    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • CluniC Cluni
    @armilar said in SONOFF NSPanel mit Lovelace UI:
    @cluni
    Nein, Alle Verzeichnisse (Datenpunkte) in 0_userdata.0 und alias.0, die das NSPanel automatisch angelegt hat löschen...
    Dann das Script neu starten und erneut anlegen lassen... Dann sollte auch alles gefüllt sein...
    Das hat nichts geändert.
    @tt-tom said in SONOFF NSPanel mit Lovelace UI:
    Kannst du bitte den Debug Modus vom Panel aktivieren und das Script nochmals starten und das log dann posten.
    Hier das LOG:
    16:12:46.069	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: compiling TypeScript source...
    16:12:47.598	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: source code did not change, using cached compilation result...
    16:12:47.937	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: setObjects enabled - create Alias Channels possible
    16:12:47.968	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: weather alias for accuweather.0. already exists
    16:12:48.104	warn	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: error at function check_updates: Cannot read properties of null (reading 'split')
    16:12:48.105	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: registered 30 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    16:12:48.843	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Desired TFT Firmware: 53 / v4.3.3
    16:12:48.844	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Installed TFT Firmware: 53 / v4.3.3
    16:12:49.139	warn	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: error setState in function get_tasmota_status0Cannot read properties of undefined (reading 'Version')
    16:12:49.154	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Debug mode activated
    16:12:49.395	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: get_current_tasmota_ip_address: 192.168.0.126
    16:12:49.814	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting tasmota firmware version
    16:12:49.819	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting current berry driver version
    16:12:49.820	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: get_current_tasmota_ip_address: 192.168.0.126
    16:12:49.822	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online berry driver version
    16:12:49.823	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online TFT version
    16:12:49.825	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online firmware version
    16:12:50.192	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online display firmware version => 53
    16:12:50.310	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online TFT firmware version => 4.3.3
    16:12:50.334	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: current berry driver version => undefined
    16:12:50.417	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online berry driver version => 9
    16:12:50.509	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online tasmota firmware version => 13.2.0
    16:12:53.489	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Start MQTT-Port-Check -------------------------------------
    16:12:53.490	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- admin.0 - 8081
    16:12:53.490	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- hm-rpc.0 - 0
    16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- hue.0 - 443
    16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- influxdb.0 - 8086
    16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- mihome-vacuum.0 - 5432
    16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- mqtt.0 - 1883
    16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- shelly.0 - 1882
    16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- telegram.0 - 8443
    16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- web.0 - 8082
    16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- zigbee.0 - /dev
    16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1883
    16:12:53.494	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: End MQTT-Port-Check ---------------------------------------
    16:12:59.307	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: moments.js --> Datum 2023-11-27T08:10:00+01:00 valid?: true
    16:12:59.310	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleScreensaverUpdate payload: weatherUpdate~~~~25407~~4.5 °C~~~~65363~Sonne~08:10~~~~26095~Wind~4.7m/s~~~~34351~Böen~9.5m/s~~~~65535~Windr.~180°~
    16:12:59.315	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleMessage -> sleepReached
    16:13:00.039	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: moments.js --> Datum 2023-11-27T08:10:00+01:00 valid?: true
    16:13:00.042	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleScreensaverUpdate payload: weatherUpdate~~~~25407~~4.5 °C~~~~65363~Sonne~08:10~~~~26095~Wind~4.7m/s~~~~34351~Böen~9.5m/s~~~~65535~Windr.~180°~
    CluniC Offline
    CluniC Offline
    Cluni
    #4386
    Liegt das am Berry driver?
    Den habe ich aber auch gestern noch auf den neusten Stand gebracht über den Befehl:
    Backlog UrlFetch https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
    • ArmilarA Armilar
      @cluni
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #4387
      Update v4.3.3.14
      Was ist passiert?
      Der Sonos-Media-Player hat ne Menge Funktionalität bekommen und hat sich zu einem richtig coolen Player entwickelt...
      • anlegen von Playlists jetzt Möglich
      • automatisches Abgreifen der Tracklist
      • Favoritenliste wird angezeigt (und kann natürlich auch bedient werden)
      • Equalizer kann alternativ zur Favoritenliste genutzt werden
      • kleinere Fixes zu den Funktionen von gestern (Die anderen Player)
      Tester gesucht:
      Da ich leider nur eine der ersten Sonos One habe, ist ein umfänglicher Sonos Test natürlich nicht einfach. Daher würde ich die Sonos-User unter euch kurz um ein Feedback bitten...
      Was ist neu an der Seitenvariable?
      Player mit Favoriten:
      let Sonos = <PageMedia>
          'type': 'cardMedia',
          'heading': 'Sonos',
          'useColor': true,
          'items': [<PageItem>{
                      id: AliasPath + 'Media.PlayerSonos',
                      adapterPlayerInstance: 'sonos.0.',
                      mediaDevice: '192_168_1_212',
                      speakerList: ['Terrasse'],
                      playList: ['Hartmann','Armilars Playlist'],
                      colorMediaIcon: colorSonos,
                      colorMediaArtist: Yellow,
                      colorMediaTitle: Yellow,
                      alwaysOnDisplay: true,
                      autoCreateALias: true
      Player mit Equalizer:
          'heading': 'Sonos',
          'useColor': true,
                      equalizerList: ['Bassboost','Klassik','Dance', 'Deep', 'Electronic', 'Flat', 'Hip-Hop', 'Rock',
                                      'Metal', 'Jazz', 'Latin', 'Tonstärke', 'Lounge', 'Piano'],
      wie gestern im Update schon verfügbar, gibt es die Funktion alwaysOnDisplay: true,. Damit bekommt der Player noch einmal einen richtigen Schub...
      Da es kein verfügbares Sonos-Logo gibt, habe ich mal einen Kreis mit einem "S" verwendet und die aktuellen Sonosfarben benutzt.
      const colorSonos:       RGB = { red: 216, green: 161, blue:  88 };
      einfach irgendwo zwischen den Konstanten einfügen, falls ihr die Farbe nutzen möchtet:
      So und das wars auch schon wieder...
      Viel Spaß beim ausprobieren.
      LG
      @TT-Tom & Armilar 😊
      P.S: Den Rest der Woche habt ihr jetzt "Release-Ruhe" von meiner Seite ;-)
      EDIT: Das NSPanelTs.ts bekommt ihr natürlich wie immer hier:
      https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
      Es reicht, den unteren Teil ab:
      zu tauschen.
      • CluniC Cluni
        TT-Tom
        #4388
        @cluni
        Gib bitte mal im Browser http:// ip Adresse Panel /cm?cmnd=GetDriverVersion ein und poste mal das Ergebnis.
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        • T TT-Tom
          @cluni
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #4389
          @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
          @Cluni
          Kann es sein dass du dein NSPanel im Tasmota mit einem Passwort (http) gesichert hast?
          Falls ja, dann muss das Passwort ebenfalls in das Script:
          // nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
              const tasmota_web_admin_user: string = 'admin';
              // setzten, falls "Web Admin Password" in Tasmota vergeben
              const tasmota_web_admin_password: string = '';
          Falls nicht abgesichert, aber im Script irgendwas eingetragen, dann bitte im Script wieder entfernen... Dann bleiben die Zeilen exakt so, wie oben abgebildet.
          Der Post von @TT-Tom hat mich da hingeschubst. Dadurch würden die HTTP-Abfragen des Scriptes blockiert und können natürlich auch nicht ausgewertet werden... Es wird nicht ausschließlich MQTT verwendet...
          T CluniC 2 Antworten Letzte Antwort
          • ArmilarA Armilar
            @Cluni
            TT-Tom
            #4390
            @armilar
            ja den Verdacht hatte ich auch schon. Wollte nochmal sicher gehen, mit der Browserausgabe.
            Gruß Tom
            Public Transport
            • ArmilarA Armilar
              @Cluni
              CluniC Offline
              CluniC Offline
              Cluni
              schrieb am zuletzt editiert von Cluni
              #4391
              Schädelklatsch :man-facepalming: - das war es!
              Vielen Dank euch beiden!!!!
              Ich dachte, dass alles über MQTT läuft.
              PS: Das Wechseln der Pages klappt übrigens auch!
              • P Offline
                Pit99
                schrieb am zuletzt editiert von Pit99
                #4392
                habe das NSPanel und Lovelace UI.
                möchte es abgeben, so das ich das NSPanel auf die Werkseinstellung zurück setzten möchte.
                Wie mach ich das???
                Bitte um Hilfe.
                Hello
                have the NSPanel and Lovelace UI.
                I would like to hand it over so that I want to reset the NSPanel to the factory setting.
                How do I do that???
                Ask for help.
                • ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #4393
                  @pit99
                  Grundsätzlich gibt es da mind. 4 Möglichkeiten:
                  1. Versuche es nicht zu ändern - sondern verkaufe es geflashed. Gibt da einige die sich freuen würden, wenn das Teil schon fertig ist und per "DHCP" eingebunden werden kann
                  2. Stelle es hier rein: https://forum.iobroker.net/category/15/marktplatz
                  3. Suche in den 4400 Beiträgen oder in dem Vorgängerpost nach der Lösung. Es gab bereits jemanden, der es wieder in den Stock-Zustand gebracht hat.
                  4. Frage Blakadder - Ich denke er hatte eine Lösung
                  • P Offline
                    Pit99
                    #4394
                    Dank dir.
                    muss halt in den Werkszustand.
                    Gefunden hab ich noch nichts, oder habe es übersehen....
                    Also wenn jemand eine Lösung hat, gerne melden.
                    • P Pit99
                      Dank dir.
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #4395
                      @pit99
                      Handelt alles vom Originalzustand... Habe nur mal so gesucht... Ab da würde ich die Verläufe mal jeweils weiterlesen, oder die User fragen...
                      https://forum.iobroker.net/post/906187
                      https://forum.iobroker.net/post/907040
                      https://forum.iobroker.net/post/829086
                      • ArmilarA Armilar
                        Update v4.3.3.14
                        Was ist passiert?
                        Tester gesucht:
                            'heading': 'Sonos',
                            'useColor': true,
                            'heading': 'Sonos',
                            'useColor': true,
                        LG
                        @TT-Tom & Armilar 😊
                        zu tauschen.
                        docf
                        #4396
                        @armilar
                        Hi leider bekomme beim Austauschen unterhalb von der Zeile -- Ab hier keine Konfiguration mehr -- folgende Fehler
                        Muss ich da noch etwas beim Update von 4.3.3.5 beachten.
                        18:43:44.126	error	javascript.0 (30620) script.js.NS_Panels.NS_Panel_Wohnzimmer: TypeScript compilation failed: let Icons = new IconsSelector(); ^ ERROR: Cannot redeclare block-scoped variable 'Icons'. let timeoutSlider: any; ^ ERROR: Cannot redeclare block-scoped variable 'timeoutSlider'. let vwIconColor = []; ^ ERROR: Cannot redeclare block-scoped variable 'vwIconColor'. let weatherForecast: boolean; ^ ERROR: Cannot redeclare block-scoped variable 'weatherForecast'. const Icons = new IconsSelector(); ^ ERROR: Cannot redeclare block-scoped variable 'Icons'. let timeoutSlider: any; ^ ERROR: Cannot redeclare block-scoped variable 'timeoutSlider'. let vwIconColor = []; ^ ERROR: Cannot redeclare block-scoped variable 'vwIconColor'. let weatherForecast: boolean; ^ ERROR: Cannot redeclare block-scoped variable 'weatherForecast'.
                        Sven WagnerS 1 Antwort Letzte Antwort
                        • D docf
                          @armilar
                          Sven WagnerS Offline
                          Sven Wagner
                          #4397
                          @docf said in SONOFF NSPanel mit Lovelace UI:
                          @armilar
                          • ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #4398
                            @docf
                            nur den unteren Teil ausgetauscht? oder auch die Konstante mit der Farbe... Sieht für mich im ersten Moment aus, als würde da noch ein Semikolon fehlen...
                            Kannst du mir die Stellen sonst mal kurz zeigen?
                            EDIT:
                            Ja du musst da noch mehr ändern:
                            Die Struktur des Scriptes hat sich geändert. Das ist mit der v4.3.3.10 passiert und irgendwie habe ich die ReleaseNotes im Punkt 10 nicht aktualisiert...
                            Die einfachste Vorgehensweise ist von @TT-Tom hier beschrieben:
                            https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
                            Es ist für die meisten jetzt einfacher mit der Neuinstallation/Updates, da sich vieles im oberen Bereich abspielt. Hatte aber auch zur Folge, dass wir Konstanten aus dem oberen Config-Bereich in den unteren Teil verschoben haben. Diese Konstanten versucht dein "Mix"-Script jetzt erneut zu laden, daher die Fehler...
                            Die Update-Anleitung von @TT-Tom bringt das wieder in Ordnung...
                            Siehe auch https://forum.iobroker.net/post/1085163
                            • Sven WagnerS Sven Wagner
                              @armilar
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #4399
                              @sven-wagner
                              Hast du das gleiche Problem oder bist du nur noch nicht zur Frage/Antwort gekommen?
                              • ArmilarA Armilar
                                @sven-wagner
                                Josh303
                                schrieb am zuletzt editiert von Josh303
                                #4400
                                Ich habe jetzt 3 NSPanels laufen. Funktioniert soweit auch alles. Sehr schönes Projekt dafür erst mal ein Dank an die Entwickler. Ich habe allerdings noch ein Problem und hier leider noch nicht die Lösung gefunden. Ich bekomme immer folgende Fehlermeldung:
                                	script.js.NSPanel.NSPanel_3: error at function HandleScreensaverUpdate: parseFormat is not a function
                                In der JS-Instanz habe ich "moment-parseformat" und "moment" eingetragen. Ich weiß nicht mehr weiter.
                                Ich nutze die Script Version: v4.3.3.5
                                Jemand eine Idee?
                                • J Josh303
                                  Jemand eine Idee?
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #4401
                                  @josh303
                                  Jo 🙄
                                  Trage auch schon mal dayjs ein. Wenn du dabei bist, mache mal einen Screenshot von der JS-Instanz
                                  EDIT:
                                  Ich vermute mal, dass da nicht "moment-" vor dem parseformat steht oder das irgendein Dreher in den Buchstaben ist...
                                  • ArmilarA Armilar
                                    @josh303
                                    Jo 🙄
                                    EDIT:
                                    Josh303
                                    #4402
                                    @armilar
                                    habe gerade die Reihenfolge geändert, so wie bei dir. js neu gestartet. Script neu gestartet.
                                    20:26:15.575	error	javascript.0 (152658) script.js.NSPanel.NSPanel_1: Error: Cannot find module 'moment-parseformat'
                                    20:26:15.576	error	javascript.0 (152658) at script.js.NSPanel.NSPanel_1:850:19
                                    • J Josh303
                                      @armilar
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #4403
                                      @josh303
                                      Ein Träumchen...
                                      Hast du diese Zeilen in deinem Script?
                                      Musste gerade mal in die History von der v4.3.3.5
                                      Und nachdem ich den Fehler sehe...
                                      • Du hast auch nur die eine JS-Instanz?
                                      • Den ioBroker mal komplett neu gestartet? Denn irgendwie will die Instanz das Modul ja nicht laden...
                                      • Zufällig ne funktionierende Internetverbindung am ioBroker?
                                      • ArmilarA Armilar
                                        @josh303
                                        Ein Träumchen...
                                        Josh303
                                        #4404
                                        @armilar
                                        yep, die Zeilen sind drin und ich habe nur eine JS-Instanz laufen. Mache jetzt mal einen reboot.
                                        // _________________________________ Ab hier keine Konfiguration mehr _____________________________________
                                        const request = require('request');
                                        const moment  = require('moment');
                                        const parseFormat = require('moment-parseformat');
                                        moment.locale(getState(NSPanel_Path + 'Config.locale').val);
                                        //Desired Firmware
                                        const tft_version: string = 'v4.3.3';
                                        const desired_display_firmware_version = 53;
                                        const berry_driver_version = 9;
                                        • J Josh303
                                          @armilar
                                          //Desired Firmware
                                          Josh303
                                          #4405
                                          @josh303
                                          Neustart iob =>
                                          20:41:26.947	error	javascript.0 (419) script.js.NSPanel.NSPanel_1: Error: Cannot find module 'moment-parseformat'
                                          20:41:26.949	error	javascript.0 (419) at script.js.NSPanel.NSPanel_1:850:19
