  4. Slave startet nicht mehr
43 Beiträge 4 Kommentatoren 4.8k Aufrufe 2 Beobachtet
    @wusa
    Temp directories causing npm8 problem: 6
    Some problems detected, please run iob fix
    Damit mal anfangen. Also
    iob fix
    Dann
    cd /opt/iobroker
    npm ls
    anschauen.
    W Offline
    W Offline
    wusa
    iob fix
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@iob-slave:~ $ iobroker start
    pi@iob-slave:~ $ cd /opt/iobroker/
    pi@iob-slave:/opt/iobroker $ npm ls
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @buttercup/fetch@0.1.2 /opt/iobroker/node_modules/@buttercup/fetch
    npm ERR! extraneous: @googleapis/drive@8.4.0 /opt/iobroker/node_modules/@googleapis/drive
    npm ERR! extraneous: @microsoft/microsoft-graph-types@2.38.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
    npm ERR! extraneous: @sindresorhus/is@5.6.0 /opt/iobroker/node_modules/@sindresorhus/is
    npm ERR! extraneous: @szmarczak/http-timer@5.0.1 /opt/iobroker/node_modules/@szmarczak/http-timer
    npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
    npm ERR! extraneous: append-field@ /opt/iobroker/node_modules/append-field
    npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
    npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
    npm ERR! extraneous: bignumber.js@9.1.2 /opt/iobroker/node_modules/bignumber.js
    npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
    npm ERR! extraneous: cacheable-lookup@7.0.0 /opt/iobroker/node_modules/cacheable-lookup
    npm ERR! extraneous: cacheable-request@10.2.13 /opt/iobroker/node_modules/cacheable-request
    npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
    npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
    npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
    npm ERR! extraneous: cors@ /opt/iobroker/node_modules/cors
    npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
    npm ERR! extraneous: data-uri-to-buffer@4.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
    npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
    npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
    npm ERR! extraneous: dropbox-v2-api@2.5.10 /opt/iobroker/node_modules/dropbox-v2-api
    npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
    npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
    npm ERR! extraneous: fetch-blob@3.2.0 /opt/iobroker/node_modules/fetch-blob
    npm ERR! extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
    npm ERR! extraneous: formdata-polyfill@4.0.10 /opt/iobroker/node_modules/formdata-polyfill
    npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
    npm ERR! extraneous: gaxios@6.1.1 /opt/iobroker/node_modules/gaxios
    npm ERR! extraneous: gcp-metadata@6.1.0 /opt/iobroker/node_modules/gcp-metadata
    npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
    npm ERR! extraneous: googleapis-common@7.0.1 /opt/iobroker/node_modules/googleapis-common
    npm ERR! extraneous: got@12.6.0 /opt/iobroker/node_modules/got
    npm ERR! extraneous: gtoken@7.0.1 /opt/iobroker/node_modules/gtoken
    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
    npm ERR! extraneous: hot-patcher@2.0.1 /opt/iobroker/node_modules/hot-patcher
    npm ERR! extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
    npm ERR! extraneous: http2-wrapper@2.2.0 /opt/iobroker/node_modules/http2-wrapper
    npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
    npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
    npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/isarray
    npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
    npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
    npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
    npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
    npm ERR! extraneous: keyv@4.5.3 /opt/iobroker/node_modules/keyv
    npm ERR! extraneous: layerr@2.0.1 /opt/iobroker/node_modules/layerr
    npm ERR! extraneous: lowercase-keys@3.0.0 /opt/iobroker/node_modules/lowercase-keys
    npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
    npm ERR! extraneous: mimic-response@4.0.0 /opt/iobroker/node_modules/mimic-response
    npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
    npm ERR! extraneous: multer@ /opt/iobroker/node_modules/multer
    npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
    npm ERR! extraneous: node-domexception@1.0.0 /opt/iobroker/node_modules/node-domexception
    npm ERR! extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
    npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
    npm ERR! extraneous: normalize-url@8.0.0 /opt/iobroker/node_modules/normalize-url
    npm ERR! extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
    npm ERR! extraneous: p-cancelable@3.0.0 /opt/iobroker/node_modules/p-cancelable
    npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
    npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
    npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
    npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
    npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
    npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
    npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
    npm ERR! extraneous: responselike@3.0.0 /opt/iobroker/node_modules/responselike
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/string_decoder
    npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
    npm ERR! extraneous: tar-fs@3.0.4 /opt/iobroker/node_modules/tar-fs
    npm ERR! extraneous: tr46@0.0.3 /opt/iobroker/node_modules/tr46
    npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/typedarray
    npm ERR! extraneous: url-join@5.0.0 /opt/iobroker/node_modules/url-join
    npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
    npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
    npm ERR! extraneous: uuid@9.0.1 /opt/iobroker/node_modules/uuid
    npm ERR! extraneous: web-streams-polyfill@ /opt/iobroker/node_modules/web-streams-polyfill
    npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
    npm ERR! extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/webidl-conversions
    npm ERR! extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/whatwg-url
    npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
    npm ERR! extraneous: xtend@ /opt/iobroker/node_modules/xtend
    iobroker.inst@3.0.0 /opt/iobroker
    ├── @buttercup/fetch@0.1.2 extraneous
    ├── @googleapis/drive@8.4.0 extraneous
    ├── @microsoft/microsoft-graph-types@2.38.0 extraneous
    ├── @sindresorhus/is@5.6.0 extraneous
    ├── @szmarczak/http-timer@5.0.1 extraneous
    ├── @types/http-cache-semantics@4.0.1 extraneous
    ├── append-field@ extraneous
    ├── base-64@1.0.0 extraneous
    ├── base64-js@1.5.1 extraneous
    ├── bignumber.js@9.1.2 extraneous
    ├── byte-length@1.0.2 extraneous
    ├── cacheable-lookup@7.0.0 extraneous
    ├── cacheable-request@10.2.13 extraneous
    ├── charenc@0.0.2 extraneous
    ├── compress-json@2.1.2 extraneous
    ├── concat-stream@ extraneous
    ├── cors@ extraneous
    ├── crypt@0.0.2 extraneous
    ├── data-uri-to-buffer@4.0.1 extraneous
    ├── decompress-response@6.0.0 extraneous
    ├── defer-to-connect@2.0.1 extraneous
    ├── dropbox-v2-api@2.5.10 extraneous
    ├── end-of-stream@1.4.4 extraneous
    ├── fast-xml-parser@ extraneous
    ├── fetch-blob@3.2.0 extraneous
    ├── form-data-encoder@2.1.4 extraneous
    ├── formdata-polyfill@4.0.10 extraneous
    ├── ftp@0.3.10 extraneous
    ├── gaxios@6.1.1 extraneous
    ├── gcp-metadata@6.1.0 extraneous
    ├── google-auth-library@ extraneous
    ├── googleapis-common@7.0.1 extraneous
    ├── got@12.6.0 extraneous
    ├── gtoken@7.0.1 extraneous
    ├── he@1.2.0 extraneous
    ├── hot-patcher@2.0.1 extraneous
    ├── http-cache-semantics@4.1.1 extraneous
    ├── http2-wrapper@2.2.0 extraneous
    ├── iobroker.admin@6.12.0
    ├── iobroker.backitup@ invalid: "2.8.7" from the root project
    ├── iobroker.discovery@4.2.0
    ├── iobroker.ds18b20@2.0.5
    ├── iobroker.js-controller@5.0.17
    ├── iobroker.smartmeter@3.4.0
    ├── iobroker.tahoma@0.10.2
    ├── iobroker.zigbee@1.10.1
    ├── is-buffer@1.1.6 extraneous
    ├── is-empty-object@1.1.1 extraneous
    ├── isarray@0.0.1 extraneous
    ├── json-bigint@1.0.0 extraneous
    ├── json-buffer@3.0.1 extraneous
    ├── jwa@2.0.0 extraneous
    ├── jws@4.0.0 extraneous
    ├── keyv@4.5.3 extraneous
    ├── layerr@2.0.1 extraneous
    ├── lowercase-keys@3.0.0 extraneous
    ├── md5@2.3.0 extraneous
    ├── mimic-response@4.0.0 extraneous
    ├── minimist@ extraneous
    ├── mkdirp-classic@0.5.3 extraneous
    ├── multer@ extraneous
    ├── nested-property@4.0.0 extraneous
    ├── node-domexception@1.0.0 extraneous
    ├── node-fetch@2.7.0 extraneous
    ├── node-wol@0.1.1 extraneous
    ├── normalize-url@8.0.0 extraneous
    ├── onedrive-api@1.1.1 extraneous
    ├── p-cancelable@3.0.0 extraneous
    ├── path-posix@1.0.0 extraneous
    ├── pump@3.0.0 extraneous
    ├── querystringify@2.2.0 extraneous
    ├── quick-lru@5.1.1 extraneous
    ├── readable-stream@1.1.14 extraneous
    ├── requires-port@1.0.0 extraneous
    ├── resolve-alpn@1.2.1 extraneous
    ├── responselike@3.0.0 extraneous
    ├── string_decoder@0.10.31 extraneous
    ├── strnum@1.0.5 extraneous
    ├── tar-fs@3.0.4 extraneous
    ├── tr46@0.0.3 extraneous
    ├── typedarray@ extraneous
    ├── url-join@5.0.0 extraneous
    ├── url-parse@1.5.10 extraneous
    ├── url-template@2.0.8 extraneous
    ├── uuid@9.0.1 extraneous
    ├── web-streams-polyfill@ extraneous
    ├── webdav@ extraneous
    ├── webidl-conversions@3.0.1 extraneous
    ├── whatwg-url@5.0.0 extraneous
    ├── xregexp@2.0.0 extraneous
    └── xtend@ extraneous
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T14_45_40_084Z-debug-0.log
    • W wusa
      @homoran sagte in Slave startet nicht mehr:
      und damit hast du das Dateisystem zerschossen
      Jetzt muss ich nochmal darauf eingehen.
      Das Dateisystem kann ich mir ja fast nicht zerschossen haben?
      Ich komme per SSH auf die Kiste drauf.
      Ich habe mir vermutlich iobroker zerschossen oder?
      HomoranH Offline
      HomoranH Offline
      @wusa sagte in Slave startet nicht mehr:
      wo ist da die Logik?
      die Dateien dazu!
      mindestens diese Datei
      /opt/iobroker/node_modules/fs-extra/package.json: Unexpected end of JSON input
      ist defekt
      W 1 Antwort Letzte Antwort
        die Dateien dazu!
        ist defekt
        W Offline
        W Offline
        wusa
        Wenn ich mir das Dateisystem zerschieße, dann stelle ich mir vor, dass die ganze Kiste nicht mehr funktioniert.
        Über diesem Beitrag habe ich die Ausgabe von iob fix eingefügt.
        Ich denke hier ist mehr kaputt?
        • W wusa
          Nein, es sind Teile (inodes) defekt. Welche Auswirkungen das hat hängt davon ab, was in diesen Bereichen gespeichert war.
          Ich denke hier ist ein Modul aus dem backitup-Adapter zerschossen. Deswegen den ach Möglichkeit noch mal drüber installieren.
          • W wusa
            HomoranH Offline
            HomoranH Offline
            das wäre der worst case, je nachdem wie man es sieht.
            Ob es jetzt noch schlimmer ist wenn nur einzelne Dateien defekt sind, von denrn man nur nichts weiß, die aber schlafende Zeitbomben sind, bleibt deiner Wertung überlassen.
            das sind Probleme von möglicherweise krummen Installationen
              W Offline
              W Offline
              wusa
              @thomas-braun sagte in Slave startet nicht mehr:
              Folgendes kommt beim drüber installieren:
              pi@iob-slave:/opt/iobroker $ iob upgrade backitup@2.9.8
              node:internal/modules/package_json_reader:92
                      throw error;
              SyntaxError: Error parsing /opt/iobroker/node_modules/fs-extra/package.json: Unexpected end of JSON input
                  at parse (<anonymous>)
                  at read (node:internal/modules/package_json_reader:79:16)
                  at readPackage (node:internal/modules/package_json_reader:140:10)
                  at resolveExports (node:internal/modules/cjs/loader:580:15)
                  at Module._findPath (node:internal/modules/cjs/loader:658:31)
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                  at Module._load (node:internal/modules/cjs/loader:975:27)
                  at Module.require (node:internal/modules/cjs/loader:1225:19)
                  at require (node:internal/modules/helpers:177:18)
                  at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:30:36) {
                path: '/opt/iobroker/node_modules/fs-extra/package.json'
              Node.js v18.19.0
              • W wusa
                        throw error;
                Node.js v18.19.0
                @wusa
                Dann ist da package_json_reader auch zerschossen.
                Da ich den aber gar nicht im ioBroker habe kann ich dir auch nicht sagen wo du da ansetzten kannst.
                echad@chet:/opt/iobroker $ npm ls package_json_reader
                └── (empty)
                • W wusa
                          throw error;
                  Node.js v18.19.0
                  HomoranH Offline
                  HomoranH Offline
                  fs-extra
                  hast du dieses modul irgendwo selbst hinzugefügt?
                    @wusa
                    └── (empty)
                    Okay, falsch geschaut...
                    cd /opt/iobroker
                    npm ls fs-extra
                    sagt?
                      fs-extra
                      W Offline
                      W Offline
                      wusa
                      @Thomas-Braun
                      Mir ist nicht bewusst, dass ich das Modul/Adapter hinzugefügt hätte.
                      Mir sagt fs-extra so auch nichts.
                      Hier ist die Ausgabe
                      pi@iob-slave:/opt/iobroker $ npm ls fs-extra
                      npm ERR! invalid: fs-extra@ /opt/iobroker/node_modules/fs-extra
                      └─┬ iobroker.js-controller@5.0.17
                        ├─┬ @iobroker/db-objects-file@5.0.17
                        │ ├─┬ @iobroker/db-base@5.0.17
                        │ │ └── fs-extra@ deduped invalid: "^11.1.0" from node_modules/iobroker.js-controller, "^11.1.0" from node_modules/@iobroker/db-objects-file, "^11.1.0" from node_modules/@iobroker/db-objects-jsonl, "^11.1.0" from node_modules/@iobroker/js-controller-adapter, "^11.1.0" from node_modules/@iobroker/js-controller-cli, "^11.1.0" from node_modules/@iobroker/js-controller-common-db, "^11.1.0" from node_modules/@iobroker/js-controller-common, "^11.1.0" from node_modules/@iobroker/db-base
                        ├─┬ @iobroker/db-objects-jsonl@5.0.17
                        │ ├─┬ @alcalzone/jsonl-db@3.1.0
                        │ │ └── fs-extra@10.1.0
                        ├─┬ @iobroker/js-controller-adapter@5.0.17
                        │ ├─┬ @alcalzone/pak@0.8.1
                        ├─┬ @iobroker/js-controller-cli@5.0.17
                        ├─┬ @iobroker/js-controller-common-db@5.0.17
                        ├─┬ @iobroker/js-controller-common@5.0.17
                        └── fs-extra@ invalid: "^11.1.0" from node_modules/iobroker.js-controller, "^11.1.0" from node_modules/@iobroker/db-objects-file, "^11.1.0" from node_modules/@iobroker/db-objects-jsonl, "^11.1.0" from node_modules/@iobroker/js-controller-adapter, "^11.1.0" from node_modules/@iobroker/js-controller-cli, "^11.1.0" from node_modules/@iobroker/js-controller-common-db, "^11.1.0" from node_modules/@iobroker/js-controller-common
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T15_34_53_777Z-debug-0.log
                      • W wusa
                        @Thomas-Braun
                        HomoranH Offline
                        HomoranH Offline
                        also nichts aus javascript oder node-red o.ä.
                        die Ausgabe
                        deutet dann wohl eher auf den Controller hin, was ich bereits zu Beginn befürchtet hatte.
                        oder irgendetwas was vor langer Zeit (deswegen total veraltete Version) mal via GitHub installiert wurde
                        • W wusa
                          @Thomas-Braun
                          @wusa
                          Da sind verweise auf eine invalide Version vorhanden.
                          Sauber sieht das so aus:
                          echad@chet:/opt/iobroker $ npm ls fs-extra
                          ├─┬ iobroker.backitup@2.10.10
                          │ └── fs-extra@11.2.0
                          ├─┬ iobroker.js-controller@5.0.19
                          │ ├─┬ @iobroker/db-objects-file@5.0.19
                          │ │ ├─┬ @iobroker/db-base@5.0.19
                          │ │ │ └── fs-extra@11.2.0 deduped
                          │ ├─┬ @iobroker/db-objects-jsonl@5.0.19
                          │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                          │ │ │ └── fs-extra@10.1.0
                          │ ├─┬ @iobroker/js-controller-adapter@5.0.19
                          │ │ ├─┬ @alcalzone/pak@0.8.1
                          │ ├─┬ @iobroker/js-controller-cli@5.0.19
                          │ ├─┬ @iobroker/js-controller-common-db@5.0.19
                          │ ├─┬ @iobroker/js-controller-common@5.0.19
                          └─┬ iobroker.tuya@3.15.0
                          Die 'deduped' Module verweisen auf
                          was es aber bei dir nicht (mehr) gibt. Jag da mal ein
                          cd /opt/iobroker
                          npm prune
                          drüber
                            @wusa
                            cd /opt/iobroker
                            npm prune
                            drüber
                            W Offline
                            W Offline
                            wusa
                            Sorry jetzt hat es ein wenig gedauert.
                            pi@iob-slave:/opt/iobroker $ npm prune
                            added 2 packages, removed 11 packages, and changed 7 packages in 23s
                            54 packages are looking for funding
                              run `npm fund` for details
                            • W wusa
                              @wusa
                              Schaut das jetzt besser aus?
                              iob diag
                              anschauen.
                                die Ausgabe
                                W Offline
                                W Offline
                                wusa
                                Mir fällt ein, dass ich vor einiger Zeit mal auf Beta umgeschaltet hatte, damit ich einen Adapter testen kann, welcher noch nicht im Stable war. Ob das mit einspielt?
                                Ansonsten bin ich nur Stable unterwegs und versuche auch die Updates zügig zu machen, damit ich aktuell bin.
                                Ja schaut jetzt besser aus. Unter Hosts ist der Slave auch wieder online.
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                   Static hostname: iob-slave
                                         Icon name: computer
                                  Operating System: Debian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v8+
                                      Architecture: arm64
                                Model		: Raspberry Pi 3 Model B Rev 1.2
                                Docker          : false
                                Virtualization  : none
                                Kernel          : aarch64
                                Userland        : arm64
                                Systemuptime and Load:
                                 19:28:38 up  6:21,  3 users,  load average: 0.49, 0.32, 0.36
                                CPU threads: 4
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                ~ Under-voltage detected
                                ~ Arm frequency capped
                                Previously detected issues:
                                ~ Under-voltage has occurred
                                ~ Arm frequency capping has occurred
                                *** Time and Time Zones ***
                                               Local time: Sat 2024-02-10 19:28:38 CET
                                           Universal time: Sat 2024-02-10 18:28:38 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** User and Groups ***
                                pi
                                /home/pi
                                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                *** X-Server-Setup ***
                                X-Server: 	false
                                Desktop:
                                Terminal: 	tty
                                Boot Target: 	multi-user.target
                                *** MEMORY ***
                                Mem:            909M        357M        127M        0.0K        424M        487M
                                Swap:            99M          0B         99M
                                Total:          1.0G        357M        227M
                                          909 M total memory
                                          357 M used memory
                                          506 M active memory
                                          148 M inactive memory
                                          127 M free memory
                                           28 M buffer memory
                                          396 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FAILED SERVICES ***
                                0 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4      252G  6.7G  235G   3% /
                                devtmpfs       devtmpfs  325M     0  325M   0% /dev
                                tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                tmpfs          tmpfs     182M  716K  182M   1% /run
                                /dev/sda1      vfat      253M   31M  222M  13% /boot
                                tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                [Sat Feb 10 13:07:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=a80191bf-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Sat Feb 10 13:07:12 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sat Feb 10 13:07:12 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                [Sat Feb 10 13:07:15 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                TARGET  SOURCE    FSTYPE OPTIONS
                                /       /dev/sda2 ext4   rw,noatime
                                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                /var:
                                4.4G	/var/
                                3.7G	/var/log/journal/19fdaf3f36764551bcb55642e03afc3e
                                3.7G	/var/log
                                400M	/var/cache
                                Archived and active journals take up 3.6G in the file system.
                                /opt/iobroker/backups:
                                4.0K	/opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                4.4M	/opt/iobroker/iobroker-data/
                                1.2M	/opt/iobroker/iobroker-data/files
                                472K	/opt/iobroker/iobroker-data/files/discovery.admin
                                420K	/opt/iobroker/iobroker-data/files/backitup.admin
                                252K	/opt/iobroker/iobroker-data/files/admin.admin
                                2.9M	/opt/iobroker/iobroker-data/objects.jsonl
                                340K	/opt/iobroker/iobroker-data/states.jsonl
                                200K	/opt/iobroker/iobroker-data/files/discovery.admin/words.js
                                164K	/opt/iobroker/iobroker-data/files/backitup.admin/words.js
                                120K	/opt/iobroker/iobroker-data/files/discovery.admin/index_m.html
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0c8a15a4093bec11a27d9c957a0af07f-if00-port0
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs 	v18.19.0
                                /usr/bin/node 		v18.19.0
                                /usr/bin/npm 		10.2.3
                                /usr/bin/npx 		10.2.3
                                /usr/bin/corepack 	0.22.0
                                nodejs:
                                  Installed: 18.19.0-1nodesource1
                                  Candidate: 18.19.0-1nodesource1
                                  Version table:
                                 *** 18.19.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                     18.18.2-1nodesource1 1001
                                     18.18.1-1nodesource1 1001
                                     18.18.0-1nodesource1 1001
                                     18.17.1-1nodesource1 1001
                                     18.17.0-1nodesource1 1001
                                     18.16.1-1nodesource1 1001
                                     18.16.0-1nodesource1 1001
                                     18.15.0-1nodesource1 1001
                                     18.14.2-1nodesource1 1001
                                     18.14.1-1nodesource1 1001
                                     18.14.0-1nodesource1 1001
                                     18.13.0-1nodesource1 1001
                                     18.12.0-1nodesource1 1001
                                     18.11.0-1nodesource1 1001
                                     18.10.0-1nodesource1 1001
                                     18.9.1-1nodesource1 1001
                                     18.9.0-1nodesource1 1001
                                     18.8.0-1nodesource1 1001
                                     18.7.0-1nodesource1 1001
                                     18.6.0-1nodesource1 1001
                                     18.5.0-1nodesource1 1001
                                     18.4.0-1nodesource1 1001
                                     18.3.0-1nodesource1 1001
                                     18.2.0-1nodesource1 1001
                                     18.1.0-1nodesource1 1001
                                     18.0.0-1nodesource1 1001
                                     12.22.12~dfsg-1~deb11u4 500
                                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                No problems detected
                                Errors in npm tree:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                At least one iobroker host is running.
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                js-controller: 	5.0.17
                                admin: 		6.12.0
                                javascript: 	"javascript" not found
                                Adapters from github: 	0
                                Adapter State
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                  system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                + system.adapter.ds18b20.0                : ds18b20               : iob-slave                                -  enabled
                                  system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.111.10
                                + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                  system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.smartmeter.0             : smartmeter            : iob-slave                                -  enabled
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                + system.adapter.tahoma.0                 : tahoma                : iob-slave                                -  enabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
                                + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : iob-slave                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0c8a15a4093bec11a27d9c957a0af07f-if00-port0
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): stable
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "admin"        : 6.13.16  , installed 6.12.0 [Updatable]
                                Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
                                Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
                                Controller "js-controller": 5.0.17   , installed 5.0.17
                                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                                Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                Objects and States
                                Objects: 	5082
                                States: 	4442
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Reading package lists...
                                Pending Updates: 18
                                *** Listening Ports ***
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12725      513/sshd: /usr/sbin
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          12727      513/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14559      599/dhcpcd
                                udp        0      0 0.0.0.0:33446           0.0.0.0:*                           108        14468      418/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14466      418/avahi-daemon: r
                                udp6       0      0 :::33386                :::*                                108        14469      418/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        14467      418/avahi-daemon: r
                                2024-02-10 19:15:02.772  - info: tahoma.0 (54618) Using stored bearer token 635112b1cca5680435cb
                                2024-02-10 19:15:08.682  - info: ds18b20.0 (54629) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v18.19.0, js-controller: 5.0.17
                                2024-02-10 19:15:09.914  - warn: ds18b20.0 (54629) Error reading sensor 28-0000067cc099: Error: No temperature read
                                2024-02-10 19:15:11.155  - info: tahoma.0 (54618) eventRegisterID = 199922c5-4c54-4fd2-8a12-54ebed5390a6
                                2024-02-10 19:15:12.582  - info: zigbee.0 (54607) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                                2024-02-10 19:15:12.939  - info: zigbee.0 (54607) delete old Backup files. keep only last 10
                                2024-02-10 19:15:12.967  - info: zigbee.0 (54607) Starting Zigbee  npm ...
                                2024-02-10 19:15:14.263  - info: zigbee.0 (54607) Installed Version: iobroker.zigbee@1.10.1
                                2024-02-10 19:15:16.996  - warn: zigbee.0 (54607) Extended PAN ID is reversed (expected=28bcc824004b1200, actual=00124b0024c8bc28)
                                2024-02-10 19:15:19.953  - info: zigbee.0 (54607) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                                2024-02-10 19:15:19.966  - info: zigbee.0 (54607) Unable to disable LED, unsupported function.
                                2024-02-10 19:15:20.000  - info: zigbee.0 (54607)   --> transmitPower : normal
                                2024-02-10 19:15:20.033  - info: zigbee.0 (54607) Currently 8 devices are joined:
                                2024-02-10 19:15:20.244  - info: zigbee.0 (54607) 0x84ba20fffe7aa44c (addr 229): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                                2024-02-10 19:15:20.259  - info: zigbee.0 (54607) 0x00158d000806884a (addr 22797): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                2024-02-10 19:15:20.271  - info: zigbee.0 (54607) 0x00158d0008482cfe (addr 3116): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                2024-02-10 19:15:20.280  - info: zigbee.0 (54607) 0x00158d00084831fc (addr 31697): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                2024-02-10 19:15:20.300  - info: zigbee.0 (54607) 0x04cd15fffe6a7146 (addr 31352): LED1736G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, white spectrum, clear (Router)
                                2024-02-10 19:15:20.309  - info: zigbee.0 (54607) 0xb4e3f9fffebe952e (addr 12697): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                2024-02-10 19:15:20.323  - info: zigbee.0 (54607) 0xa4c138eed51355f8 (addr 26613): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
                                2024-02-10 19:15:20.328  - info: zigbee.0 (54607) 0x003c84fffe18ad0f (addr 2414): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                                2024-02-10 19:15:20.331  - info: zigbee.0 (54607) Zigbee started
                                2024-02-10 19:15:20.545  - info: zigbee.0 (54607) debug devices set to []
                                2024-02-10 19:15:46.744  - warn: zigbee.0 (54607) DeviceAvailability:Failed to ping 0xb4e3f9fffebe952e TRADFRI control outlet
                                2024-02-10 19:21:17.879  - info: zigbee.0 (54607) Device '0x003c84fffe18ad0f' announced itself
                                iob diag has finished.
                                Fällt euch sonst noch irgendwas auf, was bei mir falsch ist?
                                Jetzt schon mal ein großes DANKE für die Hilfe!
                                • W wusa
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server: 	false
                                  Desktop:
                                  Terminal: 	tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                            909 M total memory
                                            357 M used memory
                                            506 M active memory
                                            127 M free memory
                                             28 M buffer memory
                                            396 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  4.4G	/var/
                                  3.7G	/var/log
                                  400M	/var/cache
                                  USB-Devices by-id:
                                  /usr/bin/npm 		10.2.3
                                  /usr/bin/npx 		10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin: 		6.12.0
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects: 	5082
                                  States: 	4442
                                  Pending Updates: 18
                                  Hau die Updates des Betriebssstem drauf und auch die Adapter auf den letzten Stand bringen.
                                  Und dann ist die Extended PAN-Id im Zigbee-Adapter verdreht.
