  3. Einsteigerfragen
  4. Installation
  5. ZimaBoard 832 # Debian12 (i386) # js-controler startet nicht
installatonzimaboard
25 Beiträge 2 Kommentatoren 3.1k Aufrufe 2 Beobachtet
    @derauge sagte in ZimaBoard 832 mit Debian12 # js-controler startet nicht:
    node -v v18.13.0
    Ist falsch. Da muss eine 18.18.2 aus dem nodesource-Repo angelegt werden. Macht eigentlich der Installer.
    iob nodejs-update
    sagt?
    derAugeD Offline
    derAugeD Offline
    derAuge
    @thomas-braun sagte in ZimaBoard 832 mit Debian12 # js-controler startet nicht:
    node -v v18.13.0
    iob nodejs-update
    sagt?
    ioBroker nodejs fixer 2023-10-13
    No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v18.13.0
    /usr/bin/node           v18.13.0
    /usr/bin/npm            9.2.0
    /usr/bin/npx            9.2.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.13.0+dfsg1-1
      Candidate: 18.13.0+dfsg1-1
      Version table:
     *** 18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main i386 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.13.0. Do you want to install latest version from nodejs v.18 tree?
    Press <y> to continue or any other key to quit
    Trying to update your installation now. Please be patient.
    rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Fetched 12.1 kB in 2s (5235 B/s)
    N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' doesn't support architecture 'i386'
    Installing the recommended nodejs version now!
    Exact recommended version unknown, installing a fallback!
    E: Version '18.0.0-1nodesource1' for 'nodejs' was not found
    Updating fallback to latest nodejs v18 release
    v18.13.0 has been installed! You are using the latest version now!
    Installing the recommended nodejs version!
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    auge@CasaOS-1:~$
    auge@CasaOS-1:~$ node -v
    v18.13.0
    auge@CasaOS-1:~$ npm -v
    9.2.0
    auge@CasaOS-1:~$ iobroker -v
    5.0.12
    auge@CasaOS-1:~$
    Das ist ja spannend. Durch den Script wird es nicht neu installiert
    • derAugeD derAuge
      node -v v18.13.0
      iob nodejs-update
      sagt?
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      nodejs:
        Version table:
      Package: nodejs
      Pin-Priority: 1001
      auge@CasaOS-1:~$
      v18.13.0
      9.2.0
      5.0.12
      auge@CasaOS-1:~$
      @derauge
      Dann leg es zu Fuß an.
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      • derAugeD derAuge
        node -v v18.13.0
        iob nodejs-update
        sagt?
        /usr/bin/npm            9.2.0
        /usr/bin/npx            9.2.0
        nodejs:
          Version table:
        Package: nodejs
        Pin-Priority: 1001
        auge@CasaOS-1:~$
        v18.13.0
        9.2.0
        5.0.12
        auge@CasaOS-1:~$
        @derauge
        sudo apt update
        apt policy nodejs
        sagt?
        derAugeD 1 Antwort Letzte Antwort
          @derauge
          sudo apt update
          apt policy nodejs
          sagt?
          derAugeD Offline
          derAugeD Offline
          derAuge
          @derauge
          sudo apt update
          apt policy nodejs
          sagt?
          auge@CasaOS-1:~$ iob stop
          auge@CasaOS-1:~$ sudo nano /etc/apt/sources.list.d/nodesource.list
          auge@CasaOS-1:~$ sudo apt update
          OK:1 http://deb.debian.org/debian bookworm InRelease
          OK:2 http://security.debian.org/debian-security bookworm-security InRelease
          OK:3 http://deb.debian.org/debian bookworm-updates InRelease
          Ign:4 https://deb.nodesource.com/node_18.18.2 nodistro InRelease
          Fehl:5 https://deb.nodesource.com/node_18.18.2 nodistro Release
            404  Not Found [IP: 172.67.10.205 443]
          E: Das Depot »https://deb.nodesource.com/node_18.18.2 nodistro Release« enthält keine Release-Datei.
          N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
          N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
          auge@CasaOS-1:~$
          auge@CasaOS-1:~$ apt policy nodejs
          nodejs:
            Installiert:           18.13.0+dfsg1-1
            Installationskandidat: 18.13.0+dfsg1-1
            Versionstabelle:
          auge@CasaOS-1:~$
          • derAugeD derAuge
            @derauge
            sudo apt update
            apt policy nodejs
            sagt?
            auge@CasaOS-1:~$
            nodejs:
              Versionstabelle:
            auge@CasaOS-1:~$
            @derauge
            Ist ja auch falsch. Hast du da was geändert oder kommt das so aus dem Installer?
              @derauge
              derAugeD Offline
              derAugeD Offline
              derAuge
              @derauge
              habe die Datei angepasst
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.18.2 nodistro main
              für die "manuelle" Installation
              • derAugeD derAuge
                @derauge
                @derauge
                Dann ist es falsch angepasst. Im HowTo steht es richtig drin.
                  @derauge
                  derAugeD Offline
                  derAugeD Offline
                  derAuge
                  OK
                  OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                  OK:2 http://deb.debian.org/debian bookworm InRelease
                  OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Alle Pakete sind aktuell.
                  N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
                  auge@CasaOS-1:~$ sudo apt full-upgrade
                  Paketaktualisierung (Upgrade) wird berechnet… Fertig
                  0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  auge@CasaOS-1:~$
                  Da kommen wir der Sache schon etws näher:
                  • derAugeD derAuge
                    OK
                    auge@CasaOS-1:~$
                    @derauge
                    apt policy nodejs
                    liefert?
                      @derauge
                      apt policy nodejs
                      liefert?
                      derAugeD Offline
                      derAugeD Offline
                      derAuge
                      @derauge
                      apt policy nodejs
                      liefert?
                      Auszug aus "iob diag"
                      *** NodeJS-Installation ***
                      /usr/bin/npm            9.2.0
                      /usr/bin/npx            9.2.0
                      /home/iobroker/.diag.sh: line 281: corepack: command not found
                      *** nodejs is NOT correctly installed ***
                      nodejs:
                        Version table:
                                              v.2023-10-10
                       Static hostname: CasaOS-1
                             Icon name: computer-desktop
                               Chassis: desktop 🖥️
                                Kernel: Linux 6.1.0-13-686-pae
                          Architecture: x86
                       Hardware Vendor: IceWhale Technology Co.,Ltd.
                        Hardware Model: ZimaBoard 832
                      Firmware Version: 5.12
                      Kernel:                 i686
                      Userland:               i386
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     0
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v18.13.0
                                              /usr/bin/npm            9.2.0
                                              /usr/bin/npx            9.2.0
                      /home/iobroker/.diag.sh: line 490: corepack: command not found
                      Recommended versions are nodejs  and npm
                      Wrong installation path detected. This needs to be fixed
                      Please check
                      for more information on how to fix these errors.
                      MEMORY:
                      Mem:            8.2G        783M        7.7G        962K        435M        7.5G
                      Swap:           1.0G          0B        1.0G
                      Total:          9.3G        783M        8.7G
                      Active iob-Instances:   1
                      Active repo(s): stable
                      ioBroker Core:          js-controller           5.0.12
                                              admin                   6.10.1
                      ioBroker Status:        iobroker is not running on this host.
                      Objects type: jsonl
                      States  type: jsonl
                        system.adapter.admin.0                  : admin                 : CasaOS-1                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      Objects:                96
                      States:                 21
                      Size of iob-Database:
                      3.8M    /opt/iobroker/iobroker-data/objects.jsonl
                      8.0K    /opt/iobroker/iobroker-data/states.jsonl
                      • derAugeD derAuge
                        @derauge
                        apt policy nodejs
                        liefert?
                        /usr/bin/npm            9.2.0
                        /usr/bin/npx            9.2.0
                        nodejs:
                          Version table:
                                                v.2023-10-10
                                 Chassis: desktop 🖥️
                            Architecture: x86
                        Kernel:                 i686
                        Userland:               i386
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.2.0
                                                /usr/bin/npx            9.2.0
                        Please check
                        MEMORY:
                        Swap:           1.0G          0B        1.0G
                                                admin                   6.10.1
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                96
                        States:                 21
                        @derauge
                        apt policy nodejs
                        liefert?
                          @derauge
                          apt policy nodejs
                          liefert?
                          derAugeD Offline
                          derAugeD Offline
                          derAuge
                          nodejs:
                            Versionstabelle:
                          auge@CasaOS-1:~$
                          • derAugeD derAuge
                            nodejs:
                              Versionstabelle:
                            auge@CasaOS-1:~$
                            @derauge
                            Ich sehe schon...
                            nodesource baut nicht für 32bit-Systeme. Das läuft also auf deiner i386-Architektur nicht.
                              @derauge
                              Ich sehe schon...
                              derAugeD Offline
                              derAugeD Offline
                              derAuge
                              schrieb am zuletzt editiert von derAuge
                              @derauge
                              Ich sehe schon...
                              Das habe ich fast befürchtet
                              Dann muss ich mal schauen, dass ich dort ein amd64 Image drauf bekomme
                              Beim OrginalOS ist es:
                              Linux CasaOS 5.10.0-10-amd64 #1 SMP Debian 5.10.84-1 (2021-12-08) x86_64 GNU/Linux
                              Auf meinem "neuen" Host ist:
                              Linux CasaOS-1 6.1.0-13-686-pae #1 SMP PREEMPT_DYNAMIC Debian 6.1.55-1 (2023-09-29) i686 GNU/Linux
                              Es bleibt spannend :-)
                              Danke für deine Unterstützung !!
                              Jürgen
                              ;-) Nur noch mal ein Test mit "Install Node.js 20.x Current": :-( :-( :-(
                              N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_20.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
                              • derAugeD derAuge
                                @derauge
                                Ich sehe schon...
                                Jürgen
                                @derauge
                                Auch das läuft natürlich nicht auf 32bit.
                                Aber offenbar kann man da ja frei 'irgendwas' installieren. Nimm halt das richtige Installations-Medium für Debian.
                                  @derauge
                                  derAugeD Offline
                                  derAugeD Offline
                                  derAuge
                                  @thomas-braun sagte in ZimaBoard 832 # Debian12 (i386) # js-controler startet nicht:
                                  @derauge
                                  Hier ist die Lösung das Problems :-)
