  4. Neustart Nachts - aber warum?
43 Beiträge 10 Kommentatoren 6.4k Aufrufe 9 Beobachtet
  • V vatoslocos
    Habs mal eingekürzt... in diesem Zeitraum muss es eigentlich passieren.... der js Controller wird dann ja auch neu gestartet.... keine Ahnung warum
    2024-02-01 02:01:10.398  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/7.png
    2024-02-01 02:01:10.472  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_symbolB with 54
    2024-02-01 02:01:10.511  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_symbol with 14
    2024-02-01 02:01:10.560  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_dir with SW
    2024-02-01 02:01:10.639  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.wind_value with 21 km/h
    2024-02-01 02:01:10.709  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/54.png
    2024-02-01 02:01:10.759  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.windgusts_value with 44 km/h
    2024-02-01 02:01:10.802  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.rain_value with 0.1 mm
    2024-02-01 02:01:10.844  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.humidity_value with 86
    2024-02-01 02:01:10.929  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.pressure_value with 1027 mb
    2024-02-01 02:01:10.976  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.clouds_value with 100%
    2024-02-01 02:01:11.018  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.snowline_value with 3400 m
    2024-02-01 02:01:11.059  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.windchill_value with 4 °C
    2024-02-01 02:01:11.141  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_5.uv_index_value with 0
    2024-02-01 02:01:11.165  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6 with null  {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}}
    2024-02-01 02:01:11.180  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.hour_value with 17:00
    2024-02-01 02:01:11.219  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.temp_value with 8 °C
    2024-02-01 02:01:11.252  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.symbol_desc2 with Bedeckt mit leichtem Regen
    2024-02-01 02:01:11.295  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.symbol_value2 with 7
    2024-02-01 02:01:11.330  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.symbol_desc with Bedeckt mit leichtem Regen
    2024-02-01 02:01:11.362  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.symbol_value with 7
    2024-02-01 02:01:11.398  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/7.png
    2024-02-01 02:01:11.438  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.wind_symbolB with 54
    2024-02-01 02:01:11.470  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.wind_symbol with 14
    2024-02-01 02:01:11.504  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.wind_dir with SW
    2024-02-01 02:01:11.551  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.wind_value with 20 km/h
    2024-02-01 02:01:11.577  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/54.png
    2024-02-01 02:01:11.606  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.windgusts_value with 40 km/h
    2024-02-01 02:01:11.642  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.rain_value with 0.3 mm
    2024-02-01 02:01:11.691  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.humidity_value with 91
    2024-02-01 02:01:11.794  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.pressure_value with 1026 mb
    2024-02-01 02:01:11.990  - info: mihome-vacuum.0 (2522234) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
    2024-02-01 02:01:13.291  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.clouds_value with 100%
    2024-02-01 02:01:14.329  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.snowline_value with 3400 m
    2024-02-01 02:01:18.228  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.windchill_value with 5 °C
    2024-02-01 02:01:18.247  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"GzsNVpse9mHY5vJC","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:01:21.917  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_6.uv_index_value with 0
    2024-02-01 02:01:21.989  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7 with null  {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}}
    2024-02-01 02:01:21.995  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.hour_value with 20:00
    2024-02-01 02:01:22.760  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.temp_value with 9 °C
    2024-02-01 02:01:24.114  - error: daswetter.0 (3287385) force terminate
    2024-02-01 02:01:24.116  - debug: daswetter.0 (3287385) Plugin sentry destroyed
    2024-02-01 02:01:24.118  - warn: daswetter.0 (3287385) Terminated (UNKNOWN_ERROR): Without reason
    2024-02-01 02:01:25.989  - debug: daswetter.0 (3287385) redis get daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.temp_value, error - Connection is closed.
    2024-02-01 02:01:25.991  - error: daswetter.0 (3287385) exception in await insertIntoList [Error: DB closed]
    2024-02-01 02:01:25.992  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc2 with Bedeckt
    2024-02-01 02:01:26.009  - error: daswetter.0 (3287385) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc2": Connection is closed.
    2024-02-01 02:01:26.020  - error: daswetter.0 (3287385) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc2: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc2": Connection is closed.]
    2024-02-01 02:01:26.021  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value2 with 4
    2024-02-01 02:01:26.033  - error: daswetter.0 (3287385) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value2": Connection is closed.
    2024-02-01 02:01:26.036  - error: daswetter.0 (3287385) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value2: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value2": Connection is closed.]
    2024-02-01 02:01:26.037  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc with Bedeckt
    2024-02-01 02:01:26.051  - error: daswetter.0 (3287385) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc": Connection is closed.
    2024-02-01 02:01:26.078  - error: daswetter.0 (3287385) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_desc": Connection is closed.]
    2024-02-01 02:01:26.079  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value with 4
    2024-02-01 02:01:26.091  - error: daswetter.0 (3287385) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value": Connection is closed.
    2024-02-01 02:01:26.134  - error: daswetter.0 (3287385) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.symbol_value": Connection is closed.]
    2024-02-01 02:01:26.134  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/4.png
    2024-02-01 02:01:26.152  - error: daswetter.0 (3287385) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.iconURL": Connection is closed.
    2024-02-01 02:01:26.173  - error: daswetter.0 (3287385) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.iconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7.iconURL": Connection is closed.]
    2024-02-01 02:01:26.174  - debug: daswetter.0 (3287385) insert NextDaysDetailed.Location_1.Day_2.Hour_7.wind_symbolB with 55
    2024-02-01 02:01:26.287  - error: host.ioBroker-RasPi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    2024-02-01 02:01:26.837  - warn: yeelight-2.0 (708725) State "yeelight-2.0.yeelight_oben.info.connect" has no existing object, this might lead to an error in future versions
    2024-02-01 02:01:28.261  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"fQilswKy4taisI4h","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:01:38.199  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"dCtcBpcSEvBRo8qa","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:01:48.175  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"5HtHuSnBH4WMORzv","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:01:48.675  - warn: yeelight-2.0 (708725) State "yeelight-2.0.yeelight_oben.info.connect" has no existing object, this might lead to an error in future versions
    2024-02-01 02:01:48.735  - info: mihome-vacuum.0 (2522234) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
    2024-02-01 02:02:11.148  - error: fb-checkpresence.0 (708564) Objects database error: read ECONNRESET
    2024-02-01 02:02:16.359  - error: fb-checkpresence.0 (708564) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:16.228  - error: sonos.0 (708477) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:19.082  - error: tuya.0 (708503) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:19.843  - error: yeelight-2.0 (708725) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:21.036  - info: sonos.0 (708477) terminating
    2024-02-01 02:02:21.052  - info: fb-checkpresence.0 (708564) cleaned everything up ...
    2024-02-01 02:02:21.066  - info: fb-checkpresence.0 (708564) terminating
    2024-02-01 02:02:21.128  - info: fb-checkpresence.0 (708564) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:21.145  - info: yeelight-2.0 (708725) cleaned everything up...
    2024-02-01 02:02:21.171  - info: sonos.0 (708477) terminating
    2024-02-01 02:02:21.181  - info: yeelight-2.0 (708725) terminating
    2024-02-01 02:02:21.195  - info: sonos.0 (708477) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:21.001  - info: trashschedule.0 (708745) cleaned everything up...
    2024-02-01 02:02:21.264  - info: trashschedule.0 (708745) terminating
    2024-02-01 02:02:21.289  - info: trashschedule.0 (708745) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:21.303  - info: yeelight-2.0 (708725) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:21.644  - info: javascript.0 (708316) Stop script script.js.Broadlink.Garten.Bewegungsmelder_TerrassenLicht
    2024-02-01 02:02:21.265  - info: tradfri.0 (708698) terminating
    2024-02-01 02:02:21.919  - info: tradfri.0 (708698) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:21.606  - info: solarviewdatareader.0 (708650) cleaned everything up...
    2024-02-01 02:02:22.388  - info: tr-064.0 (708488) terminating
    2024-02-01 02:02:22.434  - info: tr-064.0 (708488) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:21.605  - info: fritzdect.0 (708580) cleaned everything up...
    2024-02-01 02:02:22.756  - info: tr-064.0 (708488) terminating
    2024-02-01 02:02:21.636  - info: simple-api.0 (708643) terminating http server on port 8087
    2024-02-01 02:02:24.646  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"iW6zsS0R94rZADYb","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:02:21.796  - info: javascript.0 (708316) Stop script script.js.Broadlink.Garten.Brunnen_Terrasse_ein_aus
    2024-02-01 02:02:21.797  - info: javascript.0 (708316) Stop script script.js.Broadlink.Garten.Garten_Licht_Dämmerung
    2024-02-01 02:02:21.826  - info: javascript.0 (708316) Stop script script.js.Broadlink.Garten.Garten_Licht_ein_aus
    2024-02-01 02:02:21.828  - info: javascript.0 (708316) Stop script script.js.Broadlink.Garten.Terrasse_Licht_ein/aus
    2024-02-01 02:02:21.828  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Beamer_An_Aus
    2024-02-01 02:02:21.829  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.FireTVmodus_aktivieren
    2024-02-01 02:02:21.830  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Hdmi_Switch
    2024-02-01 02:02:21.834  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Kinomodus_an_aus
    2024-02-01 02:02:21.835  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Leinwand_runter_hoch
    2024-02-01 02:02:21.835  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Playstationmodus_aktivieren
    2024-02-01 02:02:21.836  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Receiver_an_aus_Kopieren
    2024-02-01 02:02:21.837  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.Receivermodus_aktivieren
    2024-02-01 02:02:21.838  - info: javascript.0 (708316) Stop script script.js.Broadlink.Technik.TV_an_aus
    2024-02-01 02:02:21.839  - info: javascript.0 (708316) Stop script script.js.Fritzbox.Restart
    2024-02-01 02:02:21.840  - info: javascript.0 (708316) Stop script script.js.Heizung.Flur_WC_Bad.Heizung_Bad_Fenster_Kontakt
    2024-02-01 02:02:21.841  - info: javascript.0 (708316) Stop script script.js.Heizung.Flur_WC_Bad.Heizung_Bad_Flur
    2024-02-01 02:02:21.842  - info: javascript.0 (708316) Stop script script.js.Heizung.Flur_WC_Bad.Heizung_Gaeste_WC
    2024-02-01 02:02:21.845  - info: javascript.0 (708316) Stop script script.js.Heizung.Kinder_Eltern.Heizung_Eltern_Fenster
    2024-02-01 02:02:21.846  - info: javascript.0 (708316) Stop script script.js.Heizung.Kinder_Eltern.Heizung_Kinder_Abends
    2024-02-01 02:02:21.846  - info: javascript.0 (708316) Stop script script.js.Heizung.Kinder_Eltern.Heizung_Philipp_Fenster
    2024-02-01 02:02:21.847  - info: javascript.0 (708316) Stop script script.js.Heizung.Kinder_Eltern.Heizung_Simon_Fenster
    2024-02-01 02:02:21.857  - info: javascript.0 (708316) Stop script script.js.Heizung.Lüftung.Belueftung_Pruefung_Raeume
    2024-02-01 02:02:21.858  - info: javascript.0 (708316) Stop script script.js.Heizung.Sommer_Urlaubsmodus_aktiv/inaktiv
    2024-02-01 02:02:21.861  - info: javascript.0 (708316) Stop script script.js.Heizung.Wohnbereich.Heizung_Wohnbereich_Fenster_Tuer_Kontakt
    2024-02-01 02:02:21.862  - info: javascript.0 (708316) Stop script script.js.Heizung.Wohnbereich.Heizung_Wohnbereich_Kueche
    2024-02-01 02:02:21.863  - info: javascript.0 (708316) Stop script script.js.Lichter.Bewegungsmelder_Xiaomi_E27
    2024-02-01 02:02:21.864  - info: javascript.0 (708316) Stop script script.js.Lichter.Wohzimmer_Lichter_an_aus
    2024-02-01 02:02:21.865  - info: javascript.0 (708316) Stop script script.js.Lichter.ZeitschaltuhrFlurUntenOben
    2024-02-01 02:02:21.866  - info: javascript.0 (708316) Stop script script.js.Pool.Laufzeit_SandFilter_Tag
    2024-02-01 02:02:21.867  - info: javascript.0 (708316) Stop script script.js.Pool.Pool_Solar_Strom_Temp
    2024-02-01 02:02:21.869  - info: javascript.0 (708316) Stop script script.js.Pool.Poolsteuerung
    2024-02-01 02:02:21.870  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Bad_anlernen
    2024-02-01 02:02:21.871  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Flur_anlernen
    2024-02-01 02:02:21.872  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Wohnzimmer_anlernen
    2024-02-01 02:02:21.874  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Zone_Bad
    2024-02-01 02:02:21.875  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Zone_Flur
    2024-02-01 02:02:21.876  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Zone_Flur_Bad
    2024-02-01 02:02:21.877  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Zone_Kueche
    2024-02-01 02:02:21.878  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Zone_Kueche_Wohnzimmer
    2024-02-01 02:02:21.880  - info: javascript.0 (708316) Stop script script.js.Saugroboter.Zone_Wohnzimmer
    2024-02-01 02:02:21.882  - info: javascript.0 (708316) Stop script script.js.Technik.Speetest
    2024-02-01 02:02:21.882  - info: javascript.0 (708316) Stop script script.js.Technik.Spülmaschine_An
    2024-02-01 02:02:21.883  - info: javascript.0 (708316) Stop script script.js.Telegramm.Abwesenheit_Bild
    2024-02-01 02:02:21.884  - info: javascript.0 (708316) Stop script script.js.Telegramm.BatterieWarnung
    2024-02-01 02:02:21.885  - info: javascript.0 (708316) Stop script script.js.Telegramm.Verpasster_Anruf
    2024-02-01 02:02:21.886  - info: javascript.0 (708316) Stop script script.js.Tradfri.Dash_Button_Couch
    2024-02-01 02:02:21.886  - info: javascript.0 (708316) Stop script script.js.Tradfri.Xiaomi_Button_Decke
    2024-02-01 02:02:21.887  - info: javascript.0 (708316) Stop script script.js.Tradfri.Xiaomi_Button_Essen
    2024-02-01 02:02:21.888  - info: javascript.0 (708316) Stop script script.js.Tuya-Steurung.Luftbesteuber_an_aus
    2024-02-01 02:02:21.889  - info: javascript.0 (708316) Stop script script.js.Wetter.Astro-Daten
    2024-02-01 02:02:21.890  - info: javascript.0 (708316) Stop script script.js.Xiaomi.Xiaomi_Button_Bett_LED
    2024-02-01 02:02:21.890  - info: javascript.0 (708316) Stop script script.js.common.Adapterrunning
    2024-02-01 02:02:22.010  - info: javascript.0 (708316) Stop script script.js.common.Batterie_Max_Xiaomi
    2024-02-01 02:02:22.016  - info: javascript.0 (708316) Stop script script.js.common.GastWlan_deaktivieren
    2024-02-01 02:02:22.017  - info: javascript.0 (708316) Stop script script.js.common.MüllTage_Info
    2024-02-01 02:02:22.018  - info: javascript.0 (708316) Stop script script.js.common.VIS_ViewWechsel_5Minuten
    2024-02-01 02:02:22.018  - info: javascript.0 (708316) Stop script script.js.common.VIS_ViewWechsel_Kamera_Bewegung
    2024-02-01 02:02:22.019  - info: javascript.0 (708316) Stop script script.js.common.VIS_ViewWechsel_Pool_Bewegung
    2024-02-01 02:02:22.020  - info: javascript.0 (708316) Stop script script.js.common.VIS_View_Restart
    2024-02-01 02:02:22.035  - info: javascript.0 (708316) Stop script script.js.Technik.Blink_Aktivierung
    2024-02-01 02:02:22.036  - info: javascript.0 (708316) Stop script script.js.Sauna
    2024-02-01 02:02:24.652  - error: javascript.0 (708316) Objects database error: write EPIPE
    2024-02-01 02:02:24.647  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"5JwGYNCqiMq2JQJR","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:02:24.652  - debug: mihome.0 (708448) RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dcb91296","short_id":"0","token":"5MiHGrtKalur9ruE","data":{"ip":"192.168.1.35"}}
    2024-02-01 02:02:25.453  - info: web.0 (708722) <== Disconnect system.user.admin from ::ffff:192.168.1.76 vis.0
    2024-02-01 02:02:25.564  - info: web.0 (708722) <== Disconnect system.user.admin from ::ffff:192.168.1.75 vis.0
    2024-02-01 02:02:24.560  - info: admin.0 (708293) terminating http server on port 8081
    2024-02-01 02:02:25.835  - info: admin.0 (708293) terminating
    2024-02-01 02:02:25.878  - info: admin.0 (708293) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:25.905  - info: admin.0 (708293) terminating
    2024-02-01 02:02:26.140  - info: web.0 (708722) ==> Connected system.user.admin from ::ffff:192.168.1.75
    2024-02-01 02:02:26.040  - info: alexa2.0 (708908) terminating
    2024-02-01 02:02:26.215  - info: mihome.0 (708448) terminating
    2024-02-01 02:02:26.212  - info: alexa2.0 (708908) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:26.275  - info: alexa2.0 (708908) terminating
    2024-02-01 02:02:26.279  - warn: web.0 (708722) Timeout by termination of web-extensions!
    2024-02-01 02:02:26.250  - debug: mihome.0 (708448) Plugin sentry destroyed
    2024-02-01 02:02:26.293  - info: mihome.0 (708448) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:26.296  - info: mihome.0 (708448) terminating
    2024-02-01 02:02:26.304  - info: web.0 (708722) terminated http server on port 8082
    2024-02-01 02:02:26.313  - info: web.0 (708722) ==> Connected system.user.admin from ::ffff:192.168.1.76
    2024-02-01 02:02:26.373  - info: web.0 (708722) terminating
    2024-02-01 02:02:26.428  - info: web.0 (708722) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:26.428  - info: web.0 (708722) terminating
    2024-02-01 02:02:26.483  - error: ical.0 (3288961) Objects database error: read ECONNRESET
    2024-02-01 02:02:26.019  - info: backitup.0 (708384) cleaned everything up...
    2024-02-01 02:02:26.694  - info: admin.0 (708293) terminating with timeout
    2024-02-01 02:02:26.929  - info: web.0 (708722) <== Disconnect system.user.admin from ::ffff:192.168.1.75
    2024-02-01 02:02:27.057  - info: alexa2.0 (708908) terminating with timeout
    2024-02-01 02:02:27.091  - info: mihome.0 (708448) terminating with timeout
    2024-02-01 02:02:27.308  - info: web.0 (708722) terminating with timeout
    2024-02-01 02:02:27.381  - info: ical.0 (3288961) terminating
    2024-02-01 02:02:27.396  - info: ical.0 (3288961) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:27.818  - info: web.0 (708722) <== Disconnect system.user.admin from ::ffff:192.168.1.76
    2024-02-01 02:02:27.825  - info: ham.0 (708514) cleaned everything up...
    2024-02-01 02:02:28.648  - warn: ham.0 (708514) Exception: Error [ERR_IPC_CHANNEL_CLOSED]: Channel closed
    2024-02-01 02:02:28.664  - error: ham.0 (708514) uncaught exception: Channel closed
    2024-02-01 02:02:28.665  - error: ham.0 (708514) Error: Channel closed
        at new NodeError (node:internal/errors:405:5)
        at process.target.send (node:internal/child_process:740:16)
        at IpcService.sendMessage (/opt/iobroker/node_modules/homebridge-plugin-wrapper/src/ipcService.ts:46:13)
        at Server.setServerStatus (/opt/iobroker/node_modules/homebridge-plugin-wrapper/src/server.ts:159:16)
        at Server.teardown (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:145:14)
        at HomebridgeWrapper.finish (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:431:21)
        at Object.end (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:155:23)
        at process.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/main.js:43:72)
        at process.emit (node:events:526:35)
    2024-02-01 02:02:28.666  - error: ham.0 (708514) Exception-Code: ERR_IPC_CHANNEL_CLOSED: Channel closed
    2024-02-01 02:02:29.039  - info: backitup.0 (708384) terminating with timeout
    2024-02-01 02:02:29.064  - info: backitup.0 (708384) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:29.174  - info: ham.0 (708514) terminating
    2024-02-01 02:02:29.188  - info: ham.0 (708514) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:29.189  - info: ham.0 (708514) terminating
    2024-02-01 02:02:27.679  - info: fritzbox.0 (708396) terminating
    2024-02-01 02:02:28.948  - info: fritzbox.0 (708396) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:29.019  - info: fritzbox.0 (708396) terminating
    2024-02-01 02:02:29.021  - info: fritzbox.0 (708396) terminating with timeout
    2024-02-01 02:02:30.006  - info: ham.0 (708514) terminating with timeout
    2024-02-01 02:02:29.075  - info: sourceanalytix.0 (708661) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
    2024-02-01 02:02:30.528  - info: sourceanalytix.0 (708661) terminating
    2024-02-01 02:02:30.604  - info: telegram.0 (708360) terminating
    2024-02-01 02:02:30.695  - info: sourceanalytix.0 (708661) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:30.696  - info: sourceanalytix.0 (708661) terminating
    2024-02-01 02:02:30.696  - info: vw-connect.0 (708738) cleaned everything up...
    2024-02-01 02:02:30.735  - info: telegram.0 (708360) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:31.375  - info: vw-connect.0 (708738) terminating
    2024-02-01 02:02:31.377  - info: sourceanalytix.0 (708661) terminating with timeout
    2024-02-01 02:02:31.414  - info: vw-connect.0 (708738) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:31.429  - info: telegram.0 (708360) terminating with timeout
    2024-02-01 02:02:31.445  - info: vw-connect.0 (708738) terminating
    2024-02-01 02:02:29.693  - info: discovery.0 (708543) terminating
    2024-02-01 02:02:31.097  - info: discovery.0 (708543) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:31.443  - info: discovery.0 (708543) terminating with timeout
    2024-02-01 02:02:31.544  - info: discovery.0 (708543) terminating
    2024-02-01 02:02:31.670  - error: mihome-vacuum.0 (2522234) Socket Close
    2024-02-01 02:02:32.263  - info: vw-connect.0 (708738) terminating with timeout
    2024-02-01 02:02:32.296  - info: mihome-vacuum.0 (2522234) terminating
    2024-02-01 02:02:32.409  - info: mihome-vacuum.0 (2522234) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:32.418  - info: mihome-vacuum.0 (2522234) terminating
    2024-02-01 02:02:29.779  - info: nuki.0 (708582) cleaned everything up...
    2024-02-01 02:02:31.727  - info: hmip.0 (708403) cleaned everything up...
    2024-02-01 02:02:32.800  - info: nuki.0 (708582) terminating
    2024-02-01 02:02:32.838  - info: nuki.0 (708582) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:32.864  - warn: hmip.0 (708403) ws connection closed (0) - code: 1000 - reason:
    2024-02-01 02:02:32.851  - info: nuki.0 (708582) terminating
    2024-02-01 02:02:32.896  - info: hmip.0 (708403) terminating
    2024-02-01 02:02:31.489  - info: sayit.0 (708636) stopping...
    2024-02-01 02:02:32.906  - info: hmip.0 (708403) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:32.907  - info: hmip.0 (708403) terminating
    2024-02-01 02:02:32.929  - info: sayit.0 (708636) terminating
    2024-02-01 02:02:32.965  - info: sayit.0 (708636) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:32.994  - info: sayit.0 (708636) terminating
    2024-02-01 02:02:32.938  - info: history.0 (708300) terminating
    2024-02-01 02:02:33.156  - info: history.0 (708300) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:33.033  - info: sonoff.0 (708466) Client [Sonoff-Spuelmaschine] reconnected. Old secret 1706664531125_762. New secret 1706749351573_292
    2024-02-01 02:02:33.241  - info: sonoff.0 (708466) Client [Sonoff-TvBereich] reconnected. Old secret 1706664531140_3916. New secret 1706749351609_5641
    2024-02-01 02:02:33.264  - info: sonoff.0 (708466) Client [Sonoff-Duftlampe] reconnected. Old secret 1706664532155_7630. New secret 1706749351644_790
    2024-02-01 02:02:33.272  - info: sonoff.0 (708466) Client [Sonoff-T1-GaesteWC] reconnected. Old secret 1706670331240_9187. New secret 1706749351661_5656
    2024-02-01 02:02:33.299  - info: sonoff.0 (708466) Client [Sonoff-Wohnwand_links] reconnected. Old secret 1706664532152_3536. New secret 1706749351694_7582
    2024-02-01 02:02:33.301  - info: sonoff.0 (708466) Client [Sonoff-Wohnwand_rechts] reconnected. Old secret 1706664532175_2253. New secret 1706749351715_5510
    2024-02-01 02:02:33.304  - info: sonoff.0 (708466) Client [Sonoff_basic_chill] reconnected. Old secret 1706664532219_3611. New secret 1706749351762_9742
    2024-02-01 02:02:33.306  - info: sonoff.0 (708466) Client [Sonoff-Ipad-Küche] reconnected. Old secret 1706664532177_8041. New secret 1706749351777_1561
    2024-02-01 02:02:33.384  - info: sonoff.0 (708466) Client [Sonoff-T1-GaesteWC] connection closed: closed
    2024-02-01 02:02:33.390  - info: sonoff.0 (708466) Client [Sonoff-Duftlampe] connection closed: closed
    2024-02-01 02:02:33.392  - info: sonoff.0 (708466) Client [Sonoff-TvBereich] connection closed: closed
    2024-02-01 02:02:33.401  - info: sonoff.0 (708466) Client [Sonoff-Spuelmaschine] connection closed: closed
    2024-02-01 02:02:33.419  - info: sonoff.0 (708466) terminating
    2024-02-01 02:02:33.460  - info: sonoff.0 (708466) Terminated (NO_ERROR): Without reason
    2024-02-01 02:02:33.685  - info: hmip.0 (708403) terminating with timeout
    2024-02-01 02:02:33.830  - info: sonoff.0 (708466) terminating with timeout
    2024-02-01 02:02:34.413  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:37.197  - info: sonoff.0 (708466) Client [Sonoff-Spuelmaschine] connected with secret 1706749357196_1635
    2024-02-01 02:02:37.769  - info: sonoff.0 (708466) Client [Sonoff-TvBereich] connected with secret 1706749357767_8563
    2024-02-01 02:02:39.980  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:45.674  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:51.187  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:02:51.562  - error: backitup.0 (708384) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/iobroker_2024_02_01-02_00_11_backupiobroker.tar.gz" not found
    2024-02-01 02:02:56.604  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:02.014  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:06.671  - error: backitup.0 (708384) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    2024-02-01 02:03:07.373  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:12.908  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:18.350  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:23.750  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:29.137  - error: backitup.0 (708384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2024-02-01 02:03:31.697  - warn: backitup.0 (708384) get state error: Connection is closed.
    2024-02-01 02:03:31.706  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.710  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.711  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.712  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.717  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.718  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.719  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.720  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.721  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.722  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.723  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.729  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.730  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.731  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.732  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.733  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.734  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.736  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.737  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.738  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.739  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.740  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.741  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.742  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.743  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.744  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.745  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.746  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.747  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.748  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.749  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.750  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.751  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.752  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.753  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.754  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.755  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.756  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.757  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.758  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.759  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.760  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.761  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.762  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.763  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.764  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.765  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.766  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.767  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.768  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.769  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.770  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.771  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.772  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.773  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.783  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.784  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.785  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.787  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.788  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.789  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.790  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.791  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.792  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.793  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.794  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.795  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.796  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.797  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.798  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.800  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.801  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.802  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.803  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.804  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.805  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.809  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.810  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.811  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.812  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.813  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.814  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.824  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.825  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.826  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.843  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.844  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.845  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.846  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.847  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.848  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.849  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.851  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.860  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.878  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:31.879  - warn: backitup.0 (708384) get state error: DB closed
    2024-02-01 02:03:32.163  - info: backitup.0 (708384) terminating
    2024-02-01 02:03:32.166  - info: backitup.0 (708384) terminating
    2024-02-01 02:03:59.773  - info: host.ioBroker-RasPi iobroker.js-controller version 5.0.17 js-controller starting
    2024-02-01 02:03:59.786  - info: host.ioBroker-RasPi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-02-01 02:03:59.787  - info: host.ioBroker-RasPi hostname: ioBroker-RasPi, node: v18.17.1
    2024-02-01 02:03:59.789  - info: host.ioBroker-RasPi ip addresses: 192.168.1.28 2a04:9740:12f:ca00:3536:e92a:94ff:d391 fe80::b756:ed78:8cec:2829
    2024-02-01 02:04:05.796  - info: host.ioBroker-RasPi connected to Objects and States
    2024-02-01 02:04:05.856  - info: host.ioBroker-RasPi added notifications configuration of host
    2024-02-01 02:04:10.243  - info: host.ioBroker-RasPi Delete state "system.host.ioBroker-RasPi.versions.nodeCurrent"
    2024-02-01 02:04:10.249  - info: host.ioBroker-RasPi 65 instances found
    2024-02-01 02:04:10.457  - info: host.ioBroker-RasPi starting 52 instances
    2024-02-01 02:04:11.192  - info: host.ioBroker-RasPi Delete state "system.host.ioBroker-RasPi.versions.nodeNewest"
    2024-02-01 02:04:11.214  - info: host.ioBroker-RasPi Delete state "system.host.ioBroker-RasPi.versions.nodeNewestNext"
    2024-02-01 02:04:11.298  - info: host.ioBroker-RasPi instance system.adapter.admin.0 started with pid 3290500
    2024-02-01 02:04:11.326  - info: host.ioBroker-RasPi Delete state "system.host.ioBroker-RasPi.versions.npmCurrent"
    2024-02-01 02:04:11.338  - info: host.ioBroker-RasPi Delete state "system.host.ioBroker-RasPi.versions.npmNewest"
    2024-02-01 02:04:11.356  - info: host.ioBroker-RasPi Delete state "system.host.ioBroker-RasPi.versions.npmNewestNext"
    2024-02-01 02:04:11.367  - info: host.ioBroker-RasPi Some obsolete host states deleted.
    2024-02-01 02:04:15.442  - info: host.ioBroker-RasPi instance system.adapter.history.0 started with pid 3290507
    2024-02-01 02:04:20.033  - info: host.ioBroker-RasPi instance system.adapter.javascript.0 started with pid 3290522
    2024-02-01 02:04:24.903  - info: host.ioBroker-RasPi instance system.adapter.scenes.0 started with pid 3290532
    2024-02-01 02:04:25.541  - info: admin.0 (3290500) starting. Version 6.13.15 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.17
    2024-02-01 02:04:25.741  - info: admin.0 (3290500) requesting all objects
    2024-02-01 02:04:40.918  - warn: javascript.0 (3290522) slow connection to objects DB. Still waiting ...
    2024-02-01 02:04:40.958  - warn: scenes.0 (3290532) slow connection to objects DB. Still waiting ...
    2024-02-01 02:04:50.626  - info: host.ioBroker-RasPi instance system.adapter.telegram.0 started with pid 3290559
    2024-02-01 02:04:57.106  - info: admin.0 (3290500) received all objects
    2024-02-01 02:04:59.952  - info: admin.0 (3290500) Request actual repository...
    2024-02-01 02:05:01.523  - info: host.ioBroker-RasPi instance system.adapter.whatsapp-cmb.0 started with pid 3290576
    2024-02-01 02:05:03.386  - info: admin.0 (3290500) socket.io server listening on port 8081
    2024-02-01 02:05:03.420  - info: admin.0 (3290500) http server listening on port 8081
    2024-02-01 02:05:03.421  - info: admin.0 (3290500) Use link "http://127.0.0.1:8081" to configure.
    2024-02-01 02:05:06.821  - info: host.ioBroker-RasPi instance system.adapter.alexa2.0 started with pid 3290587
    2024-02-01 02:05:07.894  - info: host.ioBroker-RasPi instance system.adapter.backitup.0 started with pid 3290594
    2024-02-01 02:05:08.978  - info: host.ioBroker-RasPi instance system.adapter.fritzbox.0 started with pid 3290601
    2024-02-01 02:05:10.743  - warn: telegram.0 (3290559) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:12.593  - info: host.ioBroker-RasPi instance scheduled system.adapter.ical.0 1,31 * * * *
    2024-02-01 02:05:12.767  - info: host.ioBroker-RasPi instance system.adapter.ical.0 started with pid 3290612
    2024-02-01 02:05:13.107  - info: host.ioBroker-RasPi instance system.adapter.hmip.0 started with pid 3290618
    2024-02-01 02:05:16.238  - warn: whatsapp-cmb.0 (3290576) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:17.142  - info: host.ioBroker-RasPi instance system.adapter.mihome-vacuum.0 started with pid 3290630
    2024-02-01 02:05:23.466  - info: host.ioBroker-RasPi instance system.adapter.mihome.0 started with pid 3290649
    2024-02-01 02:05:23.553  - warn: alexa2.0 (3290587) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:26.616  - warn: backitup.0 (3290594) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:27.770  - debug: mihome.0 (3290649) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-02-01 02:05:29.447  - warn: fritzbox.0 (3290601) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:30.418  - info: host.ioBroker-RasPi instance system.adapter.ping.0 started with pid 3290664
    2024-02-01 02:05:30.533  - debug: mihome.0 (3290649) Objects client ready ... initialize now
    2024-02-01 02:05:32.596  - warn: ical.0 (3290612) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:32.689  - warn: hmip.0 (3290618) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:35.511  - debug: mihome.0 (3290649) Objects create System PubSub Client
    2024-02-01 02:05:35.543  - warn: mihome-vacuum.0 (3290630) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:35.514  - debug: mihome.0 (3290649) Objects create User PubSub Client
    2024-02-01 02:05:35.846  - info: host.ioBroker-RasPi instance system.adapter.sonoff.0 started with pid 3290675
    2024-02-01 02:05:37.764  - warn: mihome.0 (3290649) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:43.464  - info: admin.0 (3290500) register notification warning
    2024-02-01 02:05:43.533  - info: host.ioBroker-RasPi instance system.adapter.sonos.0 started with pid 3290688
    2024-02-01 02:05:44.113  - warn: ping.0 (3290664) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:44.239  - info: host.ioBroker-RasPi instance system.adapter.tr-064.0 started with pid 3290695
    2024-02-01 02:05:49.817  - warn: sonoff.0 (3290675) slow connection to objects DB. Still waiting ...
    2024-02-01 02:05:53.000  - info: host.ioBroker-RasPi instance system.adapter.tuya.0 started with pid 3290711
    2024-02-01 02:05:53.045  - debug: mihome.0 (3290649) Objects client initialize lua scripts
    2024-02-01 02:05:56.806  - info: host.ioBroker-RasPi instance system.adapter.ham.0 started with pid 3290718
    2024-02-01 02:05:59.562  - info: host.ioBroker-RasPi instance scheduled system.adapter.daswetter.0 */15 * * * *
    2024-02-01 02:05:59.724  - info: host.ioBroker-RasPi instance system.adapter.daswetter.0 started with pid 3290729
    2024-02-01 02:06:01.632  - warn: sonos.0 (3290688) slow connection to objects DB. Still waiting ...
    @vatoslocos was mach dein DasWetter Adapter da im Millisekundentakt?
      CodierknechtC Offline
      Codierknecht
      @homoran sagte in Neustart Nachts - aber warum?:
      Der steht auf Debug und haut wohl alles raus was er hat 😵
      @vatoslocos
      Es sieht danach aus, dass Du den "dasWetter"-Adapter zur vollen Stunde die Daten holen lässt.
      Keine gute Idee, weil das die meisten so machen.
      Stelle dessen Zeitplan auf etwas "krummes" ein.
      Und stell' bei dem Ding den Loglevel um.
      Wird zu der besagten Zeit etwa Dein Router neu gestartet oder verbunden?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        @vatoslocos
        @codierknecht sagte in Neustart Nachts - aber warum?:
        ja, aber auch die error Meldungen kommen mehrfach die Sekunde
          Codierknecht
          Jo - stimmt auch wieder.
          @vatoslocos
          Vielleicht stoppst Du den Wetter-Adapter mal und beobachtest, ob das Phänomen weiterhin auftritt.
          • V vatoslocos
            @vatoslocos
            Da seh ich ja schon wieder Gammelversionen.
            Grundsanierung:
            iob stop
            iob fix
            iob nodejs-update
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            Dann
            iob update
            iob upgrade
            iob stop
            iob upgrade self
            iob start
            Läuft da zufällig um 2Uhr ein Backup?
            V 1 Antwort Letzte Antwort
            • V vatoslocos
              JoJo58J Offline
              JoJo58J Offline
              JoJo58
              schrieb am zuletzt editiert von JoJo58
              @vatoslocos
              Wie @Thomas-Braun schon sagte. Machst du zufällig über RaspiBackup ein Backup und hast bei "Zu stoppende und startende Services" den IoBroker aktiviert? Den Fehler hab ich mal gemacht und mich gewundert, was da los ist.
              Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
              Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
              Einfach ein tolles Hobby :-)
                @vatoslocos
                Grundsanierung:
                iob stop
                iob fix
                iob nodejs-update
                sudo apt update
                sudo reboot
                Dann
                iob update
                iob upgrade
                iob stop
                iob upgrade self
                iob start
                V Offline
                V Offline
                vatoslocos
                werde ich wohl dran müssen
                Am liebste direkt mit einem Umzuga auf eine andere Hardware..
                @JoJo58 Ja - es läuft um 2 Uhr über Backitup ein Tagesbackup.... Konnte aber da jetzt nicht sehen das er irgendwas stoppt - aber der Ansatz könnte richtig sein
                Thomas BraunT JoJo58J 3 Antworten Letzte Antwort
                • V vatoslocos
                  @vatoslocos sagte in Neustart Nachts - aber warum?:
                  Mach es jetzt, dann ist auch deine Basis stabil. Von dort aus kannst du dann immer noch auf Fehlersuche gehen.
                  • V vatoslocos
                    JoJo58J Offline
                    JoJo58J Offline
                    JoJo58
                    @vatoslocos
                    BackItUp vom IoBroker stoppt nichts, jedenfalls nicht das ich wüsste. Ich meinte ein Backup auf Linux Ebene.
                    • V vatoslocos
                      Das dürfte dir wohl den Speicher vollknallen. Wie bist du da ausgestattet?
                      iob diag
                      zeigen. Die Langfassung.
                        iob diag
                        V Offline
                        V Offline
                        vatoslocos
                        Nutze ich schon seit über 2 Jahren. Das Problem was ich habe ist aber erst seid ca. 1nem Monat aktiv
                        HomoranH Samson71S CodierknechtC 3 Antworten Letzte Antwort
                        • V vatoslocos
                          was?
                          iob diag?
                          dann zeig es uns
                          • V vatoslocos
                            Samson71S Offline
                            Samson71S Offline
                            Samson71
                            Das sagt
                            1. im Zweifelsfall gar nichts aus und
                            2. was ist so schwierig daran die von Helfern mehrfach geforderten Angaben zu liefern?
                            Markus
                            Bitte beachten:
                            • V vatoslocos
                              Codierknecht
                              Na irgendwann ist der Kram halt so groß, dass dem Backup dann der Speicher ausgeht.
                              Also:
                              iob diag
                              • Samson71S Samson71
                                Das sagt
                                V Offline
                                V Offline
                                vatoslocos
                                @samson71
                                Sorry, aber kein Verständnis für dein Kommentar...
                                1. bin ich dabei die einzelnen Schritte durchzugehen. Vielleicht habt Ihr mehr Ressourcen am Tag wie ich aber mal in 5 Minuten sind die Schritte von @Thomas-Braun nicht erledigt und
                                2. dann kann ich auch das liefern was über "iob diag" als Ausgabe kommt....
                                HomoranH Samson71S 2 Antworten Letzte Antwort
                                • V vatoslocos
                                  @samson71
                                  ääähm!
                                  wenn du jetzt die Schritte durchgehst ohne vorher das iob diag laufen zu lassen, werden wir nie erfahren was due Ursache war.
                                  Di hast du dann ja ggf. entfernt.
                                  • V vatoslocos
                                    @samson71
                                    Samson71S Offline
                                    Samson71S Offline
                                    Samson71
                                    @vatoslocos
                                    Es ging darum, dass Du anstelle das Ergebnis zu liefern, quasi versuchst zu erklären dass das ja schon seit Jahren so läuft. Also praktisch ja gar nicht das Problem sein kann. Im Übrigen eine sehr häufige Fehleinschätzung. Aber auch der Post kostet Zeit, die Du angeblich ja nicht hast und die erste Forderung nach einem 'iob diag' war da auch schon 7 Stunden alt.
                                    Markus
                                    Bitte beachten:
                                    • V Offline
                                      V Offline
                                      vatoslocos
                                      schrieb am zuletzt editiert von vatoslocos
                                      Copy text starting here:
                                                              v.2023-10-10
                                         Static hostname: ioBroker-RasPi
                                               Icon name: computer-desktop
                                                 Chassis: desktop
                                                  Kernel: Linux 5.10.0-16-amd64
                                            Architecture: x86-64
                                      Kernel:                 x86_64
                                      Userland:               amd64
                                      Timezone:               Europe/Berlin (CET, +0100)
                                      User-ID:                1000
                                      X-Server:               false
                                      Pending OS-Updates:     0
                                      Pending iob updates:    2
                                      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                              /usr/bin/node           v18.19.0
                                                              /usr/bin/npm            10.2.3
                                                              /usr/bin/npx            10.2.3
                                                              /usr/bin/corepack       0.22.0
                                      Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                      MEMORY:
                                      Mem:            3.4G        2.7G        200M        0.0K        544M        510M
                                      Swap:           1.5G        719M        785M
                                      Total:          4.9G        3.4G        985M
                                      Active iob-Instances:   35
                                      Active repo(s): beta
                                      ioBroker Core:          js-controller           5.0.19
                                                              admin                   6.13.16
                                      Objects type: jsonl
                                      States  type: redis
                                      + system.adapter.admin.0                  : admin                 : ioBroker-RasPi                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.web.0                    : web                   : ioBroker-RasPi                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                60222
                                      States:                 55616
                                      Size of iob-Database:
                                      54M     /opt/iobroker/iobroker-data/objects.jsonl
                                      19M     /opt/iobroker/iobroker-data/objects.json.migrated
                                      19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                      18M     /opt/iobroker/iobroker-data/objects.json.broken
                                      8.0K    /opt/iobroker/iobroker-data/states.json.bak
                                      4.0K    /opt/iobroker/iobroker-data/states.json
                                      === Mark text until here for copying ===
                                      • GlasfaserG Offline
                                        GlasfaserG Offline
                                        link zum log:
                                        Habe den Link mal (gesichert ) geöffnet ...
                                        Du wohnst in Stadtlohn ... deine Bankverbindung ist ...
                                        und
                                        processing URL: Termine Familie https://calendar.google.com/calendar/ical/XXXXXXX
                                        und retuschiere die Ausgaben in deinem Log !
                                        Zu deinen scheduled
                                        scheduled system.adapter.feiertage.0 0 0 * * *
                                        scheduled system.adapter.dwd.0 */5 * * * *
                                        backup will be activated at 02:00 every 1 day(s)
                                        States connected to redis: 127.0.0.1:6379
                                        Leider fehlt der Anfang vom Log , ich sehe eher das deine Datenbank zusammenbricht
                                        Infos zu deinem System , was man so aus dem Log ließt
                                        node: v18.17.1
                                        Raspberry
                                        • V vatoslocos
        v.2023-10-10
                                                     Chassis: desktop
                                          Kernel:                 x86_64
                                          Userland:               amd64
                                          User-ID:                1000
                                          X-Server:               false
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                          MEMORY:
        admin                   6.13.16
                                          Objects type: jsonl
                                          States  type: redis
                                          Objects:                60222
                                          States:                 55616
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @vatoslocos
                                          Bitte die Full Ausgabe !
