  2. English
  3. Development
  4. New Adapter - Soliscloud
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.7k Aufrufe 9 Beobachtet
  • S Schneider_Helmut
    @trixx
    Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
    Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
    M TM Offline
    M TM Offline
    M T
    Hallo
    Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
    @schneider_helmut said in New Adapter - Soliscloud:
    @trixx
    mcm1957M M TM 2 Antworten Letzte Antwort
    • M TM M T
      Hallo
      @trixx
      mcm1957M Offline
      mcm1957M Offline
      mcm1957
      @m-t said in New Adapter - Soliscloud:
      Hallo
      Können sie bitte einen Bild hochladen .........
      This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      M TM 1 Antwort Letzte Antwort
      • mcm1957M mcm1957
        Hallo
        M TM Offline
        M TM Offline
        M T
        Can you give me a screenshot of the app settings? how to enter the data
        @mcm57 said in New Adapter - Soliscloud:
        Hallo
        • M TM M T
          Hallo
          @trixx
          M TM Offline
          M TM Offline
          M T
          Can you tell me what data I need to enter??
          Hallo
          @trixx
          • M TM M T
            Hallo
            @trixx
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            @m-t
            Did you follow the instructions at README.md (https://github.com/Trixx34/ioBroker.SolisCloud?tab=readme-ov-file#soliscloud-adapter-for-iobroker) ? Looks like that getting the required data is decribed there.
            What information do you miss in detail?
            • mcm1957M mcm1957
              @m-t
              M TM Offline
              M TM Offline
              M T
              I'm concerned about which data and where should I enter it?
              IMG_4452.jpeg @mcm57 said in New Adapter - Soliscloud:
              @m-t
              • M TM M T
                @m-t
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                @m-t
                As your screenshot shows there is exactly one field for api key and one filed for the api secret at the first line.
                Did you try to enter them there?
                Or did I misunderstand your question.
                What cocerns do you have?
                • mcm1957M mcm1957
                  @m-t
                  M TM Offline
                  M TM Offline
                  M T
                  @m-t
                  I use iobroker which data I have to enter where so that I can establish a connection
                  TrixxT 1 Antwort Letzte Antwort
                  • M TM M T
                    @m-t
                    TrixxT Offline
                    TrixxT Offline
                    Trixx
                    @m-t
                    Hi!
                    What you show in your screenshot should work.
                    You will also need to add a specific interval that's used between each API call. (Between 45 & 1800 seconds).
                    Unrelated remark: I noticed I've left some test code in the last release that logs an error every time the api is polled. This will show "This is the error" in the logging. This can be ignored, I'll push a new version during the weekend that fixes this.
                    Regards,
                    T
                    • TrixxT Trixx
                      @m-t
                      Hi!
                      Regards,
                      T
                      M TM Offline
                      M TM Offline
                      M T
                      @trixx said in New Adapter - Soliscloud:
                      @m-t
                      Hi!
                      Regards,
                      T
                      The connection is established! Excellent ! Can't you shorten the polling time by 0-1800?
                      • M TM M T
                        @m-t
                        Hi!
                        Regards,
                        T
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @m-t
                        Cloud access MUST have a reasonable minimum Intervall. Otherwise cloud service might ve overliaded an access might be blocked for all ioBroker users. So a minimum of 0bis definitly too low and would not be accepted at repository.
                        G 1 Antwort Letzte Antwort
                        • TrixxT Trixx
                          @luapsi
                          Hi !
                          Sorry for the long delay. I had some stuff going on that I needed to handle first...
                          I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                          Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                          With that I should be able to map the values you requested.
                          Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                          Happy holidays !
                          Regards,
                          Trixx
                          Luapsi
                          @trixx
                          Thank you for the implementation and your commitment.
                          Update carried out.
                          My adapter version is 1.4.0.
                          What settings can I make to support you?
                          greeting
                          Luapsi
                          • mcm1957M mcm1957
                            @m-t
                            gabylein
                            Hy
                            installed it V1.4.1 - but getting no value from the cloud.
                            get this error
                            Instance:
                            Objects:
                            What is the right way to get the Information from the Cloud ?
                            greatings
                            gabylein
                            • G gabylein
                              Hy
                              get this error
                              Instance:
                              Objects:
                              greatings
                              gabylein
                              TrixxT Offline
                              TrixxT Offline
                              Trixx
                              @gabylein
                              Hi !
                              Do you see more info if you set the logging level to debug ? The configuration seems right.
                              It should show what is returned from the different api calls.
                              • TrixxT Trixx
                                @gabylein
                                Hi !
                                gabylein
                                schrieb am zuletzt editiert von gabylein
                                Its running
                                all the time I call directly this link ..
                                https://www.soliscloud.com/#/station/inverter/inverterdetail?id=xxxxxxxxxxxxxxxxxxxxxxxx&stationId=xxxxxxxxxxxxxxxxxxx
                                there is a mistake * Station ID is not Inverter ID :-)
                                running now
                                gabylein
                                  meikel
                                  First of all, great work 👍 . The adapter works perfectly and provides reliable data.
                                  If adjustments are made to the data points in the future, I would find the "total yield" value very interesting for further evaluations.
                                  Regards
                                    Mirtl
                                    @Trixx
                                    Is it possible for you to integrate these?
                                    • iDC1 Current
                                    • iDC2 Current
                                    • iDC3 Current
                                    • iCD4 Current
                                    • uDC1 Voltage
                                    • uDC2 Voltage
                                    • uDC3 Voltage
                                    • uDC4 Voltage
                                    • pDC1 Power
                                    • pDC2 Power
                                    • pDC3 Power
                                    • pDC4 Power
                                    Thank you very much in advance!
                                    Mirtl
                                    • M Mirtl
                                      @Trixx
                                      • iDC1 Current
                                      • iDC2 Current
                                      • iDC3 Current
                                      • iCD4 Current
                                      • uDC1 Voltage
                                      • uDC2 Voltage
                                      • uDC3 Voltage
                                      • uDC4 Voltage
                                      • pDC1 Power
                                      • pDC2 Power
                                      • pDC3 Power
                                      • pDC4 Power
                                      Mirtl
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @trixx
                                      You archived the repo ioBroker.soliscloud.
                                      Please let us lnow if hhe adapter is nonlonger worki g due tp some cganges at the solis website or if you just do not have time or interrest to makntain it any further.
                                      If the later is valud please consider movi g itvinto iobroker-community-adapters.This wpukd ne only a few clicks for you. Transfer ownership of repo to me (mcm1957) would be sufficient. I can do the rest.
                                      Thanks for your feedback
                                      Mcm1956
                                      Edit
                                      https://github.com/iobroker-community-adapters/info?tab=readme-ov-file#ask-to-move-your-repository-to-iobroker-community-adapters
                                      des ribes the steps to initiate a transfer
                                      • H Offline
                                        Honnkoponko
                                        @Trixx
                                        Is it possible to implement Inverter Control as on Home Assistant?
                                        Energy Storage Control Switch
                                        Overdischarge SOC
                                        Force Charge SOC
                                        Backup SOC
                                        Or does anyone knows how to control and monitor those values via Iobroker?
                                        • H Honnkoponko
                                          @Trixx
                                          Overdischarge SOC
                                          Force Charge SOC
                                          Backup SOC
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          @honnkoponko
                                          This adapter is no longer maintained. I do not have any information WHY it was archived.
                                          IF the adpater is still working (and change by solis cloud etc.) is the reason to stop maintaining this adapter we could move it to iobroker-community-area so that at least base maintainance can be provided. Adding new features is always possible but depends on available developers.
                                          Please let me know if adapter is still working and if you eventually would help testing after migration to iobroker-community-area.
                                          (Please ping me again if I miss any answer)
