  3. Off Topic
  4. InfluxDB
  5. mit backitup kein Influxdb und Grafana backup möglich
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
119 Beiträge 10 Kommentatoren 19.8k Aufrufe 8 Beobachtet
  • W Willi-Wunder
    @simatec sagte in mit backitup kein Influxdb und Grafana backup möglich:
    sudo apt install influxdb2-client
    pi@iobroker:~ $ sudo apt install influxdb2-client
    Reading package lists... Done
    The following NEW packages will be installed:
      influxdb2-client
    0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
    Need to get 10.5 MB of archives.
    After this operation, 24.0 MB of additional disk space will be used.
    Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb2-client arm64 2.7.1-1 [10.5 MB]
    Fetched 10.5 MB in 2s (4392 kB/s)
    apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
    perl: warning: Setting locale failed.
    perl: warning: Please check that your locale settings:
            LANGUAGE = "de_DE",
            LC_ALL = "de_DE",
            LANG = (unset)
        are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    locale: Cannot set LC_CTYPE to default locale: No such file or directory
    locale: Cannot set LC_MESSAGES to default locale: No such file or directory
    locale: Cannot set LC_ALL to default locale: No such file or directory
    Selecting previously unselected package influxdb2-client.
    (Reading database ... 146179 files and directories currently installed.)
    Preparing to unpack .../influxdb2-client_2.7.1-1_arm64.deb ...
    Unpacking influxdb2-client (2.7.1-1) ...
    dpkg: error processing archive /var/cache/apt/archives/influxdb2-client_2.7.1-1_arm64.deb (--unpack):
     trying to overwrite '/usr/bin/influx', which is also in package influxdb2-cli 2.7.3-1
    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Hätte ich vorher InfluxDB stoppen müssen?
    simatecS Offline
    simatecS Offline
    simatec
    #69
    @willi-wunder sagte in mit backitup kein Influxdb und Grafana backup möglich:
    /usr/bin/influx
    ohhh man da ist einiges vermurkst ...
    sudo rm /usr/bin/influx
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    W 1 Antwort Letzte Antwort
    • simatecS simatec
      /usr/bin/influx
      W Offline
      W Offline
      Willi-Wunder
      schrieb am zuletzt editiert von Willi-Wunder
      #70
      pi@iobroker:~ $ sudo rm /usr/bin/influx
        influxdb2-client
      Need to get 0 B/10.5 MB of archives.
              LANGUAGE = "de_DE",
              LC_ALL = "de_DE",
              LANG = (unset)
      Hab den Rasp von Buster auf Bookworm neu eingerichtet, allerdings ein Backup vom Iobroker eingespielt. Hatte unter Buster influxDB 1.x gehabt. Mist...... Vielen Dank für eure Hilfe.
      • W Willi-Wunder
          influxdb2-client
                LANGUAGE = "de_DE",
                LC_ALL = "de_DE",
                LANG = (unset)
        simatecS Offline
        simatecS Offline
        simatec
        #71
        @willi-wunder Hast du vorher nicht den Befehl zum löschen ausgeführt?
        • simatecS simatec
          W Offline
          W Offline
          Willi-Wunder
          #72
          @simatec
          Doch, gerade oben mit ergänzt, hatte ich zuvor mit ausgeführt......
          • W Willi-Wunder
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            #73
            @willi-wunder
            apt policy influxdb2-cli
            • simatecS simatec
              @willi-wunder
              W Offline
              W Offline
              Willi-Wunder
              #74
              pi@iobroker:~ $ apt policy influxdb2-cli
              influxdb2-cli:
                Installed: 2.7.3-1
                Candidate: 2.7.3-1
                Version table:
               *** 2.7.3-1 500
                      500 https://repos.influxdata.com/debian stable/main arm64 Packages
                   2.7.1-2 500
                   2.6.1 500
                   2.6.0 500
                   2.5.0 500
                   2.4.0 500
                   2.3.0 500
              simatecS 2 Antworten Letzte Antwort
              • W Willi-Wunder
                influxdb2-cli:
                  Installed: 2.7.3-1
                  Candidate: 2.7.3-1
                  Version table:
                 *** 2.7.3-1 500
                     2.7.1-2 500
                     2.6.1 500
                     2.6.0 500
                     2.5.0 500
                     2.4.0 500
                     2.3.0 500
                simatecS Offline
                simatecS Offline
                simatec
                #75
                @willi-wunder Dann war aber die Ausgabe vorher nicht vollständig...
                • W Willi-Wunder
                  influxdb2-cli:
                    Installed: 2.7.3-1
                    Candidate: 2.7.3-1
                    Version table:
                   *** 2.7.3-1 500
                       2.7.1-2 500
                       2.6.1 500
                       2.6.0 500
                       2.5.0 500
                       2.4.0 500
                       2.3.0 500
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #76
                  @willi-wunder
                  sudo apt remove influxdb2-cli
                  • simatecS simatec
                    W Offline
                    W Offline
                    Willi-Wunder
                    #77
                    @simatec
                    Du meinst wegen sudo rm /usr/bin/influx ? Das hatte ich beim Code kopieren übersehen und dann nachgetragen.
                    • W Willi-Wunder
                      @simatec
                      W Offline
                      W Offline
                      Willi-Wunder
                      #78
                      pi@iobroker:~ $ sudo apt remove influxdb2-cli
                      The following packages will be REMOVED:
                        influxdb2-cli
                      0 upgraded, 0 newly installed, 1 to remove and 3 not upgraded.
                      After this operation, 24.1 MB disk space will be freed.
                      Do you want to continue? [Y/n] y
                              LANGUAGE = "de_DE",
                              LC_ALL = "de_DE",
                              LANG = (unset)
                      Removing influxdb2-cli (2.7.3-1) ...
                        influxdb2-client
                              LANGUAGE = "de_DE",
                              LC_ALL = "de_DE",
                              LANG = (unset)
                      (Reading database ... 146176 files and directories currently installed.)
                      Setting up influxdb2-client (2.7.1-1) ...
                      • W Willi-Wunder
                          influxdb2-cli
                                LANGUAGE = "de_DE",
                                LC_ALL = "de_DE",
                                LANG = (unset)
                          influxdb2-client
                                LANGUAGE = "de_DE",
                                LC_ALL = "de_DE",
                                LANG = (unset)
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #79
                        @willi-wunder ohhh je da ist soviel krum ...
                        Was bekommst du nun als Ausgabe von
                        sudo influx auth list -t 74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A== --json
                        • simatecS simatec
                          W Offline
                          W Offline
                          Willi-Wunder
                          #80
                          pi@iobroker:~ $ sudo influx auth list -t 74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A== --json
                          /usr/local/bin/influx: 1: Syntax error: ")" unexpected
                          • W Willi-Wunder
                            #81
                            @willi-wunder
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                              @willi-wunder
                              sudo apt update
                              sudo reboot
                              W Offline
                              W Offline
                              Willi-Wunder
                              #82
                              pi@iobroker:~ $ sudo apt update
                              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:5 https://repos.influxdata.com/debian stable InRelease
                              Hit:6 https://apt.grafana.com stable InRelease
                              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                              3 packages can be upgraded. Run 'apt list --upgradable' to see them.
                              pi@iobroker:~ $ sudo apt full-upgrade
                              Calculating upgrade... Done
                              The following packages will be upgraded:
                                curl libcurl3-gnutls libcurl4
                              3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                              Need to get 1034 kB of archives.
                              After this operation, 0 B of additional disk space will be used.
                              Get:1 http://deb.debian.org/debian-security bookworm-security/main arm64 curl arm64 7.88.1-10+deb12u5 [308 kB]
                              Get:2 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl4 arm64 7.88.1-10+deb12u5 [366 kB]
                              Get:3 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u5 [360 kB]
                              Fetched 1034 kB in 0s (3344 kB/s)
                              Changelogs werden gelesen... Fertig
                                      LANGUAGE = "de_DE",
                                      LC_ALL = "de_DE",
                                      LANG = (unset)
                              Preparing to unpack .../curl_7.88.1-10+deb12u5_arm64.deb ...
                              Unpacking curl (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
                              Preparing to unpack .../libcurl4_7.88.1-10+deb12u5_arm64.deb ...
                              Unpacking libcurl4:arm64 (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
                              Preparing to unpack .../libcurl3-gnutls_7.88.1-10+deb12u5_arm64.deb ...
                              Unpacking libcurl3-gnutls:arm64 (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
                              Setting up libcurl3-gnutls:arm64 (7.88.1-10+deb12u5) ...
                              Setting up libcurl4:arm64 (7.88.1-10+deb12u5) ...
                              Setting up curl (7.88.1-10+deb12u5) ...
                              Processing triggers for man-db (2.11.2-2) ...
                              Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
                              Nach Reboot:
                              Bleibt es leider so......
                              • W Willi-Wunder
                                        LANGUAGE = "de_DE",
                                        LC_ALL = "de_DE",
                                        LANG = (unset)
                                Nach Reboot:
                                #83
                                @willi-wunder
                                ls -lAh /usr/local/bin/influx
                                  @willi-wunder
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  #84
                                  pi@iobroker:~ $ ls -lAh /usr/local/bin/influx
                                  -rwxr-xr-x 1 root root 25M Dec 26 22:38 /usr/local/bin/influx
                                  • W Willi-Wunder
                                    #85
                                    @willi-wunder
                                    sudo rm /usr/local/bin/influx
                                    Das ist ein Überbleibsel aus dem manuellen Hantier mit influx. Eine ordentliche Installation landet nicht in /usr/local/bin
                                      @willi-wunder
                                      W Offline
                                      W Offline
                                      Willi-Wunder
                                      #86
                                      Bingo Banane........ jetzt kommt etwas. Brauch ich die anderen zwei Einträge? (Iobroker (cloned at 2023-12-26 20:56:55) + Backitup in den API Token in InfluxDB? Diese dann löschen und nur den iobroker behalten?
                                                      "id": "0c54cd2ed3814000",
                                                      "description": "Iobroker",
                                                      "token": "74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A==",
                                                      "status": "active",
                                                      "userName": "Markus",
                                                      "userID": "0c52172c23814000",
                                                      "permissions": [
                                                              "read:orgs/5585922b87b26ff0/annotations",
                                                              "write:orgs/5585922b87b26ff0/annotations",
                                                              "read:orgs/5585922b87b26ff0/authorizations",
                                                              "write:orgs/5585922b87b26ff0/authorizations",
                                                              "read:orgs/5585922b87b26ff0/buckets",
                                                              "write:orgs/5585922b87b26ff0/buckets",
                                                              "read:orgs/5585922b87b26ff0/checks",
                                                              "write:orgs/5585922b87b26ff0/checks",
                                                              "read:orgs/5585922b87b26ff0/dashboards",
                                                              "write:orgs/5585922b87b26ff0/dashboards",
                                                              "read:orgs/5585922b87b26ff0/dbrp",
                                                              "write:orgs/5585922b87b26ff0/dbrp",
                                                              "read:orgs/5585922b87b26ff0/documents",
                                                              "write:orgs/5585922b87b26ff0/documents",
                                                              "read:orgs/5585922b87b26ff0/labels",
                                                              "write:orgs/5585922b87b26ff0/labels",
                                                              "read:orgs/5585922b87b26ff0/notebooks",
                                                              "write:orgs/5585922b87b26ff0/notebooks",
                                                              "read:orgs/5585922b87b26ff0/notificationEndpoints",
                                                              "write:orgs/5585922b87b26ff0/notificationEndpoints",
                                                              "read:orgs/5585922b87b26ff0/notificationRules",
                                                              "write:orgs/5585922b87b26ff0/notificationRules",
                                                              "read:/orgs/5585922b87b26ff0",
                                                              "read:orgs/5585922b87b26ff0/remotes",
                                                              "write:orgs/5585922b87b26ff0/remotes",
                                                              "read:orgs/5585922b87b26ff0/replications",
                                                              "write:orgs/5585922b87b26ff0/replications",
                                                              "read:orgs/5585922b87b26ff0/scrapers",
                                                              "write:orgs/5585922b87b26ff0/scrapers",
                                                              "read:orgs/5585922b87b26ff0/secrets",
                                                              "write:orgs/5585922b87b26ff0/secrets",
                                                              "read:orgs/5585922b87b26ff0/sources",
                                                              "write:orgs/5585922b87b26ff0/sources",
                                                              "read:orgs/5585922b87b26ff0/tasks",
                                                              "write:orgs/5585922b87b26ff0/tasks",
                                                              "read:orgs/5585922b87b26ff0/telegrafs",
                                                              "write:orgs/5585922b87b26ff0/telegrafs",
                                                              "read:/users/0c52172c23814000",
                                                              "write:/users/0c52172c23814000",
                                                              "read:orgs/5585922b87b26ff0/variables",
                                                              "write:orgs/5585922b87b26ff0/variables",
                                                              "read:orgs/5585922b87b26ff0/views",
                                                              "write:orgs/5585922b87b26ff0/views"
                                                      "id": "0c55f9fbfc67e000",
                                                      "description": "Iobroker (cloned at 2023-12-26 20:56:55)",
                                                      "token": "2HXiLlQiU_mc3wKWMMkPSlnH66opy68vpkXBxIkWlDfzwpOFf3JjRfk8HUdEUxLegV3Vy0qHSY7dIR78jUB8bA==",
                                                      "status": "active",
                                                      "permissions": [
                                                      "id": "0c55fb5aac495000",
                                                      "description": "Backitup",
                                                      "token": "qa1TtBLVxvesQrUawIgN98VLv4__pSLmstVX6L-uW28IlUQk8EvcKNeCbUH82BH3t3JV6RWUB-ssdFdxg4xyqg==",
                                                      "status": "active",
                                                      "permissions": [
                                                              "write:/orgs/5585922b87b26ff0",
                                                              "write:orgs/5585922b87b26ff0/views",
                                      W simatecS 2 Antworten Letzte Antwort
                                      • W Willi-Wunder
                                                        "status": "active",
                                                        "permissions": [
                                                        "status": "active",
                                                        "permissions": [
                                                        "status": "active",
                                                        "permissions": [
                                        W Offline
                                        W Offline
                                        Willi-Wunder
                                        #87
                                        Backitup klappt aber trotzdem noch nicht
                                        [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                        [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                        [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_12_27-00_04_27_backupiobroker"
                                        [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_12_27-00_04_27_backupiobroker" successfully deleted
                                        [ERROR] [influxDB] - Error: Command failed: influx backup --bucket Iobroker -t 74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A== "/opt/iobroker/backups/influxDB_2023_12_27-00_04_27_backupiobroker"
                                        2023/12/27 00:04:27 INFO: Downloading metadata snapshot
                                        Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                                        • W Willi-Wunder
                                                          "status": "active",
                                                          "permissions": [
                                                          "status": "active",
                                                          "permissions": [
                                                          "status": "active",
                                                          "permissions": [
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #88
                                          @willi-wunder Bingo ... du hast deinen Operator-Token gelöscht
                                          https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#operator-token-für-influxdb-2x-wiederherstellen
