  4. js controller update nicht möglich
js controller
48 Beiträge 3 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    @spaddel sagte in js controller update nicht möglich:
    Ich habe noch den Homematic server auf den Pi laufen und keine Ahnung, wie das damals gemacht habe.
    Ich auch nicht.
    spaddel
    Hallo Thomas,
    leider auch im zweiten Ansatz kein Erfolg.
    Hier der Log:
    ioBroker nodejs fixer 2023-10-13
    Recommended nodejs-version is: 16.20.2
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    Nothing to do - Your installation is using the correct paths.
    Nothing to do - Your version is the recommended one.
    You can now keep your whole system up-to-date using the usual 'sudo apt update &       & sudo apt full-upgrade' commands.
    Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel.        They will break your current installation!
    pi@raspberrypi:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.3.5  [Updatable]
    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Adapter    "lgtv"         : 2.1.1    , installed 1.1.12 [Updatable]
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "synology"     : 3.0.0    , installed 2.1.13 [Updatable]
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
    pi@raspberrypi:~ $ iob upgrade all
    This upgrade of "hm-rpc" will introduce the following changes:
    -> 1.15.19:
    Updated packages
    -> 1.15.18:
    no longer support EOL versions, please upgrade to node 16
    -> 1.15.17:
    added new images (closes #778, closes #873, closes #882)
    fix wrong paramsets (closes #617, closes #584, closes #539, closes #764, closes #460, c
    fix wrong events (closes #872)
    Would you like to upgrade hm-rpc from @1.15.16 to @1.15.19 now? [(y)es, (n)o]: y
    Update hm-rpc from @1.15.16 to @1.15.19
    NPM version: 8.19.4
    Installing iobroker.hm-rpc@1.15.19... (System call)
    upload [275] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
    upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
    upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/154_hmip-spdr_thumb.png icons/154_hmip-spdr_thumb.png image/png
    upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/201_hmip-stv_thumb.png icons/201_hmip-stv_thumb.png image/png
    upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/42_hm-cc-tc_thumb.png icons/42_hm-cc-tc_thumb.png image/png
    upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/51_hm-sec-sd_thumb.png icons/51_hm-sec-sd_thumb.png image/png
    upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/59_hmw-io-12-fm_thumb.png icons/59_hmw-io-12-fm_thumb.png image/png
    upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/69_hm-lc-sw2-dr_thumb.png icons/69_hm-lc-sw2-dr_thumb.png image/png
    upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/7_hm-lc-bl1-fm_thumb.png icons/7_hm-lc-bl1-fm_thumb.png image/png
    upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/87_hm-sen-rd-o_thumb.png icons/87_hm-sen-rd-o_thumb.png image/png
    upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/99_hm-mod-em-8_thumb.png icons/99_hm-mod-em-8_thumb.png image/png
    upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/IP65_G201_thumb.png icons/IP65_G201_thumb.png image/png
    upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-cap-moist.png icons/hb-uni-sen-cap-moist.png image/png
    upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
    upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
    upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
    upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
    upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
    upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
    upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
    upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
    upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
    upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
    upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
    upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
    upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
    upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
    upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
    upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
    upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
    upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
    upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
    upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
    This upgrade of "admin" will at least introduce the following changes:
    -> 6.12.0:
    fixed issue when updating news in backend
    validate json config against the schema
    update socket-client to improve performance
    -> 6.11.0:
    jsonConfig type number now stores values as number instead of string
    objects browser number value input behavior change to allow leading minus
    Added component `interfaces` to the JSON config
    Implemented Backend to GUI communication
    -> 6.10.9:
    Improvement of the public accessibility check
    -> 6.10.8:
    update adapter-react-v5 to fix issues with object browser
    -> 6.10.7:
    Corrected adapter termination if the alias has no target
    -> 6.10.6:
    Added possibility to show the icon on JSON config tabs
    on upgrade all, not yet started commands can now be aborted
    Added security check if the server is available from the internet without protection
    Corrected navigation after the settings closing
    -> 6.10.5:
    JSON config component `port` does no longer mark port as occupied if it is only occupied on another host
    register news as notifications
    if upgrade all is stopped on error, activate close button
    Export/import objects with its values
    Would you like to upgrade admin from @6.3.5 to @6.12.0 now? [(y)es, (n)o]: y
    Update admin from @6.3.5 to @6.12.0
    NPM version: 8.19.4
    Installing iobroker.admin@6.12.0... (System call)
    Update "system.adapter.admin.0"
    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    This upgrade of "ws" will at least introduce the following changes:
    -> 2.5.5:
    upgraded socket-classes to fix crash cases
    -> 2.5.4:
    added missing node16 requirement
    -> 2.5.3:
    Added the subscribing on the specific instance messages
    -> 2.4.0:
    (bluefox) extended the getObjects function with the possibility to read the list of IDs
    -> 2.3.6:
    Allowed deletion of fullcalendar objects
    -> 2.3.5:
    added `publishFileAll` method (for future use)
    -> 2.3.4:
    corrected connection string
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade ws from @1.3.0 to @2.5.5 now? [(y)es, (n)o]: y
    Update ws from @1.3.0 to @2.5.5
    NPM version: 8.19.4
    Installing iobroker.ws@2.5.5... (System call)
    upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
    This upgrade of "web" will at least introduce the following changes:
    -> 6.1.2:
    upgrade socketio and ws dependencies
    -> 6.1.1:
    -> 6.1.0:
    -> 6.0.3:
    Updated packages
    Implemented the possibility to view folder content
    -> 6.0.1:
    Removed letsencrypt handling from web adapter
    -> 5.5.3:
    Increased max size of the uploaded file via socket.io to 200MB (from 10MB)
    -> 5.5.2:
    Would you like to upgrade web from @4.3.0 to @6.1.2 now? [(y)es, (n)o]: y
    Update web from @4.3.0 to @6.1.2
    NPM version: 8.19.4
    Installing iobroker.web@6.1.2... (System call)
    upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
    upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
    upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
    upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
    upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
    upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
    upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
    upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
    upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
    upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
    upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
    upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
    upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
    upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
    upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
    upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
    upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
    upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
    upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
    upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
    upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
    upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
    upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
    upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
    upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
    upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
    upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
    upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
    upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
    upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
    upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
    upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
    upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
    upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
    upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
    upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
    upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
    upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
    upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
    upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
    upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
    upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
    upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
    upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
    upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    This upgrade of "synology" will introduce the following changes:
    -> 3.0.0:
    Added WOL to awake Synology NAS server
    Only node 16 or higher supported
    Would you like to upgrade synology from @2.1.13 to @3.0.0 now? [(y)es, (n)o]: y
    Update synology from @2.1.13 to @3.0.0
    NPM version: 8.19.4
    Installing iobroker.synology@3.0.0... (System call)
    upload [19] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/_data.json _data.json application/json
    upload [18] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/admin.d.ts admin.d.ts video/mp2t
    upload [17] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/background.jpg background.jpg image/jpeg
    upload [16] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/cover.png cover.png image/png
    upload [15] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [14] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [13] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [12] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [11] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [10] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [9] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [8] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [6] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [5] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/index_m.html index_m.html text/html
    upload [4] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/jsonConfig.json jsonConfig.json application/json
    upload [3] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology.png synology.png image/png
    upload [2] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology_admin.png synology_admin.png image/png
    upload [1] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/tsconfig.json tsconfig.json application/json
    upload [0] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/words.js words.js application/javascript
    This upgrade of "lgtv" will introduce the following changes:
    -> 2.1.1:
    Websocket configuration has been fixed [#161].
    -> 2.1.1-alpha.0:
    -> 2.1.0:
    A bug that destryed the actual app state on changing from tv to app mode has been fixed.
    Websocket SSL states can now be sent / received again due to the websocket ssl changes.
    Plain websocket has been replaced by SSL Websocket.
    -> 2.0.0:
    Adapter has been moved to iobroker-community-adapters area
    POSSIBLE BREAKING: Adapter has been built from current github content. As latest npm packages have been created external, theres a chance that some changes got lost.
    Travis and AppVeyor have been replced by GitHub Actions, based on ioBroker/create-adapter
    Adpter requires NodeJS 16 minimum now
    Dependencies have been updated
    Configuration item healthIntervall has been rename/correct to healthInterval
    -> 2.0.0-alpha.0:
    Travis and AppVeyor have been replaced by GitHub Actions, based on ioBroker/create-adapter
    Adapter requires NodeJS 16 minimum now
    Would you like to upgrade lgtv from @1.1.12 to @2.1.1 now? [(y)es, (n)o]: y
    Update lgtv from @1.1.12 to @2.1.1
    NPM version: 8.19.4
    Installing iobroker.lgtv@2.1.1... (System call)
    upload [3] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index.html index.html text/html
    upload [2] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
    upload [1] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
    upload [0] lgtv.admin /opt/iobroker/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
    This upgrade of "info" will introduce the following changes:
    -> 2.0.0:
    Updated packages
    Breaking change: minimal supported node.js version is 16.x
    Would you like to upgrade info from @1.9.26 to @2.0.0 now? [(y)es, (n)o]: y
    Update info from @1.9.26 to @2.0.0
    NPM version: 8.19.4
    Installing iobroker.info@2.0.0... (System call)
    Adapter "system.adapter.vis.0" restarted.
    upload [91] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
    upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
    upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/memory.png lib/img/icons/memory.png image/png
    upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
    upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
    upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
    upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
    upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/chartist.min.js lib/js/chartist.min.js application/javascript
    upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/clock.js lib/js/clock.js application/javascript
    upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/commons.js lib/js/commons.js application/javascript
    upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/documentation.js lib/js/documentation.js application/javascript
    upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
    upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/format-google-calender.js lib/js/format-google-calender.js application/javascript
    upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
    upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
    upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
    upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
    upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
    upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
    upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
    upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
    upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
    upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
    upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
    upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
    upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
    pi@raspberrypi:~ $ iob stop
    ^[[A^[[Api@raspberrypi:~ $ iob upgrade self
    Update js-controller from @4.0.24 to @5.0.12
    Stopped Objects DB
    Stopped States DB
    NPM version: 8.19.4
    Installing iobroker.js-controller@5.0.12... (System call)
    pi@raspberrypi:~ $ iob start
    pi@raspberrypi:~ $ iobroker start admin
    The adapter "admin.0" was started.
    pi@raspberrypi:~ $
    • S spaddel
      Hallo Thomas,
      Hier der Log:
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      -> 1.15.19:
      Updated packages
      -> 1.15.18:
      -> 1.15.17:
      NPM version: 8.19.4
      -> 6.12.0:
      -> 6.11.0:
      -> 6.10.9:
      -> 6.10.8:
      -> 6.10.7:
      -> 6.10.6:
      -> 6.10.5:
      NPM version: 8.19.4
      -> 2.5.5:
      -> 2.5.4:
      -> 2.5.3:
      -> 2.4.0:
      -> 2.3.6:
      -> 2.3.5:
      -> 2.3.4:
      NPM version: 8.19.4
      -> 6.1.2:
      -> 6.1.1:
      -> 6.1.0:
      -> 6.0.3:
      Updated packages
      -> 6.0.1:
      -> 5.5.3:
      -> 5.5.2:
      NPM version: 8.19.4
      -> 3.0.0:
      NPM version: 8.19.4
      -> 2.1.1:
      -> 2.1.1-alpha.0:
      -> 2.1.0:
      -> 2.0.0:
      -> 2.0.0-alpha.0:
      NPM version: 8.19.4
      -> 2.0.0:
      Updated packages
      NPM version: 8.19.4
      Stopped Objects DB
      Stopped States DB
      NPM version: 8.19.4
      pi@raspberrypi:~ $
      @spaddel
      Gib mal die Ausgabe von
      iob diag
      Vorher mal
      iob nodejs-update 18
        @spaddel
        iob diag
        Vorher mal
        spaddel
        Hier der Log:
                                v.2023-10-10
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    8
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/node           v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                /usr/bin/corepack       0.19.0
        Recommended versions are nodejs 16.20.2 and npm 8.19.4
        MEMORY:
        Mem:           3.8G        995M        1.2G        8.0M        1.7G        2.7G
        Swap:           99M          0B         99M
        Total:         3.9G        995M        1.3G
        Active iob-Instances:   13
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                2753
        States:                 2429
        Size of iob-Database:
        15M     /opt/iobroker/iobroker-data/objects.jsonl
        4.0M    /opt/iobroker/iobroker-data/objects.json.migrated
        4.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        2.7M    /opt/iobroker/iobroker-data/states.jsonl
        320K    /opt/iobroker/iobroker-data/states.json.migrated
        320K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        • S spaddel
          Hier der Log:
                                  v.2023-10-10
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               armhf
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
          MEMORY:
          Swap:           99M          0B         99M
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                2753
          States:                 2429
          @spaddel
          Die Langfassung bitte.
            @spaddel
            spaddel
            Hi Thomas, leider bekomme ich eine Fehlermeldung (Payload), wenn ich den Log posten will.
            Ich versuche es aber später noch mal.
            • S spaddel
              Dann ist die Datei zu groß -> Zu viele Fehler.
              Lad eine txt-Datei mit dem Inhalt hoch.
                spaddel
                Mit Chrome bekomme ich ständig Fehlermeldung. Mit Edge funktioniert es aber. Hier der Log
                Log.txt
                Christian
                • S spaddel
                  Log.txt
                  Christian
                  @spaddel
                  Das ist nicht vollständig.
                  • S spaddel
                    Log.txt
                    Christian
                    @spaddel
                    Die beiden sind aber schon mal krumm:
                    npm ERR! invalid: iobroker.samsung_tizen@0.0.12 /opt/iobroker/node_modules/iobroker.samsung_tizen
                    npm ERR! invalid: iobroker.samsung2016@0.0.2 /opt/iobroker/node_modules/iobroker.samsung2016
                    Schmeiß die raus:
                    iob del samsung_tizen
                    iob del samsung2016
                    iob update
                    iob upgrade
                      @spaddel
                      spaddel
                      Ich habe den kompletten Inhalt aus Putty kopiert. Mehr war da nicht. Ich starte es noch mal und poste es.
                      • S spaddel
                        @spaddel
                        Das log liegt auch in /home/iobroker/iob_diag.log herum.
                          @spaddel
                          Schmeiß die raus:
                          iob del samsung2016
                          iob update
                          iob upgrade
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          samsung_tizen ist als 1.0.0 im repo verfügbar. Diese Release ist für js-controlelr 5 auch erforderlich.
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          • mcm1957M mcm1957
                            @mcm57 sagte in js controller update nicht möglich:
                            Ja, das ist aber bei weitem nicht der einzige Fehler im Tree.
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Nö - wollt nur die Info gleich mal deponieren.
                              Was da alles im npm tree nicht passt - keine Ahnung. Da kannst du sicher besser helfen.
                              • mcm1957M mcm1957
                                Da ist so viel... Muss mal schauen was da noch geht.
                                  @spaddel
                                  spaddel
                                  Zweiter Versuch
                                  iob_diag.log
                                  • S spaddel
                                    Zweiter Versuch
                                    iob_diag.log
                                    @spaddel
                                    Höchste Zeit das Ding komplett neuauzusetzen.
                                    Als Bookworm-64Bit-Version 'Lite'.
                                    Versuch
                                    find "/opt/iobroker/" -iname "*package-lock*" -exec rm -rf "{}" \;
                                    dann
                                    iob update
                                    iob upgrade
                                      @spaddel
                                      Versuch
                                      dann
                                      iob update
                                      iob upgrade
                                      spaddel
                                      Wenn ich die Kommentare lese scheint einiges im Argen zu sein. Wie kann ich das System sauber neu aufsetzen. Wenn ich mich richtig erinnere, habe ich damals eine Anleitung von verdrahtet.info auf youtube verwendet.
                                      CHristian
                                      • S spaddel
                                        CHristian
                                        @spaddel
                                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                        Zu allem was da sonst noch läuft musst du dir aber selber Gedanken machen.
                                          @spaddel
                                          spaddel
                                          Danke für den Link.
                                          Nach dem o.g. Befehlen sind die Adapter wieder auf Stand aber der js-controller steht noch auf 4.0.24. Kann ich jetzt den vorgeschlagenen Weg gehen?
                                          cd /opt/iobroker/
                                          sudo iobroker stop
                                          sudo iobroker update
                                          sudo iobroker upgrade self
                                          sudo iobroker start
                                          Christian
