  4. Problem mit Shelly Adapter - Shelly 2.5 Position rot
19 Beiträge 5 Kommentatoren 914 Aufrufe 3 Beobachtet
  • G guitardoc
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.5.11-8-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     20:31:18 up  1:17,  4 users,  load average: 0.29, 0.23, 0.29
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2024-02-05 20:31:18 CET
               Universal time: Mon 2024-02-05 19:31:18 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    mn
    /home/mn
    mn adm dialout sudo users iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.3G        2.1G        1.6G        139K        637M        2.2G
    Swap:           536M          0B        536M
    Total:          4.8G        2.1G        2.1G
             4096 M total memory
             1965 M used memory
             1921 M active memory
              485 M inactive memory
             1522 M free memory
                0 M buffer memory
              608 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  3.7G  3.8G  50% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       94G  6.2G   83G   7% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  128K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--101--disk--0                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    700M    /var/
    306M    /var/cache
    302M    /var/cache/apt
    248M    /var/log
    247M    /var/log/journal/105f04df101b4fd9aa5af34dea5da7f8
    Archived and active journals take up 246.9M in the file system.
    /opt/iobroker/backups:
    48M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    325M    /opt/iobroker/iobroker-data/
    193M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.1.6
    Adapters from github:   2
    Adapter State
      system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    stable        : https://download.iobroker.net/sources-dist.json
    beta          : https://download.iobroker.net/sources-dist-latest.json
    live-stable   : http://iobroker.live/repo/sources-dist.json
    live-beta     : http://iobroker.live/repo/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "eusec"        : 1.2.1    , installed 1.2.1
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "logparser"    : 2.2.1    , installed 2.2.1
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vw-connect"   : 0.0.67   , installed 0.1.3
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        11953
    States:         9388
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       1690163    2200/go2rtc
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1687127    1913/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1688015    1913/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1598978    1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1688301    2034/io.shelly.1
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       1688213    2004/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       1688212    2004/io.mqtt.0
    tcp        0      0 127.0.0.1:38951         0.0.0.0:*               LISTEN      1000       1693153    2298/io.yahka.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1602640    302/master
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       1690158    2200/go2rtc
    tcp6       0      0 :::43617                :::*                    LISTEN      1000       1693938    2298/io.yahka.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1598980    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1596297    1/init
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       1690157    2200/go2rtc
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1602641    302/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1690746    2125/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1688092    1932/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1692839    2268/io.simple-api.
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1598979    1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1693939    2298/io.yahka.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1688254    2019/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1687505    2049/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1687506    2049/io.tuya.0
    udp        0      0 0.0.0.0:40295           0.0.0.0:*                           1000       1690104    2170/io.eusec.0
    udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       1690159    2200/go2rtc
    udp        0      0 0.0.0.0:44352           0.0.0.0:*                           1000       1691187    2170/io.eusec.0
    udp6       0      0 :::111                  :::*                                0          1598981    1/init
    2024-02-05 19:50:44.994  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 19:50:45.028  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 19:52:49.298  - warn: zigbee.0 (2079) DeviceAvailability:Stopping to ping 0xa4c1382ad59e8217 TS011F after 4 ping attempts
    2024-02-05 19:53:52.712  - error: vw-connect.0 (2283) restart adapter in 10min
    2024-02-05 19:53:52.712  - warn: vw-connect.0 (2283) Restart initiated
    2024-02-05 19:53:52.712  - info: vw-connect.0 (2283) cleaned everything up...
    2024-02-05 19:53:52.715  - info: vw-connect.0 (2283) terminating
    2024-02-05 19:53:52.715  - info: vw-connect.0 (2283) Terminated (NO_ERROR): Without reason
    2024-02-05 19:53:53.214  - info: vw-connect.0 (2283) terminating
    2024-02-05 19:54:23.906  - info: vw-connect.0 (2689) starting. Version 0.1.3 (non-npm: TA2k/ioBroker.vw-connect#d6af9940664239b28c563db9ca1eadf10d6b5ce5) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
    2024-02-05 19:54:23.914  - info: vw-connect.0 (2689) Login in with id
    2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) ID login successfull
    2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) History limit: -1, set to -1 to disable wallcharging login
    2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) History limit is set to -1, no wall charging login
    2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) Login successful
    2024-02-05 19:54:27.179  - info: vw-connect.0 (2689) Found 1 vehicles
    2024-02-05 19:54:27.179  - info: vw-connect.0 (2689) Create vehicle WVGZZZCR7RD005807
    2024-02-05 20:00:46.041  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:00:46.060  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:10:47.174  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:10:47.194  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:20:48.320  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:20:48.323  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:30:49.318  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
    2024-02-05 20:30:49.338  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
    Steuerung eigentlich mit Shuttercontrol, zum Test im Moment allerdings per Hand.
    W Online
    W Online
    Wildbill
    schrieb am zuletzt editiert von Wildbill
    @guitardoc Beim Test von Hand wichtig, dass Du dann unten den Haken bei „Bestätigt“ NICHT setzen darfst. Sonst wird auch nix ausgeführt!
    Kommen irgendwelche Meldungen im Log, wenn Du von Hand schaltest?
    Gruss, Jürgen
    EDIT: Mach mal einen Reboot, da scheinen ein paar Services sich aufgehängt zu haben.
    EDIT2: Du hast zwei Shelly-Adapter laufen. Einmal auf Port 1882 und einmal auf 1883. Absicht? Sind die Shelly mit dem richtigen Adapter verbunden (Port im Shelly richtig)?
    G 1 Antwort Letzte Antwort
    • W Wildbill
      Gruss, Jürgen
      guitardoc
      Die Fehlermeldungen kommen immer nach dem Reboot des Systems, schon seit langer Zeit. Sind teils auch schon bekannte Probleme wo dran gearbeitet wird.
      Die beiden Shelly Instanzen sind Absicht - einmal für Coap-Geräte und einmal für MQTT-Geräte.
      • G guitardoc
        da_WoodyD Online
        da_WoodyD Online
        @guitardoc seit wann braucht CoAP einen port?
        • da_WoodyD da_Woody
          guitardoc
          @da_woody das weiß ich nicht, es müssen aber die alten Geräte von den neueren durch zwei Instanzen getrennt werden.
          Das ist aber alles nicht das Problem, denn es lief ja monatelang.
          da_WoodyD 2 Antworten Letzte Antwort
          • G guitardoc
            da_WoodyD Online
            da_WoodyD Online
            @guitardoc du hast mich falsch verstanden. Ich hab auch 2 Instanzen. .0 für CoAP (gen1), .1 für MQTT (gen2).
            Aber bei gen1 (CoAP) gibt's keinen Port!
            • G guitardoc
              da_WoodyD Online
              da_WoodyD Online
              @guitardoc sagte in Problem mit Shelly Adapter - Shelly 2.5 Position rot:
              Ich hab da so einen Verdacht nach der Aussage. Zeig mal deine Einstellungen der Instanzen und von einem gen1 und gen2 Gerät...
              Imho biste noch auf mcast unterwegs...
                guitardoc
                Haha! Ich denke, ich habe das Problem gefunden. ioBroker und Homebridge für Homekit laufen bei mir auf einem Proxmox in jeweiligen CTs. Der Neustart der CTs reicht offensichtlich nicht immer aus - man muss den gesamten Proxmox neu starten. Dann läuft es wieder. So ein Theater…
                Hier aber trotzdem mal noch die Einstellungen:
                  haus-automatisierungH Offline
                  @da_woody sagte in Problem mit Shelly Adapter - Shelly 2.5 Position rot:
                  Natürlich gibt es den. Unicast richtig konfigurieren. Wie sollen Geräte sonst kommunizieren? Port 5683.
                  5683 tcp coap Constrained Application Protocol (CoAP) [RFC8323] , registered 2017-12-22
                  Siehe
                  https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md
                  📚 Meine Dokumentation
                  • G guitardoc
                    da_WoodyD Online
                    da_WoodyD Online
                    @guitardoc schön und gut. die 2. seiten wären etwas aussagekräftiger, was du da eingestellt hast..
                    was mich aber noch mehr interessiert:
                    coap
                    wenn da mcast steht, könnte das auch probleme machen.
                    mqtt
                    nebenbei wäre schon im ersten posting nicht schlecht gewesen wie dein system läuft. sonst is das stochern im trüben und kristallkugel.gif
                      Siehe
                      da_WoodyD Online
                      da_WoodyD Online
                      warum ich wohl gefragt habe?
                        coap
                        mqtt
                        guitardoc
                        schrieb am zuletzt editiert von guitardoc
                        @da_woody MQTT hab ich die gleich Einstellungen.
                        Bei Coap steht bei mir vermutlich in allen Shellys das hier drin (über die App lässt sich da ja nichts einstellen und in der Oberfläche der Shellys per IP hab ich nur gelegentlich was eingestellt):
                        Wenn ich aber die IP dezidiert hier eintrage, dann befürchte ich, dass dann keine Übertragung mehr zu Homekit über die Homebridge stattfindet sondern eben nur noch zu ioB. Das ist es doch was Multicast macht, oder?
                        • G guitardoc
                          da_WoodyD Online
                          da_WoodyD Online
                          @guitardoc und somit hat sich meine Vermutung bestätigt!
                          mcast wurde schon vor längerer Zeit auf unicast umgestellt. Funktioniert bei einigen noch, irgendwann kommen die probs.
                          Dort gehört auch nur die IP vom iobroker rein, save, der Port wird automatisch zugefügt. Hab ich auch schon in gefühlten Postings geschrieben.
                          Ja, jeh mehr shelly, um so mehr Arbeit. Bei mir waren es mehr als 60. Bei neuen mach ich das automatisch gleich beim Einrichten (gen1) wie auch im Router die IP an die MAC binden.
                          Edith: sorry mit deinem homekit Gedöns kenn ich mich nicht aus.
                          • G Offline
                            guitardoc
                            @da_woody Hab’s gerade getestet, mit dezidierter IP geht die Steuerung über Homekit nicht mehr. Mit mcast funktioniert alles so wie es soll.
                            • G guitardoc
                              da_WoodyD Online
                              da_WoodyD Online
                              @guitardoc ok. mir stellt sich nur gerade die frage, warum ioB und Homekit. ist m.W. was ähnliches.
                              warum beides? was bietet dir homekit mehr als ioB?
                              nachdem dein problem ja abgehakt ist, wäre das eventuell auch für andere interessant.
                              ansonsten wäre der tread als gelöst zu markieren...
                              • G Offline
                                guitardoc
                                @da_woody über HomeKit lassen sich alle Geräte per Tastendruck steuern ohne dass man erst eine Visualisierung bauen muss. Auch diverse Automationen (nicht alle, dafür brauche ich ja eben den ioB) gehen mit HomeKit super einfach zu erstellen und zu nutzen. Und über Kurzbefehle lassen sich auch mehrere Geräte komplex auswerten und ausführen. Über das integrierte Geofencing wird die Haustür automatisch verriegelt wenn ich das Haus verlasse. Und ich kann die Geräte von Ferne aus steuern ohne irgend etwas programmieren zu müssen. Alles schon fertig vorhanden…
                                Möglicherweise geht vieles davon auch in ioBroker, aber in HomeKit ist das meiste (bis auf komplexe Steuerungen) mit zwei drei Klicks zusammen geklickt und schon fertig da. Einschließlich Übersichten von Überwachungskameras, Visualisierung der Standorte von Fahrzeugen, etc…
                                • G guitardoc
                                  da_WoodyD Online
                                  da_WoodyD Online
                                  @guitardoc also im prinzip so wie ich ioB und die shelly cloud verwende... ok, ich hab da noch iQontrol als visu. ja, die alexa tusse treibt sich auch in diversen ecken hier rum...
                                  klappert aber auch in timbuktu, wenns dort inet zugang gibt.
                                  aber gut, ich bin apfel verweigerer, hab nur ein kleines macbook als spielerei und für kleinigkeiten unterwegs.
