  4. Node-Red
  5. S7 mit Node Red (node-red-contrib-s7)
92 Beiträge 9 Kommentatoren 15.2k Aufrufe 8 Beobachtet
  • fu_zhouF fu_zhou
    @wal Update:
    Ich habe sporadisch Abweichungen, aber die Werte bleiben im Bereich zwischen -99 und 99:
    2023-12-31 08:21:57.712  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:21:57.712  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 65
    2023-12-31 08:21:57.713  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 74
    2023-12-31 08:22:02.458  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:22:02.461  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 74
    2023-12-31 08:22:02.461  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: -99
    2023-12-31 08:22:02.881  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:22:02.884  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: -91
    2023-12-31 08:22:02.884  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 33
    2023-12-31 08:22:02.973  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:22:02.974  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: -12
    2023-12-31 08:22:02.974  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 33
    2023-12-31 08:22:03.085  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:22:03.088  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 71
    2023-12-31 08:22:03.089  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: -87
    2023-12-31 08:22:04.409  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:22:04.409  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 33
    2023-12-31 08:22:04.411  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 78
    2023-12-31 08:22:04.483  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: Abweichung S7.0 DB22.Reserve92
    2023-12-31 08:22:04.483  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: -87
    2023-12-31 08:22:04.484  - javascript.0 (35683) script.js.zz_Test_WIP.S7_Komm_Test_JS: 78
    Für mich sieht das so aus, als würde node snap7 zyklisch im 1 Sekunden-Takt schreiben, der S7-Adapter braucht aber ab und zu länger, den Wert zu lesen und dann wird die Abweichung erkannt. Wie würdest du das interpretieren? Ich mache mal ne neue Instanz mit nur einem Wert und lass das Script damit arbeiten.
    WalW Offline
    WalW Offline
    Wal
    @fu_zhou ,
    diese Abweichungen sind unwichtig da wie du schon feststellen konntest nur Zeit Überschneidungen sind.
    Diese Überschneidungen habe ich nur bei zu hoher Pollzeit oder ich hatte vergessen bei dem Wert den ich schreibe den Haken bei Abfrage in der Adapter Config zu entfernen.
    Walter
    DoorIO-Adapter
    fu_zhouF 1 Antwort Letzte Antwort
    • WalW Wal
      @fu_zhou ,
      fu_zhouF Offline
      fu_zhouF Offline
      fu_zhou
      @wal Prost Neujahr! Eine Idee habe ich noch: Ich schreibe die Zufallszahl -99 - 99 mit Blockly in ein User-Objekt und das Script schickt den Wert dann direkt über node snap 7 an die S7.
      Kannst du mir helfen, die Zeile
       buf.writeFloatBE(parseInt(Math.floor(Math.random() * 198 - 99), 10), 0, 4);
      so anzupassen, dass anstatt der Zufallszahl der Wert vom Objekt
      javascript.0.S7_Komm_Test.real
      geschrieben wird?
      Ich will testen, on nicht doch Blockly da was verbockt...
      Synology DS920+ VM, S7-315 PN mit ET200S
      WalW 1 Antwort Letzte Antwort
      • fu_zhouF fu_zhou
        geschrieben wird?
        WalW Offline
        WalW Offline
        Wal
        @fu_zhou ,
        buf.writeFloatBE(getState('javascript.0.S7_Komm_Test.real').val);
        Walter
        DoorIO-Adapter
        fu_zhouF 2 Antworten Letzte Antwort
        • WalW Wal
          @fu_zhou ,
          fu_zhouF Offline
          fu_zhouF Offline
          fu_zhou
          schrieb am zuletzt editiert von fu_zhou
          @wal Was seit Neujahr passiert ist:
          • Alle Real-Werte, die ich schreibe, sind bei mir im DB22
          • Ich habe die S7.1 Instanz angelegt und den DB22 aus der S7.0 dort hin verschoben
          • Regelmäßig schreibe ich nur 4 Real-Werte in die S7 (DB22)
          • Diese Werte schreibe ich jetzt nicht mehr direkt aus Blockly über den Adapter, sondern lege sie mit Blockly in 4 User-Objekten (javascript.0.PV.Netzleistung, javascript.0.PV.Batterieleistung, javascript.0.Ansteuerung_Thyro.AW128_LIMIT, javascript.0.Ansteuerung_Thyro.AW128_LADE_SOLL) ab, welche ich dann regelmäßig über Javascript über node snap 7 in die S7 schreibe (aktuell 200ms Intervall):
          var snap7 = require('node-snap7');
          let buf;
          var s7client = new snap7.S7Client();
          s7client.ConnectTo('1.1.1.1', 0, 2, function(err) {
              if(err)
                  return console.log(' >> Connection failed. Code #' + err + ' - ' + s7client.ErrorText(err));
          function anS7senden() {
              buf = Buffer.alloc(4);
              buf.writeFloatBE(getState('javascript.0.PV.Netzleistung').val);
              s7client.DBWrite(22, 336, 4, buf, function(err, res) {
              if(err)
                  return console.log(' >> DBWrite failed. Code #' + err + ' - ' + s7client.ErrorText(err));
              buf.writeFloatBE(getState('javascript.0.PV.Batterieleistung').val);
              s7client.DBWrite(22, 352, 4, buf, function(err, res) {
              if(err)
              buf.writeFloatBE(getState('javascript.0.Ansteuerung_Thyro.AW128_LIMIT').val);
              s7client.DBWrite(22, 340, 4, buf, function(err, res) {
              if(err)
              buf.writeFloatBE(getState('javascript.0.Ansteuerung_Thyro.AW128_LADE_SOLL').val);
              s7client.DBWrite(22, 348, 4, buf, function(err, res) {
              if(err)
          setInterval(anS7senden, 200);
          • In dem Blockly, in dem ich die 4 Objekte aktualisiere, überprüfe ich die Werte im DB22 auf Änderung und gebe bei Abweichung eine entsprechend Log-Meldung aus.
          Und jetzt der Knaller: 2 der 4 Werte weichen massiv häufig (beide Werte zusammen 93x in einer Stunde) ab (DB22.DBD352 = Batterieleistung, DB22.DBD340 = AW128_LIMIT), die anderen beiden Werte nicht ein einziges Mal in der gleichen Zeit. Lt. Zeitstempel hat Blockly die Werte nicht verändert, (stehen bei 0), der Zeitstempel der zugeh. Wertes aus dem DB22 steht auf dem Zeitstempel kurz nach dem Überlauf, als 0 wieder geschrieben/gelesen wurde.
          Die Werte, die keine Ausreißer haben (Netzleistung, AW128_Lade_Soll) sind ungleich 0 (Null).
          Hast du eine Idee, wo und wie ich weiter in die Details gehen kann?
          Edit: Habe den Teil im Blockly jetzt mal deaktiviert, wo AW128_LIMIT aktualisiert wird und fest den Wert 1.23 ins Objekt javascript.0.Ansteuerung_Thyro.AW128_LIMIT geschrieben. Ausreißer kommt wieder:
          2024-01-07 20:40:05.197 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: Abweichung s7.1.DBs.DB22.AW128_LIMIT
          2024-01-07 20:40:05.198 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: -93510772337884000000
          2024-01-07 20:40:05.198 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: 1.23
          2024-01-07 20:41:52.834 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: Abweichung s7.1.DBs.DB22.AW128_LIMIT
          2024-01-07 20:41:52.835 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: 26160945152
          2024-01-07 20:41:52.835 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: 1.23
          2024-01-07 20:43:21.150 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: Abweichung s7.1.DBs.DB22.AW128_LIMIT
          2024-01-07 20:43:21.150 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: -93510772337884000000
          2024-01-07 20:43:21.151 - debug: javascript.0 (942) script.js._Werte_an_S7.Ansteuerung_Thyro: 1.23
          • WalW Wal
            @fu_zhou ,
            fu_zhouF Offline
            fu_zhouF Offline
            fu_zhou
            @wal Ich glaube, ich habe das Problem gefunden, auf jeden Fall ist seit der Änderung über die letzten 2 Stunden Ruhe mit den Ausreißern - mal sehen, was über die nächsten Stunden so passiert...
            Ich habe jetzt für jeden der (mittlerweile) 5 zu schreibenden Real-Werte einen eigenen Buffer angelegt: buf1 - buf5. Vorher habe ich für jeden Wert buf verwendet (s.o.):
            let buf1;
            let buf2;
            let buf3;
            let buf4;
            let buf5;
                if(err)
                buf1 = Buffer.alloc(4);
                buf1.writeFloatBE(getState('javascript.0.PV.Netzleistung').val);
                s7client.DBWrite(22, 336, 4, buf1, function(err, res) {
                if(err)
                buf2 = Buffer.alloc(4);
                buf2.writeFloatBE(getState('javascript.0.PV.Batterieleistung').val);
                s7client.DBWrite(22, 352, 4, buf2, function(err, res) {
                if(err)
                buf3 = Buffer.alloc(4);
                buf3.writeFloatBE(getState('javascript.0.Ansteuerung_Thyro.AW128_LIMIT').val);
                s7client.DBWrite(22, 340, 4, buf3, function(err, res) {
                if(err)
                buf4 = Buffer.alloc(4);
                buf4.writeFloatBE(getState('javascript.0.Ansteuerung_Thyro.AW128_LADE_SOLL').val);
                s7client.DBWrite(22, 348, 4, buf4, function(err, res) {
                if(err)
                buf5 = Buffer.alloc(4);
                buf5.writeFloatBE(getState('javascript.0.S7_Komm_Test.Reserve').val);
                s7client.DBWrite(22, 92, 4, buf5, function(err, res) {
                if(err)
            Obwohl buf ja immer mit dem neuen Wert beschrieben wird (getState...), scheint der buf da irgendwie sporadisch durcheinander zu kommen und dann stehen die Fantasiewerte drin.
            Jetzt habe ich überhaupt keine Ahnung, wo und wie dieses Problem abzufangen ist. Im node Snap7 Wrapper? Im S7 Adapter? Hast du eine Idee?
            Edit: auch nach 10 Stunden (über Nacht) keine Ausreißer mehr...
            WalW 2 Antworten Letzte Antwort
            • fu_zhouF fu_zhou
              let buf1;
              let buf2;
              let buf3;
              let buf4;
              let buf5;
                  if(err)
                  if(err)
                  if(err)
                  if(err)
                  if(err)
                  if(err)
              WalW Offline
              WalW Offline
              Wal
              @fu_zhou ,
              den "buf" gibt es auch im S7 Adapter den ich nach Befüllung mit geloggt hatte und keine Ausreißer hatte, aber zwischen "buf" befüllen und "buf" mit s7client.DBWrite schreiben könnte sich ja evtl. sich was ändern.
              Walter
              DoorIO-Adapter
              • fu_zhouF fu_zhou
                let buf1;
                let buf2;
                let buf3;
                let buf4;
                let buf5;
                    if(err)
                    if(err)
                    if(err)
                    if(err)
                    if(err)
                    if(err)
                WalW Offline
                WalW Offline
                Wal
                schrieb am zuletzt editiert von Wal
                @fu_zhou ,
                bin ja auf dem "latest" und auf nodejs20 mit meinem ioBroker.
                Habe am Anfang des Jahres alles geupdatet und kann den Fehler seit Stunden mit verschiedenen Skripten nicht mehr reproduzieren.
                Nach diesem Post wird der Fehler gleich da sein, werde berichten.
                edit: ich habs gewusst, 2 Minuten hat es gedauert. ;-)
                Walter
                DoorIO-Adapter
                • WalW Wal
                  @fu_zhou ,
                  fu_zhouF Offline
                  fu_zhouF Offline
                  fu_zhou
                  @wal für mich sieht das mit einem buf so aus: es wird ja nicht gewartet, ob oder bis der Wert aus dem Buffer tatsächlich in der S7 ankommt. Wenn der Schreibvorgang länger als 200ms (mein Intervall) dauert, steht möglicherweise in dem buf schon ein Teil von dem anderen Wert drin und dann ergibt der Inhalt dieser 4 "zusammengewürfelten" Bytes diese Werte, die völlig daneben sind. Das würde auch erklären, dass die Häufigkeit der Abweichung mit steigender Zykluszeit abnimmt. Allerdings kommt bei einem 1 Sek.-Intervall der Fehler noch immer hin und wieder und so lange kann der s7client.DBWrite ja eigentlich nicht dauern - oder hin und wieder eben doch?
                  Wenn wir, außer buf 1 - buf n, eine Lösung finden, immer die korrekten Werte in die S7 zu schreiben, ist das im Adapter leicht behoben, denke ich. Ich habe auch mal in die main.js geschaut und die Zeilen dazu gefunden...
                  In der API-Beschreibung habe ich nichts gefunden, was darauf hinweist, dass auf den Schreibzyklus zu achten wäre. Ich habe das aber mal im issue auf Github gefragt.
                  • fu_zhouF fu_zhou
                    WalW Offline
                    WalW Offline
                    Wal
                    @fu_zhou ,
                    kannst du mal den Adapter über mein Github installieren und testen ?
                    Bei mir dauert es immer sehr lang bis der Ausreißer kommt, deshalb wären 2 Tester besser.
                    Github Link
                    Walter
                    DoorIO-Adapter
                    • WalW Wal
                      @fu_zhou ,
                      Github Link
                      fu_zhouF Offline
                      fu_zhouF Offline
                      fu_zhou
                      @wal Ist jetzt installiert und ich beschreibe die S7 mit dem Adapter mit 200ms Poll-Delay mit 3 Real Werten, wobei einer in der S7 umkopiert wird, also lese ich die 3 geschriebenen + den 1 umkopierten Wert.
                      Ich bin soooo gespannt....
                      • fu_zhouF fu_zhou
                        WalW Offline
                        WalW Offline
                        Wal
                        @fu_zhou ,
                        bis jetzt hatte ich noch kein Ausreißer, aber nach dieser Nachricht ... ;-)
                        Walter
                        DoorIO-Adapter
                        • WalW Wal
                          @fu_zhou ,
                          fu_zhouF Offline
                          fu_zhouF Offline
                          fu_zhou
                          @wal seit wann läuft's bei dir?
                          • fu_zhouF fu_zhou
                            WalW Offline
                            WalW Offline
                            Wal
                            #66
                            @fu_zhou ,
                            10 Stunden.
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @fu_zhou ,
                              10 Stunden.
                              fu_zhouF Offline
                              fu_zhouF Offline
                              fu_zhou
                              #67
                              @wal Noch kein Ausreißer die letzten 20 Minuten!!!!! Ich gehe jetzt nochmal auf den S7 Adapter ohne deine Änderung zurück und schaue, wie lange es dauert, bis der erste Wert daneben liegt.
                              Edit: die ersten Ausreißer sind angekommen, ich gehe jetzt wieder auf deine Modifikation...
                              • WalW Wal
                                @fu_zhou ,
                                10 Stunden.
                                fu_zhouF Offline
                                fu_zhouF Offline
                                fu_zhou
                                #68
                                @wal kein Ausreißer über Nacht - bei 3 Instanzen in 2 ioBroker Installationen, die alle die selbe S7 traktieren. Das war bisher das Rezept für verlässliche sporadische Ausreißer! Kann es das gewesen sein????? - Sieht danach aus!!!!!
                                Ich würde sagen, dass das eine Version 1.5, wenn nicht sogar 2.0 Wert ist. Kannst du dich darum kümmern, dass das ioBroker Repository angepasst wird, so dass die funktionierende Version über ioBroker installiert wird?
                                Auf jeden Fall vielen Dank für deine Unterstützung bisher!
                                • fu_zhouF fu_zhou
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #69
                                  @fu_zhou ,
                                  es waren doch noch mehr User denen das aufgefallen ist, wenn die auch noch einmal testen könnten ...
                                  So schnell wage ich noch kein Pull Request, ;-) lass mal noch eine Woche so laufen.
                                  Walter
                                  DoorIO-Adapter
                                  HF_SPSlerH 1 Antwort Letzte Antwort
                                  • WalW Wal
                                    @fu_zhou ,
                                    HF_SPSlerH Offline
                                    HF_SPSlerH Offline
                                    HF_SPSler
                                    #70
                                    Moin @wal ,
                                    ich gehöre auch zu denen die Probleme mit den Ausreißern in den Werten haben :) Leider habe ich tagsüber nicht die Möglichkeit Tests durchzuführen da ich meine private S7 mit dem iobroker gekoppelt habe und mir auf der Arbeit aktuell keine Möglichkeit besteht eine S7 mit einem iobroker zu koppeln.
                                    Aber ich könnte jetzt heute Abend mal eine Trace aufzeichnen, zumindest für ein paar stunden. Jedoch weiß ich leider noch nicht wie man den Adapter von Github installiert bekommt, da bin ich noch totales Greenhorn.
                                    S7 1214 (Master) + Logo!8(Slave Erdgeschoss) + Logo!8 (Slave Obergeschoss) + S7 1214 (Slave Garage/Nebengebäude)
                                    • HF_SPSlerH HF_SPSler
                                      Moin @wal ,
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      #71
                                      @hf_spsler ,
                                      du rufst die Adapter in deinem ioBroker auf und klickst auf die Katze im weißen Kreis.
                                      Danach auf Benutzerdefiniert und kopierst die oben gepostete Github Url hinein, jetzt auf den Button installieren klicken.
                                      Walter
                                      DoorIO-Adapter
                                      • WalW Wal
                                        @hf_spsler ,
                                        HF_SPSlerH Offline
                                        HF_SPSlerH Offline
                                        HF_SPSler
                                        #72
                                        @wal Okay 👍 Muss dafür der bereits installierte Adapter erst entfernt werden? Der ist mit über 200 DB Adressen bereits für Iqontrol in Verwendung 😨
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #73
                                          @hf_spsler ,
                                          nein
                                          Walter
                                          DoorIO-Adapter
