  4. Test Adapter sureflap v3.4.2
154 Beiträge 17 Kommentatoren 44.5k Aufrufe 19 Beobachtet
  • S Stefi
    @sickboy78 kannst du mir eventuell weiterhelfen? Seit dem Update des js-controllers bekomme ich den Adapter weder mit der 1.2.0 noch mit der 1.1.9 ans Laufen :(
    2023-10-17 21:02:29.544 - info: sureflap.0 (288818) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.12
    2023-10-17 21:02:29.588 - info: sureflap.0 (288818) checking adapter configuration...
    2023-10-17 21:02:29.589 - info: sureflap.0 (288818) sureflap battery voltage full: 6.1
    2023-10-17 21:02:29.590 - info: sureflap.0 (288818) sureflap battery voltage empty: 5.1
    2023-10-17 21:02:29.591 - info: sureflap.0 (288818) surefeed battery voltage full: 6.2
    2023-10-17 21:02:29.592 - info: sureflap.0 (288818) surefeed battery voltage empty: 5.2
    2023-10-17 21:02:29.593 - info: sureflap.0 (288818) felaqua battery voltage full: 6.2
    2023-10-17 21:02:29.593 - info: sureflap.0 (288818) felaqua battery voltage empty: 5.2
    2023-10-17 21:02:29.594 - info: sureflap.0 (288818) adapter configuration ok
    2023-10-17 21:02:29.598 - info: sureflap.0 (288818) connecting...
    2023-10-17 21:02:30.369 - info: sureflap.0 (288818) connected
    2023-10-17 21:02:30.371 - info: sureflap.0 (288818) starting update loop...
    2023-10-17 21:02:30.379 - info: sureflap.0 (288818) update loop started
    2023-10-17 21:02:37.407 - info: admin.0 (174) <== Disconnect system.user.admin from ::ffff:192.168.178.100
    2023-10-17 21:02:39.022 - warn: sureflap.0 (288818) no remaining food data for feeder 'Lia_s_Futterbox' found
    2023-10-17 21:02:39.024 - warn: sureflap.0 (288818) no remaining food data for feeder 'Benjis_Futterbox' found
    2023-10-17 21:02:39.028 - warn: sureflap.0 (288818) aggregated report for pet 'Benji' does not contain feeding data
    2023-10-17 21:02:39.029 - warn: sureflap.0 (288818) aggregated report for pet 'Lia' does not contain feeding data
    2023-10-17 21:02:39.057 - error: sureflap.0 (288818) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-17 21:02:39.058 - error: sureflap.0 (288818) unhandled promise rejection: undefined is not a valid state value
    2023-10-17 21:02:39.062 - error: sureflap.0 (288818) Error: undefined is not a valid state value
    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
    at Sureflap._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49)
    at Sureflap.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21)
    at Immediate. (/opt/iobroker/node_modules/iobroker.sureflap/main.js:1099:12)
    at process.processImmediate (node:internal/timers:478:21)
    2023-10-17 21:02:39.063 - error: sureflap.0 (288818) undefined is not a valid state value
    2023-10-17 21:02:39.093 - info: sureflap.0 (288818) everything cleaned up
    2023-10-17 21:02:39.095 - info: sureflap.0 (288818) terminating
    2023-10-17 21:02:39.096 - warn: sureflap.0 (288818) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-17 21:02:39.640 - info: sureflap.0 (288818) terminating
    Sickboy78S Offline
    Sickboy78S Offline
    Sickboy78
    #81
    Hallo @stefi, das sieht mir nach einem der Probleme durch die API Änderungen aus. Probier doch bitte mal die 1.2.1 aus.
    Falls das nicht hilft, sag Bescheid, dann muss ich es mir genauer ansehen.
    • Sickboy78S Sickboy78
      Stefi
      #82
      @sickboy78 Hi, habe es endlich geschafft auf die 1.2.1 zu aktualisieren. Aber es scheint noch immer nicht zu gehen:
      sureflap.0
      2023-11-26 20:46:34.517	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      sureflap.0
      2023-11-26 20:46:34.461	error	adapter disabled
      sureflap.0
      2023-11-26 20:46:01.951	info	terminating
      sureflap.0
      2023-11-26 20:46:01.438	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      sureflap.0
      2023-11-26 20:46:01.436	info	terminating
      sureflap.0
      2023-11-26 20:46:01.435	info	everything cleaned up
      sureflap.0
      2023-11-26 20:46:01.433	error	unhandled promise rejection: null
      sureflap.0
      2023-11-26 20:46:01.432	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      sureflap.0
      2023-11-26 20:45:51.866	info	update loop started
      sureflap.0
      2023-11-26 20:45:51.858	info	starting update loop...
      sureflap.0
      2023-11-26 20:45:51.857	info	connected
      sureflap.0
      2023-11-26 20:45:50.894	info	connecting...
      sureflap.0
      2023-11-26 20:45:50.889	info	adapter configuration ok
      sureflap.0
      2023-11-26 20:45:50.888	info	felaqua battery voltage empty: 5.2
      sureflap.0
      2023-11-26 20:45:50.888	info	felaqua battery voltage full: 6.2
      sureflap.0
      2023-11-26 20:45:50.887	info	surefeed battery voltage empty: 5.2
      sureflap.0
      2023-11-26 20:45:50.886	info	surefeed battery voltage full: 6.2
      sureflap.0
      2023-11-26 20:45:50.886	info	sureflap battery voltage empty: 5.1
      sureflap.0
      2023-11-26 20:45:50.884	info	sureflap battery voltage full: 6.1
      sureflap.0
      2023-11-26 20:45:50.883	info	checking adapter configuration...
      sureflap.0
      2023-11-26 20:45:50.839	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.16
      Hilft dir das etwas?
      Liebe Grüße,
      Stefi
      Thomas BraunT Sickboy78S 2 Antworten Letzte Antwort
      • S Stefi
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        sureflap.0
        Liebe Grüße,
        Stefi
        #83
        @stefi sagte in Test Adapter sureflap v1.0.x GitHub:
        node: v18.17.1
        Zu alt, aktualisier das per
        iob nodejs-update
        • S Stefi
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          sureflap.0
          Liebe Grüße,
          Stefi
          Sickboy78S Offline
          Sickboy78S Offline
          Sickboy78
          #84
          Sure Petcare hat seine App auf eine neue API umgestellt. Ich weiß nicht, wann die alte API abgeschaltet wird.
          Ab Version 1.2.3 kann man die API konfigurieren und standardmäßig wird die neue API verwendet.
          Falls der Adapter also plötzlich nicht mehr funktioniert, bitte auf eine Version >=1.2.3 upgraden.
          Ich habe alle Funktionen mit der neuen API erfolgreich getestet. Falls euch Probleme oder Funktionen auffallen, die nicht mehr funktionieren, bitte hier im Forum oder auf Github https://github.com/Sickboy78/ioBroker.sureflap/issues bescheid geben.
          Ich wünsche euch allen einen Guten Rutsch ins neue Jahr!
          English:
          Sure Petcare has changed its app to a new API. I don't know when the old API will be switched off.
          From version 1.2.3 you can configure the API and the new API is used by default.
          So if the adapter suddenly stops working for you, please upgrade to a version >=1.2.3.
          I have successfully tested all functions with the new API. If you notice any problems or functions that no longer work, please let me know here in the forum or on Github https://github.com/Sickboy78/ioBroker.sureflap/issues.
          I wish you all a Happy New Year!
          @Stefi
          Ich hoffe ich habe dein Problem mit der neuesten Version behoben. Bitte probier mal Version 1.2.3 (auf dem latest repository oder direkt von github) und gib mir Bescheid, ob es funktioniert hat.
          Sickboy78S 1 Antwort Letzte Antwort
            English:
            @Stefi
            Sickboy78S Offline
            Sickboy78S Offline
            Sickboy78
            schrieb am zuletzt editiert von Sickboy78
            #85
            Version 2.0.1 ist da und zeigt nun an, welches Tier zuletzt durch welche Klappe gegangen ist. Das ist vor allem für diejenigen interessant, die sich mit mehreren Klappen eine "Schleuse" gebaut haben. Außerdem gibt es Datenpunkte für wie oft und wie lange jedes Tier draußen war.
            Anmerkung: Die movement.last_* Datenpunkte enthalten nur tatsächliche Bewegungen durch eine Klappe, aber keine Änderung der Position, die per App oder Adapter vorgenommen wurde.
            English:
            Version 2.0.1 is now available and shows which animal last passed through which flap. This is particularly interesting for those who have built a "sluice" with several flaps. There are also data points for how often and for how long each animal was outside.
            Note: The movement.last_* data points only contain actual movements through a flap, but no location change made via app or adapter.
            C 1 Antwort Letzte Antwort
              English:
              christianfeu
              #86
              @sickboy78
              Hallo, vielen Dank erstmal für diesen Adapter. Ich bin noch relativ neu bei SureFlap und habe meine Katzenklappe erst seit vergangener Woche. Bei mir hat die Stable 1.3.2 ein paar Tage funktioniert und auch die 2.0.1 lief bei mir. Seit ein paar Tagen gibt es bei mir aber Probleme. Ich kann die Klappe nicht mehr per Adapter verriegeln oder entriegeln. Das manuelle Setzen der An- oder Abwesenheit funktioniert aber. Weiterhin stürzt bei mir mir alle 20-30 min der javascript Adapter ab. Nur dann wenn der Sureflap Adapter läuft. Sobald er gestoppt wird, läuft wieder alles stabil. Die Probleme betreffen sowohl 1.3.2 als auch 2.0.1 & 2.0.2. Mein iobroker ist auf dem aktuellen Stand, node und js sind aktuell.
              Bin ich der Einzige mit diesen Problemen? Sind das Probleme durch die neue API seitens SureFlap?
              • C christianfeu
                @sickboy78
                #87
                @christianfeu
                Und im Log steht dazu genau was?
                  @christianfeu
                  christianfeu
                  schrieb am zuletzt editiert von christianfeu
                  #88
                  Sehr schwierige Frage: kein Error, kein Warn, weder bei javascript noch beim sureflap
                  Was genau ist die Frage? Das Protokoll ist groß….
                  • C christianfeu
                    @sickboy78
                    #89
                    @christianfeu sagte in Test Adapter sureflap v1.0.x GitHub:
                    Das tut der unter Garantie nicht lautlos.
                    Schau in
                    iob logs --watch
                    uns spiel mit dem Adapter herum.
                      Schau in
                      iob logs --watch
                      christianfeu
                      #90
                      ok mache ich. Vielen Dank.
                      Wollte erstmal rausfinden, ob ich der einzige bin mit Problemen…
                      • C christianfeu
                        christianfeu
                        #91
                        @christianfeu
                        Also, in dem Moment wo ich eine Aktion über den SureFlap Adapter ansteuere und ein paar Sekunden später stürzt der Javascript Adapter ab. Habe das jetzt exakt beobachtet. Beim Absturz kommen Meldungen, die mit Redis zusammenhängen.
                        Hilft das weiter?
                        2024-02-08 19:57:40.560 - silly: sureflap.0 (102333) doing http request with tag get_data
                        2024-02-08 19:57:50.615 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.inputCount
                        2024-02-08 19:57:50.716 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cputime
                        2024-02-08 19:57:50.717 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.alive
                        2024-02-08 19:57:51.019 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cpu
                        2024-02-08 19:57:51.052 - silly: sureflap.0 (102333) doing http request with tag get_data
                        2024-02-08 19:57:51.122 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.outputCount
                        2024-02-08 19:57:51.123 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.eventLoopLag
                        2024-02-08 19:57:51.632 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapUsed
                        2024-02-08 19:57:51.935 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapTotal
                        2024-02-08 19:57:52.140 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memRss
                        2024-02-08 19:57:52.343 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.connected
                        2024-02-08 19:57:52.344 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.uptime
                        2024-02-08 19:58:01.520 - silly: sureflap.0 (102333) doing http request with tag get_data
                          Aktuelle Test Version 3.4.2
                          Aktuelle Stable Version 3.4.2
                          Veröffentlichungsdatum 09.01.2026
                          Github Link https://github.com/Sickboy78/ioBroker.sureflap
                          Beschreibung des Adapters
                          Der Adapter erlaubt Zugriff auf Smarte Haustierklappen, Futterautomaten und Wasserspender von Surepetcare, einer der führenden Hersteller von smarten Katzenklappen und Futterautomaten mit App-Integration am Markt.
                          Es werden Statuswerte zum Hub (LED und Verbindung) und zur Katzenklappe (Batterie, Verbindung, Sperrmodus und Ausgangssperre) angezeigt. Es wird der Aufenthaltsort (drin oder draußen, seit) des oder der Haustiere angezeigt.
                          Über den Adapter kann der Sperrmodus der Klappe verändert werden, die Ausgangssperre ein- oder ausgeschaltet werden oder der Aufenthaltsort des Haustiers aktualisiert werden, wenn es z.B. das Haus auf einem anderen Weg als der Klappe verlassen oder betreten hat. Für den Futterautomat und den Wasserspende werden die verbleibende Menge Wasser und Futter angezeigt, sowie wieviel und wie oft das Tier heute getrunken und/oder gefressen hat.
                          Vorraussetzungen
                          Um den Adapter sinnvoll einsetzen zu können, benötigt man eine Katzenklappe Connect oder Haustierklappe Connect oder Futterautomat Connect oder Felaqua Connect sowie einen Hub und einen Account für die Surepetcare App (Android oder Apple).
                          cooper2k4
                          schrieb am zuletzt editiert von cooper2k4
                          #92
                          ich habe seit ca. 3 Wochen das Problem, dass die Protokollierung via SQL-Adapter (sqlite) nicht mehr funktioniert. Ich kann mich leider an keine Änderung an der ioBroker Installation erinnern...
                          Wenn ich den sureflap-Adapter neustarte wird das Logging automatisch deaktiviert. Ich habe gerade von v1.2.3 auf v2.0.1 aktualisiert. Das hat aber keine Änderung gebracht. Mit anderen Adaptern funktioniert das SQL-Logging ohne Probleme. Liegt es am sureflap- oder SQL-Adapter?
                          Ich habe schon alles Mögliche probiert (npm cache clean/rebuild, iob Objekte löschen etc.). Weiß jemand noch Rat?
                          Viele Grüße
                          Thorsten
                          pi@iobroker:/opt/iobroker $ iob info
                          Platform       : linux
                          os             : linux
                          Architecture   : arm64
                          CPUs           : 4
                          Speed          : 1700 MHz
                          Model          : Cortex-A72
                          RAM            : 3.7 GB
                          System uptime  : 1d. 15:52:06
                          Node.js        : v20.5.1
                          time           : 1707651469831
                          timeOffset     : -60
                          NPM            : 10.4.0
                          adapters count : 530
                          Disk size      : 29.1 GiB
                          Disk free      : 9.2 GiB
                          • C cooper2k4
                            Viele Grüße
                            Thorsten
                            Platform       : linux
                            os             : linux
                            CPUs           : 4
                            Speed          : 1700 MHz
                            Model          : Cortex-A72
                            RAM            : 3.7 GB
                            Node.js        : v20.5.1
                            timeOffset     : -60
                            NPM            : 10.4.0
                            Disk free      : 9.2 GiB
                            #93
                            @cooper2k4
                            Installier nodejs/npm ordentlich.
                            iob nodejs-update 18
                            Und künftig die Finger von individuellen Installationen von npm lassen.
                              @cooper2k4
                              cooper2k4
                              #94
                              @thomas-braun sagte in Test Adapter sureflap v1.0.x GitHub:
                              Danke für den Hinweis. Das ändert aber nichts.
                              Platform       : linux
                              os             : linux
                              CPUs           : 4
                              Speed          : 1700 MHz
                              Model          : Cortex-A72
                              RAM            : 3.7 GB
                              System uptime  : 1d. 20:53:35
                              Node.js        : v18.17.1
                              time           : 1707669559211
                              timeOffset     : -60
                              NPM            : 10.4.0
                              Disk free      : 9.2 GiB
                              • C cooper2k4
                                Platform       : linux
                                os             : linux
                                CPUs           : 4
                                Speed          : 1700 MHz
                                Model          : Cortex-A72
                                RAM            : 3.7 GB
                                Node.js        : v18.17.1
                                timeOffset     : -60
                                NPM            : 10.4.0
                                Disk free      : 9.2 GiB
                                #95
                                @cooper2k4 sagte in Test Adapter sureflap v1.0.x GitHub:
                                Doch. Dann wäre die Laufzeitumgebung richtig.
                                Denn
                                Node.js : v18.17.1
                                NPM : 10.4.0
                                ist immer noch falsch.
                                iob stop
                                iob fix
                                iob start
                                ausführen.
                                  Denn
                                  Node.js : v18.17.1
                                  NPM : 10.4.0
                                  iob stop
                                  iob fix
                                  iob start
                                  ausführen.
                                  cooper2k4
                                  #96
                                  Die Laufzeitumgebung sollte jetzt richtig sein. Das ursprüngliche Problem besteht aber weiterhin.
                                                          v.2023-10-10
                                   Static hostname: iobroker
                                         Icon name: computer
                                            Kernel: Linux 6.1.21-v8+
                                      Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               arm64
                                  Timezone:               Europe/Berlin (CET, +0100)
                                  User-ID:                1000
                                  X-Server:               false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                          /usr/bin/node           v18.19.0
                                                          /usr/bin/npm            10.2.3
                                                          /usr/bin/npx            10.2.3
                                                          /usr/bin/corepack       0.22.0
                                  Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                  MEMORY:
                                  Mem:            4.0G        1.6G        679M        2.1M        1.8G        2.4G
                                  Swap:           1.3G        2.1M        1.3G
                                  Total:          5.3G        1.6G        2.0G
                                  Active iob-Instances:   17
                                  Active repo(s): stable
                                  ioBroker Core:          js-controller           5.0.17
                                                          admin                   6.13.16
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                  Objects:                10080
                                  States:                 7643
                                  Size of iob-Database:
                                  17M     /opt/iobroker/iobroker-data/objects.jsonl
                                  7.8M    /opt/iobroker/iobroker-data/objects.json.migrated
                                  7.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  9.0M    /opt/iobroker/iobroker-data/states.jsonl
                                  5.2M    /opt/iobroker/iobroker-data/states.json.migrated
                                  5.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  • C christianfeu
                                    @christianfeu
                                    Hilft das weiter?
                                    Sickboy78S Offline
                                    Sickboy78S Offline
                                    Sickboy78
                                    #97
                                    Hallo @christianfeu
                                    hab grad bei mir getestet und kann sowohl die Klappe als auch die Ausgangssperre per Adapter aktivieren und deaktivieren. Scheint also kein Problem mit der API zu sein.
                                    Dein Log hilft mir leider auch nicht weiter, da ist nichts Ungewöhnliches zu erkennen. Auch nicht welche Aktion du ausführst. Wenn du die Klappe verriegelst, sollte sowas im log stehen:
                                    2024-02-13 19:16:14.717 info lock mode changed to 1
                                    2024-02-13 19:16:12.427 debug changing lock mode to 1...
                                    Kannst du bitte nochmal einen Logauszug machen, wo die Aktion erkennbar ist, die du vor dem Absturz gemacht hast?
                                    Wenn der Adapter neu startet, sollte es solche Einträge im Log geben:
                                    2024-02-13 19:40:11.179 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.17
                                    2024-02-13 19:40:05.798 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-02-13 19:40:05.798 info terminating
                                    2024-02-13 19:40:05.798 info everything cleaned up
                                    2024-02-13 19:40:05.797 info Got terminate signal TERMINATE_YOURSELF
                                    Wenn du davon bitte auch nochmal einen Logauszug posten könntest.
                                    Auf was für einem Rechner läuft dein ioBroker? Wieviel Speicher hat der?
                                    • C cooper2k4
                                                              v.2023-10-10
                                             Icon name: computer
                                          Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               arm64
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            10.2.3
                                                              /usr/bin/npx            10.2.3
                                      MEMORY:
                                                              admin                   6.13.16
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                10080
                                      States:                 7643
                                      Sickboy78S Offline
                                      Sickboy78S Offline
                                      Sickboy78
                                      #98
                                      Hallo @cooper2k4
                                      interessantes Problem. Ich logge die battery Datenpunkte auch, ohne Probleme.
                                      Kannst du mal bitte posten was nach den disabled logging Einträgen im Log erscheint?
                                      Vorher bitte den Adapter auch auf debug oder silly umstellen.
                                        Hallo @christianfeu
                                        christianfeu
                                        #99
                                        @sickboy78
                                        erstmal danke für deine Antwort. Ich habe im Grunde ja 2 Probleme, die ich mir nicht erklären kann. Um die Sache im 1. Schritt zu vereinfachen, habe ich mir meinen Backup Raspberry 4 genommen und ioBroker frisch installiert und darauf den SureFlap Adapter eingerichtet. Auch hier habe ich das Problem, dass ich den lockmode und curfew nicht ausführen kann (Adapter Version ist unerheblich, es geht mit keiner Version). Wenn ich die Datenpunkte manuell (nicht bestätigt) ändere, bleiben diese auch rot. Egal wie ich das mache, ob manuell oder per VIS oder Skript, die Änderungen werden einfach nicht durchgereicht.
                                        Ich habe grundsätzlich mit dem Adapter Zugriff. Ich kann die Anwesenheit des Tiers per Adapter ändern und mir auch alle Änderungen der History per VIS visualisieren. In den Adapter Einstellungen sehe ich auch das Bild meiner Katze.
                                        Per SureFlap App kann ich alle Funktionen einwandfrei benutzen. Öffnen, Schließen, Zeitregel etc. Alles ohne Probleme. Der Hub ist 4m von der Klappe entfernt. Alles ist korrekt verbunden und eingerichtet. Allerdings habe ich die Hardware erst seit 3 Wochen.
                                        Katzenklappe Firmware: 1.1
                                        Katzenklappe Hardware: 1.2
                                        Hub Firmware: 734.50
                                        Hub Hardware: 3.0
                                        Ich kann mir das einfach nicht erklären. Warum kann ich die Klappe über die App steuern aber nicht über den Adapter?
                                        Das Log bringt wenig interessante Informationen, wenn ich curfew oder den lockmode ändere. Irgendwie hilft das nicht weiter.
                                        Woran kann das liegen?
                                        LOG Auszug bei Änderung lockmode. Danach kommt auch nichts mehr. Adapter ist auf maximale Protokollierungsstufe eingestellt.
                                        LOG-Auszug bei Neustart des Adapters:
                                        Raspberry Info:
                                        • C christianfeu
                                          @sickboy78
                                          Hub Hardware: 3.0
                                          Raspberry Info:
                                          Sickboy78S Offline
                                          Sickboy78S Offline
                                          Sickboy78
                                          #100
                                          Hallo @christianfeu
                                          Der Eintrag "lock mode changed to 0" bedeutet zumindest, dass der Aufruf an die Surepet API erfolgreich war und mit einem 200 OK quittiert wurde. Warum der Datenpunkt dann nicht aktualisiert wird, ist mir rätselhaft.
                                          Ändert sich eigentlich der Zustand in der App?
                                          Ich vermute, dass du eine neue Version der Katzenklappe hast und hier die Datenstruktur abweicht, da deine Versionen (1.1 und 1.2) ganz anders sind als bei mir (335.422 und 9). Um weiter zu analysieren, bräuchte ich aber einen Auszug aus dem Datenverkehr.
                                          Du scheinst dich auszukennen, darum verzichte ich mal auf die Erklärung, wie man sich die Requests im Browser mit den Entwicklertools anschaut. Falls nicht, sag bescheid.
                                          Und zwar hätte ich gerne die Antwort auf den PUT Request für eine Änderung des Lockmode.
                                          Dazu müsstest du im Browser https://surepetcare.io/ aufrufen dich anmelden und ähnlich wie in der App zu den Einstellungen der Klappe gehen und dort die Klappe ver- oder entriegeln.
                                          Da bräuchte ich dann die Antwort auf den PUT request https://app-api.production.surehub.io/api/device/.../control wie im Screenshot als unformatiertes JSON:
                                          Und dann hätte ich gerne noch, wenn du die Übersicht aufrufst https://surepetcare.io/dashboard, die Antwort auf den GET request https://app-api.production.surehub.io/api/me/start (wichtig, der request api/me/start nicht /api/start):
                                          Wichtig, wenn du das JSON (am besten als Textdatei) hier hochlädst, vorher persönliche Daten wie Email entfernen. Alternativ kannst du es mir auch direkt per Email senden: asmoday_666@gmx.de
