  3. Off Topic
  4. Proxmox
  5. Proxmox - keine Konsole möglich in VM
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
24 Beiträge 8 Kommentatoren 4.2k Aufrufe 5 Beobachtet
  • S Snopy_16
    @kalle-blomquist sagte in Proxmox - keine Konsole möglich in VM:
    https://pve.proxmox.com/wiki/Qemu-guest-agent
    Hätte ich schon probiert - leider irgendwo ist der Wurm drin
    root@pimox:~# apt-get install qemu-guest-agent
    Reading package lists... Done
    The following packages were automatically installed and are no longer required:
      ceph-common ceph-dkms ceph-fuse corosync criu cstream dctrl-tools dkms dmeventd dtach ebtables faketime fontconfig fontconfig-config
      fonts-dejavu-core fonts-font-awesome fonts-glyphicons-halflings genisoimage glusterfs-client glusterfs-common hdparm ipset ksmtuned libaio1
      libanyevent-http-perl libanyevent-perl libappconfig-perl libapt-pkg-perl libasyncns0 libauthen-pam-perl libc-devtools libcairo2 libcephfs2
      libcfg7 libcmap4 libcorosync-common4 libcpg4 libcrypt-openssl-bignum-perl libcrypt-openssl-random-perl libcrypt-openssl-rsa-perl libdatrie1
      libdbi1 libdevel-cycle-perl libdevmapper-event1.02.1 libepoxy0 libfaketime libfile-chdir-perl libfile-readbackwards-perl libfilesys-df-perl
      libfontconfig1 libfuse3-3 libgbm1 libgd3 libgfapi0 libgfchangelog0 libgfrpc0 libgfxdr0 libglusterd0 libglusterfs0 libgoogle-perftools4
      libgraphite2-3 libharfbuzz0b libibverbs1 libio-multiplex-perl libio-stringy-perl libipset13 libiscsi7 libjaeger libjemalloc2 libjs-bootstrap
      libjs-extjs libjs-jquery libjs-qrcodejs libknet1 libleveldb1d liblinux-inotify2-perl liblttng-ust-ctl4 liblttng-ust0 liblua5.3-0
      liblvm2cmd2.03 liblzo2-2 libmime-base32-perl libnet-dbus-perl libnet-dns-perl libnet-ip-perl libnet1 libnetaddr-ip-perl libnetfilter-log1
      libnozzle1 libnvpair3linux liboath0 libopus0 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libposix-strptime-perl
      libprotobuf23 libproxmox-acme-perl libproxmox-acme-plugins libproxmox-backup-qemu0 libproxmox-rs-perl libpulse0 libpve-access-control
      libpve-apiclient-perl libpve-cluster-api-perl libpve-cluster-perl libpve-common-perl libpve-guest-common-perl libpve-http-server-perl
      libpve-rs-perl libpve-storage-perl libpve-u2f-server-perl libqb100 libqrencode4 libquorum5 librabbitmq4 librados2 librados2-perl
      libradosstriper1 librbd1 librdkafka1 librdmacm1 librgw2 librrd8 librrds-perl libsnappy1v5 libsndfile1 libspice-server1 libstatgrab10
      libstring-shellquote-perl libtcmalloc-minimal4 libtemplate-perl libthai-data libthai0 libu2f-server0 liburcu6 liburing1 libusbredirparser1
      libuuid-perl libuutil3linux libvirglrenderer1 libvorbisenc2 libvotequorum8 libwayland-server0 libxcb-render0 libxcb-shm0 libxml-libxml-perl
      libxml-twig-perl libxpm4 libxrender1 libxslt1.1 libyaml-libyaml-perl libzfs4linux libzpool5linux linux-headers-5.10.0-25-arm64
      linux-headers-5.10.0-25-common linux-headers-5.10.0-26-arm64 linux-headers-5.10.0-26-common linux-headers-arm64 linux-kbuild-5.10 lvm2 lxcfs
      lzop novnc-pve pigz proxmox-archive-keyring proxmox-backup-client proxmox-backup-file-restore proxmox-mini-journalreader
      proxmox-websocket-tunnel proxmox-widget-toolkit pve-cluster pve-docs pve-edk2-firmware pve-firewall pve-i18n pve-lxc-syscalld pve-qemu-kvm
      pve-xtermjs python3-ceph-argparse python3-ceph-common python3-cephfs python3-distutils python3-jwt python3-lib2to3 python3-prettytable
      python3-protobuf python3-rados python3-rbd python3-rgw python3-spidev python3-wcwidth python3-yaml qrencode rrdcached sgml-base smartmontools
      socat spiceterm sqlite3 thin-provisioning-tools uidmap vncterm xsltproc zfs-dkms zfs-zed zfsutils-linux
    Use 'apt autoremove' to remove them.
    The following additional packages will be installed:
      binutils binutils-aarch64-linux-gnu binutils-common chrony libbinutils libc-bin libc-dev-bin libc6 libc6-dbg libc6-dev libctf0 libgnutls30
      libgprofng0 liburing2 libzstd1 locales rpcsvc-proto
    Suggested packages:
      binutils-doc dnsutils networkd-dispatcher glibc-doc libnss-nis libnss-nisplus gnutls-bin
    Recommended packages:
      libc-devtools
    The following packages will be REMOVED:
      libgnutlsxx28 lxc-pve proxmox-ve pve-container pve-ha-manager pve-manager qemu-server
    The following NEW packages will be installed:
      libgprofng0 liburing2 qemu-guest-agent rpcsvc-proto
    The following packages will be upgraded:
      libzstd1 locales
    14 upgraded, 4 newly installed, 7 to remove and 435 not upgraded.
    Need to get 0 B/23.6 MB of archives.
    After this operation, 27.6 MB disk space will be freed.
    Do you want to continue? [Y/n]
    W: (pve-apt-hook) !! WARNING !!
    W: (pve-apt-hook) You are attempting to remove the meta-package 'proxmox-ve'!
    W: (pve-apt-hook)
    W: (pve-apt-hook) If you really want to permanently remove 'proxmox-ve' from your system, run the following command
    W: (pve-apt-hook)       touch '/please-remove-proxmox-ve'
    W: (pve-apt-hook) run apt purge proxmox-ve to remove the meta-package
    W: (pve-apt-hook) and repeat your apt invocation.
    W: (pve-apt-hook)
    W: (pve-apt-hook) If you are unsure why 'proxmox-ve' would be removed, please verify
    W: (pve-apt-hook)       - your APT repository settings
    W: (pve-apt-hook)       - that you are using 'apt full-upgrade' to upgrade your system
    E: Sub-process /usr/share/proxmox-ve/pve-apt-hook returned an error code (1)
    E: Failure running script /usr/share/proxmox-ve/pve-apt-hook
    root@pimox:~# systemctl start qemu-guest-agent
    Failed to start qemu-guest-agent.service: Unit qemu-guest-agent.service not found.
    root@pimox:~#
    Kalle Blomquist
    @snopy_16 sagte in Proxmox - keine Konsole möglich in VM:
    du bist als root unterwegs! Also neuen benutzer anlegen und den zur Gruppe sudo hinzu fügen.
    usermod -aG sudo <benutzer>
    Dann liegen da " 14 upgraded, 4 newly installed, 7 to remove and 435 not upgraded ".
    Mir ist nicht so ganz klar wie du das installiert hast. Liegen deine VM´s etc auf einem NAS und kannst du schnell darauf zugreifen? Wenn ja, würde ich Proxmox neu installieren und gleich die neue Version nehmen. Dauert ja höchsten 5 Min. und Backup zurück spielen vielleicht noch mal 2 MIn.
    und
    sudo apt update &&  sudo apt ugrade -y && sudo apt autoremove
    hast du ja auch schon gemacht?
    • S Snopy_16
      Suggested packages:
        libc-devtools
        libzstd1 locales
      W: (pve-apt-hook)
      W: (pve-apt-hook)
      root@pimox:~#
      Radi
      schrieb am zuletzt editiert von Radi
      @snopy_16 Mal abgesehen davon, dass ich die Installation von Proxmox auf dem Raspi auf Grund seiner eingeschränkten Ressourcen nicht für besonders sinvoll halte: Warum eine alte Version des Proxmox?
      Nach dieser Anleitung gibt es ein einigermaßen aktuelles Proxmox auf dem Pi. Ob du damit deine aktuellen Probleme gelöst bekommst, weiß ich allerdings auch nicht.
      K S 2 Antworten Letzte Antwort
      • R Radi
        Kalle Blomquist
        @radi Oh, installation von Proxmox auf einem PI habe ich glatt überlesen. Bin dann raus!
        R 1 Antwort Letzte Antwort
        • K Kalle Blomquist
          Radi
          @kalle-blomquist Das ging mir erst auch so, hatte erst später noch mal den ersten Artikel genauer gelesen. Bei Pimox bin ich dann auch raus.
          • R Radi
            Snopy_16
            @radi @Kalle-Blomquist
            OK - Danke für Eure Hilfe👍
            Das sind meine 1. Gehversuche mit Proxmox mittels learning bei doing (darum auf PI)😕
            Werds aber nochmal mit einer Neuinstallation versuchen, man lernt ja immer dazu😀
            Entgültig will ich sowie so auf ein stärkeres System umstellen (NUC, .... oder ähnliches). Vielleicht gehts auch mit dem neuen PI5 ???
            Zumindest mein Echtsystem auf einem anderen Raspi 4 läuft zufriedenstellend.
            Es laufen halt schon viele verschiedene Services drauf (Influxdb, grafana, mosquitto, unifi-controller, Wireguard,..).
            Das will ich in Zukunft mit Proxmox trennen.
            Iobroker als VM, alles andere dann in Container.
            Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
            LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
            iobroker auf Proxmox VM
            Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
            FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
            • S Snopy_16
              mickymM Offline
              mickymM Offline
              mickym
              @snopy_16 Na was hast Du denn für eine Anzeige in deiner virtuellen Maschinenkonfiguration eingestellt? Und wie hast Du denn überhaupt Deine virutelle Maschine installiert wenn Du keine Anzeige hast?
              Und warum verschlüsselst Du irgendwas?
                Snopy_16
                @mickym
                Wo kann man die Anzeige inder Maschinenkonfiguration einstellen?
                Die VM hab ich auf der Desktop-Oberfläche von Proxmox installiert. IP:8006
                Was sollte ich verschlüsselt haben?
                Sorry, bin noch sehr unerfahren
                mickymM R 2 Antworten Letzte Antwort
                • S Snopy_16
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @snopy_16
                  Bei Anzeige und Hardware kannst Du was einstellen.
                  und wie hast Du installiert mit einem offiziellen Debian ISO?
                  • S Snopy_16
                    @mickym
                    Radi
                    @snopy_16 Ich doch noch mal: Die Qemu-Seite ist HTTPS-verschlüsselt. Das ist aber, so glaube ich, Standart. Hast du mal einfach versucht, diese Seite zu den Ausnahmen in deinem Browser hinzu zu fügen.
                    • crunchipC Abwesend
                      crunchipC Abwesend
                      nur so nebenbei,
                      Befehle dazu:
                      sudo apt-get install qemu-guest-agent
                      sudo systemctl start qemu-guest-agent
                      allerdings nicht wie du auf dem Host, sondern in der VM muss das installiert werden und das auch nur bei ubuntu, bei debian ist das schon dabei.
                      da allerdings bei dir pimox läuft kann ich zu deinem ....display Problem nix sagen
                      • mickymM mickym
                        @snopy_16
                        Snopy_16
                        @mickym
                        Die selben einstellungen wie bei dir
                        @Radi
                        ja, hab ich auch versucht
                        @crunchip
                        in der VM komme ich eben nicht ins Terminal (das grundsätzliche Problem)
                        K R 2 Antworten Letzte Antwort
                        • S Snopy_16
                          @mickym
                          @Radi
                          @crunchip
                          Kalle Blomquist
                          schrieb am zuletzt editiert von Kalle Blomquist
                          @snopy_16 Kommst du über Putty in deine VM.
                          Du mußt doch die IP kennen - von deiner VM bitte!
                          Ha, Sorry, war ein Denkfehler von mir. Vergiss es
                          • S Snopy_16
                            @mickym
                            @Radi
                            @crunchip
                            Radi
                            @snopy_16 Schau mal hier: https://github.com/pimox/pimox7/issues/32. Der Artikel ist zwar schon zwei Jahre alt, aber das scheint auf deine Symptomatic zu passen. Du brauchst für die VM offensichtlich ein passendes ISO-file für die Installation der VM.
                            • Dr. BakteriusD Offline
                              Dr. Bakterius
                              Bei heise gibt es aktuell einen Artikel zu proxmox auf dem Raspi: https://www.heise.de/ratgeber/Drei-Virtualisierer-fuer-den-Raspberry-Pi-im-Ueberblick-9586052.html
