.1
                          timeOffset     : -60
                          NPM            : 10.4.0
                          Disk free      : 9.2 GiB
                          #95
                          @cooper2k4 sagte in Test Adapter sureflap v1.0.x GitHub:
                          Doch. Dann wäre die Laufzeitumgebung richtig.
                          Denn
                          Node.js : v18.17.1
                          NPM : 10.4.0
                          ist immer noch falsch.
                          iob stop
                          iob fix
                          iob start
                          ausführen.
                            Denn
                            Node.js : v18.17.1
                            NPM : 10.4.0
                            iob stop
                            iob fix
                            iob start
                            ausführen.
                            cooper2k4
                            #96
                            Die Laufzeitumgebung sollte jetzt richtig sein. Das ursprüngliche Problem besteht aber weiterhin.
                                                    v.2023-10-10
                             Static hostname: iobroker
                                   Icon name: computer
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               arm64
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            X-Server:               false
                            Boot Target:            multi-user.target
                            Pending OS-Updates:     0
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                    /usr/bin/node           v18.19.0
                                                    /usr/bin/npm            10.2.3
                                                    /usr/bin/npx            10.2.3
                                                    /usr/bin/corepack       0.22.0
                            Recommended versions are nodejs 18.19.0 and npm 10.2.3
                            MEMORY:
                            Mem:            4.0G        1.6G        679M        2.1M        1.8G        2.4G
                            Swap:           1.3G        2.1M        1.3G
                            Total:          5.3G        1.6G        2.0G
                            Active iob-Instances:   17
                            Active repo(s): stable
                            ioBroker Core:          js-controller           5.0.17
                                                    admin                   6.13.16
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                            Objects:                10080
                            States:                 7643
                            Size of iob-Database:
                            17M     /opt/iobroker/iobroker-data/objects.jsonl
                            7.8M    /opt/iobroker/iobroker-data/objects.json.migrated
                            7.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            9.0M    /opt/iobroker/iobroker-data/states.jsonl
                            5.2M    /opt/iobroker/iobroker-data/states.json.migrated
                            5.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            • C christianfeu
                              @christianfeu
                              Hilft das weiter?
                              Sickboy78S Offline
                              Sickboy78S Offline
                              Sickboy78
                              #97
                              Hallo @christianfeu
                              hab grad bei mir getestet und kann sowohl die Klappe als auch die Ausgangssperre per Adapter aktivieren und deaktivieren. Scheint also kein Problem mit der API zu sein.
                              Dein Log hilft mir leider auch nicht weiter, da ist nichts Ungewöhnliches zu erkennen. Auch nicht welche Aktion du ausführst. Wenn du die Klappe verriegelst, sollte sowas im log stehen:
                              2024-02-13 19:16:14.717 info lock mode changed to 1
                              2024-02-13 19:16:12.427 debug changing lock mode to 1...
                              Kannst du bitte nochmal einen Logauszug machen, wo die Aktion erkennbar ist, die du vor dem Absturz gemacht hast?
                              Wenn der Adapter neu startet, sollte es solche Einträge im Log geben:
                              2024-02-13 19:40:11.179 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.17
                              2024-02-13 19:40:05.798 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-02-13 19:40:05.798 info terminating
                              2024-02-13 19:40:05.798 info everything cleaned up
                              2024-02-13 19:40:05.797 info Got terminate signal TERMINATE_YOURSELF
                              Wenn du davon bitte auch nochmal einen Logauszug posten könntest.
                              Auf was für einem Rechner läuft dein ioBroker? Wieviel Speicher hat der?
                              • C cooper2k4
                                                        v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm64
                                Kernel:                 aarch64
                                Userland:               arm64
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            10.2.3
                                                        /usr/bin/npx            10.2.3
                                MEMORY:
                                                        admin                   6.13.16
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                10080
                                States:                 7643
                                Sickboy78S Offline
                                Sickboy78S Offline
                                Sickboy78
                                #98
                                Hallo @cooper2k4
                                interessantes Problem. Ich logge die battery Datenpunkte auch, ohne Probleme.
                                Kannst du mal bitte posten was nach den disabled logging Einträgen im Log erscheint?
                                Vorher bitte den Adapter auch auf debug oder silly umstellen.
                                  Hallo @christianfeu
                                  christianfeu
                                  #99
                                  @sickboy78
                                  erstmal danke für deine Antwort. Ich habe im Grunde ja 2 Probleme, die ich mir nicht erklären kann. Um die Sache im 1. Schritt zu vereinfachen, habe ich mir meinen Backup Raspberry 4 genommen und ioBroker frisch installiert und darauf den SureFlap Adapter eingerichtet. Auch hier habe ich das Problem, dass ich den lockmode und curfew nicht ausführen kann (Adapter Version ist unerheblich, es geht mit keiner Version). Wenn ich die Datenpunkte manuell (nicht bestätigt) ändere, bleiben diese auch rot. Egal wie ich das mache, ob manuell oder per VIS oder Skript, die Änderungen werden einfach nicht durchgereicht.
                                  Ich habe grundsätzlich mit dem Adapter Zugriff. Ich kann die Anwesenheit des Tiers per Adapter ändern und mir auch alle Änderungen der History per VIS visualisieren. In den Adapter Einstellungen sehe ich auch das Bild meiner Katze.
                                  Per SureFlap App kann ich alle Funktionen einwandfrei benutzen. Öffnen, Schließen, Zeitregel etc. Alles ohne Probleme. Der Hub ist 4m von der Klappe entfernt. Alles ist korrekt verbunden und eingerichtet. Allerdings habe ich die Hardware erst seit 3 Wochen.
                                  Katzenklappe Firmware: 1.1
                                  Katzenklappe Hardware: 1.2
                                  Hub Firmware: 734.50
                                  Hub Hardware: 3.0
                                  Ich kann mir das einfach nicht erklären. Warum kann ich die Klappe über die App steuern aber nicht über den Adapter?
                                  Das Log bringt wenig interessante Informationen, wenn ich curfew oder den lockmode ändere. Irgendwie hilft das nicht weiter.
                                  Woran kann das liegen?
                                  LOG Auszug bei Änderung lockmode. Danach kommt auch nichts mehr. Adapter ist auf maximale Protokollierungsstufe eingestellt.
                                  LOG-Auszug bei Neustart des Adapters:
                                  Raspberry Info:
                                  • C christianfeu
                                    @sickboy78
                                    Hub Hardware: 3.0
                                    Raspberry Info:
                                    Sickboy78S Offline
                                    Sickboy78S Offline
                                    Sickboy78
                                    #100
                                    Hallo @christianfeu
                                    Der Eintrag "lock mode changed to 0" bedeutet zumindest, dass der Aufruf an die Surepet API erfolgreich war und mit einem 200 OK quittiert wurde. Warum der Datenpunkt dann nicht aktualisiert wird, ist mir rätselhaft.
                                    Ändert sich eigentlich der Zustand in der App?
                                    Ich vermute, dass du eine neue Version der Katzenklappe hast und hier die Datenstruktur abweicht, da deine Versionen (1.1 und 1.2) ganz anders sind als bei mir (335.422 und 9). Um weiter zu analysieren, bräuchte ich aber einen Auszug aus dem Datenverkehr.
                                    Du scheinst dich auszukennen, darum verzichte ich mal auf die Erklärung, wie man sich die Requests im Browser mit den Entwicklertools anschaut. Falls nicht, sag bescheid.
                                    Und zwar hätte ich gerne die Antwort auf den PUT Request für eine Änderung des Lockmode.
                                    Dazu müsstest du im Browser https://surepetcare.io/ aufrufen dich anmelden und ähnlich wie in der App zu den Einstellungen der Klappe gehen und dort die Klappe ver- oder entriegeln.
                                    Da bräuchte ich dann die Antwort auf den PUT request https://app-api.production.surehub.io/api/device/.../control wie im Screenshot als unformatiertes JSON:
                                    Und dann hätte ich gerne noch, wenn du die Übersicht aufrufst https://surepetcare.io/dashboard, die Antwort auf den GET request https://app-api.production.surehub.io/api/me/start (wichtig, der request api/me/start nicht /api/start):
                                    Wichtig, wenn du das JSON (am besten als Textdatei) hier hochlädst, vorher persönliche Daten wie Email entfernen. Alternativ kannst du es mir auch direkt per Email senden: asmoday_666@gmx.de
                                      Hallo @cooper2k4
                                      cooper2k4
                                      #101
                                      @sickboy78
                                      Hier ist jetzt der Protokollauszug von Sureflap und SQL mit Silly Log-Level:
                                      2024-02-17 12:21:08.441  - debug: sureflap.0 (1266997) searching and removing of obsolete objects
                                      2024-02-17 12:21:08.442  - silly: sureflap.0 (1266997) deleting obsolete object 'Familie_K_____i.Katzenklappe.led_mode'
                                      2024-02-17 12:21:08.443  - silly: sureflap.0 (1266997) checking for object Familie_K_____i.Katzenklappe.
                                      2024-02-17 12:21:08.443  - silly: sureflap.0 (1266997) deleting obsolete object 'Familie_K_____i.Katzenklappe.control.led_mode'
                                      2024-02-17 12:21:08.443  - silly: sureflap.0 (1266997) deleting obsolete object 'Familie_K_____i.Katzenklappe.control'
                                      2024-02-17 12:21:08.444  - silly: sureflap.0 (1266997) deleting obsolete object 'Familie_K_____i.Katzenklappe.online'
                                      2024-02-17 12:21:08.445  - silly: sureflap.0 (1266997) deleting obsolete object 'Familie_K_____i.Katzenklappe.serial_number'
                                      2024-02-17 12:21:08.445  - silly: sureflap.0 (1266997) deleting obsolete object 'Familie_K_____i.Katzenklappe'
                                      2024-02-17 12:21:08.460  - silly: sureflap.0 (1266997) obsolete object 'Familie_K_____i.Katzenklappe.led_mode' not found
                                      2024-02-17 12:21:08.462  - debug: sureflap.0 (1266997) obsolete object Familie_K_____i.Katzenklappe.control.led_mode found. trying to delete ...
                                      2024-02-17 12:21:08.464  - debug: sureflap.0 (1266997) obsolete object Familie_K_____i.Katzenklappe.control found. trying to delete ...
                                      2024-02-17 12:21:08.465  - debug: sureflap.0 (1266997) obsolete object Familie_K_____i.Katzenklappe.online found. trying to delete ...
                                      2024-02-17 12:21:08.468  - debug: sureflap.0 (1266997) obsolete object Familie_K_____i.Katzenklappe.serial_number found. trying to delete ...
                                      2024-02-17 12:21:08.469  - debug: sureflap.0 (1266997) obsolete object Familie_K_____i.Katzenklappe found. trying to delete ...
                                      2024-02-17 12:21:08.515  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.control.led_mode:null
                                      2024-02-17 12:21:08.517  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.online:null
                                      2024-02-17 12:21:08.522  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.serial_number:null
                                      2024-02-17 12:21:08.527  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868514,"ack":true,"ts":1708168868525,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868525}
                                      2024-02-17 12:21:08.529  - silly: sql.0 (1266515) States user redis pmessage */sureflap.0.Familie_K_____i.Katzenklappe.control.led_mode:null
                                      2024-02-17 12:21:08.531  - silly: sureflap.0 (1266997) States user redis pmessage sureflap.0.*.control.*/sureflap.0.Familie_K_____i.Katzenklappe.control.led_mode:null
                                      2024-02-17 12:21:08.533  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868517,"ack":true,"ts":1708168868528,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868528}
                                      2024-02-17 12:21:08.535  - silly: sql.0 (1266515) States user redis pmessage */sureflap.0.Familie_K_____i.Katzenklappe.online:null
                                      2024-02-17 12:21:08.539  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.control:null
                                      2024-02-17 12:21:08.541  - silly: sql.0 (1266515) States user redis pmessage */sureflap.0.Familie_K_____i.Katzenklappe.serial_number:null
                                      2024-02-17 12:21:08.542  - debug: sureflap.0 (1266997) obsolete object 'Familie_K_____i.Katzenklappe.control.led_mode' deleted
                                      2024-02-17 12:21:08.544  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe:null
                                      2024-02-17 12:21:08.546  - debug: sureflap.0 (1266997) obsolete object 'Familie_K_____i.Katzenklappe.online' deleted
                                      2024-02-17 12:21:08.549  - debug: sureflap.0 (1266997) obsolete object 'Familie_K_____i.Katzenklappe.control' deleted
                                      2024-02-17 12:21:08.551  - debug: sureflap.0 (1266997) obsolete object 'Familie_K_____i.Katzenklappe.serial_number' deleted
                                      2024-02-17 12:21:08.552  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868522,"ack":true,"ts":1708168868549,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868549}
                                      2024-02-17 12:21:08.554  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868539,"ack":true,"ts":1708168868550,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868550}
                                      2024-02-17 12:21:08.595  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868545,"ack":true,"ts":1708168868593,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868593}
                                      2024-02-17 12:21:08.600  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe:null
                                      2024-02-17 12:21:08.606  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.assigned_pets:null
                                      2024-02-17 12:21:08.611  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868599,"ack":true,"ts":1708168868604,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868604}
                                      2024-02-17 12:21:08.620  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868606,"ack":true,"ts":1708168868616,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868616}
                                      2024-02-17 12:21:08.624  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.assigned_pets.Loki:null
                                      2024-02-17 12:21:08.631  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868625,"ack":true,"ts":1708168868629,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868629}
                                      2024-02-17 12:21:08.638  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.battery:null
                                      2024-02-17 12:21:08.639  - info: sql.0 (1266515) disabled logging of sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.battery
                                      2024-02-17 12:21:08.644  - silly: sql.0 (1266515) States user redis pmessage */sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.battery:null
                                      2024-02-17 12:21:08.648  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868638,"ack":true,"ts":1708168868645,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868645}
                                      2024-02-17 12:21:08.653  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.battery_percentage:null
                                      2024-02-17 12:21:08.655  - info: sql.0 (1266515) disabled logging of sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.battery_percentage
                                      2024-02-17 12:21:08.657  - silly: sql.0 (1266515) States user redis pmessage */sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.battery_percentage:null
                                      2024-02-17 12:21:08.662  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868653,"ack":true,"ts":1708168868659,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868659}
                                      2024-02-17 12:21:08.665  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.control:null
                                      2024-02-17 12:21:08.671  - silly: sql.0 (1266515) Objects user redis pmessage */cfg.o.sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.control.curfew:null
                                      2024-02-17 12:21:08.676  - silly: sql.0 (1266515) States user redis pmessage */system.adapter.javascript.0.lastSync:{"val":1708168868665,"ack":true,"ts":1708168868671,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1708168868671}
                                      2024-02-17 12:21:08.677  - silly: sureflap.0 (1266997) States user redis pmessage sureflap.0.*.control.*/sureflap.0.Familie_K_____i.Katzenklappe.Katzenklappe.control.curfew:null
                                      Ich hoffe, das hilft. Da werden Objekte anscheinend aufgeräumt und gelöscht 🤔
                                      Viele Grüße
                                      • C cooper2k4
                                        @sickboy78
                                        Viele Grüße
                                        Sickboy78S Offline
                                        Sickboy78S Offline
                                        Sickboy78
                                        #102
                                        Hallo @cooper2k4,
                                        ich habe einen Verdacht.
                                        Sowohl dein Hub, als auch deine Klappe heißen "Katzenklappe".
                                        Den Namen vom Hub kann man leider imho nicht ändern, aber die Klappe lässt sich in der App umbenennen.
                                        Wenn du ihr testweise mal einen anderen Namen geben könntest, z.B. nur "Klappe" o.ä.
                                        Danach müsstest du entweder alle Objekte unterhalb sureflap.0 löschen und den Adapter neu starten, damit die Struktur neu angelegt wird. Oder alternativ die Instanz löschen und neu hinzufügen.
                                        Und dann prüfen, ob das Problem noch besteht.
                                        Problem ist, dass es vor kurzem eine Änderung in der API gab, wodurch die Geräte (z.B. Klappe) fälschlicherweise direkt unter dem Haushalt erzeugt wurden, statt unterhalb des Hubs. Um das zu korrigieren, habe ich eine Funktion eingebaut, die nach den Geräten unterhalb des Haushalts sucht und, falls es sie findet, wieder löscht.
                                        Jetzt sucht er bei dir nach "Katzenklappe" und findet diese auch. Allerdings handelt es sich aufgrund der Namensgleichheit nicht um die Klappe, sondern um den Hub. Und dann versucht er fälschlicherweise den Hub zu löschen, statt der Klappe. Dadurch wird auch der battery-State gelöscht und somit das Logging deaktiviert.
                                        Ich muss mir mal überlegen, wie ich dieses Problem umgehe, aber temporär sollte es hoffentlich helfen, wenn du unterschiedliche Namen vergibst.
                                        Sebastian
                                          Hallo @cooper2k4,
                                          Sebastian
                                          cooper2k4
                                          #103
                                          @sickboy78
                                          Hallo Sebastian,
                                          super! 👍
                                          Vielen Dank für Deine Arbeit und die Erklärung und Lösung. Das war es. Nach dem Umbenennen der Klappe funktioniert es wieder!
                                          Schönes Wochenende
                                          Thorsten
