  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
120 Beiträge 4 Kommentatoren 17.0k Aufrufe 2 Beobachtet
  • R Radix75
    So neue SD Karte neues Glück ich fange nochmal bei Null an!
    Ich habe auch absichtlich nur den IO Broker installiert und würde gerne Fehler Stück für Stück beheben
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-2712
        Architecture: arm64
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:28:33 up 26 min,  3 users,  load average: 0.36, 0.17, 0.05
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-12-27 20:28:34 CET
               Universal time: Wed 2023-12-27 19:28:34 UTC
                     RTC time: Wed 2023-12-27 19:28:34
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    Radix1975
    /home/Radix1975
    Radix1975 adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.4G        503M        7.2G        5.9M        799M        7.9G
    Swap:           104M          0B        104M
    Total:          8.5G        503M        7.3G
             8049 M total memory
              481 M used memory
              451 M active memory
              529 M inactive memory
             6904 M free memory
               45 M buffer memory
              717 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    vc_gencmd_read_response returned -1
    error=1 error_msg="Command not registered"
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     805M  5.7M  800M   1% /run
    /dev/mmcblk0p2 ext4       59G  2.9G   53G   6% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     805M     0  805M   0% /run/user/1000
    [Wed Dec 27 20:02:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BC:98:3F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=9ad9f164-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
    [Wed Dec 27 20:02:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
    [Wed Dec 27 20:02:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    566M    /var/
    262M    /var/cache
    255M    /var/cache/apt
    163M    /var/lib
    144M    /var/cache/apt/archives
    Archived and active journals take up 40.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    19M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
    2.9M    /opt/iobroker/iobroker-data/states.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionD        etai-57e02d.0886b730.chunk.js.map
    920K    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE19626        17-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi5        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
    + system.adapter.backitup.0               : backitup              : raspberrypi5        -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi5        -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    Objects and States
    Objects:        138
    States:         104
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25626      4179/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          17659      832/vncserver-x11-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16670      822/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15733      822/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15689      821/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          25628      4179/sshd: /usr/sbi
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          17658      832/vncserver-x11-c
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15688      821/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14874      884/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        17419      637/avahi-daemon: r
    udp        0      0 0.0.0.0:48785           0.0.0.0:*                           104        17421      637/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14949      949/cups-browsed
    udp6       0      0 :::5353                 :::*                                104        17420      637/avahi-daemon: r
    udp6       0      0 :::36885                :::*                                104        17422      637/avahi-daemon: r
    udp6       0      0 fe80::1bc9:5af2:f2b:546 :::*                                0          17712      776/NetworkManager
    2023-12-27 20:02:36.843  - info: host.raspberrypi5 Delete state "system.host.raspberrypi5.versions.npmNewestNext"
    2023-12-27 20:02:36.845  - info: host.raspberrypi5 Some obsolete host states deleted.
    2023-12-27 20:02:38.005  - info: admin.0 (884) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
    2023-12-27 20:02:38.020  - info: admin.0 (884) requesting all objects
    2023-12-27 20:02:38.085  - warn: admin.0 (884) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
    2023-12-27 20:02:38.106  - info: admin.0 (884) received all objects
    2023-12-27 20:02:38.170  - warn: admin.0 (884) Repository cannot be read: Active repo - stable
    2023-12-27 20:02:38.170  - warn: admin.0 (884) Active repository "stable" cannot be read
    2023-12-27 20:02:38.290  - warn: admin.0 (884) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
    2023-12-27 20:02:38.303  - info: admin.0 (884) socket.io server listening on port 8081
    2023-12-27 20:02:38.304  - info: admin.0 (884) http server listening on port 8081
    2023-12-27 20:02:38.305  - info: admin.0 (884) Use link "http://127.0.0.1:8081" to configure.
    2023-12-27 20:02:38.310  - warn: admin.0 (884) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
    2023-12-27 20:02:40.787  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 942
    2023-12-27 20:02:41.564  - info: discovery.0 (942) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
    2023-12-27 20:02:44.784  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 964
    2023-12-27 20:02:45.485  - info: backitup.0 (964) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
    2023-12-27 20:02:45.513  - info: backitup.0 (964) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2023-12-27 20:08:45.530  - info: admin.0 (884) failed connection to socket.io from ::ffff:192.168.1.10: Passport was not initialized
    2023-12-27 20:08:49.762  - info: admin.0 (884) ==> Connected system.user.admin from ::ffff:192.168.1.10
    2023-12-27 20:08:49.975  - info: host.raspberrypi5 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-27 20:09:09.982  - error: host.raspberrypi5 Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    2023-12-27 20:09:36.578  - info: host.raspberrypi5 iobroker install deconz
    2023-12-27 20:09:37.292  - info: host.raspberrypi5 iobroker Update repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-27 20:09:58.358  - info: host.raspberrypi5 iobroker exit 0
    iob diag has finished.
    Press any key for a summary
    Bild der Adapterwebseite
    Fehlermeldung
    So warum kommt dieser Fehler?? es lassen sich keine Adapter oder instanzen fertig installieren
    HomoranH Offline
    HomoranH Offline
    #75
    @radix75 sagte in Daikin Adapter:
    anscheinend hast du immer noch Probleme mit dem Zugriff aufs Internet
    kannst du diese Seite öffnen?
    bei mir klappt das einwandfrei
    R 1 Antwort Letzte Antwort
      Radix75
      #76
      @homoran said in Daikin Adapter:
      Ich kann die Webseite im Browser am PC öffnen es kommt eine sehr große liste die ich hier nicht posten kann
      Muss ich den Port 8081 in der Fritzbox freigeben????
      R HomoranH 2 Antworten Letzte Antwort
      • R Radix75
        Radix75
        #77
        Hab mal schon ein Prr Checks gemacht sag mal was dazu ob ein Fehler sichtbar ist
        Radix1975@raspberrypi5:~ $ netstat -n -a -p TCP
        (Not all processes could be identified, non-owned process info
         will not be shown, you would have to be root to see it all.)
        Active Internet connections (servers and established)
        Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      -
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      -
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      -
        tcp        0      0 127.0.0.1:33806         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:51980         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:50920         ESTABLISHED -
        tcp        0      0 127.0.0.1:58100         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:33808         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:50906         ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:50890         ESTABLISHED -
        tcp        0      0 127.0.0.1:50888         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:58128         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:50890         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:58146         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:58112         ESTABLISHED -
        tcp        0      0 192.168.1.225:22        192.168.1.10:54425      ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:51942         ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:51976         ESTABLISHED -
        tcp        0      0 127.0.0.1:50906         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:51960         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:33778         ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:51956         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:33808         ESTABLISHED -
        tcp        0      0 127.0.0.1:58112         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:50912         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:50920         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:58100         ESTABLISHED -
        tcp        0      0 127.0.0.1:58110         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:51942         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:58110         ESTABLISHED -
        tcp        0      0 127.0.0.1:58146         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:58132         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:50912         ESTABLISHED -
        tcp        0      0 127.0.0.1:50882         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:51960         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:33806         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:58128         ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:51980         ESTABLISHED -
        tcp        0      0 127.0.0.1:51976         127.0.0.1:9001          ESTABLISHED -
        tcp        0      0 127.0.0.1:33796         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:50888         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:58132         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:33796         ESTABLISHED -
        tcp        0      0 127.0.0.1:33778         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:9001          127.0.0.1:50882         ESTABLISHED -
        tcp        0      0 127.0.0.1:9000          127.0.0.1:33780         ESTABLISHED -
        tcp        0      0 127.0.0.1:33780         127.0.0.1:9000          ESTABLISHED -
        tcp        0      0 127.0.0.1:51956         127.0.0.1:9001          ESTABLISHED -
        tcp6       0      0 :::22                   :::*                    LISTEN      -
        tcp6       0      0 :::5900                 :::*                    LISTEN      -
        tcp6       0      0 ::1:631                 :::*                    LISTEN      -
        tcp6       0      0 :::8081                 :::*                    LISTEN      -
        tcp6       0      0 192.168.1.225:8081      192.168.1.10:52751      TIME_WAIT   -
        tcp6       0      0 192.168.1.225:8081      192.168.1.10:52749      TIME_WAIT   -
        tcp6       0      0 192.168.1.225:8081      192.168.1.10:52752      TIME_WAIT   -
        tcp6       0      0 192.168.1.225:8081      192.168.1.10:52753      TIME_WAIT   -
        tcp6       0      0 192.168.1.225:8081      192.168.1.10:52750      TIME_WAIT   -
        tcp6       0      0 192.168.1.225:8081      192.168.1.10:52748      TIME_WAIT   -
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           -
        udp        0      0 0.0.0.0:48785           0.0.0.0:*                           -
        udp        0      0 192.168.1.225:68        192.168.1.1:67          ESTABLISHED -
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           -
        udp6       0      0 :::5353                 :::*                                -
        udp6       0      0 :::36885                :::*                                -
        udp6       0      0 fe80::1bc9:5af2:f2b:546 :::*                                -
        raw6       0      0 :::58                   :::*                    7           -
        Active UNIX domain sockets (servers and established)
        Proto RefCnt Flags       Type       State         I-Node   PID/Program name     Path
        unix  3      [ ]         STREAM     CONNECTED     15543    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     14587    -
        unix  3      [ ]         STREAM     CONNECTED     34052    -
        unix  2      [ ACC ]     STREAM     LISTENING     12098    -                    /run/avahi-daemon/socket
        unix  2      [ ]         DGRAM      CONNECTED     14549    -
        unix  3      [ ]         STREAM     CONNECTED     15839    -
        unix  2      [ ACC ]     STREAM     LISTENING     12101    -                    /run/cups/cups.sock
        unix  2      [ ]         DGRAM                    16828    989/systemd          /run/user/1000/systemd/notify
        unix  2      [ ACC ]     STREAM     LISTENING     12103    -                    /run/dbus/system_bus_socket
        unix  2      [ ACC ]     STREAM     LISTENING     16831    989/systemd          /run/user/1000/systemd/private
        unix  2      [ ACC ]     STREAM     LISTENING     12105    -                    /run/thd.socket
        unix  2      [ ACC ]     STREAM     LISTENING     16839    989/systemd          /run/user/1000/bus
        unix  3      [ ]         STREAM     CONNECTED     17591    -                    /run/systemd/journal/stdout
        unix  2      [ ACC ]     STREAM     LISTENING     16841    989/systemd          /run/user/1000/gnupg/S.dirmngr
        unix  3      [ ]         STREAM     CONNECTED     16564    -                    /run/systemd/journal/stdout
        unix  2      [ ACC ]     STREAM     LISTENING     16843    989/systemd          /run/user/1000/gnupg/S.gpg-agent.browser
        unix  2      [ ]         DGRAM      CONNECTED     12242    -
        unix  2      [ ACC ]     STREAM     LISTENING     16845    989/systemd          /run/user/1000/gnupg/S.gpg-agent.extra
        unix  2      [ ACC ]     STREAM     LISTENING     16847    989/systemd          /run/user/1000/gnupg/S.gpg-agent.ssh
        unix  3      [ ]         STREAM     CONNECTED     16833    989/systemd
        unix  2      [ ACC ]     STREAM     LISTENING     16849    989/systemd          /run/user/1000/gnupg/S.gpg-agent
        unix  3      [ ]         STREAM     CONNECTED     14795    -
        unix  3      [ ]         STREAM     CONNECTED     15535    -
        unix  3      [ ]         DGRAM      CONNECTED     14556    -
        unix  2      [ ]         DGRAM      CONNECTED     17649    -
        unix  3      [ ]         STREAM     CONNECTED     12148    -
        unix  2      [ ]         DGRAM      CONNECTED     14600    -
        unix  2      [ ]         STREAM     CONNECTED     34028    -
        unix  3      [ ]         STREAM     CONNECTED     16545    -
        unix  3      [ ]         DGRAM      CONNECTED     849      -
        unix  3      [ ]         STREAM     CONNECTED     14776    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     14840    -
        unix  2      [ ]         DGRAM      CONNECTED     17651    -                    /tmp/.vncserver-license/0.832
        unix  3      [ ]         STREAM     CONNECTED     15820    -
        unix  2      [ ACC ]     STREAM     LISTENING     17671    -                    /tmp/.vnc-vncservice/vncserver-x11.CtrlComms
        unix  3      [ ]         STREAM     CONNECTED     12155    -
        unix  3      [ ]         STREAM     CONNECTED     15687    -
        unix  3      [ ]         STREAM     CONNECTED     14592    -
        unix  3      [ ]         STREAM     CONNECTED     16784    989/systemd
        unix  3      [ ]         STREAM     CONNECTED     34053    -
        unix  3      [ ]         STREAM     CONNECTED     15904    -                    /run/dbus/system_bus_socket
        unix  2      [ ]         DGRAM      CONNECTED     16559    -
        unix  3      [ ]         STREAM     CONNECTED     15762    -
        unix  3      [ ]         STREAM     CONNECTED     14826    -
        unix  3      [ ]         STREAM     CONNECTED     15541    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     15044    -
        unix  3      [ ]         STREAM     CONNECTED     15542    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         DGRAM      CONNECTED     13460    -
        unix  3      [ ]         STREAM     CONNECTED     17540    -
        unix  3      [ ]         DGRAM      CONNECTED     14553    -
        unix  3      [ ]         STREAM     CONNECTED     15838    -
        unix  2      [ ]         DGRAM                    14794    -
        unix  3      [ ]         STREAM     CONNECTED     14760    -
        unix  3      [ ]         STREAM     CONNECTED     24830    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     14950    -
        unix  2      [ ]         DGRAM      CONNECTED     16805    989/systemd
        unix  3      [ ]         STREAM     CONNECTED     16562    -
        unix  2      [ ]         DGRAM      CONNECTED     844      -
        unix  3      [ ]         STREAM     CONNECTED     14656    -                    /run/systemd/journal/stdout
        unix  2      [ ]         DGRAM      CONNECTED     34039    -
        unix  3      [ ]         STREAM     CONNECTED     15819    -
        unix  3      [ ]         STREAM     CONNECTED     15544    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     14808    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     14595    -                    /run/systemd/journal/stdout
        unix  2      [ ]         DGRAM      CONNECTED     14839    -
        unix  2      [ ]         DGRAM      CONNECTED     17500    -
        unix  3      [ ]         STREAM     CONNECTED     14779    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     15856    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     12154    -
        unix  2      [ ]         DGRAM      CONNECTED     15546    -
        unix  3      [ ]         STREAM     CONNECTED     15761    -
        unix  3      [ ]         STREAM     CONNECTED     14491    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     14948    -
        unix  3      [ ]         DGRAM      CONNECTED     13461    -
        unix  3      [ ]         STREAM     CONNECTED     12160    -
        unix  3      [ ]         STREAM     CONNECTED     16563    -                    /run/systemd/journal/stdout
        unix  3      [ ]         DGRAM      CONNECTED     14554    -
        unix  3      [ ]         STREAM     CONNECTED     14888    -
        unix  2      [ ]         STREAM     CONNECTED     35867    -
        unix  3      [ ]         STREAM     CONNECTED     15841    -
        unix  3      [ ]         STREAM     CONNECTED     15547    -                    /run/dbus/system_bus_socket
        unix  2      [ ]         DGRAM      CONNECTED     17784    -
        unix  3      [ ]         STREAM     CONNECTED     12256    -
        unix  3      [ ]         STREAM     CONNECTED     14813    -
        unix  3      [ ]         STREAM     CONNECTED     16570    -                    /run/systemd/journal/stdout
        unix  2      [ ]         DGRAM                    16656    -                    /run/wpa_supplicant/wlan0
        unix  2      [ ]         DGRAM                    16661    -                    /run/wpa_supplicant/p2p-dev-wlan0
        unix  3      [ ]         STREAM     CONNECTED     17454    -
        unix  3      [ ]         STREAM     CONNECTED     853      -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     15588    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     15854    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     15818    -
        unix  2      [ ]         STREAM     CONNECTED     17653    -
        unix  3      [ ]         STREAM     CONNECTED     12145    -
        unix  3      [ ]         DGRAM      CONNECTED     16830    989/systemd
        unix  3      [ ]         STREAM     CONNECTED     15538    -
        unix  3      [ ]         STREAM     CONNECTED     14596    -
        unix  3      [ ]         STREAM     CONNECTED     16552    -
        unix  3      [ ]         STREAM     CONNECTED     15902    -
        unix  3      [ ]         STREAM     CONNECTED     15764    -
        unix  2      [ ]         DGRAM      CONNECTED     14837    -
        unix  2      [ ]         DGRAM      CONNECTED     12153    -
        unix  2      [ ]         DGRAM      CONNECTED     16794    -
        unix  3      [ ]         STREAM     CONNECTED     14588    -
        unix  3      [ ]         STREAM     CONNECTED     16868    -
        unix  2      [ ]         DGRAM      CONNECTED     15550    -
        unix  3      [ ]         STREAM     CONNECTED     14891    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     15586    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     17547    -
        unix  3      [ ]         DGRAM      CONNECTED     14555    -
        unix  3      [ ]         STREAM     CONNECTED     15840    -
        unix  3      [ ]         STREAM     CONNECTED     15623    -
        unix  3      [ ]         STREAM     CONNECTED     14996    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     15589    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     14488    -
        unix  4      [ ]         DGRAM      CONNECTED     13459    -                    /run/systemd/notify
        unix  2      [ ACC ]     STREAM     LISTENING     13462    -                    /run/systemd/private
        unix  3      [ ]         STREAM     CONNECTED     15539    -
        unix  3      [ ]         STREAM     CONNECTED     15903    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     15817    -
        unix  2      [ ACC ]     STREAM     LISTENING     13464    -                    /run/systemd/userdb/io.systemd.DynamicUser
        unix  2      [ ACC ]     STREAM     LISTENING     13465    -                    /run/systemd/io.system.ManagedOOM
        unix  2      [ ACC ]     STREAM     LISTENING     13476    -                    /run/systemd/fsck.progress
        unix  3      [ ]         STREAM     CONNECTED     15719    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     14610    -                    /run/systemd/journal/stdout
        unix  3      [ ]         DGRAM      CONNECTED     16829    989/systemd
        unix  13     [ ]         DGRAM      CONNECTED     13480    -                    /run/systemd/journal/dev-log
        unix  7      [ ]         DGRAM      CONNECTED     13482    -                    /run/systemd/journal/socket
        unix  2      [ ACC ]     STREAM     LISTENING     13484    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     14771    -                    /run/systemd/journal/stdout
        unix  2      [ ACC ]     SEQPACKET  LISTENING     13486    -                    /run/udev/control
        unix  3      [ ]         DGRAM      CONNECTED     850      -
        unix  2      [ ]         DGRAM      CONNECTED     740      -
        unix  2      [ ]         DGRAM      CONNECTED     13535    -
        unix  3      [ ]         STREAM     CONNECTED     17508    -
        unix  3      [ ]         STREAM     CONNECTED     15763    -
        unix  3      [ ]         STREAM     CONNECTED     16633    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     14591    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     15037    -                    /run/dbus/system_bus_socket
        unix  3      [ ]         STREAM     CONNECTED     15873    -                    /run/systemd/journal/stdout
        unix  2      [ ]         STREAM     CONNECTED     35894    -
        unix  3      [ ]         STREAM     CONNECTED     24829    -
        unix  3      [ ]         STREAM     CONNECTED     14657    -                    /run/systemd/journal/stdout
        unix  3      [ ]         STREAM     CONNECTED     835      -
        unix  2      [ ACC ]     STREAM     LISTENING     735      -                    /run/systemd/journal/io.systemd.journal
        Radix1975@raspberrypi5:~ $ node -v
        v18.19.0
        Radix1975@raspberrypi5:~ $ npm -v
        10.2.3
        Radix1975@raspberrypi5:~ $ cd /opt/iobroker
        iobroker list instances
        + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + instance is alive
        Radix1975@raspberrypi5:/opt/iobroker $ Radix1975@raspberrypi5:~ $ ps -A | grep iobroker
            822 ?        00:02:44 iobroker.js-con
        BLISHED    0      0 127.0.0.1:9000          127.0.0.1:33780         ESTABLISHED -
        • R Radix75
          v18.19.0
          10.2.3
          + instance is alive
          Thomas BraunT Offline
          #78
          @radix75
          Da läuft ein X und VNC drauf.
          Schalt den Kram AUS!
          • R Radix75
            HomoranH Offline
            HomoranH Offline
            #79
            unwichtig!
            kommt der pi da ran?
            anscheinend ja nicht
              unwichtig!
              Radix75
              #80
              unwichtig!
              mus ich die Webseite so wie unten aufrufen? Ich wies nicht wie das geht mit der Konsole
              login as: Radix1975
              Radix1975@192.168.1.225's password:
              Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20        23-11-24) aarch64
              permitted by applicable law.
              Last login: Thu Dec 28 10:05:44 2023
              Radix1975@raspberrypi5:~ $ http://download.iobroker.net/sources-dist.json
              -bash: http://download.iobroker.net/sources-dist.json: No such file or directory
              • R Radix75
                unwichtig!
                login as: Radix1975
                #81
                @radix75
                ping6 download.iobroker.net
                ping download.iobroker.net
                  @radix75
                  Radix75
                  #82
                  @thomas-braun said in Daikin Adapter:
                  @radix75
                  VNC hat der mir einfach installiert nachdem ich inb26525cf-7ba9-4cb3-88fc-9179435b923a-image.png
                  an gemacht habe
                  Was X ist weis ich nicht
                  Ich weis nicht mit welchen Konsolen Kommandos ich es Deinstallieren kann
                  R Thomas BraunT 2 Antworten Letzte Antwort
                  • R Radix75
                    @radix75
                    an gemacht habe
                    Radix75
                    #83
                    login as: Radix1975
                    Last login: Thu Dec 28 13:15:51 2023 from 192.168.1.10
                    Radix1975@raspberrypi5:~ $ ping6 download.iobroker.net
                    ping6: download.iobroker.net: Address family for hostname not supported
                    PING download.iobroker.net (93.90.206.45) 56(84) bytes of data.
                    ^C
                    --- download.iobroker.net ping statistics ---
                    29 packets transmitted, 0 received, 100% packet loss, time 28679ms
                    • R Radix75
                      @radix75
                      an gemacht habe
                      #84
                      @radix75
                      Du sollst ja auch kein VNC anmachen!
                      sudo systemctl set-default multi-user.target
                      sudo reboot
                      Trag mal die live-Repos ein. Siehe hier:
                      echad@chet:~ $ iob repo list
                      live-stable   : http://iobroker.live/repo/sources-dist.json
                      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                      • R Radix75
                        login as: Radix1975
                        ^C
                        #85
                        @radix75
                        Der host könnte aber gerade down sein. Hier geht der auch nicht.
                        echad@chet:~ $ ping download.iobroker.net
                        ^C
                        16 packets transmitted, 0 received, 100% packet loss, time 15366ms
                          @radix75
                          ^C
                          Radix75
                          #86
                          @radix75
                          ^C
                          so oder wie was soll ich wo und wie eintragen kenne mich mit der Konsole nicht aus
                          login as: Radix1975
                          Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10
                          Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list
                          -bash: echad@chet:~: command not found
                          Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li                                   st
                          -bash: Radix1975@raspberrypi5:~: command not found
                          -bash: -bash:: command not found
                          -bash: beta: command not found
                          -bash: live-stable: command not found
                          -bash: live-beta: command not found
                          -bash: stable: command not found
                          • R Radix75
                            @radix75
                            ^C
                            login as: Radix1975
                            HomoranH Offline
                            HomoranH Offline
                            #87
                            wie
                            in den Systemeinstellungen über den admin
                              wie
                              Radix75
                              schrieb am zuletzt editiert von Radix75
                              #88
                              wie
                              wenn ich die Adminseite in Broser neu öffne fehlen die gerade erst neu eingetragenen Repos wieder
                              HomoranH R 2 Antworten Letzte Antwort
                              • R Radix75
                                wie
                                HomoranH Offline
                                HomoranH Offline
                                #89
                                hast du auch gespeichert?
                                • R Radix75
                                  wie
                                  Radix75
                                  #90
                                  beta kommt auch der Fehler
                                  • R Radix75
                                    Radix75
                                    #91
                                    @radix75 said in Daikin Adapter:
                                    ja habe gespeichert sollten also 4 Repos sein bleiben aber nur immer 2 drin
                                    • R Radix75
                                      HomoranH Offline
                                      HomoranH Offline
                                      #92
                                      natürlich!
                                      @thomas-braun sagte in Daikin Adapter:
                                      ist ja der selbe Server
                                      • R Radix75
                                        HomoranH Offline
                                        HomoranH Offline
                                        #93
                                        und wenn du die änderst?
                                        • R Radix75
                                          #94
                                          @radix75
                                          iob repo list
                                          anschauen .
