  4. ioBroker extrem langsam
iobrokerlangsamkeine aktualisierung möglich
95 Beiträge 8 Kommentatoren 19.0k Aufrufe 6 Beobachtet
  • S Spidermike
    @homoran sagte in ioBroker extrem langsam:
    @spidermike sagte in ioBroker extrem langsam:
    dann
    iob stop
    iob fix
    iob start
    w a r t e n
    iob node-update
    erledigt bekomme aber das gleiche wie ich schon gepostet hab
    pi@raspberrypi4-iobroker:~ $ iob node-update
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    @spidermike
    iob nodejs-update
    S 2 Antworten Letzte Antwort
      @spidermike
      iob nodejs-update
      Spidermike
      @thomas-braun sagte in ioBroker extrem langsam:
      iob nodejs-update
      es tut sich jetzt etwas 👍
      wie kann ich dann influxdb-Repository aktualisieren?
        @spidermike
        iob nodejs-update
        Spidermike
        @spidermike
        iob nodejs-update
        danke Dir bzw. ihr seid der Wahnsinn, es hat funktioniert.
        Der 1. Eindruck beim starten. "jetzt hab ich ein Ferrari"
        was muss ich jetzt machen das es auch so bleibt?
        • S Spidermike
          iob nodejs-update
          https://forum.iobroker.net/topic/67822/grafana-repo-braucht-neuen-schlüssel
          • S Spidermike
            @spidermike
            iob nodejs-update
            haselchenH Offline
            haselchenH Offline
            haselchen
            @spidermike
            Damit er noch schneller wird , solltest Du die 150 Updates noch machen
            • haselchenH haselchen
              @spidermike
              Spidermike
              @haselchen sagte in ioBroker extrem langsam:
              @spidermike
              und wie geht das ?
                Spidermike
                schrieb am zuletzt editiert von Spidermike
                hab ich jetzt gemacht und wie kann ich schauen ob es geklappt hat?
                • S Spidermike
                  @spidermike
                  und wie geht das ?
                  @spidermike
                  sudo apt update
                  sudo apt full-upgrade
                    @spidermike
                    sudo apt update
                    Spidermike
                    jetzt hab ich mal
                    "sudo reboot" gemacht
                    und bekomme jetzt diese Fehlermeldungen im Protokoll
                    admin.0
                    	2023-10-15 21:29:59.173	info	<== Disconnect system.user.admin from ::ffff:192.168.178.20 javascript
                    host.raspberrypi4-iobroker
                    	2023-10-15 21:29:59.118	info	instance system.adapter.rpi2.0 started with pid 1191
                    admin.0
                    admin.0
                    admin.0
                    admin.0
                    smartthings.0
                    	2023-10-15 21:28:52.523	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.powerConsumptionReport.powerConsumption.value {"energy":1385000,"deltaEnergy":0,"power":18,"powerEnergy":796.4271791658799,"persistedEnergy":0,"energySaved":0,"start":"2023-10-01T16:44:55Z","end":"2023-10-02T16:52:57Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.522	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.523	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.522	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.audioVolume.volume {"value":1,"unit":"%","timestamp":"2022-08-28T16:55:08.492Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.521	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.waterFilter.waterFilterUsage {"value":0,"timestamp":"2023-08-23T13:22:35.380Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.521	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.520	error	Error: DB closed
                    smartthings.0
                    smartthings.0
                    	2023-10-15 21:28:52.519	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.temperatureMeasurement.temperature {"value":18,"unit":"C","timestamp":"2023-10-02T16:52:58.244Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.519	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.mnml {"value":"http://www.samsung.com","timestamp":"2020-04-08T03:47:32.225Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.520	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.icemaker-02.switch.switch {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.518	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.519	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.518	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModes.value.Natürlich "Natürlich"
                    smartthings.0
                    	2023-10-15 21:28:52.517	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModes.value.Film "Film"
                    smartthings.0
                    	2023-10-15 21:28:52.517	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.sec.wifiConfiguration.supportedAuthType.value.WPA2-PSK "WPA2-PSK"
                    smartthings.0
                    	2023-10-15 21:28:52.516	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.517	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:53.621	error	Caught by controller[0]: at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                    smartthings.0
                    	2023-10-15 21:28:52.516	error	Cannot extract array d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap
                    smartthings.0
                    	2023-10-15 21:28:52.515	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.fridgeMode.fridgeModeValue {"value":""}
                    	2023-10-15 21:28:53.621	error	Caught by controller[0]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                    smartthings.0
                    	2023-10-15 21:28:52.514	error	Error: DB closed
                    smartthings.0
                    smartthings.0
                    	2023-10-15 21:28:52.515	error	Error: DB closed
                    	2023-10-15 21:28:53.620	error	Caught by controller[0]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                    smartthings.0
                    	2023-10-15 21:28:52.513	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.sec.diagnosticsInformation.signinPermission {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.514	error	Cannot extract array d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap
                    	2023-10-15 21:28:53.620	error	Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                    smartthings.0
                    	2023-10-15 21:28:52.513	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.512	error	Error: DB closed
                    	2023-10-15 21:28:53.620	error	Caught by controller[0]: Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.511	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.temperatureMeasurement.temperature {"value":18,"unit":"C","timestamp":"2023-10-02T16:52:58.244Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.511	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.mnpv {"value":"Tizen 4.0","timestamp":"2020-04-08T03:47:32.225Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.512	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.mnpv {"value":"Tizen 4.0","timestamp":"2020-04-08T03:47:32.225Z"}
                    	2023-10-15 21:28:53.620	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    smartthings.0
                    	2023-10-15 21:28:52.510	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.511	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.510	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cooler.custom.thermostatSetpointControl.minimumSetpoint {"value":1,"unit":"C","timestamp":"2023-02-12T10:51:16.092Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.509	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.508	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.507	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.temperatureMeasurement.temperature {"value":18,"unit":"C","timestamp":"2023-10-02T16:52:58.244Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.508	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.dmv {"value":"res.1.1.0,sh.1.1.0","timestamp":"2020-04-08T03:47:32.225Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.507	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.506	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.505	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.execute.data.value.payload {"rt":["x.com.samsung.tv.deviceinfo"],"if":["oic.if.baseline","oic.if.r"],"x.com.samsung.country":"GERMANY","x.com.samsung.infolinkversion":"T-INFOLINK2018-1013","x.com.samsung.modelid":"18_KANTM2_QTV","x.com.samsung.tv.ambientsupport":true,"x.com.samsung.tv.blemac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.btmac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.category":"tv","x.com.samsung.tv.countrycode":"DE","x.com.samsung.tv.ethmac":"fc:03:9f:a3:82:1c","x.com.samsung.tv.onsupport":true,"x.com.samsung.tv.p2pmac":"fe:03:9f:58:c9:b5","x.com.samsung.tv.paneltime":57281,"x.com.samsung.tv.sn":"0E6B3HEKB00847R","x.com.samsung.tv.swmodel":"QNQ9F","x.com.samsung.tv.thingversion":"2.4.0","x.com.samsung.tv.ttxsupport":false,"x.com.samsung.tv.udn":"abb0b0b1-4f1b-4336-8882-a927118b269b","x.com.samsung.tv.wifimac":"fc:03:9f:58:c9:b5"}
                    smartthings.0
                    	2023-10-15 21:28:52.506	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.deviceIdentification.binaryId {"value":"23K_REF_LCD_FHUB8.0","timestamp":"2023-10-02T16:52:58.063Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.505	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.504	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.503	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.n {"value":"[refrigerator] Samsung (LCD)","timestamp":"2023-09-05T09:48:57.735Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.504	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.energyType.supportedEnergySavingLevels {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.503	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.502	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.fridgeMode.fridgeMode {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.501	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cooler.thermostatCoolingSetpoint.coolingSetpoint {"value":3,"unit":"C","timestamp":"2023-08-23T20:04:06.005Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.500	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.501	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.500	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.vid {"value":"VD-STV_2018_K","timestamp":"2020-04-08T03:47:32.225Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.499	error	Cannot extract array d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap
                    smartthings.0
                    	2023-10-15 21:28:52.498	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.499	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.498	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.viewInside.lastUpdatedTime {"value":"2023-10-02T16:52:54Z","timestamp":"2023-10-02T16:52:58.187Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.497	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.execute.data.value.payload {"rt":["x.com.samsung.tv.deviceinfo"],"if":["oic.if.baseline","oic.if.r"],"x.com.samsung.country":"GERMANY","x.com.samsung.infolinkversion":"T-INFOLINK2018-1013","x.com.samsung.modelid":"18_KANTM2_QTV","x.com.samsung.tv.ambientsupport":true,"x.com.samsung.tv.blemac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.btmac":"FC:03:9F:58:C9:B6","x.com.samsung.tv.category":"tv","x.com.samsung.tv.countrycode":"DE","x.com.samsung.tv.ethmac":"fc:03:9f:a3:82:1c","x.com.samsung.tv.onsupport":true,"x.com.samsung.tv.p2pmac":"fe:03:9f:58:c9:b5","x.com.samsung.tv.paneltime":57281,"x.com.samsung.tv.sn":"0E6B3HEKB00847R","x.com.samsung.tv.swmodel":"QNQ9F","x.com.samsung.tv.thingversion":"2.4.0","x.com.samsung.tv.ttxsupport":false,"x.com.samsung.tv.udn":"abb0b0b1-4f1b-4336-8882-a927118b269b","x.com.samsung.tv.wifimac":"fc:03:9f:58:c9:b5"}
                    smartthings.0
                    	2023-10-15 21:28:52.496	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.497	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.496	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.fridgeMode.fridgeModeValue {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.495	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.ocf.icv {"value":"core.1.1.0","timestamp":"2020-04-08T03:47:32.225Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.494	error	Error: DB closed
                    smartthings.0
                    smartthings.0
                    	2023-10-15 21:28:52.495	error	Error: DB closed
                    	2023-10-15 21:28:52.981	error	Caught by controller[0]: at TCP.<anonymous> (node:net:350:12)
                    smartthings.0
                    	2023-10-15 21:28:52.493	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.energyType.energySavingSupport {"value":false,"timestamp":"2023-02-12T10:51:16.400Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.493	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cvroom.custom.fridgeMode.fridgeModeValue {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.494	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.freezer.custom.thermostatSetpointControl.maximumSetpoint {"value":-15,"unit":"C","timestamp":"2023-02-12T10:51:16.092Z"}
                    	2023-10-15 21:28:52.981	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                    smartthings.0
                    	2023-10-15 21:28:52.492	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.493	error	Error: DB closed
                    	2023-10-15 21:28:52.980	error	Caught by controller[0]: at Socket.emit (node:events:517:28)
                    smartthings.0
                    	2023-10-15 21:28:52.491	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.error.error {"value":"","timestamp":"2020-10-16T19:24:39.390Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.491	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.viewInside.contents.e67bbc40-f9aa-949b-1e0a-6184228169f4 {"fileId":"e67bbc40-f9aa-949b-1e0a-6184228169f4","mimeType":"image/jpeg","expiredTime":"2023-08-28T15:02:06Z"}
                    	2023-10-15 21:28:52.980	error	Caught by controller[0]: at Object.onceWrapper (node:events:632:26)
                    smartthings.0
                    	2023-10-15 21:28:52.490	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.491	error	Error: DB closed
                    	2023-10-15 21:28:52.980	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                    smartthings.0
                    	2023-10-15 21:28:52.490	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.execute.data.value.payload.rt.x.com.samsung.tv.deviceinfo "x.com.samsung.tv.deviceinfo"
                    smartthings.0
                    	2023-10-15 21:28:52.489	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.samsungce.viewInside.contents.e67bbc40-f9aa-949b-1e0a-6184228169f4 {"fileId":"e67bbc40-f9aa-949b-1e0a-6184228169f4","mimeType":"image/jpeg","expiredTime":"2023-08-28T15:02:06Z"}
                    	2023-10-15 21:28:52.980	error	Caught by controller[0]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                    smartthings.0
                    	2023-10-15 21:28:52.488	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.489	error	Error: DB closed
                    	2023-10-15 21:28:52.980	error	Caught by controller[0]: Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.488	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.cvroom.custom.fridgeMode.fridgeMode {"value":""}
                    smartthings.0
                    	2023-10-15 21:28:52.487	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.pi {"value":"fd9e8b42-11df-2073-6607-17d0ab099f3a","timestamp":"2023-02-12T10:51:16.548Z"}
                    	2023-10-15 21:28:52.979	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    smartthings.0
                    	2023-10-15 21:28:52.487	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.486	error	Error: DB closed
                    smartthings.0
                    smartthings.0
                    	2023-10-15 21:28:52.485	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModes {"value":["Dynamisch","Standard","Natürlich","Film"],"timestamp":"2020-11-21T21:13:41.247Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.486	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.picturemode.supportedPictureModesMap {"value":[{"id":"modeDynamic","name":"Dynamisch"},{"id":"modeStandard","name":"Standard"},{"id":"modeNatural","name":"Natürlich"},{"id":"modeMovie","name":"Film"}],"timestamp":"2020-12-22T23:29:19.098Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.484	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.484	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.sec.wifiConfiguration.supportedAuthType {"value":["OPEN","WEP","WPA-PSK","WPA2-PSK"],"timestamp":"2023-09-05T09:48:57.670Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.483	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.st {"value":"2021-01-01T09:00:40Z","timestamp":"2023-06-18T10:46:31.282Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.483	error	Error: DB closed
                    smartthings.0
                    smartthings.0
                    	2023-10-15 21:28:52.482	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.st {"value":"2021-01-01T09:00:40Z","timestamp":"2023-06-18T10:46:31.282Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.481	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.samsungvd.ambientContent.supportedAmbientApps {"value":[],"timestamp":"2021-01-17T04:57:10.341Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.480	error	Error: DB closed
                    smartthings.0
                    smartthings.0
                    	2023-10-15 21:28:52.481	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.479	error	Error extract keys: d41f95c2-7a28-4d9a-acad-58360616c12f.status.custom.soundmode.soundMode {"value":"Standard","timestamp":"2020-11-21T21:13:41.457Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.480	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.custom.deviceReportStateConfiguration.reportStatePeriod {"value":"enabled","timestamp":"2023-02-12T10:51:16.341Z"}
                    smartthings.0
                    	2023-10-15 21:28:52.479	error	Error: DB closed
                    smartthings.0
                    	2023-10-15 21:28:52.478	error	Error extract keys: fd9e8b42-11df-2073-6607-17d0ab099f3a.status.main.ocf.mnhw {"value":"","timestamp":"2023-09-05T09:48:50.375Z"}
                    und
                    • S Spidermike
                      jetzt hab ich mal
                      admin.0
                      admin.0
                      admin.0
                      admin.0
                      admin.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      smartthings.0
                      und
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @spidermike
                      Was sagt denn jetzt
                      iob diag
                        @spidermike
                        Was sagt denn jetzt
                        iob diag
                        Spidermike
                        iob diag
                        *** BASE SYSTEM ***
                           Static hostname: raspberrypi4-iobroker
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.4
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : armhf
                        Systemuptime and Load:
                         17:52:10 up 20:23,  1 user,  load average: 2.58, 3.55, 3.71
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Mon 2023-10-16 17:52:10 CEST
                                   Universal time: Mon 2023-10-16 15:52:10 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        1.5G        4.6G        0.0K        1.7G        6.2G
                        Swap:            99M          0B         99M
                        Total:          7.9G        1.5G        4.7G
                                 7811 M total memory
                                 1516 M used memory
                                 2222 M active memory
                                  849 M inactive memory
                                 4578 M free memory
                                   86 M buffer memory
                                 1629 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4      118G   23G   90G  21% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
                        tmpfs          tmpfs     1.6G  904K  1.6G   1% /run
                        /dev/sdb1      exfat      29G  2.7G   27G  10% /mnt/usb0
                        /dev/sda1      vfat      253M   51M  202M  20% /boot
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                        [Sun Oct 15 21:29:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:FD:BB:CC vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 console=ttyS0,11520        0 root=PARTUUID=1045efe5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes ro        otwait
                        [Sun Oct 15 21:29:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                        [Sun Oct 15 21:29:11 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                        [Sun Oct 15 21:29:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        TARGET      SOURCE    FSTYPE OPTIONS
                        /           /dev/sda2 ext4   rw,noatime
                        |-/mnt/usb0 /dev/sdb1 exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=00        00,allow_utime=0022,iocharset=utf8,errors=remount-ro
                        `-/boot     /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioch        arset=ascii,shortname=mixed,flush,errors=remount-ro
                        /var:
                        4.9G    /var/
                        3.9G    /var/log
                        3.7G    /var/log/journal/ceda8666c83a44189d7d8b22875c3095
                        502M    /var/lib
                        Archived and active journals take up 3.6G in the file system.
                        /opt/iobroker/backups:
                        6.2G    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        899M    /opt/iobroker/iobroker-data/
                        430M    /opt/iobroker/iobroker-data/history
                        324M    /opt/iobroker/iobroker-data/files
                        85M     /opt/iobroker/iobroker-data/backup-objects
                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                        25M     /opt/iobroker/iobroker-data/states.jsonl
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m        ap
                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.m        ap
                        11M     /opt/iobroker/iobroker-data/objects.json.broken
                        USB-Devices by-id:
                        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                        find: '/dev/serial/by-id/': No such file or directory
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.18.2
                        /usr/bin/node           v18.18.2
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        /usr/bin/corepack       0.19.0
                        nodejs:
                          Installed: 18.18.2-1nodesource1
                          Candidate: 18.18.2-1nodesource1
                          Version table:
                         *** 18.18.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.12
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapters from github:   3
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspberrypi4-iobroker                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.backitup.0               : backitup              : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iobroker                    -  enabled
                          system.adapter.devices.0                : devices               : raspberrypi4-iobroker                    - disabled
                        + system.adapter.discovery.0              : discovery             : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.energiefluss.1           : energiefluss          : raspberrypi4-iobroker                    -  enabled
                          system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi4-iobroker                    - disabled
                          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4-iobroker                    - disabled
                        + system.adapter.growatt.0                : growatt               : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.history.0                : history               : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.hs100.0                  : hs100                 : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.info.0                   : info                  : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.iot.0                    : iot                   : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.javascript.0             : javascript            : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iobroker                    -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.plenticore.0             : plenticore            : raspberrypi4-iobroker                    -  enabled, port: 80
                        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi4-iobroker                    -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.smartthings.0            : smartthings           : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.telegram.0               : telegram              : raspberrypi4-iobroker                    -  enabled, port: 8443, bind: 0.0.0.0
                          system.adapter.tuya.0                   : tuya                  : raspberrypi4-iobroker                    - disabled
                          system.adapter.vis.0                    : vis                   : raspberrypi4-iobroker                    - disabled
                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4-iobroker                    -  enabled
                        + system.adapter.web.0                    : web                   : raspberrypi4-iobroker                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.wled.0                   : wled                  : raspberrypi4-iobroker                    -  enabled
                          system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iobroker                    - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2414409-if00
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.10.1   , installed 6.10.1
                        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                        Adapter    "devices"      : 1.1.5    , installed 1.1.5
                        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                        Adapter    "growatt"      : 3.2.1    , installed 3.2.1
                        Adapter    "history"      : 2.2.6    , installed 2.2.6
                        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Controller "js-controller": 5.0.12   , installed 5.0.12
                        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                        Adapter    "plenticore"   : 2.2.0    , installed 2.3.1
                        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                        Adapter    "web"          : 6.1.2    , installed 6.1.2
                        Adapter    "wled"         : 0.7.1    , installed 0.7.1
                        Adapter    "ws"           : 2.5.5    , installed 2.5.5
                        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                        Objects and States
                        Objects:        8968
                        States:         16359
                        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                        W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                        W: Some index files failed to download. They have been ignored, or old ones used instead.
                        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Get:4 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Err:4 https://repos.influxdata.com/debian bullseye InRelease
                        Fetched 7040 B in 2s (3908 B/s)
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12652      427/influxd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        15421      577/mosquitto
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12965      776/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16684      776/iobroker.js-con
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13913      574/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          15457      422/python
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        12825      427/influxd
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21903      1679/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14290      1089/io.admin.0
                        tcp6       0      0 :::1883                 :::*                    LISTEN      110        15422      577/mosquitto
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13915      574/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13979      484/dhcpcd
                        udp        0      0 0.0.0.0:49382           0.0.0.0:*                           108        13746      399/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19160      1888/io.wled.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13744      399/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17601      1247/io.shelly.0
                        udp6       0      0 :::546                  :::*                                0          15323      484/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        13745      399/avahi-daemon: r
                        udp6       0      0 :::55835                :::*                                108        13747      399/avahi-daemon: r
                        2023-10-16 17:50:37.856  - info: admin.0 (1089) Subscribe to all states again
                        2023-10-16 17:50:40.956  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                        2023-10-16 17:51:39.536  - error: host.raspberrypi4-iobroker Caught by controller[0]: <--- Last few GCs --->
                        2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: [32592:0x54af008] 39717362 ms: Scavenge 908.4 (1045.2) -> 907.7 (1045.2) MB, 10.5 / 0.0 ms  (average mu = 0.912, current mu = 0.956) allocation failure;
                        2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: [32592:0x54af008] 39717425 ms: Scavenge 908.8 (1045.2) -> 908.2 (1045.2) MB, 10.3 / 0.0 ms  (average mu = 0.912, current mu = 0.956) allocation failure;
                        2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: [32592:0x54af008] 39717454 ms: Scavenge 909.5 (1045.2) -> 909.4 (1049.2) MB, 24.8 / 0.0 ms  (average mu = 0.912, current mu = 0.956) allocation failure;
                        2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: <--- JS stacktrace --->
                        2023-10-16 17:51:39.538  - error: host.raspberrypi4-iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                        2023-10-16 17:51:39.539  - warn: host.raspberrypi4-iobroker instance system.adapter.smartthings.0 terminated due to SIGABRT
                        2023-10-16 17:51:39.539  - info: host.raspberrypi4-iobroker instance system.adapter.smartthings.0 terminated with code null ()
                        2023-10-16 17:51:39.539  - info: host.raspberrypi4-iobroker Restart adapter system.adapter.smartthings.0 because enabled
                        2023-10-16 17:51:41.875  - info: admin.0 (1089) Subscribe to all states again
                        2023-10-16 17:51:44.975  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                        2023-10-16 17:52:06.891  - info: weatherunderground.0 (30819) Terminated (NO_ERROR): Without reason
                        2023-10-16 17:52:07.426  - info: host.raspberrypi4-iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                        2023-10-16 17:52:09.657  - info: host.raspberrypi4-iobroker instance system.adapter.smartthings.0 started with pid 5069
                        2023-10-16 17:52:13.567  - info: smartthings.0 (5069) starting. Version 0.0.4 (non-npm: TA2k/ioBroker.smartthings#2f3c7e70f203e4c904dba0d692a387e1c44d7bbe) in /opt/iobroker/node_modules/iobroker.smartthings, node: v18.18.2, js-controller: 5.0.12
                        2023-10-16 17:52:13.618  - info: smartthings.0 (5069) Set interval to minimum 1
                        2023-10-16 17:52:14.363  - info: smartthings.0 (5069) 4 devices detected
                        2023-10-16 17:52:45.899  - info: admin.0 (1089) Subscribe to all states again
                        2023-10-16 17:52:49.000  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                        2023-10-16 17:52:54.129  - info: alexa2.0 (1159) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-10-16 17:52:55.811  - info: alexa2.0 (1159) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-10-16 17:53:49.341  - info: admin.0 (1089) Subscribe to all states again
                        2023-10-16 17:53:53.486  - info: admin.0 (1089) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                        DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                        • S Spidermike
                          iob diag
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7811 M total memory
                                   1516 M used memory
                                   4578 M free memory
                                     86 M buffer memory
                                   1629 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          4.9G    /var/
                          3.9G    /var/log
                          502M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.10.1
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        8968
                          States:         16359
                          Pending Updates: 0
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @spidermike setz das ganze bitte in Codetags - dann kann man das besser lesen ;)
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            Spidermike
                            @djmarc75 sagte in ioBroker extrem langsam:
                            jetzt besser habs geändert
                            • S Spidermike
                              iob diag
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7811 M total memory
                                       1516 M used memory
                                       4578 M free memory
                                         86 M buffer memory
                                       1629 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              4.9G    /var/
                              3.9G    /var/log
                              502M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        8968
                              States:         16359
                              Pending Updates: 0
                              Da musst du ran.
                              Es muss ein neuer Schlüssel installiert werden.
                                Da musst du ran.
                                Spidermike
                                #66
                                Da musst du ran.
                                ich dachte das hab ich gestern gemacht
                                kannst Du mir nochmal sagen wie genau das geht
                                • S Spidermike
                                  Da musst du ran.
                                  #67
                                  @spidermike
                                  wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                  echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                  echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                    @spidermike
                                    Spidermike
                                    #68
                                    pi@raspberrypi4-iobroker:~ $ wget -q https://repos.influxdata.com/influxdata-arc        hive_compat.key
                                    pi@raspberrypi4-iobroker:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133fadd        af92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxd        ata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata        -archive_compat.gpg > /dev/null
                                    influxdata-archive_compat.key: OK
                                    pi@raspberrypi4-iobroker:~ $ echo 'deb [signed-by=/usr/share/keyrings/influxdata        -archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee        /etc/apt/sources.list.d/influxdata.list
                                    deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.        influxdata.com/debian stable main
                                    ist das korrekt gelaufen?
                                    • S Spidermike
                                      #69
                                      Das siehst du, wenn du dein System wie üblich aktuell hältst...
                                      sudo apt update
                                      Bitte verwende puTTY im Vollbild (oder gleich ein besseres Terminal)
                                        sudo apt update
                                        Spidermike
                                        #70
                                        pi@raspberrypi4-iobroker:~ $ sudo apt update
                                        OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Holen:4 https://repos.influxdata.com/debian stable InRelease [6.892 B]
                                        Holen:5 https://repos.influxdata.com/debian bullseye InRelease [7.040 B]
                                        OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Holen:7 https://repos.influxdata.com/debian stable/main armhf Packages [3.417 B]
                                        Fehl:5 https://repos.influxdata.com/debian bullseye InRelease
                                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                        Es wurden 17,3 kB in 2 s geholt (9.321 B/s).
                                        Alle Pakete sind aktuell.
                                        W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                        W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/bullseye/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                        W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                        OK:4 https://repos.influxdata.com/debian stable InRelease
                                        Es wurden 7.040 B in 2 s geholt (3.996 B/s).
                                        der Fehler ist immer noch
                                        • S Spidermike
                                          #71
                                          @spidermike
                                          ls -lAh /etc/apt/sources.list.d/
                                          wird dir zwei Dateien zu influx auflisten. Lösche die, die nicht influxdata.list heißt.
