  4. [Aufruf] TP-Link HS100 HS110 Adapter Testen
215 Beiträge 41 Kommentatoren 72.2k Aufrufe 3 Beobachtet
    tomtom
    Hallo arteck,
    unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api# ls
    befindet sich nur:
    CHANGELOG.md lib LICENSE package.json README.md
    Der Ordner node_modules ist nicht vorhanden.
    Ich habe den Adapter 0.0.21 über den 0.0.18, wie folgt manuell installiert:
    cd /opt/iobroker
    iobroker stop
    npm install iobroker.hs100@0.0.21 –production
    iobroker upload hs100
    iobroker start
    LG
    Thomas
    • DolomitiD Offline
      DolomitiD Offline
      Dolomiti
      Hallo arteck,
      ich hatte auch eine Menge Fehlermeldungen
      host.raspi3	2017-12-04 20:41:24.027	error	instance system.adapter.hs100.0 terminated with code 1 ()
      Caught	2017-12-04 20:41:24.027	error	by controller[0]: at node.js:1043:3
      Caught	2017-12-04 20:41:24.026	error	by controller[0]: at startup (node.js:140:18)
      Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Function.Module.runMain (module.js:441:10)
      Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Function.Module._load (module.js:300:12)
      Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Module.load (module.js:343:32)
      Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Object.Module._extensions..js (module.js:416:10)
      Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Module._compile (module.js:373:25)
      Caught	2017-12-04 20:41:24.025	error	by controller[0]: at exports.runInThisContext (vm.js:53:16)
      Caught	2017-12-04 20:41:24.025	error	by controller[0]: SyntaxError: Unexpected token {
      Caught	2017-12-04 20:41:24.025	error	by controller[0]: ^
      Caught	2017-12-04 20:41:24.024	error	by controller[0]: const { Client } = require('./lib/tplink-smarthome-api/lib/index');
      Caught	2017-12-04 20:41:24.024	error	by controller[0]: /opt/iobroker/node_modules/iobroker.hs100/main.js:14
      Unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/node_modules babel-runtime habe ich die Verzeichnisse
      core-js
      helpers
      regenerator
      und noch 4 Dateien
      Bin momentan zurück auf 0.0.18, die einwandfrei läuft. Der Trockner wird momentan geloggt. :)
      Dolomiti
      Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
      • arteckA Offline
        arteckA Offline
        arteck
        schon komisch .bei euch beiden.. es ist als ob nicht alles von GIT gezogen wurde..
        so die hs110 liefert jetzt auch daten.. version 0.22
        und die restlichen tp-link derivate sollten auch laufen.. (so hoffe ich :oops: )
        • G Offline
          Gerni
          ich hatte auch das Problem, dass der State nicht übergeben wurde, entsprechendes UpDate steht ja zur Verfügung.
          Also Adapter gestoppt, Unter Objekte HS100 alles gelöscht, UpDate gemacht -> Adapter startet
          Adapter komplett deinstalliert und wieder installiert -> Adapter startet nicht.
          Ideen?
          Jede Menge verschiedenes Zeug
          • AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #66
            Ist da nicht-transpilierter Code auf NPM gelandet? Die Syntax ist relativ neu und wird aktuell nur von Babel/TypeScript unterstützt, evtl auch Node 8+
            • arteckA Offline
              arteckA Offline
              arteck
              #67
              @AlCalzone:
              Ist da nicht-transpilierter Code auf NPM gelandet? Die Syntax ist relativ neu und wird aktuell nur von Babel/TypeScript unterstützt, evtl auch Node 8+ `
              ich hab node 6.12 .. auf dem Pi und 6 nochwas auf dem Win Entwickler System
              ich check mal ob auf NPM alles gelandet ist .. da kann das Problem sein
              installier es bitte nur vom GIT..
              über admin
                AlCalzoneA Offline
                AlCalzone
                #68
                Node 8 war geraten, aber Node 4 kann es definitiv nicht und davon sind hier noch einige im Umlauf.
                Lässt sich aber relativ einfach fixen:
                const Client = require('./lib/tplink-smarthome-api/lib/index').Client;
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #69
                  @AlCalzone:
                  ok… ich check das mal
                  wobei mit node 4 läuft der adapter nicht
                    tomtom
                    #70
                    also ich habe die Version 6.10.0 im Einsatz:
                    hs100.0 2017-12-03 20:06:57.758 info starting. Version 0.0.21 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.10.0
                    Was ist mit
                    -installier es bitte nur vom GIT..
                    -über admin
                    gemeint?
                    cd /opt/iobroker
                    npm install https://github.com/arteck/ioBroker.hs10 … ll/master/
                    LG
                    Thomas
                      AlCalzoneA Offline
                      AlCalzone
                      #71
                      @tomtom:
                      -über admin
                      gemeint? `
                      => ioBroker Admin öffnen
                      => Auf das GitHub-Icon klicken
                      => hs110 aus der Liste auswählen
                      => OK
                      • DolomitiD Offline
                        DolomitiD Offline
                        Dolomiti
                        #72
                        Ich Vollpfosten :)
                        Man sollte den Adapter auch auf dem richtigen Slave-Raspi mit Node 6 installieren und nicht auf dem Master-Raspi mit Node 4.
                        Jetzt klappt´s.
                        Dolomiti
                        P.S. Bei mir lief 0.0.18 auch unter Node 4.8
                        • cvidalC Offline
                          cvidalC Offline
                          cvidal
                          Forum Testing
                          #73
                          So 0.0.22 Läuft Instaliert habe ich über Admin Octocat Symbol siehe Bild…
                          Läuft erstmal soweit sehr gut der Adapter, danke dafür.
                          Einzig der Datenpunkt Total gibt mir immer noch Rätsel auf, was soll der überhaupt ausgeben? Verbrauch Heute, Vergangene 7 Tage oder Vergangene 30 Tage kann das nicht sein denn die Kasa App zeigt einen völlig anderen Wert an…
                          Gruß Christian
                            mamoel
                            #74
                            Auch die 0.0.22 läuft bei mir fehlerfrei. Aber auch bei dieser Version musste ich unter "Objects" den HS100-Knoten löschen. Sonst wird der "state" nicht aktualisiert.
                            <size size="85">ioBroker (docker) auf Synology DS418play
                            Alexa2, cloud, fritzdect, g-homa, harmony, hm-rega, hm-rpc, hs100, hue, javascript, nuki, ring, sayit, sonos, sql, viessmannapi</size>
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              #75
                              freut mich dass es läuft…
                              wobei ich probleme mit dem npm Paket habe
                              also bitte erstmal vom Git installieren
                              @AlCalzone:
                              => OK `
                              • X Offline
                                X Offline
                                xelarep
                                #76
                                hab heute auch ne HS110 bekommen. Leider klappts bei mir nicht: Hatte erst händisch versucht per````
                                sudo npm install iobroker.hs100
                                Es wurde v0.0.23 installiert, ich seh in der Admin Oberfläche einen Adapter und kann eine Instanz hs100.0 anlegen und konfigurieren. Sie stoppt aber sofort wieder, und wirft folgende Fehler ins log.
                                host.morbo 2017-12-06 15:02:55.522 info Restart adapter system.adapter.hs100.0 because enabled
                                host.morbo 2017-12-06 15:02:55.521 error instance system.adapter.hs100.0 terminated with code 0 (OK)
                                hs100.0 2017-12-06 15:02:55.503 info terminating
                                hs100.0 2017-12-06 15:02:55.296 info starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.11.2
                                hs100.0 2017-12-06 15:02:54.994 error at Function.Module._load (module.js:438:3)
                                hs100.0 2017-12-06 15:02:54.994 error at tryModuleLoad (module.js:446:12)
                                hs100.0 2017-12-06 15:02:54.994 error at Module.load (module.js:487:32)
                                hs100.0 2017-12-06 15:02:54.994 error at Object.Module._extensions..js (module.js:579:10)
                                hs100.0 2017-12-06 15:02:54.994 error at Module._compile (module.js:570:32)
                                hs100.0 2017-12-06 15:02:54.994 error at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
                                hs100.0 2017-12-06 15:02:54.994 error at require (internal/module.js:20:19)
                                hs100.0 2017-12-06 15:02:54.994 error at Module.require (module.js:497:17)
                                hs100.0 2017-12-06 15:02:54.994 error at Function.Module._load (module.js:417:25)
                                hs100.0 2017-12-06 15:02:54.994 error at Function.Module._resolveFilename (module.js:469:15)
                                hs100.0 2017-12-06 15:02:54.994 error Error: Cannot find module 'babel-runtime/core-js/json/stringify'
                                hs100.0 2017-12-06 15:02:54.979 error uncaught exception: Cannot find module 'babel-runtime/core-js/json/stringify'
                                Node ist 6.11.2 auf einem RPi3
                                Wenn ich per Github installieren möchte bekomme ich keine hs100 angeboten?
                                Was mach ich falsch?
                                Alexander
                                [edit] ich hab noch etwas rumgespielt: wenn ich einmal händisch per Terminal installiert habe, kann ich per GitHub drüberinstallieren (dann kommt eine hs100 in der Github Liste), und dann wird auch eine lauffähige Instanz und ein Objekt erzeugt, die ich benutzen kann?!
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #77
                                  link eintragen https://github.com/arteck/ioBroker.hs100
                                  dann weiter mit
                                  => OK
                                  • cvidalC Offline
                                    cvidalC Offline
                                    cvidal
                                    Forum Testing
                                    #78
                                    Seit Version 0.0.23 Kommt leider keine Rückmeldung wenn ich über die App schalte…
                                    Verbrauchsdaten werden auch keine mehr angezeigt.
                                    Ich hab zwei HS110 eingebunden.
                                    Gruß Christian
                                    • X Offline
                                      X Offline
                                      xelarep
                                      #79
                                      es wäre prima diese Installations-Info (also die URL einsetzen!) nochmal im Startbeitrag klar darzustellen, dann geht das nicht unter ;-)
                                      Ansonsten: bisher prima, Danke!
                                      [Nachtrag]: Die Rückmeldung ob aus der App geschalten (oder auch per Taster) geht bei mir in der 0.0.23 - ich verwende derzeit ein 2s Intervall.
                                      [Nachtrag2]: ein kleiner kosmetischer: In der Adapterübersicht, und im Einstellungsdialog fehlt bei mir ein Icon?
                                      Alexander
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #80
                                        @cvidal:
                                        Gruß Christian `
                                        stoppe den adapter und lösche die Objekte
                                        dann starte den adapter neu
                                        • arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #81
                                          @xelarep:
                                          Alexander `
                                          aktualisiere den adapter mal
