  4. Flot Adapter: zeigt die vorhandenen Diagramme nicht mehr an.
23 Beiträge 3 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • K Karacho
    wie kann ich manuelle die diagramme wieder sichtbar machen?
    Karacho
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker7
           Icon name: computer
              Kernel: Linux 6.1.0-rpi6-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     13:59:42 up 15:57,  3 users,  load average: 0.64, 0.65, 0.50
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** Time and Time Zones ***
                   Local time: Sat 2023-12-02 13:59:42 CET
               Universal time: Sat 2023-12-02 12:59:42 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        2.2G        1.1G         26M        785M        1.7G
    Swap:           104M          0B        104M
    Total:          4.1G        2.2G        1.2G
             3793 M total memory
             2141 M used memory
             2310 M active memory
              270 M inactive memory
             1010 M free memory
               43 M buffer memory
              706 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    Can't open device file: /dev/vcio
    Try creating a device file with: sudo mknod /dev/vcio c 100 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  379M   1% /run
    /dev/mmcblk0p2 ext4       58G  7.2G   48G  13% /
    tmpfs          tmpfs     1.9G  152K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     380M   36K  380M   1% /run/user/106
    tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
    [Fri Dec  1 22:01:58 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=aae4be3f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Fri Dec  1 22:02:01 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Dec  1 22:02:03 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    724M    /var/
    233M    /var/log/journal/91daad0776a14141898a052dbbda684b
    233M    /var/log
    195M    /var/lib
    Archived and active journals take up 232.0M in the file system.
    /opt/iobroker/backups:
    46M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    959M    /opt/iobroker/iobroker-data/
    693M    /opt/iobroker/iobroker-data/history
    219M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker7                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker7                                -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker7                                -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker7                                -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker7                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker7                                -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker7                                -  enabled
      system.adapter.devices.0                : devices               : iobroker7                                -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker7                                -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker7                                -  enabled
    + system.adapter.easee.0                  : easee                 : iobroker7                                -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker7                                -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker7                                -  enabled
      system.adapter.flot.0                   : flot                  : iobroker7                                -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker7                                -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker7                                -  enabled
    + system.adapter.history.0                : history               : iobroker7                                -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker7                                -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker7                                -  enabled
      system.adapter.hs100.0                  : hs100                 : iobroker7                                - disabled
      system.adapter.ical.0                   : ical                  : iobroker7                                -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker7                                -  enabled
    + system.adapter.info.0                   : info                  : iobroker7                                -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker7                                -  enabled
    + system.adapter.meater.0                 : meater                : iobroker7                                -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : iobroker7                                -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker7                                -  enabled, port: 54321
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker7                                -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker7                                -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker7                                -  enabled
    + system.adapter.smartgarden.0            : smartgarden           : iobroker7                                -  enabled
    + system.adapter.solarlog.0               : solarlog              : iobroker7                                -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : iobroker7                                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : iobroker7                                -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker7                                -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker7                                -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker7                                -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker7                                -  enabled
      system.adapter.vis.0                    : vis                   : iobroker7                                -  enabled
    + system.adapter.web.0                    : web                   : iobroker7                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : iobroker7                                -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker7                                -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bmw"          : 2.5.7    , installed 2.6.3
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.1.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.1
    Adapter    "harmony"      : 1.3.0    , installed 1.2.2  [Updatable]
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hs100"        : 2.2.0    , installed 2.2.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "meater"       : 1.0.2    , installed 1.0.2
    Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarlog"     : 2.2.8    , installed 2.2.8
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.96.0 [Updatable]
    Adapter    "vis-justgage" : 2.0.2    , installed 2.0.0  [Updatable]
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        8419
    States:         7194
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14738      843/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       143118     20949/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       143122     20949/iobroker.js-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          39476      3783/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       143319     21139/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14740      843/sshd: /usr/sbin
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          13896      773/xrdp-sesman
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       147483     22169/io.harmony.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       141988     21120/io.nuki-exten
    tcp6       0      0 :::3389                 :::*                    LISTEN      112        18650      846/xrdp
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          39475      3783/cupsd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       145315     22229/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       143612     20973/io.admin.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       144487     21178/io.mihome-vac
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       147484     22169/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          37424      3785/cups-browsed
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       147548     22249/io.broadlink2
    udp        0      0 0.0.0.0:48181           0.0.0.0:*                           1001       145375     22249/io.broadlink2
    udp        0      0 0.0.0.0:56437           0.0.0.0:*                           104        3970       486/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3968       486/avahi-daemon: r
    udp        0      0 0.0.0.0:60678           0.0.0.0:*                           1001       147551     22249/io.broadlink2
    udp6       0      0 :::5353                 :::*                                104        3969       486/avahi-daemon: r
    udp6       0      0 :::46608                :::*                                104        3971       486/avahi-daemon: r
    2023-12-02 13:58:10.211  - info: admin.0 (20973) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:14.975  - info: admin.0 (20973) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:42.567  - info: admin.0 (20973) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:46.782  - info: admin.0 (20973) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:48.325  - info: admin.0 (20973) <== Disconnect system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:51.286  - info: web.0 (22229) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:51.518  - info: web.0 (22229) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:53.884  - info: web.0 (22229) ==> Connected system.user.admin from ::ffff:192.168.178.44
    2023-12-02 13:58:59.632  - info: web.0 (22229) <== Disconnect system.user.admin from ::ffff:192.168.178.44 flot
    2023-12-02 13:58:59.637  - info: web.0 (22229) <== Disconnect system.user.admin from ::ffff:192.168.178.44 flotEditDialog
    2023-12-02 13:58:59.638  - info: web.0 (22229) <== Disconnect system.user.admin from ::ffff:192.168.178.44 flotEdit
    2023-12-02 14:00:00.155  - info: host.iobroker7 instance system.adapter.dwd.0 started with pid 22884
    2023-12-02 14:00:03.511  - info: dwd.0 (22884) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16
    2023-12-02 14:00:04.184  - info: host.iobroker7 instance system.adapter.daswetter.0 started with pid 22914
    2023-12-02 14:00:07.312  - info: daswetter.0 (22914) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.16
    2023-12-02 14:00:07.353  - info: daswetter.0 (22914) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-12-02 14:00:07.877  - info: daswetter.0 (22914) cleaned everything up...
    2023-12-02 14:00:07.895  - info: host.iobroker7 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-02 14:00:08.201  - info: host.iobroker7 instance system.adapter.ical.0 started with pid 22946
    2023-12-02 14:00:08.314  - info: dwd.0 (22884) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-02 14:00:08.867  - info: host.iobroker7 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-02 14:00:11.214  - info: ical.0 (22946) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.16
    2023-12-02 14:00:11.541  - info: ical.0 (22946) processing URL: Abfuhr-2023 /opt/iobroker/iobroker-data/Abfuhr-Moss-2023.ics
    2023-12-02 14:00:16.729  - info: ical.0 (22946) Terminated (NO_ERROR): Without reason
    2023-12-02 14:00:17.273  - info: host.iobroker7 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    • K Karacho
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3793 M total memory
               2141 M used memory
               1010 M free memory
                 43 M buffer memory
                706 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      *** FILESYSTEM ***
      /var:
      724M    /var/
      233M    /var/log
      195M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8419
      States:         7194
      Pending Updates: 1
      @karacho
      Warum läuft da ein Desktop/X-Server?
      • K Karacho
        sehr lange.... kein einziger Adapter hat sich installiert....
        @karacho sagte in Flot Adapter: zeigt die vorhandenen Diagramme nicht mehr an.:
        sehr lange...
        heisst in belastbaren Zahlen?
        Da ich nicht weiss was da schiefgelaufen ist, kann ich das nicht sagen.
        Nach einem korrekten Restore hätte alles da sein müssen
        edit
        history hast du aber auch wiederhergestellt??
          sehr lange...
          edit
          Karacho
          über Nacht.
          • normal installiert
          • restore iobroker eingespielt
          • alle instanzen tauchen auf mit schwarzem Punkt
          • über Nacht laufen lassen
          • nix passiert
          History alles wiederhergestellt. In derVisualiserung sind alle Diagramme da und werden mit Daten gefüttert und sind auch aktuell.
          Nur über Flot sind die Diagramme nicht da...
            @karacho
            Karacho
            Weil ich auch über Desktop mir verzeichnisbäume anschaue
            Ist das ein Problem?
            • K Karacho
              @karacho
              Ja, auf einem Server setzt man keine GUI ein.
              Diese Meldung kommt auch aus der GUI-Ecke.
                @karacho
                Karacho
                Ist das der Grund?
                • K Karacho
                  Ist das der Grund?
                  @karacho
                  Vielleicht. Jedenfalls ist die Basis bei dir schon schief.
                    Karacho
                    @karacho
                    Aber den Desktop habe ich viel später installiert....
                    Kann das daran liegen, dass Buster auf einer SSD lief... Davon Backup und dann Bookworm auf einer SD hat gar nicht geklappt.
                    Habe dann die SSD auf SD Card kopiert - da läuft das alte Buster stabil auf der SD und ist auch alles da.
                    Dann von dort Backup für Neuinstallation Bookworm auf SD und das Backup Buster SD auf Restore Bookworm SD klappt nicht...
                    • K Karacho
                      @karacho
                      nein!
                      warum nicht?
                      was hat das log / die Konsole gesagt?
                      das geht meistens schief. Oft auch erst nur verdeckt
                        Karacho
                        Ich installier jetzt noch mal neu...
                        wie rufe ich das log auf?
                        ich mache auf dem alten System Backup von iobroker, history, zigbee und javascripts... das ist es doch?
                        • K Karacho
                          64Bit Lite
                          iob logs --watch | uniq
                          • K Karacho
                            das ist es doch?
                            javascript ist in iobroker enthalten
                              das ist es doch?
                              Karacho
                              schrieb am zuletzt editiert von Karacho
                              In welcher Reihenfolge restore
                              1. iobroker
                              2. History
                              3. zigbee
                              Vorher vis installieren und aktivieren?
                              • K Karacho
                                1. iobroker
                                2. History
                                3. zigbee
                                @karacho klingt gut.
                                ich nutze kein zigbee.
                                vis vorher installieren.
                                und bitte Meldungen in code-tags posten!
                                  Karacho
                                  nach Installation Bookworm und iobroker kommt folgendes im iobroker
                                  2023-12-02 17:22:48.051 - warn: admin.0 (9213) Repository cannot be read: Active repo - stable
                                  2023-12-02 17:22:48.052 - warn: admin.0 (9213) Active repository "stable" cannot be read
                                  • K Karacho
                                    wie sind die Pfade der Repos definiert.
                                    kommt das bei jedem reload der Seite Adapter, oder nur einmalig
                                    oder mach mal iob update
                                      Karacho
                                      • iob update nichts zu aktualisieren
                                      • nach restart kommt im Protokoll diese Meldung nicht mehr
                                      • es kommt nur noch Vis spezielles
                                        • keine Lizenz obwohl aktiviert
                                      --> hab ejetzt restore iobroker gemacht und lasse jetzt laufen....
                                      --> heisst aber auch gar nix machen und einfach laufen lassen richtig?
                                      --> Instanzen nicht starten richtig?
                                      JEder Adapter der versucht wird zu installieren:
                                      host.iobroker8
                                      2023-12-02 18:28:30.736	warn	startInstance cannot find adapter "worx@2.3.4". Try to install it... 1 attempt
                                      host.iobroker8
                                      2023-12-02 18:27:46.941	warn	startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                                      host.iobroker8
                                      2023-12-02 18:27:30.108	warn	startInstance cannot find adapter "vis-timeandweather@1.2.2". Try to install it... 1 attempt
                                      host.iobroker8
                                      2023-12-02 18:27:13.284	warn	startInstance cannot find adapter "vis-rgraph@0.0.2". Try to install it... 1 attempt
                                      host.iobroker8
                                      2023-12-02 18:26:55.881	warn	startInstance cannot find adapter "vis-justgage@2.0.0". Try to install it... 1 attempt
                                      host.iobroker8
                                      2023-12-02 18:26:51.572	warn	startInstance cannot find adapter "vis-icontwo". Try to install it... 2 attempt
                                      • K Karacho
                                        host.iobroker8
                                        host.iobroker8
                                        host.iobroker8
                                        host.iobroker8
                                        host.iobroker8
                                        host.iobroker8
                                        zeigen!
                                        alles, incl eingabe
                                        höchstens per Konsole iob logs --watch um zu sehen wo er teht
                                        warum nicht?
                                        aber ist möglicherweise erst mal gut so.
