  2. English
  3. Development
  4. New Adapter - Soliscloud
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.7k Aufrufe 9 Beobachtet
  • TrixxT Trixx
    @luapsi said in New Adapter - Soliscloud:
    @trixx sagte in New Adapter - Soliscloud:
    battery_current_usage
    hi @trixx,
    The SolisCloud adapter also works for me. Thank you for your implementation.
    As you requested, it would be great if these values ​​could be added:
    from the Power Station List:
    1. batteryTodayDischargeEnergy
    2. batteryTodayChargeEnergy
    3. homeLoadTodayEnergy
    4. state
    5. oneSelf
    from the Inverter List:
    1. eToday
    2. etodayStr
    3. state
    Gerne teste ich für Dich!
    Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
    I'll let you know once I have an update on this.
    Luapsi
    schrieb am zuletzt editiert von Luapsi
    Hi @trixx,
    all data fields are correct.
    Thanks for the quick and professional work.
    from the v1/api/InverterDetail:
    1. familyLoadPower
    2. familyLoadPowerStr
    3. id inverter id
    4. sn inverter sn
    5. iAc1 AC current R
    6. iAc2 AC current S
    7. iAc3 AC current T
    8. uAc1 AC voltage R
    9. uAc2 AC voltage S
    10. uAc3 AC voltage T
    11. inverterTemperature
    12. batteryPower
    13. batterypowerStr
    14. batteryPowerPec
    15. batteryTodayChargeEnergy
    16. batteryTodayChargeEnergyStr
    17. batteryMonthChargeEnergy
    18. batteryMonthChargeEnergyStr
    19. batteryYearChargeEnergy
    20. batteryYearChargeEnergyStr
    21. batteryTotalChargeEnergy
    22. batteryTotalChargeEnergyStr
    23. batteryTodayDischargeEnergy
    24. batteryTodayDischargeEnergyStr
    25. batteryMonthDischargeEnergy
    26. batteryMonthDischargeEnergyStr
    27. batteryYearDischargeEnergy
    28. batteryYearDischargeEnergyStr
    29. batteryTotalDischargeEnergy
    30. batteryTotalDischargeEnergyStr
    another note about the data structure:
    Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
    • Power Station List (v1/api/userStationList)
    • Power Station Detail (v1/api/stationDetail)
    • Datalogger List (v1/api/collectorList)
    • Data logger details (v1/api/collectorDetail)
    Inverter List (v1/api/inverterList)
    • Inverter details (v1/api/inverterDetail)
      possible!
    If I can support you here, please let me know.
    Greetings from Saxony
    PS: the app currently available from Solis cannot be used in this way.
    TrixxT 1 Antwort Letzte Antwort
    • L Luapsi
      Hi @trixx,
      1. familyLoadPower
      3. id inverter id
      4. sn inverter sn
      12. batteryPower
      13. batterypowerStr
      14. batteryPowerPec
        possible!
      TrixxT Offline
      TrixxT Offline
      Trixx
      @luapsi
      I've pushed another version to github.
      The values are split up between the inverter & station details, for the values I did have to switch some things.
      The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
      I still have a few more to add and need to adjust some units .
      I'll try to get to those later today or later this week.
      Regards,
      Trixx
      L 1 Antwort Letzte Antwort
      • TrixxT Trixx
        @luapsi
        Regards,
        Trixx
        Luapsi
        @trixx
        Thank you for your enthusiasm and commitment!
        For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
        Let me know if there is any news.
        Greetings Sven
        • L Luapsi
          @trixx
          Greetings Sven
          Luapsi
          @Trixx
          The problem with the API is solved.
          An additional group is still needed :)
          Is it possible for you to integrate these?
          is needed to calculate data!
          Thank you very much in advance!
          from v1/api/epmDetail:
          1. state
          2. iAc1 Current U
          3. iAc2 Current V
          4. iAc3 Current W
          5. uAc1 Voltage U
          6. uAc2 Voltage V
          7. uAc3 Voltage W
          8. pAc1 Power U
          9. pAc2 Power V
          10. pAc3 Power W
          11. facMeter
          12. pEpmTotal
          13. pEpmTotalStr
          14. eTotalBuy
          15. eTotalBayStr
          16. eTotalSell
          17. etotalSellStr
          Thanks
          TrixxT 2 Antworten Letzte Antwort
          • L Luapsi
            @Trixx
            1. state
            2. iAc1 Current U
            3. iAc2 Current V
            4. iAc3 Current W
            5. uAc1 Voltage U
            6. uAc2 Voltage V
            7. uAc3 Voltage W
            8. pAc1 Power U
            9. pAc2 Power V
            10. pAc3 Power W
            11. facMeter
            12. pEpmTotal
            13. pEpmTotalStr
            14. eTotalBuy
            15. eTotalBayStr
            16. eTotalSell
            17. etotalSellStr
            Thanks
            TrixxT Offline
            TrixxT Offline
            Trixx
            @luapsi
            I'll see what I can do !
            • L Luapsi
              @Trixx
              1. state
              2. iAc1 Current U
              3. iAc2 Current V
              4. iAc3 Current W
              5. uAc1 Voltage U
              6. uAc2 Voltage V
              7. uAc3 Voltage W
              8. pAc1 Power U
              9. pAc2 Power V
              10. pAc3 Power W
              11. facMeter
              12. pEpmTotal
              13. pEpmTotalStr
              14. eTotalBuy
              15. eTotalBayStr
              16. eTotalSell
              17. etotalSellStr
              Thanks
              TrixxT Offline
              TrixxT Offline
              Trixx
              @luapsi
              Sorry for the delayed response. I've taken a look at this, it should be possible to add to the adapter. But I don't have anything in the EPM result for my plant so i'll try to create this based on the documentation.
              I do have some IRL things to take care of this week, so it might be a few days before I get to this.
              Regards,
              Trixx
              • TrixxT Offline
                TrixxT Offline
                Trixx
                schrieb am zuletzt editiert von Trixx
                @luapsi
                Hi !
                Sorry for the long delay. I had some stuff going on that I needed to handle first...
                I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                With that I should be able to map the values you requested.
                Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                Happy holidays !
                Regards,
                Trixx
                • S Schneider_Helmut
                  @trixx
                  Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                  Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                  M TM Offline
                  M TM Offline
                  M T
                  Hallo
                  Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
                  @schneider_helmut said in New Adapter - Soliscloud:
                  @trixx
                  mcm1957M M TM 2 Antworten Letzte Antwort
                  • M TM M T
                    Hallo
                    @trixx
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    @m-t said in New Adapter - Soliscloud:
                    Hallo
                    Können sie bitte einen Bild hochladen .........
                    This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    M TM 1 Antwort Letzte Antwort
                    • mcm1957M mcm1957
                      Hallo
                      M TM Offline
                      M TM Offline
                      M T
                      Can you give me a screenshot of the app settings? how to enter the data
                      @mcm57 said in New Adapter - Soliscloud:
                      Hallo
                      • M TM M T
                        Hallo
                        @trixx
                        M TM Offline
                        M TM Offline
                        M T
                        Can you tell me what data I need to enter??
                        Hallo
                        @trixx
                        • M TM M T
                          Hallo
                          @trixx
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          @m-t
                          Did you follow the instructions at README.md (https://github.com/Trixx34/ioBroker.SolisCloud?tab=readme-ov-file#soliscloud-adapter-for-iobroker) ? Looks like that getting the required data is decribed there.
                          What information do you miss in detail?
                          • mcm1957M mcm1957
                            @m-t
                            M TM Offline
                            M TM Offline
                            M T
                            I'm concerned about which data and where should I enter it?
                            IMG_4452.jpeg @mcm57 said in New Adapter - Soliscloud:
                            @m-t
                            • M TM M T
                              @m-t
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @m-t
                              As your screenshot shows there is exactly one field for api key and one filed for the api secret at the first line.
                              Did you try to enter them there?
                              Or did I misunderstand your question.
                              What cocerns do you have?
                              • mcm1957M mcm1957
                                @m-t
                                M TM Offline
                                M TM Offline
                                M T
                                @m-t
                                I use iobroker which data I have to enter where so that I can establish a connection
                                • M TM M T
                                  @m-t
                                  TrixxT Offline
                                  TrixxT Offline
                                  Trixx
                                  @m-t
                                  Hi!
                                  What you show in your screenshot should work.
                                  You will also need to add a specific interval that's used between each API call. (Between 45 & 1800 seconds).
                                  Unrelated remark: I noticed I've left some test code in the last release that logs an error every time the api is polled. This will show "This is the error" in the logging. This can be ignored, I'll push a new version during the weekend that fixes this.
                                  Regards,
                                  T
                                  • TrixxT Trixx
                                    @m-t
                                    Hi!
                                    Regards,
                                    T
                                    M TM Offline
                                    M TM Offline
                                    M T
                                    @trixx said in New Adapter - Soliscloud:
                                    @m-t
                                    Hi!
                                    Regards,
                                    T
                                    The connection is established! Excellent ! Can't you shorten the polling time by 0-1800?
                                    • M TM M T
                                      @m-t
                                      Hi!
                                      Regards,
                                      T
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @m-t
                                      Cloud access MUST have a reasonable minimum Intervall. Otherwise cloud service might ve overliaded an access might be blocked for all ioBroker users. So a minimum of 0bis definitly too low and would not be accepted at repository.
                                      G 1 Antwort Letzte Antwort
                                      • TrixxT Trixx
                                        @luapsi
                                        Hi !
                                        Happy holidays !
                                        Regards,
                                        Trixx
                                        Luapsi
                                        @trixx
                                        Thank you for the implementation and your commitment.
                                        Update carried out.
                                        My adapter version is 1.4.0.
                                        What settings can I make to support you?
                                        greeting
                                        Luapsi
                                        • mcm1957M mcm1957
                                          @m-t
                                          gabylein
                                          Hy
                                          installed it V1.4.1 - but getting no value from the cloud.
                                          get this error
                                          Instance:
                                          Objects:
                                          What is the right way to get the Information from the Cloud ?
                                          greatings
                                          gabylein
