  4. Test Adapter onvif camera v1.x.x
    6.6k
341 Beiträge 48 Kommentatoren 125.8k Aufrufe 49 Beobachtet
  • M micw42
    seit Version 1.1.1 startet der Adapter nicht mehr, Fehlermeldung ist folgende:
    TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:328:4) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:494:9) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:157:8) at emitErrorCloseNT (node:internal/streams/destroy:122:3) at processTicksAndRejections (node:internal/process/task_queues:83:21)
    Jemand eine Idee?
    #234
    @micw42 sagte in Test Adapter onvif camera v1.0.0:
    Jemand eine Idee?
    Das Umfeld schaut wie aus?
    iob diag
    anschauen.
    XBiTX 1 Antwort Letzte Antwort
      Jemand eine Idee?
      iob diag
      anschauen.
      XBiTX Online
      XBiTX Online
      XBiT
      #235
      @thomas-braun @micw42
      bei mir leider das gleiche..
      Log:
      host.IoBroker
      2023-11-20 13:32:55.269	info	Restart adapter system.adapter.onvif.0 because enabled
      host.IoBroker
      2023-11-20 13:32:55.269	error	instance system.adapter.onvif.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:82:21)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at endReadableNT (node:internal/streams/readable:1368:12)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.emit (node:events:529:35)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14)
      host.IoBroker
      2023-11-20 13:32:55.269	error	Caught by controller[0]: TypeError: callback.call is not a function
      onvif.0
      2023-11-20 13:32:55.037	error	callback.call is not a function
      onvif.0
      2023-11-20 13:32:55.036	error	TypeError: callback.call is not a function at Cam.<anonymous> (/opt/iobroker/node_modules/onvif/lib/events.js:309:14) at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4) at IncomingMessage.emit (node:events:529:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1368:12) at processTicksAndRejections (node:internal/process/task_queues:82:21)
      onvif.0
      2023-11-20 13:32:55.036	error	uncaught exception: callback.call is not a function
      onvif.0
      2023-11-20 13:32:43.482	info	Starting snapshot server
      onvif.0
      2023-11-20 13:32:43.481	info	Finished onvif discovery
      onvif.0
      2023-11-20 13:32:41.644	info	Data: undefined xml: undefined
      iob_diag:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: IoBroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-24-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       13:33:48 up 16 days, 18:50,  1 user,  load average: 0.50, 0.66, 0.67
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Mon 2023-11-20 13:33:49 CET
                 Universal time: Mon 2023-11-20 12:33:49 UTC
                       RTC time: Mon 2023-11-20 12:33:50
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      stephan
      /home/stephan
      stephan cdrom floppy sudo audio dip video plugdev netdev
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            16G        3.4G         10G         24M        2.1G         12G
      Swap:          6.1G          0B        6.1G
      Total:          22G        3.4G         16G
              16042 M total memory
               3423 M used memory
               4064 M active memory
                987 M inactive memory
              10474 M free memory
                482 M buffer memory
               1662 M swap cache
               6140 M total swap
                  0 M used swap
               6140 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      udev           devtmpfs  7.9G     0  7.9G   0% /dev
      tmpfs          tmpfs     1.6G   25M  1.6G   2% /run
      /dev/sda1      ext4       34G  7.8G   24G  25% /
      tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     7.9G     0  7.9G   0% /sys/fs/cgroup
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Fri Nov  3 18:43:46 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Nov  3 18:43:46 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
      `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      /var:
      565M    /var/
      392M    /var/cache
      385M    /var/cache/apt
      324M    /var/cache/apt/archives
      156M    /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      379M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      747M    /opt/iobroker/iobroker-data/
      402M    /opt/iobroker/iobroker-data/files
      238M    /opt/iobroker/iobroker-data/backup-objects
      94M     /opt/iobroker/iobroker-data/files/vis-2-beta
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      21M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.605c1bc5.js.map
      21M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.605c1bc5.js.map
      20M     /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.0
      javascript:     7.1.4
      Adapters from github:   11
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : IoBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoBroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : IoBroker                                 -  enabled
      + system.adapter.enigma2.1                : enigma2               : IoBroker                                 -  enabled
      + system.adapter.enigma2.2                : enigma2               : IoBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
      + system.adapter.followthesun.0           : followthesun          : IoBroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
      + system.adapter.google-sharedlocations.0 : google-sharedlocations: IoBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
      + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
      + system.adapter.logparser.0              : logparser             : IoBroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : IoBroker                                 -  enabled, port: 8091, bind: 192.168.1.251, run as: admin
      + system.adapter.meater.0                 : meater                : IoBroker                                 -  enabled
      + system.adapter.mercedesme.0             : mercedesme            : IoBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
      + system.adapter.omada.0                  : omada                 : IoBroker                                 -  enabled, port: 8043
        system.adapter.onvif.0                  : onvif                 : IoBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
        system.adapter.roborock.0               : roborock              : IoBroker                                 - disabled
      + system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
      + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 2023, bind: 0.0.0.0
      + system.adapter.sia.0                    : sia                   : IoBroker                                 -  enabled, port: 50001, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
      + system.adapter.sony-bravia.0            : sony-bravia           : IoBroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled, port: 3306
      + system.adapter.synochat.0               : synochat              : IoBroker                                 -  enabled
      + system.adapter.synology.0               : synology              : IoBroker                                 -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.2               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : IoBroker                                 -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : IoBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "device-watcher": 2.9.4   , installed 2.9.4
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "followthesun" : 0.4.2    , installed 0.4.2
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "meater"       : 1.0.2    , installed 1.0.2
      Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "onvif"        : 1.1.1    , installed 1.1.1
      Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sia"          : 1.0.4    , installed 1.0.4
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "synochat"     : 1.3.1    , installed 1.3.1
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        30217
      States:         24890
      Hit:1 http://deb.debian.org/debian buster InRelease
      Hit:2 http://deb.debian.org/debian buster-updates InRelease
      Hit:3 http://security.debian.org/debian-security buster/updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.1.251:42010     0.0.0.0:*               LISTEN      1001       42089991   4473/io.hm-rpc.1
      tcp        0      0 192.168.1.251:8091      0.0.0.0:*               LISTEN      1001       42092665   5196/io.lovelace.0
      tcp        0      0 192.168.1.251:8701      0.0.0.0:*               LISTEN      1001       42088993   4503/io.hm-rpc.3
      tcp        0      0 0.0.0.0:2023            0.0.0.0:*               LISTEN      1001       42089126   4632/io.shelly.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42088726   4305/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42090513   4305/iobroker.js-co
      tcp        0      0 192.168.1.251:49292     0.0.0.0:*               LISTEN      1001       42090005   4488/io.hm-rpc.2
      tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          5652559    12204/node
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12300      1/init
      tcp        0      0 0.0.0.0:50001           0.0.0.0:*               LISTEN      1001       42093859   5245/io.sia.0
      tcp        0      0 192.168.1.251:42001     0.0.0.0:*               LISTEN      1001       42088247   4458/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14888      400/sshd
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       42096728   5308/io.upnp.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      0          5652562    12204/node
      tcp6       0      0 :::3501                 :::*                    LISTEN      1001       42088329   4566/io.sonos.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2523       1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       42088772   4326/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       42092359   5372/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14890      400/sshd
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       42095759   5533/io.fullybrowse
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       42090843   4533/io.mihome-vacu
      udp        0      0 192.168.1.251:5353      0.0.0.0:*                           1001       42090232   4616/io.tr-064.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12301      1/init
      udp        0      0 0.0.0.0:50001           0.0.0.0:*                           1001       42093860   5245/io.sia.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       42092344   5308/io.upnp.0
      udp        0      0 0.0.0.0:42883           0.0.0.0:*                           1001       42094828   5308/io.upnp.0
      udp6       0      0 :::111                  :::*                                0          2526       1/init
      2023-11-20 13:33:20.553  - info: host.IoBroker "system.adapter.onvif.0" disabled
      2023-11-20 13:33:26.814  - error: onvif.0 (5601) adapter disabled
      2023-11-20 13:33:26.826  - warn: javascript.0 (4353) getState "system.adapter.onvif.0.cpu" not found (3)
      2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at tabelle_generieren (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:56:20)
      2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at Object.<anonymous> (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:92:3)
      2023-11-20 13:33:26.827  - warn: javascript.0 (4353) getState "system.adapter.onvif.0.memHeapUsed" not found (3)
      2023-11-20 13:33:26.827  - warn: javascript.0 (4353)     at tabelle_generieren (script.js.common.0_userdata_0_.Home.Status.Adapter.adapterstatus:61:20)
      2023-11-20 13:33:26.861  - warn: onvif.0 (5601) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      2023-11-20 13:33:27.457  - error: host.IoBroker instance system.adapter.onvif.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2023-11-20 13:33:27.458  - info: host.IoBroker Do not restart adapter system.adapter.onvif.0 because disabled or deleted
      2023-11-20 13:33:34.843  - info: mihome-vacuum.0 (4533) create states for mop
      2023-11-20 13:33:34.846  - info: mihome-vacuum.0 (4533) change states from State control.fan_power
      2023-11-20 13:33:34.846  - info: mihome-vacuum.0 (4533) create states for water box
      2023-11-20 13:33:34.850  - info: mihome-vacuum.0 (4533) create states for water box mode
      2023-11-20 13:33:34.922  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011242.roomFanPower
      2023-11-20 13:33:34.922  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011304.roomFanPower
      2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.218001011305.roomFanPower
      2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room1.roomFanPower
      2023-11-20 13:33:34.923  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room16.roomFanPower
      2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room17.roomFanPower
      2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room18.roomFanPower
      2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room19.roomFanPower
      2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room2.roomFanPower
      2023-11-20 13:33:34.924  - info: mihome-vacuum.0 (4533) change states from State control.fan_power mihome-vacuum.0.rooms.room20.roomFanPower
      • XBiTX XBiT
        Log:
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        host.IoBroker
        onvif.0
        onvif.0
        onvif.0
        onvif.0
        onvif.0
        onvif.0
        iob_diag:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        stephan
        /home/stephan
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:          6.1G          0B        6.1G
        Total:          22G        3.4G         16G
                 3423 M used memory
                10474 M free memory
                  482 M buffer memory
                 1662 M swap cache
                 6140 M total swap
                    0 M used swap
                 6140 M free swap
        *** FILESYSTEM ***
        /var:
        565M    /var/
        392M    /var/cache
        385M    /var/cache/apt
        156M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        30217
        States:         24890
        Pending Updates: 0
        #236
        @xbit sagte in Test Adapter onvif camera v1.0.0:
        buster
        Muss durch ein lebendes Release ersetzt werden.
        Deutlich zu viele GitHub-Installationen. Du führst für alle diese Adapter Alpha-Testings durch?
        Wage ich zu bezweifeln.
          buster
          XBiTX Online
          XBiTX Online
          XBiT
          #237
          Okay auf bullseye kann ich wechseln aber die 11 git Adapter kommen doch schnell zusammen (hier der Adapter, Lovelace, energiefluss-erweiter usw.)...
          Werde berichten ob der Adapter danach läuft.
            micw42
            #238
            Ich habe auch buster. Ist bullseye denn jetzt Voraussetzung für iobroker?
            Alle anderen Adapter laufen reibungslos.
            • XBiTX XBiT
              #239
              @xbit
              Bookworm / Debian 12 ist das aktuelle Stable-Release.
              • M micw42
                #240
                Ein stabiles Release ist allgemeine Voraussetzung. Der Hersteller hat Debian 10 halt abgekündigt, da passiert nix mehr.
                  @xbit
                  XBiTX Online
                  XBiTX Online
                  XBiT
                  #241
                  Update ist durch
                  stephan@IoBroker:~$ cat /etc/os-release
                  PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                  NAME="Debian GNU/Linux"
                  VERSION_ID="12"
                  VERSION="12 (bookworm)"
                  VERSION_CODENAME=bookworm
                  ID=debian
                  HOME_URL="https://www.debian.org/"
                  SUPPORT_URL="https://www.debian.org/support"
                  BUG_REPORT_URL="https://bugs.debian.org/"
                  aber leider startet der Adapter noch nicht.
                  • T tombox
                    @knusterus Ja vielleicht mal Hersteller wegen onvif events anfragen
                    Knusterus
                    #242
                    @tombox
                    So Antwort von Ctronics ist da .
                    Die Kamera unterstützt nur ONVIF Profil S , damit werden keine Events übertragen.
                    Naja ist nicht schlimm die Kamera ist ja auch schon 4 Jahre alt.
                    Danke für die Hilfe
                    Knusterus
                    • David G.D Online
                      David G.D Online
                      David G.
                      #243
                      Wollte mir den Adapter auch gerade mal anschauen.
                      Allerdings möchte die Installation nicht durchlaufen.
                      $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
                      install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f
                      NPM version: 10.2.3Installing iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f... (System call)
                      npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
                      npm ERR! code 2
                      host.iobroker Cannot install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f: 2
                      ERROR: Process exited with code 25
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***                                            Static hostname: iobroker
                               Chassis: vm 🖴
                        Virtualization: kvm
                      Operating System: Debian GNU/Linux 12 (bookworm)                        Kernel: Linux 6.1.0-13-amd64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                      model name      : 12th Gen Intel(R) Core(TM) i3-12100
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                       16:16:13 up 6 days,  4:40,  2 users,  load average: 0.84, 0.96, 0.64
                      CPU threads: 1
                                     Local time: Thu 2023-12-28 16:16:13 CET
                                 Universal time: Thu 2023-12-28 15:16:13 UTC
                                       RTC time: Thu 2023-12-28 15:16:13
                                    NTP service: active
                                RTC in local TZ: no
                      iobroker
                      /home/iobroker
                      iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            7.3G        4.0G        2.1G        487K        1.5G        3.3G
                      Swap:           1.0G        520K        1.0G
                      Total:          8.3G        4.0G        3.1G
                               6933 M total memory
                               3787 M used memory
                                744 M active memory
                               3703 M inactive memory
                               1995 M free memory
                                250 M buffer memory
                               1195 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.4G     0  3.4G   0% /dev
                      tmpfs          tmpfs     694M  520K  693M   1% /run
                      /dev/sda1      ext4       31G  9.3G   20G  32% /
                      tmpfs          tmpfs     3.4G     0  3.4G   0% /dev/shm
                      tmpfs          tmpfs     694M     0  694M   0% /run/user/1000
                      [sudo] password for iobroker:
                      [Fri Dec 22 11:35:23 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                      [Fri Dec 22 11:35:23 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
                      /var:
                      1.3G    /var/
                      575M    /var/log
                      559M    /var/log/journal/c2f62aa20c614a09b8a2622bde83939a
                      531M    /var/cache
                      Archived and active journals take up 79.1M in the file system.
                      1.1G    /opt/iobroker/backups/
                      1.1G    /opt/iobroker/iobroker-data/
                      717M    /opt/iobroker/iobroker-data/files
                      278M    /opt/iobroker/iobroker-data/backup-objects
                      153M    /opt/iobroker/iobroker-data/files/vis-2
                      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
                      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      34M     /opt/iobroker/iobroker-data/states.jsonl
                      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
                      /usr/bin/nodejs         v18.19.0
                      /usr/bin/node           v18.19.0
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      /usr/bin/corepack       0.22.0
                      nodejs:
                        Installed: 18.19.0-1nodesource1
                        Candidate: 18.19.0-1nodesource1
                        Version table:
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                       *** 18.19.0-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      js-controller:  5.0.12
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapters from github:   8
                      Adapter State
                      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                      + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
                      + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
                        system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                      + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        system.adapter.daswetter.1              : daswetter             : iobroker                                 - disabled
                        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
                      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                        system.adapter.devices.0                : devices               : iobroker                                 - disabled
                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                      + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
                        system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                        system.adapter.iceroad.0                : iceroad               : iobroker                                 - disabled
                        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                      + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                        system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
                      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                      + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                        system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
                      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                        system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
                        system.adapter.parcel.1                 : parcel                : iobroker                                 - disabled
                        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                      + system.adapter.places.0                 : places                : iobroker                                 -  enabled
                      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                        system.adapter.proxy.0                  : proxy                 : iobroker                                 - disabled
                        system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                      + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                        system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
                        system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.telegram.1               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
                        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 - disabled
                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                        system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                      + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
                      + instance is alive
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
                      Adapter    "adb"          : 0.0.7    , installed 0.0.7
                      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                      Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
                      Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                      Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                      Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                      Adapter    "email"        : 1.2.1    , installed 1.2.0  [Updatable]
                      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                      Adapter    "hass"         : 1.4.0    , installed 1.4.0
                      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                      Adapter    "icons-material-png": 0.1.0, installed 0.1.1
                      Adapter    "imap"         : 0.1.1    , installed 0.1.1
                      Adapter    "iot"          : 2.0.11   , installed 2.0.11
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                      Controller "js-controller": 5.0.17   , installed 5.0.12 [Updatable]
                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                      Adapter    "lovelace"     : 3.0.1    , installed 4.0.12
                      Adapter    "moma"         : 1.2.9    , installed 1.2.9
                      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                      Adapter    "nina"         : 0.0.25   , installed 0.0.25
                      Adapter    "notification-manager": 1.0.0, installed 1.0.0
                      Adapter    "nut"          : 1.6.0    , installed 1.6.0
                      Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                      Adapter    "parcel"       : 0.0.27   , installed 0.1.1
                      Adapter    "parser"       : 2.0.7    , installed 2.0.7
                      Adapter    "places"       : 1.1.2    , installed 1.1.2
                      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
                      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                      Adapter    "reolink"      : 1.0.2    , installed 1.0.2
                      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
                      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                      Adapter    "telegram"     : 3.0.1    , installed 3.0.0  [Updatable]
                      Adapter    "telegram-menu": 1.5.1    , installed 0.8.5  [Updatable]
                      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                      Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
                      Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
                      Objects and States
                      Objects:        32736
                      States:         29860
                      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                      Pending Updates: 6
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       10986669   1474482/iobroker.js
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       10986662   1474482/iobroker.js
                      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       10989477   1475102/adb
                      tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1000       10987316   1474629/io.hm-rpc.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       10988468   1474941/io.sonoff.0
                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       10987646   1474704/io.mqtt.0
                      tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1000       10988338   1474919/io.shelly.0
                      tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1000       10987374   1474644/io.hm-rpc.1
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13251      1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16486      534/sshd: /usr/sbin
                      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       10993483   1476066/io.lovelace
                      tcp6       0      0 :::8092                 :::*                    LISTEN      1000       10993587   1476106/io.lovelace
                      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       10994313   1476222/io.web.1
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       10994197   1476204/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       10986790   1474500/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       10993665   1476123/io.simple-a
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13257      1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          16500      534/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       10995213   1476298/io.upnp.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14482      425/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13254      1/init
                      udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1000       10989088   1474991/io.tr-064.0
                      udp6       0      0 :::111                  :::*                                0          13260      1/init
                      2023-12-28 16:13:16.540  - info: fb-checkpresence.0 (1476275) createFbDeviceObjects finished successfully
                      2023-12-28 16:13:16.541  - info: fb-checkpresence.0 (1476275) states successfully subscribed
                      2023-12-28 16:13:16.541  - info: fb-checkpresence.0 (1476275) loop successfully started
                      2023-12-28 16:14:17.666  - info: host.iobroker iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
                      2023-12-28 16:14:18.869  - info: host.iobroker iobroker install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f
                      2023-12-28 16:14:19.270  - info: host.iobroker iobroker NPM version: 10.2.3Installing iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f... (System call)2023-12-28 16:14:27.410  - info: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
                      2023-12-28 16:14:31.684  - info: host.iobroker iobroker npm ERR! code 2
                      2023-12-28 16:14:31.686  - info: host.iobroker iobroker npm ERR! path /opt/iobroker/node_modules/json2iob
                      2023-12-28 16:14:31.692  - info: host.iobroker iobroker npm ERR! command failed
                      2023-12-28 16:14:31.693  - info: host.iobroker iobroker npm ERR! command sh -c npm run build
                      2023-12-28 16:14:31.694  - info: host.iobroker iobroker npm ERR! > json2iob@2.6.0 build
                      2023-12-28 16:14:31.695  - info: host.iobroker iobroker npm ERR! > tsc
                      2023-12-28 16:14:31.696  - info: host.iobroker iobroker npm ERR!
                      2023-12-28 16:14:31.697  - info: host.iobroker iobroker npm ERR! error TS2688: Cannot find type definition file for 'bl'.
                      2023-12-28 16:14:31.698  - info: host.iobroker iobroker npm ERR!   The file is in the program because:
                      2023-12-28 16:14:31.699  - info: host.iobroker iobroker npm ERR!     Entry point for implicit type library 'bl'
                      2023-12-28 16:14:31.701  - info: host.iobroker iobroker
                      2023-12-28 16:14:31.702  - info: host.iobroker iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T15_14_19_468Z-debug-0.log
                      2023-12-28 16:14:31.749  - error: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git npm ERR! code 2npm ERR! path /opt/iobroker/node_modules/json2iobnpm ERR! command failednpm ERR! command sh -c npm run buildnpm ERR! > json2iob@2.6.0 buildnpm ERR! > tscnpm ERR! npm ERR! error TS2688: Cannot find type definition file for 'bl'.npm ERR!   The file is in the program because:npm ERR!     Entry point for implicit type library 'bl'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T15_14_19_Copy text starting here:
                      • wendy2702W Online
                        wendy2702W Online
                        #244
                        @david-g
                        https://forum.iobroker.net/search?term=Error 25&in=titlesposts
                        • David G.D David G.
                          npm ERR! code 2
                          Skript v.2023-10-10
                                   Chassis: vm 🖴
                            Virtualization: kvm
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 1
                                        NTP service: active
                                    RTC in local TZ: no
                          iobroker
                          /home/iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                                   6933 M total memory
                                   3787 M used memory
                                    744 M active memory
                                   1995 M free memory
                                    250 M buffer memory
                                   1195 M swap cache
                                    974 M total swap
                                      0 M used swap
                                    974 M free swap
                          *** FILESYSTEM ***
                          /var:
                          1.3G    /var/
                          575M    /var/log
                          531M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        32736
                          States:         29860
                          Pending Updates: 6
                          #245
                          @david-g
                          Hau die anderen Updates drauf. Insbesondere den js-controller.
                          • David G.D Online
                            David G.D Online
                            David G.
                            #246
                            @wendy2702 sagte in Test Adapter onvif camera v1.0.0:
                            @david-g
                            Die Lösungen zu dem Problem sind so weit ich weiß in iob fix eingebaut.
                            @thomas-braun sagte in Test Adapter onvif camera v1.0.0:
                            @david-g
                            Habe alles aktualisiert. Meldung bleibt identisch.
                            Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                              @david-g
                              @david-g
                              #247
                              @david-g sagte in Test Adapter onvif camera v1.0.0:
                              Muss aber was individuelles bei dir sein, hier läuft es nämlich einwandfrei durch:
                              echad@chet:~ $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --debug
                              NPM version: 10.2.4
                              added 29 packages, removed 149 packages, and changed 1 package in 26s
                              106 packages are looking for funding
                                run `npm fund` for details
                              upload [1] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/onvif.png onvif.png image/png
                              echad@chet:~ $
                                @david-g
                                @david-g
                                wendy2702W Online
                                wendy2702W Online
                                #248
                                Ist das so? Dann habe ich das nicht mitbekommen.
                                Kann aber auch nicht sehen das der Fix lief.
                                • wendy2702W wendy2702
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #249
                                  Jepp,
                                  kann es leider nicht zitieren.
                                  Oh, muss ich versehentlich gelöscht haben, als ich das Ergebnis vom iob diag von der Kurz- zu Langfassung abgeändert habe...
                                  wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                                    Jepp,
                                    wendy2702W Online
                                    wendy2702W Online
                                    #250
                                    @david-g OK.
                                    Da steht aber auch „sollte“ was für mich keine 100% Garantie ist das es auch wirklich dein spezielles Problem löst.
                                      Jepp,
                                      #251
                                      @david-g
                                      Das ist aber kein Fix zu deinem Problem. Das ist was anderes bei dir.
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        #252
                                        Nach den Updates und einem erneuten iob fix hat sich die Meldung verändert:
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T17_56_02_375Z-debug-0.log
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git npm ERR! code 2npm ERR! path /opt/iobroker/node_modules/json2iobnpm ERR! command failednpm ERR! command sh -c npm run buildnpm ERR! > json2iob@2.6.0 buildnpm ERR! > tscnpm ERR! npm ERR! error TS2688: Cannot find type definition file for 'bl'.npm ERR! The file is in the program because:npm ERR! Entry point for implicit type library 'bl'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T17_56_02_375Z-debug-0.loghost.iobroker Cannot install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f: 2
                                        Suche das Log nachher mal raus was da steht.
                                        EDIT
                                        Hier der Inhalt der Logdatei:
                                        0 verbose cli /usr/bin/node /usr/bin/npm
                                        1 info using npm@10.2.3
                                        2 info using node@v18.19.0
                                        3 timing npm:load:whichnode Completed in 10ms
                                        4 timing config:load:defaults Completed in 2ms
                                        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
                                        6 timing config:load:builtin Completed in 5ms
                                        7 timing config:load:cli Completed in 2ms
                                        8 timing config:load:env Completed in 0ms
                                        9 timing config:load:file:/opt/iobroker/node_modules/json2iob/.npmrc Completed in 0ms
                                        10 timing config:load:project Completed in 2ms
                                        11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                                        12 timing config:load:user Completed in 1ms
                                        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                        14 timing config:load:global Completed in 0ms
                                        15 timing config:load:setEnvs Completed in 1ms
                                        16 timing config:load Completed in 13ms
                                        17 timing npm:load:configload Completed in 13ms
                                        18 timing config:load:flatten Completed in 2ms
                                        19 timing npm:load:mkdirpcache Completed in 0ms
                                        20 timing npm:load:mkdirplogs Completed in 0ms
                                        21 verbose title npm run build
                                        22 verbose argv "run" "build"
                                        23 timing npm:load:setTitle Completed in 1ms
                                        24 timing npm:load:display Completed in 0ms
                                        25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-12-28T17_56_12_453Z-
                                        26 verbose logfile /home/iobroker/.npm/_logs/2023-12-28T17_56_12_453Z-debug-0.log
                                        27 timing npm:load:logFile Completed in 6ms
                                        28 timing npm:load:timers Completed in 0ms
                                        29 timing npm:load:configScope Completed in 1ms
                                        30 timing npm:load Completed in 41ms
                                        31 silly logfile start cleaning logs, removing 1 files
                                        32 silly logfile done cleaning log files
                                        33 timing command:run Completed in 2634ms
                                        34 verbose exit 2
                                        35 timing npm Completed in 2705ms
                                        36 verbose code 2
                                        • Thomas BraunT Online
                                          #253
                                          @david-g
                                          Da geht ein build in die Hose. Das Modul muss nichtmal was mit onvif zu tun haben. Solange das da quer in der Pipeline hängt geht da nix mehr.
