  3. Off Topic
  4. Logfile läuft voll mit TimeoutoverflowWarning etc.
    6.0k
61 Beiträge 3 Kommentatoren 7.1k Aufrufe 2 Beobachtet
  • J JoergH
    Hi Thomas. Wie gewünscht...
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     18:03:35 up  1:46,  1 user,  load average: 4.97, 5.04, 5.26
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-07 18:03:36 CET
               Universal time: Sun 2024-01-07 17:03:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        3.3G        211M        1.0M        4.3G        4.5G
    Swap:            99M          0B         99M
    Total:          7.9G        3.3G        311M
             7811 M total memory
             3316 M used memory
             6908 M active memory
              403 M inactive memory
              211 M free memory
               42 M buffer memory
             4240 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      118G   15G   99G  13% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Sun Jan  7 16:16:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Jan  7 16:16:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Jan  7 16:16:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Jan  7 16:16:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    9.5G    /var/
    5.7G    /var/log
    4.2G    /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
    1.9G    /var/lib
    Archived and active journals take up 4.1G in the file system.
    /opt/iobroker/backups:
    333M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    441M    /opt/iobroker/iobroker-data/
    301M    /opt/iobroker/iobroker-data/files
    102M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    19M     /opt/iobroker/iobroker-data/states.jsonl
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
    npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
    npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
    npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
    npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
    npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
    npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
    npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
    npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
    npm ERR! extraneous: fs-extra@10.1.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/fs-extra
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
    npm ERR! extraneous: tslib@2.5.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
    npm ERR! missing: cheerio@^1.0.0-rc.12, required by iobroker.javascript@7.1.6
    npm ERR! missing: puppeteer@^21.6.1, required by iobroker.javascript@7.1.6
    npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
    npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-07T17_04_20_177Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   4
    Adapter State
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
    + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
      system.adapter.odl.0                    : odl                   : raspberrypi                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    List is empty
    Installed ioBroker-Instances
    Error: Object "system.repositories" not found
    Objects and States
    Objects:        27182
    States:         22818
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       967/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       40806      2549/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       37985      2426/io.mqtt.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      111        15567      861/influxd
    tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       42033      2510/io.hm-rpc.1
    tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       32118      2221/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15946      1652/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15029      1652/iobroker.js-co
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15521      952/dnsmasq
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       967/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        16893      1651/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      111        14917      861/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       93089      3023/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16064      1862/io.admin.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15520      952/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15517      952/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15378      630/dhclient
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       47467      2568/io.mihome-vacu
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       46609      2581/io.mihome-vacu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       34486      2132/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3671       425/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       54901      2502/io.shelly.0
    udp        0      0 0.0.0.0:51826           0.0.0.0:*                           0          14535      -
    udp        0      0 0.0.0.0:44435           0.0.0.0:*                           108        3673       425/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        3672       425/avahi-daemon: r
    udp6       0      0 :::38694                :::*                                108        3674       425/avahi-daemon: r
    udp6       0      0 :::51826                :::*                                0          14536      -
    2024-01-07 18:07:28.195  - info: javascript.0 (2077) script.js.Heizung.Zirkulationspumpe_Bedarf: Speichertemperatur: 46.7 - Temperaturdifferenz Speicher - RL ( >25 Grad ? ): 16.500000000000004
    2024-01-07 18:07:28.196  - info: javascript.0 (2077) script.js.Heizung.Zirkulationspumpe_Bedarf: Zirkulation ist AUS - Temperaturdifferenz Vorlauf - Vorlauf ALT ( >0.1 Grad ?): 0 Zeit seit Ausschalten ( >900000 ) in ms: 2728664
    2024-01-07 18:07:28.230  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1408.4911666666667
    2024-01-07 18:07:28.232  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
    2024-01-07 18:07:28.232  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
    2024-01-07 18:07:28.233  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
    2024-01-07 18:07:28.233  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -12 / -12
    2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
    2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
    2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
    2024-01-07 18:07:30.006  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1408.5207666666668
    2024-01-07 18:07:30.011  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
    2024-01-07 18:07:30.012  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
    2024-01-07 18:07:30.012  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
    2024-01-07 18:07:30.013  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -12 / -12
    2024-01-07 18:07:30.013  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
    2024-01-07 18:07:30.014  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
    2024-01-07 18:07:30.016  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
    2024-01-07 18:07:33.878  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-07 18:07:34.591  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
    2024-01-07 18:07:34.591  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
    2024-01-07 18:07:34.593  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
    2024-01-07 18:07:34.593  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
    2024-01-07 18:07:34.651  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
    2024-01-07 18:07:34.652  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
    und
    pi@raspberrypi://var/log $ sudo apt update
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:5 https://apt.grafana.com stable InRelease
    OK:6 https://apt.pivccu.de/piVCCU stable InRelease
    OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Alle Pakete sind aktuell.
    pi@raspberrypi://var/log $ apt policy influxdb
    influxdb:
      Installiert:           1.8.10-1
      Installationskandidat: 1.8.10-1
      Versionstabelle:
     *** 1.8.10-1 100
         1.6.7~rc0-1+b5 500
    @joergh sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
    Ist verdammt hoch und dein influxdb hängt da irgendwie ohne Anbindung an ein Repo herum. Wie hast du das installiert?
    • J JoergH
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
               3316 M used memory
                211 M free memory
                 42 M buffer memory
               4240 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      9.5G    /var/
      5.7G    /var/log
      1.9G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      List is empty
      Objects and States
      Objects:        27182
      States:         22818
      Pending Updates: 0
      und
      influxdb:
        Versionstabelle:
       *** 1.8.10-1 100
           1.6.7~rc0-1+b5 500
      Was ist da los? LXC auf einem Raspberry?
      • J JoergH
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7811 M total memory
                 3316 M used memory
                  211 M free memory
                   42 M buffer memory
                 4240 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        9.5G    /var/
        5.7G    /var/log
        1.9G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        List is empty
        Objects and States
        Objects:        27182
        States:         22818
        Pending Updates: 0
        und
        influxdb:
          Versionstabelle:
         *** 1.8.10-1 100
             1.6.7~rc0-1+b5 500
        Was ist da kaputt?
          JoergH
          Ich meine, dass ich das so installiert habe:
          wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
          source /etc/os-release
          echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
          sudo apt-get update
          sudo apt-get install influxdb
          Ist lange her....
          • J JoergH
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                     3316 M used memory
                      211 M free memory
                       42 M buffer memory
                     4240 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            9.5G    /var/
            5.7G    /var/log
            1.9G    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            List is empty
            Objects and States
            Objects:        27182
            States:         22818
            Pending Updates: 0
            und
            influxdb:
              Versionstabelle:
             *** 1.8.10-1 100
                 1.6.7~rc0-1+b5 500
            List is empty
            Hier stimmt auch was nicht. Keine Repos angelegt?
              Was ist da kaputt?
              JoergH
              Da sollte eigentlich nichts kaputt sein. Ich habe mal probiert eine Webseite zu parsen mit einem Javascript...funktionierte aber nicht wie gewünscht und ich habe das dann aufgegeben. Die Skripte sind nicht aktiv, die das genutzt haben.
                List is empty
                JoergH
                Verstehe nicht von was Du redest, tut mir leid. Was muss ich denn für Repos anlegen?
                  JoergH
                  @thomas-braun Was ist LXC?
                  • J JoergH
                    @joergh
                    Ein Containerformat. Könnte aber vom pivCCU kommen.
                    Aber warum ist dein LoginPrompt so merkwürdig?
                    Das sollte ohne // da stehen. So wie hier:
                    echad@chet:~ $ cd /var/log/
                    echad@chet:/var/log $
                    • J JoergH
                      @joergh
                      Da sind so viele Ungereimheiten auf dem System... Keine Ahnung was du da wie und warum wann gemacht hast...
                      Wird das LogFile z. B. dauerhaft im Millisekundentakt zugekleistert?
                        @joergh
                        JoergH
                        @thomas-braun sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
                        @joergh
                        Gute Frage. Wissentlich habe ich nichts geändert, wüsste auch nicht wie...
                          @joergh
                          JoergH
                          @joergh
                          Ja, das geht ständig weiter...
                          Nach einem cd /var/log ist der zweite Backslash nun weg....
                          • J JoergH
                            Auf dem System ist eigentlich sogar ziemlich viel 'kaputt'.
                            • J JoergH
                              Systemdata Bitte Ausfüllen
                              Hardwaresystem: Pi4.
                              Arbeitsspeicher: 32GB
                              Festplattenart: SSD
                              Betriebssystem: Debian
                              Nodejs-Version: 18.19.0
                              NPM-Version: 10.2.3
                              Bei mir läuft das Logfile zu mit folgenden Meldungen:
                              Jan 07 17:41:30 raspberrypi bash[1652]: (node:2009) TimeoutOverflowWarning: 3600000000 does not fit into a 32-bit signed integer.
                              Jan 07 17:41:30 raspberrypi bash[1652]: Timeout duration was set to 1.
                              Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd2d99b-ad7b-11ee-9b10-dca632f1625f 112496
                              Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd3090e-ad7b-11ee-9b16-dca632f1625f 111350
                              Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd30d89-ad7b-11ee-9b17-dca632f1625f 111299
                              Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd2e778-ad7b-11ee-9b12-dca632f1625f 112315
                              Woran kann das liegen?
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              Du hast mit ziemlicher Sicherheit einen zu großen Zeitwert in den InfluxDB Adapter Einstellungen eingetragen. Das wird da nicht verhindert. Zeig mal die Instanzeinstellungen (DB).
                                JoergH
                                Tja, Linux halt. Durch normales Installieren geht anscheinend irgendwann alles kaputt....
                                • Marc BergM Marc Berg
                                  JoergH
                                  @marc-berg sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
                                  Welchen Wert meinst Du? Schreibintervall?
                                  • J JoergH
                                    @joergh
                                    Tja, Ahnungslosigkeit halt... Es ist ja eben nicht vom Admin (dir?) ordentlich installiert.
                                    • J JoergH
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      Wahrscheinlich Timeout. Deswegen solltest du ja mal die Einstellungen zeigen.
                                        JoergH
                                        schrieb am zuletzt editiert von JoergH
                                        Sind mehrere Seiten, deswegen frage ich ja...
                                        Marc BergM 2 Antworten Letzte Antwort
                                        • J JoergH
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          Deswegen schrieb ich "DB" :-)
