  4. Bambulab 3d-Drucker adapter
    6.8k
331 Beiträge 54 Kommentatoren 129.2k Aufrufe 53 Beobachtet
  • kmxakK kmxak
    gibt ne neue x1c firmware... angeblich soll sich was am mqtt getan haben, weiß aber noch nix genaueres.
    WebrangerW Offline
    WebrangerW Offline
    Webranger
    #167
    Ich hab mal nen update gemacht.
    Hab zwar noch ne verbindung aber es wird mir das log voll geschrieben.
    bambulab.0
    2023-12-11 21:32:12.081	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:11.073	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:10.369	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:10.070	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:08.022	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:07.072	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:06.006	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    bambulab.0
    2023-12-11 21:32:05.084	info	State value to set for "bambulab.0.00M09A361400xxx.finishTime" has to be type "date" but received type "string"
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
    BjoernFB M 2 Antworten Letzte Antwort
    • WebrangerW Webranger
      bambulab.0
      bambulab.0
      bambulab.0
      bambulab.0
      bambulab.0
      bambulab.0
      bambulab.0
      bambulab.0
      BjoernFB Offline
      BjoernFB Offline
      BjoernF
      #168
      @webranger jupp, hauts log zu und sobald die instanz läuft gehts ordentlich mit der CPU hoch....da hat sich mit der neuen Firmware beim X1C definitiv was mit MQTT verändert.....bei 3x X1C und 3 Instanzen aktuell net lustig leider :-(
        bambulab.0
        bambulab.0
        bambulab.0
        bambulab.0
        bambulab.0
        bambulab.0
        bambulab.0
        bambulab.0
        M Online
        M Online
        mick70
        schrieb am zuletzt editiert von mick70
        #169
        @webranger hier auch. Ich habe einfach das fragliche Objekt gelöscht und an gleicher Stelle ein neues mit gleichem Namen aber als String angelegt (Expertenmodus). Wird brav gefüllt, keine Fehler mehr. [Ed.: Einfacher kann man natürlich gleich den Typ entsprechend ändern]
        Ist halt ein workaround, va wenn man mit finishTime noch was machen will, muss man halt mehr tun.
        P1S übrigens hier.
        H BjoernFB 2 Antworten Letzte Antwort
        • M mick70
          P1S übrigens hier.
          homecineplexx
          #170
          @mick70 beim P1S gibts auch schon einen Update?
          BjoernFB 1 Antwort Letzte Antwort
          • M mick70
            P1S übrigens hier.
            BjoernFB Offline
            BjoernFB Offline
            BjoernF
            #171
            @mick70 da reicht es auch dem Objekt einfach den Zustandstyp auf STRING zu stellen :-)
            Aber mal blöd gefragt, muss der DP zur Finish Time sekündlich ne geschrieben werden????
            Was mich ebenso stutzig macht ist die sehr hohe Zahl an Ausgabeereignissen und die damit einhergehenden Performance Einbußen. Das System wird einfach super lahm sobald die Instanzen jetzt laufen....
            • H homecineplexx
              BjoernFB Offline
              BjoernFB Offline
              BjoernF
              #172
              @homecineplexx nein, nur X1C hat ein FW update bekommen. P1x kommt später mit NoiseCancelling usw.
              H 1 Antwort Letzte Antwort
              • BjoernFB BjoernF
                homecineplexx
                #173
                @bjoernf said in Bambulab 3d-Drucker adapter:
                danke, daher auch meine frage an @mick70 da er zum Schluss geschrieben hat: "P1S übrigens hier." und das hab ich nicht ganz verstanden
                • H homecineplexx
                  M Online
                  M Online
                  mick70
                  #174
                  @homecineplexx Ich hatte das Problem mit den Fehlermeldungen beim P1S auch ohne das dafür noch nicht veröffentlichte NC update. FW Stand beim P1S ist afair 09/2023. Die Ursache für den Fehler im Adapter liegt daher evtl woanders.
                  @BjoernF Ja, ich hätte auch gleich den Typ ändern können. Meine Reihenfolge war andersrum, ich wollte erst probieren, ob der Adapter das Objekt nach dem Löschen einfach für mich neu richtig anlegt - das war leider nicht der Fall, gab neue Fehler, und ich musste das Objekt selbst neu anlegen. Diesen (retrospektiv) umständlichen Weg hatte ich beschrieben 😁
                  • BjoernFB Offline
                    BjoernFB Offline
                    BjoernF
                    schrieb am zuletzt editiert von BjoernF
                    #175
                    @Dutchman sieht so aus alsob hier sekündlich mc_remaining_time aktualisiert wird, was dann auch durch deinen angelegten DP für finishTime sekündlich updated und die Instanz unnötig belastet. Könnte man das updaten des finishTime DPs nicht auf die Änderung im mc_remaining_time DP triggern? Also maximal minütlich?
                    im übrigen werden beide DPs auch sekündlich aktualisiert, wenn KEIN Druckauftrag läuft.....
                    WebrangerW 1 Antwort Letzte Antwort
                    • BjoernFB BjoernF
                      WebrangerW Offline
                      WebrangerW Offline
                      Webranger
                      #176
                      Ich hab den Adapter jetzt erstmal gestopt und warte auf ein update.
                      Sollte ja auch noch was mit den zeiten kommen.
                        hennott
                        #177
                        @webranger auf was für einer Hardware läuft er bei Dir?
                        • H hennott
                          WebrangerW Offline
                          WebrangerW Offline
                          Webranger
                          #178
                          @hennott Intel NUC im Container.
                            hennott
                            #179
                            @webranger ich hatte von dem Adapter 16 Instanzen auf einem QNAP als Container laufen und das hat der Performance nicht so stark geschadet, allerdings massiv Ressourcen verbraten, weswegen ich jetzt warte, bis man in einer Instanz mehrere Drucker einrichten kann.
                            • skvarelS Online
                              skvarelS Online
                              skvarel
                              schrieb am zuletzt editiert von skvarel
                              #180
                              Das liegt NICHT am Update vom X1 ... das tritt auch beim P1S auf.
                              @Dutchman weiß aber schon Bescheid und will sich kümmern.
                              https://github.com/DrozmotiX/ioBroker.bambulab/issues/58
                              #TeamInventwo
                              Unsere Adapter:
                              • M Online
                                M Online
                                mick70
                                #181
                                Was mir auch noch aufgefallen ist: Ich trenne den Drucker bei Nichtgebrauch immer mit Shelly vom Netz (spart so 9W). Trotzdem versucht der Adapter alle 30 Sekunden zu verbinden und wirft dann Fehler aus:
                                bambulab.0
                                2023-12-19 07:15:59.411	warn	Connection to Printer closed
                                bambulab.0
                                2023-12-19 07:15:59.410	error	Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.137:8883
                                bambulab.0
                                2023-12-19 07:15:26.355	warn	Connection to Printer closed
                                bambulab.0
                                2023-12-19 07:15:26.354	error	Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.137:8883
                                Dieses Intervall ist unabhängig von der Einstellung "Sekunden zwischen der Datenabfrage (Wird nur für die P1x-Serie verwendet)". Das ist schon recht oft und das Log wird so arg unübersichtlich.
                                @Dutchman Vielleicht wären ja Instanzeinstellungen möglich, mit denen man das reconnect-Intervall verlängern und Fehlermeldungen verhindern könnte, wenn man Drucker nicht im Dauerbetrieb einsetzen möchte?
                                BjoernFB GarganoG 2 Antworten Letzte Antwort
                                • M mick70
                                  bambulab.0
                                  bambulab.0
                                  bambulab.0
                                  bambulab.0
                                  BjoernFB Offline
                                  BjoernFB Offline
                                  BjoernF
                                  #182
                                  @mick70 kleines blockly und Instanz mit dem Shelly starten/stoppen 😉👍🏻
                                  • M Online
                                    M Online
                                    mick70
                                    #183
                                    @bjoernf Das wäre ein halbwegs eleganter Workaround - kann man Instanzen im Blockly inzwischen direkt ein- und ausschalten oder muss man da immer noch ein Javascript nutzen (z.B. so)?
                                    [Edit: Der Datenpunkt "Alive" der Instanz im Zweig "System" (sichtbar im Expertenmodus) kann jedenfalls manuell zum Ein-/Ausschalten der Instanz genutzt werden. Probiere ich so jetzt auch mal im Blockly]
                                    [Edit 2: Klappt, dieses Thema ist für mich gelöst!]
                                    Interessant wird's eh erst, wenn das string/date Problem beim "finishTime"-Datenpunkt behoben ist, denn bei jedem Neustart der Instanz wird der Typ ja wieder zurückgesetzt und löst dann die entsprechenden Fehlermeldungen aus.
                                    • FlexerF Offline
                                      FlexerF Offline
                                      Flexer
                                      #184
                                      Gibts hier schon was neues?
                                      Unterm Strich ist alles besser.
                                      Ja, voll geil hier!
                                      • DutchmanD Dutchman
                                        @homecineplexx sagte in Bambulab 3d-Drucker adapter:
                                        Wo genau finde ich eigentlich den Token? Sollte mir der Drucker diesen irgendwo bereitstellen?
                                        jep, bei den Einstellungen unter netwerk
                                        Metro75
                                        #185
                                        @dutchman Guten Abend. Wo genau in den Netzwerk-Einstellungen meint ihr? In der Handy-App, oder in BambuStudio. Hab mir jetzt den gesamten Thread durchgelesen. Steh irgendwie auf dem Schlauch.
                                          Metro75
                                          #186
                                          @dutchman said in Bambulab 3d-Drucker adapter:
                                          ich meine natürlich bezogen darauf 🙂
