  4. Admin startet nicht - buanet image[gelöst]
55 Beiträge 2 Kommentatoren 6.3k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @hmuser sagte in Admin startet nicht - buanet image:
    Inzwischen ist 9.1.0 installiert,
    kannst du bitte die Full Ausgabe von
    iob diag
    davon mal zeigen !
    HMuser
    @glasfaser
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : Intel Corporation
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.1.0
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:34:54 up 4 days,  7:01,  0 user,  load average: 2.68, 2.29, 2.18
    CPU threads: 4
    *** Time and Time Zones ***
    Tue Jan 23 20:34:54 UTC 2024
    Tue Jan 23 21:34:54 CET 2024
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            1.0G        915M        120M        3.0M        230M        120M
    Swap:           2.8G        727M        2.0G
    Total:          3.8G        1.6G        2.2G
              988 M total memory
              873 M used memory
              195 M active memory
              239 M inactive memory
              115 M free memory
                8 M buffer memory
              211 M swap cache
             2641 M total swap
              693 M used swap
             1948 M free swap
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    none                   aufs   3.6T  1.7T  2.0T  47% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  495M     0  495M   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 ext4   3.6T  1.7T  2.0T  47% /opt/iobroker
    tmpfs                  tmpfs  495M     0  495M   0% /proc/acpi
    tmpfs                  tmpfs  495M     0  495M   0% /proc/scsi
    tmpfs                  tmpfs  495M     0  495M   0% /sys/firmware
    [Fri Jan 19 14:34:06 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:08 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:08 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:13 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Jan 19 14:34:14 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Fri Jan 19 14:34:34 2024] EXT4-fs (dm-0): barriers disabled
    [Fri Jan 19 14:34:35 2024] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,oldalloc
    [Fri Jan 19 14:34:49 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  none        aufs   rw,relatime,si=e20874a68cf9f35,dio,dirperm1
    |-/opt/iobroker    /dev/mapper/cachedev_0[/docker/iobroker_data]        ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@docker/containers/b7b29cf44ccd7e3917f6654705dce653b19400dcfc8a57fc13178d0aa6077bba/resolv.conf] ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/hostname    /dev/mapper/cachedev_0[/@docker/containers/b7b29cf44ccd7e3917f6654705dce653b19400dcfc8a57fc13178d0aa6077bba/hostname]    ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    `-/etc/hosts       /dev/mapper/cachedev_0[/@docker/containers/b7b29cf44ccd7e3917f6654705dce653b19400dcfc8a57fc13178d0aa6077bba/hosts]       ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    /var:
    38M     /var/
    35M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    17M     /var/lib/dpkg
    /opt/iobroker/backups:
    54M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    114M    /opt/iobroker/iobroker-data/
    62M     /opt/iobroker/iobroker-data/files
    34M     /opt/iobroker/iobroker-data/backup-objects
    30M     /opt/iobroker/iobroker-data/files/web.admin/static
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    6.7M    /opt/iobroker/iobroker-data/states.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        299
    States:         271
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17400825   -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       17407578   -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       19043686   -
    udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          17394061   -
    2024-01-23 21:22:27.635  - info: admin.1 (227) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-23 21:22:27.532  - info: host.iobroker stopInstance system.adapter.admin.1 (force=false, process=true)
    2024-01-23 21:22:27.666  - info: host.iobroker stopInstance system.adapter.admin.1 send kill signal
    2024-01-23 21:22:28.138  - info: admin.1 (227) terminating
    2024-01-23 21:22:28.201  - error: admin.1 (227) Cannot find view "system" for search "instance" : Connection is closed.
    2024-01-23 21:22:28.692  - info: host.iobroker stopInstance system.adapter.admin.1 killing pid 227
    2024-01-23 21:22:29.192  - info: host.iobroker instance system.adapter.admin.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-23 21:24:09.233  - info: host.iobroker "system.adapter.admin.0" enabled
    2024-01-23 21:24:09.473  - info: host.iobroker instance system.adapter.admin.0 started with pid 24575
    2024-01-23 21:24:16.245  - info: admin.0 (24575) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
    2024-01-23 21:24:16.315  - info: admin.0 (24575) requesting all objects
    2024-01-23 21:24:18.107  - info: admin.0 (24575) received all objects
    2024-01-23 21:24:19.773  - info: admin.0 (24575) Request actual repository...
    2024-01-23 21:24:19.983  - error: host.iobroker cannot call visUtils: Not exists
    2024-01-23 21:24:20.046  - info: admin.0 (24575) socket.io server listening on port 8081
    2024-01-23 21:24:20.151  - info: admin.0 (24575) http server listening on port 8081
    2024-01-23 21:24:20.152  - info: admin.0 (24575) Use link "http://127.0.0.1:8081" to configure.
    2024-01-23 21:24:21.041  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-01-23 21:24:29.941  - info: admin.0 (24575) Repository received successfully.
    2024-01-23 21:24:31.334  - info: admin.0 (24575) failed connection to socket.io from ::ffff:172.17.0.1: Passport was not initialized
    2024-01-23 21:24:42.251  - info: admin.0 (24575) ==> Connected system.user.admin from ::ffff:172.17.0.1
    2024-01-23 21:24:51.278  - error: host.iobroker cannot call visUtils: Not exists
    2024-01-23 21:25:27.271  - error: host.iobroker cannot call visUtils: Not exists
    2024-01-23 21:33:39.133  - info: admin.0 (24575) <== Disconnect system.user.admin from ::ffff:172.17.0.1 admin
    2024-01-23 21:35:17.076  - info: admin.0 (24575) failed connection to socket.io from ::ffff:172.17.0.1: Passport was not initialized
    Synology 713+
    IOBroker im Dockerumfeld auf Synology
    Raspimatic
      iob diag
      davon mal zeigen !
      HMuser
      @glasfaser
      Jetzt läuft soweit alles - das einzige was mir noch unklar ist: Im docker ist nur der portainer als Container sichtbar, iobroker nicht: das kenne ich von einer anderen Installation nicht so.
      Synology 713+
      Raspimatic
      • H HMuser
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @hmuser
        Hattest du nicht schonmal diese Problem !?
        Würde mal Portainer als app deinstallieren , neustes Image laden und dann neu installieren
        H 1 Antwort Letzte Antwort
          @hmuser
          HMuser
          @glasfaser
          Nein, das hatte ich noch nicht.
          Portainer habe ich über die Konsole installiert, ist das auch eine app auf der Synology?
          Synology 713+
          Raspimatic
          • H HMuser
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @hmuser
            Einfach den Container löschen ... über die Syn Docker Konsole
            • H HMuser
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              Das war doch hier
              https://forum.iobroker.net/topic/45625/gelöst-iobroker-container-in-portainer-verschwunden
              Zitat :
              Von einem Tag auf den anderen "fehlt" der Container ioBroker im Portainer.
                @hmuser
                HMuser
                @glasfaser
                Also nicht Container in der Docker app löschen sondern über die Konsole der Syno ?
                Synology 713+
                Raspimatic
                  Das war doch hier
                  HMuser
                  @glasfaser
                  Nein, jetzt ist es ja anders herum: Im Portier da (und läuft!) aber nicht sichtbar unter docker...
                  Synology 713+
                  Raspimatic
                  • H HMuser
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Achso !?
                    Also im Syn Container Manager . nicht sichtbar / aufgeführt.
                    H 2 Antworten Letzte Antwort
                      Achso !?
                      HMuser
                      @glasfaser
                      Ist bei mir noch docker. Weiss nicht warum DSM das nicht Updated. Bei einer anderen Syno hat das Funktioniert. Auf dieser ist DSM 7.1.1 installiert, etwas neueres bietet er mir nicht an.
                      Synology 713+
                      Raspimatic
                        Achso !?
                        HMuser
                        @glasfaser
                        Genau: nicht sichtbar
                        Synology 713+
                        Raspimatic
                        • H HMuser
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Ich kenne dein Syn nicht , laut Signatur die DS713+ aber die meinst du ja nicht .
                          Schau mal hier nach ..
                          https://www.synology.com/de-de/support/download/DS713+?version=7.1#system
                          sollte es aber als download geben
                            HMuser
                            @glasfaser
                            exakt: 713+
                            Schaue mir das mal an, danke
                            Synology 713+
                            Raspimatic
                              HMuser
                              @glasfaser
                              Wennn ich das richtig verstehe habe ich die neueste installiert: 7.1.1-42962 Update 6
                              Synology 713+
                              Raspimatic
                              • H HMuser
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @hmuser
                                Jipp , sehe es auch gerade , eine andere gibt es nicht .
                                  @hmuser
                                  HMuser
                                  @glasfaser
                                  Die andere Syno ist eine 720+, wahrscheinlich deshalb.
                                  Setzt das aktuelle buanet image 7.2x voraus?
                                  Synology 713+
                                  Raspimatic
                                  • H HMuser
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    NEIN , es gibt keine Abhängigkeit !
                                    Der Fehler liegt an etwas anderes Portainer / Syn Docker und nicht am Image !
                                      HMuser
                                      @glasfaser
                                      Okay, alles klar. Docker App und Portainer sind gerade frisch aufgesetzt. Wenn ich portainer lösche und neu installiere muss ich iobroker auch wieder neu installieren- glaube das tue ich mir jetzt nicht an. Trotzdem Danke!
                                      Synology 713+
                                      Raspimatic
                                      • H HMuser
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Portainer ist nur eine Weboberfläche / Hilfe mehr nicht , sowie auch der Syn Container Manager .
                                          HMuser
                                          @glasfaser
                                          Das bedeutet dass ich Portainer und Docker löschen und neu installieren kann ohne die ioBroker Installation/ Container zu beeinflussen?
                                          Wenn das so ist: mit welchen Befehlen würde ich auf der Syno Konsole das Löschen/ die Neuinstallation durchführen?
                                          Synology 713+
                                          Raspimatic
