  4. Test Adapter telegram-menu v.1.6.x
    6.3k
1.9k Beiträge 65 Kommentatoren 987.2k Aufrufe 63 Beobachtet
  • arteckA arteck
    @michael-roling guckst du
    bei 0.8.7
    Michael RolingM Offline
    Michael Roling
    #730
    @arteck bei was passiert das?
    • Michael RolingM Michael Roling
      arteckA Offline
      arteckA Offline
      arteck
      #731
      @michael-roling bei start
      Michael RolingM 2 Antworten Letzte Antwort
      • arteckA arteck
        Michael Roling
        #732
        @arteck ohja ich habe es gesehen, kümmere ich mich drum
        • arteckA arteck
          Michael Roling
          #733
          @arteck habe ich in der 0.9.1 gefixt
          W 1 Antwort Letzte Antwort
            W Offline
            W Offline
            Willi-Wunder
            #734
            @michael-roling
            Bekomme beim Start diese Meldung, Adapter startet jetzt nicht mehr V0.9.1
            telegram-menu.0
            	2023-11-26 11:52:05.405	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            telegram-menu.0
            	2023-11-26 11:52:05.403	info	terminating
            telegram-menu.0
            	2023-11-26 11:52:05.379	error	Cannot convert undefined or null to object
            telegram-menu.0
            	2023-11-26 11:52:05.377	error	TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at TelegramMenu.onReady (/opt/iobroker/node_modules/iobroker.telegram-menu/main.js:64:30) at TelegramMenu.emit (node:events:517:28) at TelegramMenu._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9108:18) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9087:26
            telegram-menu.0
            	2023-11-26 11:52:05.373	error	unhandled promise rejection: Cannot convert undefined or null to object
            telegram-menu.0
            	2023-11-26 11:52:05.372	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            Michael RolingM 1 Antwort Letzte Antwort
            • W Willi-Wunder
              @michael-roling
              telegram-menu.0
              telegram-menu.0
              telegram-menu.0
              telegram-menu.0
              telegram-menu.0
              telegram-menu.0
              Michael Roling
              #735
              @willi-wunder du warst zu schnell installiere 0.9.2
                Rene55R Offline
                Rene55R Offline
                Rene55
                #736
                @michael-roling Fleißig, fleißig. Ist ja mal richtig gut aufgeräumt - alle Achtung. Wenn du mal viel Lust hast, kannst du bitte auch noch "Confirm message" eindeutschen.
                • Rene55R Rene55
                  Michael Roling
                  #737
                  @rene55 top, du hast recht! Das fehlt noch 😎
                  W 2 Antworten Letzte Antwort
                    W Offline
                    W Offline
                    Willi-Wunder
                    #738
                    @michael-roling
                    Super, läuft wieder 👍
                      W Offline
                      W Offline
                      Willi-Wunder
                      #739
                      @michael-roling
                      Bei den Aktionen "GetState" + "SetState" kann man beim Bearbeiten den Rückgabetext nicht mehr markieren um diesen ggf. zu kopieren. Hier wird die ganze Zeile markiert. Im Menü geht das Markieren wie gewohnt.
                      • W Willi-Wunder
                        @michael-roling
                        Michael Roling
                        #740
                        @willi-wunder Okay, ja das ist eine css eigenschaft die ich da rein gemacht hatte weil sonst beim draggen alles markiert wurde. Schaue ich mir noch mal an
                          W Offline
                          W Offline
                          Willi-Wunder
                          #741
                          Hi, bastel mir gerade etwas zusammen. Aber irgendwie klappt das nicht so recht, kann mir da jemand einen Tipp geben?
                          Ich möchte beim Einstellen der Zirku Pumpe zuerst noch die aktuellen Werte von "Familie" + "Single" anzeigen lassen bevor ich etwas einstelle. Schöne wäre:
                          Zirku ein- oder ausschalten? (neue Zeile)
                          Familie Status xy (neue Zeile)
                          Single Status xy (neue Zeile)
                          Bei mir wird aktuell nur der erste Wert mit "true" angezeigt und nicht umgewandelt, beim zweiten Wert kommt der Code mit. Was mache ich falsch?
                          Vielen Dank.
                          Gruß Willi
                          • W Willi-Wunder
                            Vielen Dank.
                            Gruß Willi
                            Michael Roling
                            #742
                            @willi-wunder das geht erstmal nur mit einem datenpunkt
                              W Offline
                              W Offline
                              Willi-Wunder
                              #743
                              @michael-roling
                              Ah okay, danke für die Info. Aber die Umwandlung mit "true" und "false" sollte aber klappen, oder?
                                W Offline
                                W Offline
                                Willi-Wunder
                                #744
                                @michael-roling
                                Mir ist noch aufgefallen das nun alle Werte "&&" mit "&&amp" ersetzt wurden. Ist das so gewollt? Funktion ist nach wie vor da, jedoch wird es unübersichtlicher. Nur zur Info :-)
                                • W Willi-Wunder
                                  @michael-roling
                                  Michael Roling
                                  #745
                                  @willi-wunder nein mit dem && ist nicht so gewollt. War mir selbst aber noch nicht aufgefallen.
                                  Mit dem change geht meine ich auch an der Stelle noch nicht.
                                  Ich komme aber leider erst am Wochenende wieder dazu.
                                  W Michael RolingM 2 Antworten Letzte Antwort
                                    W Offline
                                    W Offline
                                    Willi-Wunder
                                    #746
                                    @michael-roling
                                    Man denkt zuerst immer selbst an einen Anwendungsfehler, bin dann beruhigt wenn es nicht an mir lag. Mach dir keinen Stress, dein Einsatz ist eh schon hammer.
                                      Michael Roling
                                      schrieb am zuletzt editiert von Michael Roling
                                      #747
                                      @Willi-Wunder Moin, so jetzt kannst du text markieren und auch das & sollte an allen Stellen weg sein.
                                      Als nächstes schaue ich mal nach dem change, du kannst in zwischenzeit schon mal testen wenn Zeit ist.
                                      Welche Fehler waren sonst noch da? Ich habe den Überblick verloren
                                      • W Willi-Wunder
                                        @michael-roling
                                        Michael Roling
                                        #748
                                        @willi-wunder so jetzt sollte es mit change auch funktionieren
                                          W Offline
                                          W Offline
                                          Willi-Wunder
                                          #749
                                          @michael-roling
                                          Hi, hab gerade die neuste Version geladen :-)
                                          Rückmeldung:
                                          && ist behoben und wird richtig dargestellt
                                          Change Befehl geht jetzt auch in der Navigation
                                          Das Markieren vom Text bei Aktion- Getstate+Setstate geht nicht. Dies geht nur bei Navigation.
                                          Frage:
                                          Die Abfrage mit den Status Befehl in der Navigation geht ja bisher nur mit einem Objekt. Ist dies noch vorgesehen das es auch mit mehreren geht?
                                          Wie kann man einen Zeilenumbruch in Navigation - bei Text erzwingen?
