  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    6.7k
267 Beiträge 8 Kommentatoren 63.7k Aufrufe 8 Beobachtet
    @gismoh und wie du siehst, der vis bug, denn laut deinem log wurde vis nicht installiert
    Gismoh
    #68
    @crunchip
    ist für mich ok mit VIS, wenn alles wieder da ist, wenn ich nur den Adapter neu installiere.
    ansonsten:
    Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp existiert nicht
    Mache dann später weiter.
    ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
    • G Gismoh
      @crunchip
      ansonsten:
      crunchipC Abwesend
      crunchipC Abwesend
      #69
      @gismoh seltsam, dann probier mal so
      iob stop
      iob fix
      cd /opt/iobroker
      npm install iobroker.ble
      iobroker upload ble
      iobroker start ble
      G 1 Antwort Letzte Antwort
        iob stop
        iob fix
        cd /opt/iobroker
        iobroker upload ble
        iobroker start ble
        Gismoh
        #70
        @crunchip
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
        npm ERR! command failed
        npm ERR! command sh -c node-gyp-build
        npm ERR! gyp info it worked if it ends with ok
        npm ERR! gyp info using node-gyp@7.1.2
        npm ERR! gyp info using node@18.18.2 | linux | x64
        npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
        npm ERR! (node:3121) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
        npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! gyp info spawn args [
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! gyp info spawn args   '-f',
        npm ERR! gyp info spawn args   'make',
        npm ERR! gyp info spawn args   '-I',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! gyp info spawn args   'build',
        npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! gyp info spawn args ]
        npm ERR! Traceback (most recent call last):
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
        npm ERR!     sys.exit(gyp.script_main())
        npm ERR!              ^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
        npm ERR!     return main(sys.argv[1:])
        npm ERR!            ^^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
        npm ERR!     return gyp_main(args)
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
        npm ERR!     [generator, flat_list, targets, data] = Load(
        npm ERR!                                             ^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
        npm ERR!     result = gyp.input.Load(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
        npm ERR!     LoadTargetBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
        npm ERR!     build_file_data = LoadOneBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
        npm ERR!     build_file_contents = open(build_file_path, "rU").read()
        npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
        npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
        npm ERR! gyp ERR! configure error
        npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
        npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
        npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
        npm ERR! gyp ERR! node -v v18.18.2
        npm ERR! gyp ERR! node-gyp -v v7.1.2
        npm ERR! gyp ERR! not ok
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T21_11_08_735Z-debug-0.log
        Verstehe es wirklich nicht, warum der ble läuft, aber nach dem einspielen des Backups nicht mehr.
        Kann man den ble irgendwie "sperren", so das das Backitup den nicht "anfasst" ?
        • G Gismoh
          @crunchip
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          #71
          @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
          Da muss in einer Datei was umgestellt werden. Hatte den Fall erst unlängst. Such mal im Forum danach.
            crunchipC Abwesend
            crunchipC Abwesend
            #72
            @thomas-braun das ahb ich ihm ja oben schon geschrieben, er findet sie aber nicht in seinem System
              Gismoh
              #73
              @crunchip
              verstehe ich nicht:
              root@ioBrokerVM:/# cd /opt
              root@ioBrokerVM:/opt# ls
              iobroker
              root@ioBrokerVM:/opt# cd /iobroker
              -bash: cd: /iobroker: Datei oder Verzeichnis nicht gefunden
              er zeigt mit das Verzeichnis iobroker erst an, dann sagt er, er hätte nichts gefunden.
              Ober ist meine Eingabe falsch?
              • G Gismoh
                @crunchip
                verstehe ich nicht:
                iobroker
                #74
                Dein Herumgehampel als root ist falsch.
                Und relative Pfade werden ohne / angesprochen. Absolute Pfade halt mit /
                Linux-Grundschule, Herr root.
                • G Gismoh
                  @crunchip
                  verstehe ich nicht:
                  iobroker
                  #75
                  @gismoh cd /opt/iobroker
                  oder
                  cd /opt
                  cd iobroker
                  beim zweiten kein / davor
                    oder
                    cd /opt
                    cd iobroker
                    Gismoh
                    #76
                    argh, merci, ein Verzeichniswechsel dacht ich da muss ein "/" vor merci
                    • G Gismoh
                      #77
                      das bringt dich wieder in die root-ebene
                      was nicht bedeutet dass man da als root rumläuft
                        Gismoh
                        #78
                        Okay, hatte ich nach einer Anleitung aufgesetzt, dort wurde es mit "root" gemacht, sogar auch in weiteren.
                        also das Verzeichnis node-gyp gibt es bei mir nicht, nur ein node-gyp-build.
                        Dieser taucht dann auf, wenn ich mich mit etwas anderem anmelde?
                        Ich suche mal nach ner Anleitung, wie ich mich andres anmelde.
                        Merci
                        • G Gismoh
                          Merci
                          #79
                          Dann schmeiß die Anleitung weg, leg dir einen User an, falls noch keiner vorhanden ist und stolper mit dem durch das System.
                          • G Gismoh
                            Merci
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #80
                            Ich hab dir den Befehl doch oben geschrieben
                            https://forum.iobroker.net/post/1076264
                              Gismoh
                              #81
                              @crunchip
                              ja, hatte ich ja auch gelesen, aber den Pfad gibt es ja bei mir (aktuell) nicht.
                              Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                              So wie ich @Thomas-Braun verstanden habe liegt das daran, das ich mit root unterwegs bin. Versuche also gleich einen anderen user anzulegen, und dann komme ich wohl zur Datei ;)
                              Thomas BraunT G 2 Antworten Letzte Antwort
                                @gismoh
                                du musst die Zeile
                                mit nano aufrufen und das U in der entsprechenden Zeile entfernen
                                abspeichern, fertig
                                sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                dabei musst du ein stück nach unten blättern
                                #82
                                @crunchip sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                                Bei mir kommt die direkt über nodejs/gyp:
                                echad@chet:~ $ locate input.py
                                /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                • G Gismoh
                                  @crunchip
                                  #83
                                  Die Datei ist auch für einen anderen user nicht vorhanden. Aber grundsätzlich kapsert man nicht als root durch das System. Schon mal gar nicht, wenn man überhaupt keine Ahnung hat was man da wo warum überhaupt macht.
                                  • G Gismoh
                                    @crunchip
                                    Gismoh
                                    #84
                                    hmm, irgendwie bekomme ich njun mit dem anderen user diese Meldung:
                                    idash@ioBrokersudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.pyput.[sudo] Passwort für idash:
                                    Sorry, user idash is not allowed to execute '/usr/bin/nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py' as root on ioBrokerVM.
                                    idash@ioBrokerVM:~$
                                    • G Gismoh
                                      idash@ioBrokerVM:~$
                                      #85
                                      groups
                                      sagt? Der ist mit Sicherheit nicht in der Gruppe 'sudo' drin.
                                      Ist aber auch für diese Datei nicht erforderlich, da mit root-Rechten zu agieren.
                                        groups
                                        Gismoh
                                        #86
                                        idash@ioBrokerVM:~$ groups
                                        idash users
                                        • G Gismoh
                                          idash users
                                          #87
                                          @gismoh
                                          Siehste...
                                          Als root:
                                          usermod -a -G adm,dialout,sudo,plugdev,input,netdev,iobroker idash
                                          exit
                                          Danach niemehr als root anmelden. Den 'idash' auch ab- und wieder anmelden.
