  4. Probleme mit Zigbee Adapter 1.9.5
66 Beiträge 5 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • Jens G.J Jens G.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: smarthomepi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     12:24:44 up  1:03,  2 users,  load average: 0.32, 0.25, 0.29
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-01-06 12:24:44 CET
               Universal time: Sat 2024-01-06 11:24:44 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        1.2G        372M        1.2M        2.4G        2.7G
    Swap:           104M          0B        104M
    Total:          4.1G        1.2G        477M
             3793 M total memory
             1189 M used memory
             1172 M active memory
             2005 M inactive memory
              354 M free memory
               92 M buffer memory
             2241 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       29G  3.5G   24G  13% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Jan  6 11:20:50 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:2B:81:55 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3381e9f9-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Jan  6 11:20:52 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jan  6 11:20:54 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    503M    /var/
    202M    /var/cache
    197M    /var/cache/apt
    160M    /var/lib
    132M    /var/lib/apt/lists
    Archived and active journals take up 40.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    217M    /opt/iobroker/iobroker-data/
    198M    /opt/iobroker/iobroker-data/files
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/files/iqontrol.meta/userimages/userwidgets/abfallkalender_2023 (1)-cropped (1).html
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthomepi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : smarthomepi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : smarthomepi                              -  enabled
    + system.adapter.discovery.0              : discovery             : smarthomepi                              -  enabled
    + system.adapter.dwd.0                    : dwd                   : smarthomepi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : smarthomepi                              -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : smarthomepi                              -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : smarthomepi                              -  enabled
    + system.adapter.javascript.0             : javascript            : smarthomepi                              -  enabled
    + system.adapter.maxcul.0                 : maxcul                : smarthomepi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : smarthomepi                              -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.scenes.0                 : scenes                : smarthomepi                              - disabled
    + system.adapter.sonoff.0                 : sonoff                : smarthomepi                              -  enabled, port: 1883, bind: 192.168.188.159
    + system.adapter.tankerkoenig.0           : tankerkoenig          : smarthomepi                              -  enabled
      system.adapter.terminal.0               : terminal              : smarthomepi                              - disabled, port: 8099, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : smarthomepi                              -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : smarthomepi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0
    + instance is alive
    ioBroker-Repositories
    stable        : http://repo.iobroker.live/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
    Objects and States
    Objects:        4797
    States:         1744
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13059      773/sshd: /usr/sbin
    tcp        0      0 192.168.188.159:1883    0.0.0.0:*               LISTEN      1001       51787      10516/io.sonoff.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       51828      10547/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       51827      10547/io.mqtt.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51508      10210/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       51515      10210/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13061      773/sshd: /usr/sbin
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       54602      11727/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49898      10239/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15395      511/avahi-daemon: r
    udp        0      0 0.0.0.0:51346           0.0.0.0:*                           104        15397      511/avahi-daemon: r
    udp6       0      0 fe80::8152:7386:387:546 :::*                                0          13144      652/NetworkManager
    udp6       0      0 :::44029                :::*                                104        15398      511/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        15396      511/avahi-daemon: r
    2024-01-06 12:20:26.629  - info: host.smarthomepi "system.adapter.zigbee.0" enabled
    2024-01-06 12:20:26.865  - info: host.smarthomepi instance system.adapter.zigbee.0 started with pid 11984
    2024-01-06 12:20:31.349  - info: zigbee.0 (11984) starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    2024-01-06 12:20:31.453  - info: zigbee.0 (11984) delete old Backup files. keep only last 10
    2024-01-06 12:20:31.456  - info: zigbee.0 (11984) Starting Zigbee  npm ...
    2024-01-06 12:20:31.790  - info: zigbee.0 (11984) Installed Version: iobroker.zigbee@1.9.5
    2024-01-06 12:20:32.727  - info: zigbee.0 (11984) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    2024-01-06 12:20:32.737  - info: zigbee.0 (11984) Unable to disable LED, unsupported function.
    2024-01-06 12:20:32.762  - info: zigbee.0 (11984)   --> transmitPower : high+
    2024-01-06 12:20:32.783  - info: zigbee.0 (11984) Currently 5 devices are joined:
    2024-01-06 12:20:32.837  - info: zigbee.0 (11984) 0x00158d0002f7bc51 (addr 30345): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
    2024-01-06 12:20:32.842  - info: zigbee.0 (11984) 0x00158d0002732ad3 (addr 49658): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2024-01-06 12:20:32.843  - info: zigbee.0 (11984) 0x00158d00051e85e8 (addr 46898): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2024-01-06 12:20:32.846  - info: zigbee.0 (11984) 0x7cb03eaa0a00c5df (addr 39975): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
    2024-01-06 12:20:32.848  - info: zigbee.0 (11984) 0xa4c1384e05b39d11 (addr 45128): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    2024-01-06 12:20:32.849  - info: zigbee.0 (11984) Zigbee started
    2024-01-06 12:20:32.910  - info: zigbee.0 (11984) debug devices set to []
    2024-01-06 12:20:55.844  - warn: zigbee.0 (11984) DeviceAvailability:Failed to ping 0x7cb03eaa0a00c5df CLA60 TW OSRAM
    2024-01-06 12:21:04.726  - info: admin.0 (10239) ==> Connected system.user.admin from ::ffff:192.168.188.21
    2024-01-06 12:21:05.097  - info: zigbee.0 (11984) List of port: [{"path":"/dev/ttyUSB1","manufacturer":"SHK","serialNumber":"868","pnpId":"usb-SHK_NANO_CUL_868-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"78c227e46ed8ed11ad85736162c613ac","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0","vendorId":"10c4","productId":"ea60"}]
    2024-01-06 12:21:06.742  - warn: zigbee.0 (11984) DeviceAvailability:Failed to ping 0xa4c1384e05b39d11 TS011F
    2024-01-06 12:25:00.041  - info: host.smarthomepi instance system.adapter.dwd.0 started with pid 12220
    2024-01-06 12:25:02.430  - info: dwd.0 (12220) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
    2024-01-06 12:25:13.275  - info: dwd.0 (12220) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-06 12:25:13.807  - info: host.smarthomepi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    So hier ist die Langfassung
    @jens-g
    System ist richtig aufgesetzt.
    Die OSRAM-Klamotten sind bekannt dafür zickig zu sein.
    Bring vielleicht die Firmware des Sticks auf Stand, die ist wohl schon älter.
    Jens G.J 1 Antwort Letzte Antwort
      @jens-g
      Jens G.J Offline
      Jens G.J Offline
      Jens G.
      schrieb am zuletzt editiert von Jens G.
      Osram teste ich mal kurz. Lampe lässt sich schalten Temp und Helligkeit einstellen obwohl im Adapter steht nicht verbunden
      Wie update ich den Stick denn ?
      • Jens G.J Jens G.
        @jens-g sagte in Probleme mit Zigbee Adapter 1.9.5:
        Musste mal schauen. Ich hab den selber nicht und mich daher noch nie darum gesorgt.
          Jens G.J Offline
          Jens G.J Offline
          Jens G.
          Verstehe, hab dazu schon mal etwas auf youtube gesehen über ssh möglich mal schauen. Werde das hier mal testen: https://www.youtube.com/watch?v=0en12lyJPAs
          Jetzt ist die Steckdose doch wieder verbunden, warum auch immer hat jetzt Linkquality 87.
          Stick brauch wohl länger alle geräte kommen wieder zurück, einfach mal abwarten
          • Jens G.J Jens G.
            @jens-g
            Ich mach es bei meinem immer so:
            https://forum.iobroker.net/topic/50180/anleitung-zigbee-firmware-auf-der-kommandozeile-flashen
            • Jens G.J Jens G.
              Das ist aber auch das typische Verhalten eines Zigbee-Netzes.
                Jens G.J Offline
                Jens G.J Offline
                Jens G.
                Ok, vllt. lag es auch an der Lampe und oder das der Stromverbrauch unverändert war und dadurch kein Wert kam. Nun immerhin dann werde ich es jetzt erstmal laufen lassen und etwas mehr Geduld haben. Firmware lasse ich erstmal so, nun läufts ja.
                Bin froh das mein Upgrade auf Bookworm so flüssig gelaufen ist.
                Großes Dankeschön für deine wertvollen Tipps und deinen Log Check.
                Ok bin wohl ein wenig zu ungeduldig jetz gehts.
                Allerdings verstehe ich die Netzwerkkarte nicht, mit dem alten Stick wurde direkt angezeigt das die End Devices am Coordinator waren, beim Sonoff nur noch die Steckdose und Lampe siehe Bilder
                • Jens G.J Jens G.
                  @jens-g
                  Vergiss die Karte. Die zeigt alles mögliche an. Oder auch nicht.
                    @jens-g
                    Jens G.J Offline
                    Jens G.J Offline
                    Jens G.
                    Verstehe, dann kann hier zu
                    • Jens G.J Jens G.
                      @jens-g
                      Hier wird nix geschlossen. Aber du könntest deinen ersten Beitrag mit 'Gelöst' bezeichnen. Überschrift editieren.
                        @jens-g
                        Jens G.J Offline
                        Jens G.J Offline
                        Jens G.
                        Leider zu früh gefreut, sobald ich die Osram Lampe ausschalte verliert der Stick die Steckdose also muss ich jetzt Firmware Update machen. Leider auch kein Erfolg, die Revision lautet jetzt zwar 20230507 aber das Ergebnis ist das gleiche. Kann somit die Steckdose nicht steuern. Was ein Mist
                        • Jens G.J Jens G.
                          @jens-g
                          Ich glaube @arteck empfiehlt für OSRAM-Hardware folgendes:
                          Geräte entfernen, Gerät ausbauen, Wertstofftonne auf, Gerät reinwerfen, Wertstofftonne schließen.
                            @jens-g
                            Jens G.J Offline
                            Jens G.J Offline
                            Jens G.
                            Gut zu wissen, aber ich glaube es liegt irgendwie am Stick, denn mit meinem alten CC2531 lief alles wie am Schnürchen. Jetzt geht nur wenn OSRAM eingeschaltet ist. Ich kriege immer nur Failed to ping für die Steckdose.
                            Werde dann mal wieder den CC2531 anschließen und diesen Sonoff Stick zurücksenden
                            • Jens G.J Jens G.
                              @jens-g
                              Einen aus dieser Liste:
                              https://www.zigbee2mqtt.io/guide/adapters/#recommended
                              Ich habe den von slaesh. Deiner findet sich aber auch darunter.
                              Ich würde eher die Steckdose austauschen.
                                @jens-g
                                Jens G.J Offline
                                Jens G.J Offline
                                Jens G.
                                Wieso die Steckdose, die läuft doch einwandfrei am alten CC2531
                                Ich baue jetzt erstmal den alten Stick wieder dran
                                Thomas BraunT arteckA 2 Antworten Letzte Antwort
                                • Jens G.J Jens G.
                                  @jens-g
                                  Aber jetzt nicht mehr. Frag @arteck nach seiner Meinung zu den Dingern...
                                  • Jens G.J Jens G.
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @jens-g ja und wenn du Holzräder am Porsche montierst werden die auch laufen...
                                    ersetzt die Osram die sind scheisxx.. PUNKT
                                    und den cc2531 kannst auch direkt in die Tonne kloppen..
                                    bleib bei dem Sonoff..und die Firmware musst du auch ersetzten.. die 20230507 war fehlerhaft..ausser du hast die Korrigierte genommen
                                    • arteckA arteck
                                      Jens G.J Offline
                                      Jens G.J Offline
                                      Jens G.
                                      @arteck
                                      Ganz ehrlich habe nun Schnauze voll bleibt beim alten CC2531 und Sonoff geht zurück.
                                      Zack den CC2531 rein und alles läuft wieder, sogar die Netzwerkkarte siehe Bilderfunktioniert.png , nur etwas schade um die Reichweite, egal gibt ja genug Repeater aka Router dafür. netzwerkkarte.png.
                                      Kann man nur vorstellen, das es an dieser Antenne liegt die mit dabei ist.
                                      Verwende jetzt eine 10dbi Antenne sieht aus wie eine von ASUS Routern, am alten Stick.
                                      Alle Geräte extra neu pairen mit dem sonoff habe ich kein Bock drauf.
                                      Letzte Chance für Sonoff eine bessere Antenne sonst geht der Retoure
                                      • Jens G.J Jens G.
                                        @arteck
                                        Da wirst du wohl nicht drum herum kommen.
                                          Jens G.J Offline
                                          Jens G.J Offline
                                          Jens G.
                                          Kann schon sein, aber dann müsste ich doch auch meine Skripte überarbeiten oder bleibt es trotz repair beim gleichen Eintrag
