  4. Jarvis Adapter lässt sich nicht Installieren
83 Beiträge 5 Kommentatoren 12.5k Aufrufe 2 Beobachtet
    @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
    complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
    zeigen
      zeigen
      Schweiz
      john@raspberrypi:~ $ curl -L -o diag.sh https://iobroker.net/diag.sh
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
      100   185  100   185    0     0    693      0 --:--:-- --:--:-- --:--:--   692
      100 18519  100 18519    0     0  25049      0 --:--:-- --:--:-- --:--:-- 25049
      john@raspberrypi:~ $ nano /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-deb        ug-0.log
        GNU nano 7.2                                                        /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.2.3
      2 info using node@v18.19.0
      3 timing npm:load:whichnode Completed in 4ms
      4 timing config:load:defaults Completed in 6ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
      6 timing config:load:builtin Completed in 4ms
      7 timing config:load:cli Completed in 12ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
      10 timing config:load:project Completed in 18ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 3ms
      16 timing config:load Completed in 49ms
      17 timing npm:load:configload Completed in 50ms
      18 timing config:load:flatten Completed in 9ms
      19 timing npm:load:mkdirpcache Completed in 1ms
      20 timing npm:load:mkdirplogs Completed in 0ms
      21 verbose title npm install iobroker.alexa2@3.26.4
      22 verbose argv "install" "--save-exact" "iobroker.alexa2@3.26.4"
      23 timing npm:load:setTitle Completed in 4ms
      24 timing npm:load:display Completed in 2ms
      25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-
      26 verbose logfile /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
      27 timing npm:load:logFile Completed in 29ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 1ms
      30 timing npm:load Completed in 146ms
      31 timing arborist:ctor Completed in 3ms
      32 silly logfile start cleaning logs, removing 2 files
      33 silly logfile done cleaning log files
      34 timing idealTree:init Completed in 2412ms
      35 timing idealTree:userRequests Completed in 5ms
      36 silly idealTree buildDeps
      37 silly fetch manifest iobroker.alexa2@3.26.4
      38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
      39 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 460149ms (cache stale)
      40 silly placeDep ROOT iobroker.alexa2@ REPLACE for: iobroker.inst@3.0.0 want: 3.26.4
      41 timing idealTree:#root Completed in 460211ms
      42 timing idealTree:node_modules/iobroker.alexa2 Completed in 1ms
      43 timing idealTree:buildDeps Completed in 460215ms
      44 timing idealTree:fixDepFlags Completed in 85ms
      45 timing idealTree Completed in 462721ms
      46 timing command:install Completed in 462749ms
      47 verbose type version
      MFG Schweizer
      • S Schweiz
        MFG Schweizer
        GlasfaserG Offline
        GlasfaserG Offline
        iob stop
        rm /opt/iobroker/package*
        sudo reboot
        • GlasfaserG Glasfaser
          iob stop
          sudo reboot
          Schweiz
          @glasfaser
          john@raspberrypi:~ $ iob upgrade alexa2@3.26.4 --debug
          This upgrade of "alexa2" will introduce the following changes:
          -> 3.26.4:
          Removed Weblink
          Adjust History query to recent Amazon changes
          Would you like to upgrade alexa2 from @3.26.3 to @3.26.4 now? [(y)es, (n)o]: y
          Update alexa2 from @3.26.3 to @3.26.4
          NPM version: 10.2.3
          Installing iobroker.alexa2@3.26.4... (System call)
          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          removed 746 packages, and changed 20 packages in 29s
          15 packages are looking for funding
            run `npm fund` for details
          Could not install iobroker.alexa2@3.26.4: Could not determine controller directory
          Cannot upgrade: Could not determine controller directory
          MFG Schweizer
          GlasfaserG S 2 Antworten Letzte Antwort
          • S Schweiz
            @glasfaser
            -> 3.26.4:
            Removed Weblink
            NPM version: 10.2.3
            MFG Schweizer
            GlasfaserG Offline
            GlasfaserG Offline
            @schweiz
            Zeige mal
            iob diag
            aber die Full Ausgabe
            • S Schweiz
              @glasfaser
              -> 3.26.4:
              Removed Weblink
              NPM version: 10.2.3
              MFG Schweizer
              Schweiz
              und es lässt sich weder iobroker noch homematic starten ;(
              MFG Schweizer
              • S Schweiz
                MFG Schweizer
                GlasfaserG Offline
                GlasfaserG Offline
                MFG Schweizer
                Hat aber nichts mit den Befehlen von mir zu tun !
                Da klemmt eher was bei dir !
                Starte nochmal durch , dann
                iob diag
                  @schweiz
                  Zeige mal
                  iob diag
                  Schweiz
                  @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
                  iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.1.0-rpi7-rpi-v8
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   21:28:36 up 5 min,  2 users,  load average: 0.13, 0.65, 0.40
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Sat 2024-01-27 21:28:36 CET
                             Universal time: Sat 2024-01-27 20:28:36 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  john
                  /home/john
                  john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            4.0G        439M        3.2G        1.3M        405M        3.5G
                  Swap:           104M          0B        104M
                  Total:          4.1G        439M        3.3G
                           3793 M total memory
                            419 M used memory
                            446 M active memory
                            180 M inactive memory
                           3061 M free memory
                             39 M buffer memory
                            346 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                  /dev/mmcblk0p2 ext4       59G  3.8G   52G   7% /
                  tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                  /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Sat Jan 27 21:22:48 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sat Jan 27 21:22:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sat Jan 27 21:22:52 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET           SOURCE         FSTYPE OPTIONS
                  /                /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.2G    /var/
                  837M    /var/lib
                  662M    /var/lib/piVCCU3
                  604M    /var/lib/piVCCU3/rootfs
                  279M    /var/lib/piVCCU3/rootfs/opt
                  Archived and active journals take up 85.1M in the file system.
                  /opt/iobroker/backups:
                  34M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  319M    /opt/iobroker/iobroker-data/
                  185M    /opt/iobroker/iobroker-data/files
                  86M     /opt/iobroker/iobroker-data/backup-objects
                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                  49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
                  38M     /opt/iobroker/iobroker-data/objects.jsonl
                  36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                  13M     /opt/iobroker/iobroker-data/states.jsonl
                  13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
                  USB-Devices by-id:
                  find: '/dev/serial/by-id/': No such file or directory
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.19.0
                  /usr/bin/node           v18.19.0
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  /usr/bin/corepack       0.22.0
                  nodejs:
                    Installed: 18.19.0-1nodesource1
                    Candidate: 18.19.0-1nodesource1
                    Version table:
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                   *** 18.19.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0+dfsg1-1 500
                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  node:internal/modules/cjs/loader:1137
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                      at Module._load (node:internal/modules/cjs/loader:975:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                      at node:internal/main/run_main_module:28:49 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  Node.js v18.19.0
                  Core adapters versions
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                  js-controller:
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                  admin:
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                  javascript:
                  Adapters from github:   0
                  Adapter State
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                  ioBroker-Repositories
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                  Installed ioBroker-Instances
                    throw err;
                    requireStack: []
                  Node.js v18.19.0
                  Objects and States
                  Objects:        0
                  States:         0
                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                  Reading package lists...
                  Pending Updates: 10
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16812      1009/sshd: /usr/sbi
                  tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16839      1053/dnsmasq
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16814      1009/sshd: /usr/sbi
                  udp        0      0 0.0.0.0:56245           0.0.0.0:*                           104        15562      507/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15560      507/avahi-daemon: r
                  udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16838      1053/dnsmasq
                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16835      1053/dnsmasq
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      906/dhclient
                  udp6       0      0 :::46068                :::*                                104        15563      507/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        15561      507/avahi-daemon: r
                  - /opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js
                  - /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
                  - /opt/iobroker/node_modules/iobroker.alexa2/main.js
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                      at Function.Module._load (node:internal/modules/cjs/loader:975:27)
                      at Module.require (node:internal/modules/cjs/loader:1225:19)
                      at require (node:internal/modules/helpers:177:18)
                      at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:82
                      at AdapterClass._setObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:34)
                  2024-01-27 21:24:08.726  - error: alexa2.0 (1919) Exception-Code: MODULE_NOT_FOUND: Cannot find module './defaultObjs.js'
                  Require stack:
                  - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js
                  - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/index.js
                  - /opt/iobroker/node_modules/@iobroker/adapter-core/build/utils.js
                  2024-01-27 21:24:09.032  - info: hm-rpc.1 (2113) terminating
                  2024-01-27 21:24:09.035  - info: hm-rpc.1 (2113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-01-27 21:24:09.065  - info: hm-rpc.0 (1981) terminating
                  2024-01-27 21:24:09.069  - info: hm-rpc.0 (1981) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-01-27 21:24:09.083  - error: iceroad.0 (2213) Objects database error: read ECONNRESET
                  2024-01-27 21:24:10.692  - info: iceroad.0 (2213) terminating with timeout
                  2024-01-27 21:24:10.694  - info: iceroad.0 (2213) Terminated (NO_ERROR): Without reason
                  2024-01-27 21:24:14.100  - warn: iceroad.0 (2213) get state error: Connection is closed.
                  MFG Schweizer
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    @schweiz
                    cd /opt/iobroker
                    npm cache clean --force
                    sudo -H -u iobroker npm install iobroker.js-controller
                    S GlasfaserG 2 Antworten Letzte Antwort
                      @schweiz
                      cd /opt/iobroker
                      Schweiz
                      john@raspberrypi:~ $ cd /opt/iobroker
                      john@raspberrypi:/opt/iobroker $ npm cache clean --force
                      npm WARN using --force Recommended protections disabled.
                      john@raspberrypi:/opt/iobroker $ iob stop
                      john@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-con        troller
                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
                      added 275 packages, and removed 2 packages in 1m
                      25 packages are looking for funding
                      sudo reboot
                      iob start
                      das komplette system ist tot, es startet nicht mehr seid
                      iob stop
                      sudo reboot
                      nun schaut es anders aus...
                      Would you like to reinstall version 3.26.4 of alexa2 now? [(y)es, (n)o]: y
                      Update alexa2 from @3.26.4 to @3.26.4
                      NPM version: 10.2.3
                      removed 58 packages, and changed 1 package in 6s
                      Update "system.adapter.alexa2.0"
                      upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.        png alexa.png image/png
                      upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot3.png icons/echo_dot3.png image/png
                      upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot4.png icons/echo_dot4.png image/png
                      upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_flex.png icons/echo_flex.png image/png
                      upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_plus2.png icons/echo_plus2.png image/png
                      upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show.png icons/echo_show.png image/png
                      upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show2.png icons/echo_show2.png image/png
                      upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show5.png icons/echo_show5.png image/png
                      upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_studio.png icons/echo_studio.png image/png
                      upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_sub.png icons/echo_sub.png image/png
                      upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetab.png icons/firetab.png image/png
                      upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetv.png icons/firetv.png image/png
                      upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        icrophone.png icons/microphone.png image/png
                      upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        ultiroom.png icons/multiroom.png image/png
                      upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        aspi.png icons/raspi.png image/png
                      upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        everb.png icons/reverb.png image/png
                      upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        onos.png icons/sonos.png image/png
                      upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        pot.png icons/spot.png image/png
                      upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m        .html index_m.html text/html
                      upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.pn        g info.png image/png
                      upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning        .png warning.png image/png
                      upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.j        s words.js application/javascript
                      aber wie starte ich das ganze jetzt wider....????
                      MFG Schweizer
                      GlasfaserG HomoranH 2 Antworten Letzte Antwort
                      • S Schweiz
                        sudo reboot
                        iob start
                        iob stop
                        sudo reboot
                        NPM version: 10.2.3
                        MFG Schweizer
                        GlasfaserG Offline
                        GlasfaserG Offline
                        dann zeige jetzt nochmal
                        iob diag
                        • S Schweiz
                          sudo reboot
                          iob start
                          iob stop
                          sudo reboot
                          NPM version: 10.2.3
                          MFG Schweizer
                          zeig noch mal ein aktuelles iob diag
                            Schweiz
                            @homoran sagte in Jarvis Adapter lässt sich nicht Installieren:
                            iob diag
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             21:45:09 up 9 min,  2 users,  load average: 2.33, 1.94, 1.07
                            CPU threads: 4
                            Current issues:
                                           Local time: Sat 2024-01-27 21:45:10 CET
                                       Universal time: Sat 2024-01-27 20:45:10 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            john
                            /home/john
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.0G        1.5G        1.0G        1.3M        1.5G        2.4G
                            Swap:           104M          0B        104M
                            Total:          4.1G        1.5G        1.2G
                                     3793 M total memory
                                     1476 M used memory
                                     1483 M active memory
                                     1141 M inactive memory
                                      996 M free memory
                                       41 M buffer memory
                                     1363 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
                            [Sat Jan 27 21:35:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Sat Jan 27 21:35:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sat Jan 27 21:35:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            /var:
                            1.3G    /var/
                            837M    /var/lib
                            Archived and active journals take up 101.1M in the file system.
                            323M    /opt/iobroker/iobroker-data/
                            40M     /opt/iobroker/iobroker-data/objects.jsonl
                            14M     /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            npm ERR! code ELSPROBLEMS
                            npm ERR! extraneous: iobroker.viessmannapi@2.4.0 /opt/iobroker/node_modules/iobroker.viessmannapi
                            npm ERR! extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                            npm ERR! extraneous: qs@6.11.2 /opt/iobroker/node_modules/iobroker.viessmannapi/node_modules/qs
                            npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
                            npm ERR! A complete log of this run can be found in: /home/john/.npm/_logs/2024-01-27T20_45_21_968Z-debug-0.log
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            js-controller:  5.0.17
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapters from github:   1
                            Adapter State
                              system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                            + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                              system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                            + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                              system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                              system.adapter.iceroad.0                : iceroad               : raspberrypi                              -  enabled
                              system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                              system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
                            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                            + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                            + system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              -  enabled
                            + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                              system.adapter.youtube.0                : youtube               : raspberrypi                              - disabled
                            + instance is alive
                            Active repo(s): stable
                            Used repository: stable
                            Adapter    "admin"        : 6.12.0   , installed 6.12.0
                            Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                            Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                            Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                            Adapter    "ical"         : 1.13.3   , installed 1.13.3
                            Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                            Controller "js-controller": 5.0.17   , installed 5.0.17
                            Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                            Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                            Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
                            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                            Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
                            Adapter    "weather-warnings": 0.6.6 , installed 0.6.4  [Updatable]
                            Adapter    "web"          : 6.1.10   , installed 6.1.10
                            Adapter    "worx"         : 2.3.4    , installed 2.3.4
                            Adapter    "ws"           : 2.5.8    , installed 2.5.8
                            Adapter    "youtube"      : 4.4.0    , installed 4.4.0
                            Objects and States
                            Objects:        11787
                            States:         9567
                            Pending Updates: 10
                            tcp        0      0 192.168.2.113:2010      0.0.0.0:*               LISTEN      1001       28770      4393/io.hm-rpc.1
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16496      966/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16017      966/iobroker.js-con
                            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14299      1058/dnsmasq
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15842      1012/sshd: /usr/sbi
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25725      3881/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26787      4256/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          15853      1012/sshd: /usr/sbi
                            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14298      1058/dnsmasq
                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14295      1058/dnsmasq
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13253      909/dhclient
                            udp        0      0 0.0.0.0:55548           0.0.0.0:*                           104        15391      437/avahi-daemon: r
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15389      437/avahi-daemon: r
                            udp6       0      0 :::53648                :::*                                104        15392      437/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                104        15390      437/avahi-daemon: r
                            2024-01-27 21:45:39.402  - info: hm-rpc.1 (3986) Terminated (NO_ERROR): Without reason
                            2024-01-27 21:45:39.430  - info: hm-rpc.1 (3986) terminating
                            2024-01-27 21:45:39.471  - info: hm-rpc.1 (3986) terminating
                            2024-01-27 21:45:39.920  - info: admin.0 (4256) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2024-01-27 21:45:40.017  - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                            2024-01-27 21:45:40.017  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                            2024-01-27 21:45:40.257  - info: admin.0 (4256) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
                            2024-01-27 21:45:40.316  - info: admin.0 (4256) requesting all objects
                            2024-01-27 21:45:43.816  - info: admin.0 (4256) received all objects
                            2024-01-27 21:45:44.637  - info: admin.0 (4256) socket.io server listening on port 8081
                            2024-01-27 21:45:44.644  - info: admin.0 (4256) http server listening on port 8081
                            2024-01-27 21:45:44.645  - info: admin.0 (4256) Use link "http://127.0.0.1:8081" to configure.
                            2024-01-27 21:46:02.392  - error: hm-rpc.0 (4197) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2001
                            2024-01-27 21:46:02.414  - info: hm-rpc.0 (4197) xmlrpc -> 192.168.2.122:2001/ init ["http://192.168.2.113:2001",""]
                            2024-01-27 21:46:03.422  - info: hm-rpc.0 (4197) terminating
                            2024-01-27 21:46:03.425  - info: hm-rpc.0 (4197) Terminated (NO_ERROR): Without reason
                            2024-01-27 21:46:04.037  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                            2024-01-27 21:46:04.038  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                            2024-01-27 21:46:08.568  - error: hm-rega.0 (2608) CCU 192.168.2.122 unreachable
                            2024-01-27 21:46:10.169  - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 4393
                            2024-01-27 21:46:12.464  - info: hm-rpc.1 (4393) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2024-01-27 21:46:12.735  - info: hm-rpc.1 (4393) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                            2024-01-27 21:46:13.081  - info: hm-rpc.1 (4393) xmlrpc server is trying to listen on 192.168.2.113:2010
                            2024-01-27 21:46:13.082  - info: hm-rpc.1 (4393) xmlrpc client is trying to connect to 192.168.2.122:2010/ with ["http://192.168.2.113:2010","raspberrypi:hm-rpc.1:ff6dfd3a7f0f6cc5fcbfb9b363ac5e5a"]
                            2024-01-27 21:46:16.186  - error: hm-rpc.1 (4393) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2010
                            wenn ich iob fix mache kommt
                            john@raspberrypi:/opt/iobroker $ iob fix
                            library: loaded
                            Library version=2024-01-04
                            ioBroker or some processes are still running:
                             io.alexa2.0
                             io.telegram.0
                             io.javascript.0
                             io.discovery.0
                             io.backitup.0
                             io.enigma2.0
                             io.heizoel.0
                             io.tankerkoenig.0
                             io.worx.0
                            Please stop them first and try again!
                            klar, irgendwas läuft, nur nicht ccu und nicht iob
                            MFG Schweizer
                            HomoranH GlasfaserG 4 Antworten Letzte Antwort
                            • S Schweiz
                              iob diag
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              john
                              /home/john
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           104M          0B        104M
                                       3793 M total memory
                                       1476 M used memory
                                        996 M free memory
                                         41 M buffer memory
                                       1363 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              1.3G    /var/
                              837M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        11787
                              States:         9567
                              Pending Updates: 10
                              library: loaded
                               io.alexa2.0
                               io.telegram.0
                               io.javascript.0
                               io.discovery.0
                               io.backitup.0
                               io.enigma2.0
                               io.heizoel.0
                               io.tankerkoenig.0
                               io.worx.0
                              MFG Schweizer
                              iob läuft, auch der admin.
                              zumindest war das als diag lief
                              • S Schweiz
                                iob diag
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                john
                                /home/john
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           104M          0B        104M
                                         3793 M total memory
                                         1476 M used memory
                                          996 M free memory
                                           41 M buffer memory
                                         1363 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                1.3G    /var/
                                837M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        11787
                                States:         9567
                                Pending Updates: 10
                                library: loaded
                                 io.alexa2.0
                                 io.telegram.0
                                 io.javascript.0
                                 io.discovery.0
                                 io.backitup.0
                                 io.enigma2.0
                                 io.heizoel.0
                                 io.tankerkoenig.0
                                 io.worx.0
                                MFG Schweizer
                                nur nicht ccu
                                sudo pivccu-info
                                • S Schweiz
                                  iob diag
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  john
                                  /home/john
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           104M          0B        104M
                                           3793 M total memory
                                           1476 M used memory
                                            996 M free memory
                                             41 M buffer memory
                                           1363 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  1.3G    /var/
                                  837M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        11787
                                  States:         9567
                                  Pending Updates: 10
                                  library: loaded
                                   io.alexa2.0
                                   io.telegram.0
                                   io.javascript.0
                                   io.discovery.0
                                   io.backitup.0
                                   io.enigma2.0
                                   io.heizoel.0
                                   io.tankerkoenig.0
                                   io.worx.0
                                  MFG Schweizer
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Logo ... steht doch da
                                  iob stop
                                  zuvor
                                    iob stop
                                    zuvor
                                    Schweiz
                                    ich hatte iob fix nur ausgeführt um zu sehen ob es mit iob start gestartet ist, aber ich habe keinen zugriff auf die oberfläche bekommen.
                                    Nun nochmal sudo reboot gemacht und nun geht es...
                                    CCU läuft auch, aber...
                                    das ist echt strange...
                                    über die console ging es mit dem alexa Adapter... zu aktuallsieren
                                    über IOB geht es nicht mit dem wetter Adapter...
                                    und über die console auch nicht ;(
                                    john@raspberrypi:/opt/iobroker $ john@raspberrypi:/opt/iobroker $ iob upgrade weather-warnings@0.6.6 --debug
                                    This upgrade of "weather-warnings" will introduce the following changes:
                                    -> 0.6.6:
                                    fullday(ZAMG only): If time span is 24h +/- 5 minutes and the start hour is between 0-3, day of the week from start time, otherwise blank.
                                    -> 0.6.5:
                                    Added: ZAMG full day token
                                    fixed: Send emails asynchron
                                    fixed: dont ignore uwz activate setting
                                    update dp-objects on every start.
                                    Would you like to upgrade weather-warnings from @0.6.4 to @0.6.6 now? [(y)es, (n)o]: y
                                    Update weather-warnings from @0.6.4 to @0.6.6
                                    NPM version: 10.2.3
                                    Installing iobroker.weather-warnings@0.6.6... (System call)
                                    npm ERR! code ETIMEDOUT
                                    npm ERR! syscall connect
                                    npm ERR! errno ETIMEDOUT
                                    npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:223:443
                                    npm ERR! network This is a problem related to network connectivity.
                                    npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                    npm ERR! network
                                    npm ERR! network If you are behind a proxy, please make sure that the
                                    npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_09_40_353Z-debug-0.log
                                    npm ERR! network
                                    host.raspberrypi Cannot install iobroker.weather-warnings@0.6.6: 1
                                    und nach wie vor kein anderer Adapter...
                                    ich verzweifle bald...
                                    MFG Schweizer
                                    • S Schweiz
                                      -> 0.6.6:
                                      -> 0.6.5:
                                      NPM version: 10.2.3
                                      npm ERR! network
                                      npm ERR! network
                                      MFG Schweizer
                                      da hatten wir ja auch das Problem vorher behoben.
                                      dann musst du da auch nochmal mit --debug arbeiten
                                      • S Schweiz
                                        -> 0.6.6:
                                        -> 0.6.5:
                                        NPM version: 10.2.3
                                        npm ERR! network
                                        npm ERR! network
                                        MFG Schweizer
                                        doch wieder ipv6 Probleme?
                                          Schweiz
                                          nein, am gleichen tag als ich die anderen adapter installiert habe wollte ich auch jarvis installieren, weil das so an sich das letzte war,... das die anderen auch nicht gehen war mir nicht bewusst... auch hat der Internet Test ja gezeigt das IPV6 voll da ist...
                                          hab ich doch gemacht mit Debug, siehe gerade eben... ;)
                                          MFG Schweizer
