  4. Net-Tools update auf 1.0.1 Fehler
22 Beiträge 5 Kommentatoren 3.3k Aufrufe 6 Beobachtet
    @teletapi hab das abgetrennt!
    bitte provisorischen Threadtitel ändern
    teletapiT Online
    teletapiT Online
    teletapi
    hier mal ein IOB Diag ohne den Net-Tools Adapter
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     12:19:28 up  2:09,  1 user,  load average: 1.08, 1.76, 1.75
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-01-20 12:19:29 CET
               Universal time: Sat 2024-01-20 11:19:29 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.7G        3.0G        1.0M        2.1G        5.0G
    Swap:            99M          0B         99M
    Total:          7.9G        2.7G        3.1G
             7811 M total memory
             2718 M used memory
             3790 M active memory
              799 M inactive memory
             3030 M free memory
              146 M buffer memory
             1915 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  9.0G   47G  16% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Sat Jan 20 10:09:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Jan 20 10:09:42 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jan 20 10:09:42 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Jan 20 10:09:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
    1.1G    /var/log
    620M    /var/lib
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    1.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    370M    /opt/iobroker/iobroker-data/
    185M    /opt/iobroker/iobroker-data/files
    77M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/node-red
    71M     /opt/iobroker/iobroker-data/node-red/node_modules
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    19M     /opt/iobroker/iobroker-data/states.jsonl
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.15
    javascript:     7.7.0
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.13.15  , installed 6.13.15
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.10.3   , installed 2.10.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "ical"         : 1.14.0   , installed 1.14.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
    Adapter    "javascript"   : 7.7.0    , installed 7.7.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        9642
    States:         9862
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13624      566/sshd: /usr/sbin
    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       179028     10408/io.hm-rpc.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20230      1784/io.jarvis.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       16371      1498/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15086      560/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19210      1552/io.shelly.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18493      1235/node-red
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13639      542/cupsd
    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       183523     10645/io.hm-rpc.1
    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       182669     10580/io.hm-rpc.2
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16481      658/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16488      658/iobroker.js-con
    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       332089     19001/io.simple-api
    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24665      1936/io.nuki.0
    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       180930     10538/io.hm-rpc.3
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13626      566/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13638      542/cupsd
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        15087      560/mosquitto
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        16385      657/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15160      547/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24273      2330/io.socketio.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       333363     19065/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13958      982/io.admin.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13654      617/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14903      403/avahi-daemon: r
    udp        0      0 0.0.0.0:56063           0.0.0.0:*                           108        14905      403/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15209      480/dhcpcd
    udp6       0      0 :::546                  :::*                                0          15226      480/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14904      403/avahi-daemon: r
    udp6       0      0 :::46450                :::*                                108        14906      403/avahi-daemon: r
    2024-01-20 12:15:28.359  - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
    2024-01-20 12:15:29.695  - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
    2024-01-20 12:15:57.531  - info: web.0 (19065) <== Disconnect system.user.admin from ::ffff:192.168.178.63
    2024-01-20 12:16:01.702  - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
    iob diag has finished.
    • teletapiT teletapi
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
               2718 M used memory
               3030 M free memory
                146 M buffer memory
               1915 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.9G    /var/
      1.1G    /var/log
      620M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.15
      javascript:     7.7.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9642
      States:         9862
      Pending Updates: 1
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @teletapi hi das ist unerfreulich ich hab geradr einen Notfall in der Familie. Sobald ich kann schau ich mir das an.
      3€ ist ein anderer Adapter.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
        Ich war jetzt gerade etwas überrascht als ich das Update für den Net-Tools Adapter gesehen habe, aber gut ich hab auch auch jedes Verständniss dafür das eure Arbeit auch was bringen muss und nicht nur Hobby sein kann. Daher hab ich natürlich auch umgehend den Lizenz key gekauft und den Adapter auf die 1.0.1 installiert.
        Problem dabei ist das ich jetzt nur noch Fehler habe der Adapter startet garnicht mehr so das ich ihn deinstallieren musste damit mein System wieder einigermaßen fehlerfrei lief.
        Nach neu installation das gleiche wieder, Key eingegeben aber der Adapter rührt sich nicht und verursacht jede Menge Fehler
        Was ist eigentlich der Unterschied zwischen der 2 und 3 Euro Version....?
        2024-01-20 11:53:06.006 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
        2024-01-20 11:53:07.207 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
        2024-01-20 11:53:31.999 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
        2024-01-20 11:53:33.782 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
        2024-01-20 11:53:46.523 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
        2024-01-20 11:54:24.559 - info: host.iobroker iobroker add net-tools auto --host iobroker --debug
        2024-01-20 11:54:29.154 - info: host.iobroker iobroker NPM version: 10.2.3Installing iobroker.net-tools@1.0.1... (System call)
        2024-01-20 11:54:49.008 - info: host.iobroker iobroker
        2024-01-20 11:54:49.009 - info: host.iobroker iobroker added 27 packages, and changed 1 package in 19s
        2024-01-20 11:54:49.013 - info: host.iobroker iobroker 141 packages are looking for funding run `npm fund` for details
        2024-01-20 11:54:49.064 - info: host.iobroker iobroker host.iobroker install adapter net-tools
        2024-01-20 11:54:49.188 - info: host.iobroker iobroker upload [12] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/de/translations.json i18n/de/translations.json application/json
        2024-01-20 11:54:49.204 - info: host.iobroker iobroker upload [11] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/en/translations.json i18n/en/translations.json application/json
        2024-01-20 11:54:49.215 - info: host.iobroker iobroker upload [10] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/es/translations.json i18n/es/translations.json application/json
        2024-01-20 11:54:49.225 - info: host.iobroker iobroker upload [9] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        2024-01-20 11:54:49.235 - info: host.iobroker iobroker upload [8] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/it/translations.json i18n/it/translations.json application/json
        2024-01-20 11:54:49.246 - info: host.iobroker iobroker upload [7] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        2024-01-20 11:54:49.257 - info: host.iobroker iobroker upload [6] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        2024-01-20 11:54:49.268 - info: host.iobroker iobroker upload [5] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        2024-01-20 11:54:49.278 - info: host.iobroker iobroker upload [4] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        2024-01-20 11:54:49.289 - info: host.iobroker iobroker upload [3] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        2024-01-20 11:54:49.299 - info: host.iobroker iobroker upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        2024-01-20 11:54:49.309 - info: host.iobroker iobroker upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/jsonConfig.json jsonConfig.json application/json
        2024-01-20 11:54:49.319 - info: host.iobroker iobroker upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png image/png
        2024-01-20 11:54:49.492 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools created/updated
        2024-01-20 11:54:49.604 - info: host.iobroker iobroker host.iobroker create instance net-tools
        2024-01-20 11:54:49.621 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.alive created
        2024-01-20 11:54:49.638 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.connected created
        2024-01-20 11:54:49.654 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.compactMode created
        2024-01-20 11:54:49.678 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cpu created
        2024-01-20 11:54:49.696 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cputime created
        2024-01-20 11:54:49.710 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapUsed created
        2024-01-20 11:54:49.725 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapTotal created
        2024-01-20 11:54:49.742 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memRss created
        2024-01-20 11:54:49.754 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.uptime created
        2024-01-20 11:54:49.790 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.inputCount created
        2024-01-20 11:54:49.805 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.outputCount created
        2024-01-20 11:54:49.821 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.eventLoopLag created
        2024-01-20 11:54:49.833 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.sigKill created
        2024-01-20 11:54:49.850 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.logLevel created
        2024-01-20 11:54:49.863 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost created
        2024-01-20 11:54:49.874 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost.ports created
        2024-01-20 11:54:49.887 - info: host.iobroker iobroker host.iobroker object net-tools.0.discover created
        2024-01-20 11:54:49.909 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0 created
        2024-01-20 11:54:51.005 - info: host.iobroker iobroker exit 0
        2024-01-20 11:54:53.175 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 19720
        2024-01-20 11:54:55.035 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
        2024-01-20 11:54:55.035 - error: host.iobroker Caught by controller[0]: throw err;
        2024-01-20 11:54:55.036 - error: host.iobroker Caught by controller[0]: ^
        2024-01-20 11:54:55.037 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@jey-cee/dm-utils'
        2024-01-20 11:54:55.038 - error: host.iobroker Caught by controller[0]: Require stack:
        2024-01-20 11:54:55.038 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
        2024-01-20 11:54:55.039 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
        2024-01-20 11:54:55.039 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        2024-01-20 11:54:55.039 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
        2024-01-20 11:54:55.039 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-20 11:54:55.040 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-01-20 11:54:55.040 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
        2024-01-20 11:54:55.040 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-20 11:54:55.041 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-01-20 11:54:55.041 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-01-20 11:54:55.041 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-01-20 11:54:55.042 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
        2024-01-20 11:54:55.042 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        2024-01-20 11:54:55.042 - error: host.iobroker Caught by controller[0]: requireStack: [
        2024-01-20 11:54:55.042 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
        2024-01-20 11:54:55.043 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
        2024-01-20 11:54:55.043 - error: host.iobroker Caught by controller[0]: ]
        2024-01-20 11:54:55.043 - error: host.iobroker Caught by controller[0]: }
        2024-01-20 11:54:55.043 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
        2024-01-20 11:54:55.044 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-20 11:54:55.044 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
        2024-01-20 11:54:55.045 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
        2024-01-20 11:54:55.046 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        2024-01-20 11:54:55.047 - info: host.iobroker iobroker rebuild
        2024-01-20 11:54:56.218 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
        2024-01-20 11:54:57.128 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
        2024-01-20 11:55:35.549 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
        2024-01-20 11:55:35.588 - info: host.iobroker iobroker npm-rebuild:
        2024-01-20 11:55:35.589 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
        2024-01-20 11:55:36.639 - info: host.iobroker iobroker npm-rebuild: exit 0
        2024-01-20 11:55:37.020 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 20246
        2024-01-20 11:55:38.484 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
        2024-01-20 11:55:38.485 - error: host.iobroker Caught by controller[0]: throw err;
        2024-01-20 11:55:38.485 - error: host.iobroker Caught by controller[0]: ^
        2024-01-20 11:55:38.485 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@jey-cee/dm-utils'
        2024-01-20 11:55:38.486 - error: host.iobroker Caught by controller[0]: Require stack:
        2024-01-20 11:55:38.486 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
        2024-01-20 11:55:38.486 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
        2024-01-20 11:55:38.486 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        2024-01-20 11:55:38.486 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
        2024-01-20 11:55:38.486 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        2024-01-20 11:55:38.487 - error: host.iobroker Caught by controller[0]: requireStack: [
        2024-01-20 11:55:38.488 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
        2024-01-20 11:55:38.488 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
        2024-01-20 11:55:38.488 - error: host.iobroker Caught by controller[0]: ]
        2024-01-20 11:55:38.488 - error: host.iobroker Caught by controller[0]: }
        2024-01-20 11:55:38.488 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
        2024-01-20 11:55:38.488 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-20 11:55:38.489 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
        2024-01-20 11:55:38.489 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
        2024-01-20 11:55:38.489 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
        2024-01-20 11:55:38.489 - info: host.iobroker iobroker rebuild
        2024-01-20 11:55:39.987 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
        2024-01-20 11:56:18.888 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
        2024-01-20 11:56:18.938 - info: host.iobroker iobroker npm-rebuild:
        2024-01-20 11:56:18.939 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
        2024-01-20 11:56:19.962 - info: host.iobroker iobroker npm-rebuild: exit 0
        2024-01-20 11:56:20.167 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 20774
        2024-01-20 11:56:21.506 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
        2024-01-20 11:56:21.507 - error: host.iobroker Caught by controller[0]: throw err;
        2024-01-20 11:56:21.507 - error: host.iobroker Caught by controller[0]: ^
        2024-01-20 11:56:21.507 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@jey-cee/dm-utils'
        2024-01-20 11:56:21.507 - error: host.iobroker Caught by controller[0]: Require stack:
        2024-01-20 11:56:21.507 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-01-20 11:56:21.508 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: requireStack: [
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: ]
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: }
        2024-01-20 11:56:21.509 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
        2024-01-20 11:56:21.509 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-20 11:56:21.510 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
        2024-01-20 11:56:21.510 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
        2024-01-20 11:56:21.510 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
        2024-01-20 11:56:21.510 - info: host.iobroker iobroker rebuild
        2024-01-20 11:56:23.299 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
        2024-01-20 11:57:00.749 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
        2024-01-20 11:57:00.794 - info: host.iobroker iobroker npm-rebuild:
        2024-01-20 11:57:00.795 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
        2024-01-20 11:57:01.810 - info: host.iobroker iobroker npm-rebuild: exit 0
        2024-01-20 11:57:02.023 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 21282
        2024-01-20 11:57:03.423 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
        2024-01-20 11:57:03.423 - error: host.iobroker Caught by controller[0]: throw err;
        2024-01-20 11:57:03.423 - error: host.iobroker Caught by controller[0]: ^
        2024-01-20 11:57:03.423 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@jey-cee/dm-utils'
        2024-01-20 11:57:03.424 - error: host.iobroker Caught by controller[0]: Require stack:
        2024-01-20 11:57:03.424 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
        2024-01-20 11:57:03.424 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
        2024-01-20 11:57:03.424 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        2024-01-20 11:57:03.424 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
        2024-01-20 11:57:03.424 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: requireStack: [
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
        2024-01-20 11:57:03.425 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
        2024-01-20 11:57:03.426 - error: host.iobroker Caught by controller[0]: ]
        2024-01-20 11:57:03.426 - error: host.iobroker Caught by controller[0]: }
        2024-01-20 11:57:03.426 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
        2024-01-20 11:57:03.426 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-20 11:57:03.426 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        @teletapi Ich hab es gefixt sollte bald die version 1.0.2 verfügbar sein.
        teletapiT 1 Antwort Letzte Antwort
        • Jey CeeJ Jey Cee
          teletapiT Online
          teletapiT Online
          teletapi
          schrieb am zuletzt editiert von teletapi
          @jey-cee Ich habe jetzt gerade mal die 1.0.2 installiert, der Fehlker bleibt aber der gleiche Instanz startet garnicht erst und die gleichen fehler wie oben mit der 1.0.1
          2024-01-20 18:30:00.154 - info: host.iobroker instance system.adapter.ical.0 started with pid 74065
          2024-01-20 18:30:03.414 - info: ical.0 (74065) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 18:30:09.679 - info: ical.0 (74065) Terminated (NO_ERROR): Without reason
          2024-01-20 18:30:10.238 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-01-20 19:00:00.201 - info: host.iobroker instance system.adapter.ical.0 started with pid 77844
          2024-01-20 19:00:03.294 - info: ical.0 (77844) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 19:00:09.573 - info: ical.0 (77844) Terminated (NO_ERROR): Without reason
          2024-01-20 19:00:10.138 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-01-20 19:08:51.757 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
          2024-01-20 19:08:51.758 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:09:12.010 - info: nuki.0 (1936) status change received for NukiID 790083444: locking
          2024-01-20 19:09:12.011 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:09:31.958 - info: nuki.0 (1936) status change received for NukiID 790083444: locked
          2024-01-20 19:09:31.959 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:19:47.675 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
          2024-01-20 19:19:47.675 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:20:07.687 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
          2024-01-20 19:20:07.688 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:20:33.458 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
          2024-01-20 19:20:35.821 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2024-01-20 19:20:50.379 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
          2024-01-20 19:28:26.897 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
          2024-01-20 19:30:00.146 - info: host.iobroker instance system.adapter.ical.0 started with pid 81588
          2024-01-20 19:30:03.101 - info: ical.0 (81588) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 19:30:09.531 - info: ical.0 (81588) Terminated (NO_ERROR): Without reason
          2024-01-20 19:30:10.107 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-01-20 19:36:49.011 - info: nuki.0 (1936) status change received for NukiID 790083444: unlatched
          2024-01-20 19:36:49.012 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:37:09.663 - info: nuki.0 (1936) status change received for NukiID 790083444: locking
          2024-01-20 19:37:09.664 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 19:37:29.600 - info: nuki.0 (1936) status change received for NukiID 790083444: locked
          2024-01-20 19:37:29.601 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
          2024-01-20 20:00:00.159 - info: host.iobroker instance system.adapter.ical.0 started with pid 85926
          2024-01-20 20:00:03.259 - info: ical.0 (85926) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 20:00:09.627 - info: ical.0 (85926) Terminated (NO_ERROR): Without reason
          2024-01-20 20:00:10.146 - warn: ical.0 (85926) get state error: Connection is closed.
          2024-01-20 20:00:10.233 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-01-20 20:30:00.157 - info: host.iobroker instance system.adapter.ical.0 started with pid 89711
          2024-01-20 20:30:03.126 - info: ical.0 (89711) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 20:30:09.477 - info: ical.0 (89711) Terminated (NO_ERROR): Without reason
          2024-01-20 20:30:10.029 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-01-20 20:34:57.068 - info: hm-rpc.1 (10645) Firmware update status of 3014F711A000021D89A1B02B changed to 1
          2024-01-20 21:00:00.159 - info: host.iobroker instance system.adapter.ical.0 started with pid 93560
          2024-01-20 21:00:03.182 - info: ical.0 (93560) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 21:00:09.549 - info: ical.0 (93560) Terminated (NO_ERROR): Without reason
          2024-01-20 21:00:10.098 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-01-20 21:03:48.746 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
          2024-01-20 21:04:00.066 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
          2024-01-20 21:04:02.059 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2024-01-20 21:04:14.219 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
          2024-01-20 21:04:36.158 - info: host.iobroker iobroker add net-tools auto --host iobroker --debug
          2024-01-20 21:04:40.566 - info: host.iobroker iobroker NPM version: 10.2.3
          2024-01-20 21:04:40.570 - info: host.iobroker iobroker Installing iobroker.net-tools@1.0.2... (System call)
          2024-01-20 21:04:57.827 - info: host.iobroker iobroker
          2024-01-20 21:04:57.828 - info: host.iobroker iobroker added 27 packages, and changed 1 package in 16s141 packages are looking for funding run `npm fund` for details
          2024-01-20 21:04:57.877 - info: host.iobroker iobroker host.iobroker install adapter net-tools
          2024-01-20 21:04:57.980 - info: host.iobroker iobroker upload [12] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/de/translations.json i18n/de/translations.json application/json
          2024-01-20 21:04:58.036 - info: host.iobroker iobroker upload [11] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/en/translations.json i18n/en/translations.json application/json
          2024-01-20 21:04:58.091 - info: host.iobroker iobroker upload [10] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/es/translations.json i18n/es/translations.json application/json
          2024-01-20 21:04:58.106 - info: host.iobroker iobroker upload [9] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          2024-01-20 21:04:58.125 - info: host.iobroker iobroker upload [8] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/it/translations.json i18n/it/translations.json application/json
          2024-01-20 21:04:58.149 - info: host.iobroker iobroker upload [7] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          2024-01-20 21:04:58.161 - info: host.iobroker iobroker upload [6] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          2024-01-20 21:04:58.171 - info: host.iobroker iobroker upload [5] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          2024-01-20 21:04:58.189 - info: host.iobroker iobroker upload [4] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          2024-01-20 21:04:58.212 - info: host.iobroker iobroker upload [3] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          2024-01-20 21:04:58.228 - info: host.iobroker iobroker upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          2024-01-20 21:04:58.244 - info: host.iobroker iobroker upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/jsonConfig.json jsonConfig.json application/json
          2024-01-20 21:04:58.259 - info: host.iobroker iobroker upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png image/png
          2024-01-20 21:04:58.415 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools created/updated
          2024-01-20 21:04:58.596 - info: host.iobroker iobroker host.iobroker create instance net-tools
          2024-01-20 21:04:58.616 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.alive created
          2024-01-20 21:04:58.630 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.connected created
          2024-01-20 21:04:58.646 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.compactMode created
          2024-01-20 21:04:58.670 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cpu created
          2024-01-20 21:04:58.689 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cputime created
          2024-01-20 21:04:58.720 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapUsed created
          2024-01-20 21:04:58.735 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapTotal created
          2024-01-20 21:04:58.748 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memRss created
          2024-01-20 21:04:58.763 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.uptime created
          2024-01-20 21:04:58.777 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.inputCount created
          2024-01-20 21:04:58.792 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.outputCount created
          2024-01-20 21:04:58.805 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.eventLoopLag created
          2024-01-20 21:04:58.824 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.sigKill created
          2024-01-20 21:04:58.838 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.logLevel created
          2024-01-20 21:04:58.851 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost created
          2024-01-20 21:04:58.865 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost.ports created
          2024-01-20 21:04:58.878 - info: host.iobroker iobroker host.iobroker object net-tools.0.discover created
          2024-01-20 21:04:58.897 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0 created
          2024-01-20 21:04:59.985 - info: host.iobroker iobroker exit 0
          2024-01-20 21:05:02.023 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 94264
          2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
          2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: throw err;
          2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: ^
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: Require stack:
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: requireStack: [
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: ]
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: }
          2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
          2024-01-20 21:05:03.825 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-20 21:05:03.825 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
          2024-01-20 21:05:03.825 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
          2024-01-20 21:05:03.827 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
          2024-01-20 21:05:03.827 - info: host.iobroker iobroker rebuild
          2024-01-20 21:05:04.593 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
          2024-01-20 21:05:05.684 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
          2024-01-20 21:05:43.058 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
          2024-01-20 21:05:43.095 - info: host.iobroker iobroker npm-rebuild:
          2024-01-20 21:05:43.097 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
          2024-01-20 21:05:44.111 - info: host.iobroker iobroker npm-rebuild: exit 0
          2024-01-20 21:05:44.279 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 94760
          2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
          2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: throw err;
          2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: ^
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: Require stack:
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: requireStack: [
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: ]
          2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: }
          2024-01-20 21:05:45.551 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
          2024-01-20 21:05:45.551 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-20 21:05:45.551 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
          2024-01-20 21:05:45.551 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
          2024-01-20 21:05:45.551 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
          2024-01-20 21:05:45.551 - info: host.iobroker iobroker rebuild
          2024-01-20 21:05:46.971 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
          2024-01-20 21:06:40.883 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
          2024-01-20 21:06:41.001 - info: host.iobroker iobroker npm-rebuild:
          2024-01-20 21:06:41.002 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
          2024-01-20 21:06:42.023 - info: host.iobroker iobroker npm-rebuild: exit 0
          2024-01-20 21:06:42.253 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 95354
          2024-01-20 21:06:44.790 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
          2024-01-20 21:06:44.791 - error: host.iobroker Caught by controller[0]: throw err;
          2024-01-20 21:06:44.791 - error: host.iobroker Caught by controller[0]: ^
          2024-01-20 21:06:44.792 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
          2024-01-20 21:06:44.792 - error: host.iobroker Caught by controller[0]: Require stack:
          2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
          2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
          2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          2024-01-20 21:06:44.794 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          2024-01-20 21:06:44.795 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-20 21:06:44.795 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-01-20 21:06:44.796 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
          2024-01-20 21:06:44.796 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-20 21:06:44.797 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-20 21:06:44.797 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-20 21:06:44.798 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-20 21:06:44.799 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
          2024-01-20 21:06:44.799 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2024-01-20 21:06:44.800 - error: host.iobroker Caught by controller[0]: requireStack: [
          2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
          2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
          2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: ]
          2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: }
          2024-01-20 21:06:44.810 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
          2024-01-20 21:06:44.810 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-20 21:06:44.810 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
          2024-01-20 21:06:44.810 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
          2024-01-20 21:06:44.811 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
          2024-01-20 21:06:44.811 - info: host.iobroker iobroker rebuild
          2024-01-20 21:06:47.105 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
          2024-01-20 21:07:43.520 - info: host.iobroker stopInstance system.adapter.simple-api.0 (force=false, process=true)
          2024-01-20 21:07:43.669 - info: simple-api.0 (19001) Got terminate signal TERMINATE_YOURSELF
          2024-01-20 21:07:43.683 - info: simple-api.0 (19001) terminating http server on port 8087
          2024-01-20 21:07:43.685 - info: simple-api.0 (19001) terminating
          2024-01-20 21:07:43.688 - info: simple-api.0 (19001) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-20 21:07:43.704 - info: host.iobroker stopInstance system.adapter.simple-api.0 send kill signal
          2024-01-20 21:07:44.190 - info: simple-api.0 (19001) terminating
          2024-01-20 21:07:44.241 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
          2024-01-20 21:07:44.252 - info: host.iobroker "system.adapter.web.0" disabled
          2024-01-20 21:07:44.252 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
          2024-01-20 21:07:44.244 - info: cloud.0 (1676) Reconnect because web instance stopped
          2024-01-20 21:07:44.383 - info: web.0 (19065) Got terminate signal TERMINATE_YOURSELF
          2024-01-20 21:07:44.384 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
          2024-01-20 21:07:44.387 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
          2024-01-20 21:07:44.406 - info: cloud.0 (1676) Reconnect because web instance started
          2024-01-20 21:07:44.429 - info: host.iobroker "system.adapter.web.0" enabled
          2024-01-20 21:07:44.430 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
          2024-01-20 21:07:44.437 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
          2024-01-20 21:07:44.493 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
          2024-01-20 21:07:44.497 - info: web.0 (19065) Got terminate signal TERMINATE_YOURSELF
          2024-01-20 21:07:44.587 - info: host.iobroker instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-20 21:07:44.594 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
          2024-01-20 21:07:44.639 - info: web.0 (19065) terminated http server on port 8082
          2024-01-20 21:07:44.640 - info: web.0 (19065) terminating
          2024-01-20 21:07:44.642 - info: web.0 (19065) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-20 21:07:44.887 - info: web.0 (19065) terminating
          2024-01-20 21:07:45.378 - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-20 21:07:46.832 - info: host.iobroker instance system.adapter.simple-api.0 started with pid 95868
          2024-01-20 21:07:47.740 - info: host.iobroker instance system.adapter.web.0 started with pid 95876
          2024-01-20 21:07:51.969 - info: simple-api.0 (95868) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 21:07:52.049 - warn: simple-api.0 (95868) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
          2024-01-20 21:07:52.064 - info: simple-api.0 (95868) simpleAPI server listening on port 8087
          2024-01-20 21:07:52.067 - info: simple-api.0 (95868) Allow states only when user is owner: false
          2024-01-20 21:07:52.114 - info: simple-api.0 (95868) http server listening on port 8087
          2024-01-20 21:07:53.479 - info: web.0 (95876) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 21:07:54.626 - info: web.0 (95876) socket.io server listening on port 8082
          2024-01-20 21:07:54.653 - info: web.0 (95876) http server listening on port 8082
          2024-01-20 21:07:57.522 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
          2024-01-20 21:07:57.659 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
          2024-01-20 21:07:58.668 - info: host.iobroker iobroker npm-rebuild: exit 0
          2024-01-20 21:07:58.919 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 95960
          2024-01-20 21:08:03.601 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
          2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: throw err;
          2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: ^
          2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
          2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: Require stack:
          2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: requireStack: [
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: ]
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: }
          2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
          2024-01-20 21:08:03.605 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-20 21:08:03.605 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2024-01-20 21:08:15.117 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
          2024-01-20 21:08:15.126 - info: host.iobroker "system.adapter.web.0" disabled
          2024-01-20 21:08:15.127 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
          2024-01-20 21:08:15.121 - info: cloud.0 (1676) Reconnect because web instance stopped
          2024-01-20 21:08:15.249 - info: web.0 (95876) Got terminate signal TERMINATE_YOURSELF
          2024-01-20 21:08:15.263 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
          2024-01-20 21:08:15.275 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
          2024-01-20 21:08:15.281 - info: host.iobroker "system.adapter.web.0" enabled
          2024-01-20 21:08:15.282 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
          2024-01-20 21:08:15.286 - info: cloud.0 (1676) Reconnect because web instance started
          2024-01-20 21:08:15.290 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
          2024-01-20 21:08:15.316 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
          2024-01-20 21:08:15.317 - info: web.0 (95876) Got terminate signal TERMINATE_YOURSELF
          2024-01-20 21:08:15.341 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
          2024-01-20 21:08:15.411 - info: web.0 (95876) terminated http server on port 8082
          2024-01-20 21:08:15.413 - info: web.0 (95876) terminating
          2024-01-20 21:08:15.415 - info: web.0 (95876) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-20 21:08:15.752 - info: web.0 (95876) terminating
          2024-01-20 21:08:16.045 - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-20 21:08:18.446 - info: host.iobroker instance system.adapter.web.0 started with pid 96037
          2024-01-20 21:08:22.117 - info: web.0 (96037) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
          2024-01-20 21:08:22.474 - info: web.0 (96037) socket.io server listening on port 8082
          2024-01-20 21:08:22.497 - info: web.0 (96037) http server listening on port 8082
          2024-01-20 21:09:31.972 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 96426
          2024-01-20 21:09:33.597 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
          2024-01-20 21:09:33.597 - error: host.iobroker Caught by controller[0]: throw err;
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: ^
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: Require stack:
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: requireStack: [
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: ]
          2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: }
          2024-01-20 21:09:33.600 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
          2024-01-20 21:09:33.600 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-20 21:09:33.600 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2024-01-20 21:10:01.096 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
          Wenn ich den Adapter neu starten will, kommen folgende Fehler
          host.iobroker
          	2024-01-20 21:15:16.359	info	Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          host.iobroker
          	2024-01-20 21:15:16.359	error	instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          	2024-01-20 21:15:16.359	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          	2024-01-20 21:15:16.359	error	Caught by controller[0]: }
          host.iobroker
          	2024-01-20 21:15:16.359	error	Caught by controller[0]: ]
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: requireStack: [
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: Require stack:
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
          host.iobroker
          	2024-01-20 21:15:16.357	error	Caught by controller[0]: ^
          host.iobroker
          	2024-01-20 21:15:16.356	error	Caught by controller[0]: throw err;
          host.iobroker
          	2024-01-20 21:15:16.355	error	Caught by controller[0]: node:internal/modules/cjs/loader:1137
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          	2024-01-20 21:15:15.011	info	instance system.adapter.net-tools.0 started with pid 97263
          admin.0
          	2024-01-20 21:10:01.096	warn	net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
          GlasfaserG Jey CeeJ 2 Antworten Letzte Antwort
          • teletapiT teletapi
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            admin.0
            GlasfaserG Offline
            GlasfaserG Offline
            @teletapi
            Editiere bitte dein Log mit den Privaten Daten von ical :
            z.B
            2024-01-20 19:30:03.805 - info: ical.0 (81588) processing URL: Wichtige Termine .....ics
            usw ...
            • GlasfaserG Glasfaser
              @teletapi
              z.B
              usw ...
              @glasfaser sagte in Net-Tools update auf 1.0.1 Fehler:
              @teletapi
              z.B
              usw ...
              ich hoffe ich hab alles
              am Handy eine Qual so lange logs zu editieren
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                admin.0
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                @teletapi das kommt davon wenn man das mal schnell macht wenn man im Stress ist.
                Persönlicher Support
                Spenden -> paypal.me/J3YC33
                  @teletapi
                  z.B
                  usw ...
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @homoran sagte in Net-Tools update auf 1.0.1 Fehler:
                    teletapiT Online
                    teletapiT Online
                    teletapi
                    Ich hab die 1.0.3 jetzt installiert und der Adapter startet auch wird auch grün und findet die Geräte, als Warnung habe ich im Protocol aber noch folgendes stehn
                    net-tools.0 2024-01-20 23:49:34.177 warn License Key is invalid
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: iobroker
                             Icon name: computer
                      Operating System: Debian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v8+
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : arm64
                    Systemuptime and Load:
                     23:57:58 up 13:48,  1 user,  load average: 0.93, 0.87, 0.94
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Sat 2024-01-20 23:57:58 CET
                               Universal time: Sat 2024-01-20 22:57:58 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            7.8G        3.1G        2.2G        1.0M        2.5G        4.5G
                    Swap:            99M          0B         99M
                    Total:          7.9G        3.1G        2.3G
                             7811 M total memory
                             3149 M used memory
                             4172 M active memory
                             1245 M inactive memory
                             2157 M free memory
                              170 M buffer memory
                             2333 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4       59G  9.1G   47G  17% /
                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                    /dev/sda1      vfat      255M   31M  225M  13% /boot
                    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                    [Sat Jan 20 10:09:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.ma                                     caddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Sat Jan 20 10:09:42 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Sat Jan 20 10:09:42 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    [Sat Jan 20 10:09:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    TARGET  SOURCE    FSTYPE OPTIONS
                    /       /dev/sda2 ext4   rw,noatime
                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    2.0G    /var/
                    1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
                    1.1G    /var/log
                    637M    /var/lib
                    Archived and active journals take up 1.0G in the file system.
                    /opt/iobroker/backups:
                    1.6G    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    382M    /opt/iobroker/iobroker-data/
                    185M    /opt/iobroker/iobroker-data/files
                    77M     /opt/iobroker/iobroker-data/backup-objects
                    72M     /opt/iobroker/iobroker-data/node-red
                    71M     /opt/iobroker/iobroker-data/node-red/node_modules
                    37M     /opt/iobroker/iobroker-data/objects.jsonl
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                    8.5M    /opt/iobroker/iobroker-data/states.jsonl
                    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    admin:          6.13.15
                    javascript:     7.7.0
                    Adapters from github:   2
                    Adapter State
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
                    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): beta
                    Installed ioBroker-Instances
                    Used repository: beta
                    Adapter    "admin"        : 6.13.15  , installed 6.13.15
                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                    Adapter    "backitup"     : 2.10.3   , installed 2.10.3
                    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                    Adapter    "hue"          : 3.10.2   , installed 3.10.2
                    Adapter    "ical"         : 1.14.0   , installed 1.14.0
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
                    Adapter    "javascript"   : 7.7.0    , installed 7.7.0
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "net-tools"    : 1.0.2    , installed 1.0.3
                    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
                    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                    Adapter    "ws"           : 2.5.10   , installed 2.5.10
                    Objects and States
                    Objects:        10002
                    States:         10092
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                    Hit:6 https://apt.grafana.com stable InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13624      566/sshd: /usr/sbin
                    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       179028     10408/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20230      1784/io.jarvis.0
                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       16371      1498/io.sonoff.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15086      560/mosquitto
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19210      1552/io.shelly.0
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18493      1235/node-red
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13639      542/cupsd
                    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       183523     10645/io.hm-rpc.1
                    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       182669     10580/io.hm-rpc.2
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16481      658/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16488      658/iobroker.js-con
                    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       1855617    95868/io.simple-api
                    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24665      1936/io.nuki.0
                    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       180930     10538/io.hm-rpc.3
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13626      566/sshd: /usr/sbin
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13638      542/cupsd
                    tcp6       0      0 :::1883                 :::*                    LISTEN      116        15087      560/mosquitto
                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        16385      657/grafana
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15160      547/influxd
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24273      2330/io.socketio.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1857814    96037/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13958      982/io.admin.0
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13654      617/cups-browsed
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14903      403/avahi-daemon: r
                    udp        0      0 0.0.0.0:56063           0.0.0.0:*                           108        14905      403/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15209      480/dhcpcd
                    udp6       0      0 :::546                  :::*                                0          15226      480/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        14904      403/avahi-daemon: r
                    udp6       0      0 :::46450                :::*                                108        14906      403/avahi-daemon: r
                    2024-01-20 23:56:54.582  - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=true)
                    2024-01-20 23:56:54.701  - info: net-tools.0 (121771) Got terminate signal TERMINATE_YOURSELF
                    2024-01-20 23:56:54.707  - info: host.iobroker stopInstance system.adapter.net-tools.0 send kill signal
                    2024-01-20 23:56:54.703  - info: net-tools.0 (121771) terminating
                    2024-01-20 23:56:54.705  - info: net-tools.0 (121771) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2024-01-20 23:56:55.207  - info: net-tools.0 (121771) terminating
                    2024-01-20 23:56:55.308  - info: host.iobroker instance system.adapter.net-tools.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2024-01-20 23:56:57.818  - info: host.iobroker instance system.adapter.net-tools.0 started with pid 122180
                    2024-01-20 23:57:00.543  - info: net-tools.0 (122180) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                    2024-01-20 23:57:00.788  - info: net-tools.0 (122180) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                    2024-01-20 23:57:02.060  - warn: net-tools.0 (122180) License Key is invalid
                    2024-01-20 23:57:02.895  - info: net-tools.0 (122180) Port scan finished
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               7811 M total memory
                               3149 M used memory
                               2157 M free memory
                                170 M buffer memory
                               2333 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      2.0G    /var/
                      1.1G    /var/log
                      637M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.15
                      javascript:     7.7.0
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        10002
                      States:         10092
                      Pending Updates: 0
                      Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      @teletapi schick mir doch bitte eine mail an iobroker@all-smart.net, am besten von der email aus mit der du dich im shop registriert hast.
                      Dann schau ich obs am Lizenz server liegt.
                      • Jey CeeJ Jey Cee
                        teletapiT Online
                        teletapiT Online
                        teletapi
                        @jey-cee said in Net-Tools update auf 1.0.1 Fehler:
                        Hab ich gerade gemacht
                          teletapiT Online
                          teletapiT Online
                          teletapi
                          Ich hab heute morgen mal den Adapter neu suchen lassen und dabei stürzte der Adapter dann auch mal kurzfristig ab und es gab einige fehler und warnungen. Das gleiche wiederholt sich auch bei weiteren versuchen.
                          Es fehlen geräte und gelöschte bzw Geräte die ich in der Fritzbox umbenannt habe werden nicht (zumindest) automatisch gefunden
                          853
                          Log-Größe: 203.5 KB
                          Zeit
                          Nachricht
                          net-tools.0
                          	2024-01-21 12:09:12.893	info	Port scan finished
                          net-tools.0
                          	2024-01-21 12:09:11.856	warn	License Key is invalid
                          net-tools.0
                          	2024-01-21 12:09:10.728	info	Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                          net-tools.0
                          	2024-01-21 12:09:10.462	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                          host.iobroker
                          	2024-01-21 12:09:08.144	info	instance system.adapter.net-tools.0 started with pid 24532
                          host.iobroker
                          	2024-01-21 12:08:38.035	info	Restart adapter system.adapter.net-tools.0 because enabled
                          host.iobroker
                          	2024-01-21 12:08:38.034	error	instance system.adapter.net-tools.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          net-tools.0
                          	2024-01-21 12:08:37.922	info	Default value for state "net-tools.0.2462ab541893.time" could not be set: DB closed
                          net-tools.0
                          	2024-01-21 12:08:37.920	warn	get state error: Connection is closed.
                          net-tools.0
                          	2024-01-21 12:08:37.919	warn	Could not perform strict object check of state net-tools.0.2462ab541893.time: DB closed
                          net-tools.0
                          	2024-01-21 12:08:37.911	warn	redis get net-tools.0.2462ab541893.time, error - Connection is closed.
                          net-tools.0
                          	2024-01-21 12:08:37.898	info	terminating
                          net-tools.0
                          	2024-01-21 12:08:37.802	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.801	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.651	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.506	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.461	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.460	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.459	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.458	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.457	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          net-tools.0
                          	2024-01-21 12:08:37.456	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.455	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.453	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.452	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.451	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.450	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.448	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.447	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.445	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.444	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.442	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.441	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.438	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.436	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.435	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          net-tools.0
                          	2024-01-21 12:08:37.433	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.432	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          net-tools.0
                          	2024-01-21 12:08:37.431	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.430	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.429	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.428	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.427	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.426	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.425	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          net-tools.0
                          	2024-01-21 12:08:37.424	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.423	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.421	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.420	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.419	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.418	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          net-tools.0
                          	2024-01-21 12:08:37.417	warn	setTimeout called, but adapter is shutting down
                          net-tools.0
                          	2024-01-21 12:08:37.396	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          net-tools.0
                          	2024-01-21 12:08:37.394	info	terminating
                          net-tools.0
                          	2024-01-21 12:08:37.050	error	Cannot read properties of undefined (reading 'stateAlive')
                          net-tools.0
                          	2024-01-21 12:08:37.048	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                          net-tools.0
                          	2024-01-21 12:08:37.047	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                          net-tools.0
                          	2024-01-21 12:08:37.044	error	Cannot read properties of undefined (reading 'stateAlive')
                          net-tools.0
                          	2024-01-21 12:08:37.043	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                          net-tools.0
                          	2024-01-21 12:08:37.041	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                          discovery.0
                          	2024-01-21 12:08:12.374	info	Discovery finished
                          discovery.0
                          	2024-01-21 12:08:12.179	info	Discovery finished. Found new or modified 13 instances
                          net-tools.0
                          	2024-01-21 12:07:01.161	warn	Unknown message origin: 1777722
                          discovery.0
                          	2024-01-21 12:04:35.882	info	Found 43 addresses
                          discovery.0
                          	2024-01-21 12:04:35.720	info	Done discovering ping devices. 42 packages received
                          discovery.0
                          	2024-01-21 12:04:09.872	info	Discovering ping devices...
                          net-tools.0
                          	2024-01-21 12:04:08.806	error	Error: No outstanding message, can't send a new one
                          admin.0
                          	2024-01-21 12:03:54.291	warn	net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
                          host.iobroker
                          	2024-01-21 12:00:10.219	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          ical.0
                          	2024-01-21 12:00:10.057	warn	get state error: Connection is closed.
                            853
                            Log-Größe: 203.5 KB
                            Zeit
                            Nachricht
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            net-tools.0
                            discovery.0
                            discovery.0
                            net-tools.0
                            discovery.0
                            discovery.0
                            discovery.0
                            net-tools.0
                            admin.0
                            host.iobroker
                            ical.0
                            Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            @teletapi sagte in Net-Tools update auf 1.0.1 Fehler:
                            Das Geräte Fehlen kann daran liegen das sie nicht auf den Ping reagieren. Es gab auch früher Meldungen das Geräte nicht gefunden wurden obwohl sie per Ping erreichbar sind. Dieses Problem betrifft auch drn Ping Adapter und die Ursache hab ich bisher nicht finden können.
                            Hier hilft es nur die Geräte von Hand an zu legen.
                            Warum gelöschte Geräte nicht gefunden werden können ergibt für mich erst mal keinen Sinn. Das muss ich versuchen Nach zu stellen.
                            Da Geräte mit ihrer Mac im Adapter angelegt werden hat der Name keinen Einfluss. Es kann sein das der Name nicht in den Adapter übernommen wird, dennoch sollte es weiterhin im Adapter zu sehen sein, wenn es nicht gelöscht wurde.
                            Die Fehlermeldungen sehe ich mir an.
                            teletapiT 1 Antwort Letzte Antwort
                            • Jey CeeJ Jey Cee
                              teletapiT Online
                              teletapiT Online
                              teletapi
                              @jey-cee
                              Ja ich lösch den Adapter jetzt, das hier macht irgendwie so garkeinen Sinn
                              2999+
                              Log-Größe: 54.1 KB
                              Zeit
                              Nachricht
                              admin.0
                              	2024-01-21 15:03:27.368	info	<== Disconnect system.user.admin from ::ffff:192.168.178.63
                              admin.0
                              	2024-01-21 15:02:18.027	info	==> Connected system.user.admin from ::ffff:192.168.178.63
                              net-tools.0
                              	2024-01-21 15:01:32.871	info	Port scan finished
                              net-tools.0
                              	2024-01-21 15:01:31.880	warn	License Key is invalid
                              net-tools.0
                              	2024-01-21 15:01:30.741	info	Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                              net-tools.0
                              	2024-01-21 15:01:30.553	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                              host.iobroker
                              	2024-01-21 15:01:28.059	info	instance system.adapter.net-tools.0 started with pid 50632
                              host.iobroker
                              	2024-01-21 15:00:57.972	info	Restart adapter system.adapter.net-tools.0 because enabled
                              host.iobroker
                              	2024-01-21 15:00:57.971	error	instance system.adapter.net-tools.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              net-tools.0
                              	2024-01-21 15:00:57.824	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.822	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.821	warn	Could not perform strict object check of state net-tools.0.2462ab541893.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.821	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.820	warn	Could not perform strict object check of state net-tools.0.2462ab541893.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.819	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.819	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.818	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.818	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.817	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.817	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.816	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.816	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.815	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.814	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.814	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.813	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.812	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.812	warn	Could not perform strict object check of state net-tools.0.308398a2f258.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.811	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.810	warn	Could not perform strict object check of state net-tools.0.308398a2f258.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.810	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.809	warn	Could not perform strict object check of state net-tools.0.308398a2f258.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.808	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.808	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.807	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.806	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.805	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.804	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.804	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.803	warn	Could not perform strict object check of state net-tools.0.70039f01361f.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.802	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.802	warn	Could not perform strict object check of state net-tools.0.70039f01361f.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.800	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.798	warn	Could not perform strict object check of state net-tools.0.70039f01361f.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.797	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.797	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.796	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.795	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.795	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.794	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.793	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.792	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.792	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.791	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.790	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.790	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.789	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.788	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.788	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.787	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.786	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.785	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.785	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.784	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.rps: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.783	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.783	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.time: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.782	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.781	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.alive: DB closed
                              net-tools.0
                              	2024-01-21 15:00:57.758	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.757	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.756	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.755	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.754	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.753	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.752	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.751	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.750	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.749	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.748	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.747	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.746	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.745	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.744	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.743	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.742	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.741	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.740	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.739	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.738	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.737	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.736	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.735	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.734	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.733	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.732	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.731	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.730	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.729	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.728	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.727	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.726	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.725	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.724	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.723	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.722	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.711	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.710	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.709	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.708	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.707	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.706	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.705	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.704	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.703	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.702	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.701	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.700	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.699	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.698	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.697	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.695	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 15:00:57.694	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.693	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.692	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.691	warn	get state error: Connection is closed.
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.645	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.644	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.643	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.642	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.641	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.640	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.639	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.638	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.637	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.636	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.635	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.634	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.633	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.632	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.631	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.629	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.628	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.627	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.626	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.625	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.624	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.623	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.622	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.621	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.620	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.619	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 15:00:57.618	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.617	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.616	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.615	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.614	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.613	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 15:00:57.593	info	terminating
                              net-tools.0
                              	2024-01-21 15:00:57.021	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              net-tools.0
                              	2024-01-21 15:00:57.019	info	terminating
                              net-tools.0
                              	2024-01-21 15:00:56.980	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.979	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.978	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.979	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.977	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.976	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.977	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.975	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.974	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.975	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.973	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.972	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.973	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.971	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.970	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.971	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.969	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.969	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.968	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.967	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.968	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.966	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.966	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.965	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.964	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 15:00:56.964	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.964	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 15:00:56.963	error	Cannot read properties of undefined (reading 'stateAlive')
                                @jey-cee
                                2999+
                                Log-Größe: 54.1 KB
                                Zeit
                                Nachricht
                                admin.0
                                admin.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                net-tools.0
                                teletapiT Online
                                teletapiT Online
                                teletapi
                                schrieb am zuletzt editiert von teletapi
                                Morjen, ich denke ich weiß jetzt woher die Fehler und warnungen kommen.
                                Ich hab heute morgen gesehen das der "Net-tools" Adapter in der version 1.03 vorhanden ist und hab den nochmal installiert, eigentlich wollte ich damit nur schauen ob ich vielleicht einen fehler bei der Installation über die Katze ein Fehler gemacht habe. Nach der Installation blieben die Fehler und Warnungen aber die gleichen.
                                Dabei hab ich im Protocol aber gesehen das der Discovery Adapter scheinbar immer mit reagiert wenn ich die Gerätesuche im Net-Tools adapter starte.
                                Dann hab ich nochmal bei den Instanzen geschaut und da fielen mir die beiden Adapter "Ping" und "Discovery" auf und habe diese einfach mal gestoppt und dann den Net-tools Adapter laufen lassen neu gestartet und die Geräte suche laufen lassen, dabei wurden alle Geräte gefunden. Seiddem hat der Adapter keinen fehler mehr gezeigt
                                Den Ping Adapter habe ich mittlerweile wieder aktiviert und beide Adapter mal unabhängig voneinander neu gestartet das scheint den Net-tools Adapter aber nicht zu stören. Dürfte dann also der "Discovery Adapter" sein der hier in Verbindung mit dem Net-tools Adapter Probleme macht.
                                Sobald ich dann die Gerätesuche im Net-tools Adapter starte startet auch der Discovery Adapter neu und die Fehler sind wieder da
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 10:46:21 up 34 min,  1 user,  load average: 1.39, 1.25, 1.20
                                CPU threads: 4
                                Current issues:
                                               Local time: Mon 2024-01-22 10:46:21 CET
                                           Universal time: Mon 2024-01-22 09:46:21 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.8G        2.3G        3.7G        1.0M        1.7G        5.3G
                                Swap:            99M          0B         99M
                                Total:          7.9G        2.3G        3.8G
                                         7811 M total memory
                                         2343 M used memory
                                         3335 M active memory
                                          583 M inactive memory
                                         3727 M free memory
                                          121 M buffer memory
                                         1619 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G  9.2G   47G  17% /
                                [Mon Jan 22 10:12:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Mon Jan 22 10:12:19 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Mon Jan 22 10:12:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                [Mon Jan 22 10:12:20 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                /var:
                                1.9G    /var/
                                1.1G    /var/log
                                619M    /var/lib
                                1.8G    /opt/iobroker/backups/
                                352M    /opt/iobroker/iobroker-data/
                                181M    /opt/iobroker/iobroker-data/files
                                15M     /opt/iobroker/iobroker-data/objects.jsonl
                                8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.13.15
                                javascript:     7.7.0
                                Adapter State
                                  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                  system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                + instance is alive
                                Adapter    "backitup"     : 2.10.4   , installed 2.10.4
                                Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
                                Objects and States
                                Objects:        10033
                                States:         10104
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:5 https://apt.grafana.com stable InRelease
                                Hit:6 https://repos.influxdata.com/debian stable InRelease
                                Pending Updates: 0
                                tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17711      1371/io.hm-rpc.2
                                tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16319      1349/io.hm-rpc.1
                                tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       19209      1936/io.simple-api.
                                tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       17018      1328/io.hm-rpc.0
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16412      540/cupsd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11882      576/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14752      657/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12133      657/iobroker.js-con
                                tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17184      1425/io.hm-rpc.3
                                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23289      1856/io.jarvis.0
                                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17603      1247/node-red
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18758      1561/io.shelly.0
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15492      558/mosquitto
                                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18120      1498/io.sonoff.0
                                tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24733      1922/io.nuki.0
                                tcp6       0      0 :::3000                 :::*                    LISTEN      117        14648      656/grafana
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15817      1079/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21540      1656/io.web.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24693      2164/io.socketio.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        11946      549/influxd
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16411      540/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          11884      576/sshd: /usr/sbin
                                tcp6       0      0 :::1883                 :::*                    LISTEN      116        15493      558/mosquitto
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11920      617/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11257      401/avahi-daemon: r
                                udp        0      0 0.0.0.0:48832           0.0.0.0:*                           108        11259      401/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14641      461/dhcpcd
                                udp6       0      0 :::546                  :::*                                0          14661      461/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        11258      401/avahi-daemon: r
                                udp6       0      0 :::53051                :::*                                108        11260      401/avahi-daemon: r
                                2024-01-22 10:39:04.632  - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=true)
                                2024-01-22 10:39:04.766  - info: net-tools.0 (8472) Got terminate signal TERMINATE_YOURSELF
                                2024-01-22 10:39:04.771  - info: host.iobroker stopInstance system.adapter.net-tools.0 send kill signal
                                2024-01-22 10:39:04.772  - info: net-tools.0 (8472) terminating
                                2024-01-22 10:39:04.774  - info: net-tools.0 (8472) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-01-22 10:39:05.276  - info: net-tools.0 (8472) terminating
                                2024-01-22 10:39:05.434  - info: host.iobroker instance system.adapter.net-tools.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-22 10:39:07.862  - info: host.iobroker instance system.adapter.net-tools.0 started with pid 8574
                                2024-01-22 10:39:10.364  - info: net-tools.0 (8574) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                                2024-01-22 10:39:10.579  - info: net-tools.0 (8574) License Key is valid
                                2024-01-22 10:39:10.587  - info: net-tools.0 (8574) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                                2024-01-22 10:39:13.207  - info: net-tools.0 (8574) Port scan finished
                                Jey CeeJ mcm1957M 2 Antworten Letzte Antwort
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           7811 M total memory
                                           2343 M used memory
                                           3727 M free memory
                                            121 M buffer memory
                                           1619 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  1.9G    /var/
                                  1.1G    /var/log
                                  619M    /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.15
                                  javascript:     7.7.0
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        10033
                                  States:         10104
                                  Pending Updates: 0
                                  Jey CeeJ Online
                                  Jey CeeJ Online
                                  Jey Cee
                                  @teletapi das ist gut zu wissen. Der discovery adapter ist als dependency eingetragen und sollte so bei bedarf mit installiert werden, falls er nich da ist. Gestartet wird er Automatisch wenn er nicht läuft.
                                  Da muss ich also noch zusätzlich Warnmeldungen einbauen.
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             7811 M total memory
                                             2343 M used memory
                                             3727 M free memory
                                              121 M buffer memory
                                             1619 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.9G    /var/
                                    1.1G    /var/log
                                    619M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.13.15
                                    javascript:     7.7.0
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        10033
                                    States:         10104
                                    Pending Updates: 0
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @teletapi said in Net-Tools update auf 1.0.1 Fehler:
                                    Ping und net-tools sollten sich in keiner Weise gegenseitig beeinflussen.
                                    Da meines Wissens nach net-tools die Funktion(en) des discovery Adapters zur Gerätesuche verwendet ist dieses Verhalten logisch erklärbar. Genau aus diesem Grunde setzt ja net-tools auch die INstallation von discovery voraus.
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • mcm1957M mcm1957
                                      teletapiT Online
                                      teletapiT Online
                                      teletapi
                                      @mcm57 Das war mir natürlich so nicht ganz bewusst und hab ich erst im Nachgang einigermaßen verstanden. Die Fehler die dann dabei entstehen versteh ich halt nicht...... Wie ich sovieles noch immer nicht verstehe was alle Adapter,abhängigkeiten usw. angeht. Da bin ich ganz auf euer aller Hilfe angewiesen
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        Ja passt schon.
                                        Jey-Cee wird sich die Fehler garantiert zeitnahe ansehen.
                                        • Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          @mcm57 danke das du es noch mal etwas klarer Formuliert hast.
                                          Selbstverständlich schaue ich mir das an.
