  2. English
  3. Development
  4. New Adapter - Soliscloud
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.7k Aufrufe 9 Beobachtet
  • mcm1957M mcm1957
    @m-t
    As your screenshot shows there is exactly one field for api key and one filed for the api secret at the first line.
    Did you try to enter them there?
    Or did I misunderstand your question.
    What cocerns do you have?
    M TM Offline
    M TM Offline
    M T
    @mcm57 said in New Adapter - Soliscloud:
    @m-t
    I use iobroker which data I have to enter where so that I can establish a connection
    TrixxT 1 Antwort Letzte Antwort
    • M TM M T
      @m-t
      TrixxT Offline
      TrixxT Offline
      Trixx
      @m-t
      Hi!
      What you show in your screenshot should work.
      You will also need to add a specific interval that's used between each API call. (Between 45 & 1800 seconds).
      Unrelated remark: I noticed I've left some test code in the last release that logs an error every time the api is polled. This will show "This is the error" in the logging. This can be ignored, I'll push a new version during the weekend that fixes this.
      Regards,
      T
      M TM 1 Antwort Letzte Antwort
      • TrixxT Trixx
        @m-t
        Hi!
        Regards,
        T
        M TM Offline
        M TM Offline
        M T
        @trixx said in New Adapter - Soliscloud:
        @m-t
        Hi!
        Regards,
        T
        The connection is established! Excellent ! Can't you shorten the polling time by 0-1800?
        • M TM M T
          @m-t
          Hi!
          Regards,
          T
          mcm1957M Offline
          mcm1957M Offline
          mcm1957
          @m-t
          Cloud access MUST have a reasonable minimum Intervall. Otherwise cloud service might ve overliaded an access might be blocked for all ioBroker users. So a minimum of 0bis definitly too low and would not be accepted at repository.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          G 1 Antwort Letzte Antwort
          • TrixxT Trixx
            @luapsi
            Hi !
            Sorry for the long delay. I had some stuff going on that I needed to handle first...
            I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
            Could you try this version, enable the logging and send me a copy of the logging for the api call ?
            With that I should be able to map the values you requested.
            Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
            Happy holidays !
            Regards,
            Trixx
            Luapsi
            @trixx
            Thank you for the implementation and your commitment.
            Update carried out.
            My adapter version is 1.4.0.
            What settings can I make to support you?
            greeting
            Luapsi
            • mcm1957M mcm1957
              @m-t
              gabylein
              Hy
              installed it V1.4.1 - but getting no value from the cloud.
              get this error
              Instance:
              Objects:
              What is the right way to get the Information from the Cloud ?
              greatings
              gabylein
              • G gabylein
                Hy
                get this error
                Instance:
                Objects:
                greatings
                gabylein
                TrixxT Offline
                TrixxT Offline
                Trixx
                @gabylein
                Hi !
                Do you see more info if you set the logging level to debug ? The configuration seems right.
                It should show what is returned from the different api calls.
                • TrixxT Trixx
                  @gabylein
                  Hi !
                  gabylein
                  schrieb am zuletzt editiert von gabylein
                  Its running
                  all the time I call directly this link ..
                  https://www.soliscloud.com/#/station/inverter/inverterdetail?id=xxxxxxxxxxxxxxxxxxxxxxxx&stationId=xxxxxxxxxxxxxxxxxxx
                  there is a mistake * Station ID is not Inverter ID :-)
                  running now
                  gabylein
                    meikel
                    First of all, great work 👍 . The adapter works perfectly and provides reliable data.
                    If adjustments are made to the data points in the future, I would find the "total yield" value very interesting for further evaluations.
                    Regards
                      Mirtl
                      @Trixx
                      Is it possible for you to integrate these?
                      • iDC1 Current
                      • iDC2 Current
                      • iDC3 Current
                      • iCD4 Current
                      • uDC1 Voltage
                      • uDC2 Voltage
                      • uDC3 Voltage
                      • uDC4 Voltage
                      • pDC1 Power
                      • pDC2 Power
                      • pDC3 Power
                      • pDC4 Power
                      Thank you very much in advance!
                      Mirtl
                      • M Mirtl
                        @Trixx
                        • iDC1 Current
                        • iDC2 Current
                        • iDC3 Current
                        • iCD4 Current
                        • uDC1 Voltage
                        • uDC2 Voltage
                        • uDC3 Voltage
                        • uDC4 Voltage
                        • pDC1 Power
                        • pDC2 Power
                        • pDC3 Power
                        • pDC4 Power
                        Mirtl
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @trixx
                        You archived the repo ioBroker.soliscloud.
                        Please let us lnow if hhe adapter is nonlonger worki g due tp some cganges at the solis website or if you just do not have time or interrest to makntain it any further.
                        If the later is valud please consider movi g itvinto iobroker-community-adapters.This wpukd ne only a few clicks for you. Transfer ownership of repo to me (mcm1957) would be sufficient. I can do the rest.
                        Thanks for your feedback
                        Mcm1956
                        Edit
                        https://github.com/iobroker-community-adapters/info?tab=readme-ov-file#ask-to-move-your-repository-to-iobroker-community-adapters
                        des ribes the steps to initiate a transfer
                        • H Offline
                          Honnkoponko
                          @Trixx
                          Is it possible to implement Inverter Control as on Home Assistant?
                          Energy Storage Control Switch
                          Overdischarge SOC
                          Force Charge SOC
                          Backup SOC
                          Or does anyone knows how to control and monitor those values via Iobroker?
                          • H Honnkoponko
                            @Trixx
                            Overdischarge SOC
                            Force Charge SOC
                            Backup SOC
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            @honnkoponko
                            This adapter is no longer maintained. I do not have any information WHY it was archived.
                            IF the adpater is still working (and change by solis cloud etc.) is the reason to stop maintaining this adapter we could move it to iobroker-community-area so that at least base maintainance can be provided. Adding new features is always possible but depends on available developers.
                            Please let me know if adapter is still working and if you eventually would help testing after migration to iobroker-community-area.
                            (Please ping me again if I miss any answer)
