  2. English
  3. Development
  4. New Adapter - Soliscloud
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.7k Aufrufe 9 Beobachtet
  • L Luapsi
    @trixx
    I am also interested in the “Soliscloud” adapter.
    The installation was successful, unfortunately I can't get any further with the settings so that access to the SolisCloud is possible.
    No SolisCloud is displayed in the instances, but that's okay in the objects?
    I have already activated the Solis API.
    I have only recently started using ioBroker.
    Thk Sven
    TrixxT Offline
    TrixxT Offline
    Trixx
    @luapsi
    Thanks for trying my adapter. Once the install from github is completed, you should now be able to find the solis adapter in the "adapters" screen.
    From there you should be able to add an instance of the adapter to your ioBroker installation. Once the instance is installed, it will take you directly to the configuration screen.
    • L Luapsi
      @trixx
      Thk Sven
      @luapsi sagte in New Adapter - Soliscloud:
      that is the regular behavior by installing via github.
      The instance has to be added manually
      L 1 Antwort Letzte Antwort
        Luapsi
        Hello, I just found it in the documentation.
        Thank you very much:)
        • TrixxT Trixx
          I've created an adapter to read data from the API of soliscloud.com.
          The adapter can be installed in the expert settings / Custom.
          https://github.com/Trixx34/ioBroker.soliscloud
          At the moment it reads and stores the following values:
          • battery_current_usage
          • battery_percent
          • bought_Today
          • consumption_Today
          • current_Consumption
          • current_From_Net
          • current_Power
          • generated_Today
          • sold_Today
            More values can be added if people are interested. I'll link the documentation to what's available.
            Edit; The api information with all values is available >HERE<
          To use the API, you do need to request access trough suppport (service@ginlong.com).
          Once API access is enabled:
          • Go to https://www.soliscloud.com/#/apiManage.
          • Activate API management and agree with the usage conditions.
          • After activation, click on view key tot get a pop-up window asking for the verification code.
          • First click on "Verification code" after which you get an image with 2 puzzle pieces, which you need to overlap each other using the slider below.
          • After that, you will receive an email with the verification code you need to enter (within 60 seconds).
          • Once confirmed, you get the API ID, secret and API URL
          The configuration needs the API ID / API secret / PlantID to work, a polling interval also needs to be configured.
          All comments and feedback welcome.
          Luapsi
          @trixx sagte in New Adapter - Soliscloud:
          hi @trixx,
          The SolisCloud adapter also works for me. Thank you for your implementation.
          As you requested, it would be great if these values ​​could be added:
          from the Power Station List:
          1. batteryTodayDischargeEnergy
          2. batteryTodayChargeEnergy
          3. homeLoadTodayEnergy
          4. state
          5. oneSelf
          from the Inverter List:
          1. eToday
          2. etodayStr
          3. state
          Gerne teste ich für Dich!
          TrixxT 1 Antwort Letzte Antwort
          • L Luapsi
            hi @trixx,
            4. state
            5. oneSelf
            1. eToday
            2. etodayStr
            3. state
            TrixxT Offline
            TrixxT Offline
            Trixx
            @luapsi said in New Adapter - Soliscloud:
            hi @trixx,
            4. state
            5. oneSelf
            1. eToday
            2. etodayStr
            3. state
            Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
            I'll let you know once I have an update on this.
            L 2 Antworten Letzte Antwort
            • TrixxT Trixx
              hi @trixx,
              4. state
              5. oneSelf
              1. eToday
              2. etodayStr
              3. state
              Luapsi
              @trixx
              hi @Trixx
              thank you for taking the suggestions!
              Here's a little addition!
              In ioBroker, instances are assigned a category!
              Would you be so kind as to put your instance in the “Energy” category?
              Here is an excerpt from instances in this category
              Thx Sven
              • TrixxT Offline
                TrixxT Offline
                Trixx
                @luapsi
                I've just pushed a new version to github, I think it should include all requested additions :)
                Regards,
                Trixx
                • TrixxT Trixx
                  @luapsi
                  Regards,
                  Trixx
                  Luapsi
                  @trixx
                  Your performance is great, thank you very much.
                  I will test extensively and give you feedback.
                  I wish you a pleasant day
                  • TrixxT Trixx
                    hi @trixx,
                    4. state
                    5. oneSelf
                    1. eToday
                    2. etodayStr
                    3. state
                    Luapsi
                    schrieb am zuletzt editiert von Luapsi
                    Hi @trixx,
                    all data fields are correct.
                    Thanks for the quick and professional work.
                    from the v1/api/InverterDetail:
                    1. familyLoadPower
                    2. familyLoadPowerStr
                    3. id inverter id
                    4. sn inverter sn
                    5. iAc1 AC current R
                    6. iAc2 AC current S
                    7. iAc3 AC current T
                    8. uAc1 AC voltage R
                    9. uAc2 AC voltage S
                    10. uAc3 AC voltage T
                    11. inverterTemperature
                    12. batteryPower
                    13. batterypowerStr
                    14. batteryPowerPec
                    15. batteryTodayChargeEnergy
                    16. batteryTodayChargeEnergyStr
                    17. batteryMonthChargeEnergy
                    18. batteryMonthChargeEnergyStr
                    19. batteryYearChargeEnergy
                    20. batteryYearChargeEnergyStr
                    21. batteryTotalChargeEnergy
                    22. batteryTotalChargeEnergyStr
                    23. batteryTodayDischargeEnergy
                    24. batteryTodayDischargeEnergyStr
                    25. batteryMonthDischargeEnergy
                    26. batteryMonthDischargeEnergyStr
                    27. batteryYearDischargeEnergy
                    28. batteryYearDischargeEnergyStr
                    29. batteryTotalDischargeEnergy
                    30. batteryTotalDischargeEnergyStr
                    another note about the data structure:
                    Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
                    • Power Station List (v1/api/userStationList)
                    • Power Station Detail (v1/api/stationDetail)
                    • Datalogger List (v1/api/collectorList)
                    • Data logger details (v1/api/collectorDetail)
                    Inverter List (v1/api/inverterList)
                    • Inverter details (v1/api/inverterDetail)
                      possible!
                    If I can support you here, please let me know.
                    Greetings from Saxony
                    PS: the app currently available from Solis cannot be used in this way.
                    • L Luapsi
                      Hi @trixx,
                      1. familyLoadPower
                      3. id inverter id
                      4. sn inverter sn
                      12. batteryPower
                      13. batterypowerStr
                      14. batteryPowerPec
                        possible!
                      TrixxT Offline
                      TrixxT Offline
                      Trixx
                      @luapsi
                      I've pushed another version to github.
                      The values are split up between the inverter & station details, for the values I did have to switch some things.
                      The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
                      I still have a few more to add and need to adjust some units .
                      I'll try to get to those later today or later this week.
                      Regards,
                      Trixx
                      • TrixxT Trixx
                        @luapsi
                        Regards,
                        Trixx
                        Luapsi
                        @trixx
                        Thank you for your enthusiasm and commitment!
                        For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
                        Let me know if there is any news.
                        Greetings Sven
                        • L Luapsi
                          @trixx
                          Greetings Sven
                          Luapsi
                          @Trixx
                          The problem with the API is solved.
                          An additional group is still needed :)
                          Is it possible for you to integrate these?
                          is needed to calculate data!
                          Thank you very much in advance!
                          from v1/api/epmDetail:
                          1. state
                          2. iAc1 Current U
                          3. iAc2 Current V
                          4. iAc3 Current W
                          5. uAc1 Voltage U
                          6. uAc2 Voltage V
                          7. uAc3 Voltage W
                          8. pAc1 Power U
                          9. pAc2 Power V
                          10. pAc3 Power W
                          11. facMeter
                          12. pEpmTotal
                          13. pEpmTotalStr
                          14. eTotalBuy
                          15. eTotalBayStr
                          16. eTotalSell
                          17. etotalSellStr
                          Thanks
                          TrixxT 2 Antworten Letzte Antwort
                          • L Luapsi
                            @Trixx
                            1. state
                            2. iAc1 Current U
                            3. iAc2 Current V
                            4. iAc3 Current W
                            5. uAc1 Voltage U
                            6. uAc2 Voltage V
                            7. uAc3 Voltage W
                            8. pAc1 Power U
                            9. pAc2 Power V
                            10. pAc3 Power W
                            11. facMeter
                            12. pEpmTotal
                            13. pEpmTotalStr
                            14. eTotalBuy
                            15. eTotalBayStr
                            16. eTotalSell
                            17. etotalSellStr
                            Thanks
                            TrixxT Offline
                            TrixxT Offline
                            Trixx
                            @luapsi
                            I'll see what I can do !
                            • L Luapsi
                              @Trixx
                              1. state
                              2. iAc1 Current U
                              3. iAc2 Current V
                              4. iAc3 Current W
                              5. uAc1 Voltage U
                              6. uAc2 Voltage V
                              7. uAc3 Voltage W
                              8. pAc1 Power U
                              9. pAc2 Power V
                              10. pAc3 Power W
                              11. facMeter
                              12. pEpmTotal
                              13. pEpmTotalStr
                              14. eTotalBuy
                              15. eTotalBayStr
                              16. eTotalSell
                              17. etotalSellStr
                              Thanks
                              TrixxT Offline
                              TrixxT Offline
                              Trixx
                              @luapsi
                              Sorry for the delayed response. I've taken a look at this, it should be possible to add to the adapter. But I don't have anything in the EPM result for my plant so i'll try to create this based on the documentation.
                              I do have some IRL things to take care of this week, so it might be a few days before I get to this.
                              Regards,
                              Trixx
                              • TrixxT Offline
                                TrixxT Offline
                                Trixx
                                schrieb am zuletzt editiert von Trixx
                                @luapsi
                                Hi !
                                Sorry for the long delay. I had some stuff going on that I needed to handle first...
                                I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                                Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                                With that I should be able to map the values you requested.
                                Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                                Happy holidays !
                                Regards,
                                Trixx
                                • S Schneider_Helmut
                                  @trixx
                                  Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                                  Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                                  M TM Offline
                                  M TM Offline
                                  M T
                                  Hallo
                                  Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
                                  @schneider_helmut said in New Adapter - Soliscloud:
                                  @trixx
                                  mcm1957M M TM 2 Antworten Letzte Antwort
                                  • M TM M T
                                    Hallo
                                    @trixx
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @m-t said in New Adapter - Soliscloud:
                                    Hallo
                                    Können sie bitte einen Bild hochladen .........
                                    This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    M TM 1 Antwort Letzte Antwort
                                    • mcm1957M mcm1957
                                      Hallo
                                      M TM Offline
                                      M TM Offline
                                      M T
                                      Can you give me a screenshot of the app settings? how to enter the data
                                      @mcm57 said in New Adapter - Soliscloud:
                                      Hallo
                                      • M TM M T
                                        Hallo
                                        @trixx
                                        M TM Offline
                                        M TM Offline
                                        M T
                                        Can you tell me what data I need to enter??
                                        Hallo
                                        @trixx
                                        • M TM M T
                                          Hallo
                                          @trixx
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @m-t
                                          Did you follow the instructions at README.md (https://github.com/Trixx34/ioBroker.SolisCloud?tab=readme-ov-file#soliscloud-adapter-for-iobroker) ? Looks like that getting the required data is decribed there.
                                          What information do you miss in detail?
