  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
1.2k Beiträge 23 Kommentatoren 479.2k Aufrufe 19 Beobachtet
  • jogibear9988J jogibear9988
    @smilie108
    Zeitzone? UTC zeit vs. unserer Zeit?
    jogibear9988J Offline
    jogibear9988
    #217
    @jogibear9988
    Uups es ging um den Monat :-)
    Ja schau hier: https://www.w3schools.com/jsref/jsref_getmonth.asp liefert 0-11
    Check my ioBroker webui - a vis alternative
    see: https://github.com/iobroker-community-adapters/ioBroker.webui
    • Smilie108S Smilie108
      Hi @jogibear9988
      Kannst du damit was anfangen wo hab ichc den da einen fehler ?
      host.testhaus1-Server
      	2023-12-24 06:29:59.501	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.495	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.493	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.488	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.472	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.472	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.468	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.464	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.464	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
      	2023-12-24 06:29:59.463	warn	Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
      jogibear9988
      #218
      @smilie108
      Ja, fluent-ui sollte wohl mal aus meiner liste.
      Da fehlen im NPM Paket die Dateiendungen bei den imports (also ".js"), dann kein der browser die nicht finden. Da muss man noch einen issue bei MS dazu aufmachen.
      Wobei in dem 3.0er Beta paket scheinen die dateiendungen enthalten zu sein, d.h. die könnten vlt gehen.
      Musst mal prüfen. (manuell paket installieren (rechtsklick auf packages) und folgendes eingeben "@fluentui/web-components@3.0.0-beta.6")
      Komm da im Moment nicht dazu mir das anzuschauen
      Smilie108S 1 Antwort Letzte Antwort
        Blockmove
        #219
        @jogibear9988
        Hallo Jochen,
        wenn wir schon gerade bei den Event-Properties sind:
        Will ich diese nun Entfernen
        dann verschwindet links die zwar das SetSignalValue, die Parameter bleiben aber stehen
        Drücke ich nun OK, dann schließt sich der Dialog. Es wird aber nach wie vor ein Event angezeigt.
        Öffne ich nun das Event, dann ist die Property wieder vorhanden.
        Löschen im Quelltext funktioniert.
        Viele Grüße
        Dieter
        The difference beetween Man and Boys:
        The price of their toys 😀
        jogibear9988J 1 Antwort Letzte Antwort
        • B Blockmove
          @jogibear9988
          Hallo Jochen,
          Viele Grüße
          Dieter
          jogibear9988
          #220
          @blockmove
          löschen kannst das event auch mit rechtsklick auf das kleine 4eck vor dem eventnamen
            @blockmove
            Blockmove
            #221
            @jogibear9988 said in neue Visualisierung "webui" (alternative zu vis):
            @blockmove
            Stimmt, das funktioniert natürlich auch.
            Vorschlag: Vielleicht kannst du Remove auch noch beim "..."-Button integrieren.
            Dann wäre Anlegen und Entfernen eines Events an einer Stelle.
              @smilie108
              Smilie108S Offline
              Smilie108S Offline
              Smilie108
              #222
              @microsoft/fast-components@2.30.6: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
              webui.0
              2023-12-24 19:51:35.079 error deprecated
              webui.0
              webui.0
              2023-12-24 19:51:35.078 error WARN
              webui.0
              2023-12-24 19:51:35.077 error
              webui.0
              2023-12-24 19:51:35.077 error npm
              webui.0
              2023-12-24 19:51:10.858 info Install NPM package (@fluentui/web-components@3.0.0-beta.6)...
              jogibear9988J 2 Antworten Letzte Antwort
              • B Blockmove
                @blockmove
                jogibear9988
                #223
                @blockmove
                erledigt
                • B Blockmove
                  @jogibear9988
                  Hallo Jochen,
                  mal ne - vielleicht doofe - Frage zu den Simple-Events:
                  Mit welchen Event kann ich einen Bool-Datenpunkt auf true / false setzen?
                  SetSignalValue überträgt true als String und SetBitInSignal überträgt ne Number.
                  In Blockly funktioniert es mit SetSate.
                  Viele Grüße
                  Dieter
                  jogibear9988
                  #224
                  @blockmove
                  erledigt
                    @blockmove
                    erledigt
                    Blockmove
                    #225
                    @blockmove
                    erledigt
                    Das ging aber fix 👍
                    Vielen Dank!
                    • jogibear9988J Offline
                      jogibear9988
                      #226
                      Ich habe die Scriptsprache in den Screens & Controls von Typescript auf Javascript umgestellt. Dadurch muss ich die Scripte nicht mehr doppelt speichern. Ich erzeuge dafür nun JSDoc kommentare über den Funktionen, so das man trotzdem Code Vervollständigung hat.
                        Blockmove
                        #227
                        Hat das irgendwelche Auswirkungen auf bereits vorhandene Screens und Controls?
                          webui.0
                          webui.0
                          webui.0
                          webui.0
                          webui.0
                          webui.0
                          jogibear9988
                          #228
                          @smilie108 said in neue Visualisierung "webui" (alternative zu vis):
                          Der export abschnitt der package.json wird von mir noch nicht richtig berücksichtigt, das muss ich machen beim erzeugen der import maps, daher gehen manche imports nicht. Mal schauen wann & wie ich das fixe
                          • B Blockmove
                            jogibear9988
                            #229
                            @blockmove
                            sollte nicht, da ich ja immer den JS code erzeugt habe. Nun wird dieser einfach benutzt.
                              webui.0
                              webui.0
                              webui.0
                              webui.0
                              webui.0
                              webui.0
                              jogibear9988
                              #230
                              Mit der neusten version klappt der import von @fluentui/web-components@3.0.0-beta.6
                              Aber wie man diese nutzt, keine Ahnung
                              • Smilie108S Offline
                                Smilie108S Offline
                                Smilie108
                                #231
                                Dachte ich sollte diese installieren wegen der Fehlermeldung ?
                                Gruß Tom
                                  Smilie108S Offline
                                  Smilie108
                                  #232
                                  @jogibear9988
                                  Wenn ich versuche dieses Packet zu intallieren macht er zwar etwas aber beomme keine infos und bzw ich sehe auch im desinger tree nichts
                                  https://github.com/microsoft/fluentui da gibt es das web-components davon würde mich vor allem der tree interesieren wegen menue Aufbau ;)
                                  Mfg Tom
                                    Gruß Tom
                                    jogibear9988
                                    #233
                                    @smilie108
                                    Ja, die geht ja auch, zumindest werden die Javascriptfiles ohne Fehler geladen. Aber wie man FluentUI nutzt, weiß ich trotzdem nicht.
                                      @jogibear9988
                                      Mfg Tom
                                      jogibear9988
                                      schrieb am zuletzt editiert von jogibear9988
                                      #234
                                      @smilie108
                                      Im Baum siehst du nix, weil es keine custom-elements.json gibt, und sich wohl die Elemente nicht direkt beim laden der Bibliothek registrieren. Wie das geht, bzw. wie man die Bibliothek nutzt, musst dann bei FluentUI nachschauen
                                        jogibear9988
                                        #235
                                        Für mich sieht es so aus, als würden die 3er Komponenten noch nicht wirklich gehen (bspw: https://github.com/microsoft/fluentui/issues/28110)
                                        Die 2er laufen auf jeden Fall auch nicht, da dort die imports ohne Dateiendungen sind, d.h. die laufen nur wenn man sie in einem Projekt mit einem Bundler oder Transpiler nutzt
                                          Smilie108S Offline
                                          Smilie108
                                          #236
                                          @jogibear9988
                                          Hi Jochen
                                          Wie kann ich im blocky auf eine control.prop variabel zugreifen ?
                                          Habe dir was aufs test unter controls reinkopiert (time_selector). Würde gerne mit den vier knöpfen on klick den wert vom timerangeselector ändern.
                                          Sorry bin in der beziehung schwach.
                                          Wenn ich einmal gesehn hab wie das ghet gehts ja aber blicke bei js nicht mit den variabeln durch.
                                          würde das gerne mehrfach verwenden deswegen control mit prop um dann dementsprechend die variabel zuzuweisen.
                                          Danke im voraus für deine hilfe
