  4. Jarvis Adapter lässt sich nicht Installieren
83 Beiträge 5 Kommentatoren 12.5k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @schweiz
    Zeige mal
    iob diag
    aber die Full Ausgabe
    Schweiz
    @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:28:36 up 5 min,  2 users,  load average: 0.13, 0.65, 0.40
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-01-27 21:28:36 CET
               Universal time: Sat 2024-01-27 20:28:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    john
    /home/john
    john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        439M        3.2G        1.3M        405M        3.5G
    Swap:           104M          0B        104M
    Total:          4.1G        439M        3.3G
             3793 M total memory
              419 M used memory
              446 M active memory
              180 M inactive memory
             3061 M free memory
               39 M buffer memory
              346 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       59G  3.8G   52G   7% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Jan 27 21:22:48 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Jan 27 21:22:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jan 27 21:22:52 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    837M    /var/lib
    662M    /var/lib/piVCCU3
    604M    /var/lib/piVCCU3/rootfs
    279M    /var/lib/piVCCU3/rootfs/opt
    Archived and active journals take up 85.1M in the file system.
    /opt/iobroker/backups:
    34M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    319M    /opt/iobroker/iobroker-data/
    185M    /opt/iobroker/iobroker-data/files
    86M     /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    13M     /opt/iobroker/iobroker-data/states.jsonl
    13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.19.0
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v18.19.0
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.19.0
    admin:
      throw err;
      requireStack: []
    Node.js v18.19.0
    javascript:
    Adapters from github:   0
    Adapter State
      throw err;
      requireStack: []
    Node.js v18.19.0
      throw err;
      requireStack: []
    Node.js v18.19.0
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v18.19.0
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v18.19.0
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 10
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16812      1009/sshd: /usr/sbi
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16839      1053/dnsmasq
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16814      1009/sshd: /usr/sbi
    udp        0      0 0.0.0.0:56245           0.0.0.0:*                           104        15562      507/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15560      507/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16838      1053/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16835      1053/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      906/dhclient
    udp6       0      0 :::46068                :::*                                104        15563      507/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        15561      507/avahi-daemon: r
    - /opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js
    - /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
    - /opt/iobroker/node_modules/iobroker.alexa2/main.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Function.Module._load (node:internal/modules/cjs/loader:975:27)
        at Module.require (node:internal/modules/cjs/loader:1225:19)
        at require (node:internal/modules/helpers:177:18)
        at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:82
        at AdapterClass._setObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:34)
    2024-01-27 21:24:08.726  - error: alexa2.0 (1919) Exception-Code: MODULE_NOT_FOUND: Cannot find module './defaultObjs.js'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/index.js
    - /opt/iobroker/node_modules/@iobroker/adapter-core/build/utils.js
    2024-01-27 21:24:09.032  - info: hm-rpc.1 (2113) terminating
    2024-01-27 21:24:09.035  - info: hm-rpc.1 (2113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-27 21:24:09.065  - info: hm-rpc.0 (1981) terminating
    2024-01-27 21:24:09.069  - info: hm-rpc.0 (1981) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-27 21:24:09.083  - error: iceroad.0 (2213) Objects database error: read ECONNRESET
    2024-01-27 21:24:10.692  - info: iceroad.0 (2213) terminating with timeout
    2024-01-27 21:24:10.694  - info: iceroad.0 (2213) Terminated (NO_ERROR): Without reason
    2024-01-27 21:24:14.100  - warn: iceroad.0 (2213) get state error: Connection is closed.
    MFG Schweizer
    • GlasfaserG Offline
      GlasfaserG Offline
      @schweiz
      cd /opt/iobroker
      npm cache clean --force
      sudo -H -u iobroker npm install iobroker.js-controller
      S GlasfaserG 2 Antworten Letzte Antwort
        @schweiz
        cd /opt/iobroker
        Schweiz
        john@raspberrypi:~ $ cd /opt/iobroker
        john@raspberrypi:/opt/iobroker $ npm cache clean --force
        npm WARN using --force Recommended protections disabled.
        john@raspberrypi:/opt/iobroker $ iob stop
        john@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-con        troller
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
        added 275 packages, and removed 2 packages in 1m
        25 packages are looking for funding
          run `npm fund` for details
        sudo reboot
        iob start
        das komplette system ist tot, es startet nicht mehr seid
        iob stop
        rm /opt/iobroker/package*
        sudo reboot
        nun schaut es anders aus...
        iob upgrade alexa2@3.26.4 --debug
        Would you like to reinstall version 3.26.4 of alexa2 now? [(y)es, (n)o]: y
        Update alexa2 from @3.26.4 to @3.26.4
        NPM version: 10.2.3
        Installing iobroker.alexa2@3.26.4... (System call)
        removed 58 packages, and changed 1 package in 6s
        Update "system.adapter.alexa2.0"
        upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.        png alexa.png image/png
        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot3.png icons/echo_dot3.png image/png
        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot4.png icons/echo_dot4.png image/png
        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_flex.png icons/echo_flex.png image/png
        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_plus2.png icons/echo_plus2.png image/png
        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show.png icons/echo_show.png image/png
        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show2.png icons/echo_show2.png image/png
        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show5.png icons/echo_show5.png image/png
        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_studio.png icons/echo_studio.png image/png
        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_sub.png icons/echo_sub.png image/png
        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetab.png icons/firetab.png image/png
        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetv.png icons/firetv.png image/png
        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        icrophone.png icons/microphone.png image/png
        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        ultiroom.png icons/multiroom.png image/png
        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        aspi.png icons/raspi.png image/png
        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        everb.png icons/reverb.png image/png
        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        onos.png icons/sonos.png image/png
        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        pot.png icons/spot.png image/png
        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m        .html index_m.html text/html
        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.pn        g info.png image/png
        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning        .png warning.png image/png
        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.j        s words.js application/javascript
        aber wie starte ich das ganze jetzt wider....????
        MFG Schweizer
        GlasfaserG HomoranH 2 Antworten Letzte Antwort
        • S Schweiz
          sudo reboot
          iob start
          iob stop
          sudo reboot
          NPM version: 10.2.3
          MFG Schweizer
          GlasfaserG Offline
          GlasfaserG Offline
          @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
          dann zeige jetzt nochmal
          iob diag
          • S Schweiz
            sudo reboot
            iob start
            iob stop
            sudo reboot
            NPM version: 10.2.3
            MFG Schweizer
            zeig noch mal ein aktuelles iob diag
              Schweiz
              @homoran sagte in Jarvis Adapter lässt sich nicht Installieren:
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               21:45:09 up 9 min,  2 users,  load average: 2.33, 1.94, 1.07
              CPU threads: 4
              Current issues:
                             Local time: Sat 2024-01-27 21:45:10 CET
                         Universal time: Sat 2024-01-27 20:45:10 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              john
              /home/john
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        1.5G        1.0G        1.3M        1.5G        2.4G
              Swap:           104M          0B        104M
              Total:          4.1G        1.5G        1.2G
                       3793 M total memory
                       1476 M used memory
                       1483 M active memory
                       1141 M inactive memory
                        996 M free memory
                         41 M buffer memory
                       1363 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
              [Sat Jan 27 21:35:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Jan 27 21:35:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sat Jan 27 21:35:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              /var:
              1.3G    /var/
              837M    /var/lib
              Archived and active journals take up 101.1M in the file system.
              323M    /opt/iobroker/iobroker-data/
              40M     /opt/iobroker/iobroker-data/objects.jsonl
              14M     /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              npm ERR! code ELSPROBLEMS
              npm ERR! extraneous: iobroker.viessmannapi@2.4.0 /opt/iobroker/node_modules/iobroker.viessmannapi
              npm ERR! extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
              npm ERR! extraneous: qs@6.11.2 /opt/iobroker/node_modules/iobroker.viessmannapi/node_modules/qs
              npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
              npm ERR! A complete log of this run can be found in: /home/john/.npm/_logs/2024-01-27T20_45_21_968Z-debug-0.log
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              js-controller:  5.0.17
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   1
              Adapter State
                system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
              + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
                system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
              + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.iceroad.0                : iceroad               : raspberrypi                              -  enabled
                system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
              + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
              + system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              -  enabled
              + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                system.adapter.youtube.0                : youtube               : raspberrypi                              - disabled
              + instance is alive
              Active repo(s): stable
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "telegram"     : 3.0.1    , installed 3.0.1
              Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
              Adapter    "weather-warnings": 0.6.6 , installed 0.6.4  [Updatable]
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "worx"         : 2.3.4    , installed 2.3.4
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "youtube"      : 4.4.0    , installed 4.4.0
              Objects and States
              Objects:        11787
              States:         9567
              Pending Updates: 10
              tcp        0      0 192.168.2.113:2010      0.0.0.0:*               LISTEN      1001       28770      4393/io.hm-rpc.1
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16496      966/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16017      966/iobroker.js-con
              tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14299      1058/dnsmasq
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15842      1012/sshd: /usr/sbi
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25725      3881/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26787      4256/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15853      1012/sshd: /usr/sbi
              udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14298      1058/dnsmasq
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14295      1058/dnsmasq
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13253      909/dhclient
              udp        0      0 0.0.0.0:55548           0.0.0.0:*                           104        15391      437/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15389      437/avahi-daemon: r
              udp6       0      0 :::53648                :::*                                104        15392      437/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        15390      437/avahi-daemon: r
              2024-01-27 21:45:39.402  - info: hm-rpc.1 (3986) Terminated (NO_ERROR): Without reason
              2024-01-27 21:45:39.430  - info: hm-rpc.1 (3986) terminating
              2024-01-27 21:45:39.471  - info: hm-rpc.1 (3986) terminating
              2024-01-27 21:45:39.920  - info: admin.0 (4256) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2024-01-27 21:45:40.017  - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
              2024-01-27 21:45:40.017  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
              2024-01-27 21:45:40.257  - info: admin.0 (4256) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
              2024-01-27 21:45:40.316  - info: admin.0 (4256) requesting all objects
              2024-01-27 21:45:43.816  - info: admin.0 (4256) received all objects
              2024-01-27 21:45:44.637  - info: admin.0 (4256) socket.io server listening on port 8081
              2024-01-27 21:45:44.644  - info: admin.0 (4256) http server listening on port 8081
              2024-01-27 21:45:44.645  - info: admin.0 (4256) Use link "http://127.0.0.1:8081" to configure.
              2024-01-27 21:46:02.392  - error: hm-rpc.0 (4197) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2001
              2024-01-27 21:46:02.414  - info: hm-rpc.0 (4197) xmlrpc -> 192.168.2.122:2001/ init ["http://192.168.2.113:2001",""]
              2024-01-27 21:46:03.422  - info: hm-rpc.0 (4197) terminating
              2024-01-27 21:46:03.425  - info: hm-rpc.0 (4197) Terminated (NO_ERROR): Without reason
              2024-01-27 21:46:04.037  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
              2024-01-27 21:46:04.038  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
              2024-01-27 21:46:08.568  - error: hm-rega.0 (2608) CCU 192.168.2.122 unreachable
              2024-01-27 21:46:10.169  - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 4393
              2024-01-27 21:46:12.464  - info: hm-rpc.1 (4393) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2024-01-27 21:46:12.735  - info: hm-rpc.1 (4393) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
              2024-01-27 21:46:13.081  - info: hm-rpc.1 (4393) xmlrpc server is trying to listen on 192.168.2.113:2010
              2024-01-27 21:46:13.082  - info: hm-rpc.1 (4393) xmlrpc client is trying to connect to 192.168.2.122:2010/ with ["http://192.168.2.113:2010","raspberrypi:hm-rpc.1:ff6dfd3a7f0f6cc5fcbfb9b363ac5e5a"]
              2024-01-27 21:46:16.186  - error: hm-rpc.1 (4393) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2010
              wenn ich iob fix mache kommt
              john@raspberrypi:/opt/iobroker $ iob fix
              library: loaded
              Library version=2024-01-04
              ioBroker or some processes are still running:
               io.alexa2.0
               io.telegram.0
               io.javascript.0
               io.discovery.0
               io.backitup.0
               io.enigma2.0
               io.heizoel.0
               io.tankerkoenig.0
               io.worx.0
              Please stop them first and try again!
              klar, irgendwas läuft, nur nicht ccu und nicht iob
              MFG Schweizer
              HomoranH GlasfaserG 4 Antworten Letzte Antwort
              • S Schweiz
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                john
                /home/john
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           104M          0B        104M
                         3793 M total memory
                         1476 M used memory
                          996 M free memory
                           41 M buffer memory
                         1363 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.3G    /var/
                837M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        11787
                States:         9567
                Pending Updates: 10
                library: loaded
                 io.alexa2.0
                 io.telegram.0
                 io.javascript.0
                 io.discovery.0
                 io.backitup.0
                 io.enigma2.0
                 io.heizoel.0
                 io.tankerkoenig.0
                 io.worx.0
                MFG Schweizer
                iob läuft, auch der admin.
                zumindest war das als diag lief
                • S Schweiz
                  iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  john
                  /home/john
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           104M          0B        104M
                           3793 M total memory
                           1476 M used memory
                            996 M free memory
                             41 M buffer memory
                           1363 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.3G    /var/
                  837M    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        11787
                  States:         9567
                  Pending Updates: 10
                  library: loaded
                   io.alexa2.0
                   io.telegram.0
                   io.javascript.0
                   io.discovery.0
                   io.backitup.0
                   io.enigma2.0
                   io.heizoel.0
                   io.tankerkoenig.0
                   io.worx.0
                  MFG Schweizer
                  nur nicht ccu
                  sudo pivccu-info
                  • S Schweiz
                    iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    john
                    /home/john
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                             3793 M total memory
                             1476 M used memory
                              996 M free memory
                               41 M buffer memory
                             1363 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.3G    /var/
                    837M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        11787
                    States:         9567
                    Pending Updates: 10
                    library: loaded
                     io.alexa2.0
                     io.telegram.0
                     io.javascript.0
                     io.discovery.0
                     io.backitup.0
                     io.enigma2.0
                     io.heizoel.0
                     io.tankerkoenig.0
                     io.worx.0
                    MFG Schweizer
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Logo ... steht doch da
                    iob stop
                    zuvor
                      iob stop
                      zuvor
                      Schweiz
                      ich hatte iob fix nur ausgeführt um zu sehen ob es mit iob start gestartet ist, aber ich habe keinen zugriff auf die oberfläche bekommen.
                      Nun nochmal sudo reboot gemacht und nun geht es...
                      CCU läuft auch, aber...
                      das ist echt strange...
                      über die console ging es mit dem alexa Adapter... zu aktuallsieren
                      über IOB geht es nicht mit dem wetter Adapter...
                      und über die console auch nicht ;(
                      john@raspberrypi:/opt/iobroker $ john@raspberrypi:/opt/iobroker $ iob upgrade weather-warnings@0.6.6 --debug
                      This upgrade of "weather-warnings" will introduce the following changes:
                      -> 0.6.6:
                      fullday(ZAMG only): If time span is 24h +/- 5 minutes and the start hour is between 0-3, day of the week from start time, otherwise blank.
                      -> 0.6.5:
                      Added: ZAMG full day token
                      fixed: Send emails asynchron
                      fixed: dont ignore uwz activate setting
                      update dp-objects on every start.
                      Would you like to upgrade weather-warnings from @0.6.4 to @0.6.6 now? [(y)es, (n)o]: y
                      Update weather-warnings from @0.6.4 to @0.6.6
                      NPM version: 10.2.3
                      Installing iobroker.weather-warnings@0.6.6... (System call)
                      npm ERR! code ETIMEDOUT
                      npm ERR! syscall connect
                      npm ERR! errno ETIMEDOUT
                      npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:223:443
                      npm ERR! network This is a problem related to network connectivity.
                      npm ERR! network In most cases you are behind a proxy or have bad network settings.
                      npm ERR! network
                      npm ERR! network If you are behind a proxy, please make sure that the
                      npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_09_40_353Z-debug-0.log
                      npm ERR! network
                      host.raspberrypi Cannot install iobroker.weather-warnings@0.6.6: 1
                      und nach wie vor kein anderer Adapter...
                      ich verzweifle bald...
                      MFG Schweizer
                      • S Schweiz
                        -> 0.6.6:
                        -> 0.6.5:
                        NPM version: 10.2.3
                        npm ERR! network
                        npm ERR! network
                        MFG Schweizer
                        da hatten wir ja auch das Problem vorher behoben.
                        dann musst du da auch nochmal mit --debug arbeiten
                        • S Schweiz
                          -> 0.6.6:
                          -> 0.6.5:
                          NPM version: 10.2.3
                          npm ERR! network
                          npm ERR! network
                          MFG Schweizer
                          doch wieder ipv6 Probleme?
                            Schweiz
                            nein, am gleichen tag als ich die anderen adapter installiert habe wollte ich auch jarvis installieren, weil das so an sich das letzte war,... das die anderen auch nicht gehen war mir nicht bewusst... auch hat der Internet Test ja gezeigt das IPV6 voll da ist...
                            hab ich doch gemacht mit Debug, siehe gerade eben... ;)
                            MFG Schweizer
                            • S Schweiz
                              MFG Schweizer
                              aber nicht den debug.log der da genannt wird gezeigt
                              • S Schweiz
                                -> 0.6.6:
                                -> 0.6.5:
                                NPM version: 10.2.3
                                npm ERR! network
                                npm ERR! network
                                MFG Schweizer
                                GlasfaserG Offline
                                GlasfaserG Offline
                                curl -L -o iobroker.weather-warnings-0.6.6.tgz https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz
                                Ausgabe zeigen
                                • S Schweiz
                                  MFG Schweizer
                                  auch vom iob server aus getestet?
                                  kopier dir mal den Link in meinem Quote in einen Browser.
                                  ich kann das tar.gz runterladen, und du?
                                    Schweiz
                                    curl -L -o iobroker.weather-warnings-0.6.6.tgz https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgzgz
                                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                    100  849k  100  849k    0     0   990k      0 --:--:-- --:--:-- --:--:--  989k
                                    • S Schweiz
                                      -> 0.6.6:
                                      -> 0.6.5:
                                      NPM version: 10.2.3
                                      npm ERR! network
                                      npm ERR! network
                                      MFG Schweizer
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Zeige uns den Inhalt davon
                                        GlasfaserG Offline
                                        Was ist das .... hast du ein DNS Server eingerichtet !?
                                          Schweiz
                                          kann ich herunter laden...
                                          ein dns habe ich nicht eingerichtet... wüsste nicht wo ich das finden soll im PI
                                          in der Fritz
                                          FRITZ!Box 7272 (UI)
                                          Schweiz, FRITZ!OS 06.89, FRITZ!OS ist aktuell
                                          FRITZ!Box-Anmeldung
                                          Mit Benutzername und Kennwort gesichert
                                          LAN
                                          LAN 1
                                          LAN 2
                                          LAN 3
                                          LAN 4
                                          LAN 1, LAN 2 im Power Mode, LAN 3, LAN 4 im Green Mode
                                          WLAN
                                          Funknetzname: Schweiz
                                          aktuell 8 WLAN-Geräte verbunden, gesichert
                                          DECT
                                          aus
                                          USB-Geräte
                                          kein Gerät angeschlossen
                                          Internetverbindung
                                          IPv4: Eine bestehende Internetverbindung im Netzwerk wird mitbenutzt. IPv4-Adresse: 192.168.2.105
                                          IPv6: Eine bestehende Internetverbindung im Netzwerk wird mitbenutzt. IPv6-Adresse: 2003:f9:e724:fa91:3631:c4ff:fee4:338b
                                          Rufnummern
                                          Keine Rufnummern aktiv. Die Funktion der Festnetzrufnummer lässt sich nicht ermitteln.
                                          Heimnetz
                                          93 Geräte im Heimnetz, 0 davon online
                                          WLAN-Umgebung
                                          1 WLAN-Netz auf demselben Kanal aktiv
                                          keine WLAN-Netze mit demselben Namen
                                          PI ist auf LAN2
                                          -> 0.6.6:
                                          -> 0.6.5:
                                          NPM version: 10.2.3
                                          npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                                          npm ERR! network
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                          npm ERR! network
                                          john@raspberrypi:~ $ nano /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                            GNU nano 7.2                                                        /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                          0 verbose cli /usr/bin/node /usr/bin/npm
                                          1 info using npm@10.2.3
                                          2 info using node@v18.19.0
                                          3 timing npm:load:whichnode Completed in 4ms
                                          4 timing config:load:defaults Completed in 6ms
                                          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                                          6 timing config:load:builtin Completed in 4ms
                                          7 timing config:load:cli Completed in 12ms
                                          8 timing config:load:env Completed in 0ms
                                          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 6ms
                                          10 timing config:load:project Completed in 17ms
                                          11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                          12 timing config:load:user Completed in 1ms
                                          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                          14 timing config:load:global Completed in 0ms
                                          15 timing config:load:setEnvs Completed in 3ms
                                          16 timing config:load Completed in 48ms
                                          17 timing npm:load:configload Completed in 49ms
                                          18 timing config:load:flatten Completed in 9ms
                                          19 timing npm:load:mkdirpcache Completed in 1ms
                                          20 timing npm:load:mkdirplogs Completed in 1ms
                                          21 verbose title npm install iobroker.weather-warnings@0.6.6
                                          22 verbose argv "install" "--save-exact" "iobroker.weather-warnings@0.6.6"
                                          23 timing npm:load:setTitle Completed in 4ms
                                          24 timing npm:load:display Completed in 2ms
                                          25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-
                                          26 verbose logfile /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                          27 timing npm:load:logFile Completed in 30ms
                                          28 timing npm:load:timers Completed in 0ms
                                          29 timing npm:load:configScope Completed in 0ms
                                          30 timing npm:load Completed in 146ms
                                          31 timing arborist:ctor Completed in 3ms
                                          32 silly logfile start cleaning logs, removing 2 files
                                          33 silly logfile done cleaning log files
                                          34 timing idealTree:init Completed in 2377ms
                                          35 timing idealTree:userRequests Completed in 5ms
                                          36 silly idealTree buildDeps
                                          37 silly fetch manifest iobroker.weather-warnings@0.6.6
                                          38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                                          39 http fetch GET 200 https://registry.npmjs.org/iobroker.weather-warnings 460159ms (cache stale)
                                          40 silly placeDep ROOT iobroker.weather-warnings@0.6.6 REPLACE for: iobroker.core@1.0.0 want: 0.6.6
                                          41 timing idealTree:#root Completed in 460231ms
                                          42 timing idealTree:node_modules/iobroker.weather-warnings Completed in 0ms
                                          43 timing idealTree:buildDeps Completed in 460235ms
                                          44 timing idealTree:fixDepFlags Completed in 62ms
                                          45 timing idealTree Completed in 462726ms
                                          46 timing reify:loadTrees Completed in 462730ms
                                          47 timing reify:diffTrees Completed in 74ms
                                          MFG Schweizer
