  3. Off Topic
  4. Logfile läuft voll mit TimeoutoverflowWarning etc.
    2.0k
    2.5k
61 Beiträge 3 Kommentatoren 6.4k Aufrufe 2 Beobachtet
  • J Offline
    JoergH
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4.
    Arbeitsspeicher: 32GB
    Festplattenart: SSD
    Betriebssystem: Debian
    Nodejs-Version: 18.19.0
    NPM-Version: 10.2.3
    Bei mir läuft das Logfile zu mit folgenden Meldungen:
    Jan 07 17:41:30 raspberrypi bash[1652]: (node:2009) TimeoutOverflowWarning: 3600000000 does not fit into a 32-bit signed integer.
    Jan 07 17:41:30 raspberrypi bash[1652]: Timeout duration was set to 1.
    Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd2d99b-ad7b-11ee-9b10-dca632f1625f 112496
    Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd3090e-ad7b-11ee-9b16-dca632f1625f 111350
    Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd30d89-ad7b-11ee-9b17-dca632f1625f 111299
    Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd2e778-ad7b-11ee-9b12-dca632f1625f 112315
    Woran kann das liegen?
    Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
    • J JoergH
      Festplattenart: SSD
      NPM-Version: 10.2.3
      @joergh
      Zeig uns mal wie du da unterwegs bist:
      iob diag
      in der Langfassung bitte.
      Und
      sudo apt update
      apt policy influxdb*
        @joergh
        iob diag
        Und
        sudo apt update
        JoergH
        Hi Thomas. Wie gewünscht...
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         18:03:35 up  1:46,  1 user,  load average: 4.97, 5.04, 5.26
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-01-07 18:03:36 CET
                   Universal time: Sun 2024-01-07 17:03:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        3.3G        211M        1.0M        4.3G        4.5G
        Swap:            99M          0B         99M
        Total:          7.9G        3.3G        311M
                 7811 M total memory
                 3316 M used memory
                 6908 M active memory
                  403 M inactive memory
                  211 M free memory
                   42 M buffer memory
                 4240 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      118G   15G   99G  13% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Sun Jan  7 16:16:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sun Jan  7 16:16:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Jan  7 16:16:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sun Jan  7 16:16:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
        9.5G    /var/
        5.7G    /var/log
        4.2G    /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
        1.9G    /var/lib
        Archived and active journals take up 4.1G in the file system.
        /opt/iobroker/backups:
        333M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        441M    /opt/iobroker/iobroker-data/
        301M    /opt/iobroker/iobroker-data/files
        102M    /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        19M     /opt/iobroker/iobroker-data/states.jsonl
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
        npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
        npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
        npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
        npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
        npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
        npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
        npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
        npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
        npm ERR! extraneous: fs-extra@10.1.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/fs-extra
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
        npm ERR! extraneous: tslib@2.5.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
        npm ERR! missing: cheerio@^1.0.0-rc.12, required by iobroker.javascript@7.1.6
        npm ERR! missing: puppeteer@^21.6.1, required by iobroker.javascript@7.1.6
        npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
        npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-07T17_04_20_177Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   4
        Adapter State
          system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
        + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
        + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
        + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
        + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
        + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
          system.adapter.odl.0                    : odl                   : raspberrypi                              -  enabled
          system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
          system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
        + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
          system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        + instance is alive
        ioBroker-Repositories
        List is empty
        Installed ioBroker-Instances
        Error: Object "system.repositories" not found
        Objects and States
        Objects:        27182
        States:         22818
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       967/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       40806      2549/io.sonoff.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       37985      2426/io.mqtt.0
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      111        15567      861/influxd
        tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       42033      2510/io.hm-rpc.1
        tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       32118      2221/io.hm-rpc.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15946      1652/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15029      1652/iobroker.js-co
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15521      952/dnsmasq
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       967/sshd: /usr/sbin
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        16893      1651/grafana
        tcp6       0      0 :::8086                 :::*                    LISTEN      111        14917      861/influxd
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       93089      3023/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16064      1862/io.admin.0
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15520      952/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15517      952/dnsmasq
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15378      630/dhclient
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       47467      2568/io.mihome-vacu
        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       46609      2581/io.mihome-vacu
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       34486      2132/io.ham.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3671       425/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       54901      2502/io.shelly.0
        udp        0      0 0.0.0.0:51826           0.0.0.0:*                           0          14535      -
        udp        0      0 0.0.0.0:44435           0.0.0.0:*                           108        3673       425/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        3672       425/avahi-daemon: r
        udp6       0      0 :::38694                :::*                                108        3674       425/avahi-daemon: r
        udp6       0      0 :::51826                :::*                                0          14536      -
        2024-01-07 18:07:28.195  - info: javascript.0 (2077) script.js.Heizung.Zirkulationspumpe_Bedarf: Speichertemperatur: 46.7 - Temperaturdifferenz Speicher - RL ( >25 Grad ? ): 16.500000000000004
        2024-01-07 18:07:28.196  - info: javascript.0 (2077) script.js.Heizung.Zirkulationspumpe_Bedarf: Zirkulation ist AUS - Temperaturdifferenz Vorlauf - Vorlauf ALT ( >0.1 Grad ?): 0 Zeit seit Ausschalten ( >900000 ) in ms: 2728664
        2024-01-07 18:07:28.230  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1408.4911666666667
        2024-01-07 18:07:28.232  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
        2024-01-07 18:07:28.232  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
        2024-01-07 18:07:28.233  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
        2024-01-07 18:07:28.233  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -12 / -12
        2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
        2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
        2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
        2024-01-07 18:07:30.006  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1408.5207666666668
        2024-01-07 18:07:30.011  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
        2024-01-07 18:07:30.012  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
        2024-01-07 18:07:30.012  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
        2024-01-07 18:07:30.013  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -12 / -12
        2024-01-07 18:07:30.013  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
        2024-01-07 18:07:30.014  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
        2024-01-07 18:07:30.016  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
        2024-01-07 18:07:33.878  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-07 18:07:34.591  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
        2024-01-07 18:07:34.591  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
        2024-01-07 18:07:34.593  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
        2024-01-07 18:07:34.593  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
        2024-01-07 18:07:34.651  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
        2024-01-07 18:07:34.652  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
        und
        pi@raspberrypi://var/log $ sudo apt update
        OK:1 http://security.debian.org/debian-security bullseye-security InRelease
        OK:2 http://deb.debian.org/debian bullseye InRelease
        OK:3 http://deb.debian.org/debian bullseye-updates InRelease
        OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:5 https://apt.grafana.com stable InRelease
        OK:6 https://apt.pivccu.de/piVCCU stable InRelease
        OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Alle Pakete sind aktuell.
        pi@raspberrypi://var/log $ apt policy influxdb
        influxdb:
          Installiert:           1.8.10-1
          Installationskandidat: 1.8.10-1
          Versionstabelle:
         *** 1.8.10-1 100
             1.6.7~rc0-1+b5 500
        Thomas BraunT 4 Antworten Letzte Antwort
        • J JoergH
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7811 M total memory
                   3316 M used memory
                    211 M free memory
                     42 M buffer memory
                   4240 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          9.5G    /var/
          5.7G    /var/log
          1.9G    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          List is empty
          Objects and States
          Objects:        27182
          States:         22818
          Pending Updates: 0
          und
          influxdb:
            Versionstabelle:
           *** 1.8.10-1 100
               1.6.7~rc0-1+b5 500
          @joergh sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
          Ist verdammt hoch und dein influxdb hängt da irgendwie ohne Anbindung an ein Repo herum. Wie hast du das installiert?
          • J JoergH
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                     3316 M used memory
                      211 M free memory
                       42 M buffer memory
                     4240 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            9.5G    /var/
            5.7G    /var/log
            1.9G    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            List is empty
            Objects and States
            Objects:        27182
            States:         22818
            Pending Updates: 0
            und
            influxdb:
              Versionstabelle:
             *** 1.8.10-1 100
                 1.6.7~rc0-1+b5 500
            Was ist da los? LXC auf einem Raspberry?
            • J JoergH
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7811 M total memory
                       3316 M used memory
                        211 M free memory
                         42 M buffer memory
                       4240 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              9.5G    /var/
              5.7G    /var/log
              1.9G    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              List is empty
              Objects and States
              Objects:        27182
              States:         22818
              Pending Updates: 0
              und
              influxdb:
                Versionstabelle:
               *** 1.8.10-1 100
                   1.6.7~rc0-1+b5 500
              Was ist da kaputt?
                JoergH
                Ich meine, dass ich das so installiert habe:
                wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                source /etc/os-release
                echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                sudo apt-get update
                sudo apt-get install influxdb
                Ist lange her....
                • J JoergH
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           7811 M total memory
                           3316 M used memory
                            211 M free memory
                             42 M buffer memory
                           4240 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  9.5G    /var/
                  5.7G    /var/log
                  1.9G    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  List is empty
                  Objects and States
                  Objects:        27182
                  States:         22818
                  Pending Updates: 0
                  und
                  influxdb:
                    Versionstabelle:
                   *** 1.8.10-1 100
                       1.6.7~rc0-1+b5 500
                  List is empty
                  Hier stimmt auch was nicht. Keine Repos angelegt?
                    Was ist da kaputt?
                    JoergH
                    Da sollte eigentlich nichts kaputt sein. Ich habe mal probiert eine Webseite zu parsen mit einem Javascript...funktionierte aber nicht wie gewünscht und ich habe das dann aufgegeben. Die Skripte sind nicht aktiv, die das genutzt haben.
                      List is empty
                      JoergH
                      Verstehe nicht von was Du redest, tut mir leid. Was muss ich denn für Repos anlegen?
                        JoergH
                        @thomas-braun Was ist LXC?
                        • J JoergH
                          @joergh
                          Ein Containerformat. Könnte aber vom pivCCU kommen.
                          Aber warum ist dein LoginPrompt so merkwürdig?
                          Das sollte ohne // da stehen. So wie hier:
                          echad@chet:~ $ cd /var/log/
                          echad@chet:/var/log $
                          • J JoergH
                            @joergh
                            Da sind so viele Ungereimheiten auf dem System... Keine Ahnung was du da wie und warum wann gemacht hast...
                            Wird das LogFile z. B. dauerhaft im Millisekundentakt zugekleistert?
                              @joergh
                              JoergH
                              @thomas-braun sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
                              @joergh
                              Gute Frage. Wissentlich habe ich nichts geändert, wüsste auch nicht wie...
                                @joergh
                                JoergH
                                @joergh
                                Ja, das geht ständig weiter...
                                Nach einem cd /var/log ist der zweite Backslash nun weg....
                                • J JoergH
                                  Auf dem System ist eigentlich sogar ziemlich viel 'kaputt'.
                                  • J JoergH
                                    Festplattenart: SSD
                                    NPM-Version: 10.2.3
                                    Marc BergM Offline
                                    Marc BergM Offline
                                    Marc Berg
                                    Du hast mit ziemlicher Sicherheit einen zu großen Zeitwert in den InfluxDB Adapter Einstellungen eingetragen. Das wird da nicht verhindert. Zeig mal die Instanzeinstellungen (DB).
                                      JoergH
                                      Tja, Linux halt. Durch normales Installieren geht anscheinend irgendwann alles kaputt....
                                      • Marc BergM Marc Berg
                                        JoergH
                                        @marc-berg sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
                                        Welchen Wert meinst Du? Schreibintervall?
                                        • J JoergH
                                          @joergh
                                          Tja, Ahnungslosigkeit halt... Es ist ja eben nicht vom Admin (dir?) ordentlich installiert.
                                          83.2k
