  4. Adapter werden nicht mehr geupdated
74 Beiträge 5 Kommentatoren 5.1k Aufrufe 5 Beobachtet
  • A Accu
    @homoran ok sollte ich dann erst den Admin Adapter updaten oder Node? auf welche Node version sollte man gehen?
    @accu
    Und das Betriebssystem auch aktuell halten. Das ist vermutlich bereits abgekündigt.
    iob diag
    sagt?
      @accu
      iob stop
      iob fix
      iob nodejs-update
      Accu
      @thomas-braun said in Adapter werden nicht mehr geupdated:
        iob stop        iob fix        iob nodejs-update
      vielen Dank @Thomas-Braun:
      hat irgendwas hingeschrieben, dass er die Kernel Version nicht detecten kann.
      ioBroker nodejs fixer 2023-10-13
      Recommended nodejs-version is: 16.20.2
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs 	v14.21.3
      /usr/bin/node 		v14.21.3
      /usr/bin/npm 		6.14.18
      /usr/local/bin/npx 		8.1.2
      /usr/local/bin/corepack 	0.10.0
      *** nodejs is NOT correctly installed ***
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 14.21.3-deb-1nodesource1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
       *** 14.21.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u3 500
      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting /usr/local/bin/npx ***
      *** Deleting /usr/local/bin/corepack ***
      Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
      You are running nodejs v14.21.3. Do you want to install recommended version 16.20.2?
      Trying to update your installation now. Please be patient.
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6272 B]
      Fetched 18.4 kB in 1s (13.9 kB/s)
      Installing the recommended nodejs version now!
      (Reading database ... 144046 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.19.0-1nodesource1_armhf.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.19.0-1nodesource1) over (14.21.3-deb-1nodesource1) ...
      Setting up nodejs (18.19.0-1nodesource1) ...
      Processing triggers for man-db (2.8.5-2) ...
      Scanning processes...
      Scanning candidates...
      Scanning linux images...
      Failed to check for processor microcode upgrades.
      Restarting services...
       systemctl restart pm2.service
      No containers need to be restarted.
      No user sessions are running outdated binaries.
      Installing the recommended nodejs version!
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
        @accu
        iob diag
        sagt?
        Accu
        Die Diagnose hat folgendes ergeben @Thomas-Braun:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: Raspi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7+
              Architecture: arm
        Model		: Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         11:17:47 up 3 min,  1 user,  load average: 12.37, 5.38, 2.03
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        *** Time and Time Zones ***
                       Local time: Sun 2023-12-03 11:17:47 CET
                   Universal time: Sun 2023-12-03 10:17:47 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	multi-user.target
        *** MEMORY ***
        Mem:           923M        590M        142M        1.0M        190M        278M
        Swap:           99M         98M        1.0M
        Total:         1.0G        688M        143M
                  923 M total memory
                  590 M used memory
                  298 M active memory
                  418 M inactive memory
                  142 M free memory
                   42 M buffer memory
                  148 M swap cache
                   99 M total swap
                   98 M used swap
                    1 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       30G   21G  7.5G  74% /
        devtmpfs       devtmpfs  430M     0  430M   0% /dev
        tmpfs          tmpfs     462M  1.1M  461M   1% /dev/shm
        tmpfs          tmpfs     462M  6.6M  456M   2% /run
        tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat       63M   49M   14M  78% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/998
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
        [Sun Dec  3 11:14:33 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Sun Dec  3 11:14:36 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Dec  3 11:14:36 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Dec  3 11:14:39 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        670M	/var/
        240M	/var/cache
        222M	/var/cache/apt
        163M	/var/cache/apt/archives
        148M	/var/log
        Archived and active journals take up 5.7M in the file system.
        /opt/iobroker/backups:
        72M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1019M	/opt/iobroker/iobroker-data/
        424M	/opt/iobroker/iobroker-data/sonosCache
        325M	/opt/iobroker/iobroker-data/files
        149M	/opt/iobroker/iobroker-data/backup-objects
        56M	/opt/iobroker/iobroker-data/files/telegram.admin
        41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        23M	/opt/iobroker/iobroker-data/objects.jsonl
        18M	/opt/iobroker/iobroker-data/objects.json.migrated
        18M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.0
        /usr/bin/node 		v18.19.0
        /usr/bin/npm 		10.2.3
        /usr/bin/npx 		10.2.3
        /usr/bin/corepack 	0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @harmonyhub/discover@1.0.8 /opt/iobroker/node_modules/@harmonyhub/discover
        npm ERR! extraneous: @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
        npm ERR! extraneous: @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
        npm ERR! extraneous: @serialport/parser-delimiter@1.0.5 /opt/iobroker/node_modules/@serialport/parser-delimiter
        npm ERR! extraneous: @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
        npm ERR! extraneous: @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
        npm ERR! extraneous: @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
        npm ERR! extraneous: alexa-cookie2@2.1.0 /opt/iobroker/node_modules/alexa-cookie2
        npm ERR! extraneous: alexa-remote2@2.3.2 /opt/iobroker/node_modules/alexa-remote2
        npm ERR! extraneous: ansi-bgblack@0.1.1 /opt/iobroker/node_modules/ansi-bgblack
        npm ERR! extraneous: ansi-bgblue@0.1.1 /opt/iobroker/node_modules/ansi-bgblue
        npm ERR! extraneous: ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/ansi-bgcyan
        npm ERR! extraneous: ansi-bggreen@0.1.1 /opt/iobroker/node_modules/ansi-bggreen
        npm ERR! extraneous: ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/ansi-bgmagenta
        npm ERR! extraneous: ansi-bgred@0.1.1 /opt/iobroker/node_modules/ansi-bgred
        npm ERR! extraneous: ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/ansi-bgwhite
        npm ERR! extraneous: ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/ansi-bgyellow
        npm ERR! extraneous: ansi-black@0.1.1 /opt/iobroker/node_modules/ansi-black
        npm ERR! extraneous: ansi-blue@0.1.1 /opt/iobroker/node_modules/ansi-blue
        npm ERR! extraneous: ansi-bold@0.1.1 /opt/iobroker/node_modules/ansi-bold
        npm ERR! extraneous: ansi-colors@0.2.0 /opt/iobroker/node_modules/ansi-colors
        npm ERR! extraneous: ansi-cyan@0.1.1 /opt/iobroker/node_modules/ansi-cyan
        npm ERR! extraneous: ansi-dim@0.1.1 /opt/iobroker/node_modules/ansi-dim
        npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/ansi-gray
        npm ERR! extraneous: ansi-green@0.1.1 /opt/iobroker/node_modules/ansi-green
        npm ERR! extraneous: ansi-grey@0.1.1 /opt/iobroker/node_modules/ansi-grey
        npm ERR! extraneous: ansi-hidden@0.1.1 /opt/iobroker/node_modules/ansi-hidden
        npm ERR! extraneous: ansi-inverse@0.1.1 /opt/iobroker/node_modules/ansi-inverse
        npm ERR! extraneous: ansi-italic@0.1.1 /opt/iobroker/node_modules/ansi-italic
        npm ERR! extraneous: ansi-magenta@0.1.1 /opt/iobroker/node_modules/ansi-magenta
        npm ERR! extraneous: ansi-red@0.1.1 /opt/iobroker/node_modules/ansi-red
        npm ERR! extraneous: ansi-reset@0.1.1 /opt/iobroker/node_modules/ansi-reset
        npm ERR! extraneous: ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/ansi-strikethrough
        npm ERR! extraneous: ansi-underline@0.1.1 /opt/iobroker/node_modules/ansi-underline
        npm ERR! extraneous: ansi-white@0.1.1 /opt/iobroker/node_modules/ansi-white
        npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/ansi-wrap
        npm ERR! extraneous: ansi-yellow@0.1.1 /opt/iobroker/node_modules/ansi-yellow
        npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/arr-diff
        npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/arr-flatten
        npm ERR! extraneous: arr-swap@1.0.1 /opt/iobroker/node_modules/arr-swap
        npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/arr-union
        npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/array-unique
        npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/assign-symbols
        npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/atob
        npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
        npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/base
        npm ERR! extraneous: bottleneck@2.19.2 /opt/iobroker/node_modules/bottleneck
        npm ERR! extraneous: braces@2.3.2 /opt/iobroker/node_modules/braces
        npm ERR! extraneous: buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/buffer-alloc-unsafe
        npm ERR! extraneous: buffer-alloc@1.2.0 /opt/iobroker/node_modules/buffer-alloc
        npm ERR! extraneous: buffer-fill@1.0.0 /opt/iobroker/node_modules/buffer-fill
        npm ERR! extraneous: busboy@0.2.14 /opt/iobroker/node_modules/busboy
        npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/cache-base
        npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
        npm ERR! extraneous: choices-separator@2.0.0 /opt/iobroker/node_modules/choices-separator
        npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/class-utils
        npm ERR! extraneous: clone-deep@1.0.0 /opt/iobroker/node_modules/clone-deep
        npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/collection-visit
        npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/copy-descriptor
        npm ERR! extraneous: decode-uri-component@0.2.0 /opt/iobroker/node_modules/decode-uri-component
        npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/define-property
        npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
        npm ERR! extraneous: dotenv@4.0.0 /opt/iobroker/node_modules/dotenv
        npm ERR! extraneous: dropbox-v2-api@2.3.0 /opt/iobroker/node_modules/dropbox-v2-api
        npm ERR! extraneous: error-symbol@0.1.0 /opt/iobroker/node_modules/error-symbol
        npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
        npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/expand-brackets
        npm ERR! extraneous: expand-template@1.1.1 /opt/iobroker/node_modules/expand-template
        npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/extend-shallow
        npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/extglob
        npm ERR! extraneous: fill-range@4.0.0 /opt/iobroker/node_modules/fill-range
        npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/for-in
        npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/for-own
        npm ERR! extraneous: fragment-cache@0.2.1 /opt/iobroker/node_modules/fragment-cache
        npm ERR! extraneous: gauge@2.7.4 /opt/iobroker/node_modules/gauge
        npm ERR! extraneous: get-value@2.0.6 /opt/iobroker/node_modules/get-value
        npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
        npm ERR! extraneous: harmonyhubws@1.0.6 /opt/iobroker/node_modules/harmonyhubws
        npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
        npm ERR! extraneous: has-value@1.0.0 /opt/iobroker/node_modules/has-value
        npm ERR! extraneous: has-values@1.0.0 /opt/iobroker/node_modules/has-values
        npm ERR! extraneous: http-proxy-middleware@0.19.1 /opt/iobroker/node_modules/http-proxy-middleware
        npm ERR! extraneous: info-symbol@0.1.0 /opt/iobroker/node_modules/info-symbol
        npm ERR! extraneous: iobroker.type-detector@0.1.2 /opt/iobroker/node_modules/iobroker.type-detector
        npm ERR! extraneous: is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@0.1.4 /opt/iobroker/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@0.1.6 /opt/iobroker/node_modules/is-descriptor
        npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
        npm ERR! extraneous: is-number@6.0.0 /opt/iobroker/node_modules/is-number
        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/is-plain-object
        npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
        npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/isobject
        npm ERR! extraneous: kind-of@6.0.2 /opt/iobroker/node_modules/kind-of
        npm ERR! extraneous: koalas@1.0.2 /opt/iobroker/node_modules/koalas
        npm ERR! extraneous: lazy-cache@2.0.2 /opt/iobroker/node_modules/lazy-cache
        npm ERR! extraneous: log-ok@0.1.1 /opt/iobroker/node_modules/log-ok
        npm ERR! extraneous: log-utils@0.2.1 /opt/iobroker/node_modules/log-utils
        npm ERR! extraneous: map-cache@0.2.2 /opt/iobroker/node_modules/map-cache
        npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/map-visit
        npm ERR! extraneous: md5@2.2.1 /opt/iobroker/node_modules/md5
        npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/micromatch
        npm ERR! extraneous: mixin-deep@1.3.2 /opt/iobroker/node_modules/mixin-deep
        npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/mixin-object
        npm ERR! extraneous: nanomatch@1.2.13 /opt/iobroker/node_modules/nanomatch
        npm ERR! extraneous: node-hue-api@2.4.6 /opt/iobroker/node_modules/node-hue-api
        npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
        npm ERR! extraneous: npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
        npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/object-copy
        npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/object-visit
        npm ERR! extraneous: object.pick@1.3.0 /opt/iobroker/node_modules/object.pick
        npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
        npm ERR! extraneous: pascalcase@0.1.1 /opt/iobroker/node_modules/pascalcase
        npm ERR! extraneous: pointer-symbol@1.0.0 /opt/iobroker/node_modules/pointer-symbol
        npm ERR! extraneous: posix-character-classes@0.1.1 /opt/iobroker/node_modules/posix-character-classes
        npm ERR! extraneous: prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
        npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
        npm ERR! extraneous: prompt-actions@3.0.2 /opt/iobroker/node_modules/prompt-actions
        npm ERR! extraneous: prompt-base@4.1.0 /opt/iobroker/node_modules/prompt-base
        npm ERR! extraneous: prompt-checkbox@2.2.0 /opt/iobroker/node_modules/prompt-checkbox
        npm ERR! extraneous: prompt-choices@4.1.0 /opt/iobroker/node_modules/prompt-choices
        npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
        npm ERR! extraneous: prompt-question@5.0.2 /opt/iobroker/node_modules/prompt-question
        npm ERR! extraneous: prompt-radio@1.2.1 /opt/iobroker/node_modules/prompt-radio
        npm ERR! extraneous: pushover-notifications@1.2.0 /opt/iobroker/node_modules/pushover-notifications
        npm ERR! extraneous: radio-symbol@2.0.0 /opt/iobroker/node_modules/radio-symbol
        npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
        npm ERR! extraneous: readline-ui@2.2.3 /opt/iobroker/node_modules/readline-ui
        npm ERR! extraneous: readline-utils@2.2.3 /opt/iobroker/node_modules/readline-utils
        npm ERR! extraneous: regex-not@1.0.2 /opt/iobroker/node_modules/regex-not
        npm ERR! extraneous: repeat-element@1.1.3 /opt/iobroker/node_modules/repeat-element
        npm ERR! extraneous: repeat-string@1.6.1 /opt/iobroker/node_modules/repeat-string
        npm ERR! extraneous: request-promise-native@1.0.7 /opt/iobroker/node_modules/request-promise-native
        npm ERR! extraneous: resolve-url@0.2.1 /opt/iobroker/node_modules/resolve-url
        npm ERR! extraneous: ret@0.1.15 /opt/iobroker/node_modules/ret
        npm ERR! extraneous: safe-regex@1.1.0 /opt/iobroker/node_modules/safe-regex
        npm ERR! extraneous: semaphore@1.0.5 /opt/iobroker/node_modules/semaphore
        npm ERR! extraneous: serialport@6.2.2 /opt/iobroker/node_modules/serialport
        npm ERR! extraneous: set-getter@0.1.0 /opt/iobroker/node_modules/set-getter
        npm ERR! extraneous: set-value@3.0.2 /opt/iobroker/node_modules/set-value
        npm ERR! extraneous: shallow-clone@1.0.0 /opt/iobroker/node_modules/shallow-clone
        npm ERR! extraneous: snapdragon-node@2.1.1 /opt/iobroker/node_modules/snapdragon-node
        npm ERR! extraneous: snapdragon-util@3.0.1 /opt/iobroker/node_modules/snapdragon-util
        npm ERR! extraneous: snapdragon@0.8.2 /opt/iobroker/node_modules/snapdragon
        npm ERR! extraneous: source-map-resolve@0.5.2 /opt/iobroker/node_modules/source-map-resolve
        npm ERR! extraneous: source-map-url@0.4.0 /opt/iobroker/node_modules/source-map-url
        npm ERR! extraneous: source-map@0.5.7 /opt/iobroker/node_modules/source-map
        npm ERR! extraneous: split-string@3.1.0 /opt/iobroker/node_modules/split-string
        npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/static-extend
        npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
        npm ERR! extraneous: streamsearch@0.1.2 /opt/iobroker/node_modules/streamsearch
        npm ERR! extraneous: strip-color@0.1.0 /opt/iobroker/node_modules/strip-color
        npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
        npm ERR! extraneous: success-symbol@0.1.0 /opt/iobroker/node_modules/success-symbol
        npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
        npm ERR! extraneous: terminal-paginator@2.0.2 /opt/iobroker/node_modules/terminal-paginator
        npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/time-stamp
        npm ERR! extraneous: to-buffer@1.1.1 /opt/iobroker/node_modules/to-buffer
        npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/to-object-path
        npm ERR! extraneous: to-regex-range@2.1.1 /opt/iobroker/node_modules/to-regex-range
        npm ERR! extraneous: to-regex@3.0.2 /opt/iobroker/node_modules/to-regex
        npm ERR! extraneous: toggle-array@1.0.1 /opt/iobroker/node_modules/toggle-array
        npm ERR! extraneous: traits@0.4.0 /opt/iobroker/node_modules/traits
        npm ERR! extraneous: union-value@1.0.1 /opt/iobroker/node_modules/union-value
        npm ERR! extraneous: unset-value@1.0.0 /opt/iobroker/node_modules/unset-value
        npm ERR! extraneous: urix@0.1.0 /opt/iobroker/node_modules/urix
        npm ERR! extraneous: use@3.1.1 /opt/iobroker/node_modules/use
        npm ERR! extraneous: virtual-device-sdk@1.5.16 /opt/iobroker/node_modules/virtual-device-sdk
        npm ERR! extraneous: warning-symbol@0.1.0 /opt/iobroker/node_modules/warning-symbol
        npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
        npm ERR! extraneous: window-size@1.1.1 /opt/iobroker/node_modules/window-size
        npm ERR! extraneous: debug@4.1.1 /opt/iobroker/node_modules/@harmonyhub/discover/node_modules/debug
        npm ERR! extraneous: ms@2.1.1 /opt/iobroker/node_modules/@harmonyhub/discover/node_modules/ms
        npm ERR! extraneous: cookie@0.4.0 /opt/iobroker/node_modules/alexa-cookie2/node_modules/cookie
        npm ERR! extraneous: ws@6.2.1 /opt/iobroker/node_modules/alexa-remote2/node_modules/ws
        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/arr-swap/node_modules/is-number
        npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/base/node_modules/component-emitter
        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/base/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/base/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/base/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/base/node_modules/is-descriptor
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/braces/node_modules/extend-shallow
        npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/busboy/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/busboy/node_modules/string_decoder
        npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/cache-base/node_modules/component-emitter
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/cache-base/node_modules/extend-shallow
        npm ERR! extraneous: set-value@2.0.1 /opt/iobroker/node_modules/cache-base/node_modules/set-value
        npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/chalk/node_modules/ansi-styles
        npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/class-utils/node_modules/define-property
        npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/clone-deep/node_modules/kind-of
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/define-property/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/define-property/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/define-property/node_modules/is-descriptor
        npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/dicer/node_modules/readable-stream
        npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/dicer/node_modules/string_decoder
        npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/expand-brackets/node_modules/define-property
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/expand-brackets/node_modules/extend-shallow
        npm ERR! extraneous: fs-extra@4.0.3 /opt/iobroker/node_modules/express-fileupload/node_modules/fs-extra
        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/extend-shallow/node_modules/is-extendable
        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/extglob/node_modules/define-property
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extglob/node_modules/extend-shallow
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/extglob/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/extglob/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/extglob/node_modules/is-descriptor
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/fill-range/node_modules/extend-shallow
        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/fill-range/node_modules/is-number
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/fill-range/node_modules/kind-of
        npm ERR! extraneous: aproba@1.2.0 /opt/iobroker/node_modules/gauge/node_modules/aproba
        npm ERR! extraneous: ws@6.2.0 /opt/iobroker/node_modules/harmonyhubws/node_modules/ws
        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/has-values/node_modules/is-number
        npm ERR! extraneous: kind-of@4.0.0 /opt/iobroker/node_modules/has-values/node_modules/kind-of
        npm ERR! invalid: samsungtv@0.0.0 /opt/iobroker/node_modules/samsungtv
        npm ERR! invalid: syno@3.0.0 /opt/iobroker/node_modules/syno
        npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/is-descriptor/node_modules/kind-of
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/md5/node_modules/is-buffer
        npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/mixin-deep/node_modules/is-extendable
        npm ERR! extraneous: for-in@0.1.8 /opt/iobroker/node_modules/mixin-object/node_modules/for-in
        npm ERR! extraneous: axios@0.19.2 /opt/iobroker/node_modules/node-hue-api/node_modules/axios
        npm ERR! extraneous: debug@3.1.0 /opt/iobroker/node_modules/node-hue-api/node_modules/debug
        npm ERR! extraneous: follow-redirects@1.5.10 /opt/iobroker/node_modules/node-hue-api/node_modules/follow-redirects
        npm ERR! extraneous: sax@1.2.4 /opt/iobroker/node_modules/node-hue-api/node_modules/sax
        npm ERR! extraneous: xml2js@0.4.19 /opt/iobroker/node_modules/node-hue-api/node_modules/xml2js
        npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/object-copy/node_modules/define-property
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/object-copy/node_modules/kind-of
        npm ERR! extraneous: decompress-response@3.3.0 /opt/iobroker/node_modules/prebuild-install/node_modules/decompress-response
        npm ERR! extraneous: detect-libc@1.0.3 /opt/iobroker/node_modules/prebuild-install/node_modules/detect-libc
        npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/prebuild-install/node_modules/mimic-response
        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/prebuild-install/node_modules/mkdirp
        npm ERR! extraneous: node-abi@2.30.1 /opt/iobroker/node_modules/prebuild-install/node_modules/node-abi
        npm ERR! extraneous: simple-get@2.8.1 /opt/iobroker/node_modules/prebuild-install/node_modules/simple-get
        npm ERR! extraneous: tar-fs@1.16.3 /opt/iobroker/node_modules/prebuild-install/node_modules/tar-fs
        npm ERR! extraneous: tar-stream@1.6.2 /opt/iobroker/node_modules/prebuild-install/node_modules/tar-stream
        npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/prompt-base/node_modules/component-emitter
        npm ERR! extraneous: debug@3.2.6 /opt/iobroker/node_modules/prompt-base/node_modules/debug
        npm ERR! extraneous: ms@2.1.1 /opt/iobroker/node_modules/prompt-base/node_modules/ms
        npm ERR! extraneous: clone-deep@4.0.1 /opt/iobroker/node_modules/prompt-choices/node_modules/clone-deep
        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/prompt-choices/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/prompt-choices/node_modules/is-data-descriptor
        npm ERR! extraneous: kind-of@6.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/kind-of
        npm ERR! extraneous: shallow-clone@3.0.0 /opt/iobroker/node_modules/prompt-choices/node_modules/shallow-clone
        npm ERR! extraneous: debug@3.2.6 /opt/iobroker/node_modules/prompt-question/node_modules/debug
        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/prompt-question/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/prompt-question/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/prompt-question/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/prompt-question/node_modules/is-descriptor
        npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/prompt-question/node_modules/kind-of
        npm ERR! extraneous: ms@2.1.1 /opt/iobroker/node_modules/prompt-question/node_modules/ms
        npm ERR! extraneous: ansi-regex@3.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/ansi-regex
        npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/readline-ui/node_modules/component-emitter
        npm ERR! extraneous: is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/is-fullwidth-code-point
        npm ERR! extraneous: string-width@2.1.1 /opt/iobroker/node_modules/readline-ui/node_modules/string-width
        npm ERR! extraneous: strip-ansi@4.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/strip-ansi
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/readline-utils/node_modules/extend-shallow
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/readline-utils/node_modules/is-buffer
        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/readline-utils/node_modules/is-number
        npm ERR! extraneous: mute-stream@0.0.7 /opt/iobroker/node_modules/readline-utils/node_modules/mute-stream
        npm ERR! extraneous: request-promise-core@1.1.2 /opt/iobroker/node_modules/request-promise-native/node_modules/request-promise-core
        npm ERR! invalid: tough-cookie@2.4.3 /opt/iobroker/node_modules/tough-cookie
        npm ERR! extraneous: bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings
        npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/serialport/node_modules/commander
        npm ERR! extraneous: debug@3.2.6 /opt/iobroker/node_modules/serialport/node_modules/debug
        npm ERR! extraneous: ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms
        npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/shallow-clone/node_modules/kind-of
        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/snapdragon-node/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/snapdragon-node/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/snapdragon-node/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/snapdragon-node/node_modules/is-descriptor
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/snapdragon-util/node_modules/kind-of
        npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/snapdragon/node_modules/define-property
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/snapdragon/node_modules/extend-shallow
        npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/static-extend/node_modules/define-property
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/terminal-paginator/node_modules/extend-shallow
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/to-object-path/node_modules/kind-of
        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/to-regex-range/node_modules/is-number
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/to-regex-range/node_modules/kind-of
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/union-value/node_modules/extend-shallow
        npm ERR! extraneous: set-value@2.0.1 /opt/iobroker/node_modules/union-value/node_modules/set-value
        npm ERR! extraneous: has-value@0.3.1 /opt/iobroker/node_modules/unset-value/node_modules/has-value
        npm ERR! extraneous: has-values@0.1.4 /opt/iobroker/node_modules/unset-value/node_modules/has-values
        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/unset-value/node_modules/isarray
        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/window-size/node_modules/define-property
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/window-size/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/window-size/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/window-size/node_modules/is-descriptor
        npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/window-size/node_modules/is-number
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/arr-swap/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/fill-range/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/has-values/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/has-values/node_modules/kind-of/node_modules/is-buffer
        npm ERR! missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
        npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-accessor-descriptor/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-data-descriptor/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: xmlbuilder@9.0.7 /opt/iobroker/node_modules/node-hue-api/node_modules/xml2js/node_modules/xmlbuilder
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/object-copy/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: minimist@1.2.6 /opt/iobroker/node_modules/prebuild-install/node_modules/mkdirp/node_modules/minimist
        npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/prebuild-install/node_modules/tar-fs/node_modules/chownr
        npm ERR! extraneous: pump@1.0.3 /opt/iobroker/node_modules/prebuild-install/node_modules/tar-fs/node_modules/pump
        npm ERR! extraneous: bl@1.2.3 /opt/iobroker/node_modules/prebuild-install/node_modules/tar-stream/node_modules/bl
        npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/prebuild-install/node_modules/tar-stream/node_modules/fs-constants
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/define-property/node_modules/is-descriptor
        npm ERR! extraneous: kind-of@6.0.2 /opt/iobroker/node_modules/prompt-question/node_modules/is-accessor-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@6.0.2 /opt/iobroker/node_modules/prompt-question/node_modules/is-data-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@6.0.2 /opt/iobroker/node_modules/prompt-question/node_modules/is-descriptor/node_modules/kind-of
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/readline-utils/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/snapdragon-util/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/to-object-path/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/to-regex-range/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: isobject@2.1.0 /opt/iobroker/node_modules/unset-value/node_modules/has-value/node_modules/isobject
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/window-size/node_modules/is-number/node_modules/kind-of
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/arr-swap/node_modules/is-number/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/has-values/node_modules/is-number/node_modules/kind-of/node_modules/is-buffer
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/window-size/node_modules/is-number/node_modules/kind-of/node_modules/is-buffer
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-03T10_18_32_216Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	7.1.4
        Adapters from github: 	1
        Adapter State
        + system.adapter.admin.0                  : admin                 : Raspi                                    -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : Raspi                                    - disabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : Raspi                                    -  enabled, compact disabled
          system.adapter.backitup.0               : backitup              : Raspi                                    - disabled, compact disabled
          system.adapter.denon.0                  : denon                 : Raspi                                    - disabled, compact disabled
          system.adapter.discovery.0              : discovery             : Raspi                                    - disabled, compact disabled
          system.adapter.email.0                  : email                 : Raspi                                    - disabled, compact disabled
          system.adapter.harmony.0                : harmony               : Raspi                                    - disabled, compact disabled
          system.adapter.history.0                : history               : Raspi                                    - disabled, compact disabled
          system.adapter.hm-rega.0                : hm-rega               : Raspi                                    -  enabled, compact disabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : Raspi                                    -  enabled, compact disabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : Raspi                                    -  enabled, compact disabled, port: 0
        + system.adapter.hue-extended.0           : hue-extended          : Raspi                                    -  enabled, compact disabled
          system.adapter.hue.0                    : hue                   : Raspi                                    - disabled, compact disabled, port: 80
          system.adapter.info.0                   : info                  : Raspi                                    - disabled, compact disabled
          system.adapter.iot.0                    : iot                   : Raspi                                    - disabled, compact disabled
          system.adapter.javascript.0             : javascript            : Raspi                                    -  enabled, compact disabled
        + system.adapter.lgtv.0                   : lgtv                  : Raspi                                    -  enabled, compact disabled
          system.adapter.mielecloudservice.0      : mielecloudservice     : Raspi                                    - disabled, compact disabled
          system.adapter.mobile.0                 : mobile                : Raspi                                    - disabled
          system.adapter.mqtt.0                   : mqtt                  : Raspi                                    - disabled, compact disabled, port: 1886, bind: 0.0.0.0
        + system.adapter.netatmo.0                : netatmo               : Raspi                                    -  enabled, compact disabled
          system.adapter.pushover.0               : pushover              : Raspi                                    - disabled, compact disabled
          system.adapter.robonect.0               : robonect              : Raspi                                    - disabled, compact disabled
          system.adapter.rpi2.0                   : rpi2                  : Raspi                                    - disabled
          system.adapter.shelly.1                 : shelly                : Raspi                                    - disabled, compact disabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : Raspi                                    -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonos.0                  : sonos                 : Raspi                                    -  enabled, compact disabled
          system.adapter.spotify-premium.0        : spotify-premium       : Raspi                                    - disabled, compact disabled
          system.adapter.synology.0               : synology              : Raspi                                    - disabled, compact disabled, port: 5001
          system.adapter.tankerkoenig.0           : tankerkoenig          : Raspi                                    - disabled, compact disabled
          system.adapter.telegram.0               : telegram              : Raspi                                    - disabled, compact disabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : Raspi                                    - disabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.text2command.0           : text2command          : Raspi                                    - disabled, compact disabled
          system.adapter.tr-064.0                 : tr-064                : Raspi                                    - disabled, compact disabled
          system.adapter.vis-bars.0               : vis-bars              : Raspi                                    -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : Raspi                                    -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Raspi                                    -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Raspi                                    -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : Raspi                                    -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : Raspi                                    -  enabled
          system.adapter.vis-weather.0            : vis-weather           : Raspi                                    -  enabled
          system.adapter.vis.0                    : vis                   : Raspi                                    - disabled, compact disabled
          system.adapter.weatherunderground.0     : weatherunderground    : Raspi                                    - disabled, compact disabled
          system.adapter.web.0                    : web                   : Raspi                                    - disabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.3.5  [Updatable]
        Adapter    "alexa2"       : 3.26.3   , installed 3.24.1 [Updatable]
        Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
        Adapter    "bmw"          : 2.5.7    , installed 2.5.7
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "harmony"      : 1.3.0    , installed 1.2.2  [Updatable]
        Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
        Adapter    "hm-rega"      : 4.0.0    , installed 3.0.47 [Updatable]
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
        Adapter    "hue"          : 3.10.1   , installed 3.9.5  [Updatable]
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
        Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
        Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "luftdaten"    : 3.1.0    , installed 3.0.0  [Updatable]
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "miele"        : 0.1.5    , installed 0.1.5
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mihome-vacuum": 4.1.0    , installed 3.11.0 [Updatable]
        Adapter    "mqtt"         : 5.1.0    , installed 4.1.1  [Updatable]
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "robonect"     : 1.3.4    , installed 1.1.5  [Updatable]
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
        Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
        Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
        Adapter    "sonos"        : 3.0.0    , installed 2.3.1  [Updatable]
        Adapter    "spotify-premium": 1.3.1  , installed 1.2.2  [Updatable]
        Adapter    "synology"     : 3.0.1    , installed 2.1.13 [Updatable]
        Adapter    "telegram"     : 2.0.1    , installed 1.16.0 [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "weatherunderground": 3.6.0, installed 3.4.2 [Updatable]
        Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
        Objects and States
        Objects: 	29724
        States: 	16082
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      998        19270      907/pihole-FTL
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21273      583/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19437      583/iobroker.js-con
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          21549      966/node /home/pi/n
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11474      1/init
        tcp        0      0 192.168.1.13:2001       0.0.0.0:*               LISTEN      1001       42768      1533/io.hm-rpc.0
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      998        19260      907/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19025      615/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15104      352/cupsd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19942      894/exim4
        tcp        0      0 192.168.1.13:8701       0.0.0.0:*               LISTEN      1001       47503      1769/io.hm-rpc.1
        tcp        0      0 0.0.0.0:8093            0.0.0.0:*               LISTEN      0          20051      897/lighttpd
        tcp6       0      0 ::1:4711                :::*                    LISTEN      998        18178      907/pihole-FTL
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          21207      966/node /home/pi/n
        tcp6       0      0 :::3501                 :::*                    LISTEN      1001       48683      1395/io.sonos.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          11477      1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26107      1223/io.admin.0
        tcp6       0      0 :::21                   :::*                    LISTEN      112        18206      935/proftpd: (accep
        tcp6       0      0 :::53                   :::*                    LISTEN      998        19262      907/pihole-FTL
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          19084      680/xrdp-sesman
        tcp6       0      0 :::22                   :::*                    LISTEN      0          19027      615/sshd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       46242      2163/io.simple-api.
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15103      352/cupsd
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19943      894/exim4
        tcp6       0      0 :::3389                 :::*                    LISTEN      114        18203      846/xrdp
        tcp6       0      0 :::8093                 :::*                    LISTEN      0          20052      897/lighttpd
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           998        19259      907/pihole-FTL
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14218      561/dhcpcd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9292       1/init
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14177      481/cups-browsed
        udp        0      0 192.168.1.13:123        0.0.0.0:*                           0          19687      596/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          19685      596/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          19681      596/ntpd
        udp        0      0 0.0.0.0:40628           0.0.0.0:*                           105        16835      350/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           105        16833      350/avahi-daemon: r
        udp6       0      0 :::53                   :::*                                998        19261      907/pihole-FTL
        udp6       0      0 :::111                  :::*                                0          10314      1/init
        udp6       0      0 fe80::9430:807f:382:123 :::*                                0          19691      596/ntpd
        udp6       0      0 ::1:123                 :::*                                0          19689      596/ntpd
        udp6       0      0 :::123                  :::*                                0          19678      596/ntpd
        udp6       0      0 :::5353                 :::*                                105        16834      350/avahi-daemon: r
        udp6       0      0 :::45482                :::*                                105        16836      350/avahi-daemon: r
        2023-12-03 11:20:11.989  - error: host.Raspi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js',
        2023-12-03 11:20:11.989  - error: host.Raspi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.javascript/main.js'
        2023-12-03 11:20:11.989  - error: host.Raspi Caught by controller[0]:   ]
        2023-12-03 11:20:11.990  - error: host.Raspi Caught by controller[0]: }
        2023-12-03 11:20:11.990  - error: host.Raspi Caught by controller[0]: Node.js v18.19.0
        2023-12-03 11:20:11.991  - error: host.Raspi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2023-12-03 11:20:11.991  - info: host.Raspi Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        2023-12-03 11:20:24.874  - info: alexa2.0 (1800) Unknown Device, but enabling commands, Try it and report back if commands work.
        2023-12-03 11:20:24.876  - info: alexa2.0 (1800) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
        2023-12-03 11:20:24.878  - info: alexa2.0 (1800)     Device-type:A2RG3FY1YV97SS - Alexander's Sonos Move (Sonos Move) (Sonos Move) (Sonos Move) (Sonos Move) (Sonos Move) (Sonos Move) (Sonos Move) (Sonos Move) (Sonos Move) (HANDS_FREE,SET_LOCALE,DEEZER,DIALOG_INTERFACE_VERSION,SLEEP,VOLUME_SETTING,TIDAL,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SOUND_SETTINGS,SUPPORTS_LOCALE,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SIRIUSXM,I_HEART_RADIO,ADAPTIVE_LISTENING,GOLDFISH,CHANGE_NAME,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SPEECH_RECOGNIZER_USS,APPLE_MUSIC,FAR_FIELD,AUDIO_PLAYER,EARCONS,SUPPORTS_LOCALE_SWITCH,SET_TIME_ZONE,REMINDERS,DREAM_TRAINING,MUSIC_SKILL,AMAZON_MUSIC,DEREGISTER_DEVICE,KINDLE_BOOKS,AUDIBLE,PERSISTENT_CONNECTION,TUNE_IN,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS)
        2023-12-03 11:20:27.799  - info: hue-extended.0 (2123) State value to set for "hue-extended.0.schedules.058-sdfakj234w57das_g7_6.status" has to be type "boolean" but received type "string"
        2023-12-03 11:20:27.804  - info: hue-extended.0 (2123) State value to set for "hue-extended.0.schedules.060-sdfklj23487das_g7_6.status" has to be type "boolean" but received type "string"
        2023-12-03 11:20:28.094  - info: hue-extended.0 (2123) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
        2023-12-03 11:20:28.098  - info: hue-extended.0 (2123) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel_min" has to be type "string" but received type "number"
        2023-12-03 11:20:28.201  - info: alexa2.0 (1800) Unknown Device, but enabling commands, Try it and report back if commands work.
        2023-12-03 11:20:28.202  - info: alexa2.0 (1800) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
        2023-12-03 11:20:28.203  - info: alexa2.0 (1800)     Device-type:A3BW5ZVFHRCQPO - Alexander's BMW Group - Amazon Alexa Car Integration (BMW Group - Amazon Alexa Car Integration) (BMW Group – Amazon Alexa Car Integration) (HANDS_FREE,PEONY,DEEZER,SLEEP,VOLUME_SETTING,TIDAL,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,I_HEART_RADIO,ADAPTIVE_LISTENING,GOLDFISH,CHANGE_NAME,MICROPHONE,APPLE_MUSIC,AUDIO_PLAYER,REMINDERS,DREAM_TRAINING,MUSIC_SKILL,AMAZON_MUSIC,DEREGISTER_DEVICE,KINDLE_BOOKS,AUDIBLE,PERSISTENT_CONNECTION,TUNE_IN,TIMERS_AND_ALARMS)
        2023-12-03 11:20:59.909  - info: hue-extended.0 (2123) State value to set for "hue-extended.0.sensors.055-hue_ambient_light_sensor_3.state.lightlevel" has to be type "string" but received type "number"
        2023-12-03 11:21:37.012  - warn: sonos.0 (1395) State "sonos.0.root.192_168_1_38.current_station" has no existing object, this might lead to an error in future versions
        2023-12-03 11:21:37.016  - warn: sonos.0 (1395) State "sonos.0.root.192_168_1_38.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-03 11:21:37.028  - warn: sonos.0 (1395) State "sonos.0.root.192_168_1_38.queue_html" has no existing object, this might lead to an error in future versions
        2023-12-03 11:21:41.316  - info: alexa2.0 (1800) No smart home devices to query
        2023-12-03 11:21:49.599  - info: alexa2.0 (1800) Subscribing to states...
        2023-12-03 11:21:49.610  - info: alexa2.0 (1800) Deleting the following states: ["Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f","Smart-Home-Devices.27c11434-4f20-4307-9932-b646f378a3d8","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b","Smart-Home-Devices.8538a229-322a-43c5-a01d-092f597c2e13","Smart-Home-Devices.5187483a-33ec-48b1-9585-6dc13ad225fd","Smart-Home-Devices.63466aa0-391d-4267-9622-21ce006d023b","Smart-Home-Devices.916c8ddc-8f34-4f2e-94fb-e3185cf36426","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540","Smart-Home-Devices.7dfc2cc9-df99-4791-8091-1cd044ccc6a1","Smart-Home-Devices.d0b4e002-be43-4487-971e-707ae66571f4","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f","Smart-Home-Devices.d1a44840-c027-44b3-8bcb-3a90a5fb13d4","Smart-Home-Devices.902385ff-7599-4c0a-bff3-1d11d6c858fc","Smart-Home-Devices.6ee45440-b30e-4248-af10-f3a73dd436ac","Smart-Home-Devices.c7deca16-3fcf-4646-aa59-02ae59c9d00c","Smart-Home-Devices.a06d3094-c877-442b-925f-a262ee6d1293","Smart-Home-Devices.4f5ce600-e1a5-4c10-a0a9-ccd7ff8790bd","Smart-Home-Devices.21687d12-35c8-4aab-9704-372b29ac79ff","Smart-Home-Devices.7d6809e0-a0b5-480c-bfdc-db742387f888","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c","Smart-Home-Devices.2468af02-e5ae-4f76-bff5-cdb9cee37f74","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee","Contacts.AHHYR5TT2HE46VLSKOHJQTE5WEQQ","Contacts.AFVEBRYFDLHHYDSJORLITV6X5M3A","Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f.#enabled","Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f.#delete","Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f.percentage","Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f.#query","Smart-Home-Devices.27c11434-4f20-4307-9932-b646f378a3d8.#enabled","Smart-Home-Devices.27c11434-4f20-4307-9932-b646f378a3d8.#delete","Smart-Home-Devices.27c11434-4f20-4307-9932-b646f378a3d8.powerState","Smart-Home-Devices.27c11434-4f20-4307-9932-b646f378a3d8.#query","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b.#enabled","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b.#delete","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b.percentage","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b.#query","Smart-Home-Devices.a04cc11f-081e-4d2a-90f9-4c536c1b2926.colorTemperatureName","Smart-Home-Devices.a04cc11f-081e-4d2a-90f9-4c536c1b2926.colorTemperatureInKelvin","Smart-Home-Devices.a04cc11f-081e-4d2a-90f9-4c536c1b2926.connectivity","Smart-Home-Devices.8538a229-322a-43c5-a01d-092f597c2e13.#enabled","Smart-Home-Devices.8538a229-322a-43c5-a01d-092f597c2e13.#delete","Smart-Home-Devices.8538a229-322a-43c5-a01d-092f597c2e13.active","Smart-Home-Devices.5187483a-33ec-48b1-9585-6dc13ad225fd.#enabled","Smart-Home-Devices.5187483a-33ec-48b1-9585-6dc13ad225fd.#delete","Smart-Home-Devices.5187483a-33ec-48b1-9585-6dc13ad225fd.active","Smart-Home-Devices.63466aa0-391d-4267-9622-21ce006d023b.#enabled","Smart-Home-Devices.63466aa0-391d-4267-9622-21ce006d023b.#delete","Smart-Home-Devices.63466aa0-391d-4267-9622-21ce006d023b.active","Smart-Home-Devices.916c8ddc-8f34-4f2e-94fb-e3185cf36426.#enabled","Smart-Home-Devices.916c8ddc-8f34-4f2e-94fb-e3185cf36426.#delete","Smart-Home-Devices.916c8ddc-8f34-4f2e-94fb-e3185cf36426.active","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540.#enabled","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540.#delete","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540.active","Smart-Home-Devices.7dfc2cc9-df99-4791-8091-1cd044ccc6a1.#enabled","Smart-Home-Devices.7dfc2cc9-df99-4791-8091-1cd044ccc6a1.#delete","Smart-Home-Devices.7dfc2cc9-df99-4791-8091-1cd044ccc6a1.active","Smart-Home-Devices.d0b4e002-be43-4487-971e-707ae66571f4.#enabled","Smart-Home-Devices.d0b4e002-be43-4487-971e-707ae66571f4.#delete","Smart-Home-Devices.d0b4e002-be43-4487-971e-707ae66571f4.active","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f.#enabled","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f.#delete","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f.active","Smart-Home-Devices.d1a44840-c027-44b3-8bcb-3a90a5fb13d4.#enabled","Smart-Home-Devices.d1a44840-c027-44b3-8bcb-3a90a5fb13d4.#delete","Smart-Home-Devices.d1a44840-c027-44b3-8bcb-3a90a5fb13d4.active","Smart-Home-Devices.902385ff-7599-4c0a-bff3-1d11d6c858fc.#enabled","Smart-Home-Devices.902385ff-7599-4c0a-bff3-1d11d6c858fc.#delete","Smart-Home-Devices.902385ff-7599-4c0a-bff3-1d11d6c858fc.active","Smart-Home-Devices.6ee45440-b30e-4248-af10-f3a73dd436ac.#enabled","Smart-Home-Devices.6ee45440-b30e-4248-af10-f3a73dd436ac.#delete","Smart-Home-Devices.6ee45440-b30e-4248-af10-f3a73dd436ac.active","Smart-Home-Devices.c7deca16-3fcf-4646-aa59-02ae59c9d00c.#enabled","Smart-Home-Devices.c7deca16-3fcf-4646-aa59-02ae59c9d00c.#delete","Smart-Home-Devices.c7deca16-3fcf-4646-aa59-02ae59c9d00c.active","Smart-Home-Devices.a06d3094-c877-442b-925f-a262ee6d1293.#enabled","Smart-Home-Devices.a06d3094-c877-442b-925f-a262ee6d1293.#delete","Smart-Home-Devices.a06d3094-c877-442b-925f-a262ee6d1293.active","Smart-Home-Devices.4f5ce600-e1a5-4c10-a0a9-ccd7ff8790bd.#enabled","Smart-Home-Devices.4f5ce600-e1a5-4c10-a0a9-ccd7ff8790bd.#delete","Smart-Home-Devices.4f5ce600-e1a5-4c10-a0a9-ccd7ff8790bd.active","Smart-Home-Devices.21687d12-35c8-4aab-9704-372b29ac79ff.#enabled","Smart-Home-Devices.21687d12-35c8-4aab-9704-372b29ac79ff.#delete","Smart-Home-Devices.21687d12-35c8-4aab-9704-372b29ac79ff.active","Smart-Home-Devices.7d6809e0-a0b5-480c-bfdc-db742387f888.#enabled","Smart-Home-Devices.7d6809e0-a0b5-480c-bfdc-db742387f888.#delete","Smart-Home-Devices.7d6809e0-a0b5-480c-bfdc-db742387f888.active","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c.#enabled","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c.#delete","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c.active","Smart-Home-Devices.2468af02-e5ae-4f76-bff5-cdb9cee37f74.#enabled","Smart-Home-Devices.2468af02-e5ae-4f76-bff5-cdb9cee37f74.#delete","Smart-Home-Devices.2468af02-e5ae-4f76-bff5-cdb9cee37f74.active","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4.#enabled","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4.#delete","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4.active","Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f.Blind-Lift-rangeValue","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b.Blind-Lift-rangeValue","Smart-Home-Devices.a04cc11f-081e-4d2a-90f9-4c536c1b2926.connectivity-reason","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540.Scene-Mode-mode","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540.#query","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f.Scene-Mode-mode","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f.#query","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c.Scene-Mode-mode","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c.#query","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4.Scene-Mode-mode","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4.#query","Smart-Home-Devices.17be4409-c058-4d45-9287-d58fea953c3f.#includeInAllQuery","Smart-Home-Devices.27c11434-4f20-4307-9932-b646f378a3d8.#includeInAllQuery","Smart-Home-Devices.801bc656-aedb-48eb-aa59-b076ddd6277b.#includeInAllQuery","Smart-Home-Devices.8f9526d8-a383-4ccc-9a96-d3b070f2b540.#includeInAllQuery","Smart-Home-Devices.297e8aeb-9311-4417-952b-cfdf366c7a1f.#includeInAllQuery","Smart-Home-Devices.de43879a-1ca4-406f-bda6-ff71e3c7786c.#includeInAllQuery","Smart-Home-Devices.a9eb256c-48e7-4f80-adff-517f247681f4.#includeInAllQuery","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.#enabled","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.#delete","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.powerState","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.connectivity","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.connectivity-reason","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.#query","Smart-Home-Devices.7a4e1603-9594-4fcd-85be-004ce16f9650.#includeInAllQuery","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.#enabled","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.#delete","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.powerState","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.connectivity","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.connectivity-reason","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.#query","Smart-Home-Devices.a783ae68-ed35-4939-ad56-4e77ec2b23e2.#includeInAllQuery","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.#enabled","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.#delete","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.powerState","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.connectivity","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.connectivity-reason","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.#query","Smart-Home-Devices.72e717a7-7199-4533-ba34-a386072d178e.#includeInAllQuery","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.#enabled","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.#delete","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.Blinds-Position-rangeValue","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.connectivity","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.connectivity-reason","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.#query","Smart-Home-Devices.e95397d0-a917-4de7-8358-08f312d217ee.#includeInAllQuery","Smart-Home-Devices.4b9a880a-4e3c-44d3-934d-65bcae79dc23.percentage","Smart-Home-Devices.4b9a880a-4e3c-44d3-934d-65bcae79dc23.Blind-Lift-rangeValue","Contacts.AHHYR5TT2HE46VLSKOHJQTE5WEQQ.textMessage","Contacts.AFVEBRYFDLHHYDSJORLITV6X5M3A.textMessage"]
        2023-12-03 11:22:04.702  - info: alexa2.0 (1800) Alexa-Push-Connection (macDms = true) established. Disable Polling
        			v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Installation: 		native
        Kernel: 		armv7l
        Userland: 		armhf
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	27
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
        			/usr/bin/npm 		10.2.3
        			/usr/bin/npx 		10.2.3
        Recommended versions are nodejs  Cannot load "custom": Connection is closed.
         Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"! and npm
        MEMORY:
        Mem:           923M        528M         82M        1.0M        311M        340M
        Swap:           99M         99M        0.0K
        Total:         1.0G        627M         83M
        Active iob-Instances: 	10
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		29724
        States: 		16082
        Size of iob-Database:
        27M	/opt/iobroker/iobroker-data/objects.jsonl
        17M	/opt/iobroker/iobroker-data/objects.json.broken
        12K	/opt/iobroker/iobroker-data/objects.json.old
        17M	/opt/iobroker/iobroker-data/states.jsonl
        2.5M	/opt/iobroker/iobroker-data/states.json.migrated
        2.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
        1.9M	/opt/iobroker/iobroker-data/states.json.old
        0	/opt/iobroker/iobroker-data/states.json.broken
        • A Accu
          @thomas-braun said in Adapter werden nicht mehr geupdated:
        iob stop        iob fix        iob nodejs-update
          vielen Dank @Thomas-Braun:
          hat irgendwas hingeschrieben, dass er die Kernel Version nicht detecten kann.
          ioBroker nodejs fixer 2023-10-13
          Recommended nodejs-version is: 16.20.2
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/nodejs 	v14.21.3
          /usr/bin/node 		v14.21.3
          /usr/bin/npm 		6.14.18
          /usr/local/bin/npx 		8.1.2
          /usr/local/bin/corepack 	0.10.0
          *** nodejs is NOT correctly installed ***
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 14.21.3-deb-1nodesource1
            Candidate: 14.21.3-deb-1nodesource1
            Version table:
           *** 14.21.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u3 500
          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
          Press <y> to continue or any other key to quit
          Fixing your nodejs setup
          *** Deleting /usr/local/bin/npx ***
          *** Deleting /usr/local/bin/corepack ***
          Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
          You are running nodejs v14.21.3. Do you want to install recommended version 16.20.2?
          Trying to update your installation now. Please be patient.
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6272 B]
          Fetched 18.4 kB in 1s (13.9 kB/s)
          Installing the recommended nodejs version now!
          (Reading database ... 144046 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.19.0-1nodesource1_armhf.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.19.0-1nodesource1) over (14.21.3-deb-1nodesource1) ...
          Setting up nodejs (18.19.0-1nodesource1) ...
          Processing triggers for man-db (2.8.5-2) ...
          Scanning processes...
          Scanning candidates...
          Scanning linux images...
          Failed to check for processor microcode upgrades.
          Restarting services...
           systemctl restart pm2.service
          No containers need to be restarted.
          No user sessions are running outdated binaries.
          Installing the recommended nodejs version!
          We tried our best to fix your nodejs. Please run iob diag again to verify.
          *** RESTARTING ioBroker NOW! ***
           Please refresh or restart your browser in a few moments.
          @accu
          Dein Betriebssysrem ist zu alt.
          Aktualisier das auf Raspberry OS 12 'Bookworm'
          A 2 Antworten Letzte Antwort
            @accu
            Accu
            @thomas-braun wie mache ich das am sichersten ohne alles zu schrotten?
            • da_WoodyD Offline
              da_WoodyD Offline
              @accu wie schafft man Start und Ende in codetags zu bringen, den Rest aber nicht?
              • da_WoodyD da_Woody
                Accu
                @da_woody gute Frage, hatte ich auch gewundert, dass er es nicht genommen hatte.
                • A Accu
                  @accu sagte in Adapter werden nicht mehr geupdated:
                  ioBroker auf Stand bringen,
                  Backup ziehen,
                  Betriebssystem komplett von Grund auf neu installieren,
                  Backup einspielen.
                  • A Accu
                    zu viele code-tags an falschen Stellen!
                    ich hab's gefixt
                    bitte exakte Ausgabe posten.
                    • A Accu
                      @accu
                      Und 1GB RAM dürfte bei der Zahl der Adapter auch zu wenig sein. Insbesondere, da auch noch piHole und sowas läuft.
                        @accu
                        Accu
                        schrieb am zuletzt editiert von Accu
                        @thomas-braun pihole sollte nicht mehr laufen. Hatte ich deinstalliert. Scheinen aber immer noch irgendwelche Überreste da geblieben zu sein, die ich nicht mehr losbekomme.
                        Bzgl. upgrade hatte ich gehofft, ich kann es einfach "in place" machen so wie damals von Jessy --> auf Buster gemacht hatte. Lief dann nach dem Upgrade noch alles problemlos.
                        Gerade auch mal versucht den Admin zu upgraden - aber der scheint sich da tot zulaufen:
                        • A Accu
                          mit welcher node Version jetzt?
                          @homoran sagte in Adapter werden nicht mehr geupdated:
                          auf welche Node version sollte man gehen?
                          steht doch extra da!
                          sollte auch beim Versuch upzudaten kommen
                          • A Accu
                            Nein, geht nicht.
                              Nein, geht nicht.
                              Accu
                              @thomas-braun warum nicht - bei Jessi auf Buster gings doch auch. Glaube aber ich muss jetzt eh alles neu machen. Aktuell komme ich nicht mehr auf den ioBroker drauf:
                              pi@Raspi:~ $ iob status
                              node:internal/modules/cjs/loader:1137
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                                  at Module._load (node:internal/modules/cjs/loader:975:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                  at node:internal/main/run_main_module:28:49 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              Node.js v18.19.0
                              pi@Raspi:~ $
                              • Thomas BraunT Online
                                warum nicht
                                Weil sich hier sehr viel geändert hat. Ein Wechsel der Architektur geht ohnehin nur per Neuinstallation.
                                  warum nicht
                                  Accu
                                  @thomas-braun die Frage ist ob das neue OS überhaupt irgendwie auf meinem alten Raspi mit dem kleinen Speicher läuft. Glaube dann lasse ich es erstmal so und nutze die paar Sachen weiter die laufen -- sofern ich den ioBroker irgendwie wieder zum Laufen bekomme.
                                  • A Accu
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    pi@Raspi:~ $
                                    @accu
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.js-controller
                                    • A Accu
                                      Ein abgekündigtes System zu betreiben ist keine Option.
                                        @accu
                                        cd /opt/iobroker
                                        Accu
                                        @thomas-braun Hat er sich jetzt aufgehangen oder soll man da wieder zum Prompt zurückkommen?
                                        pi@Raspi:~ $ cd /opt/iobroker
                                        pi@Raspi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                        npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
                                        npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
                                        npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
                                        (##################) ⠋ reify:syno: timing arborist:ctor Completed in 4ms
                                        • A Accu
                                          @accu
                                          Das läuft noch. Deine Kiste ist ja kein Rennpferd.
