  4. Net-Tools update auf 1.0.1 Fehler
22 Beiträge 5 Kommentatoren 3.3k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @teletapi
    Editiere bitte dein Log mit den Privaten Daten von ical :
    z.B
    2024-01-20 19:30:03.805 - info: ical.0 (81588) processing URL: Wichtige Termine .....ics
    usw ...
    @glasfaser sagte in Net-Tools update auf 1.0.1 Fehler:
    @teletapi
    z.B
    usw ...
    ich hoffe ich hab alles
    am Handy eine Qual so lange logs zu editieren
    • teletapiT teletapi
      @jey-cee Ich habe jetzt gerade mal die 1.0.2 installiert, der Fehlker bleibt aber der gleiche Instanz startet garnicht erst und die gleichen fehler wie oben mit der 1.0.1
      2024-01-20 18:30:00.154 - info: host.iobroker instance system.adapter.ical.0 started with pid 74065
      2024-01-20 18:30:03.414 - info: ical.0 (74065) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 18:30:09.679 - info: ical.0 (74065) Terminated (NO_ERROR): Without reason
      2024-01-20 18:30:10.238 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-20 19:00:00.201 - info: host.iobroker instance system.adapter.ical.0 started with pid 77844
      2024-01-20 19:00:03.294 - info: ical.0 (77844) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 19:00:09.573 - info: ical.0 (77844) Terminated (NO_ERROR): Without reason
      2024-01-20 19:00:10.138 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-20 19:08:51.757 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
      2024-01-20 19:08:51.758 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:09:12.010 - info: nuki.0 (1936) status change received for NukiID 790083444: locking
      2024-01-20 19:09:12.011 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:09:31.958 - info: nuki.0 (1936) status change received for NukiID 790083444: locked
      2024-01-20 19:09:31.959 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:19:47.675 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
      2024-01-20 19:19:47.675 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:20:07.687 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
      2024-01-20 19:20:07.688 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:20:33.458 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
      2024-01-20 19:20:35.821 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2024-01-20 19:20:50.379 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
      2024-01-20 19:28:26.897 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
      2024-01-20 19:30:00.146 - info: host.iobroker instance system.adapter.ical.0 started with pid 81588
      2024-01-20 19:30:03.101 - info: ical.0 (81588) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 19:30:09.531 - info: ical.0 (81588) Terminated (NO_ERROR): Without reason
      2024-01-20 19:30:10.107 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-20 19:36:49.011 - info: nuki.0 (1936) status change received for NukiID 790083444: unlatched
      2024-01-20 19:36:49.012 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:37:09.663 - info: nuki.0 (1936) status change received for NukiID 790083444: locking
      2024-01-20 19:37:09.664 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 19:37:29.600 - info: nuki.0 (1936) status change received for NukiID 790083444: locked
      2024-01-20 19:37:29.601 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
      2024-01-20 20:00:00.159 - info: host.iobroker instance system.adapter.ical.0 started with pid 85926
      2024-01-20 20:00:03.259 - info: ical.0 (85926) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 20:00:09.627 - info: ical.0 (85926) Terminated (NO_ERROR): Without reason
      2024-01-20 20:00:10.146 - warn: ical.0 (85926) get state error: Connection is closed.
      2024-01-20 20:00:10.233 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-20 20:30:00.157 - info: host.iobroker instance system.adapter.ical.0 started with pid 89711
      2024-01-20 20:30:03.126 - info: ical.0 (89711) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 20:30:09.477 - info: ical.0 (89711) Terminated (NO_ERROR): Without reason
      2024-01-20 20:30:10.029 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-20 20:34:57.068 - info: hm-rpc.1 (10645) Firmware update status of 3014F711A000021D89A1B02B changed to 1
      2024-01-20 21:00:00.159 - info: host.iobroker instance system.adapter.ical.0 started with pid 93560
      2024-01-20 21:00:03.182 - info: ical.0 (93560) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 21:00:09.549 - info: ical.0 (93560) Terminated (NO_ERROR): Without reason
      2024-01-20 21:00:10.098 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-20 21:03:48.746 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
      2024-01-20 21:04:00.066 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
      2024-01-20 21:04:02.059 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2024-01-20 21:04:14.219 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
      2024-01-20 21:04:36.158 - info: host.iobroker iobroker add net-tools auto --host iobroker --debug
      2024-01-20 21:04:40.566 - info: host.iobroker iobroker NPM version: 10.2.3
      2024-01-20 21:04:40.570 - info: host.iobroker iobroker Installing iobroker.net-tools@1.0.2... (System call)
      2024-01-20 21:04:57.827 - info: host.iobroker iobroker
      2024-01-20 21:04:57.828 - info: host.iobroker iobroker added 27 packages, and changed 1 package in 16s141 packages are looking for funding run `npm fund` for details
      2024-01-20 21:04:57.877 - info: host.iobroker iobroker host.iobroker install adapter net-tools
      2024-01-20 21:04:57.980 - info: host.iobroker iobroker upload [12] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/de/translations.json i18n/de/translations.json application/json
      2024-01-20 21:04:58.036 - info: host.iobroker iobroker upload [11] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/en/translations.json i18n/en/translations.json application/json
      2024-01-20 21:04:58.091 - info: host.iobroker iobroker upload [10] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/es/translations.json i18n/es/translations.json application/json
      2024-01-20 21:04:58.106 - info: host.iobroker iobroker upload [9] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      2024-01-20 21:04:58.125 - info: host.iobroker iobroker upload [8] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/it/translations.json i18n/it/translations.json application/json
      2024-01-20 21:04:58.149 - info: host.iobroker iobroker upload [7] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2024-01-20 21:04:58.161 - info: host.iobroker iobroker upload [6] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2024-01-20 21:04:58.171 - info: host.iobroker iobroker upload [5] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2024-01-20 21:04:58.189 - info: host.iobroker iobroker upload [4] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2024-01-20 21:04:58.212 - info: host.iobroker iobroker upload [3] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      2024-01-20 21:04:58.228 - info: host.iobroker iobroker upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2024-01-20 21:04:58.244 - info: host.iobroker iobroker upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/jsonConfig.json jsonConfig.json application/json
      2024-01-20 21:04:58.259 - info: host.iobroker iobroker upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png image/png
      2024-01-20 21:04:58.415 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools created/updated
      2024-01-20 21:04:58.596 - info: host.iobroker iobroker host.iobroker create instance net-tools
      2024-01-20 21:04:58.616 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.alive created
      2024-01-20 21:04:58.630 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.connected created
      2024-01-20 21:04:58.646 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.compactMode created
      2024-01-20 21:04:58.670 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cpu created
      2024-01-20 21:04:58.689 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cputime created
      2024-01-20 21:04:58.720 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapUsed created
      2024-01-20 21:04:58.735 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapTotal created
      2024-01-20 21:04:58.748 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memRss created
      2024-01-20 21:04:58.763 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.uptime created
      2024-01-20 21:04:58.777 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.inputCount created
      2024-01-20 21:04:58.792 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.outputCount created
      2024-01-20 21:04:58.805 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.eventLoopLag created
      2024-01-20 21:04:58.824 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.sigKill created
      2024-01-20 21:04:58.838 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.logLevel created
      2024-01-20 21:04:58.851 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost created
      2024-01-20 21:04:58.865 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost.ports created
      2024-01-20 21:04:58.878 - info: host.iobroker iobroker host.iobroker object net-tools.0.discover created
      2024-01-20 21:04:58.897 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0 created
      2024-01-20 21:04:59.985 - info: host.iobroker iobroker exit 0
      2024-01-20 21:05:02.023 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 94264
      2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
      2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: throw err;
      2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: ^
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: Require stack:
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: requireStack: [
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: ]
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: }
      2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
      2024-01-20 21:05:03.825 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-20 21:05:03.825 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
      2024-01-20 21:05:03.825 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
      2024-01-20 21:05:03.827 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      2024-01-20 21:05:03.827 - info: host.iobroker iobroker rebuild
      2024-01-20 21:05:04.593 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
      2024-01-20 21:05:05.684 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
      2024-01-20 21:05:43.058 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
      2024-01-20 21:05:43.095 - info: host.iobroker iobroker npm-rebuild:
      2024-01-20 21:05:43.097 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
      2024-01-20 21:05:44.111 - info: host.iobroker iobroker npm-rebuild: exit 0
      2024-01-20 21:05:44.279 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 94760
      2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
      2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: throw err;
      2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: ^
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: Require stack:
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: requireStack: [
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: ]
      2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: }
      2024-01-20 21:05:45.551 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
      2024-01-20 21:05:45.551 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-20 21:05:45.551 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
      2024-01-20 21:05:45.551 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
      2024-01-20 21:05:45.551 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
      2024-01-20 21:05:45.551 - info: host.iobroker iobroker rebuild
      2024-01-20 21:05:46.971 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
      2024-01-20 21:06:40.883 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
      2024-01-20 21:06:41.001 - info: host.iobroker iobroker npm-rebuild:
      2024-01-20 21:06:41.002 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
      2024-01-20 21:06:42.023 - info: host.iobroker iobroker npm-rebuild: exit 0
      2024-01-20 21:06:42.253 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 95354
      2024-01-20 21:06:44.790 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
      2024-01-20 21:06:44.791 - error: host.iobroker Caught by controller[0]: throw err;
      2024-01-20 21:06:44.791 - error: host.iobroker Caught by controller[0]: ^
      2024-01-20 21:06:44.792 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
      2024-01-20 21:06:44.792 - error: host.iobroker Caught by controller[0]: Require stack:
      2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
      2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
      2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      2024-01-20 21:06:44.794 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      2024-01-20 21:06:44.795 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-20 21:06:44.795 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      2024-01-20 21:06:44.796 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
      2024-01-20 21:06:44.796 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-20 21:06:44.797 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-20 21:06:44.797 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-20 21:06:44.798 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-20 21:06:44.799 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
      2024-01-20 21:06:44.799 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2024-01-20 21:06:44.800 - error: host.iobroker Caught by controller[0]: requireStack: [
      2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
      2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
      2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: ]
      2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: }
      2024-01-20 21:06:44.810 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
      2024-01-20 21:06:44.810 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-20 21:06:44.810 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
      2024-01-20 21:06:44.810 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
      2024-01-20 21:06:44.811 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
      2024-01-20 21:06:44.811 - info: host.iobroker iobroker rebuild
      2024-01-20 21:06:47.105 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
      2024-01-20 21:07:43.520 - info: host.iobroker stopInstance system.adapter.simple-api.0 (force=false, process=true)
      2024-01-20 21:07:43.669 - info: simple-api.0 (19001) Got terminate signal TERMINATE_YOURSELF
      2024-01-20 21:07:43.683 - info: simple-api.0 (19001) terminating http server on port 8087
      2024-01-20 21:07:43.685 - info: simple-api.0 (19001) terminating
      2024-01-20 21:07:43.688 - info: simple-api.0 (19001) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-20 21:07:43.704 - info: host.iobroker stopInstance system.adapter.simple-api.0 send kill signal
      2024-01-20 21:07:44.190 - info: simple-api.0 (19001) terminating
      2024-01-20 21:07:44.241 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
      2024-01-20 21:07:44.252 - info: host.iobroker "system.adapter.web.0" disabled
      2024-01-20 21:07:44.252 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
      2024-01-20 21:07:44.244 - info: cloud.0 (1676) Reconnect because web instance stopped
      2024-01-20 21:07:44.383 - info: web.0 (19065) Got terminate signal TERMINATE_YOURSELF
      2024-01-20 21:07:44.384 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
      2024-01-20 21:07:44.387 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
      2024-01-20 21:07:44.406 - info: cloud.0 (1676) Reconnect because web instance started
      2024-01-20 21:07:44.429 - info: host.iobroker "system.adapter.web.0" enabled
      2024-01-20 21:07:44.430 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
      2024-01-20 21:07:44.437 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
      2024-01-20 21:07:44.493 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
      2024-01-20 21:07:44.497 - info: web.0 (19065) Got terminate signal TERMINATE_YOURSELF
      2024-01-20 21:07:44.587 - info: host.iobroker instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-20 21:07:44.594 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
      2024-01-20 21:07:44.639 - info: web.0 (19065) terminated http server on port 8082
      2024-01-20 21:07:44.640 - info: web.0 (19065) terminating
      2024-01-20 21:07:44.642 - info: web.0 (19065) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-20 21:07:44.887 - info: web.0 (19065) terminating
      2024-01-20 21:07:45.378 - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-20 21:07:46.832 - info: host.iobroker instance system.adapter.simple-api.0 started with pid 95868
      2024-01-20 21:07:47.740 - info: host.iobroker instance system.adapter.web.0 started with pid 95876
      2024-01-20 21:07:51.969 - info: simple-api.0 (95868) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 21:07:52.049 - warn: simple-api.0 (95868) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
      2024-01-20 21:07:52.064 - info: simple-api.0 (95868) simpleAPI server listening on port 8087
      2024-01-20 21:07:52.067 - info: simple-api.0 (95868) Allow states only when user is owner: false
      2024-01-20 21:07:52.114 - info: simple-api.0 (95868) http server listening on port 8087
      2024-01-20 21:07:53.479 - info: web.0 (95876) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 21:07:54.626 - info: web.0 (95876) socket.io server listening on port 8082
      2024-01-20 21:07:54.653 - info: web.0 (95876) http server listening on port 8082
      2024-01-20 21:07:57.522 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
      2024-01-20 21:07:57.659 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
      2024-01-20 21:07:58.668 - info: host.iobroker iobroker npm-rebuild: exit 0
      2024-01-20 21:07:58.919 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 95960
      2024-01-20 21:08:03.601 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
      2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: throw err;
      2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: ^
      2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
      2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: Require stack:
      2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: requireStack: [
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: ]
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: }
      2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
      2024-01-20 21:08:03.605 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-20 21:08:03.605 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2024-01-20 21:08:15.117 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
      2024-01-20 21:08:15.126 - info: host.iobroker "system.adapter.web.0" disabled
      2024-01-20 21:08:15.127 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
      2024-01-20 21:08:15.121 - info: cloud.0 (1676) Reconnect because web instance stopped
      2024-01-20 21:08:15.249 - info: web.0 (95876) Got terminate signal TERMINATE_YOURSELF
      2024-01-20 21:08:15.263 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
      2024-01-20 21:08:15.275 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
      2024-01-20 21:08:15.281 - info: host.iobroker "system.adapter.web.0" enabled
      2024-01-20 21:08:15.282 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
      2024-01-20 21:08:15.286 - info: cloud.0 (1676) Reconnect because web instance started
      2024-01-20 21:08:15.290 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
      2024-01-20 21:08:15.316 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
      2024-01-20 21:08:15.317 - info: web.0 (95876) Got terminate signal TERMINATE_YOURSELF
      2024-01-20 21:08:15.341 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
      2024-01-20 21:08:15.411 - info: web.0 (95876) terminated http server on port 8082
      2024-01-20 21:08:15.413 - info: web.0 (95876) terminating
      2024-01-20 21:08:15.415 - info: web.0 (95876) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-20 21:08:15.752 - info: web.0 (95876) terminating
      2024-01-20 21:08:16.045 - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-20 21:08:18.446 - info: host.iobroker instance system.adapter.web.0 started with pid 96037
      2024-01-20 21:08:22.117 - info: web.0 (96037) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
      2024-01-20 21:08:22.474 - info: web.0 (96037) socket.io server listening on port 8082
      2024-01-20 21:08:22.497 - info: web.0 (96037) http server listening on port 8082
      2024-01-20 21:09:31.972 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 96426
      2024-01-20 21:09:33.597 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
      2024-01-20 21:09:33.597 - error: host.iobroker Caught by controller[0]: throw err;
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: ^
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: Require stack:
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: requireStack: [
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: ]
      2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: }
      2024-01-20 21:09:33.600 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
      2024-01-20 21:09:33.600 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-20 21:09:33.600 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2024-01-20 21:10:01.096 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
      Wenn ich den Adapter neu starten will, kommen folgende Fehler
      host.iobroker
      	2024-01-20 21:15:16.359	info	Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.iobroker
      	2024-01-20 21:15:16.359	error	instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2024-01-20 21:15:16.359	error	Caught by controller[0]: Node.js v18.19.0
      host.iobroker
      	2024-01-20 21:15:16.359	error	Caught by controller[0]: }
      host.iobroker
      	2024-01-20 21:15:16.359	error	Caught by controller[0]: ]
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: requireStack: [
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.iobroker
      	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: Require stack:
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
      host.iobroker
      	2024-01-20 21:15:16.357	error	Caught by controller[0]: ^
      host.iobroker
      	2024-01-20 21:15:16.356	error	Caught by controller[0]: throw err;
      host.iobroker
      	2024-01-20 21:15:16.355	error	Caught by controller[0]: node:internal/modules/cjs/loader:1137
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      	2024-01-20 21:15:15.011	info	instance system.adapter.net-tools.0 started with pid 97263
      admin.0
      	2024-01-20 21:10:01.096	warn	net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @teletapi das kommt davon wenn man das mal schnell macht wenn man im Stress ist.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
        @teletapi
        z.B
        usw ...
        GlasfaserG Offline
        GlasfaserG Offline
        @homoran sagte in Net-Tools update auf 1.0.1 Fehler:
        teletapiT 1 Antwort Letzte Antwort
          teletapiT Online
          teletapiT Online
          teletapi
          schrieb am zuletzt editiert von teletapi
          Ich hab die 1.0.3 jetzt installiert und der Adapter startet auch wird auch grün und findet die Geräte, als Warnung habe ich im Protocol aber noch folgendes stehn
          net-tools.0 2024-01-20 23:49:34.177 warn License Key is invalid
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           23:57:58 up 13:48,  1 user,  load average: 0.93, 0.87, 0.94
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2024-01-20 23:57:58 CET
                     Universal time: Sat 2024-01-20 22:57:58 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            7.8G        3.1G        2.2G        1.0M        2.5G        4.5G
          Swap:            99M          0B         99M
          Total:          7.9G        3.1G        2.3G
                   7811 M total memory
                   3149 M used memory
                   4172 M active memory
                   1245 M inactive memory
                   2157 M free memory
                    170 M buffer memory
                   2333 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       59G  9.1G   47G  17% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
          /dev/sda1      vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
          [Sat Jan 20 10:09:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.ma                                     caddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sat Jan 20 10:09:42 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Jan 20 10:09:42 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sat Jan 20 10:09:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          2.0G    /var/
          1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
          1.1G    /var/log
          637M    /var/lib
          Archived and active journals take up 1.0G in the file system.
          /opt/iobroker/backups:
          1.6G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          382M    /opt/iobroker/iobroker-data/
          185M    /opt/iobroker/iobroker-data/files
          77M     /opt/iobroker/iobroker-data/backup-objects
          72M     /opt/iobroker/iobroker-data/node-red
          71M     /opt/iobroker/iobroker-data/node-red/node_modules
          37M     /opt/iobroker/iobroker-data/objects.jsonl
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          8.5M    /opt/iobroker/iobroker-data/states.jsonl
          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
          USB-Devices by-id:
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          admin:          6.13.15
          javascript:     7.7.0
          Adapters from github:   2
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
          + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
          + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
          + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.13.15  , installed 6.13.15
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
          Adapter    "backitup"     : 2.10.3   , installed 2.10.3
          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "hue"          : 3.10.2   , installed 3.10.2
          Adapter    "ical"         : 1.14.0   , installed 1.14.0
          Adapter    "info"         : 2.0.0    , installed 2.0.0
          Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
          Adapter    "javascript"   : 7.7.0    , installed 7.7.0
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "net-tools"    : 1.0.2    , installed 1.0.3
          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Adapter    "shelly"       : 6.7.0    , installed 6.7.0
          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Objects and States
          Objects:        10002
          States:         10092
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13624      566/sshd: /usr/sbin
          tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       179028     10408/io.hm-rpc.0
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20230      1784/io.jarvis.0
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       16371      1498/io.sonoff.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15086      560/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19210      1552/io.shelly.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18493      1235/node-red
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13639      542/cupsd
          tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       183523     10645/io.hm-rpc.1
          tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       182669     10580/io.hm-rpc.2
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16481      658/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16488      658/iobroker.js-con
          tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       1855617    95868/io.simple-api
          tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24665      1936/io.nuki.0
          tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       180930     10538/io.hm-rpc.3
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13626      566/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13638      542/cupsd
          tcp6       0      0 :::1883                 :::*                    LISTEN      116        15087      560/mosquitto
          tcp6       0      0 :::3000                 :::*                    LISTEN      117        16385      657/grafana
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15160      547/influxd
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24273      2330/io.socketio.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1857814    96037/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13958      982/io.admin.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13654      617/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14903      403/avahi-daemon: r
          udp        0      0 0.0.0.0:56063           0.0.0.0:*                           108        14905      403/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15209      480/dhcpcd
          udp6       0      0 :::546                  :::*                                0          15226      480/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14904      403/avahi-daemon: r
          udp6       0      0 :::46450                :::*                                108        14906      403/avahi-daemon: r
          2024-01-20 23:56:54.582  - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=true)
          2024-01-20 23:56:54.701  - info: net-tools.0 (121771) Got terminate signal TERMINATE_YOURSELF
          2024-01-20 23:56:54.707  - info: host.iobroker stopInstance system.adapter.net-tools.0 send kill signal
          2024-01-20 23:56:54.703  - info: net-tools.0 (121771) terminating
          2024-01-20 23:56:54.705  - info: net-tools.0 (121771) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-20 23:56:55.207  - info: net-tools.0 (121771) terminating
          2024-01-20 23:56:55.308  - info: host.iobroker instance system.adapter.net-tools.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-20 23:56:57.818  - info: host.iobroker instance system.adapter.net-tools.0 started with pid 122180
          2024-01-20 23:57:00.543  - info: net-tools.0 (122180) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 23:57:00.788  - info: net-tools.0 (122180) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
          2024-01-20 23:57:02.060  - warn: net-tools.0 (122180) License Key is invalid
          2024-01-20 23:57:02.895  - info: net-tools.0 (122180) Port scan finished
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                     3149 M used memory
                     2157 M free memory
                      170 M buffer memory
                     2333 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            2.0G    /var/
            1.1G    /var/log
            637M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.13.15
            javascript:     7.7.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        10002
            States:         10092
            Pending Updates: 0
            Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            @teletapi schick mir doch bitte eine mail an iobroker@all-smart.net, am besten von der email aus mit der du dich im shop registriert hast.
            Dann schau ich obs am Lizenz server liegt.
            • Jey CeeJ Jey Cee
              teletapiT Online
              teletapiT Online
              teletapi
              @jey-cee said in Net-Tools update auf 1.0.1 Fehler:
              Hab ich gerade gemacht
                teletapiT Online
                teletapiT Online
                teletapi
                Ich hab heute morgen mal den Adapter neu suchen lassen und dabei stürzte der Adapter dann auch mal kurzfristig ab und es gab einige fehler und warnungen. Das gleiche wiederholt sich auch bei weiteren versuchen.
                Es fehlen geräte und gelöschte bzw Geräte die ich in der Fritzbox umbenannt habe werden nicht (zumindest) automatisch gefunden
                853
                Log-Größe: 203.5 KB
                Zeit
                Nachricht
                net-tools.0
                	2024-01-21 12:09:12.893	info	Port scan finished
                net-tools.0
                	2024-01-21 12:09:11.856	warn	License Key is invalid
                net-tools.0
                	2024-01-21 12:09:10.728	info	Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                net-tools.0
                	2024-01-21 12:09:10.462	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                host.iobroker
                	2024-01-21 12:09:08.144	info	instance system.adapter.net-tools.0 started with pid 24532
                host.iobroker
                	2024-01-21 12:08:38.035	info	Restart adapter system.adapter.net-tools.0 because enabled
                host.iobroker
                	2024-01-21 12:08:38.034	error	instance system.adapter.net-tools.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                net-tools.0
                	2024-01-21 12:08:37.922	info	Default value for state "net-tools.0.2462ab541893.time" could not be set: DB closed
                net-tools.0
                	2024-01-21 12:08:37.920	warn	get state error: Connection is closed.
                net-tools.0
                	2024-01-21 12:08:37.919	warn	Could not perform strict object check of state net-tools.0.2462ab541893.time: DB closed
                net-tools.0
                	2024-01-21 12:08:37.911	warn	redis get net-tools.0.2462ab541893.time, error - Connection is closed.
                net-tools.0
                	2024-01-21 12:08:37.898	info	terminating
                net-tools.0
                	2024-01-21 12:08:37.802	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.801	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.651	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.506	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.461	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.460	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.459	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.458	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.457	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                net-tools.0
                	2024-01-21 12:08:37.456	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.455	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.453	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.452	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.451	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.450	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.448	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.447	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.445	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.444	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.442	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.441	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.438	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.436	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.435	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                net-tools.0
                	2024-01-21 12:08:37.433	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.432	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                net-tools.0
                	2024-01-21 12:08:37.431	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.430	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.429	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.428	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.427	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.426	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.425	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                net-tools.0
                	2024-01-21 12:08:37.424	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.423	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.421	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.420	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.419	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.418	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                net-tools.0
                	2024-01-21 12:08:37.417	warn	setTimeout called, but adapter is shutting down
                net-tools.0
                	2024-01-21 12:08:37.396	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                net-tools.0
                	2024-01-21 12:08:37.394	info	terminating
                net-tools.0
                	2024-01-21 12:08:37.050	error	Cannot read properties of undefined (reading 'stateAlive')
                net-tools.0
                	2024-01-21 12:08:37.048	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                net-tools.0
                	2024-01-21 12:08:37.047	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                net-tools.0
                	2024-01-21 12:08:37.044	error	Cannot read properties of undefined (reading 'stateAlive')
                net-tools.0
                	2024-01-21 12:08:37.043	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                net-tools.0
                	2024-01-21 12:08:37.041	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                discovery.0
                	2024-01-21 12:08:12.374	info	Discovery finished
                discovery.0
                	2024-01-21 12:08:12.179	info	Discovery finished. Found new or modified 13 instances
                net-tools.0
                	2024-01-21 12:07:01.161	warn	Unknown message origin: 1777722
                discovery.0
                	2024-01-21 12:04:35.882	info	Found 43 addresses
                discovery.0
                	2024-01-21 12:04:35.720	info	Done discovering ping devices. 42 packages received
                discovery.0
                	2024-01-21 12:04:09.872	info	Discovering ping devices...
                net-tools.0
                	2024-01-21 12:04:08.806	error	Error: No outstanding message, can't send a new one
                admin.0
                	2024-01-21 12:03:54.291	warn	net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
                host.iobroker
                	2024-01-21 12:00:10.219	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                ical.0
                	2024-01-21 12:00:10.057	warn	get state error: Connection is closed.
                • teletapiT teletapi
                  853
                  Log-Größe: 203.5 KB
                  Zeit
                  Nachricht
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  host.iobroker
                  host.iobroker
                  host.iobroker
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  net-tools.0
                  discovery.0
                  discovery.0
                  net-tools.0
                  discovery.0
                  discovery.0
                  discovery.0
                  net-tools.0
                  admin.0
                  host.iobroker
                  ical.0
                  Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  @teletapi sagte in Net-Tools update auf 1.0.1 Fehler:
                  Das Geräte Fehlen kann daran liegen das sie nicht auf den Ping reagieren. Es gab auch früher Meldungen das Geräte nicht gefunden wurden obwohl sie per Ping erreichbar sind. Dieses Problem betrifft auch drn Ping Adapter und die Ursache hab ich bisher nicht finden können.
                  Hier hilft es nur die Geräte von Hand an zu legen.
                  Warum gelöschte Geräte nicht gefunden werden können ergibt für mich erst mal keinen Sinn. Das muss ich versuchen Nach zu stellen.
                  Da Geräte mit ihrer Mac im Adapter angelegt werden hat der Name keinen Einfluss. Es kann sein das der Name nicht in den Adapter übernommen wird, dennoch sollte es weiterhin im Adapter zu sehen sein, wenn es nicht gelöscht wurde.
                  Die Fehlermeldungen sehe ich mir an.
                  • Jey CeeJ Jey Cee
                    teletapiT Online
                    teletapiT Online
                    teletapi
                    @jey-cee
                    Ja ich lösch den Adapter jetzt, das hier macht irgendwie so garkeinen Sinn
                    2999+
                    Log-Größe: 54.1 KB
                    Zeit
                    Nachricht
                    admin.0
                    	2024-01-21 15:03:27.368	info	<== Disconnect system.user.admin from ::ffff:192.168.178.63
                    admin.0
                    	2024-01-21 15:02:18.027	info	==> Connected system.user.admin from ::ffff:192.168.178.63
                    net-tools.0
                    	2024-01-21 15:01:32.871	info	Port scan finished
                    net-tools.0
                    	2024-01-21 15:01:31.880	warn	License Key is invalid
                    net-tools.0
                    	2024-01-21 15:01:30.741	info	Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                    net-tools.0
                    	2024-01-21 15:01:30.553	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                    host.iobroker
                    	2024-01-21 15:01:28.059	info	instance system.adapter.net-tools.0 started with pid 50632
                    host.iobroker
                    	2024-01-21 15:00:57.972	info	Restart adapter system.adapter.net-tools.0 because enabled
                    host.iobroker
                    	2024-01-21 15:00:57.971	error	instance system.adapter.net-tools.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    net-tools.0
                    	2024-01-21 15:00:57.824	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.822	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.821	warn	Could not perform strict object check of state net-tools.0.2462ab541893.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.821	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.820	warn	Could not perform strict object check of state net-tools.0.2462ab541893.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.819	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.819	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.818	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.818	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.817	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.817	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.816	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.816	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.815	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.814	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.814	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.813	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.812	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.812	warn	Could not perform strict object check of state net-tools.0.308398a2f258.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.811	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.810	warn	Could not perform strict object check of state net-tools.0.308398a2f258.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.810	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.809	warn	Could not perform strict object check of state net-tools.0.308398a2f258.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.808	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.808	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.807	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.806	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.805	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.804	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.804	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.803	warn	Could not perform strict object check of state net-tools.0.70039f01361f.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.802	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.802	warn	Could not perform strict object check of state net-tools.0.70039f01361f.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.800	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.798	warn	Could not perform strict object check of state net-tools.0.70039f01361f.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.797	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.797	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.796	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.795	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.795	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.794	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.793	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.792	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.792	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.791	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.790	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.790	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.789	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.788	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.788	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.787	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.786	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.785	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.785	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.784	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.rps: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.783	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.783	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.time: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.782	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.781	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.alive: DB closed
                    net-tools.0
                    	2024-01-21 15:00:57.758	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.757	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.756	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.755	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.754	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.753	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.752	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.751	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.750	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.749	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.748	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.747	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.746	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.745	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.744	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.743	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.742	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.741	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.740	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.739	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.738	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.737	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.736	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.735	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.734	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.733	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.732	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.731	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.730	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.729	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.728	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.727	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.726	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.725	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.724	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.723	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.722	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.711	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.710	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.709	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.708	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.707	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.706	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.705	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.704	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.703	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.702	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.701	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.700	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.699	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.698	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.697	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.695	warn	get state error: Connection is closed.
                    net-tools.0
                    	2024-01-21 15:00:57.694	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.693	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.692	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.691	warn	get state error: Connection is closed.
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.645	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.644	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.643	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.642	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.641	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.640	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.639	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.638	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.637	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.636	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.635	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.634	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.633	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.632	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.631	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.629	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.628	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.627	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.626	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.625	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.624	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.623	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.622	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.621	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.620	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.619	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    net-tools.0
                    	2024-01-21 15:00:57.618	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.617	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.616	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.615	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.614	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.613	warn	setTimeout called, but adapter is shutting down
                    net-tools.0
                    	2024-01-21 15:00:57.593	info	terminating
                    net-tools.0
                    	2024-01-21 15:00:57.021	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    net-tools.0
                    	2024-01-21 15:00:57.019	info	terminating
                    net-tools.0
                    	2024-01-21 15:00:56.980	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.979	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.978	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.979	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.977	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.976	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.977	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.975	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.974	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.975	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.973	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.972	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.973	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.971	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.970	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.971	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.969	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.969	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.968	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.967	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.968	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.966	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.966	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.965	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.964	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                    net-tools.0
                    	2024-01-21 15:00:56.964	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.964	error	Cannot read properties of undefined (reading 'stateAlive')
                    net-tools.0
                    	2024-01-21 15:00:56.963	error	Cannot read properties of undefined (reading 'stateAlive')
                      @jey-cee
                      2999+
                      Log-Größe: 54.1 KB
                      Zeit
                      Nachricht
                      admin.0
                      admin.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      host.iobroker
                      host.iobroker
                      host.iobroker
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      net-tools.0
                      teletapiT Online
                      teletapiT Online
                      teletapi
                      Morjen, ich denke ich weiß jetzt woher die Fehler und warnungen kommen.
                      Ich hab heute morgen gesehen das der "Net-tools" Adapter in der version 1.03 vorhanden ist und hab den nochmal installiert, eigentlich wollte ich damit nur schauen ob ich vielleicht einen fehler bei der Installation über die Katze ein Fehler gemacht habe. Nach der Installation blieben die Fehler und Warnungen aber die gleichen.
                      Dabei hab ich im Protocol aber gesehen das der Discovery Adapter scheinbar immer mit reagiert wenn ich die Gerätesuche im Net-Tools adapter starte.
                      Dann hab ich nochmal bei den Instanzen geschaut und da fielen mir die beiden Adapter "Ping" und "Discovery" auf und habe diese einfach mal gestoppt und dann den Net-tools Adapter laufen lassen neu gestartet und die Geräte suche laufen lassen, dabei wurden alle Geräte gefunden. Seiddem hat der Adapter keinen fehler mehr gezeigt
                      Den Ping Adapter habe ich mittlerweile wieder aktiviert und beide Adapter mal unabhängig voneinander neu gestartet das scheint den Net-tools Adapter aber nicht zu stören. Dürfte dann also der "Discovery Adapter" sein der hier in Verbindung mit dem Net-tools Adapter Probleme macht.
                      Sobald ich dann die Gerätesuche im Net-tools Adapter starte startet auch der Discovery Adapter neu und die Fehler sind wieder da
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       10:46:21 up 34 min,  1 user,  load average: 1.39, 1.25, 1.20
                      CPU threads: 4
                      Current issues:
                                     Local time: Mon 2024-01-22 10:46:21 CET
                                 Universal time: Mon 2024-01-22 09:46:21 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            7.8G        2.3G        3.7G        1.0M        1.7G        5.3G
                      Swap:            99M          0B         99M
                      Total:          7.9G        2.3G        3.8G
                               7811 M total memory
                               2343 M used memory
                               3335 M active memory
                                583 M inactive memory
                               3727 M free memory
                                121 M buffer memory
                               1619 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G  9.2G   47G  17% /
                      [Mon Jan 22 10:12:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Mon Jan 22 10:12:19 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Mon Jan 22 10:12:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Mon Jan 22 10:12:20 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      /var:
                      1.9G    /var/
                      1.1G    /var/log
                      619M    /var/lib
                      1.8G    /opt/iobroker/backups/
                      352M    /opt/iobroker/iobroker-data/
                      181M    /opt/iobroker/iobroker-data/files
                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.15
                      javascript:     7.7.0
                      Adapter State
                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                      + instance is alive
                      Adapter    "backitup"     : 2.10.4   , installed 2.10.4
                      Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
                      Objects and States
                      Objects:        10033
                      States:         10104
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:5 https://apt.grafana.com stable InRelease
                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                      Pending Updates: 0
                      tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17711      1371/io.hm-rpc.2
                      tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16319      1349/io.hm-rpc.1
                      tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       19209      1936/io.simple-api.
                      tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       17018      1328/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16412      540/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11882      576/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14752      657/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12133      657/iobroker.js-con
                      tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17184      1425/io.hm-rpc.3
                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23289      1856/io.jarvis.0
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17603      1247/node-red
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18758      1561/io.shelly.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15492      558/mosquitto
                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18120      1498/io.sonoff.0
                      tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24733      1922/io.nuki.0
                      tcp6       0      0 :::3000                 :::*                    LISTEN      117        14648      656/grafana
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15817      1079/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21540      1656/io.web.0
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24693      2164/io.socketio.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        11946      549/influxd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16411      540/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          11884      576/sshd: /usr/sbin
                      tcp6       0      0 :::1883                 :::*                    LISTEN      116        15493      558/mosquitto
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11920      617/cups-browsed
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11257      401/avahi-daemon: r
                      udp        0      0 0.0.0.0:48832           0.0.0.0:*                           108        11259      401/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14641      461/dhcpcd
                      udp6       0      0 :::546                  :::*                                0          14661      461/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        11258      401/avahi-daemon: r
                      udp6       0      0 :::53051                :::*                                108        11260      401/avahi-daemon: r
                      2024-01-22 10:39:04.632  - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=true)
                      2024-01-22 10:39:04.766  - info: net-tools.0 (8472) Got terminate signal TERMINATE_YOURSELF
                      2024-01-22 10:39:04.771  - info: host.iobroker stopInstance system.adapter.net-tools.0 send kill signal
                      2024-01-22 10:39:04.772  - info: net-tools.0 (8472) terminating
                      2024-01-22 10:39:04.774  - info: net-tools.0 (8472) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-01-22 10:39:05.276  - info: net-tools.0 (8472) terminating
                      2024-01-22 10:39:05.434  - info: host.iobroker instance system.adapter.net-tools.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-01-22 10:39:07.862  - info: host.iobroker instance system.adapter.net-tools.0 started with pid 8574
                      2024-01-22 10:39:10.364  - info: net-tools.0 (8574) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                      2024-01-22 10:39:10.579  - info: net-tools.0 (8574) License Key is valid
                      2024-01-22 10:39:10.587  - info: net-tools.0 (8574) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                      2024-01-22 10:39:13.207  - info: net-tools.0 (8574) Port scan finished
                      Jey CeeJ mcm1957M 2 Antworten Letzte Antwort
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 7811 M total memory
                                 2343 M used memory
                                 3727 M free memory
                                  121 M buffer memory
                                 1619 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.9G    /var/
                        1.1G    /var/log
                        619M    /var/lib
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.15
                        javascript:     7.7.0
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        10033
                        States:         10104
                        Pending Updates: 0
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        @teletapi das ist gut zu wissen. Der discovery adapter ist als dependency eingetragen und sollte so bei bedarf mit installiert werden, falls er nich da ist. Gestartet wird er Automatisch wenn er nicht läuft.
                        Da muss ich also noch zusätzlich Warnmeldungen einbauen.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7811 M total memory
                                   2343 M used memory
                                   3727 M free memory
                                    121 M buffer memory
                                   1619 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.9G    /var/
                          1.1G    /var/log
                          619M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.15
                          javascript:     7.7.0
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        10033
                          States:         10104
                          Pending Updates: 0
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @teletapi said in Net-Tools update auf 1.0.1 Fehler:
                          Ping und net-tools sollten sich in keiner Weise gegenseitig beeinflussen.
                          Da meines Wissens nach net-tools die Funktion(en) des discovery Adapters zur Gerätesuche verwendet ist dieses Verhalten logisch erklärbar. Genau aus diesem Grunde setzt ja net-tools auch die INstallation von discovery voraus.
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          • mcm1957M mcm1957
                            teletapiT Online
                            teletapiT Online
                            teletapi
                            @mcm57 Das war mir natürlich so nicht ganz bewusst und hab ich erst im Nachgang einigermaßen verstanden. Die Fehler die dann dabei entstehen versteh ich halt nicht...... Wie ich sovieles noch immer nicht verstehe was alle Adapter,abhängigkeiten usw. angeht. Da bin ich ganz auf euer aller Hilfe angewiesen
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Ja passt schon.
                              Jey-Cee wird sich die Fehler garantiert zeitnahe ansehen.
                              • Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                @mcm57 danke das du es noch mal etwas klarer Formuliert hast.
                                Selbstverständlich schaue ich mir das an.
