  4. Cannot read properties of null (reading 'native')
22 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
  • fAz3rs adventuresF fAz3rs adventures
    @glasfaser ```
    Damit müsste zumindest das wieder passen oder?
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     0
    Error: Object "system.repositories" not found
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            /usr/bin/corepack       0.22.0
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            7.8G        1.3G        5.7G         35M        888M        6.4G
    Swap:            99M          0B         99M
    Total:          7.9G        1.3G        5.8G
    Active iob-Instances:   26
    List is empty
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    Objects:                5635
    States:                 4391
    Size of iob-Database:
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    9.2M    /opt/iobroker/iobroker-data/states.jsonl
    GlasfaserG Offline
    GlasfaserG Offline
    @faz3rs-adventures
    passt
    zeige
    iob repo list
    fAz3rs adventuresF 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @faz3rs-adventures
      passt
      zeige
      iob repo list
      fAz3rs adventuresF Offline
      fAz3rs adventures
      @glasfaser
      pi@raspberrypi:~ $ iob repo list
      List is empty
        @glasfaser
        List is empty
        GlasfaserG Offline
        GlasfaserG Offline
        @faz3rs-adventures
        dann
        iob repo del beta
        iob repo del stable
        iob repo add stable http://download.iobroker.net/sources-dist.json
        iob repo add beta http://download.iobroker.net/sources-dist-latest.json
        iob repo list
          @faz3rs-adventures
          dann
          iob repo del beta
          iob repo del stable
          iob repo list
          fAz3rs adventures
          @glasfaser
          pi@raspberrypi:~ $ iob repo del beta
          Repository "beta" deleted.
          List is empty
          pi@raspberrypi:~ $ iob repo del stable
          Cannot remove repository: Cannot delete active repository: stable
          soll ich den rest trotzdem laufen lassen wenn die stable nicht entfernt werden kann?
            @glasfaser
            List is empty
            GlasfaserG Offline
            GlasfaserG Offline
            @faz3rs-adventures
            alles nacheinander ... del ist nur zur Sicherheit
              @faz3rs-adventures
              fAz3rs adventures
              @glasfaser
              pi@raspberrypi:~ $ iob repo add stable http://download.iobroker.net/sources-dist.json
              Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
              pi@raspberrypi:~ $ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
              Cannot add repository location: Repository "beta" yet exists: http://download.iobroker.net/sources-dist-latest.json
              List is empty
                @glasfaser
                List is empty
                GlasfaserG Offline
                GlasfaserG Offline
                @faz3rs-adventures
                iob stop
                iob setup first
                sudo reboot
                  @faz3rs-adventures
                  iob stop
                  iob setup first
                  sudo reboot
                  fAz3rs adventures
                  schrieb am zuletzt editiert von fAz3rs adventures
                  @glasfaser
                  pi@raspberrypi:~ $ iob stop
                  pi@raspberrypi:~ $ iob setup first
                  Successfully migrated 5683 objects to Redis Sets
                  object system.repositories created
                  object _design/system updated
                    "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----
                    "defaultPublic": "-----BEGIN CERTIFICATE-----
                  Update certificate defaultPrivate
                  The object "system.certificates" was updated successfully.
                  Update certificate defaultPublic
                  pi@raspberrypi:~ $ sudo reboot
                  Active repo(s): stable
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @faz3rs-adventures
                    sieht gut aus :)
                      @faz3rs-adventures
                      sieht gut aus :)
                      fAz3rs adventures
                      @glasfaser
                      Sau stark es passt👍
                      Kann die Updates für die Adapter laden
                      Vielen Dank👍 💪
                        @glasfaser
                        Sau stark es passt👍
                        Vielen Dank👍 💪
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @faz3rs-adventures sagte in Cannot read properties of null (reading 'native'):
                        Vielen Dank
                        Sehr gerne .... ;)
