  4. [gelöst] Adapter lassen sich nicht Installieren!
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
128 Beiträge 7 Kommentatoren 19.3k Aufrufe 4 Beobachtet
  • S Schweiz
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     18:49:52 up 39 min,  2 users,  load average: 0.72, 0.48, 0.38
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-12-26 18:49:52 GMT
               Universal time: Tue 2023-12-26 18:49:52 UTC
                     RTC time: n/a
                    Time zone: Europe/London (GMT, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    john
    /home/john
    john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        819M        2.1G        1.3M        1.1G        3.2G
    Swap:           104M          0B        104M
    Total:          4.1G        819M        2.2G
             3793 M total memory
              781 M used memory
              840 M active memory
              746 M inactive memory
             2018 M free memory
               64 M buffer memory
             1005 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       29G  3.3G   25G  12% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Dec 26 18:10:21 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fed7638c-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Dec 26 18:10:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Dec 26 18:10:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    826M    /var/lib
    661M    /var/lib/piVCCU3
    604M    /var/lib/piVCCU3/rootfs
    279M    /var/lib/piVCCU3/rootfs/opt
    Archived and active journals take up 64.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    19M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.0M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Objects and States
    Objects:        143
    States:         106
    W: GPG error: https://apt.debmatic.de/debmatic stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
    E: The repository 'https://apt.debmatic.de/debmatic stable InRelease' is not signed.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14969      968/sshd: /usr/sbin
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16511      1039/dnsmasq
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41119      9275/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41112      9275/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14971      968/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       43792      9754/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14782      534/avahi-daemon: r
    udp        0      0 0.0.0.0:38951           0.0.0.0:*                           104        14784      534/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16510      1039/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16507      1039/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14924      889/dhclient
    udp6       0      0 :::5353                 :::*                                104        14783      534/avahi-daemon: r
    udp6       0      0 :::34621                :::*                                104        14785      534/avahi-daemon: r
    2023-12-26 18:20:30.854  - info: admin.0 (9754) received all objects
    2023-12-26 18:20:30.937  - warn: admin.0 (9754) Repository cannot be read: Active repo - stable
    2023-12-26 18:20:30.939  - warn: admin.0 (9754) Active repository "stable" cannot be read
    2023-12-26 18:20:31.082  - info: admin.0 (9754) socket.io server listening on port 8081
    2023-12-26 18:20:31.087  - info: admin.0 (9754) http server listening on port 8081
    2023-12-26 18:20:31.087  - info: admin.0 (9754) Use link "http://127.0.0.1:8081" to configure.
    2023-12-26 18:20:31.350  - info: admin.0 (9754) failed connection to socket.io from ::ffff:192.168.2.116: Passport was not initialized
    2023-12-26 18:20:31.782  - info: admin.0 (9754) failed connection to socket.io from ::ffff:192.168.2.116: Passport was not initialized
    2023-12-26 18:20:48.435  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
    2023-12-26 18:20:48.914  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-26 18:21:13.453  - info: admin.0 (9754) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
    2023-12-26 18:21:49.280  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
    2023-12-26 18:21:58.099  - info: admin.0 (9754) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
    2023-12-26 18:22:15.352  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
    2023-12-26 18:22:15.648  - info: admin.0 (9754) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
    2023-12-26 18:22:21.951  - info: admin.0 (9754) ==> Connected system.user.admin from ::ffff:192.168.2.116
    2023-12-26 18:25:39.843  - info: host.raspberrypi iobroker add alexa2 --host raspberrypi
    2023-12-26 18:25:43.464  - info: host.raspberrypi iobroker NPM version: 10.2.3
    2023-12-26 18:25:43.466  - info: host.raspberrypi iobroker Installing iobroker.alexa2@3.26.3... (System call)
    2023-12-26 18:33:27.397  - error: host.raspberrypi iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall connectnpm ERR! errno ETIMEDOUTnpm ERR! network request to https://registry.npmjs.org/iobroker.alexa2 failed, reason: connect ETIMEDOUT 2606:4700::6810:1e22:443npm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly.  See: 'npm help config'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T18_25_44_393Z-debug-0.log
    2023-12-26 18:33:27.402  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.alexa2@3.26.3: 1
    2023-12-26 18:33:28.436  - info: host.raspberrypi iobroker exit 25
    2023-12-26 18:45:27.826  - info: host.raspberrypi iobroker add hm-rega --host raspberrypi
    2023-12-26 18:45:31.546  - info: host.raspberrypi iobroker NPM version: 10.2.3
    2023-12-26 18:45:31.549  - info: host.raspberrypi iobroker Installing iobroker.hm-rega@4.0.0... (System call)
    iob diag has finished.
    @schweiz sagte in Adapter lassen sich nicht Installieren!:
    da ist das unsignierte debmatic und kein piVCCU repo!
    sonst nichts aufregendes bis auf die Probleme mit dem Zugriff auf npm
    könnte ein kurzzeitiges Problem mit deren Server sein, muss aber nicht.
    später nochmal versuchen, ggf. über due Konsole mit iob add alexa2 --debug
      Schweiz
      hmmm, ok soweit läuft ja CCU und IOBm beides über eigene IP, nur das ich im IOB nix hinzufügen kann...
      Ich schau mal morgen nochmal rein, hab heute auch nicht mehr die lust, sitze schon so lange an der Kiste und gefühlt geht nix...
      Erst einmal Herzlichen Dank für die Geduld mit mir und die erbrachte Hilfe ;)
      iob add alexa2 --debug geht auf Console auch nicht voran...
      NPM version: 10.2.3
      npm ERR! network
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T18_58_23_191Z-debug-0.log
      npm ERR! network
      MFG Schweizer
      • S Schweiz
        NPM version: 10.2.3
        npm ERR! network
        npm ERR! network
        MFG Schweizer
        Schweiz
        john@raspberrypi:/opt/iobroker $ iobroker fix
        library: loaded
        Library version=2023-10-13
            Welcome to the ioBroker installation fixer!
            Script version: 2023-10-13
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Get:6 https://apt.pivccu.de/piVCCU stable InRelease [13.6 kB]
        Get:7 https://apt.debmatic.de/debmatic stable InRelease [13.6 kB]
        Err:7 https://apt.debmatic.de/debmatic stable InRelease
        Reading package lists... Done
        N: Ignoring file 'pivccu.li' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        Installed acl
        Installed libavahi-compat-libdnssd-dev
        Installed libudev-dev
        Installed libpam0g-dev
        Installed git
        Installed libcairo2-dev
        Installed libpango1.0-dev
        Installed libjpeg-dev
        Installed libgif-dev
        Installed librsvg2-dev
        Installed libpixman-1-dev
        Installed cmake
            Checking ioBroker user and directory permissions (2/5)
        This system does not support setting default permissions.
        Do not use npm to manually install adapters unless you know what you are doing!
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        npm ERR! network request to https://registry.npmjs.org/@iobroker%2fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1e22:443
        npm ERR! network
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-26T19_12_31_342Z-debug-0.log
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        das ist aus IOB FIX, kann aber im npm help config nix finden bzgl. der Netzwerk Konfig...
        MFG Schweizer
        • S Schweiz
          library: loaded
          Installed acl
          Installed git
          Installed cmake
          Done.
          npm ERR! network
          Autostart enabled!
          MFG Schweizer
          @schweiz du hast probleme mit dem Internet.
          Möglicherweise mit IPv6
          • S Schweiz
            library: loaded
            Installed acl
            Installed git
            Installed cmake
            Done.
            npm ERR! network
            Autostart enabled!
            MFG Schweizer
            @schweiz
            Sitzt du auf der Insel?
              @schweiz
              Schweiz
              bin zwar Engländer, aber nein...
              MFG Schweizer
              • S Schweiz
                MFG Schweizer
                @schweiz
                Dann ändere es auf die korrekte Zeitzone ab.
                Spart dir Rückfragen, warum irgendwas zur falschen Zeit ausgeführt wird. Und Trouble im Netzwerk auch.
                  @schweiz
                  Schweiz
                  super, ich DANKE EUCH BEIDEN...
                  die Uhrzeit hat er mir nach der konfig richtig angezeigt, und nun scheint es zu gehen...
                  MFG Schweizer
                  • S Schweiz
                    MFG Schweizer
                    @schweiz dann musst du jetzt nur noch dein piVCCU repo anlegen und dafür das debmatic repo wieder loswerden.
                    Vielleicht kann dir @Thomas-Braun dabei unter die Arme greifen. ich kann so was nicht.
                    • S Schweiz
                      MFG Schweizer
                      @schweiz
                      ls -lAh /etc/apt/sources.list.d/
                      sagt?
                        @schweiz
                        sagt?
                        Schweiz
                        Erst einmal ein Frohes neues Jahre euch allen...
                        john@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
                        total 16K
                        -rw-r--r-- 1 root root 94 Dec 26 17:55 debmatic.list
                        -rw-r--r-- 1 root root 100 Dec 26 18:30 nodesource.list
                        -rw-r--r-- 1 root root 0 Dec 26 17:32 pivccu.li
                        -rw-r--r-- 1 root root 88 Dec 26 17:55 pivccu.list
                        -rw-r--r-- 1 root root 191 Dec 26 17:55 raspi.list
                        So nachdem PIVCCU so halbwegs läuft komme ich im IOB nicht weiter...
                        Die Homematic Adapter haben sich installieren lassen, nun wollte ich JS Installieren, aber leider scheint es ein problem mit der Source zu geben...
                        Invalid request getRepository. "callback"(false) or "from"(true) is null
                        iobroker host.raspberrypi Cannot install iobroker.javascript@7.1.6: 1
                        iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall connectnpm ERR! errno ETIMEDOUTnpm ERR! network request to https://registry.npmjs.org/iobroker.javascript failed, reason: connect ETIMEDOUT 2606:4700::6810:323:443npm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly. See: 'npm help config'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-01T12_15_26_104Z-debug-0.log
                        MFG
                        • S Schweiz
                          total 16K
                          MFG
                          @schweiz
                          sudo rm /etc/apt/sources.list.d/debmatic.list
                          sudo rm /etc/apt/sources.list.d/pivccu.li
                          sudo apt update
                          • S Schweiz
                            total 16K
                            MFG
                            @schweiz
                            Bitte Konsolenoutput immer in CodeTags einbetten, damit man das besser lesen kann.
                            Dein Netzwerk scheint nicht richtig für IPv6 eingerichtet zu sein.
                              @schweiz
                              Schweiz
                              ok,...
                              ich habe davor ein iob stop gemacht
                              und dannach ein sudo apt upgrade gemacht, sowie ein iob start... gehe mal davon aus das es richtig war... nun kommt das wenn ich den JS installieren möcht...
                              $ iobroker add javascript --host raspberrypi
                              /bin/sh: 1: npm: not found
                              Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                              ERROR: Process exited with code 30
                              MFG
                              • S Schweiz
                                ok,...
                                MFG
                                @schweiz
                                https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
                                  @schweiz
                                  Schweiz
                                  schrieb am zuletzt editiert von Schweiz
                                  das ist echt ein krampf... ich hoffe die installation des Systems wird in zukunft mal etwas einfacher...
                                  war echt eine geburt...
                                  JS konnte ich nun installieren, ich hoffe das es nun mal endlich rund läuft...
                                  meine Frau ist schon generft das seid 3 monaten die Heizung nachts angeht...
                                  MFG Schweizer /DANKE
                                  • S Schweiz
                                    @schweiz
                                    Die Installation ist eigentlich nicht kompliziert.
                                    Der Installer richtet das nodesource-Repository nun auch anders ein, das Nacharbeiten bei nodejs sind nicht mehr erforderlich. War es auch nur wenige Tage
                                    Also ist das einrichten schon wieder einfacher geworden.
                                    iob diag
                                    in der Langfassung sagt nun?
                                    • S Schweiz
                                      Konkret hattest du an welcher Stelle Probleme?
                                      Denn die drei Zeilen für die richtige nodejs-Version kann man kopieren und in sein Terminal kopieren. Ich sehe da keinen Krampf.
                                        @schweiz
                                        iob diag
                                        Schweiz
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : arm64
                                         14:19:48 up 27 min,  2 users,  load average: 0.32, 0.36, 0.25
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Mon 2024-01-01 14:19:48 CET
                                                   Universal time: Mon 2024-01-01 13:19:48 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        john
                                        /home/john
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            4.0G        1.0G        2.1G        1.3M        917M        3.0G
                                        Swap:           104M          0B        104M
                                        Total:          4.1G        1.0G        2.2G
                                                 3793 M total memory
                                                  955 M used memory
                                                  972 M active memory
                                                  618 M inactive memory
                                                 2039 M free memory
                                                   51 M buffer memory
                                                  824 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/mmcblk0p2 ext4       29G  3.6G   24G  13% /
                                        [Mon Jan  1 13:52:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fed7638c-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Mon Jan  1 13:52:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Mon Jan  1 13:52:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        /var:
                                        1.2G    /var/
                                        826M    /var/lib
                                        Archived and active journals take up 80.0M in the file system.
                                        9.7M    /opt/iobroker/backups/
                                        133M    /opt/iobroker/iobroker-data/
                                        84M     /opt/iobroker/iobroker-data/files
                                        67M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        13M     /opt/iobroker/iobroker-data/objects.jsonl
                                        7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                                        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                                        5.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/484.5f7d9187.chunk.js.map
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                         *** 18.19.0-1nodesource1 1001
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0+dfsg1-1 500
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapter State
                                        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                        + instance is alive
                                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                        Objects and States
                                        Objects:        1736
                                        States:         1369
                                        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                        Get:5 https://apt.pivccu.de/piVCCU stable InRelease [13.6 kB]
                                        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Fetched 13.6 kB in 2s (6908 B/s)
                                        Pending Updates: 0
                                        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16566      1047/dnsmasq
                                        tcp        0      0 192.168.2.113:42010     0.0.0.0:*               LISTEN      1001       18103      2410/io.hm-rpc.1
                                        tcp        0      0 192.168.2.113:42001     0.0.0.0:*               LISTEN      1001       19185      2392/io.hm-rpc.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16548      989/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14160      954/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15244      954/iobroker.js-con
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          16550      989/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15603      1077/io.admin.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3979       456/avahi-daemon: r
                                        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16565      1047/dnsmasq
                                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16562      1047/dnsmasq
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16493      898/dhclient
                                        udp        0      0 0.0.0.0:58093           0.0.0.0:*                           104        3981       456/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                104        3980       456/avahi-daemon: r
                                        udp6       0      0 :::37578                :::*                                104        3982       456/avahi-daemon: r
                                        2024-01-01 13:56:45.054  - info: host.raspberrypi iobroker host.raspberrypi object javascript.0.debug.from created
                                        2024-01-01 13:56:45.060  - info: host.raspberrypi iobroker host.raspberrypi object javascript.0.debug.rules created
                                        2024-01-01 13:56:45.075  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.javascript.0 created
                                        2024-01-01 13:56:46.114  - info: host.raspberrypi iobroker exit 0
                                        2024-01-01 13:56:48.124  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 2593
                                        2024-01-01 13:56:48.902  - info: admin.0 (1077) ==> Connected system.user.admin from ::ffff:192.168.2.116
                                        2024-01-01 13:56:51.984  - info: javascript.0 (2593) starting. Version 7.1.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-01 13:56:52.372  - info: javascript.0 (2593) requesting all states
                                        2024-01-01 13:56:52.374  - info: javascript.0 (2593) requesting all objects
                                        2024-01-01 13:56:53.053  - info: javascript.0 (2593) received all objects
                                        2024-01-01 13:56:53.085  - info: javascript.0 (2593) received all states
                                        2024-01-01 14:05:26.550  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
                                        2024-01-01 14:05:26.556  - info: javascript.0 (2593) Got terminate signal TERMINATE_YOURSELF
                                        2024-01-01 14:05:26.561  - info: javascript.0 (2593) terminating
                                        2024-01-01 14:05:26.562  - info: javascript.0 (2593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2024-01-01 14:05:26.596  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
                                        2024-01-01 14:05:27.059  - info: javascript.0 (2593) terminating
                                        2024-01-01 14:05:27.128  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-01-01 14:05:29.639  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 3057
                                        2024-01-01 14:05:33.181  - info: javascript.0 (3057) starting. Version 7.1.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-01 14:05:33.579  - info: javascript.0 (3057) requesting all states
                                        2024-01-01 14:05:33.581  - info: javascript.0 (3057) requesting all objects
                                        2024-01-01 14:05:34.344  - info: javascript.0 (3057) received all objects
                                        2024-01-01 14:05:34.347  - info: javascript.0 (3057) received all states
                                        2024-01-01 14:05:46.545  - info: admin.0 (1077) <== Disconnect system.user.admin from ::ffff:192.168.2.116
                                        Dann hat es mich schlecht erwischt würde ich sagen,...
                                        Damals war es einfacher, eben das fertige Image geladen, Update gemacht und alles lief problemlos...
                                        Heute ist das Image nicht mehr da, hilfe von damals verlinkt auf nicht vorhandenen Content.
                                        Diesesmal mit mehr als 2 Wochen work, und unendlichen neuinstallationen scheint es ungewöhnlich aufwendig zu sein... aber wenn es nun jetzt endlich gefixt ist... sollte es ja beim nächsten mal deutlich einfacher von der hand gehen :D
                                        MFG Schweizer
                                        • S Schweiz
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          john
                                          /home/john
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           104M          0B        104M
                                                   3793 M total memory
                                                    955 M used memory
                                                    972 M active memory
                                                   2039 M free memory
                                                     51 M buffer memory
                                                    824 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          1.2G    /var/
                                          826M    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.12.0
                                          javascript:     7.1.6
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        1736
                                          States:         1369
                                          Pending Updates: 0
                                          MFG Schweizer
                                          @schweiz
                                          Jetzt passt es.
                                          Images...
                                          Installationseinzeiler, fertig.
