  4. Cannot read properties of null (reading 'native')
22 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
  • fAz3rs adventuresF fAz3rs adventures
    @glasfaser ```
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     0
    Error: Object "system.repositories" not found
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/local/bin/npx              10.2.3
                            /usr/local/bin/corepack         0.22.0
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            7.8G        1.2G        5.7G         34M        881M        6.4G
    Swap:            99M          0B         99M
    Total:          7.9G        1.2G        5.8G
    Active iob-Instances:   26
    List is empty
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    Objects:                5635
    States:                 4392
    Size of iob-Database:
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    7.5M    /opt/iobroker/iobroker-data/states.jsonl
    Das könne es erklären wobei ich nicht weis was da falsch gelaufen ist.
    ich bin nach der Anleitung (https://www.iobroker.net/#de/documentation/install/nodejs.md) vorgegangen.
    GlasfaserG Offline
    GlasfaserG Offline
    @faz3rs-adventures sagte in Cannot read properties of null (reading 'native'):
    FALSCH
    dafür gibt es den Befehl:
    iob nodejs-update
    EDIT:
    Dein System ist schief
    /usr/local/bin/
    richtig .. alles in
    /usr/bin/
    fAz3rs adventuresF 1 Antwort Letzte Antwort
      SUMMARY
      ist nicht
      @glasfaser sagte in Cannot read properties of null (reading 'native'):
      die Full Ausgabe
      fAz3rs adventuresF Offline
      fAz3rs adventures
      schrieb am zuletzt editiert von fAz3rs adventures
      @homoran ```
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       16:03:53 up  1:53,  3 users,  load average: 0.43, 0.27, 0.25
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-29 16:03:53 CET
                 Universal time: Fri 2023-12-29 15:03:53 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        1.3G        5.7G         35M        883M        6.4G
      Swap:            99M          0B         99M
      Total:          7.9G        1.3G        5.8G
               7812 M total memory
               1254 M used memory
               1414 M active memory
                492 M inactive memory
               5674 M free memory
                129 M buffer memory
                753 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       30G   16G   13G  57% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/mmcblk0p1 vfat      255M   53M  203M  21% /boot
      tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
      [Fri Dec 29 14:10:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:CB:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb8f5eed-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Fri Dec 29 14:10:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Dec 29 14:10:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Dec 29 14:10:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.3G    /var/
      1.9G    /var/cache/apt
      1.9G    /var/cache
      1.8G    /var/cache/apt/archives
      1.2G    /var/log/journal/a9d90c753d4c4e98916aa8f9a3f582f2
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      21M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      395M    /opt/iobroker/iobroker-data/
      329M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      45M     /opt/iobroker/iobroker-data/files/devices.admin/static
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/npm            10.2.3
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.4
      Adapters from github:   6
      Adapter State
        system.adapter.acme.0                   : acme                  : raspberrypi                              -  enabled, port: 8086, bind: 0.0.0.0
      + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
      + system.adapter.bring.1                  : bring                 : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
        system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi                              - disabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.iwg-vpn.0                : iwg-vpn               : raspberrypi                              - disabled
        system.adapter.knx.0                    : knx                   : raspberrypi                              - disabled, bind: 192.168.0.60
      + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
        system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0 (SSL)
      + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled
      + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.residents.0              : residents             : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled
        system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.snips.0                  : snips                 : raspberrypi                              - disabled, port: 1883
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.synochat.0               : synochat              : raspberrypi                              - disabled
        system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5001
        system.adapter.tapo.0                   : tapo                  : raspberrypi                              - disabled
        system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
        system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
        system.adapter.ws.0                     : ws                    : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        system.adapter.yahka.1                  : yahka                 : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      List is empty
      Installed ioBroker-Instances
      Objects and States
      Objects:        5635
      States:         4392
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       41163      4776/io.mqtt.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       41164      4776/io.mqtt.0
      tcp        0      0 0.0.0.0:45077           0.0.0.0:*               LISTEN      1001       43594      5200/io.yahka.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15734      580/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3742       544/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40992      4641/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42024      4641/iobroker.js-co
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3741       544/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15736      580/sshd: /usr/sbin
      tcp6       0      0 :::4369                 :::*                    LISTEN      0          12813      1/init
      tcp6       0      0 :::8091                 :::*                    LISTEN      1001       41470      5026/io.lovelace.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       43522      5147/io.socketio.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       42078      4659/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41646      5178/io.web.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13132      603/cups-browsed
      udp        0      0 0.0.0.0:37851           0.0.0.0:*                           1001       40497      4791/io.openknx.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15658      391/avahi-daemon: r
      udp        0      0 0.0.0.0:36860           0.0.0.0:*                           108        15660      391/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3764       523/dhcpcd
      udp6       0      0 :::546                  :::*                                0          3776       523/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        15659      391/avahi-daemon: r
      udp6       0      0 :::58918                :::*                                108        15661      391/avahi-daemon: r
      2023-12-29 15:54:30.833  - info: javascript.0 (4716) script.js.Schlafen.GoToSleep: setTimeout(ms=5000)
      2023-12-29 15:54:35.833  - info: javascript.0 (4716) script.js.Schlafen.GoToSleep: getState(id=iot.0.services.custom_Schlafenszeit, timerId=undefined) => {"val":"false","ack":true,"ts":1703861670821,"q":0,"from":"system.adapter.iot.0","user":"system.user.admin","lc":1703861670821}
      2023-12-29 15:55:00.003  - warn: javascript.0 (4716) getState "tr-064.0.devices.Dani.active" not found (3)
      2023-12-29 15:55:00.010  - warn: javascript.0 (4716)     at Object.cb (script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnungen_WoZi_1:5:221)
      2023-12-29 15:55:00.011  - warn: javascript.0 (4716)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/scheduler.js:96:109)
      2023-12-29 15:55:00.012  - warn: javascript.0 (4716)     at processImmediate (node:internal/timers:478:21)
      2023-12-29 15:55:00.056  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 9406
      2023-12-29 15:55:03.069  - info: dwd.0 (9406) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      2023-12-29 15:55:05.706  - info: dwd.0 (9406) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-29 15:55:06.254  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-29 16:00:00.003  - info: javascript.0 (4716) script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram: getState(id=dwd.0.numberOfWarnings, timerId=undefined) => {"val":2,"ack":true,"ts":1703861705369,"q":0,"from":"system.adapter.dwd.0","user":"system.user.admin","lc":1703853855155}
      2023-12-29 16:00:00.004  - info: javascript.0 (4716) script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram: getState(id=javascript.0.VariablenSkripte.DWDAlarmSchonGesendetTelegram, timerId=undefined) => {"val":2,"ack":false,"ts":1703854520019,"q":0,"c":"script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1703854520019}
      2023-12-29 16:00:00.005  - info: javascript.0 (4716) script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram: getState(id=dwd.0.numberOfWarnings, timerId=undefined) => {"val":2,"ack":true,"ts":1703861705369,"q":0,"from":"system.adapter.dwd.0","user":"system.user.admin","lc":1703853855155}
      2023-12-29 16:00:00.076  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 10346
      2023-12-29 16:00:02.673  - info: dwd.0 (10346) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      2023-12-29 16:00:04.090  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 10406
      2023-12-29 16:00:06.868  - info: ical.0 (10406) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2023-12-29 16:00:06.970  - info: dwd.0 (10346) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-29 16:00:07.505  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-29 16:00:07.893  - info: ical.0 (10406) processing URL: Gmail
      2023-12-29 16:00:28.613  - info: ical.0 (10406) processing URL: Gmail
      2023-12-29 16:00:37.277  - info: ical.0 (10406) Terminated (NO_ERROR): Without reason
      2023-12-29 16:00:37.864  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-12-29 16:05:00.025  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 11280
      2023-12-29 16:05:03.231  - info: dwd.0 (11280) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      iob diag has finished.
      Press any key for a summary
        @homoran ```
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7812 M total memory
                 1254 M used memory
                 5674 M free memory
                  129 M buffer memory
                  753 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.3G    /var/
        1.9G    /var/cache/apt
        1.9G    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.4
        Adapter State
        + instance is alive
        List is empty
        Objects and States
        Objects:        5635
        States:         4392
        Pending Updates: 0
        GlasfaserG Offline
        GlasfaserG Offline
        processing URL: Gmail Privat
        processing URL: Gmail Geschäft
        Lösche den Link ... im Log !
        • GlasfaserG Glasfaser
          FALSCH
          iob nodejs-update
          EDIT:
          /usr/local/bin/
          richtig .. alles in
          /usr/bin/
          fAz3rs adventures
          bekomm ich das so hin oder ist es weniger aufwand es platt zu machen und neu einzuspielen mit einem backup von davor?
            GlasfaserG Offline
            GlasfaserG Offline
            @faz3rs-adventures
            Alles gut ... nimm den Befehl
              @glasfaser ```
                                      v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Kernel:                 aarch64
              Userland:               armhf
              User-ID:                1000
              X-Server:               true
                                      /usr/bin/npm            10.2.3
              Please check
              MEMORY:
              Swap:            99M          0B         99M
              List is empty
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                5635
              States:                 4392
              GlasfaserG Offline
              GlasfaserG Offline
              Dazu müssen wir gleich mal schauen !
                fAz3rs adventures
                @glasfaser ```
                Damit müsste zumindest das wieder passen oder?
                                        v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                Kernel:                 aarch64
                Userland:               armhf
                User-ID:                1000
                X-Server:               true
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        /usr/bin/corepack       0.22.0
                MEMORY:
                Mem:            7.8G        1.3G        5.7G         35M        888M        6.4G
                Swap:            99M          0B         99M
                List is empty
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                5635
                States:                 4391
                9.2M    /opt/iobroker/iobroker-data/states.jsonl
                  @glasfaser ```
                                          v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               armhf
                  User-ID:                1000
                  X-Server:               true
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                  MEMORY:
                  Swap:            99M          0B         99M
                  List is empty
                                          admin                   6.12.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                5635
                  States:                 4391
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @faz3rs-adventures
                  passt
                  zeige
                  iob repo list
                    @faz3rs-adventures
                    passt
                    zeige
                    iob repo list
                    fAz3rs adventures
                    @glasfaser
                    pi@raspberrypi:~ $ iob repo list
                    List is empty
                      @glasfaser
                      List is empty
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @faz3rs-adventures
                      dann
                      iob repo del beta
                      iob repo del stable
                      iob repo add stable http://download.iobroker.net/sources-dist.json
                      iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                      iob repo list
                        @faz3rs-adventures
                        dann
                        iob repo del beta
                        iob repo del stable
                        iob repo list
                        fAz3rs adventures
                        @glasfaser
                        pi@raspberrypi:~ $ iob repo del beta
                        Repository "beta" deleted.
                        List is empty
                        pi@raspberrypi:~ $ iob repo del stable
                        Cannot remove repository: Cannot delete active repository: stable
                        soll ich den rest trotzdem laufen lassen wenn die stable nicht entfernt werden kann?
                          @glasfaser
                          List is empty
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @faz3rs-adventures
                          alles nacheinander ... del ist nur zur Sicherheit
                            @faz3rs-adventures
                            fAz3rs adventures
                            @glasfaser
                            pi@raspberrypi:~ $ iob repo add stable http://download.iobroker.net/sources-dist.json
                            Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
                            pi@raspberrypi:~ $ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                            Cannot add repository location: Repository "beta" yet exists: http://download.iobroker.net/sources-dist-latest.json
                            List is empty
                              @glasfaser
                              List is empty
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @faz3rs-adventures
                              iob stop
                              iob setup first
                              sudo reboot
                                @faz3rs-adventures
                                iob stop
                                iob setup first
                                sudo reboot
                                fAz3rs adventures
                                @glasfaser
                                pi@raspberrypi:~ $ iob stop
                                pi@raspberrypi:~ $ iob setup first
                                Successfully migrated 5683 objects to Redis Sets
                                object system.repositories created
                                object _design/system updated
                                  "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----
                                  "defaultPublic": "-----BEGIN CERTIFICATE-----
                                Update certificate defaultPrivate
                                The object "system.certificates" was updated successfully.
                                Update certificate defaultPublic
                                pi@raspberrypi:~ $ sudo reboot
                                Active repo(s): stable
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @faz3rs-adventures
                                  sieht gut aus :)
                                    @faz3rs-adventures
                                    sieht gut aus :)
                                    fAz3rs adventures
                                    @glasfaser
                                    Sau stark es passt👍
                                    Kann die Updates für die Adapter laden
                                    Vielen Dank👍 💪
                                      @glasfaser
                                      Sau stark es passt👍
                                      Vielen Dank👍 💪
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Vielen Dank
                                      Sehr gerne .... ;)
