  2. English
  3. Development
  4. New Adapter - Soliscloud
Geplant Angeheftet Gesperrt Verschoben Development
57 Beiträge 10 Kommentatoren 24.7k Aufrufe 9 Beobachtet
  • S Schneider_Helmut
    @Trixx
    If I want to install the adapter over this link
    https://github.com/Trixx34/ioBroker.SolisCloud
    I get this error message:
    ERROR: Process exited with code 25
    Siobroker url https://github. com/Trixx34/ioBroker SolisCloud --host raspberrypi debug install Trixx34/ioBroker.SolisCloud#b39242521a5f9f1b7eee929cc658b9b1c4af0f70
    NPM version: 8.19.4
    Installing Trixx34/ioBroker. SolisCloud#b39242521a5f9f1b7eee929cc6589b1c4af0170... (System call) npm WARN skipping integrity check for git dependency ssh://git@github.com/Trixx34/ioBroker.SolisCloud.git
    added 76 packages in 1m126 packages are looking for funding run npm fund for details
    pm WARN skipping integrity check for git dependency ssh://git@github.com/Trixx34/ioBroker SolisCloud git host.raspberrypi
    Cannot install Trixx34/ioBroker. SolisCloud#b39242521a5f9f1b7eee929cc658b9b1c4af0f70: 0
    MOD-EDIT: added code tags!
    mcm1957M Offline
    mcm1957M Offline
    mcm1957
    @schneider_helmut
    @Trixx
    I tried now and the installation worked as expected (I did not test the functionality).
    BUT a look at the console output look a little supect:
    For me, there seems to be a SPACE between the dot and the S of SolisCloud. Please retry and check your input.
    I do not think that capital letters cause a problem here, as urls are case insensitive.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • mcm1957M mcm1957
      @schneider_helmut
      @Trixx
      @mcm57 sagte in New Adapter - Soliscloud:
      @schneider_helmut sagte in New Adapter - Soliscloud:
      here it is, too!
      • TrixxT Trixx
        @schneider_helmut said in New Adapter - Soliscloud:
        @Trixx
        Could you try using: https://github.com/Trixx34/ioBroker.soliscloud (without caps).
        Schneider_Helmut
        schrieb am zuletzt editiert von Schneider_Helmut
        @trixx
        Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
        Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
        TrixxT M TM 2 Antworten Letzte Antwort
          @trixx
          TrixxT Offline
          TrixxT Offline
          Trixx
          @Schneider_Helmut
          Good to hear everything is working now for you!
          You're correct on the information regarding the plant ID, I'll update the documentation to make that more clear.
          If there's any value you are missing and would like to have available in in ioBroker, let me know and I'll see what I can do!
          Regards,
          Trixx
          • TrixxT Trixx
            @Schneider_Helmut
            Regards,
            Trixx
            Schneider_Helmut
            @trixx
            I really appreciate your support. Your adapter will be very useful to Solis as people increasingly want to network systems. I can't understand why manufacturers don't make an effort to open up to common automation solutions and offer adapters themselves. For example, I have been looking for a wallbox for months where the manufacturer offers an IoBroker adapter with which I can start charging via IO-Broker and specify the charging current for the car myself.
            And I still did not find one.
            TrixxT 1 Antwort Letzte Antwort
              @trixx
              TrixxT Offline
              TrixxT Offline
              Trixx
              schrieb am zuletzt editiert von Trixx
              The latest version on github is broken, I broke it while trying to fix something else...
              I'll try fixing this tonight.
              Edit; small fix. Already ok again
              L 1 Antwort Letzte Antwort
              • TrixxT Trixx
                Luapsi
                @trixx
                I am also interested in the “Soliscloud” adapter.
                The installation was successful, unfortunately I can't get any further with the settings so that access to the SolisCloud is possible.
                No SolisCloud is displayed in the instances, but that's okay in the objects?
                I have already activated the Solis API.
                I have only recently started using ioBroker.
                Thk Sven
                TrixxT HomoranH 2 Antworten Letzte Antwort
                • L Luapsi
                  @trixx
                  Thk Sven
                  TrixxT Offline
                  TrixxT Offline
                  Trixx
                  @luapsi
                  Thanks for trying my adapter. Once the install from github is completed, you should now be able to find the solis adapter in the "adapters" screen.
                  From there you should be able to add an instance of the adapter to your ioBroker installation. Once the instance is installed, it will take you directly to the configuration screen.
                  • L Luapsi
                    @trixx
                    Thk Sven
                    @luapsi sagte in New Adapter - Soliscloud:
                    that is the regular behavior by installing via github.
                    The instance has to be added manually
                      Luapsi
                      Hello, I just found it in the documentation.
                      Thank you very much:)
                      • TrixxT Trixx
                        I've created an adapter to read data from the API of soliscloud.com.
                        The adapter can be installed in the expert settings / Custom.
                        At the moment it reads and stores the following values:
                        • battery_current_usage
                        • battery_percent
                        • bought_Today
                        • consumption_Today
                        • current_Consumption
                        • current_From_Net
                        • current_Power
                        • generated_Today
                        • sold_Today
                          More values can be added if people are interested. I'll link the documentation to what's available.
                          Edit; The api information with all values is available >HERE<
                        To use the API, you do need to request access trough suppport (service@ginlong.com).
                        Once API access is enabled:
                        • Go to https://www.soliscloud.com/#/apiManage.
                        • Activate API management and agree with the usage conditions.
                        • After activation, click on view key tot get a pop-up window asking for the verification code.
                        • First click on "Verification code" after which you get an image with 2 puzzle pieces, which you need to overlap each other using the slider below.
                        • After that, you will receive an email with the verification code you need to enter (within 60 seconds).
                        • Once confirmed, you get the API ID, secret and API URL
                        The configuration needs the API ID / API secret / PlantID to work, a polling interval also needs to be configured.
                        All comments and feedback welcome.
                        Luapsi
                        @trixx sagte in New Adapter - Soliscloud:
                        hi @trixx,
                        The SolisCloud adapter also works for me. Thank you for your implementation.
                        As you requested, it would be great if these values ​​could be added:
                        from the Power Station List:
                        1. batteryTodayDischargeEnergy
                        2. batteryTodayChargeEnergy
                        3. homeLoadTodayEnergy
                        4. state
                        5. oneSelf
                        from the Inverter List:
                        1. eToday
                        2. etodayStr
                        3. state
                        Gerne teste ich für Dich!
                        • L Luapsi
                          hi @trixx,
                          4. state
                          5. oneSelf
                          1. eToday
                          2. etodayStr
                          3. state
                          TrixxT Offline
                          TrixxT Offline
                          Trixx
                          @luapsi said in New Adapter - Soliscloud:
                          hi @trixx,
                          4. state
                          5. oneSelf
                          1. eToday
                          2. etodayStr
                          3. state
                          Thanks for the suggestions, I'll see what I can do. The first 5 shouldn't be to much work, I should be able to do that right away. The other ones require an additional API call, but still shouldn't be a problem.
                          I'll let you know once I have an update on this.
                          L 2 Antworten Letzte Antwort
                          • TrixxT Trixx
                            hi @trixx,
                            4. state
                            5. oneSelf
                            1. eToday
                            2. etodayStr
                            3. state
                            Luapsi
                            @trixx
                            hi @Trixx
                            thank you for taking the suggestions!
                            Here's a little addition!
                            In ioBroker, instances are assigned a category!
                            Would you be so kind as to put your instance in the “Energy” category?
                            Here is an excerpt from instances in this category
                            Thx Sven
                            • TrixxT Offline
                              TrixxT Offline
                              Trixx
                              @luapsi
                              I've just pushed a new version to github, I think it should include all requested additions :)
                              Regards,
                              Trixx
                              • TrixxT Trixx
                                @luapsi
                                Regards,
                                Trixx
                                Luapsi
                                @trixx
                                Your performance is great, thank you very much.
                                I will test extensively and give you feedback.
                                I wish you a pleasant day
                                • TrixxT Trixx
                                  hi @trixx,
                                  4. state
                                  5. oneSelf
                                  1. eToday
                                  2. etodayStr
                                  3. state
                                  Luapsi
                                  schrieb am zuletzt editiert von Luapsi
                                  Hi @trixx,
                                  all data fields are correct.
                                  Thanks for the quick and professional work.
                                  from the v1/api/InverterDetail:
                                  1. familyLoadPower
                                  2. familyLoadPowerStr
                                  3. id inverter id
                                  4. sn inverter sn
                                  5. iAc1 AC current R
                                  6. iAc2 AC current S
                                  7. iAc3 AC current T
                                  8. uAc1 AC voltage R
                                  9. uAc2 AC voltage S
                                  10. uAc3 AC voltage T
                                  11. inverterTemperature
                                  12. batteryPower
                                  13. batterypowerStr
                                  14. batteryPowerPec
                                  15. batteryTodayChargeEnergy
                                  16. batteryTodayChargeEnergyStr
                                  17. batteryMonthChargeEnergy
                                  18. batteryMonthChargeEnergyStr
                                  19. batteryYearChargeEnergy
                                  20. batteryYearChargeEnergyStr
                                  21. batteryTotalChargeEnergy
                                  22. batteryTotalChargeEnergyStr
                                  23. batteryTodayDischargeEnergy
                                  24. batteryTodayDischargeEnergyStr
                                  25. batteryMonthDischargeEnergy
                                  26. batteryMonthDischargeEnergyStr
                                  27. batteryYearDischargeEnergy
                                  28. batteryYearDischargeEnergyStr
                                  29. batteryTotalDischargeEnergy
                                  30. batteryTotalDischargeEnergyStr
                                  another note about the data structure:
                                  Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
                                  • Power Station List (v1/api/userStationList)
                                  • Power Station Detail (v1/api/stationDetail)
                                  • Datalogger List (v1/api/collectorList)
                                  • Data logger details (v1/api/collectorDetail)
                                  Inverter List (v1/api/inverterList)
                                  • Inverter details (v1/api/inverterDetail)
                                    possible!
                                  If I can support you here, please let me know.
                                  Greetings from Saxony
                                  PS: the app currently available from Solis cannot be used in this way.
                                  • L Luapsi
                                    Hi @trixx,
                                    1. familyLoadPower
                                    3. id inverter id
                                    4. sn inverter sn
                                    12. batteryPower
                                    13. batterypowerStr
                                    14. batteryPowerPec
                                      possible!
                                    TrixxT Offline
                                    TrixxT Offline
                                    Trixx
                                    @luapsi
                                    I've pushed another version to github.
                                    The values are split up between the inverter & station details, for the values I did have to switch some things.
                                    The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
                                    I still have a few more to add and need to adjust some units .
                                    I'll try to get to those later today or later this week.
                                    Regards,
                                    Trixx
                                    • TrixxT Trixx
                                      @luapsi
                                      Regards,
                                      Trixx
                                      Luapsi
                                      @trixx
                                      Thank you for your enthusiasm and commitment!
                                      For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
                                      Let me know if there is any news.
                                      Greetings Sven
                                      • L Luapsi
                                        @trixx
                                        Greetings Sven
                                        Luapsi
                                        @Trixx
                                        The problem with the API is solved.
                                        An additional group is still needed :)
                                        Is it possible for you to integrate these?
                                        is needed to calculate data!
                                        Thank you very much in advance!
                                        from v1/api/epmDetail:
                                        1. state
                                        2. iAc1 Current U
                                        3. iAc2 Current V
                                        4. iAc3 Current W
                                        5. uAc1 Voltage U
                                        6. uAc2 Voltage V
                                        7. uAc3 Voltage W
                                        8. pAc1 Power U
                                        9. pAc2 Power V
                                        10. pAc3 Power W
                                        11. facMeter
                                        12. pEpmTotal
                                        13. pEpmTotalStr
                                        14. eTotalBuy
                                        15. eTotalBayStr
                                        16. eTotalSell
                                        17. etotalSellStr
                                        Thanks
                                        TrixxT 2 Antworten Letzte Antwort
                                        • L Luapsi
                                          @Trixx
                                          1. state
                                          2. iAc1 Current U
                                          3. iAc2 Current V
                                          4. iAc3 Current W
                                          5. uAc1 Voltage U
                                          6. uAc2 Voltage V
                                          7. uAc3 Voltage W
                                          8. pAc1 Power U
                                          9. pAc2 Power V
                                          10. pAc3 Power W
                                          11. facMeter
                                          12. pEpmTotal
                                          13. pEpmTotalStr
                                          14. eTotalBuy
                                          15. eTotalBayStr
                                          16. eTotalSell
                                          17. etotalSellStr
                                          Thanks
                                          TrixxT Offline
                                          TrixxT Offline
                                          Trixx
                                          @luapsi
                                          I'll see what I can do !
