  4. Solarprognose
    6.3k
Solarprognose
solarprognoseadapterjavascript
158 Beiträge 28 Kommentatoren 39.8k Aufrufe 31 Beobachtet
  • Palm_ManiacP Palm_Maniac
    @wendy2702
    Das hier:
    const url = 'http://www.solarprognose.de/web/solarprediction/api/v1?_format=json&access-token=....&item=inverter&id=412&type=hourly';
    const path = '0_userdata.0.SolarGraph.';
    const idLeistung_Energie = path + 'Leistung_Energie';
    const idEnergieMaxHeute = path + 'EnergieMaxHeute';
    const idEnergieMaxMorgen = path + 'EnergieMaxMorgen';
    var Leistung_Energie = {
        "axisLabels": ["8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18", "8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18"],
        "graphs": [{
            "data": [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0],
            "type": "line",
            "legendText":"Leistung",
            "yAxis_min": 0,
            "yAxis_max": 8,
            "yAxis_step": 1,
            "yAxis_position": "left",
            "yAxis_appendix": " kW",
            "datalabel_show": false
            "type": "line",
            "line_UseFillColor": true,
            "legendText":"Energie",
            "yAxis_min": 0,
            "yAxis_max": 64,
            "yAxis_step": 8,
            "yAxis_position": "right",
            "yAxis_appendix": " kWh",
            "yAxis_color": "#91d430",
    createState(idLeistung_Energie, JSON.stringify(Leistung_Energie), {type: 'string', name: 'Leistung_Energie', role: 'table'});
    createState(idEnergieMaxHeute, 0, {type: 'number', role: 'value', name: 'EnergieMaxHeute', read: true, write: false, unit: 'kWh'});
    createState(idEnergieMaxMorgen, 0, {type: 'number', role: 'value', name: 'EnergieMaxMorgen', read: true, write: false, unit: 'kWh'});
    schedule('5 7,9,12,14,16,18 * * *', function() {
        request(url, function (error, response, result) {
            if(error) log(error, 'error');
            else {
                let obj = JSON.parse(result);
                if(obj.status) log('Fehler: ' + obj.status, 'warn');
                else {
                    let data = obj.data;
                    Leistung_Energie.axisLabels = [];
                    Leistung_Energie.graphs[0].data = [];
                    Leistung_Energie.graphs[1].data = [];
                    let i = 0;
                    for(let entry in data) {
                        let time = formatDate(parseInt(entry), 'hh');
                        Leistung_Energie.axisLabels.push(time);
                        Leistung_Energie.graphs[0].data.push(data[entry][0]);
                        Leistung_Energie.graphs[1].data.push(data[entry][1]);
                        if (time == '19')
                           if (i == 0) { setState(idEnergieMaxHeute, data[entry][1], true);  i = i+1 }
                           else         setState(idEnergieMaxMorgen, data[entry][1], true);
                    setState(idLeistung_Energie, JSON.stringify(Leistung_Energie), true);
    Diamand2k22
    #129
    Von hier und dann erweitert anstatt 18->22 uhr.
    Dieses Skript habe ich noch zusätzlich in das erste mit eingefügt am Ende, wo er dann Leistung und Energie jeweils seperat aufdröselt.
    const url = 'hier die komplette URL eintragen';
    const path = '0_userdata.0.Solar.';
    const idLeistung = path + 'Leistung.';
    const idEnergie  = path + 'Energie.';
    schedule('16 4-22 * * *', function() {
            else {
                else {
                        let time = formatDate(parseInt(entry), 'MM-DD.hh:mm');
                        if(existsState(idLeistung + time)) setState(idLeistung + time, data[entry][0], true);
                        else createState(idLeistung + time, data[entry][0], {
                            type: 'number',
                            role: 'value',
                            name: 'Solarleistung ' + formatDate(parseInt(entry), 'DD.MM. hh:mm'),
                            read: true,
                            write: false,
                            unit: 'kW'
                        if(existsState(idEnergie + time)) setState(idEnergie + time, data[entry][1], true);
                        else createState(idEnergie + time, data[entry][1], {
                            type: 'number',
                            role: 'value',
                            name: 'Solarenergie ' + formatDate(parseInt(entry), 'DD.MM. hh:mm'),
                            read: true,
                            write: false,
                            unit: 'kWh'
    @palm_maniac said in Solarprognose:
    @wendy2702
    Das hier:
        "graphs": [{
            "type": "line",
            "yAxis_min": 0,
            "yAxis_max": 8,
            "yAxis_step": 1,
            "type": "line",
            "yAxis_min": 0,
            "yAxis_max": 64,
            "yAxis_step": 8,
            else {
                else {
                    let i = 0;
                        if (time == '19')
    • D Diamand2k22
              else {
                  else {
                              type: 'number',
                              role: 'value',
                              read: true,
                              write: false,
                              unit: 'kW'
                              type: 'number',
                              role: 'value',
                              read: true,
                              write: false,
                              unit: 'kWh'
      @wendy2702
      Das hier:
          "graphs": [{
              "type": "line",
              "yAxis_min": 0,
              "yAxis_max": 8,
              "yAxis_step": 1,
              "type": "line",
              "yAxis_min": 0,
              "yAxis_max": 64,
              "yAxis_step": 8,
              else {
                  else {
                      let i = 0;
                          if (time == '19')
      #130
      @diamand2k22
      Ändere mal Zeilen 61 bis 63 in
                          if (time == '22') {
                             if (i == 0) setState(idEnergieMaxHeute, data[entry][1], true);
                             else if(i == 1) setState(idEnergieMaxMorgen, data[entry][1], true);
                             i++;
                          if (i > 1) break;
        @diamand2k22
                            if (time == '22') {
                               i++;
                            if (i > 1) break;
        Diamand2k22
        #131
        das hat funktioniert, danke!
        • D Diamand2k22
          SkeeveKlah
          #132
          als frisch gebackener Photonenjäger würde es mich interessieren wie die Daten der Prognose nach Grafana zu bekommen sind. Das es der eine oder andere versucht hat konnte ich im Threadverlauf lesen, aber wie gelingt es letztendlich?! Die Daten müssten nach meinem Verständnis zu erst in die InfluxDB?!
          Könnt Ihr einem PV- und Grafana-Neuling auf die Sprünge helfen?
          Danke!
          Grüße aus dem Sauerland
          Marc
          RPI4 8GB mit SSD-RAID1, ioBroker mit Debmatic
            drdoener
            #133
            Hallo zsm,
            habe die selbe Baustelle wie SkeeveKlah.
            Die Daten von Solarprognose kann ich einwandfrei über dieses Script hier und auch über eine selbst entwickelte Abfrage in Nodered beziehen.
            Ich möchte die Werte aber u.a. zur Visualiserung in Grafana in meiner influxdb haben.
            Aktuell mache ich den Workaround über einen weiteren Pi, auf dem "solaranzeige" läuft. Dort werden die Daten so mittels php-script in eine influx geschrieben:
            Dies würde ich gerne direkt (ohne den Umweg über "solaranzeige") umsetzen.
            Hat dies schon jmd umgesetzt oder einen guten Weg dafür auf Lager?
            Danke,
            Michael
            • S SkeeveKlah
              Danke!
              drdoener
              #134
              @skeeveklah
              Hi, hier findest Du eine Lösung, via Node-Red.
              https://forum.iobroker.net/topic/68650/object-daten-in-influx-db-speichern/21
              • DocdanD Offline
                DocdanD Offline
                Docdan
                schrieb am zuletzt editiert von Docdan
                #135
                Bin noch recht neu hier im Forum, lese aber schon eine Weile mit und habe auch schon vieles erfolgreich mit eurer Hilfe eingerichtet.
                Hat jemand dieses Script noch im Einsatz oder nutzt ihr inzwischen einen anderen Weg, die Daten von "Solarprognose.de" in den IOB zu bekommen. Ich habe viele verschieden Versionen des Skriptes aus diesem Thread in JS ausprobiert, bekomme aber immer denselben Fehler:
                script.js.Smarthome.Solarprognose.Prognose: Fehler: -8
                Hier der code den ich benutze:
                const url = 'http://www.solarprognose.de/web/solarprediction/api/v1?_format=json&access-token=78f1........ce0f&item=inverter&id=43..&type=hourly';
                        else {
                            else {
                                        type: 'number',
                                        role: 'value',
                                        read: true,
                                        write: false,
                                        unit: 'kW'
                                        type: 'number',
                                        role: 'value',
                                        read: true,
                                        write: false,
                                        unit: 'kWh'
                Hat jemand hierzu eine Idee oder kann nochmal ein funktionierendes Script posten?
                Danke,
                Jens
                • DocdanD Offline
                  DocdanD Offline
                  Docdan
                  #136
                  Soweit ich jetzt herausbekommen habe hat es mit dem Code in Zeile 7 zu tun:
                  Der geht wohl so nicht mehr. Ich habe keine Ahnung von JS, kann da jemand helfen wie das Script umgeschrieben werden muss, damit es wieder funktioniert?
                  • DocdanD Docdan
                            else {
                                else {
                                            type: 'number',
                                            role: 'value',
                                            read: true,
                                            write: false,
                                            unit: 'kW'
                                            type: 'number',
                                            role: 'value',
                                            read: true,
                                            write: false,
                                            unit: 'kWh'
                    Danke,
                    Jens
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #137
                    @docdan sagte in Solarprognose:
                    Wenn du die angegeben URL im Browser aufrufst ,ist dort ein -8 enthalten .
                    EDIT :
                    Nutze dieses nicht ....
                    aber bei den anderen hier im Thread sieht die URL anders am Ende aus !?
                    DocdanD 1 Antwort Letzte Antwort
                    • GlasfaserG Glasfaser
                      EDIT :
                      DocdanD Offline
                      DocdanD Offline
                      Docdan
                      #138
                      @glasfaser
                      Der Aufruf über die URL scheint zu klappen, da auf der Webseite von Solarprognose.de API Zugriffe registriert werden.
                      Irgendwie scheint JS mit der Response Funktion ein Problem zu haben.
                      • DocdanD Offline
                        DocdanD Offline
                        Docdan
                        #139
                        Ich habe mir die url nochmal angesehen, die war tatsächlich nicht ganz korrekt. Passt jetzt aber. Das Problem war die die Abrufzeit, da gibt die API bei mir eine Minute vor, in der abgerufen werden soll. Das passt jetzt auch. Die Objekte werden jetzt auch richtig angelegt, nur stehen keine Werte drin, nur 0? 😟
                        • DocdanD Docdan
                          Meister MopperM Online
                          Meister Mopper
                          schrieb am zuletzt editiert von Meister Mopper
                          #140
                          Wie hast du das im code gelöst? Die Vorgabe für die API ist bei mir Minute 7 mit einem sleep von 45 Sekunden.
                          Proxmox und HA ...
                            DocdanD Offline
                            DocdanD Offline
                            Docdan
                            #141
                            @meister-mopper
                            Ich habe auch Minute 7 und Sleep 39, Habe das genauso jetzt eingebaut, dann alle Datenpunkte nochmals gelöscht, jetzt läuft es einwandfrei.
                            Jetzt habe ich nur noch das Problem, die Daten in Grafana anzeigen zu können, ähnlich zu dem PV-Forecast Adapter 🙄
                            Hat das jemand hinbekommen?
                            • DocdanD Docdan
                              @meister-mopper
                              Meister Mopper
                              #142
                              Ja, das genau war meine Frage: Wie hast du es im Skript eingebaut?
                              Proxmox und HA ...
                                DocdanD Offline
                                DocdanD Offline
                                Docdan
                                #143
                                @meister-mopper
                                So! Bisher läuft es!
                                schedule('7 4-22 * * *', function() {
                                    sleep(39000)
                                DocdanD arteckA 2 Antworten Letzte Antwort
                                • DocdanD Docdan
                                  @meister-mopper
                                      sleep(39000)
                                  DocdanD Offline
                                  DocdanD Offline
                                  Docdan
                                  #144
                                  @docdan said in Solarprognose:
                                  @meister-mopper
                                      sleep(39000)
                                  • DocdanD Docdan
                                    @meister-mopper
                                        sleep(39000)
                                    Meister Mopper
                                    #145
                                    @meister-mopper
                                        sleep(39000)
                                    Ich danke dir, das probier ich aus.
                                    Proxmox und HA ...
                                      @meister-mopper
                                          sleep(39000)
                                      DocdanD Offline
                                      DocdanD Offline
                                      Docdan
                                      #146
                                      @meister-mopper
                                      So wie beschrieben funktioniert es nicht, leider!
                                      Habe es jetzt folgendermaßen abgeändert, das scheint erstmal zu klappen, werde es aber weiter beobachten:
                                      function sleep(ms) {
                                        return new Promise(resolve => setTimeout(resolve, ms));
                                      async function Waiting() {
                                        console.log('Going to sleep...');
                                        await sleep(39000); // Sleep for 39 seconds
                                        console.log('Done sleeping.');
                                          Waiting();
                                              if(error) log(error, 'error');```
                                      • DocdanD Offline
                                        DocdanD Offline
                                        Docdan
                                        #147
                                        irgendwie funktioniert das alles nicht! Es wird zwar im Log eine Pause eingelegt aber im Hintergrund läuft das Script weiter.
                                        Ich habe jetzt alles wieder rausgenommen und mache die Abfrage nur in Minute 7. Ohne die Pause (bei mir sind 39 Sekunden vorgegeben).
                                        Das funktioniert soweit ohne Probleme.
                                        Hat jemand einen Tipp, wie ich die Datenpunkte in Grafana über InfluxDB in einem Diagramm darstellen kann. Wenn ich die Datenpunkte über den Influx Adapter in die Datenpunkte schreibe bekomme ich auch einen Datenpunkt in Grafana angezeigt, kann das aber nicht vernünftig in einem Diagramm darstellen. Ich möchte für jede Stunde den Letzten Wert in einem Timeline Chart darstellen, so wie in folgendem Bild.
                                        Hier kommen die Daten aber aus dem PVForecast Adapter und ich schaffe es einfach nicht, die Daten aus dem Script genauso darzustellen.
                                        • DocdanD Docdan
                                          Meister Mopper
                                          #148
                                          Bei mir funktioniert es mit deiner Hilfe sehr gut und ich bekomme stündliche Prognosen.
                                          const path = '0_userdata.0.Energie.PV.Prognose.';
                                          sleep(45000)
                                          Die Daten kommen rein
                                          Was meinst du damit, natürlich läuft das Script, solange es aktiviert ist?
                                          Proxmox und HA ...
