  4. Zigbee Tuya TS0601 Temperature & Humidity läuft nicht
    2.7k
    4.7k
    4.0k
33 Beiträge 7 Kommentatoren 5.0k Aufrufe 7 Beobachtet
  • arteckA arteck
    @arteck installier mal jetzt den Adapter von git und schau nochmal.. musst aber nochmal neu anlernen
    rocky753
    @arteck habe ich gemacht. keine Änderung... Objektbaum wie vorher.
    Log:
    2023-09-29 13:30:28.917	info	debug devices set to []
    2023-09-29 13:30:28.873	info	Zigbee started
    2023-09-29 13:30:28.872	info	0x3425b4fffe307d63 (addr 31147): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
    2023-09-29 13:30:28.870	info	0x3425b4fffe170775 (addr 49041): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
    2023-09-29 13:30:28.868	info	0x00158d000911dbbb (addr 20444): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2023-09-29 13:30:28.866	info	0xa4c138a66e67005b (addr 36428): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
    2023-09-29 13:30:28.865	info	0xa4c1380d4d269b2b (addr 16273): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
    2023-09-29 13:30:28.862	info	0x00158d0008f3290c (addr 39180): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
    2023-09-29 13:30:28.856	info	0xa4c138d0b860a01f (addr 9251): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
    2023-09-29 13:30:28.788	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
    2023-09-29 13:30:28.774	info	Currently 7 devices are joined:
    2023-09-29 13:30:28.759	info	--> transmitPower : normal
    2023-09-29 13:30:28.739	info	Unable to disable LED, unsupported function.
    2023-09-29 13:30:28.730	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
    2023-09-29 13:30:28.357	info	Installed Version: ioBroker/ioBroker.zigbee
    2023-09-29 13:30:27.474	info	Starting Zigbee npm ...
    2023-09-29 13:30:27.471	info	delete old Backup files. keep only last 10
    2023-09-29 13:30:27.332	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
    2023-09-29 13:30:19.758	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-29 13:30:19.757	info	terminating
    beim Joining steht noch das drin:
    2023-09-29 13:25:27.501	warn	Object of state "zigbee.0.exclude.TS0601_temperature_humidity_sensor_1" is missing the required property "common.type"
    2023-09-29 13:25:09.632	info	Zigbee: stop joining
    2023-09-29 13:24:28.909	info	Device '0xa4c138d0b860a01f' is supported, identified as: TuYa Temperature & humidity sensor (TS0601_temperature_humidity_sensor_1)
    2023-09-29 13:24:28.908	info	Successfully interviewed '0xa4c138d0b860a01f', device has successfully been paired
    2023-09-29 13:24:25.395	info	Device '0xa4c138d0b860a01f' announced itself
    2023-09-29 13:24:17.585	info	Starting interview of '0xa4c138d0b860a01f'
    • R rocky753
      Log:
      arteckA Offline
      arteckA Offline
      arteck
      @rocky753und jetzt pack den mal unter Ausschliessen Tab rein
      R 1 Antwort Letzte Antwort
      • arteckA arteck
        rocky753
        @arteck da war er schon drin. hab ihn nochmal neu angelernt und unter ausschliessen rein, aber keine Veränderung...
        2023-09-30 15:28:52.140	info	Zigbee started
        2023-09-30 15:28:52.139	info	0x3425b4fffe307d63 (addr 31147): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
        2023-09-30 15:28:52.137	info	0x3425b4fffe170775 (addr 49041): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
        2023-09-30 15:28:52.135	info	0x00158d000911dbbb (addr 20444): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        2023-09-30 15:28:52.133	info	0xa4c138a66e67005b (addr 36428): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
        2023-09-30 15:28:52.131	info	0xa4c1380d4d269b2b (addr 16273): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
        2023-09-30 15:28:52.129	info	0x00158d0008f3290c (addr 39180): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
        2023-09-30 15:28:52.124	info	0xa4c138d0b860a01f (addr 10643): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
        2023-09-30 15:28:52.073	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
        2023-09-30 15:28:52.055	info	Currently 7 devices are joined:
        2023-09-30 15:28:52.039	info	--> transmitPower : normal
        2023-09-30 15:28:52.019	info	Unable to disable LED, unsupported function.
        2023-09-30 15:28:52.011	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
        2023-09-30 15:28:51.629	info	Installed Version: ioBroker/ioBroker.zigbee
        2023-09-30 15:28:50.726	info	Starting Zigbee npm ...
        2023-09-30 15:28:50.723	info	delete old Backup files. keep only last 10
        2023-09-30 15:28:50.572	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
        2023-09-30 15:28:42.984	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-09-30 15:28:42.982	info	terminating
        2023-09-30 15:28:42.581	info	Zigbee: disabling joining new devices.
        2023-09-30 15:28:42.480	info	cleaned everything up...
        2023-09-30 15:28:42.476	info	Got terminate signal TERMINATE_YOURSELF
        2023-09-30 15:28:36.100	info	Zigbee: stop joining
        2023-09-30 15:28:32.589	warn	Object of state "zigbee.0.exclude.TS0601_temperature_humidity_sensor_1" is missing the required property "common.type"
        2023-09-30 15:27:48.053	warn	TypeError: Cannot read properties of undefined (reading 'replace') at Commands.deleteDevice (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:449:30) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:71:30) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:14:48) at Zigbee.emit (node:events:525:35) at Zigbee.emit (node:domain:489:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5831:34) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
        2023-09-30 15:27:47.747	warn	States system pmessage io.messagebox.system.adapter.zigbee.0 {"command":"deleteDevice","message":{"force":false},"from":"system.adapter.admin.0","callback":{"message":{"force":false},"id":281,"ack":false,"time":1696080467744},"_id":33765716} Cannot read properties of undefined (reading 'replace')
        2023-09-30 15:27:45.353	info	Device '0xa4c138d0b860a01f' is supported, identified as: TuYa Temperature & humidity sensor (TS0601_temperature_humidity_sensor_1)
        2023-09-30 15:27:45.353	info	Successfully interviewed '0xa4c138d0b860a01f', device has successfully been paired
        2023-09-30 15:27:44.122	info	Device '0xa4c138d0b860a01f' announced itself
        2023-09-30 15:27:44.066	info	Starting interview of '0xa4c138d0b860a01f'
        2023-09-30 15:27:34.565	info	Zigbee: allowing new devices to join.
        2023-09-30 15:24:52.284	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        2023-09-30 15:21:02.927	info	debug devices set to []
        2023-09-30 15:21:02.883	info	Zigbee started
        • R rocky753
          @arteck
          das gleiche Fehlerbild wie im ersten Beitrag von Darkmann2000.
          Nach pairen tauchen die Sensoren so auf:
          Log beim pairen:
          Objektbaum sieht dann so aus:
          Huligan
          schrieb am zuletzt editiert von Huligan
          @rocky753 Hi Rocky, suche mal bitte bei dir nach "_TZE200_zl1kmjqx" in deiner
          /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js
          Die wird bei dem Model 'TS0601_temperature_humidity_sensor_1' zu finden sein.
          Mir hats geholfen die Model ID sprich die Zeile mit "TZE200_zl1kmjqx" zu löschen und dann die ID
          bei dem 'TS0601_temperature_humidity_sensor
          _2' einzufügen:
          Bin ein begnadeter Zeichner ;-) f190ade5-b91c-46d1-a502-1f77a4703f71-grafik.png
          Beachte auch die Datapoints, hier ggf. den Humidity .raw Wert durch divideBy10 ersetzen. Sieht man auch im Screenshot.
          Ich hatte eine andere Modelversion wird aber sicher allgemein klappen.
          Dann Speichern, Adapter neustarten und bei dem bereits regestriertem Sensor reconfigure durchführen:
          Außer den Batterystatus kam alles nach einigen Sekunden durch. Bin aber guter Dinge das dieser wie öfters zu lesen auch noch nachgeliefert wird.
          Ich hab meinen Adapter über den Broker direkt installiert also ohne GIT oder Ähnlichem. Vielleicht hilf es ja den einen oder anderen.
          Seht mir nach das ich mich auch nicht tiefer mit dem eigentlichen Problem rumgeärgert hab und nur einen schnellen Workaround gesucht habe.
          • H Huligan
            _2' einzufügen:
            arteckA Offline
            arteckA Offline
            arteck
            @huligan sagte in Zigbee Tuya TS0601 Temperature & Humidity läuft nicht:
            TZE200_zl1kmjqx
            das würde bedeuten dass der
            TZE200_zl1kmjqx nicht TS0601_temperature_humidity_sensor_1 sondern TS0601_temperature_humidity_sensor_2 ist
            hmm
            ichhab mal ein issue angelegt https://github.com/Koenkk/zigbee2mqtt/issues/19092 aber ohne den Sensor ist es schwer
            H 1 Antwort Letzte Antwort
            • arteckA arteck
              TZE200_zl1kmjqx
              hmm
              Huligan
              @arteck Kann ich leider nicht beurteilen. War eher ein ein One-Hit bei einer Trial Error Analyse.
              Die Anpassung beim valueConverter spricht eher dagegen ebenso der noch fehlender Batterie Wert.
              Allerdings vom Bild was der Adapter dann läd passt es aber auch wieder.7c3266f0-3ceb-478f-887f-b82a1d40e7d3-grafik.png
              Zumindest Rund und nicht eckig ;-)
              Meine Model-ID war die "_TZE200_bjawzodf"
              Bin kein Entwickler und mir wars eher wichtig die beiden Werte irgendwie zu bekommen als gar nichts.
              • H Huligan
                rocky753
                @huligan hat direkt geklappt, DANKE!!!
                Wenn es als "TS0601_temperature_humidity_sensor_2" erkannt wird, passt es. Nur humidity divideby10 noch rein, dann passen auch die Werte. Nur Batterie wird bei auch nicht angezeigt.
                • arteckA Offline
                  arteckA Offline
                  arteck
                  vielleicht hängt ihr ech an das issue dran was ich gepostet habe .. und klärt das.. nicht dass Tuya da wieder murks baut.. und ballert 2 Geräte mit der gleicher id raus..
                  • arteckA arteck
                    Smo
                    Ich hab mich an das Issue rangehängt, weil Huligans Lösung funktionierte, jetzt kam ein Zigbee Update, und die Änderungen sind wieder rückgängig gemacht :/ Gibts sowas wie eine user.conf, die nicht überschrieben wird?
                    • S Smo
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @smo installier die 1.9.2 da ist es korrigiert
                      • arteckA arteck
                        Smo
                        @arteck Ah, danke dir. Wie find ich die? Das neueste Release was ich finde ist die über npm installierbere 1.9.1. In den Commits steht immer mal was von 1.9.2, also einfach den aktuellen Stand des Repos übernehmen?
                        • S Smo
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @smo 1.9.4 ist draussen
                          • arteckA arteck
                            Smo
                            @arteck Danke. Hab schon :)
