  4. Slave startet nicht mehr
43 Beiträge 4 Kommentatoren 4.8k Aufrufe 2 Beobachtet
  • W wusa
    Habe es jetzt nochmal ausgeführt. Jetzt glaube ich das richtige zu haben:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iob-slave
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     14:15:59 up  1:08,  3 users,  load average: 0.43, 0.46, 0.46
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Sat 2024-02-10 14:15:59 CET
               Universal time: Sat 2024-02-10 13:15:59 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            909M         81M        350M        0.0K        477M        765M
    Swap:            99M          0B         99M
    Total:          1.0G         81M        450M
              909 M total memory
               81 M used memory
              156 M active memory
              321 M inactive memory
              350 M free memory
               55 M buffer memory
              421 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      252G  6.6G  236G   3% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  716K  182M   1% /run
    /dev/sda1      vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Sat Feb 10 13:07:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=a80191bf-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Feb 10 13:07:12 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Feb 10 13:07:12 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Feb 10 13:07:15 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.2G	/var/
    3.6G	/var/log/journal/19fdaf3f36764551bcb55642e03afc3e
    3.6G	/var/log
    400M	/var/cache
    Archived and active journals take up 3.5G in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.4M	/opt/iobroker/iobroker-data/
    1.2M	/opt/iobroker/iobroker-data/files
    472K	/opt/iobroker/iobroker-data/files/discovery.admin
    420K	/opt/iobroker/iobroker-data/files/backitup.admin
    252K	/opt/iobroker/iobroker-data/files/admin.admin
    2.9M	/opt/iobroker/iobroker-data/objects.jsonl
    340K	/opt/iobroker/iobroker-data/states.jsonl
    200K	/opt/iobroker/iobroker-data/files/discovery.admin/words.js
    164K	/opt/iobroker/iobroker-data/files/backitup.admin/words.js
    120K	/opt/iobroker/iobroker-data/files/discovery.admin/index_m.html
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0c8a15a4093bec11a27d9c957a0af07f-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    Temp directories causing npm8 problem: 6
    Some problems detected, please run iob fix
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @buttercup/fetch@0.1.2 /opt/iobroker/node_modules/@buttercup/fetch
    npm ERR! extraneous: @googleapis/drive@8.4.0 /opt/iobroker/node_modules/@googleapis/drive
    npm ERR! extraneous: @microsoft/microsoft-graph-types@2.38.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
    npm ERR! extraneous: @sindresorhus/is@5.6.0 /opt/iobroker/node_modules/@sindresorhus/is
    npm ERR! extraneous: @szmarczak/http-timer@5.0.1 /opt/iobroker/node_modules/@szmarczak/http-timer
    npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
    npm ERR! extraneous: append-field@ /opt/iobroker/node_modules/append-field
    npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
    npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
    npm ERR! extraneous: bignumber.js@9.1.2 /opt/iobroker/node_modules/bignumber.js
    npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
    npm ERR! extraneous: cacheable-lookup@7.0.0 /opt/iobroker/node_modules/cacheable-lookup
    npm ERR! extraneous: cacheable-request@10.2.13 /opt/iobroker/node_modules/cacheable-request
    npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
    npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
    npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
    npm ERR! extraneous: cors@ /opt/iobroker/node_modules/cors
    npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
    npm ERR! extraneous: data-uri-to-buffer@4.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
    npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
    npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
    npm ERR! extraneous: dropbox-v2-api@2.5.10 /opt/iobroker/node_modules/dropbox-v2-api
    npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
    npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
    npm ERR! extraneous: fetch-blob@3.2.0 /opt/iobroker/node_modules/fetch-blob
    npm ERR! extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
    npm ERR! extraneous: formdata-polyfill@4.0.10 /opt/iobroker/node_modules/formdata-polyfill
    npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
    npm ERR! extraneous: gaxios@6.1.1 /opt/iobroker/node_modules/gaxios
    npm ERR! extraneous: gcp-metadata@6.1.0 /opt/iobroker/node_modules/gcp-metadata
    npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
    npm ERR! extraneous: googleapis-common@7.0.1 /opt/iobroker/node_modules/googleapis-common
    npm ERR! extraneous: got@12.6.0 /opt/iobroker/node_modules/got
    npm ERR! extraneous: gtoken@7.0.1 /opt/iobroker/node_modules/gtoken
    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
    npm ERR! extraneous: hot-patcher@2.0.1 /opt/iobroker/node_modules/hot-patcher
    npm ERR! extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
    npm ERR! extraneous: http2-wrapper@2.2.0 /opt/iobroker/node_modules/http2-wrapper
    npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
    npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
    npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/isarray
    npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
    npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
    npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
    npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
    npm ERR! extraneous: keyv@4.5.3 /opt/iobroker/node_modules/keyv
    npm ERR! extraneous: layerr@2.0.1 /opt/iobroker/node_modules/layerr
    npm ERR! extraneous: lowercase-keys@3.0.0 /opt/iobroker/node_modules/lowercase-keys
    npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
    npm ERR! extraneous: mimic-response@4.0.0 /opt/iobroker/node_modules/mimic-response
    npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
    npm ERR! extraneous: multer@ /opt/iobroker/node_modules/multer
    npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
    npm ERR! extraneous: node-domexception@1.0.0 /opt/iobroker/node_modules/node-domexception
    npm ERR! extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
    npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
    npm ERR! extraneous: normalize-url@8.0.0 /opt/iobroker/node_modules/normalize-url
    npm ERR! extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
    npm ERR! extraneous: p-cancelable@3.0.0 /opt/iobroker/node_modules/p-cancelable
    npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
    npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
    npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
    npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
    npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
    npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
    npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
    npm ERR! extraneous: responselike@3.0.0 /opt/iobroker/node_modules/responselike
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/string_decoder
    npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
    npm ERR! extraneous: tar-fs@3.0.4 /opt/iobroker/node_modules/tar-fs
    npm ERR! extraneous: tr46@0.0.3 /opt/iobroker/node_modules/tr46
    npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/typedarray
    npm ERR! extraneous: url-join@5.0.0 /opt/iobroker/node_modules/url-join
    npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
    npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
    npm ERR! extraneous: uuid@9.0.1 /opt/iobroker/node_modules/uuid
    npm ERR! invalid: web-streams-polyfill@ /opt/iobroker/node_modules/web-streams-polyfill
    npm ERR! extraneous: web-streams-polyfill@ /opt/iobroker/node_modules/web-streams-polyfill
    npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
    npm ERR! extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/webidl-conversions
    npm ERR! extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/whatwg-url
    npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
    npm ERR! extraneous: xtend@ /opt/iobroker/node_modules/xtend
    npm ERR! extraneous: node-fetch@3.3.2 /opt/iobroker/node_modules/@buttercup/fetch/node_modules/node-fetch
    npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/concat-stream/node_modules/isarray
    npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/concat-stream/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@ /opt/iobroker/node_modules/concat-stream/node_modules/string_decoder
    npm ERR! extraneous: mimic-response@3.1.0 /opt/iobroker/node_modules/decompress-response/node_modules/mimic-response
    npm ERR! extraneous: agent-base@7.1.0 /opt/iobroker/node_modules/gaxios/node_modules/agent-base
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/gaxios/node_modules/debug
    npm ERR! extraneous: https-proxy-agent@7.0.2 /opt/iobroker/node_modules/gaxios/node_modules/https-proxy-agent
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/gaxios/node_modules/ms
    npm ERR! invalid: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
    npm ERR! invalid: fs-extra@ /opt/iobroker/node_modules/fs-extra
    npm ERR! extraneous: mkdirp@ /opt/iobroker/node_modules/multer/node_modules/mkdirp
    npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-10T13_16_20_427Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/package_json_reader:92
            throw error;
    SyntaxError: Error parsing /opt/iobroker/node_modules/fs-extra/package.json: Unexpected end of JSON input
        at parse (<anonymous>)
        at read (node:internal/modules/package_json_reader:79:16)
        at readPackage (node:internal/modules/package_json_reader:140:10)
        at resolveExports (node:internal/modules/cjs/loader:580:15)
        at Module._findPath (node:internal/modules/cjs/loader:658:31)
        at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Module.require (node:internal/modules/cjs/loader:1225:19)
        at require (node:internal/modules/helpers:177:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:30:36) {
      path: '/opt/iobroker/node_modules/fs-extra/package.json'
    Node.js v18.19.0
    Core adapters versions
            throw error;
    Node.js v18.19.0
    js-controller:
            throw error;
    Node.js v18.19.0
    admin:
            throw error;
    Node.js v18.19.0
    javascript:
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-10T13_16_36_792Z-debug-0.log
    Adapters from github: 	0
    Adapter State
            throw error;
    Node.js v18.19.0
            throw error;
    Node.js v18.19.0
    ioBroker-Repositories
            throw error;
    Node.js v18.19.0
    Installed ioBroker-Instances
            throw error;
    Node.js v18.19.0
    Objects and States
    Objects: 	0
    States: 	0
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12725      513/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12727      513/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14559      599/dhcpcd
    udp        0      0 0.0.0.0:33446           0.0.0.0:*                           108        14468      418/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14466      418/avahi-daemon: r
    udp6       0      0 :::33386                :::*                                108        14469      418/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14467      418/avahi-daemon: r
    2024-02-10 09:12:53.047  - warn: tahoma.0 (37148) error during request: null, request path: events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch with payload:{}
    2024-02-10 09:12:53.048  - warn: tahoma.0 (37148) Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Sat, 10 Feb 2024 08:12:53 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1238-1037-7483.local:8443","port":"8443","hostname":"gateway-1238-1037-7483.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch","href":"https://gateway-1238-1037-7483.local:8443/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 635112b1cca5680435cb","Content-type":"application/json","accept":"application/json","content-length":2}}}
    2024-02-10 09:12:53.049  - warn: tahoma.0 (37148) Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
    2024-02-10 09:13:00.039  - info: host.iob-slave iobroker upgrade backitup@2.9.8
    2024-02-10 09:13:10.109  - info: host.iob-slave iobroker Update backitup from @2.8.7 to @2.9.8
    2024-02-10 09:13:13.059  - warn: tahoma.0 (37148) error during request: null, request path: events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch with payload:{}
    2024-02-10 09:13:13.060  - warn: tahoma.0 (37148) Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Sat, 10 Feb 2024 08:13:13 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1238-1037-7483.local:8443","port":"8443","hostname":"gateway-1238-1037-7483.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch","href":"https://gateway-1238-1037-7483.local:8443/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 635112b1cca5680435cb","Content-type":"application/json","accept":"application/json","content-length":2}}}
    2024-02-10 09:13:13.061  - warn: tahoma.0 (37148) Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
    2024-02-10 09:13:14.530  - info: host.iob-slave iobroker NPM version: 10.2.3
    2024-02-10 09:13:14.537  - info: host.iob-slave iobroker Installing iobroker.backitup@2.9.8... (System call)
    2024-02-10 09:13:33.057  - warn: tahoma.0 (37148) error during request: null, request path: events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch with payload:{}
    2024-02-10 09:13:33.058  - warn: tahoma.0 (37148) Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Sat, 10 Feb 2024 08:13:33 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1238-1037-7483.local:8443","port":"8443","hostname":"gateway-1238-1037-7483.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch","href":"https://gateway-1238-1037-7483.local:8443/enduser-mobile-web/1/enduserAPI/events/90ed5418-3bfc-419b-90ba-27ce67262f02/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 635112b1cca5680435cb","Content-type":"application/json","accept":"application/json","content-length":2}}}
    2024-02-10 09:13:33.059  - warn: tahoma.0 (37148) Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
    iob diag has finished.
    @wusa
    Bevor du irgendwas anderes machst spendierst du dem Raspberry ein ordentliches Netzteil. Das ist ganz offensichtlich zu schwach auf der Brust. Und unterlasse den Strom einfach zu kappen. Die Rechner müssen immer ordentlich heruntergefahren werden.
    W 1 Antwort Letzte Antwort
      @wusa
      W Offline
      W Offline
      wusa
      schrieb am zuletzt editiert von wusa
      Das mit dem Netzteil kann ich gerne machen. Bisher lief das aber die ganze Zeit und das geschätzt ca. 2 Jahre ohne Probleme.
      Das man nicht einfach den Stecker ziehen soll, ist mir durchaus bewusst. Da aber nichts mehr ging, musste ich ziehen.
      • W wusa
        @wusa sagte in Slave startet nicht mehr:
        Bisher lief das aber die ganze Zeit und das sicherlich über 2 Jahre ohne Probleme.
        Vielleicht hast du es nur 2 Jahre nicht gesehen? Oder es ist in den zwei Jahren Last dazugekommen? Jedenfalls schwimmt das Ding jetzt.
          W Offline
          W Offline
          wusa
          Heißt das jetzt für mich, das Netzteil ist schuld das nichts mehr geht? Wenn das erneuert ist, läuft wieder alles?
          Oder liegt auch ein Softwareproblem vor?
          • W wusa
            HomoranH Offline
            HomoranH Offline
            wirklich nichts?
            oder musste der klrine mit 1GB RAM nur intensiv rödeln?
            musste ich ziehen.
            und damit hast du das Dateisystem zerschossen
            W 2 Antworten Letzte Antwort
            • W wusa
              HomoranH Offline
              HomoranH Offline
              nein!
              siehe letzten Post!
              aber den Netzteil verursacht Leistungsproblene
              Zeile 21 und folgende
                wirklich nichts?
                musste ich ziehen.
                W Offline
                W Offline
                wusa
                Die Frage kann ich jetzt so leider nicht beantworten. Aber ich habe ca. 30-45 Min vergehen lasse und mehrmals die GUI aktualisiert. Slave war bis dahin nicht mehr sichtbar.
                Heißt, nicht mehr zu retten und Slave ist hinüber?
                • W wusa
                  Nein.
                  Nein.
                  Ja.
                  Aber eine stabile Spannungsversorgung ist Grundlage fur einen stabilen Betrieb.
                  Erst wenn die gewährleistet ist es sinnvoll in den höheren Etagen aufzuräumen.
                    Nein.
                    Nein.
                    Ja.
                    W Offline
                    W Offline
                    wusa
                    Ok ich werde mir ein Netzteil besorgen. Bis das aber da ist, ist Mitte der Woche, wenn nicht länger.
                    Ist das mit dem Netzteil trotzdem lösbar? Habe meine Zigbee Geräte und meinen Smartmeter über den Slave laufen, sonst habe ich ein paar Funktionen jetzt länger nicht verfügbar?
                    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                    • W wusa
                      @wusa
                      Damit mal anfangen. Also
                      iob fix
                      Dann
                      cd /opt/iobroker
                      npm ls
                      anschauen.
                      • W wusa
                        @wusa
                        Danach mal backitup neuinstallieren:
                        iob upgrade backitup@2.9.8
                        • W wusa
                          HomoranH Offline
                          HomoranH Offline
                          und diese Geräte werden auch noch vom selben Netzteil über die USB des Pi mit Strom versorgt?
                            W Offline
                            W Offline
                            wusa
                            Smartmeter läuft über GPIO und ist "nur" ein Sensor. Also Ja.
                            Und Zigbee ist ein USB Adapter. Und ja, auch über das selbe Netzteil.
                            Mich wundert das ein bisschen, da es wirklich ein "Netzteil" ist, und kein Ladegerät.
                            Aber ich tausche es aus.
                              wirklich nichts?
                              musste ich ziehen.
                              W Offline
                              W Offline
                              wusa
                              @homoran sagte in Slave startet nicht mehr:
                              Jetzt muss ich nochmal darauf eingehen.
                              Das Dateisystem kann ich mir ja fast nicht zerschossen haben?
                              Ich komme per SSH auf die Kiste drauf.
                              Ich habe mir vermutlich iobroker zerschossen oder?
                                @wusa
                                iob fix
                                Dann
                                cd /opt/iobroker
                                npm ls
                                anschauen.
                                W Offline
                                W Offline
                                wusa
                                iob fix
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                pi@iob-slave:~ $ iobroker start
                                pi@iob-slave:~ $ cd /opt/iobroker/
                                pi@iob-slave:/opt/iobroker $ npm ls
                                iobroker.inst@3.0.0 /opt/iobroker
                                ├── @buttercup/fetch@0.1.2 extraneous
                                ├── @googleapis/drive@8.4.0 extraneous
                                ├── @microsoft/microsoft-graph-types@2.38.0 extraneous
                                ├── @sindresorhus/is@5.6.0 extraneous
                                ├── @szmarczak/http-timer@5.0.1 extraneous
                                ├── @types/http-cache-semantics@4.0.1 extraneous
                                ├── append-field@ extraneous
                                ├── base-64@1.0.0 extraneous
                                ├── base64-js@1.5.1 extraneous
                                ├── bignumber.js@9.1.2 extraneous
                                ├── byte-length@1.0.2 extraneous
                                ├── cacheable-lookup@7.0.0 extraneous
                                ├── cacheable-request@10.2.13 extraneous
                                ├── charenc@0.0.2 extraneous
                                ├── compress-json@2.1.2 extraneous
                                ├── concat-stream@ extraneous
                                ├── cors@ extraneous
                                ├── crypt@0.0.2 extraneous
                                ├── data-uri-to-buffer@4.0.1 extraneous
                                ├── decompress-response@6.0.0 extraneous
                                ├── defer-to-connect@2.0.1 extraneous
                                ├── dropbox-v2-api@2.5.10 extraneous
                                ├── end-of-stream@1.4.4 extraneous
                                ├── fast-xml-parser@ extraneous
                                ├── fetch-blob@3.2.0 extraneous
                                ├── form-data-encoder@2.1.4 extraneous
                                ├── formdata-polyfill@4.0.10 extraneous
                                ├── ftp@0.3.10 extraneous
                                ├── gaxios@6.1.1 extraneous
                                ├── gcp-metadata@6.1.0 extraneous
                                ├── google-auth-library@ extraneous
                                ├── googleapis-common@7.0.1 extraneous
                                ├── got@12.6.0 extraneous
                                ├── gtoken@7.0.1 extraneous
                                ├── he@1.2.0 extraneous
                                ├── hot-patcher@2.0.1 extraneous
                                ├── http-cache-semantics@4.1.1 extraneous
                                ├── http2-wrapper@2.2.0 extraneous
                                ├── iobroker.admin@6.12.0
                                ├── iobroker.backitup@ invalid: "2.8.7" from the root project
                                ├── iobroker.discovery@4.2.0
                                ├── iobroker.ds18b20@2.0.5
                                ├── iobroker.js-controller@5.0.17
                                ├── iobroker.smartmeter@3.4.0
                                ├── iobroker.tahoma@0.10.2
                                ├── iobroker.zigbee@1.10.1
                                ├── is-buffer@1.1.6 extraneous
                                ├── is-empty-object@1.1.1 extraneous
                                ├── isarray@0.0.1 extraneous
                                ├── json-bigint@1.0.0 extraneous
                                ├── json-buffer@3.0.1 extraneous
                                ├── jwa@2.0.0 extraneous
                                ├── jws@4.0.0 extraneous
                                ├── keyv@4.5.3 extraneous
                                ├── layerr@2.0.1 extraneous
                                ├── lowercase-keys@3.0.0 extraneous
                                ├── md5@2.3.0 extraneous
                                ├── mimic-response@4.0.0 extraneous
                                ├── minimist@ extraneous
                                ├── mkdirp-classic@0.5.3 extraneous
                                ├── multer@ extraneous
                                ├── nested-property@4.0.0 extraneous
                                ├── node-domexception@1.0.0 extraneous
                                ├── node-fetch@2.7.0 extraneous
                                ├── node-wol@0.1.1 extraneous
                                ├── normalize-url@8.0.0 extraneous
                                ├── onedrive-api@1.1.1 extraneous
                                ├── p-cancelable@3.0.0 extraneous
                                ├── path-posix@1.0.0 extraneous
                                ├── pump@3.0.0 extraneous
                                ├── querystringify@2.2.0 extraneous
                                ├── quick-lru@5.1.1 extraneous
                                ├── readable-stream@1.1.14 extraneous
                                ├── requires-port@1.0.0 extraneous
                                ├── resolve-alpn@1.2.1 extraneous
                                ├── responselike@3.0.0 extraneous
                                ├── string_decoder@0.10.31 extraneous
                                ├── strnum@1.0.5 extraneous
                                ├── tar-fs@3.0.4 extraneous
                                ├── tr46@0.0.3 extraneous
                                ├── typedarray@ extraneous
                                ├── url-join@5.0.0 extraneous
                                ├── url-parse@1.5.10 extraneous
                                ├── url-template@2.0.8 extraneous
                                ├── uuid@9.0.1 extraneous
                                ├── web-streams-polyfill@ extraneous
                                ├── webdav@ extraneous
                                ├── webidl-conversions@3.0.1 extraneous
                                ├── whatwg-url@5.0.0 extraneous
                                ├── xregexp@2.0.0 extraneous
                                └── xtend@ extraneous
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T14_45_40_084Z-debug-0.log
                                • W wusa
                                  HomoranH Offline
                                  HomoranH Offline
                                  wo ist da die Logik?
                                  die Dateien dazu!
                                  mindestens diese Datei
                                  ist defekt
                                    die Dateien dazu!
                                    ist defekt
                                    W Offline
                                    W Offline
                                    wusa
                                    Wenn ich mir das Dateisystem zerschieße, dann stelle ich mir vor, dass die ganze Kiste nicht mehr funktioniert.
                                    Über diesem Beitrag habe ich die Ausgabe von iob fix eingefügt.
                                    Ich denke hier ist mehr kaputt?
                                    • W wusa
                                      Nein, es sind Teile (inodes) defekt. Welche Auswirkungen das hat hängt davon ab, was in diesen Bereichen gespeichert war.
                                      Ich denke hier ist ein Modul aus dem backitup-Adapter zerschossen. Deswegen den ach Möglichkeit noch mal drüber installieren.
                                      • W wusa
                                        HomoranH Offline
                                        HomoranH Offline
                                        das wäre der worst case, je nachdem wie man es sieht.
                                        Ob es jetzt noch schlimmer ist wenn nur einzelne Dateien defekt sind, von denrn man nur nichts weiß, die aber schlafende Zeitbomben sind, bleibt deiner Wertung überlassen.
                                        das sind Probleme von möglicherweise krummen Installationen
                                          W Offline
                                          W Offline
                                          wusa
                                          @thomas-braun sagte in Slave startet nicht mehr:
                                          Folgendes kommt beim drüber installieren:
                                          pi@iob-slave:/opt/iobroker $ iob upgrade backitup@2.9.8
                                                  throw error;
                                          Node.js v18.19.0
