  4. iobroker läuft wieder nicht...
42 Beiträge 6 Kommentatoren 5.7k Aufrufe 5 Beobachtet
  • P Pahan
    iob nodejs-update
    liefert wohl einige Fehlermeldungen, aber die Version scheint am Ende doch installiert worden zu sein
    ioBroker nodejs fixer 2023-10-13
    No recommendation for a nodejs version found on your system. We recommend to ins                                                            tall latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v16.20.2
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package                                                            s
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v16.20.2. Do you want to install latest version from node                                                            js v.18 tree?
    Press <y> to continue or any other key to quit
    Trying to update your installation now. Please be patient.
    rm: cannot remove '/etc/apt/sources.list.d/nodesource.list': No such file or dir                                                            ectory
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:3 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
    Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Err:3 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:4 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Fetched 22.0 kB in 1s (20.6 kB/s)
    Reading package lists... Done
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will                      be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verif                     ied because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will                      be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verifi                     ed because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be ve                     rified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be v                     erified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 12354 (apt-get)
    E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:6 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5700 B]
    Fetched 24.9 kB in 1s (17.9 kB/s)
    Installing the recommended nodejs version now!
    Exact recommended version unknown, installing a fallback!
    Updating fallback to latest nodejs v18 release
    v16.20.2 has been installed! You are using the latest version now!
    Installing the recommended nodejs version!
    Preconfiguring packages ...
    (Reading database ... 118426 files and directories currently installed.)
    Preparing to unpack .../base-files_11.1+rpi1+deb11u8_armhf.deb ...
    Unpacking base-files (11.1+rpi1+deb11u8) over (11.1+rpi1+deb11u7) ...
    Setting up base-files (11.1+rpi1+deb11u8) ...
    Installing new version of config file /etc/debian_version ...
    Preparing to unpack .../libssl1.1_1.1.1w-0+deb11u1+rpt1_armhf.deb ...
    Unpacking libssl1.1:armhf (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
    Setting up libssl1.1:armhf (1.1.1w-0+deb11u1+rpt1) ...
    Preparing to unpack .../libcurl3-gnutls_7.74.0-1.3+deb11u10_armhf.deb ...
    Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u10) over (7.74.0-1.3+deb11u9) ...
    Preparing to unpack .../nodejs_18.18.2-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.18.2-1nodesource1) over (16.20.2-deb-1nodesource1) ...
    Preparing to unpack .../openssl_1.1.1w-0+deb11u1+rpt1_armhf.deb ...
    Unpacking openssl (1.1.1w-0+deb11u1+rpt1) over (1.1.1w-0+deb11u1) ...
    Preparing to unpack .../python3-sense-hat_2.6.0-1_all.deb ...
    Unpacking python3-sense-hat (2.6.0-1) over (2.4.0-1) ...
    Preparing to unpack .../raspi-config_20231012~bullseye_all.deb ...
    Unpacking raspi-config (20231012~bullseye) over (20230214) ...
    Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u10) ...
    Setting up nodejs (18.18.2-1nodesource1) ...
    Setting up python3-sense-hat (2.6.0-1) ...
    Setting up openssl (1.1.1w-0+deb11u1+rpt1) ...
    Setting up raspi-config (20231012~bullseye) ...
    Processing triggers for man-db (2.9.4-2) ...
    Processing triggers for install-info (6.7.0.dfsg.2-6) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    pi@raspberrypi:~ $ nodejs -v
    v18.18.2
    pi@raspberrypi:~ $ npm -v
    9.8.1
    iob diag
    liefert nach etwa 10 Minuten:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     20:01:23 up  6:07,  2 users,  load average: 10.10, 12.52, 12.35
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-10-17 20:01:24 CEST
               Universal time: Tue 2023-10-17 18:01:24 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.4G        1.1G        0.0K        1.3G        2.3G
    Swap:            99M          0B         99M
    Total:          3.9G        1.4G        1.2G
             3794 M total memory
             1441 M used memory
             1535 M active memory
              903 M inactive memory
             1101 M free memory
              222 M buffer memory
             1028 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   11G   18G  38% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  872K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.1G    /var/
    3.4G    /var/log
    3.0G    /var/log/journal/9177676efac74b1994c74dac83b5d5f4
    378M    /var/cache
    Archived and active journals take up 2.9G in the file system.
    /opt/iobroker/backups:
    81M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    523M    /opt/iobroker/iobroker-data/
    263M    /opt/iobroker/iobroker-data/files
    129M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    49M     /opt/iobroker/iobroker-data/files/vis.0
    37M     /opt/iobroker/iobroker-data/states.jsonl
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    17M     /opt/iobroker/iobroker-data/objects.json.migrated
    17M     /opt/iobroker/iobroker-data/objects.json.broken
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   2
    Adapter State
     redis get system.host.raspberrypi.alive, error - Connection is closed.
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.binance.0                : binance               : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.eusec.0                  : eusec                 : raspberrypi                              - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
      system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
      system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
      system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              - disabled, port: 54321
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              -  enabled
      system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5001
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
    + instance is alive
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5001
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.25.2   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "eusec"        : 1.1.2    , installed 1.0.0  [Updatable]
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.1.26 [Updatable]
    Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
    Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.18 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.0.3  [Updatable]
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
    Adapter    "mihome-lamp"  : 1.1.0    , installed 1.1.0
    Adapter    "mihome-vacuum": 4.0.0    , installed 3.11.0 [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "snmp"         : 2.4.11   , installed 2.4.7  [Updatable]
    Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "synology"     : 3.0.0    , installed 2.1.13 [Updatable]
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.1.0  [Updatable]
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "weatherunderground": 3.6.0, installed 3.4.2 [Updatable]
    Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Objects and States
    Objects:        30040
    States:         20964
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Get:3 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Get:4 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Err:3 https://packages.grafana.com/oss/deb stable InRelease
    Err:4 https://repos.influxdata.com/debian bullseye InRelease
    Fetched 7040 B in 1s (5065 B/s)
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       427525     15678/io.hm-rpc.1
    tcp        0      0 0.0.0.0:12010           0.0.0.0:*               LISTEN      1001       427520     15692/io.hm-rpc.2
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12741      518/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       424859     15585/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       426167     15585/iobroker.js-c
    tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       429257     15673/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12176      563/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12744      536/influxd
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15881      536/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      115        12823      526/grafana-server
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12740      518/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12178      563/sshd: /usr/sbin
    udp        0      0 192.168.178.36:5353     0.0.0.0:*                           1001       429399     15758/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12096      396/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       428487     15694/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12771      469/dhcpcd
    udp        0      0 0.0.0.0:49317           0.0.0.0:*                           108        12098      396/avahi-daemon: r
    udp        0      0 0.0.0.0:33243           0.0.0.0:*                           1001       430179     15895/io.snmp.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15834      602/cups-browsed
    udp6       0      0 :::5353                 :::*                                108        12097      396/avahi-daemon: r
    udp6       0      0 :::35623                :::*                                108        12099      396/avahi-daemon: r
    2023-10-17 20:05:26.961  - warn: shelly.0 (15694) [authEnabled] 192.168.178.55 (shelly1 / shelly1-40F52000F535 / SHSW-1#40F52000F535#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:26.964  - warn: shelly.0 (15694) [authEnabled] 192.168.178.49 (shelly1 / shelly1-E098069629A1 / SHSW-1#E098069629A1#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:26.967  - warn: shelly.0 (15694) [authEnabled] 192.168.178.52 (shelly1 / shelly1-E09806963B80 / SHSW-1#E09806963B80#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:27.874  - warn: shelly.0 (15694) [authEnabled] 192.168.178.54 (shellyswitch25 / shellyswitch25-BCDDC277A135 / SHSW-25#BCDDC277A135#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:29.230  - info: upnp.0 (18760) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v18.18.2, js-controller: 4.0.24
    2023-10-17 20:05:29.366  - info: upnp.0 (18760) Auto discover: false
    2023-10-17 20:05:30.716  - warn: influxdb.0 (15649) Error on writePoint("{"value":28416.64,"time":"2023-10-17T18:04:30.649Z","from":"system.adapter.binance.0","q":0,"ack":false}): Error: {"error":"timeout"}
     / "{\"error\":\"timeout\"}\n""
    2023-10-17 20:05:30.716  - info: influxdb.0 (15649) Add point that had error for crypto.btc.usdt to buffer again, error-count=6
    2023-10-17 20:05:30.817  - warn: influxdb.0 (15649) Error on writePoint("{"value":0.00005609,"time":"2023-10-17T18:03:30.804Z","from":"system.adapter.binance.0","q":0,"ack":false}): Error: {"error":"timeout"}
    2023-10-17 20:05:30.817  - info: influxdb.0 (15649) Add point that had error for crypto.trx.eth to buffer again, error-count=5
    2023-10-17 20:05:30.966  - warn: influxdb.0 (15649) Error on writePoint("{"value":1567.09,"time":"2023-10-17T18:04:30.902Z","from":"system.adapter.binance.0","q":0,"ack":false}): Error: {"error":"timeout"}
    2023-10-17 20:05:30.967  - info: influxdb.0 (15649) Add point that had error for crypto.eth.usdt to buffer again, error-count=5
    2023-10-17 20:05:33.026  - warn: shelly.0 (15694) [authEnabled] 192.168.178.55 (shelly1 / shelly1-40F52000F535 / SHSW-1#40F52000F535#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:33.131  - warn: shelly.0 (15694) [authEnabled] 192.168.178.52 (shelly1 / shelly1-E09806963B80 / SHSW-1#E09806963B80#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:33.432  - warn: shelly.0 (15694) [authEnabled] 192.168.178.54 (shellyswitch25 / shellyswitch25-BCDDC277A135 / SHSW-25#BCDDC277A135#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:33.666  - warn: shelly.0 (15694) [authEnabled] 192.168.178.49 (shelly1 / shelly1-E098069629A1 / SHSW-1#E098069629A1#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-10-17 20:05:35.455  - warn: influxdb.0 (15649) Error on writePoint("{"value":21.7,"time":"2023-10-17T18:01:51.323Z","from":"system.adapter.hm-rpc.1","q":0,"ack":true}): Error: {"error":"timeout"}
    2023-10-17 20:05:35.456  - info: influxdb.0 (15649) Add point that had error for temp.ist.gaeste.wc to buffer again, error-count=9
    2023-10-17 20:05:35.469  - warn: influxdb.0 (15649) Error on writePoint("{"value":21.8,"time":"2023-10-17T18:04:45.240Z","from":"system.adapter.hm-rpc.1","q":0,"ack":true}): Error: {"error":"timeout"}
    2023-10-17 20:05:35.469  - info: influxdb.0 (15649) Discard point that had error for temp.ist.gaeste.wc, error-count=10
    iob diag has finished.
    @pahan sagte in iobroker läuft wieder nicht...:
    Die resultieren allerdings aus der schiefen Installation der weiteren Paketquellen (grafana, influx). Die musst du auch anpacken.
    Desweiteren ist da mal ein Update unterbrochen worden. Auch das führt natürlich zu entsprechenden Meldungen.
    • P Pahan
      iob nodejs-update
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      Package: nodejs
      Pin-Priority: 1001
      v18.18.2
      9.8.1
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
               1441 M used memory
               1101 M free memory
                222 M buffer memory
               1028 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.1G    /var/
      3.4G    /var/log
      378M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        30040
      States:         20964
      Pending Updates: 0
      @pahan
      Dann die Antiquitäten-Sammlung auf Stand bringen:
      iob update
      iob upgrade all -y
      iob stop
      iob fix
      iob upgrade self
      iob start
      P 2 Antworten Letzte Antwort
        @pahan
        iob update
        iob upgrade all -y
        iob stop
        iob fix
        iob upgrade self
        iob start
        Pahan
        @thomas-braun sagte in iobroker läuft wieder nicht...:
        @pahan
        "Antiquitäten" :))
        Es lief eben alles zu meiner Zufriedenheit, daher habe ich auch keine Updates gefahren...
        Also, die Updates erst nachdem grafana und influx gefixt sind oder ist das unabhängig voneinander?
        Thomas BraunT ? J 3 Antworten Letzte Antwort
        • P Pahan
          iob nodejs-update
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          nodejs:
            Version table:
          Package: nodejs
          Pin-Priority: 1001
          v18.18.2
          9.8.1
          iob diag
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3794 M total memory
                   1441 M used memory
                   1101 M free memory
                    222 M buffer memory
                   1028 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          4.1G    /var/
          3.4G    /var/log
          378M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        30040
          States:         20964
          Pending Updates: 0
          Moin,
          wenn da bei RasPI kein Multiplikator in top ist, dann werkelt da etwas ganz schön auf der Kiste, ein load von 10 ist schon heftig.
          Bernd
          P 1 Antwort Letzte Antwort
          • P Pahan
            @pahan
            "Antiquitäten" :))
            Das ist dieser 'Newah tschaindsch a running süstähm'-Bullshit, oder?
              Pahan
              schrieb am zuletzt editiert von Pahan
              janz jenau !
              • P Pahan
                janz jenau !
                @pahan
                Dann wirst du den Bullshit jetzt aufräumen.
                  Moin,
                  Bernd
                  Pahan
                  @dp20eic sagte in iobroker läuft wieder nicht...:
                  Moin,
                  Bernd
                  jaaa, also gefühlt ist das Ding dauerhaft überlastet, aber ich weiß nicht mit was und wie ich es fixen soll
                  Thomas BraunT ? 2 Antworten Letzte Antwort
                  • P Pahan
                    @pahan
                    "Antiquitäten" :))
                    Moin,
                    weil man nichts macht, kommen dann auch all die schönen kleinen Fehler mit der Zeit ;)
                    Du musst erst die Repositorys korrigieren, denn bei jedem apt update / upgrade läuft apt auf einen Fehler und bricht ab, somit kannst Du nichts aktuell halten.
                    Bernd
                    • P Pahan
                      Moin,
                      Bernd
                      Ich vermute, da läuft dir ein Skript aus dem Ruder.
                      Schalt den ioBroker aus, wenn du da die Kernsanierung vornimmst.
                      • P Pahan
                        @pahan
                        "Antiquitäten" :))
                        Jan1
                        und warum hast dann nun ein Problem, wenn das so toll war?
                        Genau wegen dieser doofen Einstellung der Systempflege gegenüber ;)
                        • P Pahan
                          Moin,
                          Bernd
                          Moin,
                          dann musst Du mal in die Logs schauen, denn dazu sind die da :)
                          aus Deinem iob diag ganz am Ende
                          In /var/log/ gibt es noch mehr Log Files, da steht sicherlich auch einiges drin.
                          Dann kannst Du mal, das 'ne Zeitlang laufen lassen und schauen, wer da so unter den Top 10 ist
                          # top
                          Bernd
                          P.S.: Sauberes Backup machen und gleich richtig neu aufsetzen, ist glaube ich der schmerzfreie Weg, ohne genau zu wissen, was da alles auf der Kiste werkelt.
                            @pahan
                            iob update
                            iob upgrade all -y
                            iob stop
                            iob fix
                            iob upgrade self
                            iob start
                            Pahan
                            @pahan
                            iob update
                            iob upgrade all -y
                            iob stop
                            iob fix
                            iob upgrade self
                            iob start
                            Habe nun grafana und influxdb aktualisiert und die von dir genannten Schritte durchgeführt. Hat sehr sehr lange gedauert und
                            iob diag
                            liefert nun folgendes:
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                             23:20:02 up  9:25,  1 user,  load average: 8.90, 7.26, 8.08
                            CPU threads: 4
                            Current issues:
                                           Local time: Tue 2023-10-17 23:20:03 CEST
                                       Universal time: Tue 2023-10-17 21:20:03 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        1.6G        534M        0.0K        1.6G        2.2G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.6G        634M
                                     3794 M total memory
                                     1646 M used memory
                                     1687 M active memory
                                     1214 M inactive memory
                                      533 M free memory
                                      240 M buffer memory
                                     1373 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G   11G   18G  39% /
                            tmpfs          tmpfs     759M  864K  759M   1% /run
                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,short        name=mixed,flush,errors=remount-ro
                            /var:
                            4.1G    /var/
                            3.4G    /var/log
                            378M    /var/cache
                            502M    /opt/iobroker/iobroker-data/
                            286M    /opt/iobroker/iobroker-data/files
                            21M     /opt/iobroker/iobroker-data/objects.jsonl
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                            USB-Devices by-id:
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            js-controller:  5.0.12
                            admin:          6.10.1
                            javascript:     7.1.4
                            Adapter State
                            + system.adapter.binance.0                : binance               : raspberrypi                              -  enabled
                            + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                            + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                            + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
                            + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                            + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                            + system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              -  enabled
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                            + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                            + instance is alive
                            Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                            Adapter    "admin"        : 6.10.1   , installed 6.10.1
                            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                            Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                            Adapter    "history"      : 2.2.6    , installed 2.2.6
                            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                            Adapter    "info"         : 2.0.0    , installed 2.0.0
                            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                            Controller "js-controller": 5.0.12   , installed 5.0.12
                            Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                            Adapter    "snmp"         : 2.4.11   , installed 2.4.11
                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                            Adapter    "synology"     : 3.0.0    , installed 3.0.0
                            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                            Adapter    "web"          : 6.1.2    , installed 6.1.2
                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                            Objects and States
                            Objects:        30179
                            States:         21095
                            E: The repository 'https://repos.influxdata.com/raspbian bullseye Release' does not have a Release file.
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       663955     30230/io.hm-rpc.1
                            tcp        0      0 0.0.0.0:12010           0.0.0.0:*               LISTEN      1001       663390     30271/io.hm-rpc.2
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       660964     30114/iobroker.js-c
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       660971     30114/iobroker.js-c
                            tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       663966     30221/io.hm-rpc.0
                            udp        0      0 192.168.178.36:5353     0.0.0.0:*                           1001       664016     30286/io.tr-064.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       664772     30278/io.shelly.0
                            udp        0      0 0.0.0.0:47183           0.0.0.0:*                           1001       665324     30464/io.snmp.0
                            2023-10-17 23:24:51.363  - warn: shelly.0 (30278) [authEnabled] 192.168.178.49 (shelly1 / shelly1-E098069629A1 / SHSW-1#E098069629A1#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:51.415  - warn: shelly.0 (30278) [authEnabled] 192.168.178.52 (shelly1 / shelly1-E09806963B80 / SHSW-1#E09806963B80#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:51.428  - warn: shelly.0 (30278) [authEnabled] 192.168.178.55 (shelly1 / shelly1-40F52000F535 / SHSW-1#40F52000F535#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:53.724  - warn: shelly.0 (30278) [authEnabled] 192.168.178.54 (shellyswitch25 / shellyswitch25-BCDDC277A135 / SHSW-25#BCDDC277A135#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:56.746  - warn: shelly.0 (30278) [authEnabled] 192.168.178.52 (shelly1 / shelly1-E09806963B80 / SHSW-1#E09806963B80#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:56.748  - warn: shelly.0 (30278) [authEnabled] 192.168.178.49 (shelly1 / shelly1-E098069629A1 / SHSW-1#E098069629A1#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:56.805  - warn: shelly.0 (30278) [authEnabled] 192.168.178.55 (shelly1 / shelly1-40F52000F535 / SHSW-1#40F52000F535#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:24:58.970  - warn: shelly.0 (30278) [authEnabled] 192.168.178.54 (shellyswitch25 / shellyswitch25-BCDDC277A135 / SHSW-25#BCDDC277A135#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:00.025  - info: upnp.0 (31633) Scheduled restart.
                            2023-10-17 23:25:00.040  - info: upnp.0 (31633) terminating
                            2023-10-17 23:25:00.042  - info: upnp.0 (31633) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            2023-10-17 23:25:00.542  - info: upnp.0 (31633) terminating
                            2023-10-17 23:25:00.555  - warn: upnp.0 (31633) get state error: Connection is closed.
                            2023-10-17 23:25:00.805  - info: host.raspberrypi instance system.adapter.upnp.0 scheduled normal terminated and will be restarted on schedule.
                            2023-10-17 23:25:00.805  - info: host.raspberrypi Restart adapter system.adapter.upnp.0 because enabled
                            2023-10-17 23:25:02.063  - info: host.raspberrypi instance system.adapter.upnp.0 started with pid 31847
                            2023-10-17 23:25:02.074  - warn: shelly.0 (30278) [authEnabled] 192.168.178.49 (shelly1 / shelly1-E098069629A1 / SHSW-1#E098069629A1#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:02.123  - warn: shelly.0 (30278) [authEnabled] 192.168.178.52 (shelly1 / shelly1-E09806963B80 / SHSW-1#E09806963B80#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:02.172  - warn: shelly.0 (30278) [authEnabled] 192.168.178.55 (shelly1 / shelly1-40F52000F535 / SHSW-1#40F52000F535#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:14.260  - warn: upnp.0 (31847) slow connection to objects DB. Still waiting ...
                            2023-10-17 23:25:25.838  - warn: shelly.0 (30278) [authEnabled] 192.168.178.52 (shelly1 / shelly1-E09806963B80 / SHSW-1#E09806963B80#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:25.845  - warn: shelly.0 (30278) [authEnabled] 192.168.178.55 (shelly1 / shelly1-40F52000F535 / SHSW-1#40F52000F535#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:26.294  - warn: shelly.0 (30278) [authEnabled] 192.168.178.49 (shelly1 / shelly1-E098069629A1 / SHSW-1#E098069629A1#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:27.093  - warn: shelly.0 (30278) [authEnabled] 192.168.178.54 (shellyswitch25 / shellyswitch25-BCDDC277A135 / SHSW-25#BCDDC277A135#1): This device is not protected via restricted login (see adapter documentation for details)
                            2023-10-17 23:25:27.436  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 31897
                            iobroker ist übers Webinterface nach wie vor nicht erreichbar. Sind aus der Diagnose evtl. weitere Fehler ableitbar ?
                            • P Pahan
                              @pahan
                              iob update
                              iob upgrade all -y
                              iob stop
                              iob fix
                              iob upgrade self
                              iob start
                              iob diag
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                       1646 M used memory
                                        533 M free memory
                                        240 M buffer memory
                                       1373 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              4.1G    /var/
                              3.4G    /var/log
                              378M    /var/cache
                              USB-Devices by-id:
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        30179
                              States:         21095
                              Pending Updates: 0
                              Immer noch abnorm viel.
                              iob stop javascript
                              iob start admin
                              Influx ist aber noch falsch:
                                iob stop javascript
                                iob start admin
                                Pahan
                                iob stop javascript
                                iob start admin
                                liefert:
                                pi@raspberrypi:~ $ iob stop javascript
                                Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                pi@raspberrypi:~ $ iob start admin
                                No connection to databases possible ...
                                • P Pahan
                                  iob stop javascript
                                  iob start admin
                                  liefert:
                                  @pahan
                                  Dann schau mit
                                  htop
                                  nach, welcher Prozess da so auf das System einprügelt.
                                    @pahan
                                    Dann schau mit
                                    htop
                                    Pahan
                                    @pahan
                                    Dann schau mit
                                    htop
                                    ist natürlich stark schwankend, aber meistens schimmert der js.controller durch
                                    • P Pahan
                                      @pahan
                                      Dann schau mit
                                      htop
                                      @pahan
                                      Da muss aber ein Prozess deutlich durchdrehen.
                                      • P Pahan
                                        @pahan
                                        Dann schau mit
                                        htop
                                        @pahan
                                        So schaut ein stabiles System aus:
                                        Sortier dir das nach CPU-Auslastung. Geht mit F6.
                                          @pahan
                                          Pahan
                                          sieht bei mir so aus, wobei der js.controller und influxdb sich jede Sekunde abwechseln
