  4. NodeJS / npm nach Neustart wieder auf alter Version
54 Beiträge 4 Kommentatoren 2.9k Aufrufe 3 Beobachtet
    @haxe sagte in NodeJS / npm nach Neustart wieder auf alter Version:
    Auszug:
    Gib mal die Langfassung.
    Und auch die Ausgabe von
    dmesg -T
    Haxe
    Hier das diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     23:08:47 up 23 min,  3 users,  load average: 0.24, 0.67, 1.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-01-06 23:08:47 CET
               Universal time: Sat 2024-01-06 22:08:47 UTC
                     RTC time: n/a
                    Time zone: Europe/Zurich (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            7.8G        1.4G        5.5G         35M        967M        6.7G
    Swap:            99M          0B         99M
    Total:          7.9G        1.4G        5.6G
             7812 M total memory
             1379 M used memory
             1307 M active memory
              821 M inactive memory
             5464 M free memory
              100 M buffer memory
              866 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   12G   16G  43% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  912K  1.6G   1% /run
    /dev/mmcblk0p1 vfat      253M   54M  200M  22% /boot
    tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
    [Sat Jan  6 22:45:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:0A:94:25 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8d81ccc6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Jan  6 22:45:46 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sat Jan  6 22:45:46 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sat Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sat Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
    [Sat Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Sat Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jan  6 22:45:47 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Jan  6 22:45:49 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.9G	/var/
    3.7G	/var/log
    2.9G	/var/log/journal/ef4df6d3a9a544f2a1705ace80cce517
    1.2G	/var/lib
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    5.3M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    239M	/opt/iobroker/iobroker-data/
    186M	/opt/iobroker/iobroker-data/files
    67M	/opt/iobroker/iobroker-data/files/javascript.admin
    48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    47M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    12M	/opt/iobroker/iobroker-data/objects.jsonl
    8.9M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node 		v16.20.2
    /usr/bin/npm 		8.19.4
    /usr/bin/npx 		8.19.4
    /usr/bin/corepack 	0.17.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.12.0
    javascript: 	7.1.6
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: xxx
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: xxx
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: xxx
      system.adapter.linktap.0                : linktap               : raspberrypi                              - disabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: xxxx, bind: 192.168.xxx, run as: admin
    + instance is alive
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: xxxx
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: xxxx, bind: 192.168xxxxx, run as: admin
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "heos"         : 2.1.0    , installed 2.1.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "linktap"      : 0.3.0    , installed 0.3.0
    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects: 	2944
    States: 	2336
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://repos.influxdata.com/debian stretch InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Get:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (3382 B/s)
    Reading package lists...
    Pending Updates: 26
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12269      539/influxd
    tcp        0      0 192.168.xxxxx:2010      0.0.0.0:*               LISTEN      1001       21540      1511/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12173      571/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18640      1014/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18633      1014/iobroker.js-co
    tcp        0      0 192.168.xxxxx:8082      0.0.0.0:*               LISTEN      1001       21446      1940/io.web.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          19559      1320/cupsd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          19558      1320/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12175      571/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       21695      1723/io.harmony.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22597      1477/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16164      539/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      115        17248      1013/grafana
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21139      1723/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18117      1321/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15390      393/avahi-daemon: r
    udp        0      0 0.0.0.0:58841           0.0.0.0:*                           108        15392      393/avahi-daemon: r
    udp        0      0 0.0.0.0:36191           0.0.0.0:*                           1001       21472      1998/io.heos.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14000      466/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15391      393/avahi-daemon: r
    udp6       0      0 :::59561                :::*                                108        15393      393/avahi-daemon: r
     / "{\"error\":\"timeout\"}\n""
    2024-01-06 22:53:15.180  - info: influxdb.0 (1457) Add point that had error for javascript.0.Solar.Wechselrichter.ACTotalRealPower to buffer again, error-count=8
    2024-01-06 22:53:15.188  - warn: influxdb.0 (1457) Error on writePoint("{"value":542,"time":"2024-01-06T21:52:55.167Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:15.192  - info: influxdb.0 (1457) Add point that had error for javascript.0.scriptEnabled.common.Solaredge_Modbus.Hausverbrauch to buffer again, error-count=8
    2024-01-06 22:53:15.385  - warn: influxdb.0 (1457) Error on writePoint("{"value":-541,"time":"2024-01-06T21:53:05.377Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:15.385  - info: influxdb.0 (1457) Add point that had error for javascript.0.Solar.Wechselrichter.ACTotalRealPower to buffer again, error-count=9
    2024-01-06 22:53:15.389  - warn: influxdb.0 (1457) Error on writePoint("{"value":541,"time":"2024-01-06T21:53:05.380Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:15.390  - info: influxdb.0 (1457) Add point that had error for javascript.0.scriptEnabled.common.Solaredge_Modbus.Hausverbrauch to buffer again, error-count=9
    2024-01-06 22:53:16.325  - warn: influxdb.0 (1457) Error on writePoint("{"value":-536,"time":"2024-01-06T21:52:56.293Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:16.326  - info: influxdb.0 (1457) Discard point that had error for javascript.0.Solar.Wechselrichter.ACTotalRealPower, error-count=10
    2024-01-06 22:53:16.330  - warn: influxdb.0 (1457) Error on writePoint("{"value":536,"time":"2024-01-06T21:52:56.299Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:16.330  - info: influxdb.0 (1457) Discard point that had error for javascript.0.scriptEnabled.common.Solaredge_Modbus.Hausverbrauch, error-count=10
    2024-01-06 22:53:16.529  - warn: influxdb.0 (1457) Error on writePoint("{"value":-540,"time":"2024-01-06T21:53:06.518Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:16.529  - info: influxdb.0 (1457) Add point that had error for javascript.0.Solar.Wechselrichter.ACTotalRealPower to buffer again, error-count=1
    2024-01-06 22:53:16.536  - warn: influxdb.0 (1457) Error on writePoint("{"value":540,"time":"2024-01-06T21:53:06.523Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2024-01-06 22:53:16.537  - info: influxdb.0 (1457) Add point that had error for javascript.0.scriptEnabled.common.Solaredge_Modbus.Hausverbrauch to buffer again, error-count=1
    2024-01-06 23:00:00.025  - info: javascript.0 (1489) script.js.common.Solaredge_Modbus.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
    2024-01-06 23:00:01.104  - info: javascript.0 (1489) script.js.common.BoilerPV.Hysterese_prod_001: !!!!!!!!!!!!!!!!!!!!!!!!!!!! Switch Anschalten erzwungen23:00:01
    • H Haxe
      Hier das diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	true
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
               1379 M used memory
               5464 M free memory
                100 M buffer memory
                866 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.9G	/var/
      3.7G	/var/log
      1.2G	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		8.19.4
      /usr/bin/npx 		8.19.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	2944
      States: 	2336
      Pending Updates: 26
      Die SD-Karte ist wohl morsch. Sauber per 'sudo reboot' neugestartet?
      H 1 Antwort Letzte Antwort
        Auszug:
        dmesg -T
        Haxe
        @thomas-braun said in NodeJS / npm nach Neustart wieder auf alter Version:
        dmesg -T
        dmesg -T
        [Sa Jan  6 22:45:45 2024] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
        [Sa Jan  6 22:45:45 2024] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
        [Sa Jan  6 22:45:45 2024] random: crng init done
        [Sa Jan  6 22:45:45 2024] Machine model: Raspberry Pi 4 Model B Rev 1.4
        [Sa Jan  6 22:45:45 2024] efi: UEFI not found.
        [Sa Jan  6 22:45:45 2024] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
        [Sa Jan  6 22:45:45 2024] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [Sa Jan  6 22:45:45 2024] Zone ranges:
        [Sa Jan  6 22:45:45 2024]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
        [Sa Jan  6 22:45:45 2024]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
        [Sa Jan  6 22:45:45 2024]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
        [Sa Jan  6 22:45:45 2024] Movable zone start for each node
        [Sa Jan  6 22:45:45 2024] Early memory node ranges
        [Sa Jan  6 22:45:45 2024]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
        [Sa Jan  6 22:45:45 2024]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        [Sa Jan  6 22:45:45 2024]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
        [Sa Jan  6 22:45:45 2024] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
        [Sa Jan  6 22:45:45 2024] On node 0, zone DMA32: 19456 pages in unavailable ranges
        [Sa Jan  6 22:45:45 2024] On node 0, zone Normal: 16384 pages in unavailable ranges
        [Sa Jan  6 22:45:45 2024] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
        [Sa Jan  6 22:45:45 2024] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
        [Sa Jan  6 22:45:45 2024] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [Sa Jan  6 22:45:45 2024] Detected PIPT I-cache on CPU0
        [Sa Jan  6 22:45:45 2024] CPU features: detected: Spectre-v2
        [Sa Jan  6 22:45:45 2024] CPU features: detected: Spectre-v3a
        [Sa Jan  6 22:45:45 2024] CPU features: detected: Spectre-v4
        [Sa Jan  6 22:45:45 2024] CPU features: detected: Spectre-BHB
        [Sa Jan  6 22:45:45 2024] CPU features: kernel page table isolation forced ON by KASLR
        [Sa Jan  6 22:45:45 2024] CPU features: detected: Kernel page table isolation (KPTI)
        [Sa Jan  6 22:45:45 2024] CPU features: detected: ARM erratum 1742098
        [Sa Jan  6 22:45:45 2024] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
        [Sa Jan  6 22:45:45 2024] alternatives: applying boot alternatives
        [Sa Jan  6 22:45:45 2024] Built 1 zonelists, mobility grouping on.  Total pages: 2028848
        [Sa Jan  6 22:45:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:0A:94:25 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8d81ccc6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sa Jan  6 22:45:45 2024] Unknown kernel command line parameters "splash", will be passed to user space.
        [Sa Jan  6 22:45:45 2024] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
        [Sa Jan  6 22:45:45 2024] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
        [Sa Jan  6 22:45:45 2024] mem auto-init: stack:off, heap alloc:off, heap free:off
        [Sa Jan  6 22:45:45 2024] software IO TLB: area num 4.
        [Sa Jan  6 22:45:45 2024] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
        [Sa Jan  6 22:45:45 2024] Memory: 7471364K/8245248K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 249596K reserved, 524288K cma-reserved)
        [Sa Jan  6 22:45:45 2024] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [Sa Jan  6 22:45:45 2024] ftrace: allocating 39744 entries in 156 pages
        [Sa Jan  6 22:45:45 2024] ftrace: allocated 156 pages with 4 groups
        [Sa Jan  6 22:45:45 2024] trace event string verifier disabled
        [Sa Jan  6 22:45:45 2024] rcu: Preemptible hierarchical RCU implementation.
        [Sa Jan  6 22:45:45 2024] rcu: 	RCU event tracing is enabled.
        [Sa Jan  6 22:45:45 2024] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
        [Sa Jan  6 22:45:45 2024] 	Trampoline variant of Tasks RCU enabled.
        [Sa Jan  6 22:45:45 2024] 	Rude variant of Tasks RCU enabled.
        [Sa Jan  6 22:45:45 2024] 	Tracing variant of Tasks RCU enabled.
        [Sa Jan  6 22:45:45 2024] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
        [Sa Jan  6 22:45:45 2024] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
        [Sa Jan  6 22:45:45 2024] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
        [Sa Jan  6 22:45:45 2024] Root IRQ handler: gic_handle_irq
        [Sa Jan  6 22:45:45 2024] GIC: Using split EOI/Deactivate mode
        [Sa Jan  6 22:45:45 2024] rcu: srcu_init: Setting srcu_struct sizes based on contention.
        [Sa Jan  6 22:45:45 2024] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [Sa Jan  6 22:45:45 2024] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [Sa Jan  6 22:45:45 2024] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [Sa Jan  6 22:45:45 2024] Console: colour dummy device 80x25
        [Sa Jan  6 22:45:45 2024] printk: console [tty1] enabled
        [Sa Jan  6 22:45:45 2024] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
        [Sa Jan  6 22:45:45 2024] pid_max: default: 32768 minimum: 301
        [Sa Jan  6 22:45:45 2024] LSM: Security Framework initializing
        [Sa Jan  6 22:45:45 2024] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
        [Sa Jan  6 22:45:45 2024] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
        [Sa Jan  6 22:45:45 2024] cgroup: Disabling memory control group subsystem
        [Sa Jan  6 22:45:45 2024] cblist_init_generic: Setting adjustable number of callback queues.
        [Sa Jan  6 22:45:45 2024] cblist_init_generic: Setting shift to 2 and lim to 1.
        [Sa Jan  6 22:45:45 2024] rcu: Hierarchical SRCU implementation.
        [Sa Jan  6 22:45:45 2024] rcu: 	Max phase no-delay instances is 1000.
        [Sa Jan  6 22:45:45 2024] EFI services will not be available.
        [Sa Jan  6 22:45:45 2024] smp: Bringing up secondary CPUs ...
        [Sa Jan  6 22:45:45 2024] Detected PIPT I-cache on CPU1
        [Sa Jan  6 22:45:45 2024] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
        [Sa Jan  6 22:45:45 2024] Detected PIPT I-cache on CPU2
        [Sa Jan  6 22:45:45 2024] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
        [Sa Jan  6 22:45:45 2024] Detected PIPT I-cache on CPU3
        [Sa Jan  6 22:45:45 2024] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
        [Sa Jan  6 22:45:45 2024] smp: Brought up 1 node, 4 CPUs
        [Sa Jan  6 22:45:45 2024] SMP: Total of 4 processors activated.
        [Sa Jan  6 22:45:45 2024] CPU features: detected: 32-bit EL0 Support
        [Sa Jan  6 22:45:45 2024] CPU features: detected: 32-bit EL1 Support
        [Sa Jan  6 22:45:45 2024] CPU features: detected: CRC32 instructions
        [Sa Jan  6 22:45:45 2024] CPU: All CPU(s) started at EL2
        [Sa Jan  6 22:45:45 2024] alternatives: applying system-wide alternatives
        [Sa Jan  6 22:45:45 2024] devtmpfs: initialized
        [Sa Jan  6 22:45:45 2024] Enabled cp15_barrier support
        [Sa Jan  6 22:45:45 2024] Enabled setend support
        [Sa Jan  6 22:45:45 2024] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
        [Sa Jan  6 22:45:45 2024] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [Sa Jan  6 22:45:45 2024] pinctrl core: initialized pinctrl subsystem
        [Sa Jan  6 22:45:45 2024] DMI not present or invalid.
        [Sa Jan  6 22:45:45 2024] NET: Registered PF_NETLINK/PF_ROUTE protocol family
        [Sa Jan  6 22:45:45 2024] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
        [Sa Jan  6 22:45:45 2024] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
        [Sa Jan  6 22:45:45 2024] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
        [Sa Jan  6 22:45:45 2024] audit: initializing netlink subsys (disabled)
        [Sa Jan  6 22:45:45 2024] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
        [Sa Jan  6 22:45:45 2024] thermal_sys: Registered thermal governor 'step_wise'
        [Sa Jan  6 22:45:45 2024] cpuidle: using governor menu
        [Sa Jan  6 22:45:45 2024] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
        [Sa Jan  6 22:45:45 2024] ASID allocator initialised with 32768 entries
        [Sa Jan  6 22:45:45 2024] Serial: AMBA PL011 UART driver
        [Sa Jan  6 22:45:45 2024] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [Sa Jan  6 22:45:45 2024] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
        [Sa Jan  6 22:45:45 2024] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
        [Sa Jan  6 22:45:45 2024] KASLR enabled
        [Sa Jan  6 22:45:45 2024] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [Sa Jan  6 22:45:45 2024] SCSI subsystem initialized
        [Sa Jan  6 22:45:45 2024] usbcore: registered new interface driver usbfs
        [Sa Jan  6 22:45:45 2024] usbcore: registered new interface driver hub
        [Sa Jan  6 22:45:45 2024] usbcore: registered new device driver usb
        [Sa Jan  6 22:45:45 2024] usb_phy_generic phy: supply vcc not found, using dummy regulator
        [Sa Jan  6 22:45:45 2024] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
        [Sa Jan  6 22:45:45 2024] pps_core: LinuxPPS API ver. 1 registered
        [Sa Jan  6 22:45:45 2024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
        [Sa Jan  6 22:45:45 2024] PTP clock support registered
        [Sa Jan  6 22:45:45 2024] vgaarb: loaded
        [Sa Jan  6 22:45:45 2024] clocksource: Switched to clocksource arch_sys_counter
        [Sa Jan  6 22:45:45 2024] VFS: Disk quotas dquot_6.6.0
        [Sa Jan  6 22:45:45 2024] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
        [Sa Jan  6 22:45:45 2024] FS-Cache: Loaded
        [Sa Jan  6 22:45:45 2024] CacheFiles: Loaded
        [Sa Jan  6 22:45:45 2024] NET: Registered PF_INET protocol family
        [Sa Jan  6 22:45:45 2024] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
        [Sa Jan  6 22:45:45 2024] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
        [Sa Jan  6 22:45:45 2024] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [Sa Jan  6 22:45:45 2024] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
        [Sa Jan  6 22:45:45 2024] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
        [Sa Jan  6 22:45:45 2024] TCP: Hash tables configured (established 65536 bind 65536)
        [Sa Jan  6 22:45:45 2024] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
        [Sa Jan  6 22:45:45 2024] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
        [Sa Jan  6 22:45:45 2024] NET: Registered PF_UNIX/PF_LOCAL protocol family
        [Sa Jan  6 22:45:45 2024] RPC: Registered named UNIX socket transport module.
        [Sa Jan  6 22:45:45 2024] RPC: Registered udp transport module.
        [Sa Jan  6 22:45:45 2024] RPC: Registered tcp transport module.
        [Sa Jan  6 22:45:45 2024] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [Sa Jan  6 22:45:45 2024] PCI: CLS 0 bytes, default 64
        [Sa Jan  6 22:45:45 2024] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
        [Sa Jan  6 22:45:45 2024] kvm [1]: IPA Size Limit: 44 bits
        [Sa Jan  6 22:45:45 2024] kvm [1]: vgic interrupt IRQ9
        [Sa Jan  6 22:45:45 2024] kvm [1]: Hyp mode initialized successfully
        [Sa Jan  6 22:45:46 2024] Initialise system trusted keyrings
        [Sa Jan  6 22:45:46 2024] workingset: timestamp_bits=46 max_order=21 bucket_order=0
        [Sa Jan  6 22:45:46 2024] zbud: loaded
        [Sa Jan  6 22:45:46 2024] NFS: Registering the id_resolver key type
        [Sa Jan  6 22:45:46 2024] Key type id_resolver registered
        [Sa Jan  6 22:45:46 2024] Key type id_legacy registered
        [Sa Jan  6 22:45:46 2024] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [Sa Jan  6 22:45:46 2024] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
        [Sa Jan  6 22:45:46 2024] Key type asymmetric registered
        [Sa Jan  6 22:45:46 2024] Asymmetric key parser 'x509' registered
        [Sa Jan  6 22:45:46 2024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
        [Sa Jan  6 22:45:46 2024] io scheduler mq-deadline registered
        [Sa Jan  6 22:45:46 2024] io scheduler kyber registered
        [Sa Jan  6 22:45:46 2024] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
        [Sa Jan  6 22:45:46 2024] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [Sa Jan  6 22:45:46 2024] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [Sa Jan  6 22:45:46 2024] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        [Sa Jan  6 22:45:46 2024] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        [Sa Jan  6 22:45:46 2024] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [Sa Jan  6 22:45:46 2024] pci_bus 0000:00: root bus resource [bus 00-ff]
        [Sa Jan  6 22:45:46 2024] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        [Sa Jan  6 22:45:46 2024] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [Sa Jan  6 22:45:46 2024] pci 0000:00:00.0: PME# supported from D0 D3hot
        [Sa Jan  6 22:45:46 2024] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
        [Sa Jan  6 22:45:46 2024] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
        [Sa Jan  6 22:45:46 2024] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
        [Sa Jan  6 22:45:46 2024] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        [Sa Jan  6 22:45:46 2024] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [Sa Jan  6 22:45:46 2024] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [Sa Jan  6 22:45:46 2024] pci 0000:01:00.0: PME# supported from D0 D3hot
        [Sa Jan  6 22:45:46 2024] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [Sa Jan  6 22:45:46 2024] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [Sa Jan  6 22:45:46 2024] pci 0000:00:00.0: PCI bridge to [bus 01]
        [Sa Jan  6 22:45:46 2024] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [Sa Jan  6 22:45:46 2024] iproc-rng200 fe104000.rng: hwrng registered
        [Sa Jan  6 22:45:46 2024] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        [Sa Jan  6 22:45:46 2024] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [Sa Jan  6 22:45:46 2024] brd: module loaded
        [Sa Jan  6 22:45:46 2024] loop: module loaded
        [Sa Jan  6 22:45:46 2024] Loading iSCSI transport class v2.0-870.
        [Sa Jan  6 22:45:46 2024] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [Sa Jan  6 22:45:46 2024] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [Sa Jan  6 22:45:46 2024] usbcore: registered new interface driver r8152
        [Sa Jan  6 22:45:46 2024] usbcore: registered new interface driver lan78xx
        [Sa Jan  6 22:45:46 2024] usbcore: registered new interface driver smsc95xx
        [Sa Jan  6 22:45:46 2024] pci 0000:00:00.0: enabling device (0000 -> 0002)
        [Sa Jan  6 22:45:46 2024] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [Sa Jan  6 22:45:46 2024] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [Sa Jan  6 22:45:46 2024] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
        [Sa Jan  6 22:45:46 2024] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [Sa Jan  6 22:45:46 2024] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [Sa Jan  6 22:45:46 2024] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
        [Sa Jan  6 22:45:46 2024] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [Sa Jan  6 22:45:46 2024] usb usb1: Product: xHCI Host Controller
        [Sa Jan  6 22:45:46 2024] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
        [Sa Jan  6 22:45:46 2024] usb usb1: SerialNumber: 0000:01:00.0
        [Sa Jan  6 22:45:46 2024] hub 1-0:1.0: USB hub found
        [Sa Jan  6 22:45:46 2024] hub 1-0:1.0: 1 port detected
        [Sa Jan  6 22:45:46 2024] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
        [Sa Jan  6 22:45:46 2024] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [Sa Jan  6 22:45:46 2024] usb usb2: Product: xHCI Host Controller
        [Sa Jan  6 22:45:46 2024] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
        [Sa Jan  6 22:45:46 2024] usb usb2: SerialNumber: 0000:01:00.0
        [Sa Jan  6 22:45:46 2024] hub 2-0:1.0: USB hub found
        [Sa Jan  6 22:45:46 2024] hub 2-0:1.0: 4 ports detected
        [Sa Jan  6 22:45:46 2024] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [Sa Jan  6 22:45:46 2024] dwc_otg: FIQ enabled
        [Sa Jan  6 22:45:46 2024] dwc_otg: NAK holdoff enabled
        [Sa Jan  6 22:45:46 2024] dwc_otg: FIQ split-transaction FSM enabled
        [Sa Jan  6 22:45:46 2024] Module dwc_common_port init
        [Sa Jan  6 22:45:46 2024] usbcore: registered new interface driver uas
        [Sa Jan  6 22:45:46 2024] usbcore: registered new interface driver usb-storage
        [Sa Jan  6 22:45:46 2024] mousedev: PS/2 mouse device common for all mice
        [Sa Jan  6 22:45:46 2024] sdhci: Secure Digital Host Controller Interface driver
        [Sa Jan  6 22:45:46 2024] sdhci: Copyright(c) Pierre Ossman
        [Sa Jan  6 22:45:46 2024] sdhci-pltfm: SDHCI platform and OF driver helper
        [Sa Jan  6 22:45:46 2024] ledtrig-cpu: registered to indicate activity on CPUs
        [Sa Jan  6 22:45:46 2024] hid: raw HID events driver (C) Jiri Kosina
        [Sa Jan  6 22:45:46 2024] usbcore: registered new interface driver usbhid
        [Sa Jan  6 22:45:46 2024] usbhid: USB HID core driver
        [Sa Jan  6 22:45:46 2024] NET: Registered PF_PACKET protocol family
        [Sa Jan  6 22:45:46 2024] Key type dns_resolver registered
        [Sa Jan  6 22:45:46 2024] registered taskstats version 1
        [Sa Jan  6 22:45:46 2024] Loading compiled-in X.509 certificates
        [Sa Jan  6 22:45:46 2024] Key type .fscrypt registered
        [Sa Jan  6 22:45:46 2024] Key type fscrypt-provisioning registered
        [Sa Jan  6 22:45:46 2024] uart-pl011 fe201000.serial: there is not valid maps for state default
        [Sa Jan  6 22:45:46 2024] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [Sa Jan  6 22:45:46 2024] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        [Sa Jan  6 22:45:46 2024] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [Sa Jan  6 22:45:46 2024] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [Sa Jan  6 22:45:46 2024] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [Sa Jan  6 22:45:46 2024] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [Sa Jan  6 22:45:46 2024] of_cfs_init
        [Sa Jan  6 22:45:46 2024] of_cfs_init: OK
        [Sa Jan  6 22:45:46 2024] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
        [Sa Jan  6 22:45:46 2024] Waiting for root device PARTUUID=8d81ccc6-02...
        [Sa Jan  6 22:45:46 2024] mmc1: new high speed SDIO card at address 0001
        [Sa Jan  6 22:45:46 2024] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
        [Sa Jan  6 22:45:46 2024] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
        [Sa Jan  6 22:45:46 2024]  mmcblk0: p1 p2
        [Sa Jan  6 22:45:46 2024] mmcblk0: mmc0:aaaa SP32G 29.7 GiB (quirks 0x00004000)
        [Sa Jan  6 22:45:46 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Sa Jan  6 22:45:46 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Sa Jan  6 22:45:46 2024] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [Sa Jan  6 22:45:46 2024] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [Sa Jan  6 22:45:46 2024] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [Sa Jan  6 22:45:46 2024] usb 1-1: Product: USB2.0 Hub
        [Sa Jan  6 22:45:46 2024] hub 1-1:1.0: USB hub found
        [Sa Jan  6 22:45:46 2024] hub 1-1:1.0: 4 ports detected
        [Sa Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Sa Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
        [Sa Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Sa Jan  6 22:45:47 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sa Jan  6 22:45:47 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sa Jan  6 22:45:47 2024] devtmpfs: mounted
        [Sa Jan  6 22:45:47 2024] Freeing unused kernel memory: 4160K
        [Sa Jan  6 22:45:47 2024] Run /sbin/init as init process
        [Sa Jan  6 22:45:47 2024]   with arguments:
        [Sa Jan  6 22:45:47 2024]     /sbin/init
        [Sa Jan  6 22:45:47 2024]     splash
        [Sa Jan  6 22:45:47 2024]   with environment:
        [Sa Jan  6 22:45:47 2024]     HOME=/
        [Sa Jan  6 22:45:47 2024]     TERM=linux
        [Sa Jan  6 22:45:47 2024] systemd[1]: System time before build time, advancing clock.
        [Sa Jan  6 22:45:47 2024] NET: Registered PF_INET6 protocol family
        [Sa Jan  6 22:45:47 2024] Segment Routing with IPv6
        [Sa Jan  6 22:45:47 2024] In-situ OAM (IOAM) with IPv6
        [Sa Jan  6 22:45:47 2024] systemd[1]: systemd 247.3-7+rpi1+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
        [Sa Jan  6 22:45:47 2024] systemd[1]: Detected architecture arm64.
        [Sa Jan  6 22:45:47 2024] systemd[1]: Set hostname to <xxxxxxxxx>.
        [Sa Jan  6 22:45:48 2024] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Queued start job for default target Graphical Interface.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Created slice system-getty.slice.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Created slice system-modprobe.slice.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Created slice system-systemd\x2dfsck.slice.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Created slice User and Session Slice.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Reached target Slices.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Reached target Swap.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on Syslog Socket.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on fsck to fsckd communication Socket.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on initctl Compatibility Named Pipe.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on Journal Audit Socket.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on Journal Socket (/dev/log).
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on Journal Socket.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on udev Control Socket.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Listening on udev Kernel Socket.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Mounting POSIX Message Queue File System...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Mounting RPC Pipe File System...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Mounting Kernel Debug File System...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Mounting Kernel Trace File System...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Restore / save the current clock...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Set the console keyboard layout...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Create list of static device nodes for the current kernel...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Load Kernel Module configfs...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Load Kernel Module drm...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Load Kernel Module fuse...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting File System Check on Root Device...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Journal Service...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Load Kernel Modules...
        [Sa Jan  6 22:45:48 2024] systemd[1]: Starting Coldplug All udev Devices...
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounted POSIX Message Queue File System.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounted RPC Pipe File System.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounted Kernel Debug File System.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounted Kernel Trace File System.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Create list of static device nodes for the current kernel.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Restore / save the current clock.
        [Sa Jan  6 22:45:49 2024] systemd[1]: modprobe@configfs.service: Succeeded.
        [Sa Jan  6 22:45:49 2024] fuse: init (API version 7.37)
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Load Kernel Module configfs.
        [Sa Jan  6 22:45:49 2024] i2c_dev: i2c /dev entries driver
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounting Kernel Configuration File System...
        [Sa Jan  6 22:45:49 2024] systemd[1]: Started File System Check Daemon to report status.
        [Sa Jan  6 22:45:49 2024] systemd[1]: modprobe@fuse.service: Succeeded.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Load Kernel Module fuse.
        [Sa Jan  6 22:45:49 2024] systemd[1]: modprobe@drm.service: Succeeded.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Load Kernel Module drm.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Load Kernel Modules.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounting FUSE Control File System...
        [Sa Jan  6 22:45:49 2024] systemd[1]: Starting Apply Kernel Variables...
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounted Kernel Configuration File System.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Mounted FUSE Control File System.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished File System Check on Root Device.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Finished Apply Kernel Variables.
        [Sa Jan  6 22:45:49 2024] systemd[1]: Starting Remount Root and Kernel File Systems...
        [Sa Jan  6 22:45:49 2024] systemd[1]: Started Journal Service.
        [Sa Jan  6 22:45:49 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        [Sa Jan  6 22:45:49 2024] systemd-journald[142]: Received client request to flush runtime journal.
        [Sa Jan  6 22:45:49 2024] systemd-journald[142]: File /var/log/journal/ef4df6d3a9a544f2a1705ace80cce517/system.journal corrupted or uncleanly shut down, renaming and replacing.
        [Sa Jan  6 22:46:00 2024] mc: Linux media interface: v0.10
        [Sa Jan  6 22:46:00 2024] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [Sa Jan  6 22:46:00 2024] [vc_sm_connected_init]: start
        [Sa Jan  6 22:46:00 2024] [vc_sm_connected_init]: installed successfully
        [Sa Jan  6 22:46:00 2024] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
        [Sa Jan  6 22:46:00 2024] videodev: Linux video capture interface: v2.00
        [Sa Jan  6 22:46:00 2024] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
        [Sa Jan  6 22:46:00 2024] bcm2835_audio bcm2835_audio: card created with 8 channels
        [Sa Jan  6 22:46:00 2024] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [Sa Jan  6 22:46:00 2024] rpivid feb10000.codec: Device registered as /dev/video19
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
        [Sa Jan  6 22:46:00 2024] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [Sa Jan  6 22:46:00 2024] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
        [Sa Jan  6 22:46:00 2024] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [Sa Jan  6 22:46:00 2024] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [Sa Jan  6 22:46:00 2024] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
        [Sa Jan  6 22:46:00 2024] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
        [Sa Jan  6 22:46:00 2024] brcmfmac: F1 signature read @0x18000000=0x15264345
        [Sa Jan  6 22:46:00 2024] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [Sa Jan  6 22:46:00 2024] usbcore: registered new interface driver brcmfmac
        [Sa Jan  6 22:46:01 2024] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
        [Sa Jan  6 22:46:01 2024] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
        [Sa Jan  6 22:46:01 2024] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
        [Sa Jan  6 22:46:01 2024] Registered IR keymap rc-cec
        [Sa Jan  6 22:46:01 2024] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
        [Sa Jan  6 22:46:01 2024] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
        [Sa Jan  6 22:46:02 2024] Registered IR keymap rc-cec
        [Sa Jan  6 22:46:02 2024] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
        [Sa Jan  6 22:46:02 2024] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
        [Sa Jan  6 22:46:02 2024] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        [Sa Jan  6 22:46:02 2024] vc4-drm gpu: [drm] Cannot find any crtc or sizes
        [Sa Jan  6 22:46:02 2024] uart-pl011 fe201000.serial: no DMA platform data
        [Sa Jan  6 22:46:02 2024] 8021q: 802.1Q VLAN Support v1.8
        [Sa Jan  6 22:46:02 2024] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        [Sa Jan  6 22:46:03 2024] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        [Sa Jan  6 22:46:03 2024] bcmgenet fd580000.ethernet eth0: Link is Down
        [Sa Jan  6 22:46:07 2024] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
        [Sa Jan  6 22:46:07 2024] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [Sa Jan  6 22:46:09 2024] Bluetooth: Core ver 2.22
        [Sa Jan  6 22:46:09 2024] NET: Registered PF_BLUETOOTH protocol family
        [Sa Jan  6 22:46:09 2024] Bluetooth: HCI device and connection manager initialized
        [Sa Jan  6 22:46:09 2024] Bluetooth: HCI socket layer initialized
        [Sa Jan  6 22:46:09 2024] Bluetooth: L2CAP socket layer initialized
        [Sa Jan  6 22:46:09 2024] Bluetooth: SCO socket layer initialized
        [Sa Jan  6 22:46:09 2024] Bluetooth: HCI UART driver ver 2.3
        [Sa Jan  6 22:46:09 2024] Bluetooth: HCI UART protocol H4 registered
        [Sa Jan  6 22:46:09 2024] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [Sa Jan  6 22:46:09 2024] Bluetooth: HCI UART protocol Broadcom registered
        [Sa Jan  6 22:46:10 2024] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [Sa Jan  6 22:46:10 2024] Bluetooth: BNEP filters: protocol multicast
        [Sa Jan  6 22:46:10 2024] Bluetooth: BNEP socket layer initialized
        [Sa Jan  6 22:46:10 2024] Bluetooth: MGMT ver 1.22
        [Sa Jan  6 22:46:10 2024] NET: Registered PF_ALG protocol family
        [Sa Jan  6 22:46:10 2024] Bluetooth: RFCOMM TTY layer initialized
        [Sa Jan  6 22:46:10 2024] Bluetooth: RFCOMM socket layer initialized
        [Sa Jan  6 22:46:10 2024] Bluetooth: RFCOMM ver 1.11
        [Sa Jan  6 22:49:41 2024] Key type cifs.spnego registered
        [Sa Jan  6 22:49:41 2024] Key type cifs.idmap registered
        [Sa Jan  6 22:49:41 2024] CIFS: Attempting to mount \\xxxxxxxxxxx
        [Sa Jan  6 23:12:50 2024] systemd[1]: systemd-journald.service: Main process exited, code=killed, status=6/ABRT
        [Sa Jan  6 23:12:50 2024] systemd[1]: systemd-journald.service: Failed with result 'watchdog'.
        [Sa Jan  6 23:12:50 2024] systemd[1]: systemd-journald.service: Consumed 4.147s CPU time.
        [Sa Jan  6 23:12:50 2024] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
        [Sa Jan  6 23:12:50 2024] systemd[1]: Stopping Flush Journal to Persistent Storage...
        [Sa Jan  6 23:12:50 2024] systemd[1]: systemd-journal-flush.service: Succeeded.
        [Sa Jan  6 23:12:50 2024] systemd[1]: Stopped Flush Journal to Persistent Storage.
        [Sa Jan  6 23:12:50 2024] systemd[1]: Stopped Journal Service.
        [Sa Jan  6 23:12:50 2024] systemd[1]: Starting Journal Service...
        [Sa Jan  6 23:13:11 2024] systemd-journald[6060]: File /var/log/journal/ef4df6d3a9a544f2a1705ace80cce517/system.journal corrupted or uncleanly shut down, renaming and replacing.
        [Sa Jan  6 23:13:11 2024] systemd[1]: Started Journal Service.
        [Sa Jan  6 23:13:11 2024] systemd-journald[6060]: Received client request to flush runtime journal.
        [Sa Jan  6 23:14:44 2024] systemd-journald[6060]: File /var/log/journal/ef4df6d3a9a544f2a1705ace80cce517/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
          Haxe
          schrieb am zuletzt editiert von Haxe
          Ja, das war kompletter Neustart via sudo reboot now.
          • H Haxe
            @haxe
            Dann würde ich umsomehr sagen, die Karte hat es hinter sich.
            Neuinstallation auf einer frischen Karte oder SSD.
              @haxe
              Haxe
              Okay - Vielen Dank für Deine Unterstützung Thomas!
              ESP8266E Thomas BraunT 2 Antworten Letzte Antwort
              • H Haxe
                ESP8266E Offline
                ESP8266E Offline
                ESP8266
                schrieb am zuletzt editiert von ESP8266
                @haxe ,....und gleich bookworm lite.
                • H Haxe
                  @haxe
                  Ganz easy:
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  ESP8266E 1 Antwort Letzte Antwort
                    @haxe
                    Ganz easy:
                    ESP8266E Offline
                    ESP8266E Offline
                    ESP8266
                    @thomas-braun , zu deinem Link. Ich sollte meinen das Rasbian bookworm keinen Node installiert hat. Ich musste ihn damals Manuel hinzufügen. Auch die rc.local muss aktiviert werden, falls da irgenwas anderes gestartet werden soll. Nur zur Info.
                    • ESP8266E ESP8266
                      @esp8266 sagte in NodeJS / npm nach Neustart wieder auf alter Version:
                      Das ist korrekt.
                      nodejs wird vom ioBroker-Installer mitgebracht. Vorherige Installation ist nicht erforderlich (und bringt ggf. nur Probleme, wenn die dfsg-Version erwischt wird).
                      • ESP8266E ESP8266
                        Nein, das wird nicht mehr verwendet. Init wird über systemd gemacht.
                          ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          @thomas-braun , kann schon sein. Meine beiden python scripts habe ich dort trotzdem eingefügt..
                          • ESP8266E ESP8266
                            @esp8266
                            Willkomen in den 80ern...
                            Die Datei rc.local ist seit dem Jahre 1983 obsolet. Es diente bei der Einführung des damals neuen, heute veralteten SysV-Init-Systems als Workaround für die Beibehaltung noch älterer Methoden zur Systeminitialisierung.
                            https://wiki.ubuntuusers.de/Archiv/rc.local/
                              @esp8266
                              ESP8266E Offline
                              ESP8266E Offline
                              ESP8266
                              @thomas-braun , so ist es halt. Der schöne Brotkasten C64. Dort wurde noch mit Basic geproggt.
                              • ESP8266E ESP8266
                                @esp8266
                                Hier hab ich aber etwas ganz ähnliches nach aktuellem Stand gemacht. Ein python-Skript über service unit gestartet:
                                https://forum.iobroker.net/topic/69229/anker-adapter/18
                                  @esp8266
                                  ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  @thomas-braun , Danke ich schaus mir morgen an bzw. nachher.
                                  • ESP8266E ESP8266
                                    @esp8266
                                    Du bist jetzt in zwei Tagen der dritte, der fälschlich behauptet die 'Einfacher-geht's-nicht'-Anleitung würde so nicht funktionieren. Wo kommt ihr auf einmal alle her? Abgesprochen?
                                      @esp8266
                                      ESP8266E Offline
                                      ESP8266E Offline
                                      ESP8266
                                      @thomas-braun , ich habe nicht behauptet, das es nicht gehen soll. Das einzigste war mir neu, das node.js von der install jetzt mitgebracht wird.
                                      Das steht selbst in der Anleitung nicht. Früher stand dort ein Hinweis das node.js vorher installiert werden musste. Aber ein Hinweis, das node.js nicht mehr voher installiert werden braucht, steht dort nicht.
                                      btw. Das habe ich erst heute gelesen.....ich brauche sowas nicht.
                                      • ESP8266E ESP8266
                                        @esp8266 Dann schau aber noch mal rein...
                                        Mit Einführung des Installationsskripts ist eine getrennte Installation von Node.js und npm auf üblichen Linux Systemen nicht mehr notwendig! Siehe Installation unter Linux
                                        https://www.iobroker.net/#de/documentation/install/nodejs.md
                                          ESP8266E Offline
                                          ESP8266E Offline
                                          ESP8266
                                          @thomas-braun , dann wurde das inzwischen hinzugefügt.....meine Installation läuft schon einige Monate.
