  4. Zigbee Stick spinnt *gelöst*
    5.1k
78 Beiträge 8 Kommentatoren 8.2k Aufrufe 8 Beobachtet
  • GlasfaserG Glasfaser
    @gluecksmann
    Zeige mal bitte die Ganze Full ausgabe davon , nicht nur ein Schnipsel , sieht schon merkwürdig aus .
    vorher noch
    sudo reboot
    dann
    iob diag
    gluecksmann
    @glasfaser
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     14:15:23 up 3 min,  1 user,  load average: 1.50, 1.08, 0.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-12-28 14:15:23 CET
               Universal time: Thu 2023-12-28 13:15:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        1.2G        6.4G        8.0M        316M        6.5G
    Swap:           99M          0B         99M
    Total:         8.0G        1.2G        6.5G
             7898 M total memory
             1153 M used memory
              149 M active memory
             1229 M inactive memory
             6428 M free memory
               53 M buffer memory
              263 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * lightdm.service loaded failed failed Light Display Manager
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  50% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    412M    /var/
    118M    /var/lib
    102M    /var/cache
    90M     /var/cache/apt
    89M     /var/log
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    60M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    616M    /opt/iobroker/iobroker-data/
    329M    /opt/iobroker/iobroker-data/files
    143M    /opt/iobroker/iobroker-data/backup-objects
    93M     /opt/iobroker/iobroker-data/sonosCache
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
    npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T13_15_38_542Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T13_16_01_385Z-debug-0.log
    Adapters from github:   2
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.25   , installed 1.8.25
    Objects and States
    Objects:        11295
    States:         9361
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18008      642/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14831      363/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20705      999/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18400      632/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19317      632/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      642/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14830      363/cupsd
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21820      980/io.sonos.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19741      1036/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19742      1036/io.tuya.0
    udp        0      0 0.0.0.0:37928           0.0.0.0:*                           1001       21652      911/io.philips-air.
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21575      856/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18449      631/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16300      460/cups-browsed
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24005      1320/io.musiccast.0
    udp        0      0 0.0.0.0:60062           0.0.0.0:*                           108        17435      356/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17433      356/avahi-daemon: r
    udp        0    704 0.0.0.0:48886           0.0.0.0:*                           1001       21952      1017/io.philips-air
    udp6       0      0 :::546                  :::*                                0          18466      631/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        17434      356/avahi-daemon: r
    udp6       0      0 :::39823                :::*                                108        17436      356/avahi-daemon: r
    2023-12-28 14:14:31.136  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
    2023-12-28 14:14:31.153  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
    2023-12-28 14:14:31.159  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
    2023-12-28 14:14:31.175  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
    2023-12-28 14:14:31.181  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-28 14:14:31.187  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-28 14:14:43.281  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
    2023-12-28 14:15:00.131  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 3526
    2023-12-28 14:15:03.497  - info: dwd.0 (3526) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
    2023-12-28 14:15:04.149  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 3748
    2023-12-28 14:15:05.756  - info: dwd.0 (3526) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-28 14:15:06.406  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-28 14:15:08.046  - info: daswetter.0 (3748) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.17
    2023-12-28 14:15:08.160  - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 3830
    2023-12-28 14:15:12.777  - info: weatherunderground.0 (3830) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.19.0, js-controller: 5.0.17
    2023-12-28 14:15:16.942  - error: weatherunderground.0 (3830) no observations in response from https://api.weather.com/v3/wx/observations/current?apiKey=e1f10a1e78da46f5b10a1e78da96f525&geocode=0%2C0&units=m&language=de&format=json
    2023-12-28 14:15:17.338  - error: weatherunderground.0 (3830) WUnderground reported an error: --/{"message":"connect ECONNREFUSED 127.0.0.1:80","name":"Error","stack":"Error: connect ECONNREFUSED 127.0.0.1:80\n    at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14)\n    at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:606:25)\n    at RedirectableRequest.emit (node:events:529:35)\n    at RedirectableRequest.emit (node:domain:489:12)\n    at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)\n    at ClientRequest.emit (node:events:529:35)\n    at ClientRequest.emit (node:domain:489:12)\n    at Socket.socketErrorListener (node:_http_client:501:9)\n    at Socket.emit (node:events:517:28)\n    at Socket.emit (node:domain:489:12)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":15000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8","User-Agent":"Mozilla/5.0 (Windows) Gecko/20100101 Firefox/68.0","Accept-Language":"de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":""},"code":"ECONNREFUSED","status":null}
    2023-12-28 14:15:17.344  - error: weatherunderground.0 (3830) No current observation data found in response
    2023-12-28 14:15:19.147  - error: weatherunderground.0 (3830) No forecast data found in response
    2023-12-28 14:15:21.159  - info: weatherunderground.0 (3830) Terminated (NO_ERROR): Without reason
    2023-12-28 14:15:21.703  - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-12-28 14:15:25.601  - info: daswetter.0 (3748) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-12-28 14:15:26.119  - info: daswetter.0 (3748) cleaned everything up...
    2023-12-28 14:15:26.137  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-28 14:16:48.051  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
    • G gluecksmann
      @glasfaser
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               7898 M total memory
               1153 M used memory
                149 M active memory
               6428 M free memory
                 53 M buffer memory
                263 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      412M    /var/
      118M    /var/lib
      102M    /var/cache
      90M     /var/cache/apt
      89M     /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11295
      States:         9361
      Pending Updates: 0
      GlasfaserG Offline
      GlasfaserG Offline
      @gluecksmann
      iob admin start
      • G gluecksmann
        @glasfaser
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M          0B         99M
                 7898 M total memory
                 1153 M used memory
                  149 M active memory
                 6428 M free memory
                   53 M buffer memory
                  263 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        412M    /var/
        118M    /var/lib
        102M    /var/cache
        90M     /var/cache/apt
        89M     /var/log
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11295
        States:         9361
        Pending Updates: 0
        @gluecksmann
        sudo systemctl set-default multi-user.target
        Installier die nochmal:
        Und dein Betriebssystem ist tot. Installier da was lebendiges.
        G 1 Antwort Letzte Antwort
          @gluecksmann
          gluecksmann
          schrieb am zuletzt editiert von gluecksmann
          @thomas-braun sagte in Zigbee Stick spinnt:
          Hallo, wie DU siehst bin ich da nicht wirklich geschickt... Eine komplette Neuinstallation würde das Forum überfordern... Wenn dann bräuchte ich da auf anderem Wege Support. Komme leider immer noch nicht an die Admin Seite
          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
          • G gluecksmann
            @gluecksmann
            Backup nach extern ziehen, Neuinstallation danach:
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            Backup wieder einspielen. Fertig.
              @gluecksmann
              gluecksmann
              Da gibt es ja scheibar mehrere Verisionen..... Was genau ist denn bei mir alt? Mache doch immer Updates? Und wie man ein Update extern sichert habe ich auch noch nicht raus...
              • G gluecksmann
                GlasfaserG Offline
                GlasfaserG Offline
                @gluecksmann sagte in Zigbee Stick spinnt:
                Das heißt ... Fehlermeldung ..oder...
                ist er im "iob diag "Log jetzt enable !?
                • G gluecksmann
                  Dein Betriebssystem in der Version Raspberry / Debian 10 'Buster'.
                  Unterstützt wird Version 11 und 12.
                  • G gluecksmann
                    Mit dem Backitup-Adapter...
                    Wie/wo machst du denn derzeitig Backups?
                      gluecksmann
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                       14:33:41 up 21 min,  1 user,  load average: 0.61, 0.55, 0.54
                      CPU threads: 4
                      Current issues:
                                     Local time: Thu 2023-12-28 14:33:41 CET
                                 Universal time: Thu 2023-12-28 13:33:41 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:           7.9G        1.2G        6.2G        8.0M        551M        6.5G
                      Swap:           99M          0B         99M
                      Total:         8.0G        1.2G        6.3G
                               7898 M total memory
                               1162 M used memory
                                292 M active memory
                               1304 M inactive memory
                               6185 M free memory
                                 99 M buffer memory
                                451 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      412M    /var/
                      118M    /var/lib
                      102M    /var/cache
                      90M     /var/cache/apt
                      89M     /var/log
                      626M    /opt/iobroker/iobroker-data/
                      22M     /opt/iobroker/iobroker-data/objects.jsonl
                      12M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T13_33_49_495Z-debug-0.log
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T13_34_11_407Z-debug-0.log
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        11295
                      States:         9341
                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Pending Updates: 0
                      2023-12-28 14:32:13.730  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
                      2023-12-28 14:32:13.748  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:13.754  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
                      2023-12-28 14:32:13.769  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:13.773  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:13.777  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.852  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.863  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.882  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.892  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
                      2023-12-28 14:32:17.963  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.973  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.990  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:17.995  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
                      2023-12-28 14:32:18.008  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:18.014  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:18.019  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
                      2023-12-28 14:32:18.029  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                      2023-12-28 14:32:48.028  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                      2023-12-28 14:33:18.030  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                      2023-12-28 14:33:26.429  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
                      2023-12-28 14:33:48.030  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                      2023-12-28 14:34:18.030  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                      2023-12-28 14:34:48.031  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                      2023-12-28 14:35:00.035  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 6771
                      • G gluecksmann
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm
                        Docker          : false
                        Kernel          : armv7l
                        Userland        : armhf
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           99M          0B         99M
                                 7898 M total memory
                                 1162 M used memory
                                  292 M active memory
                                 6185 M free memory
                                   99 M buffer memory
                                  451 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        412M    /var/
                        118M    /var/lib
                        102M    /var/cache
                        90M     /var/cache/apt
                        89M     /var/log
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        11295
                        States:         9341
                        Pending Updates: 0
                        @gluecksmann
                        iob start admin
                          @gluecksmann
                          iob start admin
                          gluecksmann
                          iob start admin
                          Scheint jetzt endlich geklappt zu haben... Backup extern... So eine Sicherung braucht ja nicht viel Platz,oder? Google Drive würde ja reichen...
                            gluecksmann
                            Könnte ich theoretisch einfach eine andere Speicherkarte nehmen um diesen "Versuch" zu starten? Speicherung sollte ja jetzt extren funktioniert haben...
                            Und...wäre es in diesem Zuge Sinnvoll gleich einen neuen Zigbee Stick zu installieren? Denke ich muss bei einem neuem Zigbee Stick auch alles neu anlernen?
                            • G gluecksmann
                              iob start admin
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              Das ist aber eine sehr pauschale Frage und hängt natürlich vom Umfang der Sicherung ab.
                              Ich sichere z.B. über backitup adapter und das umfasst iobroker selbst, alle Skripte, Zigbee und die Historywerte (falls du history adapter nutzt). Und weils so schön ist auch noch homematic :-) macht alles zusammen ca 450 MB pro Sicherung.
                              • amg_666A amg_666
                                gluecksmann
                                @amg_666
                                An Histoy hab ich mich nich nicht dran getraut... Hab auch nur Iobriker... DAs eine Sicherung aus 3 Dateien besteht ist richtig?
                                G amg_666A 2 Antworten Letzte Antwort
                                • G gluecksmann
                                  @amg_666
                                  gluecksmann
                                  @gluecksmann
                                  Jetzt wo es scheinbar wieder läuft, bin ich wieder an dem Punk das nach Aufruf des Zigbee Adapters die Fehlermeldug "You need save and run adapter before pairing!" kommt...bin also da wo ich angefangen habe...
                                  R 1 Antwort Letzte Antwort
                                  • G gluecksmann
                                    @amg_666
                                    amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    @gluecksmann Wieso besteht eine Sicherung aus 3 Dateien? Das hängt doch davon ab, was du im backup-Adapter ausgewählt hast.
                                    Aber falls es dir weiterhilft: iobroker selbst braucht bei mir inkl aller Skripts und Zigbee nur 16 MB je Sicherung. Aber das hängt natürlich auch davon ab wieviele Adapter und wieviele und wie große Skripte.
                                    • G gluecksmann
                                      @gluecksmann
                                      reutli
                                      @gluecksmann
                                      und in den Einstellungen des Adapters steht beim COM-Port das Ergebnis aus
                                      ls -la /dev/serial/by-id/
                                      Zeige mal die Einstellungen des Adapters...
                                      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                      *Wer freundlich ist, dem wird freundlich geholfen *
                                      • R reutli
                                        @gluecksmann
                                        gluecksmann
                                        @reutli sagte in Zigbee Stick spinnt:
                                        pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
                                        insgesamt 0
                                        drwxr-xr-x 2 root root 60 Dez 28 14:11 .
                                        drwxr-xr-x 4 root root 80 Dez 28 14:11 ..
                                        lrwxrwxrwx 1 root root 13 Dez 28 14:11 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00 -> ../../ttyACM0
                                        pi@raspberrypi:~ $
                                        • G gluecksmann
                                          insgesamt 0
                                          pi@raspberrypi:~ $
                                          reutli
                                          insgesamt 0
                                          pi@raspberrypi:~ $
                                          und wo ist
