  4. Test Adapter sureflap v3.4.2
154 Beiträge 17 Kommentatoren 44.5k Aufrufe 19 Beobachtet
  • M Matis
    @sickboy78
    Ich fürchte mit js 5 ist der Adapter nicht mehr lauffähig, wird nach einigen Sekunden angehalten, da zuviele Fehler.
    2023-06-29 00:09:46.292 - error: sureflap.0 (896) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-06-29 00:09:46.296 - error: sureflap.0 (896) unhandled promise rejection: undefined is not a valid state value
    2023-06-29 00:09:46.301 - error: sureflap.0 (896) Error: undefined is not a valid state value
    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
    at Sureflap._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5376:49)
    at Sureflap.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5337:21)
    at Sureflap.setSerialNumberToAdapter (/opt/iobroker/node_modules/iobroker.sureflap/main.js:1288:9)
    at /opt/iobroker/node_modules/iobroker.sureflap/main.js:576:13
    at new Promise ()
    at Sureflap.getDeviceStatusFromData (/opt/iobroker/node_modules/iobroker.sureflap/main.js:554:39)
    at /opt/iobroker/node_modules/iobroker.sureflap/main.js:300:21
    2023-06-29 00:09:46.302 - error: sureflap.0 (896) undefined is not a valid state value
    2023-06-29 00:09:46.315 - warn: sureflap.0 (896) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-06-29 00:09:46.874 - warn: sureflap.0 (896) redis get sureflap.0.Eisvogel.Eisvogel.Katzenklappe.curfew.0.enabled, error - Connection is closed.
    2023-06-29 00:09:46.876 - error: sureflap.0 (896) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-06-29 00:09:46.876 - error: sureflap.0 (896) unhandled promise rejection: null
    2023-06-29 00:09:46.892 - warn: sureflap.0 (896) redis get sureflap.0.Eisvogel.Eisvogel.Katzenklappe.curfew.0.lock_time, error - Connection is closed.
    2023-06-29 00:09:46.894 - warn: sureflap.0 (896) redis get sureflap.0.Eisvogel.Eisvogel.Katzenklappe.curfew.0.unlock_time, error - Connection is closed.
    2023-06-29 00:09:46.966 - warn: sureflap.0 (896) get state error: Connection is closed.
    2023-06-29 00:09:46.968 - warn: sureflap.0 (896) get state error: Connection is closed.
    2023-06-29 00:09:46.970 - warn: sureflap.0 (896) get state error: Connection is closed.
    2023-06-29 00:09:46.979 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.2' (Error: DB closed)
    2023-06-29 00:09:46.980 - error: sureflap.0 (896) updating event history failed (undefined)
    2023-06-29 00:09:46.980 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.3' (Error: DB closed)
    2023-06-29 00:09:46.981 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.4' (Error: DB closed)
    2023-06-29 00:09:46.981 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.5' (Error: DB closed)
    2023-06-29 00:09:46.982 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.6' (Error: DB closed)
    2023-06-29 00:09:46.982 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.7' (Error: DB closed)
    2023-06-29 00:09:46.983 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.8' (Error: DB closed)
    2023-06-29 00:09:46.984 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.9' (Error: DB closed)
    2023-06-29 00:09:46.985 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.10' (Error: DB closed)
    2023-06-29 00:09:46.985 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.11' (Error: DB closed)
    2023-06-29 00:09:46.986 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.12' (Error: DB closed)
    2023-06-29 00:09:46.987 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.13' (Error: DB closed)
    2023-06-29 00:09:46.987 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.14' (Error: DB closed)
    2023-06-29 00:09:46.988 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.15' (Error: DB closed)
    2023-06-29 00:09:46.989 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.16' (Error: DB closed)
    2023-06-29 00:09:46.989 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.17' (Error: DB closed)
    2023-06-29 00:09:46.990 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.18' (Error: DB closed)
    2023-06-29 00:09:46.991 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.19' (Error: DB closed)
    2023-06-29 00:09:46.992 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.20' (Error: DB closed)
    2023-06-29 00:09:46.992 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.21' (Error: DB closed)
    2023-06-29 00:09:46.993 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.22' (Error: DB closed)
    2023-06-29 00:09:46.994 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.23' (Error: DB closed)
    2023-06-29 00:09:46.994 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.24' (Error: DB closed)
    2023-06-29 00:09:46.995 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.0' (Error: DB closed)
    2023-06-29 00:09:46.996 - error: sureflap.0 (896) could not delete object 'Eisvogel.history.1' (Error: DB closed)
    2023-06-29 00:09:47.164 - error: host.buanet-iobroker instance system.adapter.sureflap.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    Sickboy78S Offline
    Sickboy78S Offline
    Sickboy78
    #76
    Hi @matis, sollte seit v1.1.9 gefixed sein.
    • Sickboy78S Sickboy78
      Aktuelle Test Version 3.4.2
      Aktuelle Stable Version 3.4.2
      Veröffentlichungsdatum 09.01.2026
      Github Link https://github.com/Sickboy78/ioBroker.sureflap
      Beschreibung des Adapters
      Der Adapter erlaubt Zugriff auf Smarte Haustierklappen, Futterautomaten und Wasserspender von Surepetcare, einer der führenden Hersteller von smarten Katzenklappen und Futterautomaten mit App-Integration am Markt.
      Es werden Statuswerte zum Hub (LED und Verbindung) und zur Katzenklappe (Batterie, Verbindung, Sperrmodus und Ausgangssperre) angezeigt. Es wird der Aufenthaltsort (drin oder draußen, seit) des oder der Haustiere angezeigt.
      Über den Adapter kann der Sperrmodus der Klappe verändert werden, die Ausgangssperre ein- oder ausgeschaltet werden oder der Aufenthaltsort des Haustiers aktualisiert werden, wenn es z.B. das Haus auf einem anderen Weg als der Klappe verlassen oder betreten hat. Für den Futterautomat und den Wasserspende werden die verbleibende Menge Wasser und Futter angezeigt, sowie wieviel und wie oft das Tier heute getrunken und/oder gefressen hat.
      Vorraussetzungen
      Um den Adapter sinnvoll einsetzen zu können, benötigt man eine Katzenklappe Connect oder Haustierklappe Connect oder Futterautomat Connect oder Felaqua Connect sowie einen Hub und einen Account für die Surepetcare App (Android oder Apple).
      Sickboy78S Offline
      Sickboy78S Offline
      Sickboy78
      schrieb am zuletzt editiert von Sickboy78
      #77
      Version 1.2.0 ist da mit einigen Verbesserungen bei Timeout und Fehlerbehandlung.
      Außerdem kann der Adapter nun mit umbenannten oder gelöschten Haustiere umgehen.
      English:
      Version 1.2.0 is out with improvemnents for timeout and error handling.
      Also renamed or removed pets are now handeled by the adapter.
      Sickboy78S 1 Antwort Letzte Antwort
        English:
        Sickboy78S Offline
        Sickboy78S Offline
        Sickboy78
        #78
        Surepet hat einige kritische Änderungen an der API vorgenommen. Ich arbeite daran, das Problem zu beheben, habe bereits 3 Änderungen gefunden und sie behoben/umgangen. Eine neue Version kommt in den nächsten Stunden/Tagen. Als schnelle Lösung, kann der Adapter direkt von Github installiert werden. Falls danach immer noch Probleme auftreten, bitte hier oder auf github melden.
        English:
        Surepet has made some breaking changes to the API. I'm working to resolve the issue, already found 3 changes and fixed/worked around them. I'll probably push a new version in the next hours/days. Feel free to update directly from github, for a quick fix. If you still have issues after this, please report them here or on github.
          English:
          Sickboy78S Offline
          Sickboy78S Offline
          Sickboy78
          #79
          Es scheint, dass Surepet seine Änderungen an der API zurückgerollt hat. Vielleicht weil sie auch Probleme mit ihrer App gemacht haben. Jedenfalls habe ich eine Version 1.2.1 erstellt, die für die API-Änderungen vorbereitet ist, falls sie wieder ausgerollt werden.
          English:
          It seems Surepet has rolled back it's changes to their API. Probably because it made also problems with their App.
          Anyway I made a 1.2.1 version which is prepared for the API changes, when they are released again.
            Stefi
            #80
            @sickboy78 kannst du mir eventuell weiterhelfen? Seit dem Update des js-controllers bekomme ich den Adapter weder mit der 1.2.0 noch mit der 1.1.9 ans Laufen :(
            2023-10-17 21:02:29.544 - info: sureflap.0 (288818) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.12
            2023-10-17 21:02:29.588 - info: sureflap.0 (288818) checking adapter configuration...
            2023-10-17 21:02:29.589 - info: sureflap.0 (288818) sureflap battery voltage full: 6.1
            2023-10-17 21:02:29.590 - info: sureflap.0 (288818) sureflap battery voltage empty: 5.1
            2023-10-17 21:02:29.591 - info: sureflap.0 (288818) surefeed battery voltage full: 6.2
            2023-10-17 21:02:29.592 - info: sureflap.0 (288818) surefeed battery voltage empty: 5.2
            2023-10-17 21:02:29.593 - info: sureflap.0 (288818) felaqua battery voltage full: 6.2
            2023-10-17 21:02:29.593 - info: sureflap.0 (288818) felaqua battery voltage empty: 5.2
            2023-10-17 21:02:29.594 - info: sureflap.0 (288818) adapter configuration ok
            2023-10-17 21:02:29.598 - info: sureflap.0 (288818) connecting...
            2023-10-17 21:02:30.369 - info: sureflap.0 (288818) connected
            2023-10-17 21:02:30.371 - info: sureflap.0 (288818) starting update loop...
            2023-10-17 21:02:30.379 - info: sureflap.0 (288818) update loop started
            2023-10-17 21:02:37.407 - info: admin.0 (174) <== Disconnect system.user.admin from ::ffff:192.168.178.100
            2023-10-17 21:02:39.022 - warn: sureflap.0 (288818) no remaining food data for feeder 'Lia_s_Futterbox' found
            2023-10-17 21:02:39.024 - warn: sureflap.0 (288818) no remaining food data for feeder 'Benjis_Futterbox' found
            2023-10-17 21:02:39.028 - warn: sureflap.0 (288818) aggregated report for pet 'Benji' does not contain feeding data
            2023-10-17 21:02:39.029 - warn: sureflap.0 (288818) aggregated report for pet 'Lia' does not contain feeding data
            2023-10-17 21:02:39.057 - error: sureflap.0 (288818) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-10-17 21:02:39.058 - error: sureflap.0 (288818) unhandled promise rejection: undefined is not a valid state value
            2023-10-17 21:02:39.062 - error: sureflap.0 (288818) Error: undefined is not a valid state value
            at Sureflap._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49)
            at Sureflap.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21)
            at Immediate. (/opt/iobroker/node_modules/iobroker.sureflap/main.js:1099:12)
            at process.processImmediate (node:internal/timers:478:21)
            2023-10-17 21:02:39.063 - error: sureflap.0 (288818) undefined is not a valid state value
            2023-10-17 21:02:39.093 - info: sureflap.0 (288818) everything cleaned up
            2023-10-17 21:02:39.095 - info: sureflap.0 (288818) terminating
            2023-10-17 21:02:39.096 - warn: sureflap.0 (288818) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-10-17 21:02:39.640 - info: sureflap.0 (288818) terminating
            • S Stefi
              Sickboy78S Offline
              Sickboy78S Offline
              Sickboy78
              #81
              Hallo @stefi, das sieht mir nach einem der Probleme durch die API Änderungen aus. Probier doch bitte mal die 1.2.1 aus.
              Falls das nicht hilft, sag Bescheid, dann muss ich es mir genauer ansehen.
                Stefi
                #82
                @sickboy78 Hi, habe es endlich geschafft auf die 1.2.1 zu aktualisieren. Aber es scheint noch immer nicht zu gehen:
                sureflap.0
                2023-11-26 20:46:34.517	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                sureflap.0
                2023-11-26 20:46:34.461	error	adapter disabled
                sureflap.0
                2023-11-26 20:46:01.951	info	terminating
                sureflap.0
                2023-11-26 20:46:01.438	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                sureflap.0
                2023-11-26 20:46:01.436	info	terminating
                sureflap.0
                2023-11-26 20:46:01.435	info	everything cleaned up
                sureflap.0
                2023-11-26 20:46:01.433	error	unhandled promise rejection: null
                sureflap.0
                2023-11-26 20:46:01.432	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                sureflap.0
                2023-11-26 20:45:51.866	info	update loop started
                sureflap.0
                2023-11-26 20:45:51.858	info	starting update loop...
                sureflap.0
                2023-11-26 20:45:51.857	info	connected
                sureflap.0
                2023-11-26 20:45:50.894	info	connecting...
                sureflap.0
                2023-11-26 20:45:50.889	info	adapter configuration ok
                sureflap.0
                2023-11-26 20:45:50.888	info	felaqua battery voltage empty: 5.2
                sureflap.0
                2023-11-26 20:45:50.888	info	felaqua battery voltage full: 6.2
                sureflap.0
                2023-11-26 20:45:50.887	info	surefeed battery voltage empty: 5.2
                sureflap.0
                2023-11-26 20:45:50.886	info	surefeed battery voltage full: 6.2
                sureflap.0
                2023-11-26 20:45:50.886	info	sureflap battery voltage empty: 5.1
                sureflap.0
                2023-11-26 20:45:50.884	info	sureflap battery voltage full: 6.1
                sureflap.0
                2023-11-26 20:45:50.883	info	checking adapter configuration...
                sureflap.0
                2023-11-26 20:45:50.839	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.sureflap, node: v18.17.1, js-controller: 5.0.16
                Hilft dir das etwas?
                Liebe Grüße,
                Stefi
                Thomas BraunT Sickboy78S 2 Antworten Letzte Antwort
                • S Stefi
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  sureflap.0
                  Liebe Grüße,
                  Stefi
                  #83
                  @stefi sagte in Test Adapter sureflap v1.0.x GitHub:
                  node: v18.17.1
                  Zu alt, aktualisier das per
                  iob nodejs-update
                  • S Stefi
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    sureflap.0
                    Liebe Grüße,
                    Stefi
                    Sickboy78S Offline
                    Sickboy78S Offline
                    Sickboy78
                    #84
                    Sure Petcare hat seine App auf eine neue API umgestellt. Ich weiß nicht, wann die alte API abgeschaltet wird.
                    Ab Version 1.2.3 kann man die API konfigurieren und standardmäßig wird die neue API verwendet.
                    Falls der Adapter also plötzlich nicht mehr funktioniert, bitte auf eine Version >=1.2.3 upgraden.
                    Ich habe alle Funktionen mit der neuen API erfolgreich getestet. Falls euch Probleme oder Funktionen auffallen, die nicht mehr funktionieren, bitte hier im Forum oder auf Github https://github.com/Sickboy78/ioBroker.sureflap/issues bescheid geben.
                    Ich wünsche euch allen einen Guten Rutsch ins neue Jahr!
                    English:
                    Sure Petcare has changed its app to a new API. I don't know when the old API will be switched off.
                    From version 1.2.3 you can configure the API and the new API is used by default.
                    So if the adapter suddenly stops working for you, please upgrade to a version >=1.2.3.
                    I have successfully tested all functions with the new API. If you notice any problems or functions that no longer work, please let me know here in the forum or on Github https://github.com/Sickboy78/ioBroker.sureflap/issues.
                    I wish you all a Happy New Year!
                    @Stefi
                    Ich hoffe ich habe dein Problem mit der neuesten Version behoben. Bitte probier mal Version 1.2.3 (auf dem latest repository oder direkt von github) und gib mir Bescheid, ob es funktioniert hat.
                      English:
                      @Stefi
                      Sickboy78S Offline
                      Sickboy78S Offline
                      Sickboy78
                      #85
                      Version 2.0.1 ist da und zeigt nun an, welches Tier zuletzt durch welche Klappe gegangen ist. Das ist vor allem für diejenigen interessant, die sich mit mehreren Klappen eine "Schleuse" gebaut haben. Außerdem gibt es Datenpunkte für wie oft und wie lange jedes Tier draußen war.
                      Anmerkung: Die movement.last_* Datenpunkte enthalten nur tatsächliche Bewegungen durch eine Klappe, aber keine Änderung der Position, die per App oder Adapter vorgenommen wurde.
                      English:
                      Version 2.0.1 is now available and shows which animal last passed through which flap. This is particularly interesting for those who have built a "sluice" with several flaps. There are also data points for how often and for how long each animal was outside.
                      Note: The movement.last_* data points only contain actual movements through a flap, but no location change made via app or adapter.
                      C 1 Antwort Letzte Antwort
                        English:
                        christianfeu
                        #86
                        @sickboy78
                        Hallo, vielen Dank erstmal für diesen Adapter. Ich bin noch relativ neu bei SureFlap und habe meine Katzenklappe erst seit vergangener Woche. Bei mir hat die Stable 1.3.2 ein paar Tage funktioniert und auch die 2.0.1 lief bei mir. Seit ein paar Tagen gibt es bei mir aber Probleme. Ich kann die Klappe nicht mehr per Adapter verriegeln oder entriegeln. Das manuelle Setzen der An- oder Abwesenheit funktioniert aber. Weiterhin stürzt bei mir mir alle 20-30 min der javascript Adapter ab. Nur dann wenn der Sureflap Adapter läuft. Sobald er gestoppt wird, läuft wieder alles stabil. Die Probleme betreffen sowohl 1.3.2 als auch 2.0.1 & 2.0.2. Mein iobroker ist auf dem aktuellen Stand, node und js sind aktuell.
                        Bin ich der Einzige mit diesen Problemen? Sind das Probleme durch die neue API seitens SureFlap?
                        • C christianfeu
                          @sickboy78
                          #87
                          @christianfeu
                          Und im Log steht dazu genau was?
                            @christianfeu
                            christianfeu
                            schrieb am zuletzt editiert von christianfeu
                            #88
                            Sehr schwierige Frage: kein Error, kein Warn, weder bei javascript noch beim sureflap
                            Was genau ist die Frage? Das Protokoll ist groß….
                            • C christianfeu
                              @sickboy78
                              #89
                              @christianfeu sagte in Test Adapter sureflap v1.0.x GitHub:
                              Das tut der unter Garantie nicht lautlos.
                              Schau in
                              iob logs --watch
                              uns spiel mit dem Adapter herum.
                                Schau in
                                iob logs --watch
                                christianfeu
                                #90
                                ok mache ich. Vielen Dank.
                                Wollte erstmal rausfinden, ob ich der einzige bin mit Problemen…
                                • C christianfeu
                                  christianfeu
                                  #91
                                  @christianfeu
                                  Also, in dem Moment wo ich eine Aktion über den SureFlap Adapter ansteuere und ein paar Sekunden später stürzt der Javascript Adapter ab. Habe das jetzt exakt beobachtet. Beim Absturz kommen Meldungen, die mit Redis zusammenhängen.
                                  Hilft das weiter?
                                  2024-02-08 19:57:40.560 - silly: sureflap.0 (102333) doing http request with tag get_data
                                  2024-02-08 19:57:50.615 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.inputCount
                                  2024-02-08 19:57:50.716 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cputime
                                  2024-02-08 19:57:50.717 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.alive
                                  2024-02-08 19:57:51.019 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.cpu
                                  2024-02-08 19:57:51.052 - silly: sureflap.0 (102333) doing http request with tag get_data
                                  2024-02-08 19:57:51.122 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.outputCount
                                  2024-02-08 19:57:51.123 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.eventLoopLag
                                  2024-02-08 19:57:51.632 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapUsed
                                  2024-02-08 19:57:51.935 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memHeapTotal
                                  2024-02-08 19:57:52.140 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.memRss
                                  2024-02-08 19:57:52.343 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.connected
                                  2024-02-08 19:57:52.344 - silly: sureflap.0 (102333) redis message expired/evicted keyevent@0:expired:io.system.adapter.javascript.0.uptime
                                  2024-02-08 19:58:01.520 - silly: sureflap.0 (102333) doing http request with tag get_data
                                    Vorraussetzungen
                                    cooper2k4
                                    schrieb am zuletzt editiert von cooper2k4
                                    #92
                                    ich habe seit ca. 3 Wochen das Problem, dass die Protokollierung via SQL-Adapter (sqlite) nicht mehr funktioniert. Ich kann mich leider an keine Änderung an der ioBroker Installation erinnern...
                                    Wenn ich den sureflap-Adapter neustarte wird das Logging automatisch deaktiviert. Ich habe gerade von v1.2.3 auf v2.0.1 aktualisiert. Das hat aber keine Änderung gebracht. Mit anderen Adaptern funktioniert das SQL-Logging ohne Probleme. Liegt es am sureflap- oder SQL-Adapter?
                                    Ich habe schon alles Mögliche probiert (npm cache clean/rebuild, iob Objekte löschen etc.). Weiß jemand noch Rat?
                                    Viele Grüße
                                    Thorsten
                                    pi@iobroker:/opt/iobroker $ iob info
                                    Platform       : linux
                                    os             : linux
                                    Architecture   : arm64
                                    CPUs           : 4
                                    Speed          : 1700 MHz
                                    Model          : Cortex-A72
                                    RAM            : 3.7 GB
                                    System uptime  : 1d. 15:52:06
                                    Node.js        : v20.5.1
                                    time           : 1707651469831
                                    timeOffset     : -60
                                    NPM            : 10.4.0
                                    adapters count : 530
                                    Disk size      : 29.1 GiB
                                    Disk free      : 9.2 GiB
                                    • C cooper2k4
                                      Viele Grüße
                                      Thorsten
                                      Platform       : linux
                                      os             : linux
                                      CPUs           : 4
                                      Speed          : 1700 MHz
                                      Model          : Cortex-A72
                                      RAM            : 3.7 GB
                                      Node.js        : v20.5.1
                                      timeOffset     : -60
                                      NPM            : 10.4.0
                                      Disk free      : 9.2 GiB
                                      #93
                                      @cooper2k4
                                      Installier nodejs/npm ordentlich.
                                      iob nodejs-update 18
                                      Und künftig die Finger von individuellen Installationen von npm lassen.
                                        @cooper2k4
                                        cooper2k4
                                        #94
                                        @thomas-braun sagte in Test Adapter sureflap v1.0.x GitHub:
                                        Danke für den Hinweis. Das ändert aber nichts.
                                        Platform       : linux
                                        os             : linux
                                        CPUs           : 4
                                        Speed          : 1700 MHz
                                        Model          : Cortex-A72
                                        RAM            : 3.7 GB
                                        System uptime  : 1d. 20:53:35
                                        Node.js        : v18.17.1
                                        time           : 1707669559211
                                        timeOffset     : -60
                                        NPM            : 10.4.0
                                        Disk free      : 9.2 GiB
                                        • C cooper2k4
                                          Platform       : linux
                                          os             : linux
                                          CPUs           : 4
                                          Speed          : 1700 MHz
                                          Model          : Cortex-A72
                                          RAM            : 3.7 GB
                                          Node.js        : v18.17.1
                                          timeOffset     : -60
                                          NPM            : 10.4.0
                                          Disk free      : 9.2 GiB
                                          #95
                                          @cooper2k4 sagte in Test Adapter sureflap v1.0.x GitHub:
                                          Doch. Dann wäre die Laufzeitumgebung richtig.
                                          Denn
                                          Node.js : v18.17.1
                                          NPM : 10.4.0
                                          ist immer noch falsch.
                                          iob stop
                                          iob fix
                                          iob start
                                          ausführen.
